    4. Zigbee Adapter: Test der umgeschriebenen Gruppenfunktion
      luie @Asgothian last edited by
      @asgothian
      Ich habe:
      • eine Firmwareabfrage gestart >> Adapter neustart
      • Lampen aus der Gruppe gelöscht/hinzugefügt
      • und danach die beiden Autogruppen gelöscht >> wieder Adapter neustart
      2021-04-10 14:52:43.344  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
      2021-04-10 14:52:43.420  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23212
      2021-04-10 14:52:45.747  - info: zigbee.0 (23212) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
      2021-04-10 14:52:45.858  - info: zigbee.0 (23212) Starting Zigbee  npm ...
      2021-04-10 14:52:46.191  - info: zigbee.0 (23212) Installed Version: asgothian/ioBroker.zigbee#Groups
      2021-04-10 14:52:46.398  - info: zigbee.0 (23212) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
      2021-04-10 14:52:46.477  - info: zigbee.0 (23212) Unable to disable LED, unsupported function.
      2021-04-10 14:52:46.477  - info: zigbee.0 (23212)   --> transmitPower : normal
      2021-04-10 14:52:46.479  - info: zigbee.0 (23212) Unable to set transmit power, unsupported function.
      2021-04-10 14:52:46.485  - info: zigbee.0 (23212) Currently 30 devices are joined:
      2021-04-10 14:52:46.553  - info: zigbee.0 (23212) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2021-04-10 14:52:46.557  - info: zigbee.0 (23212) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:52:46.558  - info: zigbee.0 (23212) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      2021-04-10 14:52:46.560  - info: zigbee.0 (23212) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:52:46.561  - info: zigbee.0 (23212) 0x84182600000a19e7 (addr 33275): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:52:46.563  - info: zigbee.0 (23212) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:52:46.564  - info: zigbee.0 (23212) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:52:46.566  - info: zigbee.0 (23212) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:52:46.567  - info: zigbee.0 (23212) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:52:46.568  - info: zigbee.0 (23212) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:52:46.569  - info: zigbee.0 (23212) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:52:46.571  - info: zigbee.0 (23212) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:52:46.572  - info: zigbee.0 (23212) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:52:46.574  - info: zigbee.0 (23212) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
      2021-04-10 14:52:46.575  - info: zigbee.0 (23212) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      2021-04-10 14:52:46.576  - info: zigbee.0 (23212) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:52:46.578  - info: zigbee.0 (23212) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
      2021-04-10 14:52:46.579  - info: zigbee.0 (23212) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2021-04-10 14:52:46.580  - info: zigbee.0 (23212) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:52:46.582  - info: zigbee.0 (23212) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:52:46.583  - info: zigbee.0 (23212) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:52:46.585  - info: zigbee.0 (23212) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:52:46.586  - info: zigbee.0 (23212) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      2021-04-10 14:52:46.587  - info: zigbee.0 (23212) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:52:46.588  - info: zigbee.0 (23212) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
      2021-04-10 14:52:46.590  - info: zigbee.0 (23212) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
      2021-04-10 14:52:46.594  - info: zigbee.0 (23212) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
      2021-04-10 14:52:46.596  - info: zigbee.0 (23212) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:52:46.597  - info: zigbee.0 (23212) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
      2021-04-10 14:52:46.599  - info: zigbee.0 (23212) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
      2021-04-10 14:52:46.600  - info: zigbee.0 (23212) Zigbee started
      2021-04-10 14:52:48.411  - warn: zigbee.0 (23212) Device '0x0017880102130d27' announced itself
      2021-04-10 14:54:13.486  - info: web.0 (21362) <==Disconnect system.user.admin from ::ffff:192.168.0.5 jarvis
      2021-04-10 14:54:49.342  - warn: zigbee.0 (23212) Failed to ping 0x680ae2fffe11ed0f TRADFRI bulb GU10 WS 400lm
      2021-04-10 14:54:50.399  - warn: zigbee.0 (23212) Failed to ping 0x7cb03eaa00b266c1 Plug 01
      2021-04-10 14:54:52.340  - warn: zigbee.0 (23212) Failed to ping 0x0017880108e79c10 LOM001
      2021-04-10 14:57:17.297  - info: zigbee.0 (23212) Failed to check if update available for '0x001788011039c09e' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.327  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801049bab21' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.329  - info: zigbee.0 (23212) Failed to check if update available for '0x000d6ffffe164575' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.365  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801029c2ab5' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.367  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880104907516' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.369  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880102130d27' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.375  - info: zigbee.0 (23212) Failed to check if update available for '0x90fd9ffffe78e7ca' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.378  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880103e5d609' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.381  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801011a95ad' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.383  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801011d9fce' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.385  - info: zigbee.0 (23212) Failed to check if update available for '0x00178801011ad866' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.387  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880102aca26e' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.391  - info: zigbee.0 (23212) Failed to check if update available for '0x7cb03eaa00b266c1' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.393  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880100ce3b70' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.399  - info: zigbee.0 (23212) Failed to check if update available for '0x001788010801afea' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.409  - info: zigbee.0 (23212) Failed to check if update available for '0x0017880108e79c10' (Device didn't respond to OTA request)
      2021-04-10 14:57:17.413  - info: zigbee.0 (23212) Failed to check if update available for '0x7cb03eaa0a030c48' (Device didn't respond to OTA request)
      2021-04-10 14:57:26.990  - info: zigbee.0 (23212) Start firmware update for 0x7cb03eaa0a066d68
      2021-04-10 14:57:28.759  - info: zigbee.0 (23212) Update of '0x7cb03eaa0a066d68' at 0%
      2021-04-10 14:57:58.206  - error: zigbee.0 (23212) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-10 14:57:58.207  - error: zigbee.0 (23212) unhandled promise rejection: undefined
      2021-04-10 14:57:58.209  - info: zigbee.0 (23212) cleaned everything up...
      2021-04-10 14:57:58.212  - info: zigbee.0 (23212) Zigbee: disabling joining new devices.
      2021-04-10 14:57:58.670  - info: zigbee.0 (23212) terminating
      2021-04-10 14:57:58.671  - warn: zigbee.0 (23212) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-10 14:57:59.271  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-10 14:57:59.275  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2021-04-10 14:58:29.352  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 24349
      2021-04-10 14:58:31.558  - info: zigbee.0 (24349) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
      2021-04-10 14:58:31.660  - info: zigbee.0 (24349) Starting Zigbee  npm ...
      2021-04-10 14:58:31.992  - info: zigbee.0 (24349) Installed Version: asgothian/ioBroker.zigbee#Groups
      2021-04-10 14:58:32.178  - info: zigbee.0 (24349) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
      2021-04-10 14:58:32.231  - info: zigbee.0 (24349) Unable to disable LED, unsupported function.
      2021-04-10 14:58:32.232  - info: zigbee.0 (24349)   --> transmitPower : normal
      2021-04-10 14:58:32.235  - info: zigbee.0 (24349) Unable to set transmit power, unsupported function.
      2021-04-10 14:58:32.244  - info: zigbee.0 (24349) Currently 30 devices are joined:
      2021-04-10 14:58:32.311  - info: zigbee.0 (24349) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2021-04-10 14:58:32.315  - info: zigbee.0 (24349) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:58:32.317  - info: zigbee.0 (24349) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      2021-04-10 14:58:32.319  - info: zigbee.0 (24349) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:58:32.320  - info: zigbee.0 (24349) 0x84182600000a19e7 (addr 33275): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:58:32.322  - info: zigbee.0 (24349) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:58:32.323  - info: zigbee.0 (24349) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:58:32.325  - info: zigbee.0 (24349) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:58:32.326  - info: zigbee.0 (24349) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:58:32.327  - info: zigbee.0 (24349) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 14:58:32.329  - info: zigbee.0 (24349) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:58:32.331  - info: zigbee.0 (24349) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:58:32.333  - info: zigbee.0 (24349) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:58:32.338  - info: zigbee.0 (24349) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
      2021-04-10 14:58:32.340  - info: zigbee.0 (24349) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      2021-04-10 14:58:32.342  - info: zigbee.0 (24349) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:58:32.344  - info: zigbee.0 (24349) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
      2021-04-10 14:58:32.345  - info: zigbee.0 (24349) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2021-04-10 14:58:32.350  - info: zigbee.0 (24349) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:58:32.352  - info: zigbee.0 (24349) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:58:32.353  - info: zigbee.0 (24349) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:58:32.355  - info: zigbee.0 (24349) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 14:58:32.356  - info: zigbee.0 (24349) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      2021-04-10 14:58:32.357  - info: zigbee.0 (24349) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:58:32.359  - info: zigbee.0 (24349) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
      2021-04-10 14:58:32.361  - info: zigbee.0 (24349) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
      2021-04-10 14:58:32.364  - info: zigbee.0 (24349) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
      2021-04-10 14:58:32.365  - info: zigbee.0 (24349) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 14:58:32.367  - info: zigbee.0 (24349) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
      2021-04-10 14:58:32.368  - info: zigbee.0 (24349) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
      2021-04-10 14:58:32.370  - info: zigbee.0 (24349) Zigbee started
      2021-04-10 15:00:00.073  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 24680
      2021-04-10 15:00:01.629  - info: daswetter.0 (24680) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
      2021-04-10 15:00:14.657  - info: daswetter.0 (24680) got wrong data structure! trying to repair...
      2021-04-10 15:00:18.371  - info: daswetter.0 (24680) Terminated (NO_ERROR): Without reason
      2021-04-10 15:00:18.889  - info: daswetter.0 (24680) cleaned everything up...
      2021-04-10 15:00:18.910  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-04-10 15:00:28.927  - warn: zigbee.0 (24349) Device '0x7cb03eaa0a066d68' announced itself
      2021-04-10 15:00:33.137  - warn: zigbee.0 (24349) Failed to ping 0x7cb03eaa0a030c48 Plug 01
      2021-04-10 15:00:36.136  - warn: zigbee.0 (24349) Failed to ping 0x7cb03eaa00b266c1 Plug 01
      2021-04-10 15:00:38.137  - warn: zigbee.0 (24349) Failed to ping 0x0017880108e79c10 LOM001
      2021-04-10 15:11:39.230  - warn: zigbee.0 (24349) unread state change for group members ["0x0017880104907516"]
      2021-04-10 15:15:00.047  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27674
      2021-04-10 15:15:01.635  - info: daswetter.0 (27674) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
      2021-04-10 15:15:15.067  - info: daswetter.0 (27674) got wrong data structure! trying to repair...
      2021-04-10 15:15:18.851  - info: daswetter.0 (27674) Terminated (NO_ERROR): Without reason
      2021-04-10 15:15:19.370  - info: daswetter.0 (27674) cleaned everything up...
      2021-04-10 15:15:19.391  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-04-10 15:16:09.372  - error: zigbee.0 (24349) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-10 15:16:09.376  - error: zigbee.0 (24349) unhandled promise rejection: undefined
      2021-04-10 15:16:09.378  - info: zigbee.0 (24349) cleaned everything up...
      2021-04-10 15:16:09.381  - info: zigbee.0 (24349) Zigbee: disabling joining new devices.
      2021-04-10 15:16:09.881  - info: zigbee.0 (24349) terminating
      2021-04-10 15:16:09.882  - warn: zigbee.0 (24349) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-10 15:16:10.488  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-10 15:16:10.493  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2021-04-10 15:16:40.532  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 28032
      2021-04-10 15:16:42.806  - info: zigbee.0 (28032) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
      2021-04-10 15:16:42.909  - info: zigbee.0 (28032) Starting Zigbee  npm ...
      2021-04-10 15:16:43.237  - info: zigbee.0 (28032) Installed Version: asgothian/ioBroker.zigbee#Groups
      2021-04-10 15:16:43.440  - info: zigbee.0 (28032) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
      2021-04-10 15:16:43.494  - info: zigbee.0 (28032) Unable to disable LED, unsupported function.
      2021-04-10 15:16:43.494  - info: zigbee.0 (28032)   --> transmitPower : normal
      2021-04-10 15:16:43.496  - info: zigbee.0 (28032) Unable to set transmit power, unsupported function.
      2021-04-10 15:16:43.500  - info: zigbee.0 (28032) Currently 30 devices are joined:
      2021-04-10 15:16:43.567  - info: zigbee.0 (28032) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2021-04-10 15:16:43.571  - info: zigbee.0 (28032) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 15:16:43.572  - info: zigbee.0 (28032) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      2021-04-10 15:16:43.574  - info: zigbee.0 (28032) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 15:16:43.575  - info: zigbee.0 (28032) 0x84182600000a19e7 (addr 33275): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 15:16:43.577  - info: zigbee.0 (28032) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 15:16:43.578  - info: zigbee.0 (28032) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 15:16:43.580  - info: zigbee.0 (28032) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 15:16:43.581  - info: zigbee.0 (28032) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 15:16:43.582  - info: zigbee.0 (28032) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2021-04-10 15:16:43.584  - info: zigbee.0 (28032) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 15:16:43.585  - info: zigbee.0 (28032) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 15:16:43.587  - info: zigbee.0 (28032) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 15:16:43.588  - info: zigbee.0 (28032) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
      2021-04-10 15:16:43.589  - info: zigbee.0 (28032) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      2021-04-10 15:16:43.590  - info: zigbee.0 (28032) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 15:16:43.592  - info: zigbee.0 (28032) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
      2021-04-10 15:16:43.593  - info: zigbee.0 (28032) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2021-04-10 15:16:43.594  - info: zigbee.0 (28032) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 15:16:43.596  - info: zigbee.0 (28032) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 15:16:43.597  - info: zigbee.0 (28032) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 15:16:43.599  - info: zigbee.0 (28032) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
      2021-04-10 15:16:43.600  - info: zigbee.0 (28032) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      2021-04-10 15:16:43.601  - info: zigbee.0 (28032) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 15:16:43.602  - info: zigbee.0 (28032) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
      2021-04-10 15:16:43.604  - info: zigbee.0 (28032) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
      2021-04-10 15:16:43.608  - info: zigbee.0 (28032) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
      2021-04-10 15:16:43.610  - info: zigbee.0 (28032) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
      2021-04-10 15:16:43.611  - info: zigbee.0 (28032) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
      2021-04-10 15:16:43.613  - info: zigbee.0 (28032) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
      2021-04-10 15:16:43.614  - info: zigbee.0 (28032) Zigbee started
      In dem Skript "Küche unten" habe ich jetzt die beiden LEDstrips als Gruppe geändert und es funktioniert alles soweit.
      • Asgothian
        Asgothian Developer @luie last edited by
        @luie sagte in Zigbee Adapter: Test der umgeschriebenen Gruppenfunktion:
        Fein. Inzwischen gibt es die 3. Iteration des Gruppen-Rewrite:
        • Smooth dimming über "brightness_move" and "brightness_step":
        Gültige Werte liegen zwischen 50 und -50
        Brightness_Step erhöht die Helligkeit um x
        Brightness_move weist die Lampe an die Helligkeit um x pro Sekunde zu ändern. Abschalten mit 0
        Wichtig: Bei der Nutzung dieser DP wird der DP "brightness" in der Gruppe aktuell NICHT aktualisiert.
        A.
        • Asgothian
          Asgothian Developer @Asgothian last edited by
          Und noch eine weitere (hoffentlich finale) Iteration:
          • ACK for group state changes
          • Error wenn Gruppenmitglieder einen Wert nicht unterstützen (Bsp.: Color bei Lampen die keine Farbe können)
          A.
            luie last edited by
            @asgothian
            Geräte aus der Gruppe gelöscht und wieder hinzugefügt >> Adapter neustart
            2021-04-11 17:43:02.836  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
            2021-04-11 17:43:03.047  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            2021-04-11 17:43:05.910  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 15487
            2021-04-11 17:43:08.205  - info: zigbee.0 (15487) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
            2021-04-11 17:43:08.307  - info: zigbee.0 (15487) Starting Zigbee  npm ...
            2021-04-11 17:43:08.630  - info: zigbee.0 (15487) Installed Version: asgothian/ioBroker.zigbee#Groups
            2021-04-11 17:43:08.823  - info: zigbee.0 (15487) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
            2021-04-11 17:43:08.871  - info: zigbee.0 (15487) Unable to disable LED, unsupported function.
            2021-04-11 17:43:08.872  - info: zigbee.0 (15487)   --> transmitPower : normal
            2021-04-11 17:43:08.873  - info: zigbee.0 (15487) Unable to set transmit power, unsupported function.
            2021-04-11 17:43:08.878  - info: zigbee.0 (15487) Currently 30 devices are joined:
            2021-04-11 17:43:08.946  - info: zigbee.0 (15487) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
            2021-04-11 17:43:08.950  - info: zigbee.0 (15487) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 17:43:08.951  - info: zigbee.0 (15487) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
            2021-04-11 17:43:08.953  - info: zigbee.0 (15487) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 17:43:08.954  - info: zigbee.0 (15487) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 17:43:08.956  - info: zigbee.0 (15487) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 17:43:08.957  - info: zigbee.0 (15487) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 17:43:08.959  - info: zigbee.0 (15487) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 17:43:08.960  - info: zigbee.0 (15487) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 17:43:08.961  - info: zigbee.0 (15487) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 17:43:08.963  - info: zigbee.0 (15487) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 17:43:08.964  - info: zigbee.0 (15487) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 17:43:08.966  - info: zigbee.0 (15487) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 17:43:08.967  - info: zigbee.0 (15487) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
            2021-04-11 17:43:08.968  - info: zigbee.0 (15487) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
            2021-04-11 17:43:08.969  - info: zigbee.0 (15487) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 17:43:08.971  - info: zigbee.0 (15487) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
            2021-04-11 17:43:08.972  - info: zigbee.0 (15487) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
            2021-04-11 17:43:08.973  - info: zigbee.0 (15487) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 17:43:08.975  - info: zigbee.0 (15487) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 17:43:08.976  - info: zigbee.0 (15487) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 17:43:08.978  - info: zigbee.0 (15487) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 17:43:08.979  - info: zigbee.0 (15487) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
            2021-04-11 17:43:08.980  - info: zigbee.0 (15487) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 17:43:08.987  - info: zigbee.0 (15487) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
            2021-04-11 17:43:08.989  - info: zigbee.0 (15487) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
            2021-04-11 17:43:08.994  - info: zigbee.0 (15487) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
            2021-04-11 17:43:08.995  - info: zigbee.0 (15487) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 17:43:08.996  - info: zigbee.0 (15487) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
            2021-04-11 17:43:08.998  - info: zigbee.0 (15487) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
            2021-04-11 17:43:09.000  - info: zigbee.0 (15487) Zigbee started
            2021-04-11 17:45:00.095  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 15658
            2021-04-11 17:45:01.650  - info: daswetter.0 (15658) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
            2021-04-11 17:45:14.937  - info: daswetter.0 (15658) got wrong data structure! trying to repair...
            2021-04-11 17:45:18.870  - info: daswetter.0 (15658) Terminated (NO_ERROR): Without reason
            2021-04-11 17:45:19.388  - info: daswetter.0 (15658) cleaned everything up...
            2021-04-11 17:45:19.408  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2021-04-11 18:00:00.081  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 16814
            2021-04-11 18:00:01.639  - info: daswetter.0 (16814) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
            2021-04-11 18:00:14.839  - info: daswetter.0 (16814) got wrong data structure! trying to repair...
            2021-04-11 18:00:18.696  - info: daswetter.0 (16814) Terminated (NO_ERROR): Without reason
            2021-04-11 18:00:19.217  - info: daswetter.0 (16814) cleaned everything up...
            2021-04-11 18:00:19.236  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2021-04-11 18:08:44.468  - info: web.0 (1188) <==Disconnect system.user.admin from ::ffff:192.168.0.5 jarvis
            2021-04-11 18:15:00.086  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 18073
            2021-04-11 18:15:01.592  - info: daswetter.0 (18073) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
            2021-04-11 18:15:14.829  - info: daswetter.0 (18073) got wrong data structure! trying to repair...
            2021-04-11 18:15:18.661  - info: daswetter.0 (18073) Terminated (NO_ERROR): Without reason
            2021-04-11 18:15:19.180  - info: daswetter.0 (18073) cleaned everything up...
            2021-04-11 18:15:19.199  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2021-04-11 18:21:33.636  - info: web.0 (1188) ==>Connected system.user.admin from ::ffff:192.168.0.5
            2021-04-11 18:22:38.195  - warn: zigbee.0 (15487) unread state change for group members ["0x0017880104907516"]
            2021-04-11 18:22:39.553  - error: zigbee.0 (15487) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2021-04-11 18:22:39.553  - error: zigbee.0 (15487) unhandled promise rejection: undefined
            2021-04-11 18:22:39.555  - info: zigbee.0 (15487) cleaned everything up...
            2021-04-11 18:22:39.558  - info: zigbee.0 (15487) Zigbee: disabling joining new devices.
            2021-04-11 18:22:40.051  - info: zigbee.0 (15487) terminating
            2021-04-11 18:22:40.054  - warn: zigbee.0 (15487) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2021-04-11 18:22:40.648  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2021-04-11 18:22:40.654  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
            2021-04-11 18:23:10.710  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 18716
            2021-04-11 18:23:13.051  - info: zigbee.0 (18716) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
            2021-04-11 18:23:13.157  - info: zigbee.0 (18716) Starting Zigbee  npm ...
            2021-04-11 18:23:13.484  - info: zigbee.0 (18716) Installed Version: asgothian/ioBroker.zigbee#Groups
            2021-04-11 18:23:13.678  - info: zigbee.0 (18716) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
            2021-04-11 18:23:13.731  - info: zigbee.0 (18716) Unable to disable LED, unsupported function.
            2021-04-11 18:23:13.732  - info: zigbee.0 (18716)   --> transmitPower : normal
            2021-04-11 18:23:13.734  - info: zigbee.0 (18716) Unable to set transmit power, unsupported function.
            2021-04-11 18:23:13.739  - info: zigbee.0 (18716) Currently 30 devices are joined:
            2021-04-11 18:23:13.804  - info: zigbee.0 (18716) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
            2021-04-11 18:23:13.808  - info: zigbee.0 (18716) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:23:13.809  - info: zigbee.0 (18716) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
            2021-04-11 18:23:13.811  - info: zigbee.0 (18716) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:23:13.812  - info: zigbee.0 (18716) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:23:13.814  - info: zigbee.0 (18716) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:23:13.815  - info: zigbee.0 (18716) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:23:13.818  - info: zigbee.0 (18716) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:23:13.820  - info: zigbee.0 (18716) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:23:13.822  - info: zigbee.0 (18716) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:23:13.823  - info: zigbee.0 (18716) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:23:13.826  - info: zigbee.0 (18716) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:23:13.828  - info: zigbee.0 (18716) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:23:13.830  - info: zigbee.0 (18716) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
            2021-04-11 18:23:13.831  - info: zigbee.0 (18716) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
            2021-04-11 18:23:13.833  - info: zigbee.0 (18716) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:23:13.834  - info: zigbee.0 (18716) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
            2021-04-11 18:23:13.836  - info: zigbee.0 (18716) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
            2021-04-11 18:23:13.838  - info: zigbee.0 (18716) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:23:13.841  - info: zigbee.0 (18716) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:23:13.843  - info: zigbee.0 (18716) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:23:13.845  - info: zigbee.0 (18716) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:23:13.847  - info: zigbee.0 (18716) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
            2021-04-11 18:23:13.848  - info: zigbee.0 (18716) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:23:13.850  - info: zigbee.0 (18716) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
            2021-04-11 18:23:13.853  - info: zigbee.0 (18716) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
            2021-04-11 18:23:13.857  - info: zigbee.0 (18716) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
            2021-04-11 18:23:13.858  - info: zigbee.0 (18716) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:23:13.860  - info: zigbee.0 (18716) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
            2021-04-11 18:23:13.861  - info: zigbee.0 (18716) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
            2021-04-11 18:23:13.863  - info: zigbee.0 (18716) Zigbee started
            2021-04-11 18:25:17.018  - warn: zigbee.0 (18716) Failed to ping 0x8418260000101cf6 Plug 01
            2021-04-11 18:26:14.014  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 2. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
            2021-04-11 18:27:47.032  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 3. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":3,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
            2021-04-11 18:27:47.036  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 2. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
            2021-04-11 18:28:27.339  - error: zigbee.0 (18716) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2021-04-11 18:28:27.340  - error: zigbee.0 (18716) unhandled promise rejection: undefined
            2021-04-11 18:28:27.342  - info: zigbee.0 (18716) cleaned everything up...
            2021-04-11 18:28:27.344  - info: zigbee.0 (18716) Zigbee: disabling joining new devices.
            2021-04-11 18:28:27.843  - info: zigbee.0 (18716) terminating
            2021-04-11 18:28:27.845  - warn: zigbee.0 (18716) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2021-04-11 18:28:28.449  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2021-04-11 18:28:28.454  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
            2021-04-11 18:28:58.505  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 19186
            2021-04-11 18:29:00.807  - info: zigbee.0 (19186) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
            2021-04-11 18:29:00.912  - info: zigbee.0 (19186) Starting Zigbee  npm ...
            2021-04-11 18:29:01.244  - info: zigbee.0 (19186) Installed Version: asgothian/ioBroker.zigbee#Groups
            2021-04-11 18:29:01.426  - info: zigbee.0 (19186) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
            2021-04-11 18:29:01.475  - info: zigbee.0 (19186) Unable to disable LED, unsupported function.
            2021-04-11 18:29:01.476  - info: zigbee.0 (19186)   --> transmitPower : normal
            2021-04-11 18:29:01.478  - info: zigbee.0 (19186) Unable to set transmit power, unsupported function.
            2021-04-11 18:29:01.482  - info: zigbee.0 (19186) Currently 30 devices are joined:
            2021-04-11 18:29:01.551  - info: zigbee.0 (19186) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
            2021-04-11 18:29:01.555  - info: zigbee.0 (19186) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:29:01.556  - info: zigbee.0 (19186) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
            2021-04-11 18:29:01.558  - info: zigbee.0 (19186) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:29:01.559  - info: zigbee.0 (19186) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:29:01.561  - info: zigbee.0 (19186) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:29:01.562  - info: zigbee.0 (19186) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:29:01.564  - info: zigbee.0 (19186) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:29:01.565  - info: zigbee.0 (19186) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:29:01.568  - info: zigbee.0 (19186) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
            2021-04-11 18:29:01.570  - info: zigbee.0 (19186) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:29:01.572  - info: zigbee.0 (19186) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:29:01.573  - info: zigbee.0 (19186) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:29:01.575  - info: zigbee.0 (19186) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
            2021-04-11 18:29:01.576  - info: zigbee.0 (19186) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
            2021-04-11 18:29:01.577  - info: zigbee.0 (19186) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:29:01.579  - info: zigbee.0 (19186) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
            2021-04-11 18:29:01.580  - info: zigbee.0 (19186) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
            2021-04-11 18:29:01.581  - info: zigbee.0 (19186) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:29:01.583  - info: zigbee.0 (19186) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:29:01.584  - info: zigbee.0 (19186) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:29:01.586  - info: zigbee.0 (19186) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
            2021-04-11 18:29:01.587  - info: zigbee.0 (19186) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
            2021-04-11 18:29:01.588  - info: zigbee.0 (19186) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:29:01.589  - info: zigbee.0 (19186) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
            2021-04-11 18:29:01.592  - info: zigbee.0 (19186) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
            2021-04-11 18:29:01.596  - info: zigbee.0 (19186) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
            2021-04-11 18:29:01.597  - info: zigbee.0 (19186) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
            2021-04-11 18:29:01.598  - info: zigbee.0 (19186) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
            2021-04-11 18:29:01.600  - info: zigbee.0 (19186) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
            2021-04-11 18:29:01.601  - info: zigbee.0 (19186) Zigbee started
            • Asgothian
              Asgothian Developer @luie last edited by Asgothian
              @luie Kannst du bitte den Adapter in debug schalten und nocheinmal versuchen die gleiche Steckdose den gleichen Gruppen hinzu zu fügen ? Es scheint so zu sein das es ein Problem gibt wenn das Gerät nicht erreichbar ist.
              A.
              Nachtrag: Die Meldungen bekomme ich auch, allerdings stürzt bei mir der Adapter nicht ab.
              • Asgothian
                @luie
                1. Nachtrag: Bitte nochmal vom Link anpassen - ich habe an der Fehlerbehandlung noch Anpassungen vorgenommen.
                A.
                  luie last edited by luie
                  @asgothian
                  Dieses Mal ist der iobroker oder der raspi komplett abgestürzt. Habe die Geräte aus der Gruppe gelöscht und als ich sie wieder hinzugefügt habe, kam eine leere Fehlermeldung (siehe Bild) und dazu der log vielleicht hilft er dir ja weiter.
                  Danke für eure Arbeit und Zeit.
                  log.txt
                  • Asgothian
                    @luie
                    Das Hilft.. ich denke die leere "Fehlermeldung" sollte eine Erfolgsmeldung sein.. muss ich morgen testen.
                    A.
                      Ritter last edited by
                      hab die Version auch getestet und bei mir kommt auch nur der Weiße Kasten mit Error. Die Lampen sind Müller E27 mit Farbtemperaturregelung.
                      • Asgothian
                        Asgothian Developer @Ritter last edited by
                        @ritter Sind die Lampen danach in der Gruppe drin ? (im Objektbaum bitte nachsehen)
                          Ritter @Asgothian last edited by
                          @asgothian nur zwei von drei, bei der anderen ist nur so eine Eckige Klammer.
                          • Asgothian
                            @ritter versuch bitte nochmal genau diese auch der Gruppe hinzu zu fügen
                            A.
                              @asgothian Ich hab den Adapter nochmal neu installiert danach kahm rebuild hat etwas gedauert. Ich hab die Lampen aus den Gruppen noch mal entfernt. Dann wieder hinzugefügt. Nach kurzer Zeit kommt der Kasten mit Error drei mal. Bei den Objekten sind sie alle drei jetzt drin, aber sie regeln nicht.
                              • Asgothian
                                @ritter ok.. danke.. muss ich mir morgen anschauen. Heute komm ich da nicht zu
                                A.
                                  @asgothian Ok danke.
                                    Mit der regulären Version von Git kann ich die 3 Lampen zur Gruppe hinzufügen und funktioniert dann auch. Das zusammenfügen funktioniert nur wenn alle anderen Zigbee Lampen im Haus am Netz sind. Sobald ich z.B. die Lampen am Dachboden (eine 6er Gruppe) vom Netz trenne, stürzt der Adapter beim Hinzufügen einer Lampe zu einer Gruppe ab. Mit dieser Version funktionieren die Gruppen auch nicht wenn alle Lampen am Netz sind.
                                    • Asgothian
                                      @ritter sagte in Zigbee Adapter: Test der umgeschriebenen Gruppenfunktion:
                                      Dieses Verhalten war einer der Anfangspunkte für das Rewrite. Das die Gruppen nicht gehen mit der letzten Anpassung muss ich analysieren.
                                      A
                                      • Asgothian
                                        @Ritter @luie
                                        Bug gefunden. Bitte noch einmal neu installieren und erneut testen.
                                        Wichtig: Bei dieser Installation sollte auch ein Upload durchgeführt werden, damit die Anpassungen an der Oberfläche auch mit kommen. Dann wird im Gerät direkt sauber angezeigt wie sich die Gruppen geändert haben.
                                        A.
                                        R L 2 Replies Last reply Reply Quote 0
                                          @asgothian Mit dieser Version funktioniert es.
                                            @asgothian
                                            kurze Rückmeldung auf die Schnelle
                                            Geräte gelöscht und hinzugefügt ohne Absturz und Gruppenanzeige wird direkt sichtbar geändert.
                                            Danke dafür
                                            2817
