    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • da_Woody
      da_Woody @Meistertr last edited by
      @meistertr Roborock S6 Pure 👍
        mech @BlackHawk3000 last edited by mech
        Habe den Adapter auch mal installiert und beteilige mich gern an dem Test.
        Roborock S6 maxv
        @IOBroker:~# npm -v
        6.14.4
        @IOBroker:~# nodejs -v
        v14.16.0
        Installation / Log (Ohne Auffälligkeiten):
        mihome-vacuum.0	2021-04-14 20:47:55.027	info	(8004) create new room: 644001017629
        mihome-vacuum.0	2021-04-14 20:47:55.027	info	(8004) create new room: 644001017632
        mihome-vacuum.0	2021-04-14 20:47:55.026	info	(8004) create new room: 644001016932
        mihome-vacuum.0	2021-04-14 20:47:55.021	info	(8004) create new room: 644001016935
        mihome-vacuum.0	2021-04-14 20:47:55.020	info	(8004) create new room: 644001016934
        mihome-vacuum.0	2021-04-14 20:47:55.020	info	(8004) create new room: 644001016916
        mihome-vacuum.0	2021-04-14 20:47:55.019	info	(8004) create new room: 644001016933
        mihome-vacuum.0	2021-04-14 20:47:54.951	info	(8004) create state for carpet_mode
        mihome-vacuum.0	2021-04-14 20:47:53.572	info	(8004) create states for water box mode
        mihome-vacuum.0	2021-04-14 20:47:53.566	info	(8004) settest next timer: not available
        mihome-vacuum.0	2021-04-14 20:47:53.548	info	(8004) create states for water box
        mihome-vacuum.0	2021-04-14 20:47:53.525	info	(8004) change states from State control.fan_power
        mihome-vacuum.0	2021-04-14 20:47:53.410	info	(8004) Map not selected delete states...
        mihome-vacuum.0	2021-04-14 20:47:53.027	info	(8004) select standard vacuum protocol....
        mihome-vacuum.0	2021-04-14 20:47:50.885	info	(8004) check group user admin group admin: false
        mihome-vacuum.0	2021-04-14 20:47:50.529	info	(8004) check user admin pw iobroker: false
        mihome-vacuum.0	2021-04-14 20:47:50.053	info	(8004) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.16.0, js-controller: 3.2.16
        host.IOBroker	2021-04-14 20:47:48.376	info	instance system.adapter.mihome-vacuum.0 started with pid 8004
        host.IOBroker	2021-04-14 20:47:45.773	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.IOBroker	2021-04-14 20:47:45.255	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
        mihome-vacuum.0	2021-04-14 20:47:45.211	info	(7989) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mihome-vacuum.0	2021-04-14 20:47:45.211	info	(7989) terminating
        mihome-vacuum.0	2021-04-14 20:47:45.209	info	(7989) Got terminate signal TERMINATE_YOURSELF
        host.IOBroker	2021-04-14 20:47:45.205	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
        Dann die MAP aktiviert (Adapter bleibt "Gelb", aber das dauert ja):
        mihome-vacuum.0	2021-04-14 20:53:11.786	info	(8037) Map selected create states...
        mihome-vacuum.0	2021-04-14 20:53:10.357	info	(8037) settest next timer: not available
        mihome-vacuum.0	2021-04-14 20:53:09.817	info	(8037) select standard vacuum protocol....
        mihome-vacuum.0	2021-04-14 20:53:09.815	warn	(8037) No Answer for DeviceModel use model from Config
        mihome-vacuum.0	2021-04-14 20:53:09.815	warn	(8037) No Answer for DeviceModel use old one
        mihome-vacuum.0	2021-04-14 20:53:09.814	warn	(8037) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER CONNECTION CAN TAKE UP TO 10 MINUTES PLESASE WAIT AND DON`T TRUN THE ADAPTER OFF
        Update dann noch wenn ich sehe ob der Adapter "Grün" wird und die Map verfügbar ist.
        Alle anderen Datenpunkte sehen gut aus, ich glaube das Wifi Signal zieht er aktuell nicht mehr.
        Vielen Dank für den Adapter 😉
        Update: Adapter "GRÜN" Karte wurde geladen. Wenn die sich nun auch aktualisiert ist alles roger!
        Update1:
        Der Datenpunkt für den Wassertank war vorher true / false und scheint nun vermutlich 0/1 zu sein.
        Meistertr 1 Reply Last reply Reply Quote 0
          Habe einen alten Beitrag von dir gefunden Meister, deshalb habe ich mal etwas gesucht.
          Folgende Urls habe ich schon einmal gefunden:
          # http://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:roidmi-v60:1
          gibt auch noch mit :2
          # http://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:roidmi-v60:2
          Des Weiteren habe ich dann mal die alten Befehle genutzt, die vermutlich hier nicht passen werden.
          Bitte hier um Berichtigung und evtl. um ein/zwei Beispiele, dann setze ich die Befehle anders um:
          "battery": {"siid": 3, "piid": 1},                      [{"code":0,"did":"408365077","piid":1,"siid":3,"value":100}]
          "charge_state": {"siid": 3, "piid": 2},                 [{"code":0,"did":"408365077","piid":2,"siid":3,"value":1}]
          "error": {"siid": 2, "piid": 2},                        [{"code":0,"did":"408365077","piid":2,"siid":2,"value":0}]
          "state": {"siid": 2, "piid": 1},                        [{"code":0,"did":"408365077","piid":1,"siid":2,"value":9}]
          "fan_speed": {"siid": 2, "piid": 6},                    [{"code":-4003,"did":"408365077","piid":6,"siid":2}]
          "operating_mode": {"siid": 2, "piid": 4},               [{"code":0,"did":"408365077","piid":4,"siid":2,"value":2}]
          "mop_state": {"siid": 16, "piid": 1},                   [{"did":"408365077","piid":1,"siid":16}]
          "water_level": {"siid": 2, "piid": 5},                  [{"code":-4003,"did":"408365077","piid":5,"siid":2}]
          "brush_life_level": {"siid": 14, "piid": 1},            [{"code":0,"did":"408365077","piid":1,"siid":14,"value":0}]
          #  "brush_life_time": {"siid": 14, "piid": 2},          [{"code":-4003,"did":"408365077","piid":2,"siid":14}]
          "brush_life_level2": {"siid": 15, "piid": 1},           [{"code":0,"did":"408365077","piid":1,"siid":15,"value":1722}]
          #  "brush_life_time2": {"siid": 15, "piid": 2},         [{"code":0,"did":"408365077","piid":2,"siid":15,"value":95}]
          "filter_life_level": {"siid": 11, "piid": 1},           [{"code":0,"did":"408365077","piid":1,"siid":11,"value":17922}]
          #  "filter_life_time": {"siid": 11, "piid": 2},         [{"code":0,"did":"408365077","piid":2,"siid":11,"value":99}]
          "clean_area": {"siid": 9, "piid": 1},                   [{"code":0,"did":"408365077","piid":1,"siid":9,"value":40}]
          "clean_time": {"siid": 18, "piid": 5},                  [{"did":"408365077","piid":5,"siid":18}]
          "total_clean_count": {"siid": 9, "piid": 5},            [{"code":-4003,"did":"408365077","piid":5,"siid":9}]
          #   "total_clean_area": {"siid": 9, "piid": 3},         [{"code":-4003,"did":"408365077","piid":3,"siid":9}]
          #  "dnd_enabled": {"siid": 12, "piid": 2},              [{"code":0,"did":"408365077","piid":2,"siid":12,"value":99}]
          #  "audio_volume": {"siid": 4, "piid": 2},              [{"did":"408365077","piid":2,"siid":4}]
          #  "direction_key": {"siid": 8, "piid": 1}              [{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]
          Folgende Fehlermeldung kommt wenn ich die Befehle ausgeführt habe:
          host.iobroker	2021-04-14 21:11:04.084	info	instance system.adapter.mihome-vacuum.0 started with pid 1074
          host.iobroker	2021-04-14 21:10:34.061	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
          host.iobroker	2021-04-14 21:10:34.061	error	instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          mihome-vacuum.0	2021-04-14 21:10:33.381	warn	(32537) Terminated (UNCAUGHT_EXCEPTION): Without reason
          mihome-vacuum.0	2021-04-14 21:10:33.380	info	(32537) terminating
          mihome-vacuum.0	2021-04-14 21:10:33.368	error	(32537) Cannot read property 'stateChange' of null
          mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) TypeError: Cannot read property 'stateChange' of null at MihomeVacuum.onStateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:316:10) at process._tickCallback (interna
          mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) unhandled promise rejection: Cannot read property 'stateChange' of null
          mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          mihome-vacuum.0	2021-04-14 21:10:33.366	debug	(32537) Get self send data:{"id":6,"result":[{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]}
          mihome-vacuum.0	2021-04-14 21:10:33.366	debug	(32537) MIIO RECIVE: {"id":6,"result":[{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]}
          mihome-vacuum.0	2021-04-14 21:10:33.099	debug	(32537) Message= {"id":6,"method":"get_properties","params":[{"did":"408365077","siid":8,"piid":1}]}
          mihome-vacuum.0	2021-04-14 21:10:33.099	info	(32537) send message: Method: get_properties Params: [{"did":"408365077","siid":8,"piid":1}]
          Blacky
          • Meistertr
            Meistertr Developer @BlackHawk3000 last edited by
            @blackhawk3000 kannst du das bitte in ein git issue verpacken damit ich es auf dem schirm habe
            • Meistertr
              Meistertr Developer @mech last edited by
              @mech sollte ture false sein, werde ich anpassen
                Coffeelover @Meistertr last edited by
                @meistertr Habe gerade den Adapter installiert iVm einem roborock.vacuum.a15 (Roborock S7).
                Map und History werden sauber angezeigt.
                Beim Versuch unter Rooms auf den Button "roomClean" zu klicken, passiert leider nichts. Im Log sieht es folgendermaßen aus. Ein Anwenderfehler ist nicht ganz auszuschließen - ich habe mit den Rooms bisher nicht gearbeitet.
                mihome-vacuum.3	2021-04-14 23:55:15.760	warn	(29422) Get Mappinter done redomap...
                mihome-vacuum.3	2021-04-14 23:55:15.484	warn	(29422) Get Mappinter while cleaning
                mihome-vacuum.3	2021-04-14 23:55:07.136	warn	(29422) Get Mappinter done redomap...
                mihome-vacuum.3	2021-04-14 23:55:06.916	warn	(29422) Get Mappinter while cleaning
                mihome-vacuum.3	2021-04-14 23:54:59.922	warn	(29422) Get Mappinter done redomap...
                mihome-vacuum.3	2021-04-14 23:54:59.776	warn	(29422) Get Mappinter while cleaning
                mihome-vacuum.3	2021-04-14 23:54:52.912	warn	(29422) Get Mappinter done redomap...
                mihome-vacuum.3	2021-04-14 23:54:52.575	warn	(29422) Get Mappinter while cleaning
                mihome-vacuum.3	2021-04-14 23:54:48.489	warn	(29422) Get Mappinter done redomap...
                mihome-vacuum.3	2021-04-14 23:54:48.095	warn	(29422) Get Mappinter while cleaning
                mihome-vacuum.3	2021-04-14 23:54:30.872	warn	(29422) Get Mappinter done redomap...
                mihome-vacuum.3	2021-04-14 23:54:28.865	warn	(29422) Get Mappinter while cleaning
                mihome-vacuum.3	2021-04-14 23:54:22.408	warn	(29422) Get Mappinter done redomap...
                mihome-vacuum.3	2021-04-14 23:54:22.196	warn	(29422) Get Mappinter while cleaning
                mihome-vacuum.3	2021-04-14 23:53:45.615	warn	(29422) State "mihome-vacuum.3.info.queue" has no existing object, this might lead to an error in future versions
                • Meistertr
                  Meistertr Developer @Coffeelover last edited by
                  @coffeelover sagte in Test Adapter Mihome-vacuum v3.0.5 Next Generarition:
                  queue
                  sollte in der 3.0.6 gehen
                  M 1 Reply Last reply Reply Quote 2
                    mech @Meistertr last edited by
                    @meistertr said in Test Adapter Mihome-vacuum v3.0.6 Next Generarition:
                    queue
                    306 läuft und der Fehler mit dem Mappinter ist auch weg. Danke dafür 🙂
                      Kueppert last edited by
                      Ich hab die V3.0.7 und 3.0.6 ausprobiert. Bei beiden erhalte ich KEINE Fehlermeldung answer map_slot is currently not supported mehr
                      Dafür erhalte ich aber auch keine MAP mehr 😞 In Valetudo ist sie jedoch vorhanden:
                      EInstellung Adapter Map-Settings:
                      Version 3.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum,
                      node: v12.21.0,
                      rockrobo.vacuum.v1
                      • Meistertr
                        Meistertr Developer @Kueppert last edited by
                        @kueppert zeig mal einen ausgibiegen debug log
                          Kueppert @Meistertr last edited by
                          @meistertr anbei das komplette LOG (Token hab ich ge-X-t):
                          iobroker.2021-04-15.log
                          Meistertr 2 Replies Last reply Reply Quote 0
                          • Meistertr
                            @kueppert du bruacst den token nicht xxen der ist nur lokal gültig
                            • Meistertr
                              @kueppert sollte in der 3.0.8 wieder gehen
                                Kueppert @Meistertr last edited by Kueppert
                                @meistertr YEEES Meister, Fehlermeldung weg und unter Cleanmap wieder die Map da. Perfekt. Vielen Dank 👍 👍 👍
                                NACHTRAG: Auch die CPU-Auslastung, mit der ich bei der alten Adapter-Version unheimlich Probleme hatte (bis hin zum Absturz vom NUC) sind nun weg. Hatte den Adapter daher lang nicht verwendet.
                                • Meistertr
                                  @kueppert der Performance Gewinn war zu erwarten da der Code extrem optimiert wurde.
                                  • Meistertr
                                    Dann wird Zeit von Alpha in beta zu gehen
                                    da_Woody 1 Reply Last reply Reply Quote 1
                                    • da_Woody
                                      @meistertr RoborockS6 macht keine probleme.
                                      allerdings hat er schon vor längerer zeit den goto verloren. hab da mal was eingetragen, passt allerding natürlich mit. in der App kann ich ja das target anklicken, aber ich finde die positon nirgends als xval, yval. wie kann man das rausfinden?
                                        A Former User @da_Woody last edited by
                                        @da_woody die Positionen hab ich bei meinen S5 mit der FloleApp herausgefunden.. vielleicht geht die auch mit dem S6..?
                                        C da_Woody 2 Replies Last reply Reply Quote 0
                                          Coffeelover @Guest last edited by
                                          @ilovegym mit dem S7 leider nicht mehr. Falls das mit dem Adapter sichbar wäre, wäre das äußerst cool.
                                          • Meistertr
                                            Meistertr Developer @Coffeelover last edited by Meistertr
                                            @coffeelover kommt wenn die bugs weg sind... zumindestens für zone auf jeden fall, aber damit könnte man auch einen Point bestimmen
                                            1198
                                            359737
