    4. eqiva Türschloßantrieb
    • U
      UwesSmartHome @UwesSmartHome last edited by
      @uwessmarthome
      Kleine Korrektur auf einem weiterem Raspberry (heute NPM aktualisiert) kommt keine Error Message und er Adapter wird sogar grün. Versuche in den nächsten Stunden das paring zu machen. Schönen Ostermontag
      • U
        UwesSmartHome last edited by UwesSmartHome
        code_text
        ```pi@RaspiMaster:~ $ keyble-registeruser -n 7 -q M001A22098C33K7E57A65F118662D9E3B425DA66D6ED2FNEQ1058982
        internal/modules/cjs/loader.js:1057
          return process.dlopen(module, path.toNamespacedPath(filename));
        Error: The module '/usr/lib/node_modules/keyble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node'
        was compiled against a different Node.js version using
        NODE_MODULE_VERSION 64. This version of Node.js requires
        NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        the module (for instance, using `npm rebuild` or `npm install`).
            at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
            at Module.load (internal/modules/cjs/loader.js:863:32)
            at Function.Module._load (internal/modules/cjs/loader.js:708:14)
            at Module.require (internal/modules/cjs/loader.js:887:19)
            at require (internal/modules/cjs/helpers.js:74:18)
            at Object.<anonymous> (/usr/lib/node_modules/keyble/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)
            at Module._compile (internal/modules/cjs/loader.js:999:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
            at Function.Module._load (internal/modules/cjs/loader.js:708:14)```
        code_text
          Thomas Braun Most Active @UwesSmartHome last edited by Thomas Braun
          @uwessmarthome
          Node sauber?
          Konsolenmeldungen bitte nicht als Screenshot sondern als Text in CodeTags ins Forum.
          • U
            UwesSmartHome @Thomas Braun last edited by UwesSmartHome
            codpi@RaspiMaster:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.21.0
            /usr/bin/node
            v12.21.0
            /usr/bin/npm
            6.14.12
            nodejs:
              Installiert:           12.21.0-1nodesource1
              Installationskandidat: 12.21.0-1nodesource1
              Versionstabelle:
             *** 12.21.0-1nodesource1 100
                    100 /var/lib/dpkg/status
                 10.24.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u1 500
            e_text
            Thomas Braun U 2 Replies Last reply Reply Quote 0
              @uwessmarthome
              Bitte CodeTags verwenden.
              Und das System auf Stand halten.
              sudo apt update
              sudo apt dist-upgrade
              sudo reboot
              Für node12 ist keine Paketquelle / kein Repository angelegt. Lies den Kram zu node aus meiner Signatur.
              • U
                UwesSmartHome @UwesSmartHome last edited by UwesSmartHome
                @uwessmarthome
                Hab es heute nochmal versucht, leider erfolglos. Diese Fehlermeldung bleibt. Node Modul Version falsch?
                • U
                   keyble-registeruser -n 7 -q M001A22098C33K7E57A65F11xxxxxxx        425DA66D6ED2FNEQ1058982
                  Error: The module '/usr/lib/node_modules/keyble/node_modules/@abandonware/blueto        oth-hci-socket/lib/binding/bluetooth_hci_socket.node'
                      at Object.<anonymous> (/usr/lib/node_modules/keyble/node_modules/@abandonwar        e/bluetooth-hci-socket/lib/native.js:6:15)
                  • U
                    /usr/lib/node_modules/keyble/node_modules $ sudo npm rebuild
                    > @abandonware/noble@1.9.2-11 install /usr/lib/node_modules/keyble/node_modules/@abandonware/noble
                    > node-gyp rebuild
                    gyp ERR! clean error
                    gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                    gyp ERR! System Linux 5.10.17-v7+
                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                    gyp ERR! cwd /usr/lib/node_modules/keyble/node_modules/@abandonware/noble
                    gyp ERR! node -v v12.22.1
                    gyp ERR! node-gyp -v v5.1.0
                    gyp ERR! not ok
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! @abandonware/noble@1.9.2-11 install: `node-gyp rebuild`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the @abandonware/noble@1.9.2-11 install script.
                    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                    npm ERR!     /root/.npm/_logs/2021-04-11T10_57_26_697Z-debug.log
                      @uwessmarthome Nicht als root rumhampeln, npm nicht in Verbindung mit sudo einsetzen.
                      U B 2 Replies Last reply Reply Quote 0
                      • U
                        @thomas-braun ```
                        pi@Master:~ $ keyble-registeruser -n Use -q M001A22098DF0K676641D845A53AB9481166DDAF024C9ANEQ1058450
                        Press and hold "Unlock" button until the yellow light flashes in order to enter pairing mode
                        Registering user on Smart Lock with address "00:xx:22:09:8d:xx", card key "676641d845a53aXXXXXXddaf024c9a" and serial "NEQ1058450"...
                        Habe es auf dem einem System geschafft die Fehlermeldungen kommen nicht mehr. Leider ist eine Anmeldung nicht möglich, es bleibt immer stehen nachdem der Button am Türschloss gedrückt wurde. Die QR Daten habe ich schon x-mal geprüft. Die Bluetooth Adresse ebenso, auch das Schloss ganz nahe am Raspberry bringt keine Anmeldung zustande. Noch eine Idee?
                          bambo587 @Thomas Braun last edited by
                          habe das gleich problem wie @UwesSmartHome.
                          Da fehlt die halbe Ausgabe.
                          System neu geupdatet, sogar mit Node 14 ausprobiert, wg. Fehler wieder bei node 12.
                          Was fehlt da??
                            Thomas Braun Most Active @bambo587 last edited by
                            @bambo587 sagte in eqiva Türschloßantrieb:
                            Was fehlt da??
                            Meldungen aus deinem System fehlen da...
                            • V
                              Vocaris last edited by
                              ich überlege gerade, ob ich das Türschloss von Homematic kaufen soll oder das günstigere von eqiva.
                              Der eqiva hat ja nur BT. Scheint also mit einem ioB zu gehen, wenn dieser BT hat. Zumindest verstehe ich das hier so.
                              Kann man es auch direkt mit Alexa verbinden?
                              Was meint Ihr so? Besser HM oder Eqiva.
                              PS: Wenn der ioB aus wäre (z.B. abgestürzt) könnte ich das Schloss von HM ja nicht öffnen. Bei Eqiva könnte ich immer noch per BT öffnen. Aber ist BT ggf. einfacher zu "knacken"?
                                JayP79 @Elzershark last edited by
                                @elzershark bei mir kommt nach "Registering user on Smart Lock wird address... " keine Rückmeldung mit username_1 etc.
                                Hat jemand einen Tipp für mich?
                                Viele Grüße
                                JP
                                  JayP79 @JayP79 last edited by
                                  Jetzt bekomme ich immer die Meldung: TypeError: Cannot read properties of undefined (reading 'get_discovered_characteristic')
                                  at /usr/lib/node_modules/keyble/keyble.js:878:56
                                  • Schaxxe
                                    Schaxxe last edited by
                                    Das Ding wird scheinbar nicht wirklich weiterentwickelt und gefixt oder?
                                    Ich dachte, ich nutze einen BT Dongel in einer VM unter Proxmox, bekomme aber die Selbe Meldung wie JayP79 und kann keinen Benutzer anlernen.
                                    Wenn ich einen alten Pi neben dran halte, bekomme ich User Key und einen Benutzer angelegt, dann kann ich in der eigens dafür angelegten VM genau EINMAL erfolgreich den Status des Schlosses abfragen, dann geht nie wieder irgendein Befehl (VM neu aufsetzen, dann gehts wieder, genau einmal)...Das ist dann die Antwort:
                                    Error: TypeError: Cannot read properties of undefined (reading 'get_discovered_characteristic')
                                    Ist die "Lösung" wirklich einen Pi mit Bluetooth neben das Schloss zu nageln, obwohl mein Proxmox mit BT nur ca 2m weiter hinten steht? Wenn ja, nicht sehr sexy
                                      Homoran Global Moderator Administrators @Schaxxe last edited by
                                      @schaxxe sagte in eqiva Türschloßantrieb:
                                      Dieses bitte auf Github beim Entwickler nachfragen.
                                      Das ist kein ioBroker-Projekt
                                      Sieht aber so aus, als ob die letzte Aktivität 3 Jahre her ist
                                      • Marc_el_K
                                        Marc_el_K last edited by
                                        Falls auch noch jemand Interessa dem Github Projekt mittels ESP32 hat, würde ich mich freuen, wenn ihr den Beitrag mit +1 pusht 🙂
                                        https://forum.iobroker.net/topic/68563/anfrage-für-programmier-code-anpassung-gesucht
                                        • DJMarc75
                                          DJMarc75 @Marc_el_K last edited by
                                          @marc_el_k sagte in eqiva Türschloßantrieb:
                                          den Beitrag hier im Forum oder Dein Issue auf Github ?
                                          Marc_el_K 1 Reply Last reply Reply Quote 0
                                          • Marc_el_K
                                            Marc_el_K @DJMarc75 last edited by
                                            @djmarc75 diesen hier: https://forum.iobroker.net/topic/68563/anfrage-für-programmier-code-anpassung-gesucht
                                            26
                                            4237
