    4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
      TheAriba last edited by
      Hallo zusammen!
      Wie ich tatsächlich ein homebridge plugin in ioBroker zum Laufen bekomme würde mir an der Stelle auch helfen. Irgendwie verstehe ich da nur Bahnhof 🙂 .
      Fehlt hier noch etwas an den Einstellungen? Es knallt im Log ein wenig.
      f6789800-8d22-42df-a0b8-78640dd60144-image.png fd5a655d-ec1e-4207-b2cb-2ced501fb391-image.png
      host.raspberrypi	2021-01-13 23:38:00.586	info	Restart adapter system.adapter.ham.0 because enabled
      host.raspberrypi	2021-01-13 23:38:00.585	info	instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[3]: [1/13/2021, 22:38:00] Error loading platform requested in your config.json at position 1
      host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: [1/13/2021, 22:38:00] ====================
      host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at Server.start (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:71:28)
      host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at PluginManager.initializeInstalledPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js:61:22)
      host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at Map.forEach (<anonymous>)
      host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js:63:24
      host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Plugin.load (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js:124:31)
      host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Function.Module._load (/opt/iobroker/node_modules/mock-require/index.js:30:22)
      host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
      host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/main.js
      host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js
      host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js
      host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js
      host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/api.js
      host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js
      host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js
      host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: Require stack:
      host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: [1/13/2021, 22:38:00] Error: Cannot find module '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-doorbird/dist/index.js'
      host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: [1/13/2021, 22:38:00] ERROR LOADING PLUGIN homebridge-doorbird:
      host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[1]: [1/13/2021, 22:38:00] ====================
      host.raspberrypi	2021-01-13 23:38:00.581	error	Caught by controller[0]: [1/13/2021, 22:38:00] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
      ham.0	2021-01-13 23:38:00.059	info	(4089) Terminated (NO_ERROR): Without reason
      ham.0	2021-01-13 23:38:00.058	info	(4089) terminating
      ham.0	2021-01-13 23:38:00.050	info	(4089) cleaned everything up...
      ham.0	2021-01-13 23:38:00.049	error	(4089) Error: The requested platform 'Doorbird' was not registered by any plugin. at PluginManager.getPluginForPlatform (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManag
      ham.0	2021-01-13 23:38:00.045	error	(4089) unhandled promise rejection: The requested platform 'Doorbird' was not registered by any plugin.
      ham.0	2021-01-13 23:38:00.045	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      ham.0	2021-01-13 23:38:00.041	debug	(4089) [1/13/2021, 22:38:00] Loading 1 platforms...
      ham.0	2021-01-13 23:37:58.965	info	(4089) All Libraries installed/updated
      ham.0	2021-01-13 23:37:58.964	error	(4089) Error: Library https://github.com/hjdhjd/homebridge-doorbird not installed after 3 attempts
      ham.0	2021-01-13 23:37:58.925	info	(4089) found 0 vulnerabilities
      ham.0	2021-01-13 23:37:58.846	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.395s
      ham.0	2021-01-13 23:37:43.153	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
      ham.0	2021-01-13 23:37:43.119	info	(4089) found 0 vulnerabilities
      ham.0	2021-01-13 23:37:43.043	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 20.522s
      ham.0	2021-01-13 23:37:21.253	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
      ham.0	2021-01-13 23:37:21.213	info	(4089) found 0 vulnerabilities
      ham.0	2021-01-13 23:37:21.121	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 13.538s
      ham.0	2021-01-13 23:37:06.277	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
      ham.0	2021-01-13 23:37:06.276	info	(4089) Install/Update https://github.com/hjdhjd/homebridge-doorbird
      ham.0	2021-01-13 23:37:06.275	info	(4089) Install/Update the following Libraries: https://github.com/hjdhjd/homebridge-doorbird
      ham.0	2021-01-13 23:37:06.246	info	(4089) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.20.1, js-controller: 3.1.6
      host.raspberrypi	2021-01-13 23:37:05.107	info	instance system.adapter.ham.0 started with pid 4089
      host.raspberrypi	2021-01-13 23:37:02.604	info	instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      ham.0	2021-01-13 23:37:02.072	info	(3781) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      ham.0	2021-01-13 23:37:02.071	info	(3781) terminating
      ham.0	2021-01-13 23:37:02.070	info	(3781) cleaned everything up...
      ham.0	2021-01-13 23:37:02.069	info	(3781) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-01-13 23:37:02.066	info	stopInstance system.adapter.ham.0 send kill signal
      host.raspberrypi	2021-01-13 23:37:02.065	info	stopInstance system.adapter.ham.0 (force=false, process=true)
      ham.0	2021-01-13 23:37:02.042	info	(3781) All NPM Modules got reinstalled/updated ... restarting ...
      ham.0	2021-01-13 23:37:02.041	error	(3781) Error: Library https://github.com/hjdhjd/homebridge-doorbird not installed after 3 attempts
      ham.0	2021-01-13 23:37:02.001	info	(3781) found 0 vulnerabilities
      ham.0	2021-01-13 23:37:01.912	info	(3781) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.307s
      ham.0	2021-01-13 23:36:46.329	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
      ham.0	2021-01-13 23:36:46.296	info	(3781) found 0 vulnerabilities
      ham.0	2021-01-13 23:36:46.220	info	(3781) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.364s
      ham.0	2021-01-13 22:36:30.521	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
      ham.0	2021-01-13 22:36:30.484	info	(3781) found 0 vulnerabilities
      ham.0	2021-01-13 22:36:30.402	info	updated 1 package and audited 39 packages in 14.212s
      ham.0	2021-01-13 22:36:30.402	info	(3781) + homebridge-doorbird@1.0.1
      ham.0	2021-01-13 22:36:14.865	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
      ham.0	2021-01-13 22:36:14.864	info	(3781) Install/Update https://github.com/hjdhjd/homebridge-doorbird
      ham.0	2021-01-13 22:36:14.863	info	(3781) Install/Update the following Libraries: https://github.com/hjdhjd/homebridge-doorbird
      ham.0	2021-01-13 22:36:14.834	info	(3781) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.20.1, js-controller: 3.1.6
      Ich bedanke mich vorab für eure Unterstützung!
        apollon77 @TheAriba last edited by
        @enoceaneltako said in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
        Naja teht doch alles in der Fehlermeung. DU musst in der Liste der Pakete auch die nötigen Plugin Pakete aufzählen das Sie installiert werden können.
          SkeeveKlah @Boardy last edited by
          @boardy Tja... ich habe ne Waschmaschine im Adapter und die wird wohl nur als Schalter angezeigt, irgendwo hatte ich das auch mal gelesen, hatte etwas Hoffnung das mittlerweile ein bischen mehr geht, ist aber wohl nicht.
          ManN kann eben (noch) nicht alles haben 😳
            amiethaner last edited by
            Hey @apollon77
            Ich kenn mich mit der Programmiererei so leider ned aus, aber wollte mal vorsichtig anfragen
            obs für Fibaro HC2 mal ne erweiterung geben wird, oder ob das technisch überhaupt geht.
            Hier wären ja deutlich mehr values der einzelnen Devices vorhanden als über den Ham zum IOB kommen.
            Ansonsten aber echt n dicken Danke für den Adapter! Super arbeit!
              apollon77 @amiethaner last edited by
              @amiethaner Keine ahnug obs das mal geben wird 🙂 Gibts einen Adapter Request dazu?
                amiethaner @apollon77 last edited by
                @apollon77 sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                Ich glaub ned, meinst es bringt was wenn ich einen aufmach
                  A Former User @apollon77 last edited by
                  @apollon77
                  Hier ein Beispiel für die Govee-Ambiente H6104, hab 2 Stück, es werden beide automatisch gefunden, läuft so:
                    "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                    "accessories": [],
                    "platforms": [
                        "platform": "Govee",
                        "name": "Govee",
                        "apiKey": "api-key",
                        "model": "H6104",
                        "controllable": true,
                        "retrievable": true,
                        "supportCmds": [
                          "turn",
                          "brightness",
                          "color",
                          "colorTem"
                  gelberlemmy 1 Reply Last reply Reply Quote 1
                    marcfe @apollon77 last edited by marcfe
                    homebridge-keylights (Version 1.2.4)funktioniert leider nicht richtig mit der Plugin-Version 4.0.1: https://www.npmjs.com/package/homebridge-keylights
                    Meine NodeJS-Version war v10.24.0 und ist jetzt v12.22.1 (kein Unterschied)
                    es wird zwar mit folgender Konfiguration erkannt (useIP muss true sein) und auch der Status aktualisiert, wenn ich zum Beispiel Setting über die App ändere, leider kann ich das Keylight über den iobroker nur ein und wieder aus-schalten.
                    Konfig:
                      "platforms": [
                          "name": "Elgato Key Lights",
                          "switchOnDurationMs": 100,
                          "platform": "ElgatoKeyLights",
                          "useIP": true
                    Objekte:
                    Logs:
                    # Ändern über Objekte (es passiert nichts am Licht)
                    ham.0	2021-04-15 12:55:06.729	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.Brightness {"val":25,"ack":true,"ts":1618484106722,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484106712}
                    ham.0	2021-04-15 12:55:06.717	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.Brightness {"val":25,"ack":false,"ts":1618484106712,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1618484106712}
                    # Licht über Objekte ausschalten (funktioniert)
                    ham.0	2021-04-15 12:59:00.943	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.On {"val":false,"ack":true,"ts":1618484340939,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484340708}
                    ham.0	2021-04-15 12:59:00.767	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.On {"val":false,"ack":true,"ts":1618484340763,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484340708}
                    ham.0	2021-04-15 12:59:00.713	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.On {"val":false,"ack":false,"ts":1618484340708,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1618484340708}
                    # Ändern über die App (kommt im iobroker an)
                    ham.0	2021-04-15 12:54:48.702	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.Brightness {"val":52,"ack":true,"ts":1618484088698,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484088698}
                    getestet im wrapper und local mode
                      apollon77 @marcfe last edited by
                      @marcfe naja das brauchst man etwas mehr Log 🙂 Bitte Adaoter auf Debug Log stellen und starten. Dann gesamtes Log aus dem Logfile von der Platte /opt/iobroker/log/... und posten
                        M240-Swiss @apollon77 last edited by
                        Nach dem Update auf 4.0.1 funktioniert das Plugin „homebridge-logi-circle-controls“ nicht mehr. Die Schalter zur Bedienung der Kameras sind zwar vorhanden aber ohne Funktion.
                        Ein Downgrade auf 3.0.2 und alles läuft wieder
                          apollon77 @M240-Swiss last edited by apollon77
                          @m240-swiss auch hier ... log bitte
                          Und ggf auch im Plugin schauen ob das ggf ne neue Version braucht für homebridge 1.3.x ?! Da gab es Plugins die Updates brauchen.
                            @apollon77 kann man in den HAM Adapter einbauen, dass er die Anzahl an Updates für installierte Plugins anzeigt, wie im Adapter-Tab ?
                              apollon77 @Guest last edited by
                              @ilovegym Haste Dir mal den neuen Tab des Adapters angeschaut den es seit dern 4.0. gibt?? ggf ists da schon drin ... sonst wäre ein Feature Request im Github ne idee
                                @apollon77 🙂 ja, da ist es mir ja auch aufgefallen, dass es neue Versionen gibt..
                                ich meine halt in der Leiste links, wie bei "Adapter" wenn da neue sind, zeigt er ja auch die Anzahl an Updates an..
                                ... halt für die ganz Blinden, wie mich, in extra groß und rot, wenn es geht..? 🙂
                                  @ilovegym Ne für solche "sub updates" gibt es keine optionen die ich kennen würde
                                    @apollon77 : Es gibt tatsächlich eine neue Version des Plugins. Kannst Du mir sagen wie ich es im HAM Adapter Updaten kann? (Und vielleicht auch wie ich sehe welche Version eines Plugins installiert ist) Besten Dank im Voraus
                                      @m240-swiss Updaten: Im Admin gibts nen "update plugins" checkbox. drücken, speichern, warten.
                                      Sehen neue version sollte in dem neuen Homebridge Tab (siehe infos Changelog zur 4.0 version) drin sein
                                        @apollon77 : Super, vielen Dank. Plugin upgedatet und die neue Version des Adapters geladen –> alles funktioniert
                                        • gelberlemmy
                                          gelberlemmy @Guest last edited by
                                          @ilovegym sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                                          @apollon77
                                            "accessories": [],
                                            "platforms": [
                                                "name": "Govee",
                                                "model": "H6104",
                                                "supportCmds": [
                                                  "turn",
                                                  "brightness",
                                                  "color",
                                                  "colorTem"
                                          Ich habe auch den Govee Adapter. Aber ich kann die Helligkeit und die Farbe meiner LED nicht steuern. An / Aus geht. Habe aber in den Config nur die API stehen. Muss ich für jeden Typen dies so einstellen ?
                                          ? apollon77 S 3 Replies Last reply Reply Quote 0
                                            A Former User @gelberlemmy last edited by
                                            @gelberlemmy
                                            hmm hab ich nie getestet, da ich nur ein/aus benoetige, ist ja das Ambilight, das regelt von alleine...
                                            Hab 2 Stueck, die hat er automatisch gefunden ueber die API und angelegt.
                                            238
                                            55968
