    4. [gelöst] Backitup bleibt bei Redis Backup hängen
    • Claus1985
      Claus1985 @simatec last edited by Claus1985
      @simatec Du hast recht, lokal läuft es durch:
      Started iobroker ...
      [DEBUG] [iobroker] - host.Schaltzentrale2 4401 states saved
      [DEBUG] [iobroker] - host.Schaltzentrale2 5695 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_04_07-16_28_03_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [redis] - Start Redis Backup ...
      [DEBUG] [redis] - Created redistmp directory
      [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_04_07-16_28_10_backupiobroker.tar.gz
      [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
      [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
      [DEBUG] [redis] - done
      [DEBUG] [zigbee] - found zigbee database: zigbee.0
      [DEBUG] [zigbee] - done
      [DEBUG] [javascripts] - Packed 6MB so far...
      [DEBUG] [javascripts] - Packed 7MB so far...
      [DEBUG] [javascripts] - Packed 16MB so far...
      [DEBUG] [javascripts] - Packed 36MB so far...
      [DEBUG] [javascripts] - Packed 52MB so far...
      [DEBUG] [javascripts] - Packed 71MB so far...
      [DEBUG] [javascripts] - Packed 89MB so far...
      [DEBUG] [javascripts] - Packed 108MB so far...
      [DEBUG] [javascripts] - Packed 116MB so far...
      [DEBUG] [javascripts] - Packed 129MB so far...
      [DEBUG] [javascripts] - Packed 147MB so far...
      [DEBUG] [javascripts] - Packed 166MB so far...
      [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_04_07-16_28_11_backupiobroker.tar.gz
      [DEBUG] [javascripts] - done
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [EXIT] 0
      Wobei im Logfile ein Error steht:
      backitup.0	2021-04-07 16:28:03.500	error	(558) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
      Was ich dabei allerdings nicht verstehe ist, wo da das Problem liegt.
      Denn das normale Backup inkl. Zigbee u. Javaskripte führt er problemlos aus und legt das auch auf der Fritzbox ab.
      Er löscht vorher sogar die vorhandenen Dateien. Er hat also eigentlich alle Rechte.
      Hast Du eine Idee woran das liegen kann und was ich für ein Fix probieren kann?
      Kannst Du das Skript so anpassen, dass es den temporären Dump auf der lokalen SD erzeugt und das
      erst wenn es fertig ist aufs NAS schiebt?
      • simatec
        simatec Developer Most Active @Claus1985 last edited by
        @claus1985 Prüfe mal, ob auf deinem NAS die Userrechte nur für diese Ordner gültig sind oder auch für alle Unterordner.
        Backitup legt hier einen temporären Ordner an. Eventuell wäre auch eine Option, dass du hier als NAS User auch den User "iobroker" vergibst ... Was hast du für ein NAS? Nutzt du CIFS oder NFS
        Wenn Dein NAS NFS kann, würde ich dies empfehlen
        Claus1985 2 Replies Last reply Reply Quote 0
        • Claus1985
          @simatec Verwende eine Fritzbox mit angeschlossenem USB-Stick.
          Nutze CIFS mit SMB 3.1.1. Bin mir nicht sicher wie ich die FB / den Adapter konfigurieren muss um NFS zu nutzen.
          Freigegeben sind eigentlich alle Ordner:
          • Claus1985
            @simatec Wäre es möglich, den Adapter so anzupassen, dass er die Temporären Daten auf dem lokalen Speicher anlegt und dann erst das fertige Backup kopiert? Das müsste die Freigabethemen eigentlich lösen?
            • simatec
              @claus1985 Das ist möglich ... aber nicht bei einem Mount.
              Für solche Anwendungsfälle müsstest du FTP verwenden
              Claus1985 1 Reply Last reply Reply Quote 0
              • Claus1985
                @simatec Hab es nun mal per FTP probiert, bekomme allerdings folgenden Fehler:
                [DEBUG] [ftp] - FTP connected.
                [DEBUG] [ftp] - Send iobroker_2021_04_07-17_07_28_backupiobroker.tar.gz
                [ERROR] [ftp] - Error: /FRITZ-Zentrale/Raspi_Backup/ioBroker_Backup//iobroker_2021_04_07-17_07_28_backupiobroker.tar.gz: Permission denied.
                [DEBUG] [ftp] - Send redis_2021_04_07-17_07_35_backupiobroker.tar.gz
                [ERROR] [ftp] - Error: /FRITZ-Zentrale/Raspi_Backup/ioBroker_Backup//redis_2021_04_07-17_07_35_backupiobroker.tar.gz: Permission denied.
                [DEBUG] [ftp] - Send zigbee.0_2021_04_07-17_07_36_backupiobroker.tar.gz
                [ERROR] [ftp] - Error: /FRITZ-Zentrale/Raspi_Backup/ioBroker_Backup//zigbee.0_2021_04_07-17_07_36_backupiobroker.tar.gz: Permission denied.
                [DEBUG] [ftp] - Send javascripts_2021_04_07-17_07_36_backupiobroker.tar.gz
                [ERROR] [ftp] - Error: /FRITZ-Zentrale/Raspi_Backup/ioBroker_Backup//javascripts_2021_04_07-17_07_36_backupiobroker.tar.gz: Permission denied.
                [DEBUG] [ftp] - done
                Wenn ich mich mit FileZilla und den gleichen Daten einwähle funktioniert der Zugriff inkl. Löschen / Anlegen von Dateien.
                Hast Du einen Tipp woran das liegen könnte? Scheint mir am ioBroker zu liegen?
                Auf dem NAS existiert nun ein Ordner für das REDIS Temp inkl. dump.rdb:
                  Thomas Braun Most Active @Claus1985 last edited by Thomas Braun
                  @claus1985 sagte in Backitup bleibt bei Redis Backup hängen:
                  Scheint mir eher an den usern und deren Rechte auf dem NAS zu liegen.
                  Der user iobroker hat i.d.R. die UID 1001.
                  • Claus1985
                    Claus1985 @Thomas Braun last edited by
                    @thomas-braun Dann verstehe ich allerdings nicht was da falsch ist.
                    Per CIFS kommt Backitup auch mit genau diesem User rein und kann Backups anlegen ohne Fehler.
                    Nur wenn ich Redis einbinde funktioniert es per CIFS nicht.
                    Per FTP funktioniert auch das normale Backup nicht da er mir zeigt permission denied.
                    Ich verwende einen anderen, selbst erstellten User.
                    Per FileZilla komme ich mit genau diesem User rein, kann löschen/anlegen/ändern auch in Unterordnern
                    • simatec
                      simatec Developer Most Active @Claus1985 last edited by simatec
                      @claus1985 Versuche bitte noch einmal die Version vom DEV-Branch mit cifs-mount inkl. Upload nach der Installation. Ich habe mal versucht über den Code die Rechte auf dem NAS gleich zu setzen
                      • Claus1985
                        @simatec Ich bekomme direkt am Start des Backups einen Fehler im Log:
                        backitup.0	2021-04-07 17:47:36.410	error	(5412) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                        Ansonsten läuft es wieder durch bis zum Start des Redis Backups und bleibt hängen:
                        [DEBUG] [redis] - Try deleting the old redis tmp directory: "/opt/iobroker/backups/redistmp"
                        [DEBUG] [redis] - old redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
                        [DEBUG] [redis] - Created new redistmp directory
                        [DEBUG] [redis] - Packed 0MB so far...
                        • simatec
                          @claus1985
                          Den ersten Fehler kannst du ignorieren. Den muss ich bei einem mount noch abfangen.
                          Beim zweiten scheint es ein Thema der Rechte auf deinem NAS zu sein. Schaue mal hier im Forum. Da gibt es einige Anleitungen zum Thema NAS auf der FB. Eventuell deine FB mal updaten. Vielleicht liegt da noch ein Bug vor. Hatte von Problemen bei der Umstellung auf smb 3 gelesen
                          • Claus1985
                            @simatec Ok danke für die Info.
                            Habe das mal über SMB 2.0 probiert, funktioniert allerdings auch nicht.
                            Dann spare ich Redis erstmal aus dem Backup aus, danke Dir trotzdem!
                            simatec 2 Replies Last reply Reply Quote 0
                            • simatec
                              @claus1985
                              Da finden wir schon eine Lösung. Ich schaue nachher mal
                              • simatec
                                @claus1985
                                Poste mal bitte die Einstellungen für den mount von Backitup und alle Fritzbox Einstellungen für das NAS inkl. User und smb Einstellungen
                                • Claus1985
                                  @simatec 6AC82B5F-20BD-4930-8F61-F39DD5AB44D0.jpeg C8BF4A31-5799-4783-AB93-D3120255F025.jpeg C2A5ABC2-13B1-4CD1-9682-0ECB13E90BE8.jpeg 49A07254-E58A-45A1-94C7-FAFDABECE1C0.png
                                  • Claus1985
                                    @simatec und hier noch die FTP Einstellungen für Backitup (gleiche Daten funktionieren über FileZilla):
                                    Danke Dir für Deine Mühe und Arbeit!!
                                    • simatec
                                      @claus1985
                                      Setze mal den Hacken bei smb v1 Unterstützung in der FB und aktiviere smb1 in Backitup
                                      • Claus1985
                                        @simatec hat leider nichts geholfen, bleibt nach wie vor hängen
                                        • simatec
                                          @claus1985
                                          Dann sehe ich hier nur noch das generelle Dateisystem mit NTFS auf deinem USB Stick. Das Filesystem würde ich ändern.
                                          • Claus1985
                                            @simatec ok, Teste ich aus. Einfach FAT32?
                                            Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                                            3883
