    4. IoBroker Images für BananaPi, Cubietruck und Cubox i4
      derrapf last edited by
      So.
      Habe alles was mit VIS* zu tun hat deleted, den Cache gecleant und alles neu geadded. Diesmal per Script damit ich's öfter machen kann.
      #!/bin/sh
      cd /opt/iobroker
      ./iobroker stop
      sudo npm cache clean
      ./iobroker add vis
      ./iobroker add vis-metro
       ./iobroker add vis-rgraph
       ./iobroker add vis-plumb
       ./iobroker add vis-players
       ./iobroker add vis-map
       ./iobroker add vis-keyboard
       ./iobroker add vis-lcars
       ./iobroker add vis-justgage
       ./iobroker add vis-hqwidgets
       ./iobroker add vis-jqui-mfd
       ./iobroker add vis-fancyswitch
       ./iobroker add vis-colorpicker
       ./iobroker add vis-canvas-gauges
       ./iobroker add vis-bars
       ./iobroker add vis-google-fonts
       ./iobroker add vis-history
       ./iobroker start
      Kein Unterschied. Die Metro Widgets funktionieren nicht.
      Ich hab auch das Log voller Fehler mit denen ich nichts anfangen kann:
      Broker-BPi	2017-01-09 00:36:15.384	info	host.ioBroker-BPi Restart adapter system.adapter.javascript.0 because enabled
      ioBroker-BPi	2017-01-09 00:36:15.379	error	host.ioBroker-BPi instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:36:15.110	info	javascript.0 received all objects
      javascript.0	2017-01-09 00:36:13.639	info	javascript.0 received all states
      javascript.0	2017-01-09 00:36:10.416	info	javascript.0 requesting all objects
      javascript.0	2017-01-09 00:36:10.415	info	javascript.0 requesting all states
      javascript.0	2017-01-09 00:36:10.413	info	javascript.0 starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      ioBroker-BPi	2017-01-09 00:36:04.442	info	host.ioBroker-BPi instance system.adapter.javascript.0 started with pid 19274
      ioBroker-BPi	2017-01-09 00:35:34.264	info	host.ioBroker-BPi Restart adapter system.adapter.javascript.0 because enabled
      ioBroker-BPi	2017-01-09 00:35:34.263	error	host.ioBroker-BPi instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:35:33.832	info	javascript.0 received all objects
      javascript.0	2017-01-09 00:35:32.352	info	javascript.0 received all states
      javascript.0	2017-01-09 00:35:29.197	info	javascript.0 requesting all objects
      javascript.0	2017-01-09 00:35:29.196	info	javascript.0 requesting all states
      javascript.0	2017-01-09 00:35:29.195	info	javascript.0 starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      ioBroker-BPi	2017-01-09 00:35:23.227	info	host.ioBroker-BPi instance system.adapter.javascript.0 started with pid 19237
      host.ioBroker-BPi	2017-01-09 00:34:52.964	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-BPi	2017-01-09 00:34:52.962	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:34:52.860	info	terminating
      javascript.0	2017-01-09 00:34:52.668	error	at Zlib.callback (zlib.js:625:5)
      javascript.0	2017-01-09 00:34:52.668	error	at TransformState.afterTransform (_stream_transform.js:54:12)
      javascript.0	2017-01-09 00:34:52.668	error	at afterTransform (_stream_transform.js:79:3)
      javascript.0	2017-01-09 00:34:52.668	error	at WritableState.onwrite (_stream_writable.js:89:5)
      javascript.0	2017-01-09 00:34:52.668	error	at onwrite (_stream_writable.js:345:7)
      javascript.0	2017-01-09 00:34:52.668	error	at afterWrite (_stream_writable.js:354:3)
      javascript.0	2017-01-09 00:34:52.668	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
      javascript.0	2017-01-09 00:34:52.668	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
      javascript.0	2017-01-09 00:34:52.668	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      javascript.0	2017-01-09 00:34:52.668	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      javascript.0	2017-01-09 00:34:52.668	error	at WebSocket.emit (events.js:172:7)
      javascript.0	2017-01-09 00:34:52.668	error	at emitTwo (events.js:87:13)
      javascript.0	2017-01-09 00:34:52.668	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      javascript.0	2017-01-09 00:34:52.668	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      javascript.0	2017-01-09 00:34:52.668	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2017-01-09 00:34:52.668	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2017-01-09 00:34:52.668	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:34:52.668	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
      javascript.0	2017-01-09 00:34:52.668	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
      javascript.0	2017-01-09 00:34:52.668	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:34:52.668	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:34:52.668	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      javascript.0	2017-01-09 00:34:52.668	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      javascript.0	2017-01-09 00:34:52.668	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      javascript.0	2017-01-09 00:34:52.668	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:34:52.668	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      javascript.0	2017-01-09 00:34:52.668	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:34:52.668	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:34:52.668	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2017-01-09 00:34:52.668	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      javascript.0	2017-01-09 00:34:52.668	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
      javascript.0	2017-01-09 00:34:52.668	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
      javascript.0	2017-01-09 00:34:52.668	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
      javascript.0	2017-01-09 00:34:52.668	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
      javascript.0	2017-01-09 00:34:52.668	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:34:52.632	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:34:52.339	info	received all objects
      javascript.0	2017-01-09 00:34:50.557	info	received all states
      javascript.0	2017-01-09 00:34:47.038	info	requesting all objects
      javascript.0	2017-01-09 00:34:47.030	info	requesting all states
      javascript.0	2017-01-09 00:34:46.999	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      host.	2017-01-09 00:34:46.826	info	States connected to redis 127.0.0.1:6379
      host.ioBroker-BPi	2017-01-09 00:34:40.532	info	instance system.adapter.javascript.0 started with pid 19182
      host.ioBroker-BPi	2017-01-09 00:34:09.655	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
      host.ioBroker-BPi	2017-01-09 00:34:09.186	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-BPi	2017-01-09 00:34:09.183	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:34:09.062	info	terminating
      javascript.0	2017-01-09 00:34:09.010	error	at Zlib.callback (zlib.js:625:5)
      javascript.0	2017-01-09 00:34:09.010	error	at TransformState.afterTransform (_stream_transform.js:54:12)
      javascript.0	2017-01-09 00:34:09.010	error	at afterTransform (_stream_transform.js:79:3)
      javascript.0	2017-01-09 00:34:09.010	error	at WritableState.onwrite (_stream_writable.js:89:5)
      javascript.0	2017-01-09 00:34:09.010	error	at onwrite (_stream_writable.js:345:7)
      javascript.0	2017-01-09 00:34:09.010	error	at afterWrite (_stream_writable.js:354:3)
      javascript.0	2017-01-09 00:34:09.010	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
      javascript.0	2017-01-09 00:34:09.010	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
      javascript.0	2017-01-09 00:34:09.010	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      javascript.0	2017-01-09 00:34:09.010	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      javascript.0	2017-01-09 00:34:09.010	error	at WebSocket.emit (events.js:172:7)
      javascript.0	2017-01-09 00:34:09.010	error	at emitTwo (events.js:87:13)
      javascript.0	2017-01-09 00:34:09.010	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      javascript.0	2017-01-09 00:34:09.010	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      javascript.0	2017-01-09 00:34:09.010	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2017-01-09 00:34:09.010	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2017-01-09 00:34:09.010	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:34:09.010	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
      javascript.0	2017-01-09 00:34:09.010	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
      javascript.0	2017-01-09 00:34:09.010	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:34:09.010	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:34:09.010	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      javascript.0	2017-01-09 00:34:09.010	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      javascript.0	2017-01-09 00:34:09.010	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      javascript.0	2017-01-09 00:34:09.010	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:34:09.010	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      javascript.0	2017-01-09 00:34:09.010	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:34:09.010	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:34:09.010	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2017-01-09 00:34:09.010	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      javascript.0	2017-01-09 00:34:09.010	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
      javascript.0	2017-01-09 00:34:09.010	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
      javascript.0	2017-01-09 00:34:09.010	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
      javascript.0	2017-01-09 00:34:09.010	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
      javascript.0	2017-01-09 00:34:09.010	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:34:08.979	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:34:08.766	info	received all objects
      dwd.0	2017-01-09 00:34:08.148	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.dwd, node: v4.5.0
      host.	2017-01-09 00:34:07.775	info	States connected to redis 127.0.0.1:6379
      javascript.0	2017-01-09 00:34:06.729	info	received all states
      javascript.0	2017-01-09 00:34:01.862	info	requesting all objects
      javascript.0	2017-01-09 00:34:01.845	info	requesting all states
      javascript.0	2017-01-09 00:34:01.810	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      host.	2017-01-09 00:34:01.574	info	States connected to redis 127.0.0.1:6379
      host.ioBroker-BPi	2017-01-09 00:34:00.543	info	instance system.adapter.dwd.0 started with pid 19141
      host.ioBroker-BPi	2017-01-09 00:33:55.599	info	instance system.adapter.javascript.0 started with pid 19134
      host.ioBroker-BPi	2017-01-09 00:33:25.511	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-BPi	2017-01-09 00:33:25.509	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:33:25.459	info	terminating
      javascript.0	2017-01-09 00:33:25.276	error	at Zlib.callback (zlib.js:625:5)
      javascript.0	2017-01-09 00:33:25.276	error	at TransformState.afterTransform (_stream_transform.js:54:12)
      javascript.0	2017-01-09 00:33:25.276	error	at afterTransform (_stream_transform.js:79:3)
      javascript.0	2017-01-09 00:33:25.276	error	at WritableState.onwrite (_stream_writable.js:89:5)
      javascript.0	2017-01-09 00:33:25.276	error	at onwrite (_stream_writable.js:345:7)
      javascript.0	2017-01-09 00:33:25.276	error	at afterWrite (_stream_writable.js:354:3)
      javascript.0	2017-01-09 00:33:25.276	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
      javascript.0	2017-01-09 00:33:25.276	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
      javascript.0	2017-01-09 00:33:25.276	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      javascript.0	2017-01-09 00:33:25.276	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      javascript.0	2017-01-09 00:33:25.276	error	at WebSocket.emit (events.js:172:7)
      javascript.0	2017-01-09 00:33:25.276	error	at emitTwo (events.js:87:13)
      javascript.0	2017-01-09 00:33:25.276	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      javascript.0	2017-01-09 00:33:25.276	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      javascript.0	2017-01-09 00:33:25.276	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2017-01-09 00:33:25.276	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2017-01-09 00:33:25.276	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:33:25.276	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
      javascript.0	2017-01-09 00:33:25.276	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
      javascript.0	2017-01-09 00:33:25.276	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:33:25.276	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:33:25.276	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      javascript.0	2017-01-09 00:33:25.276	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      javascript.0	2017-01-09 00:33:25.276	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      javascript.0	2017-01-09 00:33:25.276	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:33:25.276	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      javascript.0	2017-01-09 00:33:25.276	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:33:25.276	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:33:25.276	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2017-01-09 00:33:25.276	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      javascript.0	2017-01-09 00:33:25.276	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
      javascript.0	2017-01-09 00:33:25.276	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
      javascript.0	2017-01-09 00:33:25.276	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
      javascript.0	2017-01-09 00:33:25.276	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
      javascript.0	2017-01-09 00:33:25.276	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:33:25.248	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:33:25.037	info	received all objects
      javascript.0	2017-01-09 00:33:23.403	info	received all states
      javascript.0	2017-01-09 00:33:19.894	info	requesting all objects
      javascript.0	2017-01-09 00:33:19.887	info	requesting all states
      javascript.0	2017-01-09 00:33:19.857	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      host.	2017-01-09 00:33:19.674	info	States connected to redis 127.0.0.1:6379
      host.ioBroker-BPi	2017-01-09 00:33:14.010	info	instance system.adapter.javascript.0 started with pid 19116
      host.ioBroker-BPi	2017-01-09 00:32:43.920	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-BPi	2017-01-09 00:32:43.918	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:32:43.868	info	terminating
      javascript.0	2017-01-09 00:32:43.697	error	at Zlib.callback (zlib.js:625:5)
      javascript.0	2017-01-09 00:32:43.697	error	at TransformState.afterTransform (_stream_transform.js:54:12)
      javascript.0	2017-01-09 00:32:43.697	error	at afterTransform (_stream_transform.js:79:3)
      javascript.0	2017-01-09 00:32:43.697	error	at WritableState.onwrite (_stream_writable.js:89:5)
      javascript.0	2017-01-09 00:32:43.697	error	at onwrite (_stream_writable.js:345:7)
      javascript.0	2017-01-09 00:32:43.697	error	at afterWrite (_stream_writable.js:354:3)
      javascript.0	2017-01-09 00:32:43.697	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
      javascript.0	2017-01-09 00:32:43.697	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
      javascript.0	2017-01-09 00:32:43.697	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      javascript.0	2017-01-09 00:32:43.697	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      javascript.0	2017-01-09 00:32:43.697	error	at WebSocket.emit (events.js:172:7)
      javascript.0	2017-01-09 00:32:43.697	error	at emitTwo (events.js:87:13)
      javascript.0	2017-01-09 00:32:43.697	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      javascript.0	2017-01-09 00:32:43.697	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      javascript.0	2017-01-09 00:32:43.697	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2017-01-09 00:32:43.697	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2017-01-09 00:32:43.697	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:32:43.697	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
      javascript.0	2017-01-09 00:32:43.697	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
      javascript.0	2017-01-09 00:32:43.697	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:32:43.697	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:32:43.697	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      javascript.0	2017-01-09 00:32:43.697	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      javascript.0	2017-01-09 00:32:43.697	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      javascript.0	2017-01-09 00:32:43.697	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:32:43.697	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      javascript.0	2017-01-09 00:32:43.697	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:32:43.697	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:32:43.697	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2017-01-09 00:32:43.697	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      javascript.0	2017-01-09 00:32:43.697	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
      javascript.0	2017-01-09 00:32:43.697	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
      javascript.0	2017-01-09 00:32:43.697	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
      javascript.0	2017-01-09 00:32:43.697	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
      javascript.0	2017-01-09 00:32:43.697	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:32:43.672	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:32:43.505	info	received all objects
      javascript.0	2017-01-09 00:32:41.871	info	received all states
      javascript.0	2017-01-09 00:32:38.149	info	requesting all objects
      javascript.0	2017-01-09 00:32:38.142	info	requesting all states
      javascript.0	2017-01-09 00:32:38.112	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      host.	2017-01-09 00:32:37.925	info	States connected to redis 127.0.0.1:6379
      host.ioBroker-BPi	2017-01-09 00:32:32.288	info	instance system.adapter.javascript.0 started with pid 19080
      host.ioBroker-BPi	2017-01-09 00:32:02.195	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-BPi	2017-01-09 00:32:02.193	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:32:02.143	info	terminating
      javascript.0	2017-01-09 00:32:02.024	error	at Zlib.callback (zlib.js:625:5)
      javascript.0	2017-01-09 00:32:02.024	error	at TransformState.afterTransform (_stream_transform.js:54:12)
      javascript.0	2017-01-09 00:32:02.024	error	at afterTransform (_stream_transform.js:79:3)
      javascript.0	2017-01-09 00:32:02.024	error	at WritableState.onwrite (_stream_writable.js:89:5)
      javascript.0	2017-01-09 00:32:02.024	error	at onwrite (_stream_writable.js:345:7)
      javascript.0	2017-01-09 00:32:02.024	error	at afterWrite (_stream_writable.js:354:3)
      javascript.0	2017-01-09 00:32:02.024	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
      javascript.0	2017-01-09 00:32:02.024	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
      javascript.0	2017-01-09 00:32:02.024	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      javascript.0	2017-01-09 00:32:02.024	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      javascript.0	2017-01-09 00:32:02.024	error	at WebSocket.emit (events.js:172:7)
      javascript.0	2017-01-09 00:32:02.024	error	at emitTwo (events.js:87:13)
      javascript.0	2017-01-09 00:32:02.024	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      javascript.0	2017-01-09 00:32:02.024	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      javascript.0	2017-01-09 00:32:02.024	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2017-01-09 00:32:02.024	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2017-01-09 00:32:02.024	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:32:02.024	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
      javascript.0	2017-01-09 00:32:02.024	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
      javascript.0	2017-01-09 00:32:02.024	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:32:02.024	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:32:02.024	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      javascript.0	2017-01-09 00:32:02.024	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      javascript.0	2017-01-09 00:32:02.024	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      javascript.0	2017-01-09 00:32:02.024	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:32:02.024	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      javascript.0	2017-01-09 00:32:02.024	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 00:32:02.024	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 00:32:02.024	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2017-01-09 00:32:02.024	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      javascript.0	2017-01-09 00:32:02.024	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
      javascript.0	2017-01-09 00:32:02.024	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
      javascript.0	2017-01-09 00:32:02.024	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
      javascript.0	2017-01-09 00:32:02.024	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
      javascript.0	2017-01-09 00:32:02.024	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:32:01.990	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 00:32:01.790	info	received all objects
      javascript.0	2017-01-09 00:32:00.307	info	received all states
      javascript.0	2017-01-09 00:31:56.721	info	requesting all objects
      javascript.0	2017-01-09 00:31:56.714	info	requesting all states
      javascript.0	2017-01-09 00:31:56.684	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      host.	2017-01-09 00:31:56.511	info	States connected to redis 127.0.0.1:6379
      host.ioBroker-BPi	2017-01-09 00:31:47.851	info	instance system.adapter.javascript.0 started with pid 19043
      host.ioBroker-BPi	2017-01-09 00:31:17.751	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-BPi	2017-01-09 00:31:17.749	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 00:31:17.705	info	terminating
      debug	at Zlib.callback (zlib.js:625:5)
      debug	at TransformState.afterTransform (_stream_transform.js:54:12)
      debug	at afterTransform (_stream_transform.js:79:3)
      debug	at WritableState.onwrite (_stream_writable.js:89:5)
      debug	at onwrite (_stream_writable.js:345:7)
      debug	at afterWrite (_stream_writable.js:354:3)
      debug	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
      debug	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
      debug	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      debug	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      debug	at WebSocket.emit (events.js:172:7)
      debug	at emitTwo (events.js:87:13)
      debug	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      debug	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      debug	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      debug	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      debug	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      debug	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
      Auch auffällig: Obwohl oben im Script nur einmal "add vis-players" steht, kommt ein Fehler, dass man den nicht mehrfach installieren kann:
      host.ioBroker-BPi install adapter vis-plumb
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-plumb"
      got /opt/iobroker/node_modules/iobroker.vis-plumb/admin
      upload [1] vis-plumb.admin /opt/iobroker/node_modules/iobroker.vis-plumb/admin/plumb.png plumb.png image/png
      upload [0] vis-plumb.admin /opt/iobroker/node_modules/iobroker.vis-plumb/admin/index.html index.html text/html
      Adapter "system.adapter.vis.0" restarted.
      host.ioBroker-BPi object system.adapter.vis-plumb created
      host.ioBroker-BPi create instance vis-plumb
      host.ioBroker-BPi object system.adapter.vis-plumb.0 created
      npm install iobroker.vis-players --production --prefix "/opt/iobroker" (System call)
      host.ioBroker-BPi install adapter vis-players
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-players"
      got /opt/iobroker/node_modules/iobroker.vis-players/admin
      upload [0] vis-players.admin /opt/iobroker/node_modules/iobroker.vis-players/admin/players.png players.png image/png
      host.ioBroker-BPi object system.adapter.vis-players created
      host.ioBroker-BPi create instance vis-players
      host.ioBroker-BPi object system.adapter.vis-players.0 created
      host.ioBroker-BPi error: this adapter does not allow multiple instances
      npm install iobroker.vis-map --production --prefix "/opt/iobroker" (System call)
      host.ioBroker-BPi install adapter vis-map
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-map"
      got /opt/iobroker/node_modules/iobroker.vis-map/admin
      upload [1] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/vis-map.png vis-map.png image/png
      upload [0] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index.html index.html text/html
      host.ioBroker-BPi object system.adapter.vis-map created
      host.ioBroker-BPi create instance vis-map
      host.ioBroker-BPi object system.adapter.vis-map.0 created
      npm install iobroker.vis-keyboard --production --prefix "/opt/iobroker" (System call)
      host.ioBroker-BPi install adapter vis-keyboard
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-keyboard"
      got /opt/iobroker/node_modules/iobroker.vis-keyboard/admin
      upload [1] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/keyboard.png keyboard.png image/png
      upload [0] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/index.html index.html text/html
      host.ioBroker-BPi object system.adapter.vis-keyboard created
      host.ioBroker-BPi create instance vis-keyboard
      host.ioBroker-BPi object system.adapter.vis-keyboard.0 created
      npm install iobroker.vis-lcars --production --prefix "/opt/iobroker" (System call)
      Gruss Ralf
        @derrapf:
        Was ist also der Unterschied? Da fallen mir zwei Sachen ein: 1) Das neue System (und ev. andere Treiber) 2) Das verwendete Netzteil, denn so lange ich am Basteln bin verwende ich aktuell ein anderes Netzteil als das, das an dem stabil laufenden BaPi hängt.
        Punkt 2 könnte man ja mal spassehalber ändern. `
        Punkt 2 ist gar nicht so abwegig.
        @derrapf:
        Kannst Du mal bitte parallel schauen ob auf Deinem Image WLAN geht? Wenn ja liegt es an meiner Infrastruktur; `
        Das klingt interessant und reizt mich irgendwie, aber ich habe an einem BPi kein WLAN.
        @derrapf:
        Ev. wurden wirklich defekte Paktet heruntergeladen. `
        @derrapf:
        der Unzip einen Fehler geworfen: Entweder ungültiges Archiv oder Teil eines Archivs bei dem die anderen Teile fehlen `
        also defekt! 😢
        @derrapf:
        Ich würde ja gerne alles auf der Cpmmandline machen (mir ev. sogar ein script schreiben, das alle Adapter installiert) aber ich weiss nicht auswendig wie die Pakete heissen `
        Habe ich für die alten Images auch gemacht (damals hatte ich schon alles vorinstalliert), die Namen bekommst du mit sudo iobroker update
        Rainer
          Hallo Rainer
          "ipbroker update" updated den js-controller?
          Ich trau mich mal. Das hatte schon mal früher meinen IOBroker zerissen. Aber jetzt ist es eh Wurst. Der Produktive läuft ja problemlos.
          EIns noch: Es nervt total dass beim Restart der stop job für den IOBroker 5Minuten lang läuft. Hast Du das auch? Wie kann man denn das abkürzen?
          Gruss Ralf
            @derrapf:
            "ipbroker update" updated den js-controller? `
            Nein, wie bei "apt-get update" werden nur die neuesten Paketlisten geholt.
            @derrapf:
            Es nervt total dass beim Restart der stop job für den IOBroker 5Minuten lang läuft. Hast Du das auch? `
            Nein - ich habe aber im Moment keinen Dualcore mehr im Einsatz. Es ist zwar lange - aber wirklich soo lange würde ich jetzt aus dem Bauch heraus sagen, sollte es nicht sein.
            Könnte deine Hardware vielleicht einen Knacks haben?
            Rainer
              Hallo Rainer
              Erstmal die Guten Nachichten. Ich habe jetzt nochmal per Script alles was mit VIS zu tun hat deleted.
              Interessanterweise wurden da nochmal Dateien gelöscht, obwohl eigentlich die Adapter schon offiziell über die Weboberfläche deleted wurden.
              Ich habe das Script dann sicherheitshalber zweimal laufen lassen.
              Danach den Cache gecleant und wieder das Script zum Hinzufügen der Adapter über Nacht laufen lassen.
              Dann reboot.
              Jetzt sind die Metro Widgets da!!
              Allerdings habe ich immer noch Probleme mit VIS:
              Selbst mit Kabel am Bapi kommt immer wieder das hier:
              und danach wird der Verbindungsfehler angezeigt (siehe Bild in dem anderen Post).
              Im Log kommt auch weiterhin der Fehler
              host.ioBroker-BPi	2017-01-09 13:31:15.697	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
              javascript.0	2017-01-09 13:31:15.652	info	terminating
              javascript.0	2017-01-09 13:31:15.630	error	at Zlib.callback (zlib.js:625:5)
              javascript.0	2017-01-09 13:31:15.630	error	at TransformState.afterTransform (_stream_transform.js:54:12)
              javascript.0	2017-01-09 13:31:15.630	error	at afterTransform (_stream_transform.js:79:3)
              javascript.0	2017-01-09 13:31:15.630	error	at WritableState.onwrite (_stream_writable.js:89:5)
              javascript.0	2017-01-09 13:31:15.630	error	at onwrite (_stream_writable.js:345:7)
              javascript.0	2017-01-09 13:31:15.630	error	at afterWrite (_stream_writable.js:354:3)
              javascript.0	2017-01-09 13:31:15.630	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
              javascript.0	2017-01-09 13:31:15.630	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
              javascript.0	2017-01-09 13:31:15.630	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
              javascript.0	2017-01-09 13:31:15.630	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
              javascript.0	2017-01-09 13:31:15.630	error	at WebSocket.emit (events.js:172:7)
              javascript.0	2017-01-09 13:31:15.630	error	at emitTwo (events.js:87:13)
              javascript.0	2017-01-09 13:31:15.630	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
              javascript.0	2017-01-09 13:31:15.630	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
              javascript.0	2017-01-09 13:31:15.630	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
              javascript.0	2017-01-09 13:31:15.630	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
              javascript.0	2017-01-09 13:31:15.630	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              javascript.0	2017-01-09 13:31:15.630	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
              javascript.0	2017-01-09 13:31:15.630	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
              javascript.0	2017-01-09 13:31:15.630	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              javascript.0	2017-01-09 13:31:15.630	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              javascript.0	2017-01-09 13:31:15.630	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
              javascript.0	2017-01-09 13:31:15.630	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
              javascript.0	2017-01-09 13:31:15.630	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
              javascript.0	2017-01-09 13:31:15.630	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              javascript.0	2017-01-09 13:31:15.630	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
              javascript.0	2017-01-09 13:31:15.630	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              javascript.0	2017-01-09 13:31:15.630	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              javascript.0	2017-01-09 13:31:15.630	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
              javascript.0	2017-01-09 13:31:15.630	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
              javascript.0	2017-01-09 13:31:15.630	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
              javascript.0	2017-01-09 13:31:15.630	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
              javascript.0	2017-01-09 13:31:15.630	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
              javascript.0	2017-01-09 13:31:15.630	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
              javascript.0	2017-01-09 13:31:15.630	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
              javascript.0	2017-01-09 13:31:15.605	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
              javascript.0	2017-01-09 13:31:15.441	info	received all objects
              javascript.0	2017-01-09 13:31:13.984	info	received all states
              Ich kann mir nicht vorstellen, dass die Hardware einen Schuss haben sollte (welchen denn?). Dann würde ja gar nichts gehen.
              Ich kann aber auch gerne mal einen anderen Bapi verwenden.
              Bei Dir beendet sich der Bapi schneller wenn Du "sudo restart" eingibst? Hast das mal gemacht?
              Das einzge was mir jetzt noch einfällt ist, dass ich mir ein Script baue das den Bapi auf Stand bringt und Iobroker updated und ich danach nochmal mit Deinem Image anfange.
              Dazu muss ich mir noch alle Konfigurationsdateien und Scripte aufs NAS kopieren und das dann mounten.
              Gruss Ralf
                Hallo Ralf,
                @derrapf:
                Bei Dir beendet sich der Bapi schneller wenn Du "sudo restart" eingibst? Hast das mal gemacht? `
                Ich habe keinen BPi (Standard) aktiv. Den habe ich nur zur Erstellung des Images aktiviert gehabt.
                Wenn du nicht als root auf der Konsole bist MUSST du immer mit sudo arbeiten.
                Gerade die Befehle stop, start und update, install usw. funktionieren sonst nicht.
                @derrapf:
                Ich kann mir nicht vorstellen, dass die Hardware einen Schuss haben sollte (welchen denn?). Dann würde ja gar nichts gehen. `
                ich könnte mir vorstellen, dass es bei einigen Hardwareschäden, die noch nicht final sind, z.B. bei Speicherproblemen einzelner Zellen oder eines internen controllers (Netzwerk??), der langsam in die Knie geht schon zu solchen Phänomenen kommen könnte.
                @derrapf:
                Das einzge was mir jetzt noch einfällt ist, dass ich mir ein Script baue das den Bapi auf Stand bringt und Iobroker updated und ich danach nochmal mit Deinem Image anfange. `
                Klingt gut:
                Zuerst das dateisystem expandieren, dann mit````
                sudo apt-get update && apt-get upgrade
                Dann am besten ebenfalls aus der Konsole ioBroker aktualisieren:
                cd /opt/iobroker
                sudo iobroker stop
                sudo iobroker upgrade
                sudo iobroker start
                ~~@derrapf:~~
                > Dazu muss ich mir noch alle Konfigurationsdateien und Scripte aufs NAS kopieren und das dann mounten. `
                noch mehr WLAN traffic???
                Viel Glück!
                Rainer
                • Jeeper.at
                  Jeeper.at last edited by
                  Der Websocket Error ist voriges Jahr im November mal hineingekommen.
                  Dazu gibt es folgenden Thread:
                  http://forum.iobroker.net/viewtopic.php?f=22&t=4221
                  Der Fehler ist nach wie vor vorhanden.
                  Lg
                  Günther
                    Hi Rainer
                    @Homoran:
                    Ich habe keinen BPi (Standard) aktiv. Den habe ich nur zur Erstellung des Images aktiviert gehabt. `
                    Mist. Dann hab ich keine Referenz.
                    @Homoran:
                    Gerade die Befehle stop, start und update, install usw. funktionieren sonst nicht. `
                    Ich bin aktuell immer root. Und ich habe auch sudo davor geschrieben.
                    @Homoran:
                    ich könnte mir vorstellen, dass es bei einigen Hardwareschäden, die noch nicht final sind, z.B. bei Speicherproblemen einzelner Zellen oder eines internen controllers (Netzwerk??), der langsam in die Knie geht schon zu solchen Phänomenen kommen könnte. `
                    OK. Dann tausche ich einfach mal die PIs.
                    @Homoran:
                    Zuerst das dateisystem expandieren, dann mitsudo apt-get update && apt-get upgradeLinux auf den neuesten Stand bringen. `
                    Ist das ne gute Idee? Der letzte sudo apt-get upgrade hat das System auf die Bretter gebracht.
                    Obwohl…vielleicht hatte das ja auch mi den WLAN Drops zu tun...
                    @Homoran:
                    cd /opt/iobroker
                    sudo iobroker stop
                    sudo iobroker start
                    Das aktualisiert dann nur die installierten Adapter, richtig?
                    @Homoran:
                    @derrapf:
                    Dazu muss ich mir noch alle Konfigurationsdateien und Scripte aufs NAS kopieren und das dann mounten. noch mehr WLAN traffic???
                    Nein! Ich sagte doch: Der BaPi hängt jetzt erstmal für die Konfiguration am Kabel!!
                    Aber das scheint ja auch nicht viel zu nützen…
                    @Homoran:
                    Viel Glück! `
                    Danke!
                    Ich melde mich. Kann aber ein bischen dauern. Habe heute wieder angefangen zu arbeiten.
                    Gruss Ralf
                    • Jeeper.at
                      Nur für den Fall, das mein Post eine Seite vorher untergegangen ist (haben gerade zeitgleich geschrieben).
                      Lg
                      Günther
                        Hallo Günther
                        Danke für den Hinweis. Ist tatsächlich untergegangen.
                        Ich schau mir den Thread heute abend gleich mal an.
                        Gruss Ralf
                          Hallo Rainer
                          Ich habe jetzt nochmal ganz von vorne angefangen.
                          Dein Image aufgepielt und /etc/defaut/keyboard auf de gesetzt.
                          Dann sudo reboot.
                          Ergebnis:````
                          A stop job is running for LSB: starts ioBroker (5min/5min)
                          Das heisst aus irgendwelchen Gründen braucht das Beenden des iobroker 5 Minuten!
                          Das kann doch nicht sein. Da ist irgendwas fault.
                          Das müsstest Du auch reprduzieren können.
                          Ich habe jetzt leider zu weng Linux KnowHow um zu wissen was man dagegen tut. Aber ev. weiss das jemand anders.
                          Was mir aufällt: Warum heisst es "starts iobroker" wenn ich den Rechner runterfahre? Ist da irgendwo vielleicht was falsch konfiguriert?
                          Gruss Ralf
                            Nächster Statusbericht
                            • Dein Image auf die Karte gespielt (jetzt das dritte Mal)
                            • Plattenplatz erweitert
                            • Password angepasst
                            • Tastatur auf deutsch umgestellt
                            Dann:
                            • apt-get upfate
                            • apt-get upgrade
                            Der bringt am Ende aber zig Fehler:
                            U.a.
                            Bin ich zu doof das System upzugraden? Mach ich was falsch?
                            Kan mir da jemand weiter helfen?
                            Auf jeden Fall ist nach dem Reboot alles am A….
                            Das sieht dann so aus:
                            Gruss Ralf
                              Du bist sicher dass du einen BananaPi hast 😉
                              der BPi hat einen A20 SOC, da müssten oben 2 Pinguine sein, oder ist das schon ein Folgescreen, den ich nie sehe weil ich nur mit putty arbeite?
                              @derrapf:
                              Kan mir da jemand weiter helfen? `
                              Oder ist die Kiste doch defekt?
                              Ich denke, dass ich sonst morgen ein neues Image mache 😉
                              dann kann ich wenigstens parallel testen.
                              Rainer
                                Ein neues BPi-Image ist auf der Website!
                                Läuft bei mir, aber anscheinend funktioniert das Erstinstallscript nicht.
                                Bitte um feedback!
                                Rainer
                                  enricoh831 last edited by
                                  Ich habe das Problem das bei mir mein USB-RS485 mit ftdi Chip nicht funktioniert obwohl er erkannt wird.
                                  Auf Ubuntu läuft er aber vollständig.
                                  Demnach habe ich auch Probleme mit node serialbus und dem modbus Adapter.
                                  Diese Probleme habe ich aber auch unter Ubuntu.
                                  Hab das Gefühl das Jessie Probleme macht.
                                  Gesendet von meinem Pixel mit Tapatalk
                                    Hallo Rainer
                                    Ja, ich bin sicher dass es ein Bapi ist.
                                    Wenn Du ein Image aufgesetzt hast:
                                    Kannst Du bitte mal ein paar Sachen testen:
                                    • Ich habe festgestellt, dass in deinem *.img File tatsächlich "de" in /etc/default/keyboard steht, aber wenn ich das Image auf die Karte spiele, den BaPi Boote und das File ansehe steht "us" drin. Wie kann denn das sein?
                                    • Kannst Du bitte mal nach der Installation einfach mal sudo restart machen?
                                      Hast Du dann auch einen Stop Job für IoBroker der 5 Minuten dauert?
                                    • Kannst du bitte sudo apt-get update & sudo apt-get upgrade machen?
                                      Rennt bei Dir der BaPi danach noch?
                                    PS: Bitte mal per Putty auch eine Weile mal auf dem Ding arbeiten. Dazu eine feste IP vergeben.
                                    Speziell mal ein paar Adapter installieren, Files editieren usw. VIS-Verwenden. Hast Du auch Abbrueche? Bei mir sogar mit LAN Kabel.
                                    Meine interface sieht so aus. Bitte mal ähnliches Einstellungen machen. Bzw.: Wenn Du einen Fehler erkennst, mir mitteilen.
                                    Ich verwende einen Edimax USB WLAN Stick und damit die rt8192cu Treiber. Damit der Edimax nicht in den Ruhezustand geht hab ich das entsprechende File nach /etc/modprobe.d kopiert (siehe auch: https://developer-blog.net/raspberry-pi … ew-7811un/)
                                    # Wired adapter #1
                                       #auto eth0
                                       #allow-hotplug eth0
                                       iface eth0 inet dhcp
                                    # Wireless adapter #1
                                       auto wlan0
                                       allow-hotplug wlan0
                                       iface wlan0 inet static
                                       address 192.168.111.173
                                       netmask 255.255.255.0
                                       gateway 192.168.111.1
                                       broadcast 192.168.111.255
                                       dns-nameservers 8.8.8.8
                                       wpa-ssid ssid_name
                                       wpa-psk password
                                      auto lo
                                       iface lo inet loopback
                                    ` > Ein neues BPi-Image ist auf der Website!
                                    Bitte um feedback! `
                                    Was ist da anders als am Alten?
                                    Kann ich ausprobieren. Beim Alten hat die Erstinstalltion auch nicht geklappt. Die müsste doch den Platz auf der SD Karte erweitern oder? Das hat sie nie gemacht musste man immer manuell machen.
                                    @enricoh831: Ich glabe auch, dass das irgendwas mit Jessie zu tun hat. Bei Wheezy hab ich die WLAN Probleme nicht.
                                    edit: Hab grad das Image ausprobiert. Sudo reboot geh nicht mehr. Der Bapi friert ein ohne weitere Ausgaben
                                    Gruss Ralf
                                      Hallo Ralf,
                                      nur ganz kurz. Werde das alles gerne testen, habe aber vorher auch einiges getestet.
                                      Ich habe das image geschrieben, hochgeladen und anschließend das Image auf wine andere Karte geschrieben. Dateisystem wurde expandiert, Passwort für den user root wird jedoch nicht aufgefordert zu ändern.
                                      Apt-get update && apt-get upgrade hatte ich bereits während der Ersten Installation gemacht, auch mit mehreren reboots, ohne Probleme.
                                      Feste IP habe ich nicht vergeben. Ich arbeite mit in der FritzBox reservierten IPs.
                                      Ich habe stundenlang mit putty gearbeitet, habe die Adapter installiert und die Instanzen erzeugt. Alles ohne Probleme.
                                      Mit WLAN arbeite ich nicht
                                      Rainer
                                        Hallo Rainer
                                        @Homoran:
                                        Hallo Ralf,
                                        Ich habe das image geschrieben, hochgeladen und anschließend das Image auf wine andere Karte geschrieben. Dateisystem wurde expandiert, Passwort für den user root wird jedoch nicht aufgefordert zu ändern. `
                                        Hab ich verifiziert. Stimmt. Aber damit kann ich leben.
                                        @Homoran:
                                        Apt-get update && apt-get upgrade hatte ich bereits während der Ersten Installation gemacht, auch mit mehreren reboots, ohne Probleme. `
                                        Ok. Dann stelle ich das erstmal zurück und gehe davon aus dass das System aktuell genug ist.
                                        @Homoran:
                                        Feste IP habe ich nicht vergeben. Ich arbeite mit in der FritzBox reservierten IPs. `
                                        Ich habe dafür mal auf dhcp gestellt: Macht keinen Unterschied.
                                        @Homoran:
                                        Mit WLAN arbeite ich nicht `
                                        Wie gesagt: WLAN ist fast Wurst. Da tritt es nur häufiger auf.
                                        ABER!!!: Ich habe heute vielleicht einen Anhaltspunkt gefunden: Mein Produktiver Bananapi ging heute mal vom Netz und ist auch seither nicht angemeldet. Und nun ist die SSH-Verbindung zum zweiten Bananapi schon seit über einer Stunde stabil!!
                                        Ein IP-Konflikt kann es nicht sein, da ich ja feste IPs vergebe, aber es geht, denke ich, irgendwie in diese Richtung. Da beide Bananapis ja aus Deinen Images erzeugt wurden: Kann es sein, dass irgendwas bei den beiden gleich ist was da kollidiert? Der Hostname vielleicht? Wobei: Den kann man nicht ändern weil sonst IOBroker nicht mehr läuft. Ich werde im Laufe des Abends mal den produktiven BaPi wieder anwerfen; dann schau ich mal.
                                        Kann ich noch wo anders nachschauen? Was könnte es denn noch für Konflikte geben?
                                        Ich hab aber wieder ein neues Problem, ev. kannst Du mir da auch helfen:
                                        An den BaPis ist über die Klinkenbuchse eine Aktivbox angeschlossen über die der Sayit seine Meldungen ausgibt.
                                        Bei Wheezy musste ich dazu mpg321 und die alsa-utils installieren.
                                        Wenn ich das auf dem Bapi jetzt mache bekomme ich einen Fehler
                                        root@ioBroker-BPi:~# mpg321 /mnt/nas/test.mp3
                                        High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
                                        Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
                                        now maintained by Nanakos Chrysostomos and others.
                                        Uses code from various people. See 'README' for more!
                                        THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
                                        MPEG 1.0 layer III, 192 kbit/s, 44100 Hz joint-stereo
                                        ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
                                        Can't find a suitable libao driver. (Is device in use?)
                                        Ich hab dann versucht libao zu intallieren, aber da kommt
                                        root@ioBroker-BPi:~# apt-get install libao2
                                        Reading package lists... Done
                                        Building dependency tree
                                        Package libao2 is not available, but is referred to by another package.
                                        This may mean that the package is missing, has been obsoleted, or
                                        is only available from another source
                                        E: Package 'libao2' has no installation candidate
                                        Hat jemand ne Idee?
                                        Zu dem Problem mit dem ewig dauernden Stop Job bei Reboot
                                        Da hab ich mal gegoogelt und rausgefunden dass das immer dann passiert, wenn ein Prozess sich weigert auf die üblichen Signale zum Beenden zu hören
                                        Zum Beispiel:
                                        #include <signal.h>
                                        int
                                        main()
                                            signal(SIGTERM, SIG_IGN);
                                            signal(SIGHUP, SIG_IGN);
                                            signal(SIGINT, SIG_IGN);
                                            for (;;);
                                        }</signal.h>
                                        Dann wird er halt nach einiger Zeit hart gekillt. D.h. das müsste dann ein Fehler im IOBroker sein?
                                        Gruss Ralf
                                          @derrapf:
                                          ABER!!!: Ich habe heute vielleicht einen Anhaltspunkt gefunden: Mein Produktiver Bananapi ging heute mal vom Netz und ist auch seither nicht angemeldet. Und nun ist die SSH-Verbindung zum zweiten Bananapi schon seit über einer Stunde stabil!! `
                                          Da sind wir der Sache auf der Spur - ich sag ja schon seit Anfang an: dein Netzwerk ist schuld 😄
                                          @derrapf:
                                          Kann ich noch wo anders nachschauen? Was könnte es denn noch für Konflikte geben? `
                                          Haben die beide die gleiche Mac-Adresse???
                                          @derrapf:
                                          . kannst Du mir da auch helfen: `
                                          eher nicht, wäre aber für mich ggf. auch von Interesse.
                                          Habe mal auf die Schnelle nach (libao und armbian) gegoogelt da steht wohl einiges.
                                          Rainer
                                            derrapf last edited by
                                            Also das mit der Sprachausgabe hab ich hinbekommen.
                                            Ich habe folgendes intalliert:
                                            sudo apt-get install alsa-utils
                                             apt-get install mpg321
                                            Dann folgende Datei erzeugt: /etc/asound.conf
                                            pcm.!default {
                                            type hw
                                            card 0
                                            device 0
                                            ctl.!default {
                                            type hw
                                            card 0
                                            Danach hab ich alsamixer aufgerufen und mit den Einstellungen rumgspielt. Dort war alles gemutet, dewegen hab ich wohl nichts gehört.
                                            Folgende Einstellungen funktionieren bei mir:
                                            lqqqqqqqqqqqqqqqqqqqqqqqqqqqqq AlsaMixer v1.0.28 qqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
                                            x Card: sun4i-codec                                   F1:  Help               x
                                            x Chip:                                               F2:  System information x
                                            x View: F3:[Playback] F4: Capture  F5: All            F6:  Select sound card  x
                                            x Item: Power Amplifier [dB gain: -4,00]              Esc: Exit               x
                                            x        x
                                            x        x
                                            x        x
                                            x        x
                                            x                lqqk                                                         x
                                            x                x  x                                                         x
                                            x                x  x                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x                xaax                                                         x
                                            x      lqqk      mqqj      lqqk      lqqk      lqqk      lqqk      lqqk       x
                                            x      xMMx                xOOx      xMMx      xOOx      xMMx      xMMx       x
                                            x      mqqj                mqqj      mqqj      mqqj      mqqj      mqqj       x
                                            x                 86                                                          x
                                            x    Left Mixe<power amp="">Power Amp Power Amp Power Amp Right Mix Right Mix    x
                                            x        x
                                            x        x
                                            x        x
                                            mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj</power>
                                            Wie man den bedient kann man hier lesen:
                                            https://wiki.ubuntu.com/Audio/Alsamixer
                                            mpg231 spielt nun mp3s ab. Mehr brauche ich grad nicht.
                                            aplay und espeak funktionieren nicht.
                                            speakertest funktioniert.
                                            Aber ich bin erstmal so zufrieden
                                            edit:
                                            • So ganz bin ich doch nicht zufrieden: Nach dem Reboot ist wieder Stille. Man muss den Alamixer immer aufrufen dmit was aus den Speakern kommt. Das ist Sch…. Wenn jemand ne Lösung hat: Als her damit.
                                            • Dann ist es so dass beim Sayit nun immer der Anfang des Stzes verloren geht. Also aus 18:55 wird "zehn Uhr 55". Irgendwie scheint der Lautsprecher erst später zuzuschalten.
                                            nochmal edit:
                                            Ganz stabil scheint es doch nicht zu sein. Ohhh war wheezy schön...
                                            sayit.0	2017-01-17 19:02:57.745	error	Can't find a suitable libao driver. (Is device in use?)
                                            sayit.0	2017-01-17 19:02:57.745	error	MPEG 2.0 layer III, 48 kbit/s, 22050 Hz mono
                                            sayit.0	2017-01-17 19:02:57.745	error	Playing MPEG stream from 7c427f903f78105d349d98b18f5bcbf7.mp3 ...
                                            sayit.0	2017-01-17 19:02:57.745	error	Directory: /opt/iobroker/cache
                                            sayit.0	2017-01-17 19:02:57.745	error	tcgetattr(): Inappropriate ioctl for device
                                            sayit.0	2017-01-17 19:02:57.745	error	THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
                                            sayit.0	2017-01-17 19:02:57.745	error	Uses code from various people. See 'README' for more!
                                            sayit.0	2017-01-17 19:02:57.745	error	now maintained by Nanakos Chrysostomos and others.
                                            sayit.0	2017-01-17 19:02:57.745	error	Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
                                            sayit.0	2017-01-17 19:02:57.745	error	High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
                                            sayit.0	2017-01-17 19:02:57.745	error	Cannot play:Error: Command failed: /bin/sh -c mpg321 /opt/iobroker/cache/7c427f903f78105d349d98b18f5bcbf7.mp3
                                            Gruss Ralf
                                            134
                                            17207
