    4. Permission Error bei Adapter Install
      Homoran Global Moderator Administrators @Rene R last edited by Homoran
      @rene-r
      Bitte die Ausgabe von
      iobroker list instances
      iobroker list adapters
      top
      vollständig als text in Code-tags posten
      Rene R 1 Reply Last reply Reply Quote 0
      • Rene R
        Rene R @Homoran last edited by
        @homoran said in Permission Error bei Adapter Install:
        top
        code_text  pi@raspberrypi:/opt/iobroker $ iobroker list instances
          system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
          system.adapter.calendar.0               : calendar              : raspberrypi        - disabled, port: 8095
          system.adapter.discovergy.0             : discovergy            : raspberrypi        -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi        -  enabled
          system.adapter.ical.1                   : ical                  : raspberrypi        -  enabled
          system.adapter.ical.2                   : ical                  : raspberrypi        -  enabled
          system.adapter.ical.3                   : ical                  : raspberrypi        -  enabled
          system.adapter.info.0                   : info                  : raspberrypi        -  enabled
          system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
          system.adapter.material.0               : material              : raspberrypi        -  enabled
          system.adapter.pi-hole.0                : pi-hole               : raspberrypi        - disabled
          system.adapter.simple-api.0             : simple-api            : raspberrypi        - disabled, port: 8083, bind: 0.0.0.0, run as: admi        n
          system.adapter.trashschedule.0          : trashschedule         : raspberrypi        -  enabled
          system.adapter.upnp.0                   : upnp                  : raspberrypi        - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi        -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi        -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi        -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi        -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
          system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
        + instance is alive
        pi@raspberrypi:/opt/iobroker $ iobroker list adapters
        system.adapter.admin                   : admin          - v4.2.1
        system.adapter.calendar                : calendar       - v1.2.0
        system.adapter.discovergy              : discovergy     - v0.5.4
        system.adapter.discovery               : discovery      - v2.6.1
        system.adapter.fullcalendar            : fullcalendar   - v1.1.0
        system.adapter.ical                    : ical           - v1.9.2
        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
        system.adapter.influxdb                : influxdb       - v1.9.4
        system.adapter.info                    : info           - v1.7.14
        system.adapter.jarvis                  : jarvis         - v2.1.0
        system.adapter.javascript              : javascript     - v5.0.15
        system.adapter.material                : material       - v0.13.9
        system.adapter.pi-hole                 : pi-hole        - v1.3.1
        system.adapter.simple-api              : simple-api     - v2.5.3
        system.adapter.sourceanalytix          : sourceanalytix - v0.4.8
        system.adapter.synology                : synology       - v0.1.18
        system.adapter.trashschedule           : trashschedule  - v1.1.1
        system.adapter.upnp                    : upnp           - v1.0.17
        system.adapter.vis                     : vis            - v1.3.8
        system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
        system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
        system.adapter.vis-justgage            : vis-justgage   - v1.0.2
        system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.1-beta
        system.adapter.vis-metro               : vis-metro      - v1.1.2
        system.adapter.web                     : web            - v3.3.0
        pi@raspberrypi:/opt/iobroker $ top
        top - 16:11:55 up 44 min,  3 users,  load average: 0,98, 1,04, 1,20
        Tasks: 167 total,   2 running, 109 sleeping,   0 stopped,   2 zombie
        %Cpu(s): 22,3 us,  2,7 sy,  0,0 ni, 75,0 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
        KiB Mem :   948304 total,    76524 free,   209052 used,   662728 buff/cache
        KiB Swap:   102396 total,    38652 free,    63744 used.   413744 avail Mem
        Change delay from 3,0 to
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
         1609 pi        20   0  645552 278188 227652 R  74,9 29,3  30:43.50 electron
         1630 pi        20   0  238624  48940  34352 S  18,3  5,2   9:44.81 electron
         3879 pi        20   0    8208   3332   2796 R   2,1  0,4   0:01.38 top
          496 root      20   0  167928  38200  26812 S   1,7  4,0   1:44.60 Xorg
           10 root      20   0       0      0      0 I   0,4  0,0   0:03.52 rcu_sched
           44 root      20   0       0      0      0 I   0,4  0,0   0:02.66 kworker/u8:1-ev
         3816 pi        20   0   11660   3416   2692 S   0,4  0,4   0:00.13 sshd
            1 root      20   0   28096   3404   2676 S   0,0  0,4   0:02.69 systemd
            2 root      20   0       0      0      0 S   0,0  0,0   0:00.01 kthreadd
            3 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 rcu_par_gp
            8 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 mm_percpu_wq
            9 root      20   0       0      0      0 S   0,0  0,0   0:00.61 ksoftirqd/0
           11 root      20   0       0      0      0 I   0,0  0,0   0:00.00 rcu_bh
           12 root      rt   0       0      0      0 S   0,0  0,0   0:00.07 migration/0
           13 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/0
           14 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/1
           15 root      rt   0       0      0      0 S   0,0  0,0   0:00.06 migration/1
           16 root      20   0       0      0      0 S   0,0  0,0   0:00.26 ksoftirqd/1
           19 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/2
           20 root      rt   0       0      0      0 S   0,0  0,0   0:00.06 migration/2
           21 root      20   0       0      0      0 S   0,0  0,0   0:00.27 ksoftirqd/2
           24 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/3
           25 root      rt   0       0      0      0 S   0,0  0,0   0:00.02 migration/3
           26 root      20   0       0      0      0 S   0,0  0,0   0:00.30 ksoftirqd/3
           29 root      20   0       0      0      0 S   0,0  0,0   0:00.00 kdevtmpfs
           30 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 netns
           34 root      20   0       0      0      0 S   0,0  0,0   0:00.00 khungtaskd
           35 root      20   0       0      0      0 S   0,0  0,0   0:00.00 oom_reaper
           36 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 writeback
           37 root      20   0       0      0      0 S   0,0  0,0   0:00.00 kcompactd0
           38 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 crypto
           39 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 kblockd
           40 root      rt   0       0      0      0 S   0,0  0,0   0:00.00 watchdogd
           41 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 rpciod
           42 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 kworker/u9:0-hc
           43 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 xprtiod
           46 root      20   0       0      0      0 S   0,0  0,0   0:10.21 kswapd0
           47 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 nfsiod
           58 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 kthrotld
           60 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 iscsi_eh
           61 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 dwc_otg
           62 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 DWC Notificatio
           63 root       1 -19       0      0      0 S   0,0  0,0   0:00.00 vchiq-slot/0
           64 root       1 -19       0      0      0 S   0,0  0,0   0:00.00 vchiq-recy/0
           65 root       0 -20       0      0      0 S   0,0  0,0   0:00.00 vchiq-sync/0
           66 root      20   0       0      0      0 S   0,0  0,0   0:00.00 vchiq-keep/0
           67 root      10 -10       0      0      0 S   0,0  0,0   0:00.00 SMIO
           69 root     -51   0       0      0      0 S   0,0  0,0   0:04.53 irq/86-mmc1
           71 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 mmc_complete
           72 root       0 -20       0      0      0 I   0,0  0,0   0:03.03 kworker/3:1H-kb
           74 root       0 -20       0      0      0 I   0,0  0,0   0:03.65 kworker/1:1H-kb
           75 root      20   0       0      0      0 S   0,0  0,0   0:01.30 jbd2/mmcblk0p2-
           76 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 ext4-rsv-conver
          @rene-r sagte in Permission Error bei Adapter Install:
          ich weiß nicht, ob das der Grund für dein Problem ist, aber dein armer kleiner Raspi ist vollkommen überfordert!
          und habe die Knete noch nicht für nen RPI 4
          ist da leider keine Ausrede!
          Zusätzlich zu >15 Instanzen auch noch einen Desktop und einen Magic Mirror betreiben ist zu viel!
          Dein RAM ist längst aufgebraucht.
          Da würde ich jetzt nichts mehr dran schrauben ohne Gefahr zu laufen, dass danach gar nichts mehr läuft
          • Rene R
            Rene R @Homoran last edited by Rene R
            Aktuell laufen nur 7 instanzen und mehr nicht
            es ist ja nur das eine Problem mit der Berechtigung und npm der rest läuft ja stabil mehr wird da auch nichts mehr laufen.
            Möchte nur dass der NPM wieder richtig funktioniert und mehr nicht dass ich ein vollständiges system habe ohne fehler dass ich mir dann ein Backup von der sd Karte ziehen kann.
              @rene-r dein Raspi ist erst seit 44 Minuten wieder in Betrieb und hat schon 2/3 des SWAPs verbraucht.
              das geht nicht mehr lange gut!
              Wie hast du denn installiert?
              und npm
              ich habe noch nicht mal was von npm gelesen (beim Überfliegen)
              • Rene R
                erstes Bild von thread
                  das erklärt einiges!
                  Das kann ich am Handy nicht entziffern.
                  deswegen Code immer als Text in Code-tags
                  • Rene R
                    @homoran ```
                    code_text $ ./iobroker add backitup  --host raspberrypi
                    NPM version: 6.14.12
                    npm install iobroker.backitup@2.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
                    npm ERR! code EACCES
                    npm ERR! syscall mkdirnpm ERR! path /home/iobrokernpm ERR! errno -13
                    npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker'npm ERR!  [OperationalError: EACCES: permission denied, mkdir '/home/iobroker'] {npm ERR!   cause: [Error: EACCES: permission denied, mkdir '/home/iobroker'] {npm ERR!     errno: -13,npm ERR!     code: 'EACCES',npm ERR!     syscall: 'mkdir',npm ERR!     path: '/home/iobroker'npm ERR!   },npm ERR!   isOperational: true,npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'mkdir',npm ERR!   path: '/home/iobroker'npm ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
                    ERROR: host.raspberrypi Cannot install iobroker.backitup@2.1.0: 243
                    ERROR: process exited with code 25
                      @Rene-R
                      nix npm Fehler!
                      was sucht npm denn da?
                      • Rene R
                        keine ahnung wie kann ich das ändern?
                        Installiert ist es auf /opt/iobroker
                          indem du die noch offene Frage beantwortest:
                          @homoran sagte in Permission Error bei Adapter Install:
                          • Rene R
                            unter pi@raspberrypi: dann nodejs installiert.
                              @rene-r aber du musst doch in der letzten Zeit etwas geändert haben, damit es jetzt nicht mehr geht.
                              früher ging es doch noch, oder?
                              hast du npm alleine nochmal installiert?
                              • Rene R
                                habe iobroker frisch installiert auf nem neuen stretch version und das backup eingespielt , dann neugestartet und seit dem die Probleme.
                                Den Fixer habe ich auch schon mehrmals drüber gezogen aber keine Veränderung
                                habe npm neu installiert aber keine Veränderung
                                  dann ist da etwas schief gelaufen.
                                  Ich habe keine Ahnung mehr wie ich dir helfen soll, schließe mich aber @Thomas-Braun an:
                                  eine neue aktuelle Installation aufsetzen mit Buster und dem ioBroker Einzeiler und das Backup zurückspielen
                                  dabei ohne Desktop und ohne weitere Software, die natürlich auch etwas verbiegen könnte.
                                  • Rene R
                                    Habe das Problem jetzt gelöst....
                                    Problem war /home/iobroker hat der ordner gefehlt und die Passende Rechte also kann adapter wieder installieren
                                    Edit: Thread kann man schließen.
                                      das stand doch im log!!!
                                      • Rene R
                                        Ich habe im ordner Home den Ordner iobroker gelöscht, und im ersten Bild sagt er ja dass er den ordner nicht erstellen kann. dann habe ich mit dem user pi den Ordner iobroker erstellt und dann kam die nächste Fehlermeldung mit den Rechten, habe den ordner Iobroker angeschaut und user war root dies habe ich dann geändert auf dem user iobroker, gespeichert und dann hat auch wieder funktioniert mit den adapatern zu installieren.
                                          was ein Chaos!
                                          sauberes Anlegen über den Installer mit dem User iobroker und alles was dazu gehört wäre der richtige Weg gewesen.
                                          Wer weiß wo sonst noch überall etwas verbogen ist
                                          31.7k
                                          79.8k
                                          1939
