    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      Michaelnorge last edited by Michaelnorge
      Wieder Absturz 😞
      Der Adapter ist wieder abgeschmiert und auf rot gesprungen.
      Hier der Log:
      2021-04-03 11:58:32.060 - info: bluelink.0 (25067) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.bluelink, node: v10.24.0, js-controller: 3.2.16
      2021-04-03 11:58:32.097 - info: bluelink.0 (25067) Login to api
      2021-04-03 11:58:36.079 - info: bluelink.0 (25067) Vehicles found
      2021-04-03 11:58:36.102 - info: bluelink.0 (25067) Read new status from api
      2021-04-03 11:58:37.018 - error: bluelink.0 (25067) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-03 11:58:37.018 - error: bluelink.0 (25067) unhandled promise rejection: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"8e402db5-xxxx-xxxx-xxxx-ca7029a80d3b"}
      2021-04-03 11:58:37.020 - error: bluelink.0 (25067) ManagedBluelinkyError: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"8e402db5-xxxx-xxxx-xxxx-ca7029a80d3b"}
      at T (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:144032)
      at b. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:152142)
      at Generator.throw ()
      at P (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
      at process._tickCallback (internal/process/next_tick.js:68:7)
      2021-04-03 11:58:37.020 - error: bluelink.0 (25067) @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-x-xxxxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"8e402db5-xxxx-xxxx-xxxx-ca7029a80d3b"}
      2021-04-03 11:58:37.154 - info: bluelink.0 (25067) Adapter bluelink cleaned up everything...
      2021-04-03 11:58:37.155 - info: bluelink.0 (25067) terminating
      2021-04-03 11:58:37.157 - warn: bluelink.0 (25067) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-03 11:58:37.760 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-03 11:58:37.761 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
      2021-04-03 11:58:37.761 - warn: host.raspberrypi Do not restart adapter system.adapter.bluelink.0 because restart loop detected
      Der Adapter hat das drei Mal innerhalb von 2 Minuten gemacht.
      Vielleicht wäre es ja möglich den Adapter bei so einen Fehler auf "Standby" zu setzen für 5 Minuten...
        Aiouh @Newan last edited by Aiouh
        @newan bin wieder im Spiel 🙂 Adapter läuft wieder.
          Aiouh @Michaelnorge last edited by
          @Newan
          Hallo, gestern lief der Adapter sauber durch, heute ist er drei mal mit derselben Meldung wie bei @Michaelnorge abgeschmiert
            Michaelnorge @Aiouh last edited by Michaelnorge
            @aiouh Ich lasse von ioBroker den Status überwachen.
            Wenn der Adapter abschmiert und er nicht mehr läuft dann lasse ich ihn nach 5 Minuten neu starten. Damit kann ich leben 🙂
            Die Fehlermeldung kommt wahrscheinlich wenn der Adapter sich einloggt und man gleichzeitig (oder etwas zeitversetzt) versucht, sich mit dem Handy einzuloggen.
            Die Fehlermeldung bekomme ich auch dann, wenn ich zweimal zu schnell hintereinander auf einer der Control-Buttons klicke (force_refresh, lock, start etc.)
              Aiouh @Michaelnorge last edited by Aiouh
              @michaelnorge ...damit könnte ich auch leben. Ich lass mir das zwar anzeigen wenn der Adapter abgeschmiert ist, aber der Autostart fehlt. Wie startest Du den Adapter neu?
              Hast bestimmt ein Script "übrig" 😉 für das ich schon mal danke sage 🙂
              OK, ich war zu langsam 🙂 Vielen Dank !
                C 1 Reply Last reply Reply Quote 1
                  ChristianF @Michaelnorge last edited by
                  Herzlichen Dank auch von mir für die tolle Arbeit! Es läuft inzwischen auch bei mir soweit gut, nur schmiert der Adapter dann und wann ab.
                  @michaelnorge sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                  Habe mir mal erlaubt das Script abzutippen und von Telegram auf eMail umzuschreiben. Hier als Import für Blockly:
                    <variables>
                    </variables>
                    <block type="on" id="d@jQ0h%wxenZ]n~w+X8o" x="137" y="88">
                      <field name="OID">system.adapter.bluelink.0.connected</field>
                        <block type="timeouts_cleartimeout" id="HNP(jo3{q9a~Y$uun,n2">
                            <block type="controls_if" id="NT=]5=8/G9wjL(t|J9(_">
                                <block type="logic_compare" id="u,Yt3DvIG.avaCdj2yU(">
                                  <field name="OP">EQ</field>
                                    <block type="get_value" id="h7kLazPnEJYk{C?!ZM8W">
                                    <block type="logic_boolean" id="!P.#Zm3GM-@/jrl%g[5#">
                                <block type="timeouts_settimeout" id="=+bwx!]UU!C{f1BH586E">
                                  <field name="DELAY">5</field>
                                    <block type="controls_if" id="kAkokuk7%]N]%c;(f|{C">
                                        <block type="logic_compare" id="?#0*f7irHhpXBqU:24`a">
                                            <block type="get_value" id=")-nuX6yxc2LwQFD-_-%m">
                                            <block type="logic_boolean" id="4QnDuJcN/*KhYg${V}ei">
                                        <block type="exec" id="m/bl2h;?4n?rZ=6Jj6Ty">
                                          <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                          <field name="WITH_STATEMENT">FALSE</field>
                                          <field name="LOG"></field>
                                          <value name="COMMAND">
                                            <shadow type="text" id="[3kh7Y}5i!yIhy)OfIVr">
                                              <field name="TEXT">iobroker restart bluelink.0</field>
                                            <block type="email" id=",nkKLU(h9z#ENWecfY-g">
                                              <field name="IS_HTML">FALSE</field>
                                              <value name="TO">
                                                <shadow type="text" id="1x1ZkN$Y~wb1E`IfT?7E">
                                                  <field name="TEXT">xy@z.de</field>
                                              <value name="TEXT">
                                                <shadow type="text" id="oq2@Z*f/9(v=[eV#5W*I">
                                                  <field name="TEXT">Bluelink Adapter war abgestürzt</field>
                                              <value name="SUBJECT">
                                                <shadow type="text" id="u?7SG}|q4}9:+KAG!}Z3">
                  Newan 1 Reply Last reply Reply Quote 1
                  • Newan
                    Newan @ChristianF last edited by
                    War ein bisle in Osterurlaub ;-). Ich möchte den Adapter erstmal im Katalog haben, das sieht ganz gut aus. Danach muss ich dann mal einen Account haben den ich "sehr benutzen" kann, um den Fehler nachzustellen. Dann würde ich den Adapter zumindest so bauen das er nicht neu gestartet werden muss.
                      @newan Servus, mach Dir keinen Stress. Ich denke wir können das schon wieder so machen dass Du meinen Account dann nutzen kannst, sobal Kia meine Accounts bereinigt hat. Da klemmt noch immer was, vermutlich weil meine Frau und ich zwei Accounts haben, was ja grundsätzlich seitens Kia möglich ist. (shared account).
                        dominic78 last edited by
                        Ich hab nun auch mal mit dem Adapter etwas rum gespielt. Ich habe jedoch noch Probleme damit. So sieht meine VIS aus.
                        Ich kann die Tür via lock zwar schließen aber viel mehr funktioniert bei mir nicht. Reichweite und Gesamt-km zeigt er an.
                        Die Fernsteuerung und Rückmeldung von Tür und Klima haut nicht so richtig hin. Gibt es hier noch einen bug oder etwas anderes was man beachten sollte?
                        Newan 1 Reply Last reply Reply Quote 0
                        • Newan
                          Newan @dominic78 last edited by
                          @dominic78 bekommst du eine Fehlermeldung?
                          Wenn Daten fehlen, Adapter auf debug stellen und response posten (Bitte persönliche daten und Schlüssel entfernen)
                          • docadams
                            docadams last edited by docadams
                            ich habe den Adapter über die Katze installiert und es lief auch mit Fehlercone 0 prima durch.
                            Aber auch nach Aktualisierung erscheint kein neuer Eintrag in Adapter oder Instanzen. Jetzt könnte ich das nicht mal mehr deinstallieren, oder?
                            Schönes Wochenende
                            EDIT: hat sich erledigt. Er tauchte doch in den Adaptern auf, ich musste aber erst noch eine Instanz installieren.
                              FluffyIronBoots @Newan last edited by
                              @newan
                              Vielen Dank für die gute Arbeit. Der Adapter funktioniert ganz gut nachdem ich mein bluelink Konto auf ein hyundai Konto umgestellt habe. Das Auto ist ein Hyundai Ioniq Facelift. Alle daten werden bis jetzt korrekt ausgelesen, auf- und zusperren funnktioniert ohne Probleme. Nur die Klima steuerung hab ich noch nicht getestet.
                              Im Log sehe ich dass sporadisch ein Fehler auftritt und der Adapter neu startet.
                              Dadurch ergibt sich ein kleines Problem, falls der Adapter direkt nach Neustart wieder den gleichen Fehler wirft startet er nicht wieder:
                              2021-04-30 17:34:59.682 - info: bluelink.0 (44432) Vehicles found
                              2021-04-30 17:34:59.689 - info: bluelink.0 (44432) Read new status from api
                              2021-04-30 17:35:01.657 - error: bluelink.0 (44432) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-04-30 17:35:01.657 - error: bluelink.0 (44432) unhandled promise rejection: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/90e5b5c0-67ea-4e88-b34d-ba2b99b7b0a0/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"82c51469-aa46-4eda-b1bd-60d1b92abe55"}
                              2021-04-30 17:35:01.657 - error: bluelink.0 (44432) ManagedBluelinkyError: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/90e5b5c0-67ea-4e88-b34d-ba2b99b7b0a0/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"82c51469-aa46-4eda-b1bd-60d1b92abe55"}
                              at d (C:\Program Files\iobroker\SmartHome\node_modules\bluelinky\dist\index.js:17:144947)
                              at G. (C:\Program Files\iobroker\SmartHome\node_modules\bluelinky\dist\index.js:17:151385)
                              at P (C:\Program Files\iobroker\SmartHome\node_modules\bluelinky\dist\index.js:17:136)
                              2021-04-30 17:35:01.657 - error: bluelink.0 (44432) @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/90e5b5c0-67ea-4e88-b34d-ba2b99b7b0a0/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"82c51469-aa46-4eda-b1bd-60d1b92abe55"}
                              2021-04-30 17:35:01.662 - info: bluelink.0 (44432) Adapter bluelink cleaned up everything...
                              2021-04-30 17:35:01.662 - info: bluelink.0 (44432) terminating
                              2021-04-30 17:35:01.662 - warn: bluelink.0 (44432) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-04-30 17:35:02.189 - error: host.DESKTOP-20F0GB3(SmartHome) instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-04-30 17:35:02.189 - info: host.DESKTOP-20F0GB3(SmartHome) Restart adapter system.adapter.bluelink.0 because enabled
                              2021-04-30 17:35:02.189 - warn: host.DESKTOP-20F0GB3(SmartHome) Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                              Heute hat er insgesamt 7 mal diesen Fehler geworfen und einmal davon direkt 2 mal hintereinander dadurch dann auch kein Neustart mehr.
                                Michaelnorge @FluffyIronBoots last edited by
                                @fluffyironboots Dazu gibt es hier in diesem Post etwas höher eine "Not-Lösung".
                                https://forum.iobroker.net/topic/43592/adapter-hyundai-bluelink-oder-kia-uvo/83?_=1619804863809
                                  Bekomme seit 2 Tagen unregelmäßig folgende Fehlermeldung:
                                  (32733) Error on API-Request GetFullStatus
                                  Sonst jemand mit diesem Problem?
                                  Edit: Ich merke soeben daß es auch via der App zu Problemen kommt. Vielleicht liegt´s am Hyundai-Server? Der ist aber auch lahm....
                                  • Newan
                                    Newan @Michaelnorge last edited by
                                    @michaelnorge Das mein neues error handling. Es werden nun Serverfehler angefangen damit der Adapter sich net aufhängt.
                                    Im debug sollte er mehr Infos ausgeben welches Problem genau.
                                      Michaelnorge @Newan last edited by
                                      @newan Achso ja danke 😉
                                        Dein Adapter taucht hier noch gar nicht auf:
                                        http://download.iobroker.net/list.html#sortCol=created&sortDir=1&filter=
                                        • Newan
                                          @michaelnorge Ka der ist ja noch in Prüfung. Wenn die abgeschlossen ist kommt er in den Katalog
                                            Ich bekomme seit nunmehr drei Tagen immer wieder diese Fehlermeldung:
                                            2021-05-27 16:10:34.717 - error: bluelink.0 (19161) ManagedBluelinkyError: @EuropeController.login: [401] Unauthorized on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/notifications/register - {"retCode":"F","resCode":"4017","resMsg":"Invalid request value - Invalid Application Id.","msgId":"xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx"}
                                            Der Adapter gibt keine Daten mehr aus. Neustart/Boot hat nichts gebracht.
                                            Noch jemand mit diesem Problem?
                                            M L 2 Replies Last reply Reply Quote 0
                                            2295
                                            857520
