    4. Zigbee Adapter: Test der umgeschriebenen Gruppenfunktion
      luie @Asgothian last edited by luie
      @asgothian
      ich habe die Geräte aus den Gruppen gelöscht und wieder hinzugefügt. Hoffe der log ist jetzt richtig?
      2021-04-08 13:27:45.286 - warn: zigbee.0 (22631) Trying to add device 0x84182600000a21ea to group 1
      2021-04-08 13:28:03.412 - warn: zigbee.0 (22631) Trying to add device 0x00178801011a95ad to group 1
      2021-04-08 13:28:03.626 - error: zigbee.0 (22631) Exception when trying to configure reporting for 0x00178801011a95ad when adding to group 1. TypeError: ConfigureReporting 0x00178801011a95ad/11 genOnOff([{"attribute":"onOff","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":1}], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (payload is not iterable)
      2021-04-08 13:28:09.270 - warn: zigbee.0 (22631) Trying to add device 0x00178801011d9fce to group 1
      2021-04-08 13:28:09.445 - error: zigbee.0 (22631) Exception when trying to configure reporting for 0x00178801011d9fce when adding to group 1. TypeError: ConfigureReporting 0x00178801011d9fce/11 genOnOff([{"attribute":"onOff","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":1}], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (payload is not iterable)
      2021-04-08 13:28:16.963 - warn: zigbee.0 (22631) Trying to add device 0x00178801011ad866 to group 1
      2021-04-08 13:28:17.669 - error: zigbee.0 (22631) Send command to 0x0017880104907516 failed with no error code (no response received)
      2021-04-08 13:28:25.127 - warn: zigbee.0 (22631) Trying to add device 0x0017880102aca26e to group 1
      2021-04-08 13:28:25.265 - error: zigbee.0 (22631) Exception when trying to configure reporting for 0x0017880102aca26e when adding to group 1. TypeError: ConfigureReporting 0x0017880102aca26e/11 genOnOff([{"attribute":"onOff","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":1}], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (payload is not iterable)
      2021-04-08 13:28:49.429 - warn: zigbee.0 (22631) get Groups called with {"command":"getGroups","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":76,"ack":false,"time":1617881329391},"_id":44428532}
      2021-04-08 13:28:49.440 - warn: zigbee.0 (22631) get Groups: groups is {"1":"Wohnzimmer","2":"Küche","3":"Küchentisch","4":"Küche unten","5":"Kinderzimmer","6":"Schlafzimmer","7":"Sonntagmorgen"} [{"databaseID":8,"groupID":1,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]}],"model":"group"},{"databaseID":9,"groupID":2,"_members":{},"meta":{}},{"databaseID":10,"groupID":3,"_members":{},"meta":{}},{"databaseID":21,"groupID":4,"_members":{},"meta":{}},{"databaseID":35,"groupID":5,"_members":{},"meta":{}},{"databaseID":34,"groupID":6,"_members":{},"meta":{}},{"databaseID":39,"groupID":7,"_members":{},"meta":{}},{"databaseID":16,"groupID":129,"_members":{},"meta":{}},{"databaseID":4,"groupID":901,"_members":{},"meta":{}}]
      2021-04-08 13:29:01.477 - warn: zigbee.0 (22631) Trying to add device 0x84182600000a19e7 to group 1
      2021-04-08 13:29:17.510 - error: zigbee.0 (22631) Exception when trying to Add 0x00178801011ad866 to group 1. Error: Command 0x00178801011ad866/11 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
      2021-04-08 13:29:49.518 - error: zigbee.0 (22631) Send command to 0x0017880104907516 failed with no error code (no response received)
      2021-04-08 13:29:49.713 - error: zigbee.0 (22631) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-08 13:29:49.714 - error: zigbee.0 (22631) unhandled promise rejection: undefined
      2021-04-08 13:29:49.715 - info: zigbee.0 (22631) cleaned everything up...
      2021-04-08 13:29:49.718 - info: zigbee.0 (22631) Zigbee: disabling joining new devices.
      2021-04-08 13:29:50.218 - info: zigbee.0 (22631) terminating
      2021-04-08 13:29:50.219 - warn: zigbee.0 (22631) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-08 13:29:50.224 - error: zigbee.0 (22631) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-08 13:29:50.225 - error: zigbee.0 (22631) unhandled promise rejection: received frame size to small
      2021-04-08 13:29:50.225 - error: zigbee.0 (22631) Error: received frame size to small
      at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/frameParser.js:406:15)
      at Object. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/frameParser.js:371:63)
      at Generator.next ()
      at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/frameParser.js:8:71
      at new Promise ()
      at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/frameParser.js:4:12)
      at Object.processFrame [as default] (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/frameParser.js:370:12)
      at Driver. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:57:69)
      at Driver.emit (events.js:314:20)
      at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:729:14)
      2021-04-08 13:29:50.226 - error: zigbee.0 (22631) received frame size to small
      2021-04-08 13:29:50.830 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-08 13:29:50.835 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2021-04-08 13:30:00.131 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 10658
      2021-04-08 13:30:01.680 - info: daswetter.0 (10658) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
      2021-04-08 13:30:15.174 - info: daswetter.0 (10658) got wrong data structure! trying to repair...
      2021-04-08 13:30:19.041 - info: daswetter.0 (10658) Terminated (NO_ERROR): Without reason
      2021-04-08 13:30:19.560 - info: daswetter.0 (10658) cleaned everything up...
      2021-04-08 13:30:19.579 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-04-08 13:30:20.914 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10715
      2021-04-08 13:30:23.135 - info: zigbee.0 (10715) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
      2021-04-08 13:30:23.236 - info: zigbee.0 (10715) Starting Zigbee npm ...
      2021-04-08 13:30:23.563 - info: zigbee.0 (10715) Installed Version: asgothian/ioBroker.zigbee#Groups
      2021-04-08 13:30:23.774 - info: zigbee.0 (10715) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
      2021-04-08 13:30:23.822 - info: zigbee.0 (10715) Unable to disable LED, unsupported function.
      2021-04-08 13:30:23.823 - info: zigbee.0 (10715) --> transmitPower : normal
      Das Gerät "Küche unten" läuft über ein Blockly-script und wird über BWM (Bewegung und Helligkeit) gesteuert.
      • Asgothian
        Asgothian Developer @luie last edited by
        @luie
        Danke für die zusätzlichen Informationen. Was mir nicht klar ist:
        • Ist der Absturz / Neustart des Adapters systematisch, sprich kannst du den erzwingen ?
        • Kommt der Absturz aus dem Gruppen-Befehl oder einem anderen Befehl der an ein ganz anderes Gerät gesandt wird ?
        (Im Log findest du:
        und
        Es ist nicht zu ersehen welche der beiden Meldungen Absturz verursacht.
        A.
          @asgothian
          Ich habe jetzt "Küche unten" aus der Gruppe gelöscht (Haken raus und gespeichert) und kurz danach wieder hinzugefügt (Haken rein und gespeichert).
          Der Adapter Absturz/Neustart kommt häufig vor, aber ich spiele im Moment auch noch sehr viel rum (skripte, node-red, jarvis) habe erst begonnen mich mit dem iobroker zu beschäftigen.
          2021-04-08 16:19:34.442 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2021-04-08 16:20:04.526 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 13857
          2021-04-08 16:20:06.813 - info: zigbee.0 (13857) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
          2021-04-08 16:20:06.921 - info: zigbee.0 (13857) Starting Zigbee npm ...
          2021-04-08 16:20:07.250 - info: zigbee.0 (13857) Installed Version: asgothian/ioBroker.zigbee#Groups
          2021-04-08 16:20:07.452 - info: zigbee.0 (13857) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
          2021-04-08 16:20:07.505 - info: zigbee.0 (13857) Unable to disable LED, unsupported function.
          2021-04-08 16:20:07.505 - info: zigbee.0 (13857) --> transmitPower : normal
          2021-04-08 16:20:07.507 - info: zigbee.0 (13857) Unable to set transmit power, unsupported function.
          2021-04-08 16:20:07.512 - info: zigbee.0 (13857) Currently 29 devices are joined:
          2021-04-08 16:20:07.582 - info: zigbee.0 (13857) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
          2021-04-08 16:20:07.586 - info: zigbee.0 (13857) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
          2021-04-08 16:20:07.588 - info: zigbee.0 (13857) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
          2021-04-08 16:20:07.589 - info: zigbee.0 (13857) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
          2021-04-08 16:20:07.591 - info: zigbee.0 (13857) 0x84182600000a19e7 (addr 33275): AB3257001NJ - OSRAM Smart+ plug (Router)
          2021-04-08 16:20:07.592 - info: zigbee.0 (13857) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
          2021-04-08 16:20:07.594 - info: zigbee.0 (13857) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
          2021-04-08 16:20:07.595 - info: zigbee.0 (13857) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
          2021-04-08 16:20:07.597 - info: zigbee.0 (13857) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
          2021-04-08 16:20:07.598 - info: zigbee.0 (13857) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
          2021-04-08 16:20:07.599 - info: zigbee.0 (13857) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
          2021-04-08 16:20:07.601 - info: zigbee.0 (13857) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
          2021-04-08 16:20:07.602 - info: zigbee.0 (13857) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
          2021-04-08 16:20:07.604 - info: zigbee.0 (13857) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
          2021-04-08 16:20:07.605 - info: zigbee.0 (13857) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
          2021-04-08 16:20:07.606 - info: zigbee.0 (13857) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
          2021-04-08 16:20:07.607 - info: zigbee.0 (13857) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
          2021-04-08 16:20:07.609 - info: zigbee.0 (13857) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
          2021-04-08 16:20:07.610 - info: zigbee.0 (13857) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
          2021-04-08 16:20:07.612 - info: zigbee.0 (13857) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
          2021-04-08 16:20:07.613 - info: zigbee.0 (13857) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
          2021-04-08 16:20:07.615 - info: zigbee.0 (13857) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
          2021-04-08 16:20:07.616 - info: zigbee.0 (13857) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
          2021-04-08 16:20:07.617 - info: zigbee.0 (13857) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
          2021-04-08 16:20:07.618 - info: zigbee.0 (13857) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
          2021-04-08 16:20:07.622 - info: zigbee.0 (13857) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
          2021-04-08 16:20:07.625 - info: zigbee.0 (13857) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
          2021-04-08 16:20:07.627 - info: zigbee.0 (13857) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
          2021-04-08 16:20:07.628 - info: zigbee.0 (13857) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
          2021-04-08 16:20:07.629 - info: zigbee.0 (13857) Zigbee started
          2021-04-08 16:20:38.694 - info: node-red.0 (3069) Save /opt/iobroker/iobroker-data/node-red/flows.json
          2021-04-08 16:22:12.415 - warn: zigbee.0 (13857) Failed to ping 0x7cb03eaa0a066d68 Plug 01
          2021-04-08 16:22:12.416 - warn: zigbee.0 (13857) Failed to ping 0x0017880108e79c10 LOM001
          2021-04-08 16:30:00.091 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 15845
          2021-04-08 16:30:01.730 - info: daswetter.0 (15845) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-08 16:30:15.462 - info: daswetter.0 (15845) got wrong data structure! trying to repair...
          2021-04-08 16:30:19.377 - info: daswetter.0 (15845) Terminated (NO_ERROR): Without reason
          2021-04-08 16:30:19.897 - info: daswetter.0 (15845) cleaned everything up...
          2021-04-08 16:30:19.916 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-08 16:37:28.980 - warn: zigbee.0 (13857) get Groups called with {"command":"getGroups","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":54,"ack":false,"time":1617892648939},"_id":38872076}
          2021-04-08 16:37:28.996 - warn: zigbee.0 (13857) get Groups: groups is {"1":"Wohnzimmer","2":"Küche","3":"Küchentisch","4":"Küche unten","5":"Kinderzimmer","6":"Schlafzimmer","7":"Sonntagmorgen"} [{"databaseID":8,"groupID":1,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]}],"model":"group"},{"databaseID":9,"groupID":2,"_members":{},"meta":{}},{"databaseID":10,"groupID":3,"_members":{},"meta":{}},{"databaseID":21,"groupID":4,"_members":{},"meta":{}},{"databaseID":35,"groupID":5,"_members":{},"meta":{}},{"databaseID":34,"groupID":6,"_members":{},"meta":{}},{"databaseID":39,"groupID":7,"_members":{},"meta":{}},{"databaseID":16,"groupID":129,"_members":{},"meta":{}},{"databaseID":4,"groupID":901,"_members":{},"meta":{}}]
          2021-04-08 16:37:54.456 - warn: zigbee.0 (13857) get Groups called with {"command":"getGroups","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":64,"ack":false,"time":1617892674436},"_id":38872086}
          2021-04-08 16:37:54.464 - warn: zigbee.0 (13857) get Groups: groups is {"1":"Wohnzimmer","2":"Küche","3":"Küchentisch","4":"Küche unten","5":"Kinderzimmer","6":"Schlafzimmer","7":"Sonntagmorgen"} [{"databaseID":8,"groupID":1,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]}],"model":"group"},{"databaseID":9,"groupID":2,"_members":{},"meta":{}},{"databaseID":10,"groupID":3,"_members":{},"meta":{}},{"databaseID":21,"groupID":4,"_members":{},"meta":{}},{"databaseID":35,"groupID":5,"_members":{},"meta":{}},{"databaseID":34,"groupID":6,"_members":{},"meta":{}},{"databaseID":39,"groupID":7,"_members":{},"meta":{}},{"databaseID":16,"groupID":129,"_members":{},"meta":{}},{"databaseID":4,"groupID":901,"_members":{},"meta":{}}]
          2021-04-08 16:38:06.254 - warn: zigbee.0 (13857) Trying to add device 0x0017880104907516 to group 4
          2021-04-08 16:38:06.482 - error: zigbee.0 (13857) Exception when trying to configure reporting for 0x0017880104907516 when adding to group 4. TypeError: ConfigureReporting 0x0017880104907516/11 genOnOff([{"attribute":"onOff","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":1}], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (payload is not iterable)
            luie last edited by
            @asgothian
            2021-04-09 00:45:08.647 - warn: zigbee.0 (29255) Stopping to ping 0x0017880108e79c10 LOM001 after 4 ping attempts
            2021-04-09 00:45:09.646 - warn: zigbee.0 (29255) Stopping to ping 0x7cb03eaa0a066d68 Plug 01 after 4 ping attempts
            2021-04-09 00:45:14.233 - info: daswetter.0 (18232) got wrong data structure! trying to repair...
            2021-04-09 00:45:17.850 - info: daswetter.0 (18232) Terminated (NO_ERROR): Without reason
            2021-04-09 00:45:18.370 - info: daswetter.0 (18232) cleaned everything up...
            2021-04-09 00:45:18.390 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2021-04-09 00:58:00.950 - warn: zigbee.0 (29255) Device '0x000d6ffffe164575' announced itself
            2021-04-09 01:00:00.043 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 21180
            2021-04-09 01:00:01.541 - info: daswetter.0 (21180) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
            2021-04-09 01:00:14.786 - info: daswetter.0 (21180) got wrong data structure! trying to repair...
            2021-04-09 01:00:18.551 - info: daswetter.0 (21180) Terminated (NO_ERROR): Without reason
            2021-04-09 01:00:19.071 - info: daswetter.0 (21180) cleaned everything up...
            2021-04-09 01:00:19.089 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2021-04-09 01:04:44.778 - error: zigbee.0 (29255) Send command to 0x00178801029c2ab5 failed with no error code (no response received)
            2021-04-09 01:15:00.077 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 24153
            2021-04-09 04:00:18.594 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2021-04-09 04:04:27.314 - error: zigbee.0 (29255) Send command to 0x0017880104907516 failed with no error code (no response received)
            2021-04-09 04:15:00.068 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27612
            2021-04-09 06:00:18.877 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2021-04-09 06:12:47.399 - error: zigbee.0 (29255) Send command to 0x0017880104907516 failed with no error code (no response received)
            2021-04-09 06:15:00.050 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 19166
            Wenn der BWM ausgelöst wird kommt der Fehler, des hängt bestimmt mit diesem Skript zusammen:
            on({id: "zigbee.0.0017880102130d27.occupancy"/*Occupancy*/, change: "any"}, async function (obj) {
              var value = obj.state.val;
              if (true == getState("zigbee.0.0017880102130d27.occupancy").val && 1 >= getState("zigbee.0.0017880102130d27.illuminance").val) {
                (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
                if (50 >= getState("zigbee.0.0017880104907516.brightness").val) {
                  if (false == getState("zigbee.0.0017880104907516.state").val) {
                    setState("zigbee.0.0017880104907516.state"/*Switch state*/, true);
                    setState("zigbee.0.00178801029c2ab5.state"/*Switch state*/, true);
                    setState("zigbee.0.group_4.color"/*Color*/, '#F0FFFF');
              } else if (false == getState("zigbee.0.0017880102130d27.occupancy").val) {
                timeout = setTimeout(async function () {
                  setState("zigbee.0.0017880104907516.state"/*Switch state*/, false);
                  setState("zigbee.0.00178801029c2ab5.state"/*Switch state*/, false);
                }, 30000);
            • Asgothian
              Asgothian Developer @Asgothian last edited by
              Es gibt inzwischen eine verbesserte Testversion:
              • Entfall von unnötigen Warnmeldungen
              • Synchronisation der Device-States mit den Gruppen-States wenn von der Gruppe aus geschaltet wird.
              • Warnmeldungen wenn versucht wird etwas zu schalten was die Gruppe nicht kann. (z.Bsp. Farbtemperatur bei Leuchten die das nicht können)
              Über weitere Tests/Tester würde ich mich freuen.
              A.
                @asgothian
                Ich habe:
                • eine Firmwareabfrage gestart >> Adapter neustart
                • Lampen aus der Gruppe gelöscht/hinzugefügt
                • und danach die beiden Autogruppen gelöscht >> wieder Adapter neustart
                2021-04-10 14:52:43.344  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                2021-04-10 14:52:43.420  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23212
                2021-04-10 14:52:45.747  - info: zigbee.0 (23212) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                2021-04-10 14:52:45.858  - info: zigbee.0 (23212) Starting Zigbee  npm ...
                2021-04-10 14:52:46.191  - info: zigbee.0 (23212) Installed Version: asgothian/ioBroker.zigbee#Groups
                2021-04-10 14:52:46.398  - info: zigbee.0 (23212) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                2021-04-10 14:52:46.477  - info: zigbee.0 (23212) Unable to disable LED, unsupported function.
                2021-04-10 14:52:46.477  - info: zigbee.0 (23212)   --> transmitPower : normal
                2021-04-10 14:52:46.479  - info: zigbee.0 (23212) Unable to set transmit power, unsupported function.
                2021-04-10 14:52:46.485  - info: zigbee.0 (23212) Currently 30 devices are joined:
                2021-04-10 14:52:46.553  - info: zigbee.0 (23212) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
                2021-04-10 14:52:46.557  - info: zigbee.0 (23212) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:52:46.558  - info: zigbee.0 (23212) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                2021-04-10 14:52:46.560  - info: zigbee.0 (23212) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:52:46.561  - info: zigbee.0 (23212) 0x84182600000a19e7 (addr 33275): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:52:46.563  - info: zigbee.0 (23212) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:52:46.564  - info: zigbee.0 (23212) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:52:46.566  - info: zigbee.0 (23212) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:52:46.567  - info: zigbee.0 (23212) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:52:46.568  - info: zigbee.0 (23212) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:52:46.569  - info: zigbee.0 (23212) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:52:46.571  - info: zigbee.0 (23212) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:52:46.572  - info: zigbee.0 (23212) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:52:46.574  - info: zigbee.0 (23212) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                2021-04-10 14:52:46.575  - info: zigbee.0 (23212) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                2021-04-10 14:52:46.576  - info: zigbee.0 (23212) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:52:46.578  - info: zigbee.0 (23212) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                2021-04-10 14:52:46.579  - info: zigbee.0 (23212) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                2021-04-10 14:52:46.580  - info: zigbee.0 (23212) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:52:46.582  - info: zigbee.0 (23212) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:52:46.583  - info: zigbee.0 (23212) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:52:46.585  - info: zigbee.0 (23212) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:52:46.586  - info: zigbee.0 (23212) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                2021-04-10 14:52:46.587  - info: zigbee.0 (23212) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:52:46.588  - info: zigbee.0 (23212) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                2021-04-10 14:52:46.590  - info: zigbee.0 (23212) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                2021-04-10 14:52:46.594  - info: zigbee.0 (23212) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                2021-04-10 14:52:46.596  - info: zigbee.0 (23212) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:52:46.597  - info: zigbee.0 (23212) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                2021-04-10 14:52:46.599  - info: zigbee.0 (23212) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                2021-04-10 14:52:46.600  - info: zigbee.0 (23212) Zigbee started
                2021-04-10 14:52:48.411  - warn: zigbee.0 (23212) Device '0x0017880102130d27' announced itself
                2021-04-10 14:54:13.486  - info: web.0 (21362) <==Disconnect system.user.admin from ::ffff:192.168.0.5 jarvis
                2021-04-10 14:54:49.342  - warn: zigbee.0 (23212) Failed to ping 0x680ae2fffe11ed0f TRADFRI bulb GU10 WS 400lm
                2021-04-10 14:54:50.399  - warn: zigbee.0 (23212) Failed to ping 0x7cb03eaa00b266c1 Plug 01
                2021-04-10 14:54:52.340  - warn: zigbee.0 (23212) Failed to ping 0x0017880108e79c10 LOM001
                2021-04-10 14:57:17.297  - info: zigbee.0 (23212) Failed to check if update available for '0x001788011039c09e' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.327  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801049bab21' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.329  - info: zigbee.0 (23212) Failed to check if update available for '0x000d6ffffe164575' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.365  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801029c2ab5' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.367  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880104907516' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.369  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880102130d27' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.375  - info: zigbee.0 (23212) Failed to check if update available for '0x90fd9ffffe78e7ca' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.378  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880103e5d609' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.381  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801011a95ad' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.383  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801011d9fce' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.385  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801011ad866' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.387  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880102aca26e' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.391  - info: zigbee.0 (23212) Failed to check if update available for '0x7cb03eaa00b266c1' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.393  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880100ce3b70' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.399  - info: zigbee.0 (23212) Failed to check if update available for '0x001788010801afea' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.409  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880108e79c10' (Device didn't respond to OTA request)
                2021-04-10 14:57:17.413  - info: zigbee.0 (23212) Failed to check if update available for '0x7cb03eaa0a030c48' (Device didn't respond to OTA request)
                2021-04-10 14:57:26.990  - info: zigbee.0 (23212) Start firmware update for 0x7cb03eaa0a066d68
                2021-04-10 14:57:28.759  - info: zigbee.0 (23212) Update of '0x7cb03eaa0a066d68' at 0%
                2021-04-10 14:57:58.206  - error: zigbee.0 (23212) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-04-10 14:57:58.207  - error: zigbee.0 (23212) unhandled promise rejection: undefined
                2021-04-10 14:57:58.209  - info: zigbee.0 (23212) cleaned everything up...
                2021-04-10 14:57:58.212  - info: zigbee.0 (23212) Zigbee: disabling joining new devices.
                2021-04-10 14:57:58.670  - info: zigbee.0 (23212) terminating
                2021-04-10 14:57:58.671  - warn: zigbee.0 (23212) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2021-04-10 14:57:59.271  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2021-04-10 14:57:59.275  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                2021-04-10 14:58:29.352  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 24349
                2021-04-10 14:58:31.558  - info: zigbee.0 (24349) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                2021-04-10 14:58:31.660  - info: zigbee.0 (24349) Starting Zigbee  npm ...
                2021-04-10 14:58:31.992  - info: zigbee.0 (24349) Installed Version: asgothian/ioBroker.zigbee#Groups
                2021-04-10 14:58:32.178  - info: zigbee.0 (24349) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                2021-04-10 14:58:32.231  - info: zigbee.0 (24349) Unable to disable LED, unsupported function.
                2021-04-10 14:58:32.232  - info: zigbee.0 (24349)   --> transmitPower : normal
                2021-04-10 14:58:32.235  - info: zigbee.0 (24349) Unable to set transmit power, unsupported function.
                2021-04-10 14:58:32.244  - info: zigbee.0 (24349) Currently 30 devices are joined:
                2021-04-10 14:58:32.311  - info: zigbee.0 (24349) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
                2021-04-10 14:58:32.315  - info: zigbee.0 (24349) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:58:32.317  - info: zigbee.0 (24349) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                2021-04-10 14:58:32.319  - info: zigbee.0 (24349) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:58:32.320  - info: zigbee.0 (24349) 0x84182600000a19e7 (addr 33275): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:58:32.322  - info: zigbee.0 (24349) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:58:32.323  - info: zigbee.0 (24349) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:58:32.325  - info: zigbee.0 (24349) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:58:32.326  - info: zigbee.0 (24349) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:58:32.327  - info: zigbee.0 (24349) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 14:58:32.329  - info: zigbee.0 (24349) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:58:32.331  - info: zigbee.0 (24349) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:58:32.333  - info: zigbee.0 (24349) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:58:32.338  - info: zigbee.0 (24349) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                2021-04-10 14:58:32.340  - info: zigbee.0 (24349) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                2021-04-10 14:58:32.342  - info: zigbee.0 (24349) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:58:32.344  - info: zigbee.0 (24349) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                2021-04-10 14:58:32.345  - info: zigbee.0 (24349) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                2021-04-10 14:58:32.350  - info: zigbee.0 (24349) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:58:32.352  - info: zigbee.0 (24349) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:58:32.353  - info: zigbee.0 (24349) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:58:32.355  - info: zigbee.0 (24349) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 14:58:32.356  - info: zigbee.0 (24349) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                2021-04-10 14:58:32.357  - info: zigbee.0 (24349) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:58:32.359  - info: zigbee.0 (24349) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                2021-04-10 14:58:32.361  - info: zigbee.0 (24349) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                2021-04-10 14:58:32.364  - info: zigbee.0 (24349) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                2021-04-10 14:58:32.365  - info: zigbee.0 (24349) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 14:58:32.367  - info: zigbee.0 (24349) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                2021-04-10 14:58:32.368  - info: zigbee.0 (24349) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                2021-04-10 14:58:32.370  - info: zigbee.0 (24349) Zigbee started
                2021-04-10 15:00:00.073  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 24680
                2021-04-10 15:00:01.629  - info: daswetter.0 (24680) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
                2021-04-10 15:00:14.657  - info: daswetter.0 (24680) got wrong data structure! trying to repair...
                2021-04-10 15:00:18.371  - info: daswetter.0 (24680) Terminated (NO_ERROR): Without reason
                2021-04-10 15:00:18.889  - info: daswetter.0 (24680) cleaned everything up...
                2021-04-10 15:00:18.910  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                2021-04-10 15:00:28.927  - warn: zigbee.0 (24349) Device '0x7cb03eaa0a066d68' announced itself
                2021-04-10 15:00:33.137  - warn: zigbee.0 (24349) Failed to ping 0x7cb03eaa0a030c48 Plug 01
                2021-04-10 15:00:36.136  - warn: zigbee.0 (24349) Failed to ping 0x7cb03eaa00b266c1 Plug 01
                2021-04-10 15:00:38.137  - warn: zigbee.0 (24349) Failed to ping 0x0017880108e79c10 LOM001
                2021-04-10 15:11:39.230  - warn: zigbee.0 (24349) unread state change for group members ["0x0017880104907516"]
                2021-04-10 15:15:00.047  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27674
                2021-04-10 15:15:01.635  - info: daswetter.0 (27674) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
                2021-04-10 15:15:15.067  - info: daswetter.0 (27674) got wrong data structure! trying to repair...
                2021-04-10 15:15:18.851  - info: daswetter.0 (27674) Terminated (NO_ERROR): Without reason
                2021-04-10 15:15:19.370  - info: daswetter.0 (27674) cleaned everything up...
                2021-04-10 15:15:19.391  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                2021-04-10 15:16:09.372  - error: zigbee.0 (24349) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-04-10 15:16:09.376  - error: zigbee.0 (24349) unhandled promise rejection: undefined
                2021-04-10 15:16:09.378  - info: zigbee.0 (24349) cleaned everything up...
                2021-04-10 15:16:09.381  - info: zigbee.0 (24349) Zigbee: disabling joining new devices.
                2021-04-10 15:16:09.881  - info: zigbee.0 (24349) terminating
                2021-04-10 15:16:09.882  - warn: zigbee.0 (24349) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2021-04-10 15:16:10.488  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2021-04-10 15:16:10.493  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                2021-04-10 15:16:40.532  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 28032
                2021-04-10 15:16:42.806  - info: zigbee.0 (28032) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                2021-04-10 15:16:42.909  - info: zigbee.0 (28032) Starting Zigbee  npm ...
                2021-04-10 15:16:43.237  - info: zigbee.0 (28032) Installed Version: asgothian/ioBroker.zigbee#Groups
                2021-04-10 15:16:43.440  - info: zigbee.0 (28032) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                2021-04-10 15:16:43.494  - info: zigbee.0 (28032) Unable to disable LED, unsupported function.
                2021-04-10 15:16:43.494  - info: zigbee.0 (28032)   --> transmitPower : normal
                2021-04-10 15:16:43.496  - info: zigbee.0 (28032) Unable to set transmit power, unsupported function.
                2021-04-10 15:16:43.500  - info: zigbee.0 (28032) Currently 30 devices are joined:
                2021-04-10 15:16:43.567  - info: zigbee.0 (28032) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
                2021-04-10 15:16:43.571  - info: zigbee.0 (28032) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 15:16:43.572  - info: zigbee.0 (28032) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                2021-04-10 15:16:43.574  - info: zigbee.0 (28032) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 15:16:43.575  - info: zigbee.0 (28032) 0x84182600000a19e7 (addr 33275): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 15:16:43.577  - info: zigbee.0 (28032) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 15:16:43.578  - info: zigbee.0 (28032) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 15:16:43.580  - info: zigbee.0 (28032) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 15:16:43.581  - info: zigbee.0 (28032) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 15:16:43.582  - info: zigbee.0 (28032) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                2021-04-10 15:16:43.584  - info: zigbee.0 (28032) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 15:16:43.585  - info: zigbee.0 (28032) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 15:16:43.587  - info: zigbee.0 (28032) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 15:16:43.588  - info: zigbee.0 (28032) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                2021-04-10 15:16:43.589  - info: zigbee.0 (28032) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                2021-04-10 15:16:43.590  - info: zigbee.0 (28032) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 15:16:43.592  - info: zigbee.0 (28032) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                2021-04-10 15:16:43.593  - info: zigbee.0 (28032) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                2021-04-10 15:16:43.594  - info: zigbee.0 (28032) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 15:16:43.596  - info: zigbee.0 (28032) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 15:16:43.597  - info: zigbee.0 (28032) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 15:16:43.599  - info: zigbee.0 (28032) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                2021-04-10 15:16:43.600  - info: zigbee.0 (28032) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                2021-04-10 15:16:43.601  - info: zigbee.0 (28032) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 15:16:43.602  - info: zigbee.0 (28032) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                2021-04-10 15:16:43.604  - info: zigbee.0 (28032) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                2021-04-10 15:16:43.608  - info: zigbee.0 (28032) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                2021-04-10 15:16:43.610  - info: zigbee.0 (28032) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                2021-04-10 15:16:43.611  - info: zigbee.0 (28032) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                2021-04-10 15:16:43.613  - info: zigbee.0 (28032) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                2021-04-10 15:16:43.614  - info: zigbee.0 (28032) Zigbee started
                In dem Skript "Küche unten" habe ich jetzt die beiden LEDstrips als Gruppe geändert und es funktioniert alles soweit.
                • Asgothian
                  @luie sagte in Zigbee Adapter: Test der umgeschriebenen Gruppenfunktion:
                  Fein. Inzwischen gibt es die 3. Iteration des Gruppen-Rewrite:
                  • Smooth dimming über "brightness_move" and "brightness_step":
                  Gültige Werte liegen zwischen 50 und -50
                  Brightness_Step erhöht die Helligkeit um x
                  Brightness_move weist die Lampe an die Helligkeit um x pro Sekunde zu ändern. Abschalten mit 0
                  Wichtig: Bei der Nutzung dieser DP wird der DP "brightness" in der Gruppe aktuell NICHT aktualisiert.
                  A.
                  • Asgothian
                    Und noch eine weitere (hoffentlich finale) Iteration:
                    • ACK for group state changes
                    • Error wenn Gruppenmitglieder einen Wert nicht unterstützen (Bsp.: Color bei Lampen die keine Farbe können)
                    A.
                      luie last edited by
                      @asgothian
                      Geräte aus der Gruppe gelöscht und wieder hinzugefügt >> Adapter neustart
                      2021-04-11 17:43:02.836  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                      2021-04-11 17:43:03.047  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                      2021-04-11 17:43:05.910  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 15487
                      2021-04-11 17:43:08.205  - info: zigbee.0 (15487) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                      2021-04-11 17:43:08.307  - info: zigbee.0 (15487) Starting Zigbee  npm ...
                      2021-04-11 17:43:08.630  - info: zigbee.0 (15487) Installed Version: asgothian/ioBroker.zigbee#Groups
                      2021-04-11 17:43:08.823  - info: zigbee.0 (15487) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                      2021-04-11 17:43:08.871  - info: zigbee.0 (15487) Unable to disable LED, unsupported function.
                      2021-04-11 17:43:08.872  - info: zigbee.0 (15487)   --> transmitPower : normal
                      2021-04-11 17:43:08.873  - info: zigbee.0 (15487) Unable to set transmit power, unsupported function.
                      2021-04-11 17:43:08.878  - info: zigbee.0 (15487) Currently 30 devices are joined:
                      2021-04-11 17:43:08.946  - info: zigbee.0 (15487) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
                      2021-04-11 17:43:08.950  - info: zigbee.0 (15487) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 17:43:08.951  - info: zigbee.0 (15487) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                      2021-04-11 17:43:08.953  - info: zigbee.0 (15487) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 17:43:08.954  - info: zigbee.0 (15487) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 17:43:08.956  - info: zigbee.0 (15487) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 17:43:08.957  - info: zigbee.0 (15487) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 17:43:08.959  - info: zigbee.0 (15487) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 17:43:08.960  - info: zigbee.0 (15487) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 17:43:08.961  - info: zigbee.0 (15487) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 17:43:08.963  - info: zigbee.0 (15487) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 17:43:08.964  - info: zigbee.0 (15487) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 17:43:08.966  - info: zigbee.0 (15487) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 17:43:08.967  - info: zigbee.0 (15487) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                      2021-04-11 17:43:08.968  - info: zigbee.0 (15487) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                      2021-04-11 17:43:08.969  - info: zigbee.0 (15487) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 17:43:08.971  - info: zigbee.0 (15487) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                      2021-04-11 17:43:08.972  - info: zigbee.0 (15487) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                      2021-04-11 17:43:08.973  - info: zigbee.0 (15487) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 17:43:08.975  - info: zigbee.0 (15487) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 17:43:08.976  - info: zigbee.0 (15487) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 17:43:08.978  - info: zigbee.0 (15487) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 17:43:08.979  - info: zigbee.0 (15487) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                      2021-04-11 17:43:08.980  - info: zigbee.0 (15487) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 17:43:08.987  - info: zigbee.0 (15487) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                      2021-04-11 17:43:08.989  - info: zigbee.0 (15487) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                      2021-04-11 17:43:08.994  - info: zigbee.0 (15487) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                      2021-04-11 17:43:08.995  - info: zigbee.0 (15487) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 17:43:08.996  - info: zigbee.0 (15487) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                      2021-04-11 17:43:08.998  - info: zigbee.0 (15487) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                      2021-04-11 17:43:09.000  - info: zigbee.0 (15487) Zigbee started
                      2021-04-11 17:45:00.095  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 15658
                      2021-04-11 17:45:01.650  - info: daswetter.0 (15658) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
                      2021-04-11 17:45:14.937  - info: daswetter.0 (15658) got wrong data structure! trying to repair...
                      2021-04-11 17:45:18.870  - info: daswetter.0 (15658) Terminated (NO_ERROR): Without reason
                      2021-04-11 17:45:19.388  - info: daswetter.0 (15658) cleaned everything up...
                      2021-04-11 17:45:19.408  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                      2021-04-11 18:00:00.081  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 16814
                      2021-04-11 18:00:01.639  - info: daswetter.0 (16814) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
                      2021-04-11 18:00:14.839  - info: daswetter.0 (16814) got wrong data structure! trying to repair...
                      2021-04-11 18:00:18.696  - info: daswetter.0 (16814) Terminated (NO_ERROR): Without reason
                      2021-04-11 18:00:19.217  - info: daswetter.0 (16814) cleaned everything up...
                      2021-04-11 18:00:19.236  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                      2021-04-11 18:08:44.468  - info: web.0 (1188) <==Disconnect system.user.admin from ::ffff:192.168.0.5 jarvis
                      2021-04-11 18:15:00.086  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 18073
                      2021-04-11 18:15:01.592  - info: daswetter.0 (18073) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
                      2021-04-11 18:15:14.829  - info: daswetter.0 (18073) got wrong data structure! trying to repair...
                      2021-04-11 18:15:18.661  - info: daswetter.0 (18073) Terminated (NO_ERROR): Without reason
                      2021-04-11 18:15:19.180  - info: daswetter.0 (18073) cleaned everything up...
                      2021-04-11 18:15:19.199  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                      2021-04-11 18:21:33.636  - info: web.0 (1188) ==>Connected system.user.admin from ::ffff:192.168.0.5
                      2021-04-11 18:22:38.195  - warn: zigbee.0 (15487) unread state change for group members ["0x0017880104907516"]
                      2021-04-11 18:22:39.553  - error: zigbee.0 (15487) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2021-04-11 18:22:39.553  - error: zigbee.0 (15487) unhandled promise rejection: undefined
                      2021-04-11 18:22:39.555  - info: zigbee.0 (15487) cleaned everything up...
                      2021-04-11 18:22:39.558  - info: zigbee.0 (15487) Zigbee: disabling joining new devices.
                      2021-04-11 18:22:40.051  - info: zigbee.0 (15487) terminating
                      2021-04-11 18:22:40.054  - warn: zigbee.0 (15487) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2021-04-11 18:22:40.648  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2021-04-11 18:22:40.654  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                      2021-04-11 18:23:10.710  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 18716
                      2021-04-11 18:23:13.051  - info: zigbee.0 (18716) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                      2021-04-11 18:23:13.157  - info: zigbee.0 (18716) Starting Zigbee  npm ...
                      2021-04-11 18:23:13.484  - info: zigbee.0 (18716) Installed Version: asgothian/ioBroker.zigbee#Groups
                      2021-04-11 18:23:13.678  - info: zigbee.0 (18716) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                      2021-04-11 18:23:13.731  - info: zigbee.0 (18716) Unable to disable LED, unsupported function.
                      2021-04-11 18:23:13.732  - info: zigbee.0 (18716)   --> transmitPower : normal
                      2021-04-11 18:23:13.734  - info: zigbee.0 (18716) Unable to set transmit power, unsupported function.
                      2021-04-11 18:23:13.739  - info: zigbee.0 (18716) Currently 30 devices are joined:
                      2021-04-11 18:23:13.804  - info: zigbee.0 (18716) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
                      2021-04-11 18:23:13.808  - info: zigbee.0 (18716) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:23:13.809  - info: zigbee.0 (18716) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                      2021-04-11 18:23:13.811  - info: zigbee.0 (18716) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:23:13.812  - info: zigbee.0 (18716) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:23:13.814  - info: zigbee.0 (18716) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:23:13.815  - info: zigbee.0 (18716) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:23:13.818  - info: zigbee.0 (18716) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:23:13.820  - info: zigbee.0 (18716) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:23:13.822  - info: zigbee.0 (18716) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:23:13.823  - info: zigbee.0 (18716) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:23:13.826  - info: zigbee.0 (18716) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:23:13.828  - info: zigbee.0 (18716) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:23:13.830  - info: zigbee.0 (18716) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                      2021-04-11 18:23:13.831  - info: zigbee.0 (18716) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                      2021-04-11 18:23:13.833  - info: zigbee.0 (18716) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:23:13.834  - info: zigbee.0 (18716) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                      2021-04-11 18:23:13.836  - info: zigbee.0 (18716) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                      2021-04-11 18:23:13.838  - info: zigbee.0 (18716) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:23:13.841  - info: zigbee.0 (18716) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:23:13.843  - info: zigbee.0 (18716) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:23:13.845  - info: zigbee.0 (18716) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:23:13.847  - info: zigbee.0 (18716) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                      2021-04-11 18:23:13.848  - info: zigbee.0 (18716) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:23:13.850  - info: zigbee.0 (18716) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                      2021-04-11 18:23:13.853  - info: zigbee.0 (18716) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                      2021-04-11 18:23:13.857  - info: zigbee.0 (18716) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                      2021-04-11 18:23:13.858  - info: zigbee.0 (18716) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:23:13.860  - info: zigbee.0 (18716) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                      2021-04-11 18:23:13.861  - info: zigbee.0 (18716) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                      2021-04-11 18:23:13.863  - info: zigbee.0 (18716) Zigbee started
                      2021-04-11 18:25:17.018  - warn: zigbee.0 (18716) Failed to ping 0x8418260000101cf6 Plug 01
                      2021-04-11 18:26:14.014  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 2. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
                      2021-04-11 18:27:47.032  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 3. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":3,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
                      2021-04-11 18:27:47.036  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 2. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
                      2021-04-11 18:28:27.339  - error: zigbee.0 (18716) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2021-04-11 18:28:27.340  - error: zigbee.0 (18716) unhandled promise rejection: undefined
                      2021-04-11 18:28:27.342  - info: zigbee.0 (18716) cleaned everything up...
                      2021-04-11 18:28:27.344  - info: zigbee.0 (18716) Zigbee: disabling joining new devices.
                      2021-04-11 18:28:27.843  - info: zigbee.0 (18716) terminating
                      2021-04-11 18:28:27.845  - warn: zigbee.0 (18716) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2021-04-11 18:28:28.449  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2021-04-11 18:28:28.454  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                      2021-04-11 18:28:58.505  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 19186
                      2021-04-11 18:29:00.807  - info: zigbee.0 (19186) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                      2021-04-11 18:29:00.912  - info: zigbee.0 (19186) Starting Zigbee  npm ...
                      2021-04-11 18:29:01.244  - info: zigbee.0 (19186) Installed Version: asgothian/ioBroker.zigbee#Groups
                      2021-04-11 18:29:01.426  - info: zigbee.0 (19186) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                      2021-04-11 18:29:01.475  - info: zigbee.0 (19186) Unable to disable LED, unsupported function.
                      2021-04-11 18:29:01.476  - info: zigbee.0 (19186)   --> transmitPower : normal
                      2021-04-11 18:29:01.478  - info: zigbee.0 (19186) Unable to set transmit power, unsupported function.
                      2021-04-11 18:29:01.482  - info: zigbee.0 (19186) Currently 30 devices are joined:
                      2021-04-11 18:29:01.551  - info: zigbee.0 (19186) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
                      2021-04-11 18:29:01.555  - info: zigbee.0 (19186) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:29:01.556  - info: zigbee.0 (19186) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                      2021-04-11 18:29:01.558  - info: zigbee.0 (19186) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:29:01.559  - info: zigbee.0 (19186) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:29:01.561  - info: zigbee.0 (19186) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:29:01.562  - info: zigbee.0 (19186) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:29:01.564  - info: zigbee.0 (19186) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:29:01.565  - info: zigbee.0 (19186) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:29:01.568  - info: zigbee.0 (19186) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      2021-04-11 18:29:01.570  - info: zigbee.0 (19186) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:29:01.572  - info: zigbee.0 (19186) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:29:01.573  - info: zigbee.0 (19186) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:29:01.575  - info: zigbee.0 (19186) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                      2021-04-11 18:29:01.576  - info: zigbee.0 (19186) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                      2021-04-11 18:29:01.577  - info: zigbee.0 (19186) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:29:01.579  - info: zigbee.0 (19186) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                      2021-04-11 18:29:01.580  - info: zigbee.0 (19186) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                      2021-04-11 18:29:01.581  - info: zigbee.0 (19186) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:29:01.583  - info: zigbee.0 (19186) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:29:01.584  - info: zigbee.0 (19186) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:29:01.586  - info: zigbee.0 (19186) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                      2021-04-11 18:29:01.587  - info: zigbee.0 (19186) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                      2021-04-11 18:29:01.588  - info: zigbee.0 (19186) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:29:01.589  - info: zigbee.0 (19186) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                      2021-04-11 18:29:01.592  - info: zigbee.0 (19186) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                      2021-04-11 18:29:01.596  - info: zigbee.0 (19186) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                      2021-04-11 18:29:01.597  - info: zigbee.0 (19186) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2021-04-11 18:29:01.598  - info: zigbee.0 (19186) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                      2021-04-11 18:29:01.600  - info: zigbee.0 (19186) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                      2021-04-11 18:29:01.601  - info: zigbee.0 (19186) Zigbee started
                      • Asgothian
                        Asgothian Developer @luie last edited by Asgothian
                        @luie Kannst du bitte den Adapter in debug schalten und nocheinmal versuchen die gleiche Steckdose den gleichen Gruppen hinzu zu fügen ? Es scheint so zu sein das es ein Problem gibt wenn das Gerät nicht erreichbar ist.
                        A.
                        Nachtrag: Die Meldungen bekomme ich auch, allerdings stürzt bei mir der Adapter nicht ab.
                        • Asgothian
                          @luie
                          1. Nachtrag: Bitte nochmal vom Link anpassen - ich habe an der Fehlerbehandlung noch Anpassungen vorgenommen.
                          A.
                            luie last edited by luie
                            @asgothian
                            Dieses Mal ist der iobroker oder der raspi komplett abgestürzt. Habe die Geräte aus der Gruppe gelöscht und als ich sie wieder hinzugefügt habe, kam eine leere Fehlermeldung (siehe Bild) und dazu der log vielleicht hilft er dir ja weiter.
                            Danke für eure Arbeit und Zeit.
                            log.txt
                            • Asgothian
                              @luie
                              Das Hilft.. ich denke die leere "Fehlermeldung" sollte eine Erfolgsmeldung sein.. muss ich morgen testen.
                              A.
                                Ritter last edited by
                                hab die Version auch getestet und bei mir kommt auch nur der Weiße Kasten mit Error. Die Lampen sind Müller E27 mit Farbtemperaturregelung.
                                • Asgothian
                                  Asgothian Developer @Ritter last edited by
                                  @ritter Sind die Lampen danach in der Gruppe drin ? (im Objektbaum bitte nachsehen)
                                    Ritter @Asgothian last edited by
                                    @asgothian nur zwei von drei, bei der anderen ist nur so eine Eckige Klammer.
                                    • Asgothian
                                      @ritter versuch bitte nochmal genau diese auch der Gruppe hinzu zu fügen
                                      A.
                                        @asgothian Ich hab den Adapter nochmal neu installiert danach kahm rebuild hat etwas gedauert. Ich hab die Lampen aus den Gruppen noch mal entfernt. Dann wieder hinzugefügt. Nach kurzer Zeit kommt der Kasten mit Error drei mal. Bei den Objekten sind sie alle drei jetzt drin, aber sie regeln nicht.
                                        • Asgothian
                                          @ritter ok.. danke.. muss ich mir morgen anschauen. Heute komm ich da nicht zu
                                          A.
                                            @asgothian Ok danke.
                                            31.7k
                                            79.9k
                                            2307
