    4. Test Adapter pegelalarm v0.0.1-x
    • simatec
      simatec Developer Most Active @sigi234 last edited by
      @sigi234 @Negalein
      Stellt den Log mal bitte auch auf debug und beobachtet, ob alle Request richtig durchlaufen.
      Debug gibt da einige Infos raus.
      Negalein sigi234 2 Replies Last reply Reply Quote 0
      • Negalein
        Negalein Global Moderator @simatec last edited by
        @simatec sagte in Test Adapter pegelalarm v0.0.1-x:
        2021-04-02 14:52:00.098  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 15862
        2021-04-02 14:52:01.006  - debug: pegelalarm.1 (15862) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2021-04-02 14:52:01.116  - debug: pegelalarm.1 (15862) Objects client ready ... initialize now
        2021-04-02 14:52:01.150  - debug: pegelalarm.1 (15862) Objects create System PubSub Client
        2021-04-02 14:52:01.155  - debug: pegelalarm.1 (15862) Objects create User PubSub Client
        2021-04-02 14:52:01.157  - debug: pegelalarm.1 (15862) Objects client initialize lua scripts
        2021-04-02 14:52:01.228  - debug: pegelalarm.1 (15862) Objects connected to redis: 0.0.0.0:9001
        2021-04-02 14:52:01.243  - debug: pegelalarm.1 (15862) objectDB connected
        2021-04-02 14:52:01.246  - debug: pegelalarm.1 (15862) Redis States: Use Redis connection: 0.0.0.0:9000
        2021-04-02 14:52:01.283  - debug: pegelalarm.1 (15862) States create User PubSub Client
        2021-04-02 14:52:01.298  - debug: pegelalarm.1 (15862) States create System PubSub Client
        2021-04-02 14:52:01.690  - debug: pegelalarm.1 (15862) States connected to redis: 0.0.0.0:9000
        2021-04-02 14:52:01.691  - debug: pegelalarm.1 (15862) statesDB connected
        2021-04-02 14:52:03.625  - info: pegelalarm.1 (15862) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
        2021-04-02 14:52:03.655  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is started ...
        2021-04-02 14:52:03.658  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
        2021-04-02 14:52:03.904  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
        2021-04-02 14:52:06.046  - debug: pegelalarm.1 (15862) Pegelalarm request done
        2021-04-02 14:52:06.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is finish ...
        2021-04-02 14:52:07.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is started ...
        2021-04-02 14:52:07.048  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
        2021-04-02 14:52:07.396  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
        2021-04-02 14:52:09.532  - debug: pegelalarm.1 (15862) Pegelalarm request done
        2021-04-02 14:52:09.533  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is finish ...
        2021-04-02 14:52:12.536  - debug: pegelalarm.1 (15862) Pegelalarm Request is completed
        2021-04-02 14:52:17.538  - debug: pegelalarm.1 (15862) Check for deleting old objects is started
        2021-04-02 14:52:37.542  - debug: pegelalarm.1 (15862) cleaned everything up...
        2021-04-02 14:52:37.681  - info: pegelalarm.1 (15862) Terminated (NO_ERROR): Without reason
        2021-04-02 14:52:38.191  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
        2021-04-02 15:00:08.440  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 27391
        2021-04-02 15:00:09.420  - debug: pegelalarm.1 (27391) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2021-04-02 15:00:09.547  - debug: pegelalarm.1 (27391) Objects client ready ... initialize now
        2021-04-02 15:00:09.558  - debug: pegelalarm.1 (27391) Objects create System PubSub Client
        2021-04-02 15:00:09.561  - debug: pegelalarm.1 (27391) Objects create User PubSub Client
        2021-04-02 15:00:09.562  - debug: pegelalarm.1 (27391) Objects client initialize lua scripts
        2021-04-02 15:00:09.624  - debug: pegelalarm.1 (27391) Objects connected to redis: 0.0.0.0:9001
        2021-04-02 15:00:09.681  - debug: pegelalarm.1 (27391) objectDB connected
        2021-04-02 15:00:09.683  - debug: pegelalarm.1 (27391) Redis States: Use Redis connection: 0.0.0.0:9000
        2021-04-02 15:00:09.709  - debug: pegelalarm.1 (27391) States create User PubSub Client
        2021-04-02 15:00:09.717  - debug: pegelalarm.1 (27391) States create System PubSub Client
        2021-04-02 15:00:09.809  - debug: pegelalarm.1 (27391) States connected to redis: 0.0.0.0:9000
        2021-04-02 15:00:09.811  - debug: pegelalarm.1 (27391) statesDB connected
        2021-04-02 15:00:11.230  - info: pegelalarm.1 (27391) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
        2021-04-02 15:00:11.290  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is started ...
        2021-04-02 15:00:11.295  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
        2021-04-02 15:00:11.521  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
        2021-04-02 15:00:12.526  - info: host.iobroker instance system.adapter.pegelalarm.0 started with pid 27460
        2021-04-02 15:00:13.387  - debug: pegelalarm.0 (27460) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2021-04-02 15:00:13.437  - debug: pegelalarm.0 (27460) Objects client ready ... initialize now
        2021-04-02 15:00:13.484  - debug: pegelalarm.0 (27460) Objects create System PubSub Client
        2021-04-02 15:00:13.486  - debug: pegelalarm.0 (27460) Objects create User PubSub Client
        2021-04-02 15:00:13.489  - debug: pegelalarm.0 (27460) Objects client initialize lua scripts
        2021-04-02 15:00:13.571  - debug: pegelalarm.0 (27460) Objects connected to redis: 0.0.0.0:9001
        2021-04-02 15:00:13.591  - debug: pegelalarm.0 (27460) objectDB connected
        2021-04-02 15:00:13.593  - debug: pegelalarm.0 (27460) Redis States: Use Redis connection: 0.0.0.0:9000
        2021-04-02 15:00:13.618  - debug: pegelalarm.0 (27460) States create User PubSub Client
        2021-04-02 15:00:13.621  - debug: pegelalarm.0 (27460) States create System PubSub Client
        2021-04-02 15:00:13.671  - debug: pegelalarm.0 (27460) States connected to redis: 0.0.0.0:9000
        2021-04-02 15:00:13.674  - debug: pegelalarm.0 (27460) statesDB connected
        2021-04-02 15:00:13.682  - debug: pegelalarm.1 (27391) Pegelalarm request done
        2021-04-02 15:00:13.683  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is finish ...
        2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is started ...
        2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
        2021-04-02 15:00:14.912  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
        2021-04-02 15:00:15.946  - info: pegelalarm.0 (27460) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
        2021-04-02 15:00:15.966  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is started ...
        2021-04-02 15:00:15.968  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Inn&qStationName=Sch%C3%A4rding
        2021-04-02 15:00:16.261  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
        2021-04-02 15:00:17.098  - debug: pegelalarm.1 (27391) Pegelalarm request done
        2021-04-02 15:00:17.099  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is finish ...
        2021-04-02 15:00:18.420  - debug: pegelalarm.0 (27460) Pegelalarm request done
        2021-04-02 15:00:18.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is finish ...
        2021-04-02 15:00:19.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is started ...
        2021-04-02 15:00:19.422  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Pram&qStationName=Pramerdorf
        2021-04-02 15:00:19.627  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
        2021-04-02 15:00:20.102  - debug: pegelalarm.1 (27391) Pegelalarm Request is completed
        2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request done
        2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is finish ...
        2021-04-02 15:00:24.764  - debug: pegelalarm.0 (27460) Pegelalarm Request is completed
        2021-04-02 15:00:25.104  - debug: pegelalarm.1 (27391) Check for deleting old objects is started
        2021-04-02 15:00:29.765  - debug: pegelalarm.0 (27460) Check for deleting old objects is started
        2021-04-02 15:00:45.109  - debug: pegelalarm.1 (27391) cleaned everything up...
        2021-04-02 15:00:45.167  - info: pegelalarm.1 (27391) Terminated (NO_ERROR): Without reason
        2021-04-02 15:00:45.679  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
        2021-04-02 15:00:49.771  - debug: pegelalarm.0 (27460) cleaned everything up...
        2021-04-02 15:00:49.797  - info: pegelalarm.0 (27460) Terminated (NO_ERROR): Without reason
        2021-04-02 15:00:50.307  - info: host.iobroker instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
          sigi234 Forum Testing Most Active @simatec last edited by
          @simatec
          pegelalarm.0	2021-04-02 15:18:13.280	info	(2420) Terminated (NO_ERROR): Without reason
          pegelalarm.0	2021-04-02 15:18:13.277	debug	(2420) cleaned everything up...
          pegelalarm.0	2021-04-02 15:17:53.261	debug	(2420) Check for deleting old objects is started
          pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm Request is completed
          pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request for measuring station 5 is finish ...
          pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request done
          pegelalarm.0	2021-04-02 15:17:48.135	debug	(2420) Pegelalarm API is available ... Status: 200
          pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems&qStationName=Kematen%20An%20Der%20Krems
          pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) Pegelalarm request for measuring station 5 is started ...
          pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request for measuring station 4 is finish ...
          pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request done
          pegelalarm.0	2021-04-02 15:17:30.363	debug	(2420) Pegelalarm API is available ... Status: 200
          pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Traun
          pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) Pegelalarm request for measuring station 4 is started ...
          pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request for measuring station 3 is finish ...
          pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request done
          pegelalarm.0	2021-04-02 15:17:18.896	debug	(2420) Pegelalarm API is available ... Status: 200
          pegelalarm.0	2021-04-02 15:17:18.781	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Steyr
          pegelalarm.0	2021-04-02 15:17:18.780	debug	(2420) Pegelalarm request for measuring station 3 is started ...
          pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request for measuring station 2 is finish ...
          pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request done
          pegelalarm.0	2021-04-02 15:17:05.406	debug	(2420) Pegelalarm API is available ... Status: 200
          pegelalarm.0	2021-04-02 15:17:05.283	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Donau
          pegelalarm.0	2021-04-02 15:17:05.282	debug	(2420) Pegelalarm request for measuring station 2 is started ...
          pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request for measuring station 1 is finish ...
          pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request done
          pegelalarm.0	2021-04-02 15:16:57.927	debug	(2420) Pegelalarm API is available ... Status: 200
          pegelalarm.0	2021-04-02 15:16:57.765	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems
          pegelalarm.0	2021-04-02 15:16:57.764	debug	(2420) Pegelalarm request for measuring station 1 is started ...
          pegelalarm.0	2021-04-02 15:16:57.757	info	(2420) starting. Version 1.1.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.pegelalarm, node: v12.21.0, js-controller: 3.2.16
          • simatec
            @sigi234 @Negalein
            Sieht gut aus ...
            @Negalein
            Ich würde die Instanzen etwas zeitversetzt fahren, damit es nicht zu eventuellen Request Fehlern kommt.
            • Negalein
              mach ich bereits seit Anfang an 🙂
                Ich denke man brauch die API nicht alle 15 Min. abrufen, eigentlich nur wenn eine Warnung gibt. Was denk Ihr?
                simatec Negalein 2 Replies Last reply Reply Quote 0
                • simatec
                  @sigi234
                  Ich denke auch, dass einmal die Stunde reichen sollte
                  • Negalein
                    Negalein Global Moderator @sigi234 last edited by
                    @sigi234 sagte in Test Adapter pegelalarm v0.0.1-x:
                    Was denk Ihr?
                    Ja, das würde sicher reichen.
                    Cool wäre es, wenn der Adapter erkennt das eine Warnung da ist und dann selbsständig den Cron auf zB 15 Min. verändert. Wenn Warnung wieder weg, dann Cron wieder auf 60 Min.!
                    Aber ob das vom Adapter möglich ist?
                    • simatec
                      Hier die Version 1.1.5 zum testen auf Github
                      Github: https://github.com/simatec/ioBroker.pegelalarm.git
                      Changelog
                      1.1.5 (2021-04-07)
                      • (simatec) fetch added
                      • (simatec) sentry added
                      Latzi Negalein 2 Replies Last reply Reply Quote 0
                      • Latzi
                        Latzi @simatec last edited by
                        @simatec
                        👍 läuft!
                        • Negalein
                          • simatec
                            So die Version 1.1.7 ist nun im latest ..
                            Hier gehts weiter 😉
                            31.7k
                            79.8k
                            adapter fluss gewässer hochwasser hochwasser adapter pegelalarm
                            10
                            95
                            7020
