    4. [Docu] Wie installieren ich ioBroker auf einem Proxmox LXC ?
    • Kusselin
      Kusselin @Kusselin last edited by
      @kusselin hallo Zusammen,
      habe meinen NUC nun getauscht zum I5..proxmox root neu installiert....wg. neuem rechner ev. treiber usw.....dann genau nochmal die Anleitung durchgegangen....und es war ja klar das der Zigbee Stick auf gelb bleibt und nicht grün wird 😞 hier mal das log von iobroker:
      zigbee.0	2021-04-14 22:21:41.952	error	(1183) Error: Error while opening serialport 'Error: Error: Not a directory, cannot open /dev/ttyZigbee/' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/zn
      zigbee.0	2021-04-14 22:21:41.952	error	(1183) Failed to start Zigbee
      zigbee.0	2021-04-14 22:21:41.824	info	(1183) Installed Version: iobroker.zigbee@1.4.4
      zigbee.0	2021-04-14 22:21:41.816	info	(1183) Starting Zigbee npm ...
      zigbee.0	2021-04-14 22:21:41.816	info	(1183) Try to reconnect. 1 attempts left
      zigbee.0	2021-04-14 20:21:31.815	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0	2021-04-14 20:21:31.815	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0	2021-04-14 20:21:31.815	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      zigbee.0	2021-04-14 20:21:31.815	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      zigbee.0	2021-04-14 20:21:31.815	error	at new Promise (<anonymous>)
      zigbee.0	2021-04-14 20:21:31.815	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      zigbee.0	2021-04-14 20:21:31.815	error	at Generator.next (<anonymous>)
      zigbee.0	2021-04-14 20:21:31.815	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      zigbee.0	2021-04-14 20:21:31.815	error	(1183) Error: Error while opening serialport 'Error: Error: Not a directory, cannot open /dev/ttyZigbee/'
      zigbee.0	2021-04-14 20:21:31.815	error	(1183) Failed to start Zigbee
      Hier die Ausgabe von
      hier von /ls
      crw-rw----  1 root dialout   4,  72 Apr 14 22:10 ttyS8
      crw-rw----  1 root dialout   4,  73 Apr 14 22:10 ttyS9
      lrwxrwxrwx  1 root root           7 Apr 14 22:10 ttyZigbee -> ttyACM0
      crw-------  1 root root     10,  60 Apr 14 22:10 udmabuf
      und hier die die ausgabe meiner config:
      arch: amd64
      cores: 2
      hostname: iobroker-live
      memory: 6016
      net0: name=eth0,bridge=vmbr0,gw=192.168.200.1,hwaddr=9A:A7:50:06:EF:AC,ip=192.1$
      ostype: ubuntu
      rootfs: local-lvm:vm-200-disk-0,size=8G
      swap: 1000
      lxc.cgroup.devices.allow: c 7:* rwm
      lxc.mount.entry: /dev/ttyZigbee dev/ttyZigbee none bind,optional,create=file
      und der 49er rules:
      KERNEL=="ttyACM[0-9]*", SUBSYSTEM=="tty", ATTRS{idVendor}=="0451", ATTRS{idProd$
      SUBSYSTEMS=="usb", ATTRS{idVendor}=="0451", ATTRS{idProduct}=="16a8", GROUP="us$
      Ich muss dazusagen das ich beim Restore der LXC Containers den Haken bei unpriviligiert herausgenommen habe....kann das mit dem zusammenhängen?
      Gruss udn Danke
      crunchip Dutchman 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @Kusselin last edited by
        @kusselin sagte in [Docu] Wie installieren ich ioBroker auf einem Proxmox LXC ?:
        warum hast du ?
        Kusselin 1 Reply Last reply Reply Quote 0
        • Kusselin
          Kusselin @crunchip last edited by Kusselin
          @crunchip wurde mir von einem bekannten gesagt...durch das privilligierte wäre es besser....fürs system.....anscheinend war das aber nicht so gut??? Hätte ich nicht sollen?
          Hängt das mit dem Mounten zusammen das der ZigbeeStick nicht grün wird??
          Kusselin Dutchman 2 Replies Last reply Reply Quote 0
          • Kusselin
            @kusselin Hi Zusammen, ich muss heute abend nochmal in Ruhe dran gehen...das hat nicht funktioniert.
            Ich hatte als erstes ein Backup gemacht mit Acronis also ein Komplettbackup dann wollte ich mit Acronis USB Stick das Backup wieder auf dem neuen I5 einspielen - Acronis fand aber nicht die M2 Platte 😞 Warum weiss ich auch nicht!
            Dann habe ich Proxmox neu installiert also das eigentliche Root Proxmox...habe dann den ersten Container wiederhergestellt (iobroker) und den zweiten (fhem)....dann das Problem mit dem ZigbeeStick und durchreichen und beim zweiten Container fhem war auf einmal nicht mehr erreichbar....:-(
            Ne Frage: Wenn ich ne Platte egal ob SATA SSD oder m2 im NUC eingebaut habe udn dann proxmox installiere - formatiert dann proxmox automatisch die Platte..oder muss ich die dann ev. mit gparted in windows immer neu formatieren in ext3?
            Gruss und Danke
            crunchip 2 Replies Last reply Reply Quote 0
              Auf der du Proxmox installierst, ja
              Wenn du ne zweite, Platte hast, wieder einhangen,falls gewünscht oder neu formatieren und dann in Proxmox hinzufügen.
                Statische ip?
                • Dutchman
                  Dutchman Developer Most Active Administrators @Kusselin last edited by
                  Ja slechte idee den damit ist der lxc Root auf deinem host
                  • Dutchman
                    Die Einträge stehen an der falsche Stelle 😉
                    • Kusselin
                      @crunchip sagte in [Docu] Wie installieren ich ioBroker auf einem Proxmox LXC ?:
                      o.k. danke verstanden...heisst ich kann einfach proxmox mit der eingabuten Platte drin lassen udn proxmox wieder frisch installieren....dann ist die platte wieder jungfräulich mit dem neuen Proxmox---richtig?
                      • Kusselin
                        Statische ip?
                        HI, ja ich habe vor den Backups allen Containern sowie proxmox root eine statische IP vergeben.
                        Beim neuinstallieren vom Proxmox wird man ja angezeigt welche IP..da habe ich dann die feste eigentliche ip von prox eingegeben
                        • Kusselin
                          Kusselin @Dutchman last edited by Kusselin
                          @dutchman sagte in [Docu] Wie installieren ich ioBroker auf einem Proxmox LXC ?:
                          Ja, das kommt davon wenn man was macht und nicht weiss was man macht 😞
                          Wenn ich das proxmox frisch auf dem neuen I5 installiert habe und dann meine gesicherten container zurückspielen will, ist bei allen immer schon ein haken bei "unpriviligierter Container" hinterlegt... aber so grau..man kann aber den haken wegmachen....ist das richtig?
                          Dutchman crunchip 2 Replies Last reply Reply Quote 0
                          • Kusselin
                            was sagt mir das? Wo müssten die stehen?
                            • Dutchman
                              Poste mal bitte die komplette config
                              Kusselin 2 Replies Last reply Reply Quote 0
                              • Dutchman
                                aber so garu..man kann aber den haken wegmachen....ist das richtig?
                                Hmm glaube nein nach meiner Erfahrung startet er Dan nicht Probier mal 😉
                                Alternative, Backup einspielen als privilegiert, machine Clone und den Clone unpreviligiert das sollte klappen
                                • Kusselin
                                  Das was ich da gepostet habe ist die komplette config von iobroker
                                  • Kusselin
                                    Ohjee was verlangst du von mir 😞
                                    Alsoo, wenn ich das Backup einspiele dann klicke ich dieses ja an und dann sieht man ja die eigenschaften..der container steht autom. auf 100 den ändere ich in die entsprechende nummer ab unddann ist immer der haken bei unpriviligiert drin..unddiesen gabe ich rausgemacht..und das ist falsch..richtig? Einfach so lassen und einspielen ok?
                                    Dann kommt kurz „no content“ und dann startet das restore und endet mit ok.. das passt ja
                                    • Kusselin
                                      @kusselin
                                      wenn ichs heute abend nochmal probiere (habe ja auf dem I3 ein voll funktionsfähiges proxmox mit Containern), soll ich dann beim Restore nur die Containernummer ändern udn alles andere so belassen (auch nix mit haken und so wg. priviligiert usw...?
                                      • Kusselin
                                        müsste denn da mehr drinn stehen?
                                        • Kusselin
                                          @kusselin die m2 platte hat jaeigentlich 250GB..in proxmox werden dann aber ca. 237GB angezeigt..istdas richtig? Braucht proxmox soviel speicher?
                                            Kueppert @Kusselin last edited by
                                            @kusselin es wird NIE der gesamte Plattenplatz angezeigt. Zumindest wäre mir das neu 😉
                                            install installation lxc lxc-container proxmox virtualisation
                                            25
                                            232
                                            54946
