    4. Node-Red
    5. Temperaturen über Node RED und Alexa abfragen!
    • ostseereiter
      ostseereiter @LaBamba last edited by
      @LaBamba
      Wenn du in Node Red was an Alexa übergeben willst am besten erst den Adapter neu starten und dann die Geräte suchen lassen.
      • D3ltoroxp
        D3ltoroxp last edited by
        So der Flow zum abfragen läuft schon mal 1a, könnte ich hier kombinieren ? Wenn ich Frage, Alexa wie ist die Temperatur das sie dann die Temp sagt und anschließen die Luftfeuchte ? Hab den Code von @Fenian
                "id": "3ff22dd8.7fec9a",
                "type": "tab",
                "label": "Temperaturansagen",
                "disabled": false,
                "info": ""
                "id": "ffc59ffe.a9a58",
                "type": "amazon-echo-hub",
                "z": "3ff22dd8.7fec9a",
                "port": "80",
                "enableinput": false,
                "x": 100,
                "y": 64,
                "wires": [
                        "60cd043e.a012ec"
                "id": "60cd043e.a012ec",
                "type": "amazon-echo-device",
                "name": "Temperatur Schlafzimmer",
                "topic": "",
                "x": 330,
                "y": 64,
                "wires": [
                        "880ed474.c7dfb8",
                        "7cb2ff99.6c53d"
                "id": "880ed474.c7dfb8",
                "type": "ioBroker get",
                "name": "serialNumber",
                "topic": "alexa2.0.History.serialNumber",
                "attrname": "payload",
                "payloadType": "value",
                "x": 565,
                "y": 64,
                "wires": [
                        "af872fed.2e36d"
                "id": "7cb2ff99.6c53d",
                "name": "Raumklima Schlafzimmer temperature",
                "topic": "deconz.0.Sensors.39.temperature",
                "x": 633.5,
                "y": 111,
                "wires": [
                        "af872fed.2e36d"
                "id": "af872fed.2e36d",
                "type": "join",
                "name": "",
                "mode": "custom",
                "build": "array",
                "property": "payload",
                "propertyType": "msg",
                "key": "topic",
                "joiner": "\\n",
                "joinerType": "str",
                "accumulate": false,
                "timeout": "",
                "count": "2",
                "reduceRight": false,
                "reduceExp": "",
                "reduceInit": "",
                "reduceInitType": "",
                "reduceFixup": "",
                "x": 880,
                "y": 65,
                "wires": [
                        "5517ab3.6b2e7d4"
                "id": "5517ab3.6b2e7d4",
                "type": "function",
                "name": "Temperatur auslesen",
                "func": "var device = msg.payload[0]\nvar str = msg.payload[1];\nvar res = str.substr(0, 5);\nmsg.payload = Math.round(res);\nmsg.payload = \"Es sind \" + msg.payload + \" Grad im Schlafzimmer\";\nmsg.url = \"\";\nvar command = \"alexa2.0.Echo-Devices.\" + device + \".Commands.speak\"\nmsg.topic = command;\nreturn msg;\n",
                "outputs": 1,
                "noerr": 0,
                "x": 1053,
                "y": 65,
                "wires": [
                        "90bca55d.0d3348"
                "id": "90bca55d.0d3348",
                "type": "ioBroker out",
                "name": "speak",
                "topic": "",
                "ack": "false",
                "autoCreate": "false",
                "x": 1224.5,
                "y": 65,
                "wires": []
          frankyboy73 @D3ltoroxp last edited by
          @D3ltoroxp
          Ja, das geht, einfach noch mit ner Get Node die Luftfeuchte abfragen, dann aber bei Atribute was anderes als payload eintragen und das dann als Variable mit in den Text eintragen.
          Meine Lösung sieht so aus.
                  "id": "a4b2c539.1cc178",
                  "z": "f4971799.ec9a88",
                  "name": "Temperatur Schalfen",
                  "topic": "0_userdata.0.Korrektur.Temperatur_Schlafen",
                  "x": 220,
                  "y": 420,
                  "wires": [
                          "355a80e9.515da"
                  "id": "e5ab3971.1bd0d8",
                  "type": "function",
                  "name": "speak",
                  "func": "msg.payload = Math.round(msg.payload * 10) / 10;\nmsg.hue = Math.round(msg.hue);\nvar temp = msg.payload;\nvar hue = msg.hue\nmsg.payload = ' Die Temperatur im Schlafzimmer beträgt ' + temp + ' Grad;' + ' Die Luftfeuchtigkeit liegt bei' + hue + ' Prozent';\nreturn msg;",
                  "outputs": 1,
                  "noerr": 0,
                  "x": 630,
                  "y": 420,
                  "wires": [
                          "a23ad8e5.f3d738"
                  "id": "355a80e9.515da",
                  "name": "Feuchte Schlafen",
                  "topic": "deconz.0.Sensors.22.humidity",
                  "attrname": "hue",
                  "x": 450,
                  "y": 420,
                  "wires": [
                          "e5ab3971.1bd0d8"
                  "id": "a23ad8e5.f3d738",
                  "attrname": "topic",
                  "x": 800,
                  "y": 420,
                  "wires": [
                          "efbeb8f1.cd9808"
                  "id": "efbeb8f1.cd9808",
                  "type": "function",
                  "name": "Echo Ausgabe",
                  "func": "\n\nmsg.topic = 'alexa2.0.Echo-Devices.' + \n\n    msg.topic + '.Commands.speak';\n\nreturn msg;\n",
                  "outputs": 1,
                  "noerr": 0,
                  "x": 980,
                  "y": 420,
                  "wires": [
                          "3e5d48e8.73bec8"
                  "id": "3e5d48e8.73bec8",
                  "name": "",
                  "topic": "",
                  "ack": "false",
                  "x": 1140,
                  "y": 420,
                  "wires": []
          • D3ltoroxp
            D3ltoroxp last edited by D3ltoroxp
            Vielen Dank,
            ich hatte das jetzt über ioBroker und Alexa gelöst, mit NodeRed als Trigger. Das klappt soweit auch wunderbar. Dennoch vielen Dank.
            Basti97 1 Reply Last reply Reply Quote 0
            • Basti97
              Basti97 Most Active @D3ltoroxp last edited by
              @d3ltoroxp Ich hänge gerade auch bei node red. Wie muss ich das Programmieren wenn ich Frage wie hoch ist die Temperatur und sie sagt 23Grad zum Beispiel.
              • mickym
                mickym Most Active @Basti97 last edited by mickym
                @basti97 Na Du hast einen Trigger - der DEinen Flow startet - wohl eine Alexa Node.
                Dann fragst Du Deinen Datenpunkt ab und schickst es an den DAtenpunkt als Text der die Sprachausgabe macht. So was ähnliches habe ich gerade in dem Thread gemacht. Allerdings weiß ich ja nicht, ob ihr hier die gleichen Nodes verwendet.
                Basti97 2 Replies Last reply Reply Quote 0
                • Basti97
                  Basti97 Most Active @mickym last edited by
                  @mickym Mhh ich wollte das auch über Blockly machen aber dort sagt Alexa "das weiß ich leider nicht".
                    Apropo @Basti97 last edited by
                    @basti97 Du musst dazu noch in Alexa eine Routine erstellen mit Aktion 5 Sekunden warten. Dann sollte die Meldung nicht kommen.
                    • Basti97
                      Basti97 Most Active @Apropo last edited by
                      @apropo okay da muss ich mal gucken. Daher dachte ich wenn ich das über node red mache das es einfacher ist.
                      • Basti97
                        Basti97 Most Active @mickym last edited by Basti97
                        @mickym So hier
                        In der mitte ist die Temperatur
                        • mickym
                          @basti97 Ja das ist es doch schon fast - oder weist Du nicht, wie Du den Text erstellst den Du in die textCommand schicken willst?
                          Falls es das ist - dann nimm eine Template Node, schreibe den Text da rein, den Du ausgeben willst und für die geholte Temperatur gibtst {{payload}} an der entsprechenden Stelle ein. Das wars.
                          • Basti97
                            @mickym Was wäre das für ein Symbol/ Baustein was ich nehmen müsste? Die Alexa hat das "Gerät Temperatur Aquarium" auch schon erkannt. Aber das wird in der App als Lampe angezeigt ist das richtig? Ich dachte in der Alexa App wird das auch als Temperatur angezeigt oderso.
                            Bis jetzt habe ich nur digitale Befehle von meiner Alexa entgegen genommen. Aber noch nie Analoge, deshalb stelle ich die Fragen 🙂
                            • mickym
                              @basti97 Ich kann Dir leider was Alexa und deren Nodes betrifft nicht weiterhelfen, weil ich weder die Nodes noch die Alexa benutze.
                              Wenn ich mir das anschaue werden alle Geräte von Alexa nur als Licht erkannt und deshalb auch nur diese Befehle kennt.
                              Alexa, turn on/off {device}
                              Alexa, switch on/off {device}
                              Alexa, set {device} to 50%
                              Alexa, turn my {device} light green
                              Alexa, set the {device} light to orange
                              Alexa, make the {device} warmer
                              Alexa, brighten {device} to 60 percent
                              Alexa, dim the {device} lights
                              Was Du dann aber im NodeRed Flow machst kann ja dann was ganz anderes sein, das bekommt Alexa nicht mit.
                              Wenn Du also sagst: Mache Aquarium Info ein - und Du dann Text in Deine Speach Node schickt - dann wird Alexa trotzdem denken, dass Du Licht einschaltest.
                              Aber wie gesagt, dass ist nur eine Vermutung wie das funktioniert.
                              Ansonsten muss man wahrscheinliche ganz anderen Anbindungen suchen - aber ich bin was Alexa betrifft raus. Ich kann Dir innerhalb eines Flows helfen - aber nicht was die Alexa Nodes betrifft.
                              • Basti97
                                @mickym Ok Danke für den Tipp bisher habe ich mit nodered noch nicht so viel am Hut gehabt. Was kann man eigentlich alles damit machen.
                                Naja das ist mein erster Versuch mit Alexa. Eigentlich müsste ich ja nur das virtuelle Gerät in Alexa bringen. Und danach müsste sie eigentlich selbst auslesen was dort steht und mir das sagen. So die Theorie 🙂
                                Andere Variante die ich hatte war über ein Blockly oder so das ganze auszuwerten. Da über den Alexa Adapter das was man gesprochen hat abgespeichert wird. Mit Hilfe diesen könnte man auf den Text reagieren und zb die Aquarium Infos wieder zurück geben. Aber das funktioniert nicht da Alexa sagt "das sie das Gerät nicht kennt".
                                mickym F 2 Replies Last reply Reply Quote 0
                                • mickym
                                  @basti97 NodeRed ist im Prinzip genauso eine Logikmaschine wie Blockly und wenn Du lieber mit Blockly arbeitest ist das ja in Ordnung, dann musst Du Dich auch nicht groß mit NodeRed beschäftigen.
                                  Nun gibts in NodeRed einige Nodes - für die es im iobroker keine Adapter gibt oder nicht mehr so gepflegt werden (ich persönlich wollte erst kürzlich den SNMP Adapter nutzen - bin dann aber sehr schnell davon abgekommen. ). So willst Du nun halt im Node Red die Alexa Nodes nutzen.
                                  Du kannst doch einfach einen Datenpunkt im iobroker erstellen und darin speicherst Du 1:1 was aus Deine Temperatur Aquarium Alexa Node rauskommt.
                                  Dann brauchst Dich nicht mehr mit NodeRed nicht weiter zu beschäftigen, sondern verarbeitest den Output direkt mit Blockly weiter.
                                  Das ist doch das Schöne am ioBroker das man alles miteinander kombinieren kann. Nutze einfach NodeREd als Adapter und verarbeite den Output mit Blockly weiter.
                                  Das in Deinem Fall die Alexa Nodes weder die Fähigkeiten noch die Zustände Deiner Geräte selbst kennen, da kann ich wenig dazu sagen. Genauso wenig warum die Geräte aus dem iobroker Adapter das der Alexa nicht begreiflich machen können.
                                  Deshalb geht diese Herangehensweise halt davon aus, das man für Alexa eine Sprachausgabe nutzt und dieser mitteilt, was sie zum Beispiel zum Aquarium sagen soll. Das kannst Du aber mit Blockly genauso realisieren.
                                    frankyboy73 @Basti97 last edited by
                                    @basti97 Hi, die Alexa Node in Node Red können nur eine Lampe oder einen Schalter simulieren. Temperaturanzeige oder Thermosthate gehen damit nicht.
                                    Apropo hatte dir ein paar Beiträge vorher schon nen Tipp gegeben mit Routinen.
                                    Du erstellst dir eine Routine in der ALexa App mit z.B. "Wenn fogendes passiert" darin dann das was du Fragen willst z.B. "Wie ist die Temperatur im Aqaurium" als Aktion dann "Warten", dadurch meckert sie schon mal nicht bei der Frage.
                                    Über summery kannst du dir ja auslesen was sie verstanden hat und dann mit Blockly deine Sprachausgabe mit dem Temperturwert realisieren. Dann brauchst du dafür gar kein Node Red.
                                    Allerdings könnte man das ganze auch mit Node Red umsetzen.
                                    • Basti97
                                      Basti97 Most Active @frankyboy73 last edited by
                                      @frankyboy73 Routinen habe ich bis jetzt noch gar nicht benutzt. Da muss ich mal gucken wo ich das in der App finde bzw Einstellen mus.
                                      • Basti97
                                        @mickym Trotzdem Danke aber irgendwie ist Node red trotzdem interessant. Es ist gut wenn man sich überall bisschen auskennt. Also Javascript und node red stehen bei mir jetzt ganz oben wo ich mich noch einlesen muss. 🙂 🙂
                                        Fenian 1 Reply Last reply Reply Quote 0
                                        • Fenian
                                          Fenian @Basti97 last edited by
                                          @basti97 Nichts gegen Node red und Blockly...
                                          Damit kann man sehr gut so einiges lösen.
                                          Ich weiss zwar nicht, von welchem Gerät die Temperatur kommt, aber hier scheint mir der IOT-Adapter die beste Wahl zu sein.
                                          Der zeigt zwar keine Werte in der App an, aber die Abfrage mit Alexa funktioniert damit ohne Probleme.
                                          Ganz ohne Blockly / Node red und Routine in der Alexa App.
                                          P.S.: Javascript / Node Red sind trotzdem interessante Dinge in die man sich einlesen sollte 😄
                                            frankyboy73 @Basti97 last edited by frankyboy73
                                            @basti97 Wenn du spezifische Abfragen umsetzen möchtest die Alexa nicht kennt, bzw. mit der Alexa Node nicht gehen, wirst du nicht ohne Routinen auskommen damit Alexa nicht meckert. Ich habe das auch bei einigen Abfragen so umgesetzt, der Vorteil ist, das man genau die Sätze erstellen kann die einem selber als Sinnvoll erscheinen und nicht die nutzen muss die Alxea sinnvoll findet.
                                            Als Beispiel mein Geragentoröffner. Wenns nach Alxea geht muss ich sagen "schalte Garage Ein" wenn ich die Garage schließen oder öffnen will. Über Routinen habe ich das so gelöst das ich einmal eine habe, wenn ich sage " Öffne Garage" und eine wenn ich sage "Schließe Garage" in beiden Routinen habe ich dann als Aktion Smarthome Gerät Garage Ein. Ist doch viel sinnvoller.
                                            Du könntest auch den Weg gehen, ne Routine erstellen "Wie ist die Temperatur im Aquarium" als Aktion dann das Gerät Aquarium auswählen (Einschalten) und in Node Red dann wenn Aquarium eingeschaltet wurde den Temperturwert per speak ausgeben.
                                            Wenn du Node Red interessant findest, solltest du dich da auf jeden Fall mit beschäftigen. Ich bin dadurch komplett von Blockly weg und spare mir dadurch auch andere Adapter wie Telegramm, Email oder Vis, da sich das alles in Node Red umsetzen lässt. (Die Vis ist in Node Red allerdings eher funktionell als optisch schön)
                                            @Fenian Sicher wäre hier der IOT eine bequeme Lösung, ist allerdings ne Cloudlösung zu der man bei bei zu vielen Abfragen auch noch ein Abo braucht. Bei den Alexa Nodes bleibt alles Netzintern.
                                            Basti97 1 Reply Last reply Reply Quote 1
                                            109
                                            16668
