    4. Test Adapter Gartenbewässerung v0.0.x
      sigi234 Forum Testing Most Active @Tschaeens last edited by
      @tschaeens sagte in Test Adapter Gartenbewässerung v0.0.x:
      @sigi234
      Log Parser? logst du dann den Adapter Gartenbewässerung ?
      Ja
        Tschaeens @sigi234 last edited by
        @sigi234
        Kannst du mir kurz helfen, was ich im Logparser für Einstellungen machen muss? Danke
          sigi234 Forum Testing Most Active @Tschaeens last edited by sigi234
          @tschaeens
          In 30 Minuten
            @sigi234
            super danke dir. Muss ich gleich mal ausprobieren!
            • Holger Etzel
              Holger Etzel last edited by
              bekomme nach start der Instanz folgende Meldung:
              Was haben diese zu bedeuten?
              host.raspberrypi	2021-04-04 15:18:58.701	error	instance system.adapter.gartenbewaesserung.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	(760050) DB closed
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at TCP.<anonymous> (net.js:675:12)
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Socket.EventEmitter.emit (domain.js:483:12)
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Socket.emit (events.js:314:20)
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Object.onceWrapper (events.js:421:26)
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20)
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25)
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	(760050) Error: DB closed
              gartenbewaesserung.0	2021-04-04 15:18:58.192	error	(760050) unhandled promise rejection: DB closed
              gartenbewaesserung.0	2021-04-04 15:18:58.191	error	(760050) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	(760050) DB closed
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at TCP.<anonymous> (net.js:675:12)
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Socket.EventEmitter.emit (domain.js:483:12)
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Socket.emit (events.js:314:20)
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Object.onceWrapper (events.js:421:26)
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20)
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25)
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	(760050) Error: DB closed
              gartenbewaesserung.0	2021-04-04 15:18:58.180	error	(760050) unhandled promise rejection: DB closed
              gartenbewaesserung.0	2021-04-04 15:18:58.174	error	(760050) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                Snapergy @tombox last edited by
                @tombox
                hallo tombox, gibt es schon einen neuen stand?
                  tombox @Snapergy last edited by
                  @snapergy Es gibt mittlerweile ein besseren Adaper für Bewässerung.
                  Es fehlen hier zwar noch Gardena und KNX states die angesteuert werden können
                  Deswegen macht eine Entwicklung an dem Adapter kein Sinn mehr
                  https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
                  Leider gibt es noch kein Forum eintrag zu dem Adaper aber er ist auch schon im latest.
                  Bei Anfragen müsst ihr euch bei Dirk Peter direkt per Mail melden.
                    bob der 1. @tombox last edited by
                    @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
                    Was ist an dem besser?
                    Ok,sehe den Durchfluß eingepflegt was aber sehr wage ist.
                    Paar Sachen die der noch hat...aber besser? sehe eher das Wort umfangreicher...
                      sigi234 Forum Testing Most Active @bob der 1. last edited by sigi234
                      @bob-der-1
                      Jupp, die Beschreibung ist aber gut gemacht.
                      B X 2 Replies Last reply Reply Quote 0
                        bob der 1. @sigi234 last edited by
                        @sigi234
                        Sehr gut sogar.
                        Ist ein Klasse Adapter nur leider die Bennenung der einzelnen Daten-Punkte nict für jeden trivial.
                        • X
                          xbow42 @sigi234 last edited by xbow42
                          @sigi234 "spezifische Konfiguration des jeweiligen Rollladens" scheint einiges vom shuttercontrol-Adapter übernommen zu sein, oder kann man damit auch seinen Rasen abdunkeln 😉
                            A Former User last edited by
                            @xbow42 hehe, wenn du ihn lange genug bewässerst, dann wird der Rasen auch dunkel... wie n Moor.. 😉
                            • JB_Sullivan
                              JB_Sullivan @Guest last edited by
                              Leider liest sich die Aussage von @tombox so, als wenn der jetzige Adapter in diesem Status bleiben wird.
                              Heißt also im Umkehrschluss, sich vom Adapter Gartenbewässerung verabschieden, oder den Status Quo akzeptieren. Auch wenn ich sehr mit dem Adapter von TomBox zufrieden war/bin, werde ich den "neuen" Adapter auch mal ausprobieren und im Sommer einem Praxis Test unterziehen.
                              Aber im Grunde bedarf es ja nicht unbedingt immer und immer wieder etwas neuem. TomBox sein Adapter hat im letzten Jahr für MICH gut funktioniert. Also dafür nochmal herzlichen Dank.
                              Aber wie gesagt - ich werde trotzdem mal einen Blick über den Tellerrand werfen, auch wenn es nur dazu da ist um zu alt bekanntem zurück zu kehren 😉
                              T sigi234 2 Replies Last reply Reply Quote 0
                                tombox @JB_Sullivan last edited by
                                @jb_sullivan also ich werde meinen nicht weiter entwickeln dazu ist der andere zu gut außer. Ich werde aber den anderen verbessern falls es wünsche gibt
                                M S 2 Replies Last reply Reply Quote 0
                                  MartyBr @tombox last edited by
                                  @tombox Hallo tombox, ich habe mir den anderen Adapter auch angeschaut. Er hat für mich zwei Nachteile gegenüber deinem:
                                  1. Pumpe und Verbrauch: Brauche ich nicht, das hängt bei mir an dem Gartenwasserhahn. Das sollte zukünftig konfigurierbar, also abschaltbar sein.
                                  2. Gravierend ist das Fehlen eines Bodenfeuchtesensors. Das ist ein RIESEN Vorteil deines Adapters.
                                  Ich habe für mich beschlossen, dass ich deinen Adapter weiter benutze.
                                  Herzlichen Dank an dieser Stelle für den Adapter und den Support!!!
                                  Gruß und Dank
                                  Martin
                                    sigi234 Forum Testing Most Active @JB_Sullivan last edited by sigi234
                                    @jb_sullivan
                                    @tombox
                                    @Dirk-Peter-md
                                    @Kuddel
                                    Wunsch:
                                    Ich würde beide kombinieren und einen Community Adapter machen. Auch Kuddel mit ins Boot nehmen.
                                      tombox @MartyBr last edited by
                                      @martybr so wie ich Dirk verstanden habe ist feuchte Sensor das nächste was er einbaut er würde das gleich mit Temperatur Sensoren verbinden sich
                                        tombox @sigi234 last edited by
                                        @sigi234 j habe ich auch schon geäußert aber will erstmal ein Grundlage entwickelt aber du kannst ihm ja ne Mail schreiben
                                          @tombox Ich werde das verfolgen, danke für die Info.
                                          Martin
                                            sigi234 Forum Testing Most Active @tombox last edited by
                                            Jupp, schade das er nicht im Forum ist?
                                            beregnungssteuerung bewässerung garten gartenbewässerung magnetventil ventil ventile
                                            66
                                            567
                                            111626
