    4. Test Adapter lovelace v1.2.x
      Erstam Developer @Erstam last edited by
      Leider stürzt Lovelace jetzt sofort ab, wenn ich einen input_datetime anzulegen versuche. Hier der Datenpunkt, bevor ich versuche, diesen als "input_datetime" zu definieren:
        "_id": "0_userdata.0.time",
        "type": "state",
        "common": {
          "name": "time",
          "role": "date",
          "type": "number",
          "read": true,
          "write": true,
          "desc": "Uhrzeit"
        "native": {},
        "user": "system.user.admin",
        "ts": 1617949846826,
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Sobald ich jetzt diesen als "input_datetime" definiere, passiert folgendes:
      2021-04-09 08:37:01.007 - error: lovelace.0 (18681) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-09 08:37:01.008 - error: lovelace.0 (18681) unhandled promise rejection: Cannot read property 'warn' of undefined
      2021-04-09 08:37:01.010 - error: lovelace.0 (18681) TypeError: Cannot read property 'warn' of undefined
      at Object.entity.context.STATE.getParser (/opt/iobroker/node_modules/iobroker.lovelace/lib/converters/input_datetime.js:53:26)
      at /opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:855:50
      at Array.forEach ()
      at WebServer.onStateChange (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:837:22)
      at WebServer._getAllStates (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:708:30)
      at async WebServer._readAllEntities (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:262:9)
      at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2706:21)
      2021-04-09 08:37:01.010 - error: lovelace.0 (18681) Cannot read property 'warn' of undefined
      2021-04-09 08:37:01.027 - info: lovelace.0 (18681) cleaned everything up...
      2021-04-09 08:37:01.029 - info: lovelace.0 (18681) terminating
      2021-04-09 08:37:01.030 - warn: lovelace.0 (18681) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-09 08:37:01.661 - error: host.LH2io Caught by controller[0]: Unknown request: {"type":"config/area_registry/list","id":25}
      2021-04-09 08:37:01.666 - error: host.LH2io Caught by controller[1]: Unknown request: {"type":"config/device_registry/list","id":26}
      2021-04-09 08:37:01.666 - error: host.LH2io Caught by controller[1]: Unknown request: {"type":"config/entity_registry/list","id":27}
      2021-04-09 08:37:01.667 - error: host.LH2io instance system.adapter.lovelace.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-09 08:37:01.668 - info: host.LH2io Restart adapter system.adapter.lovelace.0 because enabled
      • Garfonso
        Garfonso Developer @Erstam last edited by
        @erstam said in Test Adapter lovelace v1.2.x:
        Das ist mir jetzt peinlich!
        Das muss dir nicht peinlich sein, das ging mir am Anfang auch so. 🙂
        Leider ist das bisher die einzige Form, die ich gefunden hab, mit der npm auch sicher immer die aktuellste Version aus dem Branch nimmt. Mit anderen URLs nimmt er irgendwie immer nur den master branch oder auch mal veraltete Versionen... ist etwas strange. Aber mit der URL geht es halt gut. 🙂
        Zu deinen Fehlern:
        Die sind, weil ich mal wieder die Log-Funktionen falsch aufrufe... eigentlich wollte der Adapter dir ne Warnung ausgeben, dass er den Inhalt des Objekts nicht in ein Datum verwandeln konnte... vielleicht sollte ich die Warnung noch wegmachen? Was stand denn drinnen? Noch nichts? -> das sollte ich vielleicht dann einfach ignorieren.
        Hab den Fehler jedenfalls gerade gefixt & gepusht.
          arni_h last edited by
          Ist es eigentlich möglich, den Titel im IObroker zu ändern? Das icon kann geändert werden, aber beim Titel steht immer "Übersicht - iobroker"?
            a13xde last edited by a13xde
            Ich versuche mich aktuell in Lovelace einzuarbeiten, stehe allerdings gerade auf dem Schlauch. Vielleicht könnt Ihr mir ja die Richtung weisen 🙂 Ich würde gerne Logitech Harmony Activities schalten und anzeigen lassen welche davon gerade aktiv ist. Das Activity Objekt im Harmony Adapter hat 4 Status:
            "0" -> aus
            "1" -> anschalten
            "2" -> ist aktiv
            "3" -> startet gerade
            Ich würde nun gerne einen Button erstellen der die Status "1" für anschalten und "0" für ausschalten sendet wenn man darauf klickt (toggle). Wenn der status "2" ist soll es als angeschaltet angezeigt werden.
            Könnte mir jemand einen Beispielcode dafür zeigen ?
            Ich hatte versucht es mit input_select und "states" zu lösen, bekomme es aber nicht hin:
                "states": {
                  "0": "off",
                  "1": "on"
                "custom": {
                  "lovelace.0": {
                    "enabled": true,
                    "entity": "input_select",
                    "name": "DG_HARMONY_SHIELD"
            • Z
              zyv last edited by
              Hi zusammen,
              yet another noob 😉
              Ich hab mir einen Conbee 2 Stick zugelegt und ihn in meine Iobroker docker install welche auf einem Unraid system läuft eingebunden. Läuft soweit so gut. Bin gerade dabei den ersten Sensor einzubinden, und in Lovelace zu visualisieren und hier Verzweifle ich bereits. Der Sensor wird in Phoscon und im Deconz Adapter erkannt:
              Weiterhin ist er auch unten den Objekten zu sehen:
              Ich habe die Zuordnung des Raumes und der Funktion, sowie der Rolle entsprechend durchgeführt.
              Zur Kontrolle hab ich auch den Device Adapter installiert:
              Auch das scheint zu passen.
              Aber nun zum Problem: bei den Entitäten in Lovelace taucht nur die Temperatur auf. Die Luftfeuchtigkeit krieg ich nicht angezeigt (versuche mich bereits seit ein paar Stunden und habe auch den Thread sowie ein paar andere durchsucht)
              Könnte ihr mir bitte helfen, denn das erscheint mir eigentlich echt simple und ich zweifle hier gerade echt an meiner Intelligenz 😞
              Lovelace 1.0.16
              Vielen Dank im voraus!
              • Garfonso
                Garfonso Developer @arni_h last edited by
                @arni_h said in Test Adapter lovelace v1.2.x:
                Ich meine das hatten wir schonmal... kann mich aber nicht dran erinnern, wie die Lösung war... ich glaube das geht nicht so ohne weiteres (hab beim gucken gerade noch nicht verstanden wer jetzt wo den Tittel überhaupt konfiguriert grübel)
                • Garfonso
                  Garfonso Developer @a13xde last edited by
                  @a13xde said in Test Adapter lovelace v1.2.x:
                  "0" -> aus
                  "1" -> anschalten
                  "2" -> ist aktiv
                      "states": {
                        "0": "off",
                        "1": "on"
                      "custom": {
                        "lovelace.0": {
                          "enabled": true,
                  Also der Ansatz mit input_select würde zu einem Dropdown führen. Allerdings muss das "states"-Objekt im "common"-Teil des Objekts sein. Und es wäre natürlich noch gut die anderen states hinzuzufügen, sonst werden die zu "unknown" führen...
                  Knöpfe gehen damit dann auch, wenn du einen service call nutzt, so ca. (statt toggle):
                  action:
                      service: input_select.select_option
                      target:
                        entity_id: input_select.DG_HARMONY_SHIELD
                      data:
                        option: "on"
                  ob du bei "option" irgendwie dynamische "on" / "off" rein kriegst für an / aus, weiß ich nicht... könnte aber sein. (was bei option rein kommt, muss halt wie die rechte Seite im states-Objekt heißen).
                  Da musst du auch selber nochmal forschen oder jemand anders guckt. Bei mir ist es nen dropdown, finde ich auch nicht so verkehrt. 🙂 (wobei ich mir das mit einem skript gebastelt hab, dass ich zwischen allen Aktivitäten aussuchen kann und da halt auch "PowerOff" mit dabei ist).
                  • Garfonso
                    Garfonso Developer @zyv last edited by
                    @zyv said in Test Adapter lovelace v1.2.x:
                    Lovelace 1.0.16
                    Daran liegt es, leider... irgendwie muss da nochmal was neueres in stable... bin da aber schlecht drin... sorry.. 😞
                    Du hast zwei Optionen:
                    a) lovelace 1.5.0 aus dem latest installieren (müsste mit admin->adapter irgendwie machbar sein auch ohne alles auf latest umzustellen oder aus lovelace aus github installieren)
                    b) du baust mit dem Geräte-Adapter Alias Temperatur-Sensoren die als zweiten Sensor den Feuchtigkeitssensor haben, dann kriegst du zwei entities in lovelace.
                      a13xde @Garfonso last edited by a13xde
                      @garfonso said in Test Adapter lovelace v1.2.x:
                      Jep ist im "common" Teil des Objekts, allerdings finde ich das Dop-Down nicht ideal und ich habe es auch nicht geschafft dann die option aktiv zu halten die gerade genutzt wird weil der state dann ja zu "2" wird wenn es gestartet ist.
                      action:
                          target:
                          data:
                            option: "on"
                      Das hatte ich auch versucht, bin mit dem service call aber nicht zurecht gekommen, an dieser Stelle mal Danke für das Beispiel, ich versuche es mal so !
                      • Z
                        zyv @Garfonso last edited by
                        @garfonso super, danke für deine Antwort. Ich hoffe das war nicht zu offensichtlich zu ersehen in den release notes. Falls doch: sorry für den unnötigen Post. Aber dann weiß ich jetzt wo ich lang muss ich schau mal ob ich das hinkriege 🙂
                        • nukleuz
                          nukleuz last edited by nukleuz
                          ist es möglich einen Datenpunkt, dem sein Inhalt ein Base64 codiertes Bild ist, in Lovelace anzuzeigen?
                          data:image/jpeg;base64,/9j/2wCEAAsHCAoIBwsKCQoM..................................................................
                          Wenn nicht, dann bitte ich um Hilfe bei folgender Problemstellung:
                          Ich möchte nach Bewegungserkennung meiner Reolink-Kamera einen Snapshot machen - das Bild speichern und mir in Lovelace anzeigen lassen. Ich habe das Bild als Base64-Code in einem Datenpunkt und auch als jpg/png im Ordner /home/iobroker/snapshot.jpg liegen.
                          Gebe ich diesen Pfad (/home/iobroker/snapshot.jpg) in der Card -> Picture/Picture Entity an, wird mir nichts angezeigt.
                          Ich habe auch schon versucht das Bild in /cards/ abzulegen, doch da funktioniert es ebenfalls nicht bzw. es wird mir immer nur das erste gespeicherte Bild angezeigt, aber nie das aktuellste. Datei wird bei Bewegung überschrieben.
                          Also, wo kann ich es ablegen damit es angezeigt wird (vielleicht auch zu einfach oder nur ne Blockade :))?
                          Wie habt ihr sowas gelöst?
                          Danke für Infos vorab.
                          Garfonso 2 Replies Last reply Reply Quote 0
                          • Garfonso
                            Garfonso Developer @nukleuz last edited by
                            @zyv
                            Kein Thema. Das Problem ist, dass stable schon wieder so veraltet ist... muss ich/bluefox mal ran.
                            @nukleuz
                            direkt data:image anzeigen fällt mir gerade nichts zu ein. Du könntest es mal manuell als "camera" entity oder sowas versuchen. Bin mir aber gerade nicht sicher, ob Lovelace das unterstützt.
                            Als Icon für ein Entity geht es, aber als Inhalt konnte ich nichts finden.
                            Ansonsten:
                            Du kannst einen "camera" entity machen, der auf die URL von dem Bild zeigt, falls das irgendwo per web erreichbar ist, das wird regelmäßig abgefragt (wie oft kann man in der Karte dazu einstellen, meine ich).
                            Wenn der Snapshot nicht eh irgenwo rum liegt, kannst du das Bild auch per Javascript Adapter + writeFile in den Namespace von einem Adapter hochladen und dann dessen URL angeben. In lovelace/cards geht damit vermutlich auch (und zusammen mit camera entity).
                            Falls das nicht weiterhilf, muss ich später nochmal in Ruhe überlegen 😉
                              Erstam Developer @Garfonso last edited by
                              @garfonso : So, jetzt bin ich endlich mal zum Testen des input_datetime gekommen. Grundsätzlich funktioniert die Entity, außer, dass ich einen "input_datetime" mit nur einem Zeitwert (also "has_date": false, "has_time": true) nicht so hinbekomme, wie ich das erwarte. Die Entity mit nur einem Zeitwert hat bei den Einstellungen ebenfalls ein Datum.
                              So sehen die drei input_datetime in einer Entity Card aus:
                              Und hier die drei Entities aus iobroker:
                              Nur Datum
                                "_id": "0_userdata.0.date",
                                "type": "state",
                                "common": {
                                  "name": "date",
                                  "role": "date",
                                  "type": "number",
                                  "read": true,
                                  "write": true,
                                  "desc": "Datum",
                                  "custom": {
                                    "lovelace.0": {
                                      "enabled": true,
                                      "entity": "input_datetime",
                                      "name": "Datum",
                                      "has_date": true,
                                      "has_time": false
                                "native": {},
                                "ts": 1618051146774,
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              Nur Zeit
                                "type": "state",
                                "common": {
                                  "name": "time",
                                  "role": "date",
                                  "type": "number",
                                  "read": true,
                                  "write": true,
                                  "desc": "Uhrzeit",
                                  "custom": {
                                    "lovelace.0": {
                                      "enabled": true,
                                      "name": "Zeit",
                                      "has_time": true,
                                      "has_date": false
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              Datum und Zeit
                                "ts": 1618050479040,
                                "common": {
                                  "name": "datetime",
                                  "role": "date",
                                  "type": "number",
                                  "desc": "Datum und Zeit",
                                  "read": true,
                                  "write": true,
                                  "custom": {
                                    "lovelace.0": {
                                      "enabled": true,
                                      "name": "DatumZeit",
                                      "has_time": true,
                                      "has_date": true
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "state": 1636
                                "_id": "0_userdata.0.datetime",
                                "type": "state"
                              Garfonso nukleuz 2 Replies Last reply Reply Quote 1
                                janhp last edited by
                                @Garfonso QQ: Ich habe 2x switch.XXX; allerdings wird 1x das blitz icon als toggle angezeigt und 1x der schalter toggle. Ich würde das gerne einheitlich machen --> beide als schalter. hast du eine idee?
                                über input.XXX lässt sich der state leider nicht einfärben, weshalb ich den datenpunkt gerne als switch.XXX lassen würde.
                                  janhp @janhp last edited by
                                  Ich habe ein weiteres Problem mit der custom card mini-graph-card
                                  Nachdem ich die js (wie bisher mit anderen custom-cards auch) in die iobroker instanz gezogen habe und den adapter neu gestartet habe... passiert leider nichts. in der raw datei ist der eintrag des modules vorhanden
                                  • Garfonso
                                    @erstam
                                    ok, gucke ich mir nochmal an.
                                    @janhp said in Test Adapter lovelace v1.2.x:
                                    Das liegt am Attribut "assumed_state". Im Moment ist das Verhalten so, dass automatisch erstellte Entities assumed_state: false haben (dann kommt der Schalter) und manuell erstellte entities immer assumed_state: true haben, dann kommen die zwei Blitze.
                                    Ich will das noch ändern, bin aber noch nicht so ganz sicher, wie... beim automatischen entity werde ich vermutlich bald einbauen, dass man es zumindest über Bearbeiten des custom-Teil im Objekt-Editor einstellen kann (geht noch nicht).
                                    Bis dahin kannst du halt "einfach" die Erstellung angleichen. 🙂
                                    Hast du nach dem Neustart etwas gewartet? Das Laden der Dateien dauert im Moment irgendwie etwas... da hab ich etwas umgestellt und offensichtlich nicht so optimal gelöst... daher kommt es dazu, wenn das UI angezeigt werden soll, aber der Adapter die Karten noch nicht gelesen hat. Das ist zumindest ein häufiges Problem.
                                    (den modules-Eintrag in der Raw-Datei kannst du löschen, den braucht Lovelace nicht mehr)
                                      janhp @Garfonso last edited by
                                      wo genau soll ich assumed_state: false eintragen? nach eintragen nach objekt state+raw hat sich leider nichts verändert.
                                      danke dir schon mal!
                                      • Garfonso
                                        Garfonso Developer @janhp last edited by
                                        @janhp
                                        Noch geht das nicht. Wenn dann in einer neuen Version. Wenn das soweit ist, melde ich mich.
                                        Aktuell kriegst du das nur gleich, wenn beides manuell oder automatisch generiert wird.
                                          andyb last edited by
                                          ich bin noch recht am Anfang, aber langsam steig ich dahinter. Etwas verstehe ich nicht.....
                                          Ich hab unterschiedliche Darstellung in Chrome und Fully Kiosk Browser. Cache habe ich bei beiden geleert, aber:
                                          Eigentlich will ich die Darstellung wie sie in Chrome ist, so habe ich es auch in der Theme im Skript. Aber in Fully stimmen weder die Farben (Leiste oben) noch wird mein Hintergrund geladen. Mach ich was falsch ob gibt es ein Problem mit Fully (Firefox)?
                                          Chrome:
                                          Fully:
                                          • Garfonso
                                            @nukleuz said in Test Adapter lovelace v1.2.x:
                                            Hab grad noch eine Lösung in Discord mit Markdown Card gesehen:
                                            https://cdn.discordapp.com/attachments/767748795102396420/828438285138919424/unknown.png
                                            nukleuz 1 Reply Last reply Reply Quote 0
                                            lovelace visualization
                                            78
                                            1514
                                            559310
