    4. Zigbee Adapter: Test der umgeschriebenen Gruppenfunktion
    • Asgothian
      Asgothian Developer @Asgothian last edited by
      Und noch eine weitere (hoffentlich finale) Iteration:
      • ACK for group state changes
      • Error wenn Gruppenmitglieder einen Wert nicht unterstützen (Bsp.: Color bei Lampen die keine Farbe können)
      A.
        luie last edited by
        @asgothian
        Geräte aus der Gruppe gelöscht und wieder hinzugefügt >> Adapter neustart
        2021-04-11 17:43:02.836  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2021-04-11 17:43:03.047  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        2021-04-11 17:43:05.910  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 15487
        2021-04-11 17:43:08.205  - info: zigbee.0 (15487) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
        2021-04-11 17:43:08.307  - info: zigbee.0 (15487) Starting Zigbee  npm ...
        2021-04-11 17:43:08.630  - info: zigbee.0 (15487) Installed Version: asgothian/ioBroker.zigbee#Groups
        2021-04-11 17:43:08.823  - info: zigbee.0 (15487) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
        2021-04-11 17:43:08.871  - info: zigbee.0 (15487) Unable to disable LED, unsupported function.
        2021-04-11 17:43:08.872  - info: zigbee.0 (15487)   --> transmitPower : normal
        2021-04-11 17:43:08.873  - info: zigbee.0 (15487) Unable to set transmit power, unsupported function.
        2021-04-11 17:43:08.878  - info: zigbee.0 (15487) Currently 30 devices are joined:
        2021-04-11 17:43:08.946  - info: zigbee.0 (15487) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
        2021-04-11 17:43:08.950  - info: zigbee.0 (15487) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 17:43:08.951  - info: zigbee.0 (15487) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        2021-04-11 17:43:08.953  - info: zigbee.0 (15487) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 17:43:08.954  - info: zigbee.0 (15487) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 17:43:08.956  - info: zigbee.0 (15487) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 17:43:08.957  - info: zigbee.0 (15487) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 17:43:08.959  - info: zigbee.0 (15487) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 17:43:08.960  - info: zigbee.0 (15487) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 17:43:08.961  - info: zigbee.0 (15487) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 17:43:08.963  - info: zigbee.0 (15487) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 17:43:08.964  - info: zigbee.0 (15487) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 17:43:08.966  - info: zigbee.0 (15487) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 17:43:08.967  - info: zigbee.0 (15487) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
        2021-04-11 17:43:08.968  - info: zigbee.0 (15487) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        2021-04-11 17:43:08.969  - info: zigbee.0 (15487) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 17:43:08.971  - info: zigbee.0 (15487) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
        2021-04-11 17:43:08.972  - info: zigbee.0 (15487) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
        2021-04-11 17:43:08.973  - info: zigbee.0 (15487) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 17:43:08.975  - info: zigbee.0 (15487) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 17:43:08.976  - info: zigbee.0 (15487) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 17:43:08.978  - info: zigbee.0 (15487) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 17:43:08.979  - info: zigbee.0 (15487) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        2021-04-11 17:43:08.980  - info: zigbee.0 (15487) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 17:43:08.987  - info: zigbee.0 (15487) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
        2021-04-11 17:43:08.989  - info: zigbee.0 (15487) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
        2021-04-11 17:43:08.994  - info: zigbee.0 (15487) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
        2021-04-11 17:43:08.995  - info: zigbee.0 (15487) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 17:43:08.996  - info: zigbee.0 (15487) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
        2021-04-11 17:43:08.998  - info: zigbee.0 (15487) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
        2021-04-11 17:43:09.000  - info: zigbee.0 (15487) Zigbee started
        2021-04-11 17:45:00.095  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 15658
        2021-04-11 17:45:01.650  - info: daswetter.0 (15658) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
        2021-04-11 17:45:14.937  - info: daswetter.0 (15658) got wrong data structure! trying to repair...
        2021-04-11 17:45:18.870  - info: daswetter.0 (15658) Terminated (NO_ERROR): Without reason
        2021-04-11 17:45:19.388  - info: daswetter.0 (15658) cleaned everything up...
        2021-04-11 17:45:19.408  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-04-11 18:00:00.081  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 16814
        2021-04-11 18:00:01.639  - info: daswetter.0 (16814) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
        2021-04-11 18:00:14.839  - info: daswetter.0 (16814) got wrong data structure! trying to repair...
        2021-04-11 18:00:18.696  - info: daswetter.0 (16814) Terminated (NO_ERROR): Without reason
        2021-04-11 18:00:19.217  - info: daswetter.0 (16814) cleaned everything up...
        2021-04-11 18:00:19.236  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-04-11 18:08:44.468  - info: web.0 (1188) <==Disconnect system.user.admin from ::ffff:192.168.0.5 jarvis
        2021-04-11 18:15:00.086  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 18073
        2021-04-11 18:15:01.592  - info: daswetter.0 (18073) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
        2021-04-11 18:15:14.829  - info: daswetter.0 (18073) got wrong data structure! trying to repair...
        2021-04-11 18:15:18.661  - info: daswetter.0 (18073) Terminated (NO_ERROR): Without reason
        2021-04-11 18:15:19.180  - info: daswetter.0 (18073) cleaned everything up...
        2021-04-11 18:15:19.199  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-04-11 18:21:33.636  - info: web.0 (1188) ==>Connected system.user.admin from ::ffff:192.168.0.5
        2021-04-11 18:22:38.195  - warn: zigbee.0 (15487) unread state change for group members ["0x0017880104907516"]
        2021-04-11 18:22:39.553  - error: zigbee.0 (15487) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-04-11 18:22:39.553  - error: zigbee.0 (15487) unhandled promise rejection: undefined
        2021-04-11 18:22:39.555  - info: zigbee.0 (15487) cleaned everything up...
        2021-04-11 18:22:39.558  - info: zigbee.0 (15487) Zigbee: disabling joining new devices.
        2021-04-11 18:22:40.051  - info: zigbee.0 (15487) terminating
        2021-04-11 18:22:40.054  - warn: zigbee.0 (15487) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2021-04-11 18:22:40.648  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2021-04-11 18:22:40.654  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
        2021-04-11 18:23:10.710  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 18716
        2021-04-11 18:23:13.051  - info: zigbee.0 (18716) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
        2021-04-11 18:23:13.157  - info: zigbee.0 (18716) Starting Zigbee  npm ...
        2021-04-11 18:23:13.484  - info: zigbee.0 (18716) Installed Version: asgothian/ioBroker.zigbee#Groups
        2021-04-11 18:23:13.678  - info: zigbee.0 (18716) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
        2021-04-11 18:23:13.731  - info: zigbee.0 (18716) Unable to disable LED, unsupported function.
        2021-04-11 18:23:13.732  - info: zigbee.0 (18716)   --> transmitPower : normal
        2021-04-11 18:23:13.734  - info: zigbee.0 (18716) Unable to set transmit power, unsupported function.
        2021-04-11 18:23:13.739  - info: zigbee.0 (18716) Currently 30 devices are joined:
        2021-04-11 18:23:13.804  - info: zigbee.0 (18716) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
        2021-04-11 18:23:13.808  - info: zigbee.0 (18716) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:23:13.809  - info: zigbee.0 (18716) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        2021-04-11 18:23:13.811  - info: zigbee.0 (18716) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:23:13.812  - info: zigbee.0 (18716) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:23:13.814  - info: zigbee.0 (18716) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:23:13.815  - info: zigbee.0 (18716) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:23:13.818  - info: zigbee.0 (18716) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:23:13.820  - info: zigbee.0 (18716) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:23:13.822  - info: zigbee.0 (18716) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:23:13.823  - info: zigbee.0 (18716) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:23:13.826  - info: zigbee.0 (18716) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:23:13.828  - info: zigbee.0 (18716) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:23:13.830  - info: zigbee.0 (18716) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
        2021-04-11 18:23:13.831  - info: zigbee.0 (18716) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        2021-04-11 18:23:13.833  - info: zigbee.0 (18716) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:23:13.834  - info: zigbee.0 (18716) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
        2021-04-11 18:23:13.836  - info: zigbee.0 (18716) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
        2021-04-11 18:23:13.838  - info: zigbee.0 (18716) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:23:13.841  - info: zigbee.0 (18716) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:23:13.843  - info: zigbee.0 (18716) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:23:13.845  - info: zigbee.0 (18716) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:23:13.847  - info: zigbee.0 (18716) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        2021-04-11 18:23:13.848  - info: zigbee.0 (18716) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:23:13.850  - info: zigbee.0 (18716) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
        2021-04-11 18:23:13.853  - info: zigbee.0 (18716) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
        2021-04-11 18:23:13.857  - info: zigbee.0 (18716) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
        2021-04-11 18:23:13.858  - info: zigbee.0 (18716) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:23:13.860  - info: zigbee.0 (18716) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
        2021-04-11 18:23:13.861  - info: zigbee.0 (18716) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
        2021-04-11 18:23:13.863  - info: zigbee.0 (18716) Zigbee started
        2021-04-11 18:25:17.018  - warn: zigbee.0 (18716) Failed to ping 0x8418260000101cf6 Plug 01
        2021-04-11 18:26:14.014  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 2. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
        2021-04-11 18:27:47.032  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 3. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":3,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
        2021-04-11 18:27:47.036  - error: zigbee.0 (18716) Exception when trying to Add 0x680ae2fffe3540df  to group 2. Error: Command 0x680ae2fffe3540df/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
        2021-04-11 18:28:27.339  - error: zigbee.0 (18716) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-04-11 18:28:27.340  - error: zigbee.0 (18716) unhandled promise rejection: undefined
        2021-04-11 18:28:27.342  - info: zigbee.0 (18716) cleaned everything up...
        2021-04-11 18:28:27.344  - info: zigbee.0 (18716) Zigbee: disabling joining new devices.
        2021-04-11 18:28:27.843  - info: zigbee.0 (18716) terminating
        2021-04-11 18:28:27.845  - warn: zigbee.0 (18716) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2021-04-11 18:28:28.449  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2021-04-11 18:28:28.454  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
        2021-04-11 18:28:58.505  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 19186
        2021-04-11 18:29:00.807  - info: zigbee.0 (19186) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
        2021-04-11 18:29:00.912  - info: zigbee.0 (19186) Starting Zigbee  npm ...
        2021-04-11 18:29:01.244  - info: zigbee.0 (19186) Installed Version: asgothian/ioBroker.zigbee#Groups
        2021-04-11 18:29:01.426  - info: zigbee.0 (19186) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
        2021-04-11 18:29:01.475  - info: zigbee.0 (19186) Unable to disable LED, unsupported function.
        2021-04-11 18:29:01.476  - info: zigbee.0 (19186)   --> transmitPower : normal
        2021-04-11 18:29:01.478  - info: zigbee.0 (19186) Unable to set transmit power, unsupported function.
        2021-04-11 18:29:01.482  - info: zigbee.0 (19186) Currently 30 devices are joined:
        2021-04-11 18:29:01.551  - info: zigbee.0 (19186) 0x001788011039c09e (addr 23154): 324131092621 - Philips Hue dimmer switch (EndDevice)
        2021-04-11 18:29:01.555  - info: zigbee.0 (19186) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:29:01.556  - info: zigbee.0 (19186) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        2021-04-11 18:29:01.558  - info: zigbee.0 (19186) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:29:01.559  - info: zigbee.0 (19186) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:29:01.561  - info: zigbee.0 (19186) 0xec1bbdfffecfa3d9 (addr 21371): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:29:01.562  - info: zigbee.0 (19186) 0xec1bbdfffeec05dc (addr 50519): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:29:01.564  - info: zigbee.0 (19186) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:29:01.565  - info: zigbee.0 (19186) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:29:01.568  - info: zigbee.0 (19186) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
        2021-04-11 18:29:01.570  - info: zigbee.0 (19186) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:29:01.572  - info: zigbee.0 (19186) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:29:01.573  - info: zigbee.0 (19186) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:29:01.575  - info: zigbee.0 (19186) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
        2021-04-11 18:29:01.576  - info: zigbee.0 (19186) 0x000d6f000e639ce8 (addr 11432): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        2021-04-11 18:29:01.577  - info: zigbee.0 (19186) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:29:01.579  - info: zigbee.0 (19186) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
        2021-04-11 18:29:01.580  - info: zigbee.0 (19186) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
        2021-04-11 18:29:01.581  - info: zigbee.0 (19186) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:29:01.583  - info: zigbee.0 (19186) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:29:01.584  - info: zigbee.0 (19186) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:29:01.586  - info: zigbee.0 (19186) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
        2021-04-11 18:29:01.587  - info: zigbee.0 (19186) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        2021-04-11 18:29:01.588  - info: zigbee.0 (19186) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:29:01.589  - info: zigbee.0 (19186) 0x0017880100ce3b70 (addr 57615): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
        2021-04-11 18:29:01.592  - info: zigbee.0 (19186) 0x0017880100ce3b8c (addr 43430): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
        2021-04-11 18:29:01.596  - info: zigbee.0 (19186) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
        2021-04-11 18:29:01.597  - info: zigbee.0 (19186) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
        2021-04-11 18:29:01.598  - info: zigbee.0 (19186) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
        2021-04-11 18:29:01.600  - info: zigbee.0 (19186) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
        2021-04-11 18:29:01.601  - info: zigbee.0 (19186) Zigbee started
        • Asgothian
          Asgothian Developer @luie last edited by Asgothian
          @luie Kannst du bitte den Adapter in debug schalten und nocheinmal versuchen die gleiche Steckdose den gleichen Gruppen hinzu zu fügen ? Es scheint so zu sein das es ein Problem gibt wenn das Gerät nicht erreichbar ist.
          A.
          Nachtrag: Die Meldungen bekomme ich auch, allerdings stürzt bei mir der Adapter nicht ab.
          • Asgothian
            @luie
            1. Nachtrag: Bitte nochmal vom Link anpassen - ich habe an der Fehlerbehandlung noch Anpassungen vorgenommen.
            A.
              luie last edited by luie
              @asgothian
              Dieses Mal ist der iobroker oder der raspi komplett abgestürzt. Habe die Geräte aus der Gruppe gelöscht und als ich sie wieder hinzugefügt habe, kam eine leere Fehlermeldung (siehe Bild) und dazu der log vielleicht hilft er dir ja weiter.
              Danke für eure Arbeit und Zeit.
              log.txt
              • Asgothian
                @luie
                Das Hilft.. ich denke die leere "Fehlermeldung" sollte eine Erfolgsmeldung sein.. muss ich morgen testen.
                A.
                  Ritter last edited by
                  hab die Version auch getestet und bei mir kommt auch nur der Weiße Kasten mit Error. Die Lampen sind Müller E27 mit Farbtemperaturregelung.
                  • Asgothian
                    Asgothian Developer @Ritter last edited by
                    @ritter Sind die Lampen danach in der Gruppe drin ? (im Objektbaum bitte nachsehen)
                      Ritter @Asgothian last edited by
                      @asgothian nur zwei von drei, bei der anderen ist nur so eine Eckige Klammer.
                      • Asgothian
                        @ritter versuch bitte nochmal genau diese auch der Gruppe hinzu zu fügen
                        A.
                          @asgothian Ich hab den Adapter nochmal neu installiert danach kahm rebuild hat etwas gedauert. Ich hab die Lampen aus den Gruppen noch mal entfernt. Dann wieder hinzugefügt. Nach kurzer Zeit kommt der Kasten mit Error drei mal. Bei den Objekten sind sie alle drei jetzt drin, aber sie regeln nicht.
                          • Asgothian
                            @ritter ok.. danke.. muss ich mir morgen anschauen. Heute komm ich da nicht zu
                            A.
                              @asgothian Ok danke.
                                Mit der regulären Version von Git kann ich die 3 Lampen zur Gruppe hinzufügen und funktioniert dann auch. Das zusammenfügen funktioniert nur wenn alle anderen Zigbee Lampen im Haus am Netz sind. Sobald ich z.B. die Lampen am Dachboden (eine 6er Gruppe) vom Netz trenne, stürzt der Adapter beim Hinzufügen einer Lampe zu einer Gruppe ab. Mit dieser Version funktionieren die Gruppen auch nicht wenn alle Lampen am Netz sind.
                                • Asgothian
                                  @ritter sagte in Zigbee Adapter: Test der umgeschriebenen Gruppenfunktion:
                                  Dieses Verhalten war einer der Anfangspunkte für das Rewrite. Das die Gruppen nicht gehen mit der letzten Anpassung muss ich analysieren.
                                  A
                                  • Asgothian
                                    @Ritter @luie
                                    Bug gefunden. Bitte noch einmal neu installieren und erneut testen.
                                    Wichtig: Bei dieser Installation sollte auch ein Upload durchgeführt werden, damit die Anpassungen an der Oberfläche auch mit kommen. Dann wird im Gerät direkt sauber angezeigt wie sich die Gruppen geändert haben.
                                    A.
                                    R L 2 Replies Last reply Reply Quote 0
                                      @asgothian Mit dieser Version funktioniert es.
                                        luie @Asgothian last edited by
                                        @asgothian
                                        kurze Rückmeldung auf die Schnelle
                                        Geräte gelöscht und hinzugefügt ohne Absturz und Gruppenanzeige wird direkt sichtbar geändert.
                                        Danke dafür
                                          Habe heute morgen 1.4.5 aufgespielt. Habe eine Gruppe. Allerdings eine einfache nit 2 baugleichen ikea floalt Panels. Keine Probleme festgestellt.
                                          31.7k
                                          79.9k
                                          2307
