    4. Test Adapter pegelalarm v0.0.1-x
    • Negalein
      Negalein Global Moderator @simatec last edited by
      @simatec sagte in Test Adapter pegelalarm v0.0.1-x:
      Stellt den Log mal bitte auch auf debug
      2021-04-02 14:52:00.098  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 15862
      2021-04-02 14:52:01.006  - debug: pegelalarm.1 (15862) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2021-04-02 14:52:01.116  - debug: pegelalarm.1 (15862) Objects client ready ... initialize now
      2021-04-02 14:52:01.150  - debug: pegelalarm.1 (15862) Objects create System PubSub Client
      2021-04-02 14:52:01.155  - debug: pegelalarm.1 (15862) Objects create User PubSub Client
      2021-04-02 14:52:01.157  - debug: pegelalarm.1 (15862) Objects client initialize lua scripts
      2021-04-02 14:52:01.228  - debug: pegelalarm.1 (15862) Objects connected to redis: 0.0.0.0:9001
      2021-04-02 14:52:01.243  - debug: pegelalarm.1 (15862) objectDB connected
      2021-04-02 14:52:01.246  - debug: pegelalarm.1 (15862) Redis States: Use Redis connection: 0.0.0.0:9000
      2021-04-02 14:52:01.283  - debug: pegelalarm.1 (15862) States create User PubSub Client
      2021-04-02 14:52:01.298  - debug: pegelalarm.1 (15862) States create System PubSub Client
      2021-04-02 14:52:01.690  - debug: pegelalarm.1 (15862) States connected to redis: 0.0.0.0:9000
      2021-04-02 14:52:01.691  - debug: pegelalarm.1 (15862) statesDB connected
      2021-04-02 14:52:03.625  - info: pegelalarm.1 (15862) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
      2021-04-02 14:52:03.655  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is started ...
      2021-04-02 14:52:03.658  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
      2021-04-02 14:52:03.904  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
      2021-04-02 14:52:06.046  - debug: pegelalarm.1 (15862) Pegelalarm request done
      2021-04-02 14:52:06.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is finish ...
      2021-04-02 14:52:07.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is started ...
      2021-04-02 14:52:07.048  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
      2021-04-02 14:52:07.396  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
      2021-04-02 14:52:09.532  - debug: pegelalarm.1 (15862) Pegelalarm request done
      2021-04-02 14:52:09.533  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is finish ...
      2021-04-02 14:52:12.536  - debug: pegelalarm.1 (15862) Pegelalarm Request is completed
      2021-04-02 14:52:17.538  - debug: pegelalarm.1 (15862) Check for deleting old objects is started
      2021-04-02 14:52:37.542  - debug: pegelalarm.1 (15862) cleaned everything up...
      2021-04-02 14:52:37.681  - info: pegelalarm.1 (15862) Terminated (NO_ERROR): Without reason
      2021-04-02 14:52:38.191  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
      2021-04-02 15:00:08.440  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 27391
      2021-04-02 15:00:09.420  - debug: pegelalarm.1 (27391) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2021-04-02 15:00:09.547  - debug: pegelalarm.1 (27391) Objects client ready ... initialize now
      2021-04-02 15:00:09.558  - debug: pegelalarm.1 (27391) Objects create System PubSub Client
      2021-04-02 15:00:09.561  - debug: pegelalarm.1 (27391) Objects create User PubSub Client
      2021-04-02 15:00:09.562  - debug: pegelalarm.1 (27391) Objects client initialize lua scripts
      2021-04-02 15:00:09.624  - debug: pegelalarm.1 (27391) Objects connected to redis: 0.0.0.0:9001
      2021-04-02 15:00:09.681  - debug: pegelalarm.1 (27391) objectDB connected
      2021-04-02 15:00:09.683  - debug: pegelalarm.1 (27391) Redis States: Use Redis connection: 0.0.0.0:9000
      2021-04-02 15:00:09.709  - debug: pegelalarm.1 (27391) States create User PubSub Client
      2021-04-02 15:00:09.717  - debug: pegelalarm.1 (27391) States create System PubSub Client
      2021-04-02 15:00:09.809  - debug: pegelalarm.1 (27391) States connected to redis: 0.0.0.0:9000
      2021-04-02 15:00:09.811  - debug: pegelalarm.1 (27391) statesDB connected
      2021-04-02 15:00:11.230  - info: pegelalarm.1 (27391) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
      2021-04-02 15:00:11.290  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is started ...
      2021-04-02 15:00:11.295  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
      2021-04-02 15:00:11.521  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
      2021-04-02 15:00:12.526  - info: host.iobroker instance system.adapter.pegelalarm.0 started with pid 27460
      2021-04-02 15:00:13.387  - debug: pegelalarm.0 (27460) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2021-04-02 15:00:13.437  - debug: pegelalarm.0 (27460) Objects client ready ... initialize now
      2021-04-02 15:00:13.484  - debug: pegelalarm.0 (27460) Objects create System PubSub Client
      2021-04-02 15:00:13.486  - debug: pegelalarm.0 (27460) Objects create User PubSub Client
      2021-04-02 15:00:13.489  - debug: pegelalarm.0 (27460) Objects client initialize lua scripts
      2021-04-02 15:00:13.571  - debug: pegelalarm.0 (27460) Objects connected to redis: 0.0.0.0:9001
      2021-04-02 15:00:13.591  - debug: pegelalarm.0 (27460) objectDB connected
      2021-04-02 15:00:13.593  - debug: pegelalarm.0 (27460) Redis States: Use Redis connection: 0.0.0.0:9000
      2021-04-02 15:00:13.618  - debug: pegelalarm.0 (27460) States create User PubSub Client
      2021-04-02 15:00:13.621  - debug: pegelalarm.0 (27460) States create System PubSub Client
      2021-04-02 15:00:13.671  - debug: pegelalarm.0 (27460) States connected to redis: 0.0.0.0:9000
      2021-04-02 15:00:13.674  - debug: pegelalarm.0 (27460) statesDB connected
      2021-04-02 15:00:13.682  - debug: pegelalarm.1 (27391) Pegelalarm request done
      2021-04-02 15:00:13.683  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is finish ...
      2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is started ...
      2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
      2021-04-02 15:00:14.912  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
      2021-04-02 15:00:15.946  - info: pegelalarm.0 (27460) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
      2021-04-02 15:00:15.966  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is started ...
      2021-04-02 15:00:15.968  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Inn&qStationName=Sch%C3%A4rding
      2021-04-02 15:00:16.261  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
      2021-04-02 15:00:17.098  - debug: pegelalarm.1 (27391) Pegelalarm request done
      2021-04-02 15:00:17.099  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is finish ...
      2021-04-02 15:00:18.420  - debug: pegelalarm.0 (27460) Pegelalarm request done
      2021-04-02 15:00:18.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is finish ...
      2021-04-02 15:00:19.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is started ...
      2021-04-02 15:00:19.422  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Pram&qStationName=Pramerdorf
      2021-04-02 15:00:19.627  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
      2021-04-02 15:00:20.102  - debug: pegelalarm.1 (27391) Pegelalarm Request is completed
      2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request done
      2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is finish ...
      2021-04-02 15:00:24.764  - debug: pegelalarm.0 (27460) Pegelalarm Request is completed
      2021-04-02 15:00:25.104  - debug: pegelalarm.1 (27391) Check for deleting old objects is started
      2021-04-02 15:00:29.765  - debug: pegelalarm.0 (27460) Check for deleting old objects is started
      2021-04-02 15:00:45.109  - debug: pegelalarm.1 (27391) cleaned everything up...
      2021-04-02 15:00:45.167  - info: pegelalarm.1 (27391) Terminated (NO_ERROR): Without reason
      2021-04-02 15:00:45.679  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
      2021-04-02 15:00:49.771  - debug: pegelalarm.0 (27460) cleaned everything up...
      2021-04-02 15:00:49.797  - info: pegelalarm.0 (27460) Terminated (NO_ERROR): Without reason
      2021-04-02 15:00:50.307  - info: host.iobroker instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
        sigi234 Forum Testing Most Active @simatec last edited by
        @simatec
        pegelalarm.0	2021-04-02 15:18:13.280	info	(2420) Terminated (NO_ERROR): Without reason
        pegelalarm.0	2021-04-02 15:18:13.277	debug	(2420) cleaned everything up...
        pegelalarm.0	2021-04-02 15:17:53.261	debug	(2420) Check for deleting old objects is started
        pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm Request is completed
        pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request for measuring station 5 is finish ...
        pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request done
        pegelalarm.0	2021-04-02 15:17:48.135	debug	(2420) Pegelalarm API is available ... Status: 200
        pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems&qStationName=Kematen%20An%20Der%20Krems
        pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) Pegelalarm request for measuring station 5 is started ...
        pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request for measuring station 4 is finish ...
        pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request done
        pegelalarm.0	2021-04-02 15:17:30.363	debug	(2420) Pegelalarm API is available ... Status: 200
        pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Traun
        pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) Pegelalarm request for measuring station 4 is started ...
        pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request for measuring station 3 is finish ...
        pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request done
        pegelalarm.0	2021-04-02 15:17:18.896	debug	(2420) Pegelalarm API is available ... Status: 200
        pegelalarm.0	2021-04-02 15:17:18.781	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Steyr
        pegelalarm.0	2021-04-02 15:17:18.780	debug	(2420) Pegelalarm request for measuring station 3 is started ...
        pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request for measuring station 2 is finish ...
        pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request done
        pegelalarm.0	2021-04-02 15:17:05.406	debug	(2420) Pegelalarm API is available ... Status: 200
        pegelalarm.0	2021-04-02 15:17:05.283	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Donau
        pegelalarm.0	2021-04-02 15:17:05.282	debug	(2420) Pegelalarm request for measuring station 2 is started ...
        pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request for measuring station 1 is finish ...
        pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request done
        pegelalarm.0	2021-04-02 15:16:57.927	debug	(2420) Pegelalarm API is available ... Status: 200
        pegelalarm.0	2021-04-02 15:16:57.765	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems
        pegelalarm.0	2021-04-02 15:16:57.764	debug	(2420) Pegelalarm request for measuring station 1 is started ...
        pegelalarm.0	2021-04-02 15:16:57.757	info	(2420) starting. Version 1.1.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.pegelalarm, node: v12.21.0, js-controller: 3.2.16
        • simatec
          simatec Developer Most Active @sigi234 last edited by
          @sigi234 @Negalein
          Sieht gut aus ...
          @Negalein
          Ich würde die Instanzen etwas zeitversetzt fahren, damit es nicht zu eventuellen Request Fehlern kommt.
          • Negalein
            mach ich bereits seit Anfang an 🙂
              Ich denke man brauch die API nicht alle 15 Min. abrufen, eigentlich nur wenn eine Warnung gibt. Was denk Ihr?
              simatec Negalein 2 Replies Last reply Reply Quote 0
              • simatec
                @sigi234
                Ich denke auch, dass einmal die Stunde reichen sollte
                • Negalein
                  Negalein Global Moderator @sigi234 last edited by
                  @sigi234 sagte in Test Adapter pegelalarm v0.0.1-x:
                  Was denk Ihr?
                  Ja, das würde sicher reichen.
                  Cool wäre es, wenn der Adapter erkennt das eine Warnung da ist und dann selbsständig den Cron auf zB 15 Min. verändert. Wenn Warnung wieder weg, dann Cron wieder auf 60 Min.!
                  Aber ob das vom Adapter möglich ist?
                  • simatec
                    Hier die Version 1.1.5 zum testen auf Github
                    Github: https://github.com/simatec/ioBroker.pegelalarm.git
                    Changelog
                    1.1.5 (2021-04-07)
                    • (simatec) fetch added
                    • (simatec) sentry added
                    Latzi Negalein 2 Replies Last reply Reply Quote 0
                    • Latzi
                      Latzi @simatec last edited by
                      @simatec
                      👍 läuft!
                      • Negalein
                        • simatec
                          So die Version 1.1.7 ist nun im latest ..
                          Hier gehts weiter 😉
                          31.7k
                          79.8k
                          adapter fluss gewässer hochwasser hochwasser adapter pegelalarm
                          10
                          95
                          7020
