    4. MieleCloudService Adapter
    • HomeZecke
      HomeZecke @HomeZecke last edited by
      ok. Jetzt geht's. Musste eine neue Email bei Miele beantragen. Ging auch erst beim dritten Versuch! Scheint als hätten die da ein kleines Problem...
      GRüße...
      • Grizzelbee
        Grizzelbee Developer @MarkA last edited by
        @marka
        Habe gerade ein paar neue Fixes online gestellt:
        V4.0.1 (2021-04-06) (Sign of the cross)
        • (grizzelbee) Fix: 90 setting the targetTemperature should work now.
        • (grizzelbee) Fix: 96 Added missing ACTIONS.Action_Information again
        • (grizzelbee) Fix: 97 removed unneeded additional "VentilationStep/Lüfterstufe" in path and fixed warning with this. VentilationStep-switch should work properly now.
        • (grizzelbee) Fix: 98 Color-Action has now valid type 'String'
        • (grizzelbee) Fix: 102 Fixed ACTIONS.VentilationStep has no existing object
        • (grizzelbee) Fix: Power switch is write protected now when in state 'None'. State 'None' means: No action permitted.
        • (grizzelbee) Fix: Light switch is write protected now when in state 'None'. State 'None' means: No action permitted.
        • (grizzelbee) Fix: http error 404 will be catched when requesting device actions
        M M 2 Replies Last reply Reply Quote 1
          M-A-X @Grizzelbee last edited by M-A-X
          @grizzelbee ich hab mal geupdated von 3.0.2 und bekomme den Adapter nicht mehr grün (nur gelb).
          Muss ich die credentials erneut eingeben? Davon steht nichts im changelog 🙂
          2021-04-06 21:04:43.966 - info: mielecloudservice.0 (31553) starting. Version 4.0.1 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v12.22.0, js-controller: 3.2.16
          2021-04-06 21:04:44.488 - info: mielecloudservice.0 (31553) Access-Token expires at: [Thu May 06 2021 21:04:00 GMT+0200 (GMT+02:00)]
          2021-04-06 21:04:44.491 - info: mielecloudservice.0 (31553) Setting up devices ...
          2021-04-06 21:04:45.079 - error: mielecloudservice.0 (31553) [main] :actions is not defined, Stacktrace:ReferenceError: actions is not defined
          at addMieleDeviceState (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:370:70)
          at processTicksAndRejections (internal/process/task_queues.js:97:5)
          at async addMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:335:17)
          at async parseMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:295:5)
          at async splitMieleDevices (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:273:9)
          at async main (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:647:13)
          Sascha Löbbert 1 Reply Last reply Reply Quote 0
          • Sascha Löbbert
            Sascha Löbbert @M-A-X last edited by
            @m-a-x Jau! Gleiches Problem hier bei mir.
            Grizzelbee 1 Reply Last reply Reply Quote 0
              MarkA @Grizzelbee last edited by MarkA
              Guten Morgen,
              ich habe leider auch das Problem...
              2021-04-07 08:52:32.640 - info: mielecloudservice.0 (37035) starting. Version 4.0.1 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v12.21.0, js-controller: 3.2.16
              2021-04-07 08:52:33.274 - info: mielecloudservice.0 (37035) Access-Token expires at: [Fri May 07 2021 08:52:00 GMT+0200 (GMT+02:00)]
              2021-04-07 08:52:33.278 - info: mielecloudservice.0 (37035) Setting up devices ...
              2021-04-07 08:52:34.084 - error: mielecloudservice.0 (37035) [main] :actions is not defined, Stacktrace:ReferenceError: actions is not defined
              Die Auswahl / DropDown der Ventilationsstufe ist leider leer.
              Gruß Mark
              • Grizzelbee
                Grizzelbee Developer @Sascha Löbbert last edited by Grizzelbee
                @sascha-löbbert , @MarkA, @M-A-X
                Okay. Ich wechsel mal auf die Politik der kleinen Schritte und ändere nur noch wenig pro Release...
                Ich scheine gelegentlich die Übersicht zu verlieren.
                Bitte der v4.0.2 eine Chance geben. ;o)
                @MarkA: An die Lüfterstufe machen wir uns, wenn der Adapter wieder soweit läuft. Also hoffentlich in der V4.0.3 oder V4.0.4
                  Hallo Grizzelbee,
                  leider ein anderer Fehler...
                  2021-04-07 11:37:35.727 - info: host.iobroker "system.adapter.mielecloudservice.0" enabled
                  2021-04-07 11:37:36.072 - info: host.iobroker instance system.adapter.mielecloudservice.0 started with pid 21267
                  2021-04-07 11:37:37.575 - info: mielecloudservice.0 (21267) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v12.21.0, js-controller: 3.2.16
                  2021-04-07 11:37:38.056 - info: mielecloudservice.0 (21267) Access-Token expires at: [Fri May 07 2021 11:37:00 GMT+0200 (GMT+02:00)]
                  2021-04-07 11:37:38.059 - info: mielecloudservice.0 (21267) Setting up devices ...
                  2021-04-07 11:37:40.594 - error: mielecloudservice.0 (21267) [APISendRequest] {"message":"Request failed with status code 404","name":"Error","stack":"Error: Request failed with status code 404\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/000000000000/actions","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_a7c7eb85fe2599f38c3cf46b3f31c8b4","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"json":true,"dataType":"json"}} | [Stack]: Error: Request failed with status code 404
                  2021-04-07 11:37:40.595 - error: mielecloudservice.0 (21267) Request made and server responded:
                  2021-04-07 11:37:40.595 - error: mielecloudservice.0 (21267) Response.status:404
                  2021-04-07 11:37:40.596 - error: mielecloudservice.0 (21267) Response.headers: {"date":"Wed, 07 Apr 2021 09:37:40 GMT","content-type":"application/json","content-length":"23","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains, max-age=15724800; includeSubDomains","access-control-allow-credentials":"true","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-origin":"*","x-environment":"mcs-eu-prod-std, mcs-eu-prod-default"}
                  2021-04-07 11:37:40.596 - error: mielecloudservice.0 (21267) Response.data: {"message":"Not found"}
                  2021-04-07 11:37:40.597 - error: mielecloudservice.0 (21267) [main] :Bullshit!Not found, Stacktrace:Error: Bullshit!Not found
                  at APISendRequest (/opt/iobroker/node_modules/iobroker.mielecloudservice/miele-apiTools.js:347:19)
                  at runMicrotasks ()
                  Das ist kein Problem!
                  • Grizzelbee
                    @marka
                    Ich könnte ******! Im dicken Strahl!
                    Wie kann es sein, dass die API bei der Statusabfrage Geräte meldet und wenn man dann nach deren Fähigkeiten fragt sagt: Kenne ich nicht???
                    Kannst Du mir bitte ein komplettes Debug-Log des Adapters vom Start bis zum Crash zur Verfügung stellen? (Log-Herunterladen!)
                      @grizzelbee
                      ich fürchte, dass hängt mit meinem Kochfeld zusammen, welches keine Seriennummer ausgibt. Wie oben weiter geschrieben auch nicht in dem Gateway oder der App.
                      2021-04-07 12:24:56.596 - debug: mielecloudservice.0 (26158) addMieleDevice: NewPath = [Hobs.000000000000]
                      2021-04-07 12:24:56.597 - debug: mielecloudservice.0 (26158) addMieleDevice:ident
                      2021-04-07 12:24:56.597 - debug: mielecloudservice.0 (26158) addMieleDeviceIdent: Path = [Hobs.000000000000.IDENT]
                      2021-04-07 12:24:56.598 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.ComModFirmware] Value[V1.30]
                      2021-04-07 12:24:56.598 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.ComModTechType] Value[XKS 3000 Z]
                      2021-04-07 12:24:56.598 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.DeviceSerial] Value[000000000000]
                      2021-04-07 12:24:56.599 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.DeviceTechType] Value[KM X]
                      2021-04-07 12:24:56.599 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.DeviceMatNumber] Value[00000000]
                      2021-04-07 12:24:56.599 - debug: mielecloudservice.0 (26158) addMieleDevice:state
                      2021-04-07 12:24:56.600 - debug: mielecloudservice.0 (26158) createStateDeviceMainState: Path[Hobs.000000000000.Status], setup: [true], path: [Hobs.000000000000.Status], value: [Aus]
                      2021-04-07 12:24:56.600 - debug: mielecloudservice.0 (26158) [createNumber]: Path[Hobs.000000000000.Status_raw] Value[1] Unit[]
                      2021-04-07 12:24:56.702 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.Status] Value[Aus]
                      2021-04-07 12:24:56.703 - debug: mielecloudservice.0 (26158) createStateSignalFailure: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [false]
                      2021-04-07 12:24:56.704 - debug: mielecloudservice.0 (26158) createBool: Path[Hobs.000000000000.signalFailure] Value[false]
                      2021-04-07 12:24:56.705 - debug: mielecloudservice.0 (26158) createStateConnected: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [true]
                      2021-04-07 12:24:56.705 - debug: mielecloudservice.0 (26158) createBool: Path[Hobs.000000000000.Connected] Value[true]
                      2021-04-07 12:24:56.706 - debug: mielecloudservice.0 (26158) createStateSignalInUse: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [false]
                      2021-04-07 12:24:56.706 - debug: mielecloudservice.0 (26158) createBool: Path[Hobs.000000000000.signalInUse] Value[false]
                      2021-04-07 12:24:56.707 - debug: mielecloudservice.0 (26158) createStateActionsInformation: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: []
                      2021-04-07 12:24:56.707 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.ACTIONS.Action_Information] Value[]
                      2021-04-07 12:24:56.708 - debug: mielecloudservice.0 (26158) addDeviceNicknameAction: Path:[Hobs.000000000000], mieleDevice:[{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":27,"value_localized":"Kochfeld"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000000000000","fabIndex":"00","techType":"KM X","matNumber":"00000000","swids":["12869","0"]},"xkmIdentLabel":{"techType":"XKS 3000 Z","releaseVersion":"V1.30"}},"state":{"ProgramID":{"value_raw":2600468480,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":0,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"}],"ecoFeedback":null,"batteryLevel":null}}]
                      2021-04-07 12:24:56.709 - debug: mielecloudservice.0 (26158) APISendRequest: Awaiting requested data.
                      2021-04-07 12:24:57.004 - debug: mielecloudservice.0 (26158) Given parameters:
                      2021-04-07 12:24:57.005 - debug: mielecloudservice.0 (26158) Auth: [{"access_token":"DE_888854539921b0fa76130f94a693c63f","refresh_token":"DE_6ac5e0f47f8d421e508dc166c1c20227","token_type":"Bearer","expires_in":2592000}]
                      2021-04-07 12:24:57.005 - debug: mielecloudservice.0 (26158) Endpoint: [v1/devices/000000000000/actions]
                      2021-04-07 12:24:57.006 - debug: mielecloudservice.0 (26158) Method: [GET]
                      2021-04-07 12:24:57.006 - debug: mielecloudservice.0 (26158) Payload: [""]
                      2021-04-07 12:24:57.008 - error: mielecloudservice.0 (26158) [APISendRequest] {"message":"Request failed with status code 404","name":"Error","stack":"Error: Request failed with status code 404\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/000000000000/actions","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_888854539921b0fa76130f94a693c63f","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"json":true,"dataType":"json"}} | [Stack]: Error: Request failed with status code 404
                      2021-04-07 12:24:57.008 - error: mielecloudservice.0 (26158) Request made and server responded:
                      2021-04-07 12:24:57.009 - error: mielecloudservice.0 (26158) Response.status:404
                      2021-04-07 12:24:57.009 - error: mielecloudservice.0 (26158) Response.headers: {"date":"Wed, 07 Apr 2021 10:24:56 GMT","content-type":"application/json","content-length":"23","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains, max-age=15724800; includeSubDomains","access-control-allow-credentials":"true","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-origin":"*","x-environment":"mcs-eu-prod-std, mcs-eu-prod-default"}
                      2021-04-07 12:24:57.010 - error: mielecloudservice.0 (26158) Response.data: {"message":"Not found"}
                      2021-04-07 12:24:57.010 - error: mielecloudservice.0 (26158) [main] :Bullshit!Not found, Stacktrace:Error: Bullshit!Not found
                      at runMicrotasks ()
                      Reicht das soweit?
                      Gruß Mark
                      M Grizzelbee 2 Replies Last reply Reply Quote 0
                        MarkA @MarkA last edited by
                        @marka said in MieleCloudService Adapter:
                        @grizzelbee
                        at runMicrotasks ()
                        Reicht das soweit?
                        Gruß Mark
                        Nachtrag:
                        Das Kochfeld hat natürlich eine Fabrikationsnummer, die wird nur offensichtlich nicht von dem Kommunikationsmodul erkannt. Kann man die ggfls. in einem Datenpunkt manuell setzen?
                        • Grizzelbee
                          Grizzelbee Developer @MarkA last edited by Grizzelbee
                          @marka sagte in MieleCloudService Adapter:
                          Reicht das soweit?
                          Leider nicht.
                          Bei Start des Adapters logge ich ein großes JSON raus, das die Antwort von Miele auf die Frage nach dem Status aller Geräte enthält.
                          Beispiel:
                          2021-03-19 11:22:04.887 - info: mielecloudservice.0 (3953) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v12.20.2, js-controller: 3.2.16
                          2021-03-19 11:22:04.912 - debug: mielecloudservice.0 (3953) function APIGetAccessToken
                          2021-03-19 11:22:04.914 - debug: mielecloudservice.0 (3953) Awaiting OAuth2 Token.
                          2021-03-19 11:22:04.915 - debug: mielecloudservice.0 (3953) OAuth2 grant_type: [password]
                          2021-03-19 11:22:04.915 - debug: mielecloudservice.0 (3953) options OAuth2-VG: [de-DE]
                          2021-03-19 11:22:04.915 - debug: mielecloudservice.0 (3953) config API Language: [de]
                          2021-03-19 11:22:05.256 - info: mielecloudservice.0 (3953) Access-Token expires at: [Sun Apr 18 2021 11:22:00 GMT+0200 (GMT+02:00)]
                          2021-03-19 11:22:05.257 - info: mielecloudservice.0 (3953) Setting up devices ...
                          2021-03-19 11:22:05.257 - debug: mielecloudservice.0 (3953) refreshMieleData: get data from API
                          2021-03-19 11:22:05.258 - debug: mielecloudservice.0 (3953) APISendRequest: Awaiting requested data.
                          2021-03-19 11:22:05.481 - debug: mielecloudservice.0 (3953) API returned Status: [200]
                          2021-03-19 11:22:05.481 - debug: mielecloudservice.0 (3953) refreshMieleData: handover all devices data to splitMieleDevices
                          2021-03-19 11:22:05.482 - debug: mielecloudservice.0 (3953) refreshMieleData: data [ HIER STEHT DAS gesuchte JSON DRIN ]
                          2021-03-19 11:22:05.482 - debug: mielecloudservice.0 (3953) [splitMieleDevices] Splitting JSON to single devices.
                          Mir ging es darum dieses JSON zu sehen weil dort zum einen die ID steht über die ich das Gerät ansprechen kann und zum anderen die FabNummer. Im Beispiel die "000703167977". Hier sind sie identisch - die können aber auch abweichen. Und ich vermute das das hier der Fall ist.
                          refreshMieleData: data [{"000703167977":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":17,"value_localized":"Kaffeevollautomat"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000703167977","fabIndex":"15"
                          Nachtrag:
                          Die Nummer manuell zu setzen würde leider nichts nützen - zumal die bei jedem Datenupdate überschrieben würde. Ich sehe erst einmal zu, dass ich die ID korrekt verwende. Ich vermute aktuell dort einen Bug.
                          https://github.com/Grizzelbee/ioBroker.mielecloudservice/issues/109
                          Grizzelbee created this issue in Grizzelbee/ioBroker.mielecloudservice
                          closed Request failed with status code 404 when querying actions for device #109
                            @grizzelbee
                            Hier mehr vom Log:
                            2021-04-07 12:24:51.891 - debug: mielecloudservice.0 (26158) refreshMieleData: handover all devices data to splitMieleDevices
                            2021-04-07 12:24:51.892 - debug: mielecloudservice.0 (26158) refreshMieleData: data [{"000147896692":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":1,"value_localized":"Waschmaschine"},"deviceName":"Waschmaschine","deviceIdentLabel":{"fabNumber":"000147896692","fabIndex":"14","techType":"WMG823","matNumber":"10499030","swids":["3918","25204","25117","20163","3913","20199","25017","25036","2632","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.72"}},"state":{"ProgramID":{"value_raw":3,"value_localized":"Pflegeleicht","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[0,0],"spinningSpeed":{"unit":"U/min","value_raw":1100,"value_localized":"1100","key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}},"000139847422":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":2,"value_localized":"Trockner"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000139847422","fabIndex":"11","techType":"TMM843WP","matNumber":"10499110","swids":["3545","25027","25055","20228","3493","20199","25017","25026","3493","20199","25017","25026"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.72"}},"state":{"ProgramID":{"value_raw":20,"value_localized":"Baumwolle","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":2,"value_localized":"Automatikprogramm","key_localized":"Programmart"},"programPhase":{"value_raw":522,"value_localized":"Ende","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[0,0],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":1,"value_localized":"Schranktrocken plus","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}},"mac-00124B000E881998":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":18,"value_localized":"Dunstabzugshaube"},"deviceName":"","deviceIdentLabel":{"fabNumber":"","fabIndex":"","techType":"","matNumber":"","swids":[]},"xkmIdentLabel":{"techType":"","releaseVersion":""}},"state":{"ProgramID":{"value_raw":2449473536,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":271,"value_localized":"Auffrischen + Befeuchten","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":2,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":0,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}},"mac-00124B000E0C6D06":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":27,"value_localized":"Kochfeld"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000000000000","fabIndex":"00","techType":"KM X","matNumber":"00000000","swids":["12869","0"]},"xkmIdentLabel":{"techType":"XKS 3000 Z","releaseVersion":"V1.30"}},"state":{"ProgramID":{"value_raw":2600468480,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":0,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"}],"ecoFeedback":null,"batteryLevel":null}}}]
                            2021-04-07 12:24:51.893 - debug: mielecloudservice.0 (26158) [splitMieleDevices] Splitting JSON to single devices.
                            2021-04-07 12:24:51.894 - debug: mielecloudservice.0 (26158) splitMieleDevices: 000147896692: [000147896692] *** Value: [{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":1,"value_localized":"Waschmaschine"},"deviceName":"Waschmaschine","deviceIdentLabel":{"fabNumber":"000147896692","fabIndex":"14","techType":"WMG823","matNumber":"10499030","swids":["3918","25204","25117","20163","3913","20199","25017","25036","2632","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.72"}},"state":{"ProgramID":{"value_raw":3,"value_localized":"Pflegeleicht","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[0,0],"spinningSpeed":{"unit":"U/min","value_raw":1100,"value_localized":"1100","key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}}]
                            Gruß Mark
                            • Grizzelbee
                              @marka
                              Perfekt! Danke schön! 🙂
                              Und da haben wir das Problem auch direkt (wie befürchtet) gefunden:
                              Ich frage die Fähigkeiten über die fabNummer (weil üblicherweise identisch mit der ID) ab, müsste aber halt die ID (mac-...) nehmen.
                              Dann mache ich mich mal an einen Fix ...
                              • Grizzelbee
                                Grizzelbee Developer @Grizzelbee last edited by
                                V4.0.3 (2021-04-07) (The raven child)
                                • (grizzelbee) Fix: 109 fixes 404 error when querying possible actions for device.
                                • (grizzelbee) Fix: fixes errors when executing actions on devices with API-Id!=fabNumber
                                  @grizzelbee said in MieleCloudService Adapter:
                                  Sieht sehr gut aus, keine Fehler mehr im Log!
                                  Danke!
                                  • Grizzelbee
                                    BOO-Yaah! 🙂
                                    Danke!
                                    Sehr gerne! 🙂 war ja quasi team-work. 😉
                                    Was macht die Lüfterstufe?
                                      Ich kann leider nur Testen, aber wenn es hilft, dann gerne 😄
                                      Die Lüfterstufe hat leider noch ein leeres DropDown Feld.
                                      Nachtrag:
                                      Wenn ich den Adapter stoppe, die Datenpunkte für die Haube lösche, dann kommt noch der Fehler:
                                       warn: mielecloudservice.0 (3387) State "mielecloudservice.0.Hoods.mac-IDhere.ACTIONS.VentilationStep" has no existing object, this might lead to an error in future versions
                                      Nach einem weiteren Neustart kommt die Meldung nicht mehr - wird der vielleicht zur falschen Zeit erwartet / geprüft?
                                      • Grizzelbee
                                        Okay. Was sagt denn das Debug-Log dazu? Da müsste es ein paar Einträge geben.
                                          das sieht für mich so aus, als wenn der SP ohne Inhalt angelegt wird.
                                          Bei dem "alten" Drop Down DP, der nicht im ACTIONS Pfad war, war die Auswahl vorhanden, aber ohne Funktion.
                                          Auszug:
                                          2021-04-07 16:03:53.498 - debug: mielecloudservice.0 (25477) Device: [mac-00124B000E881998] has no serial number/fabNumber. Taking DeviceNumber instead.
                                          2021-04-07 16:03:53.498 - debug: mielecloudservice.0 (25477) This is a Dunstabzugshaube
                                          2021-04-07 16:03:53.499 - debug: mielecloudservice.0 (25477) _knownDevices={"000147896692":{"deviceFolder":"Washing_machines","name":"Washing machines reported by Miele@Home API","icon":"icons/01_washingmachine.svg","API_Id":"000147896692"},"000139847422":{"deviceFolder":"Tumble_dryers","name":"Tumble dryers reported by Miele@Home API","icon":"icons/02_dryer.svg","API_Id":"000139847422"},"mac-00124B000E881998":{"deviceFolder":"Hoods","name":"Hoods reported by Miele@Home API","icon":"icons/18_hood.svg","API_Id":"mac-00124B000E881998"}}
                                          2021-04-07 16:03:53.499 - debug: mielecloudservice.0 (25477) addMieleDevice: NewPath = [Hoods.mac-00124B000E881998]
                                          2021-04-07 16:03:53.500 - debug: mielecloudservice.0 (25477) addMieleDevice:ident
                                          2021-04-07 16:03:53.501 - debug: mielecloudservice.0 (25477) addMieleDeviceIdent: Path = [Hoods.mac-00124B000E881998.IDENT]
                                          2021-04-07 16:03:53.501 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.ComModFirmware] Value[]
                                          2021-04-07 16:03:53.502 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.ComModTechType] Value[]
                                          2021-04-07 16:03:53.502 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.DeviceSerial] Value[mac-00124B000E881998]
                                          2021-04-07 16:03:53.503 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.DeviceTechType] Value[]
                                          2021-04-07 16:03:53.503 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.DeviceMatNumber] Value[]
                                          2021-04-07 16:03:53.504 - debug: mielecloudservice.0 (25477) addMieleDevice:state
                                          2021-04-07 16:03:53.504 - debug: mielecloudservice.0 (25477) createStateDeviceMainState: Path[Hoods.mac-00124B000E881998.Status], setup: [true], path: [Hoods.mac-00124B000E881998.Status], value: [Aus]
                                          2021-04-07 16:03:53.504 - debug: mielecloudservice.0 (25477) [createNumber]: Path[Hoods.mac-00124B000E881998.Status_raw] Value[1] Unit[]
                                          2021-04-07 16:03:53.678 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.Status] Value[Aus]
                                          2021-04-07 16:03:53.678 - debug: mielecloudservice.0 (25477) createStateSignalFailure: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                                          2021-04-07 16:03:53.679 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.signalFailure] Value[false]
                                          2021-04-07 16:03:53.679 - debug: mielecloudservice.0 (25477) createStateConnected: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [true]
                                          2021-04-07 16:03:53.680 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.Connected] Value[true]
                                          2021-04-07 16:03:53.680 - debug: mielecloudservice.0 (25477) createStateSignalInUse: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                                          2021-04-07 16:03:53.680 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.signalInUse] Value[false]
                                          2021-04-07 16:03:53.681 - debug: mielecloudservice.0 (25477) createStateActionsInformation: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: []
                                          2021-04-07 16:03:53.681 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.ACTIONS.Action_Information] Value[]
                                          2021-04-07 16:03:53.681 - debug: mielecloudservice.0 (25477) addDeviceNicknameAction: Path:[Hoods.mac-00124B000E881998], mieleDevice:[{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":18,"value_localized":"Dunstabzugshaube"},"deviceName":"","deviceIdentLabel":{"fabNumber":"mac-00124B000E881998","fabIndex":"","techType":"","matNumber":"","swids":[]},"xkmIdentLabel":{"techType":"","releaseVersion":""}},"state":{"ProgramID":{"value_raw":2449473536,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":271,"value_localized":"Auffrischen + Befeuchten","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":2,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":0,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}}]
                                          2021-04-07 16:03:53.682 - debug: mielecloudservice.0 (25477) APISendRequest: Awaiting requested data.
                                          2021-04-07 16:03:53.980 - debug: mielecloudservice.0 (25477) API returned Status: [200]
                                          2021-04-07 16:03:53.981 - debug: mielecloudservice.0 (25477) CurrentlyPermittedActions: {"processAction":[],"light":[1],"ambientLight":[],"startTime":[],"ventilationStep":[1,2,3,4],"programId":[],"targetTemperature":[],"deviceName":false,"powerOn":true,"powerOff":false,"colors":[],"modes":[]}
                                          2021-04-07 16:03:53.982 - debug: mielecloudservice.0 (25477) addPowerSwitch: Path[Hoods.mac-00124B000E881998]
                                          2021-04-07 16:03:53.982 - debug: mielecloudservice.0 (25477) [checkPowerAction]: Device [Hoods.mac-00124B000E881998]: PowerOn is permitted!
                                          2021-04-07 16:03:53.982 - debug: mielecloudservice.0 (25477) addPowerSwitch: result from getPowerState: [Off]
                                          2021-04-07 16:03:53.983 - debug: mielecloudservice.0 (25477) addLightSwitch: Path[Hoods.mac-00124B000E881998]
                                          2021-04-07 16:03:53.984 - debug: mielecloudservice.0 (25477) [checkPowerAction]: Device [Hoods.mac-00124B000E881998]: PowerOn is permitted!
                                          2021-04-07 16:03:53.984 - debug: mielecloudservice.0 (25477) addLightSwitch: result from getLightState: [Off]
                                          2021-04-07 16:03:53.985 - debug: mielecloudservice.0 (25477) addStopButton: Path[Hoods.mac-00124B000E881998]
                                          2021-04-07 16:03:53.986 - debug: mielecloudservice.0 (25477) addVentilationStepSwitch: Path[Hoods.mac-00124B000E881998]
                                          2021-04-07 16:03:53.986 - debug: mielecloudservice.0 (25477) addColorsAction: Path[Hoods.mac-00124B000E881998]
                                          2021-04-07 16:03:53.987 - debug: mielecloudservice.0 (25477) createStateSignalInfo: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                                          2021-04-07 16:03:53.987 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.signalInfo] Value[false]
                                          2021-04-07 16:03:53.988 - debug: mielecloudservice.0 (25477) createStateFullRemoteControl: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                                          2021-04-07 16:03:53.988 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.fullRemoteControl] Value[false]
                                          2021-04-07 16:03:53.988 - debug: mielecloudservice.0 (25477) createStateSmartGrid: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                                          2021-04-07 16:03:53.989 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.smartGrid] Value[false]
                                          2021-04-07 16:03:53.989 - debug: mielecloudservice.0 (25477) createStateMobileStart: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                                          2021-04-07 16:03:53.989 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.mobileStart] Value[false]
                                          2021-04-07 16:03:53.990 - debug: mielecloudservice.0 (25477) createStateVentilationStep: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: []
                                          2021-04-07 16:03:53.990 - debug: mielecloudservice.0 (25477) addVentilationStepSwitch: Path[Hoods.mac-00124B000E881998]
                                          2021-04-07 16:03:53.991 - debug: mielecloudservice.0 (25477) splitMieleDevices: mac-00124B000E0C6D06: [mac-00124B000E0C6D06] *** Value: [{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":27,"value_localized":"Kochfeld"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000000000000","fabIndex":"00","techType":"KM X","matNumber":"00000000","swids":["12869","0"]},"xkmIdentLabel":{"techType":"XKS 3000 Z","releaseVersion":"V1.30"}},"state":{"ProgramID":{"value_raw":2600468480,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":0,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"}],"ecoFeedback":null,"batteryLevel":null}}]
                                          2021-04-07 16:03:53.991 - debug: mielecloudservice.0 (25477) This is a Kochfeld
                                          2021-04-07 16:03:53.991 - debug: mielecloudservice.0 (25477) _knownDevices={"000147896692":{"deviceFolder":"Washing_machines","name":"Washing machines reported by Miele@Home API","icon":"icons/01_washingmachine.svg","API_Id":"000147896692"},"000139847422":{"deviceFolder":"Tumble_dryers","name":"Tumble dryers reported by Miele@Home API","icon":"icons/02_dryer.svg","API_Id":"000139847422"},"mac-00124B000E881998":{"deviceFolder":"Hoods","name":"Hoods reported by Miele@Home API","icon":"icons/18_hood.svg","API_Id":"mac-00124B000E881998"},"000000000000":{"deviceFolder":"Hobs","name":"Hobs reported by Miele@Home API","icon":"icons/14_hobhighlight.svg","API_Id":"mac-00124B000E0C6D06"}}
                                          2021-04-07 16:03:53.992 - debug: mielecloudservice.0 (25477) addMieleDevice: NewPath = [Hobs.000000000000]
                                          2021-04-07 16:03:53.992 - debug: mielecloudservice.0 (25477) addMieleDevice:ident
                                          2021-04-07 16:03:53.993 - debug: mielecloudservice.0 (25477) addMieleDeviceIdent: Path = [Hobs.000000000000.IDENT]
                                          2021-04-07 16:03:53.993 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.ComModFirmware] Value[V1.30]
                                          2021-04-07 16:03:53.993 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.ComModTechType] Value[XKS 3000 Z]
                                          2021-04-07 16:03:53.994 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.DeviceSerial] Value[000000000000]
                                          2021-04-07 16:03:53.994 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.DeviceTechType] Value[KM X]
                                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.DeviceMatNumber] Value[00000000]
                                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) addMieleDevice:state
                                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) createStateDeviceMainState: Path[Hobs.000000000000.Status], setup: [true], path: [Hobs.000000000000.Status], value: [Aus]
                                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) [createNumber]: Path[Hobs.000000000000.Status_raw] Value[1] Unit[]
                                          2021-04-07 16:03:54.007 - warn: mielecloudservice.0 (25477) State "mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS.VentilationStep" has no existing object, this might lead to an error in future versions
                                          2021-04-07 16:03:54.195 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.Status] Value[Aus]
                                          2021-04-07 16:03:54.196 - debug: mielecloudservice.0 (25477) createStateSignalFailure: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [false]
                                          • Grizzelbee
                                            @marka
                                            Hier mal ein Versuch dazu:
                                            V4.0.4 (2021-04-07) (Wastelands)
                                            • (grizzelbee) Fix: fixes ventilation step switch for hoods
                                            miele mieleathome mielecloudservice
                                            90
                                            847
                                            202492
