    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
      Kueppert @Meistertr last edited by
      @meistertr hab den Vacuum V1 mit Valetudo.
      Installation ohne AUffälligkeiten LOG auch ohne Auffälligkeiten. Das eine Answer Map Slot hatte ich vorher auch schon 🙂
      mihome-vacuum.0	2021-04-14 19:04:47.679	warn	(18778) answer map_slot is currently not supported!
      mihome-vacuum.0	2021-04-14 19:04:27.601	warn	(18778) answer map_slot is currently not supported!
      mihome-vacuum.0	2021-04-14 19:04:07.723	info	(18778) settest next timer: not available
      mihome-vacuum.0	2021-04-14 19:04:07.498	info	(18778) create state for carpet_mode
      mihome-vacuum.0	2021-04-14 19:04:07.482	warn	(18778) answer map_slot is currently not supported!
      mihome-vacuum.0	2021-04-14 19:04:07.354	info	(18778) Map selected create states...
      mihome-vacuum.0	2021-04-14 19:04:07.124	warn	(18778) State "mihome-vacuum.0.deviceInfo.mac" has no existing object, this might lead to an error in future versions
      mihome-vacuum.0	2021-04-14 19:04:07.122	warn	(18778) State "mihome-vacuum.0.deviceInfo.fw_ver" has no existing object, this might lead to an error in future versions
      mihome-vacuum.0	2021-04-14 19:04:07.121	warn	(18778) State "mihome-vacuum.0.deviceInfo.model" has no existing object, this might lead to an error in future versions
      Ok, wenn ich versuche die MAP zu laden, bekomme ich auch o. g. warn-Meldung im LOG. Hab nur Valetudo bei Map aktiviert...
        Kueppert last edited by Kueppert
        gerade den Saugi gestartet und versucht nach 30 Sek wieder nach Hause zu schicken:
        mihome-vacuum.0	2021-04-14 19:12:58.963	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 19:12:30.497	warn	(28226) Error at stop Cleaning: MESSAGE TIMEOUT
        mihome-vacuum.0	2021-04-14 19:12:24.858	info	(28226) Map selected create states...
        mihome-vacuum.0	2021-04-14 19:12:24.669	warn	(28226) Login failed
        mihome-vacuum.0	2021-04-14 19:12:23.854	info	(28226) settest next timer: not available
        mihome-vacuum.0	2021-04-14 19:12:23.262	info	(28226) select standard vacuum protocol....
        mihome-vacuum.0	2021-04-14 19:12:23.260	warn	(28226) No Answer for DeviceModel use model from Config
        mihome-vacuum.0	2021-04-14 19:12:23.259	warn	(28226) No Answer for DeviceModel use old one
        mihome-vacuum.0	2021-04-14 19:12:23.259	warn	(28226) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER CONNECTION CAN TAKE UP TO 10 MINUTES PLESASE WAIT AND DON`T TRUN THE ADAPTER OFF
        mihome-vacuum.0	2021-04-14 19:12:13.156	info	(28226) check group user admin group admin: false
        mihome-vacuum.0	2021-04-14 19:12:12.214	info	(28226) check user admin pw iobroker: true
        mihome-vacuum.0	2021-04-14 19:12:11.689	info	(28226) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
        mihome-vacuum.0	2021-04-14 19:11:39.172	warn	(27284) Terminated (UNCAUGHT_EXCEPTION): Without reason
        mihome-vacuum.0	2021-04-14 19:11:39.170	info	(27284) terminating
        mihome-vacuum.0	2021-04-14 19:11:39.125	error	(27284) Cannot read property 'channels' of null
        mihome-vacuum.0	2021-04-14 19:11:39.124	error	at processImmediate (internal/timers.js:461:21)
        mihome-vacuum.0	2021-04-14 19:11:39.124	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5559:38)
        mihome-vacuum.0	2021-04-14 19:11:39.124	error	at MihomeVacuum.emit (events.js:314:20)
        mihome-vacuum.0	2021-04-14 19:11:39.124	error	at MihomeVacuum.onStateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:316:10)
        mihome-vacuum.0	2021-04-14 19:11:39.124	error	at VacuumManager.stateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/vacuum.js:749:16)
        mihome-vacuum.0	2021-04-14 19:11:39.124	error	at VacuumManager.startCleaning (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/vacuum.js:1201:37)
        mihome-vacuum.0	2021-04-14 19:11:39.124	error	(27284) TypeError: Cannot read property 'channels' of null
        mihome-vacuum.0	2021-04-14 19:11:39.120	error	(27284) unhandled promise rejection: Cannot read property 'channels' of null
        mihome-vacuum.0	2021-04-14 19:11:39.119	error	(27284) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        gewartet...30 Sekunden, dann erst Pause, dann Home ging. Kann auch Zufall sein...
        Unter MAP hab ich aber nen IMG erhalten 🙂
        NACHTRAG:
        das hatte ich vorher auf jeden Fall nicht O.o
        mihome-vacuum.0	2021-04-14 21:01:35.255	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 21:01:15.214	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 21:00:55.161	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 21:00:35.118	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 21:00:15.077	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:59:55.026	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:59:34.976	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:59:14.934	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:58:54.877	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:58:34.832	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:58:14.792	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:57:54.746	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:57:34.694	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:57:14.647	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:56:54.605	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:56:34.565	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:56:14.515	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:55:54.461	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:55:34.422	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:55:14.372	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:54:54.330	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:54:34.282	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:54:14.234	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:53:54.186	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:53:34.132	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:53:14.088	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:52:54.036	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:52:33.990	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:52:13.947	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:51:53.888	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:51:33.847	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:51:13.803	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:50:53.760	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:50:33.712	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:50:13.668	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:49:53.616	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:49:33.573	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:49:13.523	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:48:53.482	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:48:33.439	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:48:13.392	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:47:53.343	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:47:33.296	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:47:13.241	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:46:53.188	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:46:33.142	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:46:13.087	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:45:20.722	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:45:00.670	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:44:40.551	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:44:20.431	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:44:00.377	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:43:40.326	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:43:20.195	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:43:00.136	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:42:40.074	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:42:19.941	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:41:59.898	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:41:39.843	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:41:19.708	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:40:59.651	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:40:39.603	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:40:19.522	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:39:59.480	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:39:39.433	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:39:19.297	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:38:59.251	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:38:39.213	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:38:19.070	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:37:59.023	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:37:38.984	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:37:18.712	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:36:58.673	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:36:38.634	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:36:18.595	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:35:58.556	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:35:38.508	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:35:18.362	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:34:58.316	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:34:38.259	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:34:18.130	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:33:58.065	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:33:38.025	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:33:17.874	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:32:57.834	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:32:37.790	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:32:17.616	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:31:57.576	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:31:37.528	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:31:17.378	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:30:57.336	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:30:37.294	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:30:17.158	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:29:57.102	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:29:37.060	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:29:16.925	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:28:56.872	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:28:36.827	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:28:16.708	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:27:56.661	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:27:36.611	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:27:16.472	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:26:56.416	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:26:36.363	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:26:16.225	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:25:56.187	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:25:36.145	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:25:16.013	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:24:55.950	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:24:35.905	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:24:15.753	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:23:55.702	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:23:35.655	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:23:15.539	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:22:55.495	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:22:35.448	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:22:15.393	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:21:55.347	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:21:35.303	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:21:15.260	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:20:55.219	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:20:35.176	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:20:15.133	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:19:55.074	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:19:35.033	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:19:14.973	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:18:54.930	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:18:34.870	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:18:14.810	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:17:54.764	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:17:34.695	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:17:14.613	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:16:54.566	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:16:34.528	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:16:14.489	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:15:54.442	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:15:34.400	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:15:14.356	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:14:54.316	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:14:34.271	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:14:14.217	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:13:54.167	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:13:34.115	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:13:14.073	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:12:54.019	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:12:33.979	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:12:13.932	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:11:53.887	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:11:33.845	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:11:13.805	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:10:53.750	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:10:33.702	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:10:13.644	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:09:53.602	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:09:33.559	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:09:13.515	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:08:53.468	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:08:33.428	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:08:13.377	warn	(28226) answer map_slot is currently not supported!
        mihome-vacuum.0	2021-04-14 20:07:53.327	warn	(28226) answer map_slot is currently not supported!
          BlackHawk3000 @Kueppert last edited by BlackHawk3000
          @meistertr Erstmal super Arbeit die du leistest.
          Eine Frage, seit heute bin ich im Besitz eines ROIDMI EVE Plus, der eine Untermarke von Xiaomi ist.
          Man kann diesen Sauger auch ganz normal über die MiHomeApp steuern.
          Daher meine Frage, kannst du diesen auch einbinden?
          Wenn ja was benötigst du, um dir unter die Arme zu greifen. (Achtung Anfänger) ?
          Habe bereits deinen 3.0.4 Adapter installiert. Folgendes spuckt er im Debug aus:
          mihome-vacuum.0	2021-04-14 19:54:03.212	debug	(15781) Receive Timeout<<<
          mihome-vacuum.0	2021-04-14 19:54:03.111	debug	(15781) Receive Timeout<<<
          mihome-vacuum.0	2021-04-14 19:54:03.006	debug	(15781) Receive Timeout<<<
          mihome-vacuum.0	2021-04-14 19:54:02.904	debug	(15781) Receive Timeout<<<
          mihome-vacuum.0	2021-04-14 19:54:02.713	debug	(15781) Receive Timeout<<<
          mihome-vacuum.0	2021-04-14 19:54:01.317	warn	(15781) Model roidmi.vacuum.v60 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
          mihome-vacuum.0	2021-04-14 19:54:01.317	debug	(15781) DeviceModel selected to: roidmi.vacuum.v60
          mihome-vacuum.0	2021-04-14 19:54:01.316	warn	(15781) No Answer for DeviceModel use model from Config
          mihome-vacuum.0	2021-04-14 19:54:01.316	warn	(15781) No Answer for DeviceModel use old one
          mihome-vacuum.0	2021-04-14 19:54:01.316	warn	(15781) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER CONNECTION CAN TAKE UP TO 10 MINUTES PLESASE WAIT AND DON`T TRUN THE ADAPTER OFF
          mihome-vacuum.0	2021-04-14 19:54:01.315	debug	(15781) Get Device data..4
          mihome-vacuum.0	2021-04-14 19:54:01.212	debug	(15781) Message= {"id":5,"method":"miIO.info"}
          mihome-vacuum.0	2021-04-14 19:54:01.211	debug	(15781) Get Device data..3
          mihome-vacuum.0	2021-04-14 19:54:01.109	debug	(15781) Message= {"id":4,"method":"miIO.info"}
          mihome-vacuum.0	2021-04-14 19:54:01.108	debug	(15781) Get Device data..2
          mihome-vacuum.0	2021-04-14 19:54:01.005	debug	(15781) Message= {"id":3,"method":"miIO.info"}
          mihome-vacuum.0	2021-04-14 19:54:01.005	debug	(15781) Get Device data..1
          mihome-vacuum.0	2021-04-14 19:54:00.901	debug	(15781) Message= {"id":2,"method":"miIO.info"}
          mihome-vacuum.0	2021-04-14 19:54:00.901	debug	(15781) Get Device data..0
          mihome-vacuum.0	2021-04-14 19:54:00.710	debug	(15781) Message= {"id":1,"method":"miIO.info"}
          mihome-vacuum.0	2021-04-14 19:54:00.709	debug	(15781) GETMODELFROMAPI: objModel: {"val":"roidmi.vacuum.v60","ack":true,"ts":1618422820472,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1618422820472}
          mihome-vacuum.0	2021-04-14 19:54:00.708	debug	(15781) Time difference between Mihome Vacuum and ioBroker: -1618420957 sec
          mihome-vacuum.0	2021-04-14 19:54:00.706	debug	(15781) MAIN: Connected to device, try to get model..
          mihome-vacuum.0	2021-04-14 19:54:00.705	debug	(15781) Receive <<< Helo <<< 2131002000000000185728150000075bffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-04-14 19:54:00.647	debug	(15781) server started on 0.0.0.0:53421
          Danke im Voraus
          Gruß Blacky
          M A 2 Replies Last reply Reply Quote 0
          • da_Woody
            da_Woody @Meistertr last edited by
            @meistertr Roborock S6 Pure 👍
              mech @BlackHawk3000 last edited by mech
              Habe den Adapter auch mal installiert und beteilige mich gern an dem Test.
              Roborock S6 maxv
              @IOBroker:~# npm -v
              6.14.4
              @IOBroker:~# nodejs -v
              v14.16.0
              Installation / Log (Ohne Auffälligkeiten):
              mihome-vacuum.0	2021-04-14 20:47:55.027	info	(8004) create new room: 644001017629
              mihome-vacuum.0	2021-04-14 20:47:55.027	info	(8004) create new room: 644001017632
              mihome-vacuum.0	2021-04-14 20:47:55.026	info	(8004) create new room: 644001016932
              mihome-vacuum.0	2021-04-14 20:47:55.021	info	(8004) create new room: 644001016935
              mihome-vacuum.0	2021-04-14 20:47:55.020	info	(8004) create new room: 644001016934
              mihome-vacuum.0	2021-04-14 20:47:55.020	info	(8004) create new room: 644001016916
              mihome-vacuum.0	2021-04-14 20:47:55.019	info	(8004) create new room: 644001016933
              mihome-vacuum.0	2021-04-14 20:47:54.951	info	(8004) create state for carpet_mode
              mihome-vacuum.0	2021-04-14 20:47:53.572	info	(8004) create states for water box mode
              mihome-vacuum.0	2021-04-14 20:47:53.566	info	(8004) settest next timer: not available
              mihome-vacuum.0	2021-04-14 20:47:53.548	info	(8004) create states for water box
              mihome-vacuum.0	2021-04-14 20:47:53.525	info	(8004) change states from State control.fan_power
              mihome-vacuum.0	2021-04-14 20:47:53.410	info	(8004) Map not selected delete states...
              mihome-vacuum.0	2021-04-14 20:47:53.027	info	(8004) select standard vacuum protocol....
              mihome-vacuum.0	2021-04-14 20:47:50.885	info	(8004) check group user admin group admin: false
              mihome-vacuum.0	2021-04-14 20:47:50.529	info	(8004) check user admin pw iobroker: false
              mihome-vacuum.0	2021-04-14 20:47:50.053	info	(8004) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.16.0, js-controller: 3.2.16
              host.IOBroker	2021-04-14 20:47:48.376	info	instance system.adapter.mihome-vacuum.0 started with pid 8004
              host.IOBroker	2021-04-14 20:47:45.773	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.IOBroker	2021-04-14 20:47:45.255	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
              mihome-vacuum.0	2021-04-14 20:47:45.211	info	(7989) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              mihome-vacuum.0	2021-04-14 20:47:45.211	info	(7989) terminating
              mihome-vacuum.0	2021-04-14 20:47:45.209	info	(7989) Got terminate signal TERMINATE_YOURSELF
              host.IOBroker	2021-04-14 20:47:45.205	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
              Dann die MAP aktiviert (Adapter bleibt "Gelb", aber das dauert ja):
              mihome-vacuum.0	2021-04-14 20:53:11.786	info	(8037) Map selected create states...
              mihome-vacuum.0	2021-04-14 20:53:10.357	info	(8037) settest next timer: not available
              mihome-vacuum.0	2021-04-14 20:53:09.817	info	(8037) select standard vacuum protocol....
              mihome-vacuum.0	2021-04-14 20:53:09.815	warn	(8037) No Answer for DeviceModel use model from Config
              mihome-vacuum.0	2021-04-14 20:53:09.815	warn	(8037) No Answer for DeviceModel use old one
              mihome-vacuum.0	2021-04-14 20:53:09.814	warn	(8037) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER CONNECTION CAN TAKE UP TO 10 MINUTES PLESASE WAIT AND DON`T TRUN THE ADAPTER OFF
              Update dann noch wenn ich sehe ob der Adapter "Grün" wird und die Map verfügbar ist.
              Alle anderen Datenpunkte sehen gut aus, ich glaube das Wifi Signal zieht er aktuell nicht mehr.
              Vielen Dank für den Adapter 😉
              Update: Adapter "GRÜN" Karte wurde geladen. Wenn die sich nun auch aktualisiert ist alles roger!
              Update1:
              Der Datenpunkt für den Wassertank war vorher true / false und scheint nun vermutlich 0/1 zu sein.
              Meistertr 1 Reply Last reply Reply Quote 0
                Habe einen alten Beitrag von dir gefunden Meister, deshalb habe ich mal etwas gesucht.
                Folgende Urls habe ich schon einmal gefunden:
                # http://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:roidmi-v60:1
                gibt auch noch mit :2
                # http://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:roidmi-v60:2
                Des Weiteren habe ich dann mal die alten Befehle genutzt, die vermutlich hier nicht passen werden.
                Bitte hier um Berichtigung und evtl. um ein/zwei Beispiele, dann setze ich die Befehle anders um:
                "battery": {"siid": 3, "piid": 1},                      [{"code":0,"did":"408365077","piid":1,"siid":3,"value":100}]
                "charge_state": {"siid": 3, "piid": 2},                 [{"code":0,"did":"408365077","piid":2,"siid":3,"value":1}]
                "error": {"siid": 2, "piid": 2},                        [{"code":0,"did":"408365077","piid":2,"siid":2,"value":0}]
                "state": {"siid": 2, "piid": 1},                        [{"code":0,"did":"408365077","piid":1,"siid":2,"value":9}]
                "fan_speed": {"siid": 2, "piid": 6},                    [{"code":-4003,"did":"408365077","piid":6,"siid":2}]
                "operating_mode": {"siid": 2, "piid": 4},               [{"code":0,"did":"408365077","piid":4,"siid":2,"value":2}]
                "mop_state": {"siid": 16, "piid": 1},                   [{"did":"408365077","piid":1,"siid":16}]
                "water_level": {"siid": 2, "piid": 5},                  [{"code":-4003,"did":"408365077","piid":5,"siid":2}]
                "brush_life_level": {"siid": 14, "piid": 1},            [{"code":0,"did":"408365077","piid":1,"siid":14,"value":0}]
                #  "brush_life_time": {"siid": 14, "piid": 2},          [{"code":-4003,"did":"408365077","piid":2,"siid":14}]
                "brush_life_level2": {"siid": 15, "piid": 1},           [{"code":0,"did":"408365077","piid":1,"siid":15,"value":1722}]
                #  "brush_life_time2": {"siid": 15, "piid": 2},         [{"code":0,"did":"408365077","piid":2,"siid":15,"value":95}]
                "filter_life_level": {"siid": 11, "piid": 1},           [{"code":0,"did":"408365077","piid":1,"siid":11,"value":17922}]
                #  "filter_life_time": {"siid": 11, "piid": 2},         [{"code":0,"did":"408365077","piid":2,"siid":11,"value":99}]
                "clean_area": {"siid": 9, "piid": 1},                   [{"code":0,"did":"408365077","piid":1,"siid":9,"value":40}]
                "clean_time": {"siid": 18, "piid": 5},                  [{"did":"408365077","piid":5,"siid":18}]
                "total_clean_count": {"siid": 9, "piid": 5},            [{"code":-4003,"did":"408365077","piid":5,"siid":9}]
                #   "total_clean_area": {"siid": 9, "piid": 3},         [{"code":-4003,"did":"408365077","piid":3,"siid":9}]
                #  "dnd_enabled": {"siid": 12, "piid": 2},              [{"code":0,"did":"408365077","piid":2,"siid":12,"value":99}]
                #  "audio_volume": {"siid": 4, "piid": 2},              [{"did":"408365077","piid":2,"siid":4}]
                #  "direction_key": {"siid": 8, "piid": 1}              [{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]
                Folgende Fehlermeldung kommt wenn ich die Befehle ausgeführt habe:
                host.iobroker	2021-04-14 21:11:04.084	info	instance system.adapter.mihome-vacuum.0 started with pid 1074
                host.iobroker	2021-04-14 21:10:34.061	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                host.iobroker	2021-04-14 21:10:34.061	error	instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                mihome-vacuum.0	2021-04-14 21:10:33.381	warn	(32537) Terminated (UNCAUGHT_EXCEPTION): Without reason
                mihome-vacuum.0	2021-04-14 21:10:33.380	info	(32537) terminating
                mihome-vacuum.0	2021-04-14 21:10:33.368	error	(32537) Cannot read property 'stateChange' of null
                mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) TypeError: Cannot read property 'stateChange' of null at MihomeVacuum.onStateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:316:10) at process._tickCallback (interna
                mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) unhandled promise rejection: Cannot read property 'stateChange' of null
                mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                mihome-vacuum.0	2021-04-14 21:10:33.366	debug	(32537) Get self send data:{"id":6,"result":[{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]}
                mihome-vacuum.0	2021-04-14 21:10:33.366	debug	(32537) MIIO RECIVE: {"id":6,"result":[{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]}
                mihome-vacuum.0	2021-04-14 21:10:33.099	debug	(32537) Message= {"id":6,"method":"get_properties","params":[{"did":"408365077","siid":8,"piid":1}]}
                mihome-vacuum.0	2021-04-14 21:10:33.099	info	(32537) send message: Method: get_properties Params: [{"did":"408365077","siid":8,"piid":1}]
                Blacky
                • Meistertr
                  Meistertr Developer @BlackHawk3000 last edited by
                  @blackhawk3000 kannst du das bitte in ein git issue verpacken damit ich es auf dem schirm habe
                  • Meistertr
                    Meistertr Developer @mech last edited by
                    @mech sollte ture false sein, werde ich anpassen
                      Coffeelover @Meistertr last edited by
                      @meistertr Habe gerade den Adapter installiert iVm einem roborock.vacuum.a15 (Roborock S7).
                      Map und History werden sauber angezeigt.
                      Beim Versuch unter Rooms auf den Button "roomClean" zu klicken, passiert leider nichts. Im Log sieht es folgendermaßen aus. Ein Anwenderfehler ist nicht ganz auszuschließen - ich habe mit den Rooms bisher nicht gearbeitet.
                      mihome-vacuum.3	2021-04-14 23:55:15.760	warn	(29422) Get Mappinter done redomap...
                      mihome-vacuum.3	2021-04-14 23:55:15.484	warn	(29422) Get Mappinter while cleaning
                      mihome-vacuum.3	2021-04-14 23:55:07.136	warn	(29422) Get Mappinter done redomap...
                      mihome-vacuum.3	2021-04-14 23:55:06.916	warn	(29422) Get Mappinter while cleaning
                      mihome-vacuum.3	2021-04-14 23:54:59.922	warn	(29422) Get Mappinter done redomap...
                      mihome-vacuum.3	2021-04-14 23:54:59.776	warn	(29422) Get Mappinter while cleaning
                      mihome-vacuum.3	2021-04-14 23:54:52.912	warn	(29422) Get Mappinter done redomap...
                      mihome-vacuum.3	2021-04-14 23:54:52.575	warn	(29422) Get Mappinter while cleaning
                      mihome-vacuum.3	2021-04-14 23:54:48.489	warn	(29422) Get Mappinter done redomap...
                      mihome-vacuum.3	2021-04-14 23:54:48.095	warn	(29422) Get Mappinter while cleaning
                      mihome-vacuum.3	2021-04-14 23:54:30.872	warn	(29422) Get Mappinter done redomap...
                      mihome-vacuum.3	2021-04-14 23:54:28.865	warn	(29422) Get Mappinter while cleaning
                      mihome-vacuum.3	2021-04-14 23:54:22.408	warn	(29422) Get Mappinter done redomap...
                      mihome-vacuum.3	2021-04-14 23:54:22.196	warn	(29422) Get Mappinter while cleaning
                      mihome-vacuum.3	2021-04-14 23:53:45.615	warn	(29422) State "mihome-vacuum.3.info.queue" has no existing object, this might lead to an error in future versions
                      • Meistertr
                        Meistertr Developer @Coffeelover last edited by
                        @coffeelover sagte in Test Adapter Mihome-vacuum v3.0.5 Next Generarition:
                        queue
                        sollte in der 3.0.6 gehen
                        M 1 Reply Last reply Reply Quote 2
                          mech @Meistertr last edited by
                          @meistertr said in Test Adapter Mihome-vacuum v3.0.6 Next Generarition:
                          queue
                          306 läuft und der Fehler mit dem Mappinter ist auch weg. Danke dafür 🙂
                            Ich hab die V3.0.7 und 3.0.6 ausprobiert. Bei beiden erhalte ich KEINE Fehlermeldung answer map_slot is currently not supported mehr
                            Dafür erhalte ich aber auch keine MAP mehr 😞 In Valetudo ist sie jedoch vorhanden:
                            EInstellung Adapter Map-Settings:
                            Version 3.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum,
                            node: v12.21.0,
                            rockrobo.vacuum.v1
                            • Meistertr
                              Meistertr Developer @Kueppert last edited by
                              @kueppert zeig mal einen ausgibiegen debug log
                                @meistertr anbei das komplette LOG (Token hab ich ge-X-t):
                                iobroker.2021-04-15.log
                                Meistertr 2 Replies Last reply Reply Quote 0
                                • Meistertr
                                  @kueppert du bruacst den token nicht xxen der ist nur lokal gültig
                                  • Meistertr
                                    @kueppert sollte in der 3.0.8 wieder gehen
                                      Kueppert @Meistertr last edited by Kueppert
                                      @meistertr YEEES Meister, Fehlermeldung weg und unter Cleanmap wieder die Map da. Perfekt. Vielen Dank 👍 👍 👍
                                      NACHTRAG: Auch die CPU-Auslastung, mit der ich bei der alten Adapter-Version unheimlich Probleme hatte (bis hin zum Absturz vom NUC) sind nun weg. Hatte den Adapter daher lang nicht verwendet.
                                      • Meistertr
                                        @kueppert der Performance Gewinn war zu erwarten da der Code extrem optimiert wurde.
                                        • Meistertr
                                          Dann wird Zeit von Alpha in beta zu gehen
                                          da_Woody 1 Reply Last reply Reply Quote 1
                                          • da_Woody
                                            @meistertr RoborockS6 macht keine probleme.
                                            allerdings hat er schon vor längerer zeit den goto verloren. hab da mal was eingetragen, passt allerding natürlich mit. in der App kann ich ja das target anklicken, aber ich finde die positon nirgends als xval, yval. wie kann man das rausfinden?
                                            1198
                                            359558
