    4. ZigBee neue Version 1.5.x
      hukio last edited by
      @asgothian
      Hardware: Raspi 4 und cc2538 + cc2592. Software:
      2021-04-17 11:05:15.190 - info: host.raspi-3 instance system.adapter.zigbee.0 started with pid 27203
      2021-04-17 11:05:17.574 - info: zigbee.0 (27203) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.2.16
      2021-04-17 11:05:17.679 - info: zigbee.0 (27203) Starting Zigbee npm ...
      2021-04-17 11:05:17.972 - info: zigbee.0 (27203) Installed Version: ioBroker/ioBroker.zigbee#master
      2021-04-17 11:05:17.992 - info: zigbee.0 (27203) debug devices set to []
      2021-04-17 11:05:19.824 - info: zigbee.0 (27203) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
      2021-04-17 11:05:19.829 - info: zigbee.0 (27203) Disable LED
      2021-04-17 11:05:19.833 - info: zigbee.0 (27203) --> transmitPower : high
      2021-04-17 11:05:19.846 - info: zigbee.0 (27203) Currently 61 devices are joined:
      2021-04-17 11:05:19.986 - info: zigbee.0 (27203) 0x00158d000366790e (addr 34629): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-04-17 11:05:19.992 - info: zigbee.0 (27203) 0x000d6ffffe1d3981 (addr 60539): LED1624G9 - IKEA TRADFRI LED bulb E14/E26/E27 600 lumen, dimmable, color, opal white (Router)
      Wenn ich den state DP der Ikea Birne verändere, ist die debug Antwort:
      2021-04-17 11:19:05.485 - debug: zigbee.0 (9960) User stateChange zigbee.0.000d6ffffe1d3981.state {"val":true,"ack":false,"ts":1618651145483,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1618651145483}
      2021-04-17 11:19:05.491 - debug: zigbee.0 (9960) Change state 'state' at device 0x000d6ffffe1d3981 type 'LED1624G9'
      2021-04-17 11:19:05.496 - debug: zigbee.0 (9960) entity: {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x000d6ffffe1d3981","_networkAddress":60539,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":512,"inputClusters":[0,3,4,5,6,8,768,2821,4096],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":60539,"deviceIeeeAddress":"0x000d6ffffe1d3981","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 CWS opal 600lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":1,"appVersion":19,"stackVersion":87,"hwVersion":1,"dateCode":"20200220","swBuildId":"1.3.013"}},"genOnOff":{"attributes":{"onOff":1}},"lightingColorCtrl":{"attributes":{"currentX":30153,"currentY":32971,"colorCapabilities":8}},"genPowerCfg":{"attributes":{}},"genDeviceTempCfg":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 CWS opal 600lm","_applicationVersion":19,"_stackVersion":87,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200220","_softwareBuildID":"1.3.013","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":2},"_lastSeen":1618356407407},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"composite","property":"color","name":"color_xy","features":[{"type":"numeric","name":"x","property":"x","access":7},{"type":"numeric","name":"y","property":"y","access":7}],"description":"Color of this light in the CIE 1931 color space (x/y)"}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["hue_move","saturation_move"]},{"key":["hue_step","saturation_step"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"meta":{"configureKey":2,"supportsHueAndSaturation":false},"zigbeeModel":["TRADFRI bulb E27 CWS opal 600lm","TRADFRI bulb E26 CWS opal 600lm","TRADFRI bulb E14 CWS opal 600lm","TRADFRI bulb E12 CWS opal 600lm"],"model":"LED1624G9","vendor":"IKEA","description":"TRADFRI LED bulb E14/E26/E27 600 lumen, dimmable, color, opal white","ota":{}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000d6ffffe1d3981"}
      2021-04-17 11:19:05.497 - debug: zigbee.0 (9960) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"composite","property":"color","name":"color_xy","features":[{"type":"numeric","name":"x","property":"x","access":7},{"type":"numeric","name":"y","property":"y","access":7}],"description":"Color of this light in the CIE 1931 color space (x/y)"}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["hue_move","saturation_move"]},{"key":["hue_step","saturation_step"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"meta":{"configureKey":2,"supportsHueAndSaturation":false},"zigbeeModel":["TRADFRI bulb E27 CWS opal 600lm","TRADFRI bulb E26 CWS opal 600lm","TRADFRI bulb E14 CWS opal 600lm","TRADFRI bulb E12 CWS opal 600lm"],"model":"LED1624G9","vendor":"IKEA","description":"TRADFRI LED bulb E14/E26/E27 600 lumen, dimmable, color, opal white","ota":{}}
      2021-04-17 11:19:05.497 - debug: zigbee.0 (9960) convert state, ON, {"state":"ON","transition_time":0}
      2021-04-17 11:19:05.498 - debug: zigbee.0 (9960) target: {"ID":1,"profileID":49246,"deviceID":512,"inputClusters":[0,3,4,5,6,8,768,2821,4096],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":60539,"deviceIeeeAddress":"0x000d6ffffe1d3981","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 CWS opal 600lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":1,"appVersion":19,"stackVersion":87,"hwVersion":1,"dateCode":"20200220","swBuildId":"1.3.013"}},"genOnOff":{"attributes":{"onOff":1}},"lightingColorCtrl":{"attributes":{"currentX":30153,"currentY":32971,"colorCapabilities":8}},"genPowerCfg":{"attributes":{}},"genDeviceTempCfg":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}
      2021-04-17 11:19:05.500 - debug: zigbee.0 (9960) zigbee-herdsman:controller:endpoint Command 0x000d6ffffe1d3981/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false})
      Die Birne schaltet nicht. Einige Xiaomi Temperaturmesser und Kontakte funktionieren.
      Wie gesagt, das Problem kam als ich das update machte. Dann habe ich ein 1.4.5 backup eingespielt. Das hat sich nicht mit der 1.5.1 vertragen (keine Kacheln). Dann upload von 1.5.1 und Kacheln ohne Verbindung.
      • Fenriswolf
        Fenriswolf @Neuschwansteini last edited by
        @ilovegym sagte in ZigBee neue Version 1.5.x:
        @asgothian @arteck
        wie bitte, bekommt man es hin, das es sich so gleichmäßig und übersichtlich aufteilt und darstellt ?
        amg_666 Neuschwansteini 2 Replies Last reply Reply Quote 0
        • amg_666
          amg_666 @Fenriswolf last edited by amg_666
          @fenriswolf "aufteilen", also wer meldet sich wo an, kannst du m.W. nicht beeinflussen, das machen die zigbee Devices unter sich aus. Du kannst nur die Art der Darstellung ändern indem du unten rechts bei der Netzwerkkarte auf das Aktualisieren-Symbol klickst.
          • Asgothian
            Asgothian Developer @hukio last edited by
            @hukio Das deutet darauf hin das der Koordinator keine Antwort von Deinen Geräten bekommt. Woran das liegt ist leider schwer zu sagen.
            A.
              hukio @Asgothian last edited by hukio
              @asgothian Ich habe inzwischen den Adapter gelöscht und über backitup den 1.4.5 wieder eingespielt. Alle Kacheln sind da, aber keine Verbindung. Ich kann auch nicht neu pairen. Das pairing springt nicht an. Wenn ich mit debug starte, spuckt der Adapter parse Meldungen in nicht endend wollenden Anzahl aus. Das restore ist also nicht gelungen. Hast Du irgendeine Idee, was ich noch versuchen könnte? So kann ich die Geräte nicht einmal neu anlernen (pairing startet nicht).
              PS: was macht eigentlich das reset in den settings? Löscht das die Geräte oder nur die s/w? Ich hab es vergessen.
              Irgendwie sieht das log (ohne debug) anders aus bei einem restart des Adapters. Kannst Du mal hinschauen bitte.
              2021-04-17 21:26:35.391  - info: host.raspi-3 stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2021-04-17 21:26:35.403  - info: zigbee.0 (31895) Got terminate signal TERMINATE_YOURSELF
              2021-04-17 21:26:35.405  - info: host.raspi-3 stopInstance system.adapter.zigbee.0 send kill signal
              2021-04-17 21:26:35.406  - info: zigbee.0 (31895) cleaned everything up...
              2021-04-17 21:26:35.409  - info: zigbee.0 (31895) Zigbee: disabling joining new devices.
              2021-04-17 21:26:36.145  - info: zigbee.0 (31895) terminating
              2021-04-17 21:26:36.146  - info: zigbee.0 (31895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2021-04-17 21:26:36.411  - info: host.raspi-3 stopInstance system.adapter.zigbee.0 killing pid 31895
              2021-04-17 21:26:36.888  - info: host.raspi-3 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2021-04-17 21:26:38.459  - info: host.raspi-3 instance system.adapter.zigbee.0 started with pid 1964
              2021-04-17 21:26:41.115  - info: zigbee.0 (1964) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.2.16
              2021-04-17 21:26:41.218  - info: zigbee.0 (1964) Starting Zigbee  npm ...
              2021-04-17 21:26:41.507  - info: zigbee.0 (1964) Installed Version: asgothian/ioBroker.zigbee#ExposeExtend
              2021-04-17 21:26:41.525  - info: zigbee.0 (1964) debug devices set to []
              2021-04-17 21:26:43.326  - info: zigbee.0 (1964) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
              2021-04-17 21:26:43.331  - info: zigbee.0 (1964) Disable LED
              2021-04-17 21:26:43.336  - info: zigbee.0 (1964)   --> transmitPower : high
              2021-04-17 21:26:43.348  - info: zigbee.0 (1964) Currently 61 devices are joined:
              2021-04-17 21:26:43.482  - info: zigbee.0 (1964) 0x00158d000366790e (addr 34629): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                Levent552003 @Asgothian last edited by
                @asgothian also da ich kein experte bin ergaben meine Bemühungen leider keinen Ergebnis. habe es durch die tuya app eingebunden da habe ich zwar die einzelnen Objekte aber steuern lässt sich der trotzdem nicht.
                • Asgothian
                  Asgothian Developer @Levent552003 last edited by
                  @levent552003 wenn ich das richtig erinnere lässt sich das TuYa schloss nicht steuern. Es meldet nur welcher Schlüssel zum schliessen benutzt wurde. Sicher bin ich mir aber nicht.
                  Leider ist bei TuYa geräten ein Einbinden ohne direkten Zugang zum Gerät fast ausgeschlossen.
                  A.
                  L D 2 Replies Last reply Reply Quote 0
                    @asgothian anscheinend liegt es daran das Batterie betriebene Geräte nicht mit der tuya Adapter gehen. Die Objekte werden rot nach paar Sekunden weil der auf Stand-by Modus geht. So oder so ähnlich soll es sein. Aber wenn du dich der Herausforderung annehmen willst ich arbeite für den Welt größten Paket Lieferanten. In 2 tagen wäre das teil bei dir. 🙂
                      DocGame @Asgothian last edited by
                      @asgothian Das mit den Schlüsseln waren die hier:
                      Mihome Smart Lock Zylinder
                      Tuya Smart Lock Zylinderl
                      Uns interessieren die...:
                      Airbnk M531 Türschloss Stärker Motor TUYA Zigbee Smart Lock Fingerprint
                      @Levent552003 Bekommst du irgendwas angezeigt, das auf die States schließen liese?
                      Asgothian L 3 Replies Last reply Reply Quote 0
                      • Asgothian
                        Asgothian Developer @DocGame last edited by
                        @docgame ich kam da ran gehen, aber leider nicht vor Ende Mai. Ich bin ab dem nächsten wochenende erst einmal 4 Wochen ohne Zugriff auf mein entwicklungssystem.
                        A.
                          Levent552003 @DocGame last edited by
                          @docgame @docgame also im expert modus von zigbee adapter kriege ich paar befehle zur abfrage durch habe aber den zum öffne von zylinder nicht gefunden.
                            @asgothian ich denke mal in fähigen Händen wie von dir wäre es eine sache von paar Minuten 😉
                              @docgame wenn man vielleicht einen Befehl als String zur tuya zentrale schicken könnte wäre das vielleicht auch ein Weg.
                                DocGame @Levent552003 last edited by
                                @levent552003 Uber den Tuyaadapter habe ich nur (notgedrungen) 2 WiFi Geräte (Wasserkocher und Standventilator) im ioBroker. Direkt im Zigbee-Adapter wäre sicherlich die bessere Lösung. Wenn dann noch die verschiedenen Fingerprint-Profile als State da wären hätte man eine gute Basis zur Anwesenheitserkennung (Neben Radar,TR-064, Ping usw.)
                                • Asgothian
                                  @docgame @Levent552003 könntbihr diese Diskussion bitte in einen eigenen thread auslagern ?
                                    A Former User @Guest last edited by
                                    @dp20eic Da muss ich mich einmal selber zitieren.
                                    Mein Problem ist behoben, Danke an @Asgothian und @kirovilya.
                                    Sie gaben mir den Tipp bei den Namen im Objekt-Tree nachzuschauen, da hab ich dann gesehen, dass ich wohl ein "}" anstatt "]" benutzt habe. Vor 1.5.x war das wohl kein Problem.
                                    Nun gut läuft wieder und jetzt kann mich an die Erkundung der neuen Möglichkeiten machen.
                                    Vielen Dank und echt klasse Arbeit die Ihr hier leistet.
                                    Viele Grüße
                                    Bernd
                                    • Neuschwansteini
                                      Neuschwansteini @Fenriswolf last edited by
                                      @fenriswolf Hi, ich habe an mir so pi x Daumen gedachten strategischen Orten Router installiert, und das scheint auch gut zu funktionieren.. 🙂
                                      Sind ca 300qm auf 4 Etagen und der Gartenbereich und Garage und Nebengebäude.
                                      Fenriswolf 1 Reply Last reply Reply Quote 2
                                      • Fenriswolf
                                        Danke für die Info 😉
                                          PatrickFro last edited by
                                          Moin zusammen,
                                          im Threat zur 1.4-Version habe ich mein Problem schonmal dargestellt, habe eine Lösung dann aber nicht weiter verfolgt.
                                          Es betrifft den LED-Stripe Innr FL 130 C.
                                          Es ist ein Farbstripe, es wird jedoch keine Farbe angeboten. Die Objekte habe ich schon 3 Mal gelöscht und über den Adapter hinzufügen lassen, kein Unterschied. Update des Adapters von 1.4.x auf 1.5.1 hat auch nichts verändert.
                                          zigbee.1	2021-04-20 11:01:06.486	warn	(27024) Failed to ping 0x7cb03eaa0a028bf7 Plug 01
                                          zigbee.1	2021-04-20 11:01:06.486	warn	(27024) Failed to ping 0x8418260000caad6f Flex RGBW
                                          zigbee.1	2021-04-20 11:01:05.487	warn	(27024) Failed to ping 0x000d6ffffe1d0409 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 11:01:05.487	warn	(27024) Failed to ping 0xd0cf5efffe3f60e8 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 11:01:05.487	warn	(27024) Failed to ping 0x000d6ffffe21f0e7 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 11:01:05.487	warn	(27024) Failed to ping 0xd0cf5efffe3f59f2 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 11:01:05.487	warn	(27024) Failed to ping 0x000d6ffffe20709b ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 11:01:04.486	warn	(27024) Failed to ping 0x7cb03eaa0a02827a Plug 01
                                          zigbee.1	2021-04-20 11:01:04.486	warn	(27024) Failed to ping 0x84182600001075ee Plug 01
                                          zigbee.1	2021-04-20 11:01:04.486	warn	(27024) Failed to ping 0xd0cf5efffe41b691 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 11:01:02.484	warn	(27024) Failed to ping 0x7cb03eaa00b27f7d Plug 01
                                          zigbee.1	2021-04-20 10:59:32.099	warn	(27024) Failed to read state '"color_options"'of '0x00158d000342b1b0' after query with '{"code":134}'
                                          zigbee.1	2021-04-20 10:59:32.072	warn	(27024) Failed to read state '"power_on_behavior"'of '0x00158d000342b1b0' after query with '{"code":134}'
                                          zigbee.1	2021-04-20 10:59:31.902	warn	(27024) Failed to read state '"color_temp_startup"'of '0x00158d000342b1b0' after query with '{"code":134}'
                                          zigbee.1	2021-04-20 10:59:31.832	warn	(27024) Failed to read state '"color"'of '0x00158d000342b1b0' after query with '{}'
                                          zigbee.1	2021-04-20 10:59:01.572	info	(27024) Zigbee started
                                          zigbee.1	2021-04-20 10:59:01.572	info	(27024) 0x7cb03eaa0a028bf7 (addr 34898): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.571	info	(27024) 0x00158d0001d76589 (addr 14443): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.571	info	(27024) 0x00158d0001dd7f1e (addr 54778): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.571	info	(27024) 0x00158d00019cf9ff (addr 19175): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.571	info	(27024) 0x00158d000582e5c9 (addr 33517): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.570	info	(27024) 0x00158d00019d1b9e (addr 58669): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.570	info	(27024) 0x00158d000588e6f3 (addr 64850): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.570	info	(27024) 0x00158d0001d780eb (addr 21385): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.569	info	(27024) 0x00158d00057fcfa7 (addr 5267): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.569	info	(27024) 0x00158d00058a1b52 (addr 43658): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.569	info	(27024) 0x00158d00019cf991 (addr 43522): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.568	info	(27024) 0x04cf8cdf3c866dbc (addr 63357): ZNCZ04LM - Xiaomi Mi power plug ZigBee EU (Router)
                                          zigbee.1	2021-04-20 10:59:01.568	info	(27024) 0x00158d00044ef878 (addr 12247): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.567	info	(27024) 0x00158d0003a486fe (addr 19633): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.567	info	(27024) 0x00158d00032ca0be (addr 14498): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.566	info	(27024) 0x00158d00034f4dae (addr 65521): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.566	info	(27024) 0x8418260000caad6f (addr 17864): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:59:01.566	info	(27024) 0x00158d0002ec3bc3 (addr 26425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.566	info	(27024) 0x00158d0003cf39e4 (addr 58679): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.565	info	(27024) 0x00158d00025f147d (addr 24489): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.565	info	(27024) 0x00158d00034f4db8 (addr 5574): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.565	info	(27024) 0x000d6ffffe1d0409 (addr 42403): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:59:01.563	info	(27024) 0xd0cf5efffe3f60e8 (addr 46169): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:59:01.562	info	(27024) 0x000d6ffffe21f0e7 (addr 612): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:59:01.562	info	(27024) 0xd0cf5efffe3f59f2 (addr 52417): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:59:01.561	info	(27024) 0x000d6ffffe20709b (addr 45803): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:59:01.561	info	(27024) 0x7cb03eaa0a02827a (addr 40982): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.561	info	(27024) 0xd0cf5efffe41b691 (addr 7733): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:59:01.560	info	(27024) 0x7cb03eaa0a031c2b (addr 7783): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.560	info	(27024) 0x84182600001075ee (addr 20343): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.559	info	(27024) 0x7cb03eaa00b23d4c (addr 24972): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.559	info	(27024) 0x00158d000342b1b0 (addr 18727): FL 130 C - Innr Color Flex LED strip (Router)
                                          zigbee.1	2021-04-20 10:59:01.559	info	(27024) 0x00158d0003955312 (addr 33444): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.557	info	(27024) 0x7cb03eaa00b08dac (addr 22594): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.557	info	(27024) 0x00158d0003cb5283 (addr 64294): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.557	info	(27024) 0x00158d00045cd8b4 (addr 26461): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.556	info	(27024) 0x00158d0003cb512e (addr 20693): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.556	info	(27024) 0x7cb03eaa00a5b421 (addr 52322): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:59:01.556	info	(27024) 0x000b57fffea0d8e2 (addr 26837): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                          zigbee.1	2021-04-20 10:59:01.555	info	(27024) 0x000b57fffee72518 (addr 34839): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                          zigbee.1	2021-04-20 10:59:01.555	info	(27024) 0x00158d0004248983 (addr 36783): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.554	info	(27024) 0x7cb03eaa00b0b004 (addr 43763): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.554	info	(27024) 0x8418260000caaf0d (addr 11366): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:59:01.553	info	(27024) 0x00178801066a9a7a (addr 63798): 9290018187B - Philips Hue white and color ambiance LightStrip outdoor (Router)
                                          zigbee.1	2021-04-20 10:59:01.553	info	(27024) 0x7cb03eaa00b27f7d (addr 30996): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:59:01.551	info	(27024) 0x00158d0003cd8453 (addr 26173): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:59:01.526	info	(27024) Currently 46 devices are joined:
                                          zigbee.1	2021-04-20 10:59:01.524	info	(27024) Unable to set transmit power, unsupported function.
                                          zigbee.1	2021-04-20 10:59:01.523	info	(27024) --> transmitPower : normal
                                          zigbee.1	2021-04-20 10:59:01.523	info	(27024) Unable to disable LED, unsupported function.
                                          zigbee.1	2021-04-20 10:59:01.503	info	(27024) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                                          zigbee.1	2021-04-20 10:59:01.468	info	(27024) Installed Version: ioBroker/ioBroker.zigbee#fceb2d1e2b856bc6104f78dfbdfacf88345216cf
                                          zigbee.1	2021-04-20 10:59:01.336	info	(27024) Starting Zigbee npm ...
                                          zigbee.1	2021-04-20 10:59:01.303	info	(27024) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.0, js-controller: 3.2.16
                                          zigbee.1	2021-04-20 10:58:29.735	warn	(26992) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          zigbee.1	2021-04-20 10:58:29.735	info	(26992) terminating
                                          zigbee.1	2021-04-20 10:58:29.235	info	(26992) Zigbee: disabling joining new devices.
                                          zigbee.1	2021-04-20 10:58:29.234	info	(26992) cleaned everything up...
                                          zigbee.1	2021-04-20 10:58:29.230	error	(26992) Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                                          zigbee.1	2021-04-20 10:58:29.230	error	(26992) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0' at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/decon
                                          zigbee.1	2021-04-20 10:58:29.230	error	(26992) unhandled promise rejection: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                                          zigbee.1	2021-04-20 10:58:29.229	error	(26992) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          zigbee.1	2021-04-20 10:57:39.316	info	(26992) Zigbee started
                                          zigbee.1	2021-04-20 10:57:39.315	info	(26992) 0x7cb03eaa0a028bf7 (addr 34898): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.315	info	(26992) 0x00158d0001d76589 (addr 14443): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.315	info	(26992) 0x00158d0001dd7f1e (addr 54778): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.314	info	(26992) 0x00158d00019cf9ff (addr 19175): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.314	info	(26992) 0x00158d000582e5c9 (addr 33517): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.314	info	(26992) 0x00158d00019d1b9e (addr 58669): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.313	info	(26992) 0x00158d000588e6f3 (addr 64850): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.313	info	(26992) 0x00158d0001d780eb (addr 21385): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.313	info	(26992) 0x00158d00057fcfa7 (addr 5267): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.312	info	(26992) 0x00158d00058a1b52 (addr 43658): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.312	info	(26992) 0x00158d00019cf991 (addr 43522): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.312	info	(26992) 0x04cf8cdf3c866dbc (addr 63357): ZNCZ04LM - Xiaomi Mi power plug ZigBee EU (Router)
                                          zigbee.1	2021-04-20 10:57:39.311	info	(26992) 0x00158d00044ef878 (addr 12247): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.311	info	(26992) 0x00158d0003a486fe (addr 19633): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.310	info	(26992) 0x00158d00032ca0be (addr 14498): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.310	info	(26992) 0x00158d00034f4dae (addr 65521): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.309	info	(26992) 0x8418260000caad6f (addr 17864): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:57:39.309	info	(26992) 0x00158d0002ec3bc3 (addr 26425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.309	info	(26992) 0x00158d0003cf39e4 (addr 58679): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.308	info	(26992) 0x00158d00025f147d (addr 24489): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.308	info	(26992) 0x00158d00034f4db8 (addr 5574): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.307	info	(26992) 0x000d6ffffe1d0409 (addr 42403): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:57:39.307	info	(26992) 0xd0cf5efffe3f60e8 (addr 46169): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:57:39.306	info	(26992) 0x000d6ffffe21f0e7 (addr 612): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:57:39.305	info	(26992) 0xd0cf5efffe3f59f2 (addr 52417): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:57:39.305	info	(26992) 0x000d6ffffe20709b (addr 45803): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:57:39.305	info	(26992) 0x7cb03eaa0a02827a (addr 40982): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.304	info	(26992) 0xd0cf5efffe41b691 (addr 7733): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:57:39.304	info	(26992) 0x7cb03eaa0a031c2b (addr 7783): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.303	info	(26992) 0x84182600001075ee (addr 20343): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.303	info	(26992) 0x7cb03eaa00b23d4c (addr 24972): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.301	info	(26992) 0x00158d000342b1b0 (addr 18727): FL 130 C - Innr Color Flex LED strip (Router)
                                          zigbee.1	2021-04-20 10:57:39.301	info	(26992) 0x00158d0003955312 (addr 33444): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.301	info	(26992) 0x7cb03eaa00b08dac (addr 22594): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.301	info	(26992) 0x00158d0003cb5283 (addr 64294): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.300	info	(26992) 0x00158d00045cd8b4 (addr 26461): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.300	info	(26992) 0x00158d0003cb512e (addr 20693): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.300	info	(26992) 0x7cb03eaa00a5b421 (addr 52322): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:57:39.300	info	(26992) 0x000b57fffea0d8e2 (addr 26837): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                          zigbee.1	2021-04-20 10:57:39.299	info	(26992) 0x000b57fffee72518 (addr 34839): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                          zigbee.1	2021-04-20 10:57:39.299	info	(26992) 0x00158d0004248983 (addr 36783): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.299	info	(26992) 0x7cb03eaa00b0b004 (addr 43763): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.299	info	(26992) 0x8418260000caaf0d (addr 11366): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:57:39.298	info	(26992) 0x00178801066a9a7a (addr 63798): 9290018187B - Philips Hue white and color ambiance LightStrip outdoor (Router)
                                          zigbee.1	2021-04-20 10:57:39.298	info	(26992) 0x7cb03eaa00b27f7d (addr 30996): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:57:39.297	info	(26992) 0x00158d0003cd8453 (addr 26173): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:57:39.275	info	(26992) Currently 46 devices are joined:
                                          zigbee.1	2021-04-20 10:57:39.273	info	(26992) Unable to set transmit power, unsupported function.
                                          zigbee.1	2021-04-20 10:57:39.273	info	(26992) --> transmitPower : normal
                                          zigbee.1	2021-04-20 10:57:39.273	info	(26992) Unable to disable LED, unsupported function.
                                          zigbee.1	2021-04-20 10:57:39.252	info	(26992) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                                          zigbee.1	2021-04-20 10:57:39.222	info	(26992) Installed Version: ioBroker/ioBroker.zigbee#fceb2d1e2b856bc6104f78dfbdfacf88345216cf
                                          zigbee.1	2021-04-20 10:57:39.070	info	(26992) Starting Zigbee npm ...
                                          zigbee.1	2021-04-20 10:57:39.037	info	(26992) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.0, js-controller: 3.2.16
                                          zigbee.1	2021-04-20 10:57:35.151	info	(26906) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          zigbee.1	2021-04-20 10:57:35.151	info	(26906) terminating
                                          zigbee.1	2021-04-20 10:57:34.989	info	(26906) Zigbee: disabling joining new devices.
                                          zigbee.1	2021-04-20 10:57:34.988	info	(26906) cleaned everything up...
                                          zigbee.1	2021-04-20 10:57:34.988	info	(26906) Got terminate signal TERMINATE_YOURSELF
                                          zigbee.1	2021-04-20 10:56:22.213	warn	(26906) Failed to ping 0x7cb03eaa0a028bf7 Plug 01
                                          zigbee.1	2021-04-20 10:56:22.213	warn	(26906) Failed to ping 0x8418260000caad6f Flex RGBW
                                          zigbee.1	2021-04-20 10:56:21.213	error	(26906) Send command to 0x7cb03eaa00b27f7d failed with no error code (no response received)
                                          zigbee.1	2021-04-20 10:56:21.213	warn	(26906) Failed to ping 0x000d6ffffe1d0409 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 10:56:21.212	warn	(26906) Failed to ping 0xd0cf5efffe3f60e8 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 10:56:21.212	warn	(26906) Failed to ping 0x000d6ffffe21f0e7 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 10:56:21.212	warn	(26906) Failed to ping 0xd0cf5efffe3f59f2 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 10:56:21.212	warn	(26906) Failed to ping 0x000d6ffffe20709b ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 10:56:20.211	warn	(26906) Failed to ping 0x84182600001075ee Plug 01
                                          zigbee.1	2021-04-20 10:56:20.211	warn	(26906) Failed to ping 0xd0cf5efffe41b691 ZBT-ExtendedColor
                                          zigbee.1	2021-04-20 10:56:20.211	warn	(26906) Failed to ping 0x7cb03eaa0a02827a Plug 01
                                          zigbee.1	2021-04-20 10:56:20.056	error	(26906) Send command to 0x7cb03eaa00b27f7d failed with no error code (no response received)
                                          zigbee.1	2021-04-20 10:56:18.210	warn	(26906) Failed to ping 0x7cb03eaa00b27f7d Plug 01
                                          zigbee.1	2021-04-20 10:55:32.274	error	(26906) Send command to 0x7cb03eaa00a5b421 failed with no error code (undefined)
                                          zigbee.1	2021-04-20 10:54:17.302	info	(26906) Zigbee started
                                          zigbee.1	2021-04-20 10:54:17.302	info	(26906) 0x7cb03eaa0a028bf7 (addr 34898): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.302	info	(26906) 0x00158d0001d76589 (addr 14443): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.302	info	(26906) 0x00158d0001dd7f1e (addr 54778): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.301	info	(26906) 0x00158d00019cf9ff (addr 19175): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.301	info	(26906) 0x00158d000582e5c9 (addr 33517): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.301	info	(26906) 0x00158d00019d1b9e (addr 58669): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.301	info	(26906) 0x00158d000588e6f3 (addr 64850): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.300	info	(26906) 0x00158d0001d780eb (addr 21385): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.300	info	(26906) 0x00158d00057fcfa7 (addr 5267): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.300	info	(26906) 0x00158d00058a1b52 (addr 43658): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.300	info	(26906) 0x00158d00019cf991 (addr 43522): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.299	info	(26906) 0x04cf8cdf3c866dbc (addr 63357): ZNCZ04LM - Xiaomi Mi power plug ZigBee EU (Router)
                                          zigbee.1	2021-04-20 10:54:17.299	info	(26906) 0x00158d00044ef878 (addr 12247): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.299	info	(26906) 0x00158d0003a486fe (addr 19633): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.298	info	(26906) 0x00158d00032ca0be (addr 14498): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.298	info	(26906) 0x00158d00034f4dae (addr 65521): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.298	info	(26906) 0x8418260000caad6f (addr 17864): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:54:17.297	info	(26906) 0x00158d0002ec3bc3 (addr 26425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.297	info	(26906) 0x00158d0003cf39e4 (addr 58679): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.297	info	(26906) 0x00158d00025f147d (addr 24489): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.297	info	(26906) 0x00158d00034f4db8 (addr 5574): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.297	info	(26906) 0x000d6ffffe1d0409 (addr 42403): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:54:17.296	info	(26906) 0xd0cf5efffe3f60e8 (addr 46169): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:54:17.296	info	(26906) 0x000d6ffffe21f0e7 (addr 612): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:54:17.295	info	(26906) 0xd0cf5efffe3f59f2 (addr 52417): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:54:17.295	info	(26906) 0x000d6ffffe20709b (addr 45803): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:54:17.295	info	(26906) 0x7cb03eaa0a02827a (addr 40982): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.295	info	(26906) 0xd0cf5efffe41b691 (addr 7733): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                          zigbee.1	2021-04-20 10:54:17.294	info	(26906) 0x7cb03eaa0a031c2b (addr 7783): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.294	info	(26906) 0x84182600001075ee (addr 20343): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.293	info	(26906) DeviceConfigure successful 0x00158d0001d76589 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.293	info	(26906) 0x7cb03eaa00b23d4c (addr 24972): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.291	info	(26906) Configuring 0x00158d0001d76589 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.291	info	(26906) 0x00158d000342b1b0 (addr 18727): FL 130 C - Innr Color Flex LED strip (Router)
                                          zigbee.1	2021-04-20 10:54:17.290	info	(26906) DeviceConfigure successful 0x00158d0001dd7f1e lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.290	info	(26906) 0x00158d0003955312 (addr 33444): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.289	info	(26906) Configuring 0x00158d0001dd7f1e lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.289	info	(26906) 0x7cb03eaa00b08dac (addr 22594): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.288	info	(26906) DeviceConfigure successful 0x00158d00019cf9ff lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.288	info	(26906) 0x00158d0003cb5283 (addr 64294): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.287	info	(26906) Configuring 0x00158d00019cf9ff lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.286	info	(26906) DeviceConfigure successful 0x00158d000582e5c9 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.286	info	(26906) 0x00158d00045cd8b4 (addr 26461): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.285	info	(26906) Configuring 0x00158d000582e5c9 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.285	info	(26906) 0x00158d0003cb512e (addr 20693): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.283	info	(26906) DeviceConfigure successful 0x00158d00019d1b9e lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.283	info	(26906) 0x7cb03eaa00a5b421 (addr 52322): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:54:17.282	info	(26906) Configuring 0x00158d00019d1b9e lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.282	info	(26906) 0x000b57fffea0d8e2 (addr 26837): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                          zigbee.1	2021-04-20 10:54:17.281	info	(26906) DeviceConfigure successful 0x00158d000588e6f3 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.281	info	(26906) 0x000b57fffee72518 (addr 34839): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                          zigbee.1	2021-04-20 10:54:17.279	info	(26906) Configuring 0x00158d000588e6f3 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.278	info	(26906) DeviceConfigure successful 0x00158d0001d780eb lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.278	info	(26906) 0x00158d0004248983 (addr 36783): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.277	info	(26906) Configuring 0x00158d0001d780eb lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.277	info	(26906) 0x7cb03eaa00b0b004 (addr 43763): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.276	info	(26906) DeviceConfigure successful 0x00158d00057fcfa7 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.275	info	(26906) 0x8418260000caaf0d (addr 11366): 4052899926110 - OSRAM Flex RGBW (Router)
                                          zigbee.1	2021-04-20 10:54:17.274	info	(26906) Configuring 0x00158d00057fcfa7 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.274	info	(26906) 0x00178801066a9a7a (addr 63798): 9290018187B - Philips Hue white and color ambiance LightStrip outdoor (Router)
                                          zigbee.1	2021-04-20 10:54:17.272	info	(26906) DeviceConfigure successful 0x00158d00058a1b52 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.272	info	(26906) 0x7cb03eaa00b27f7d (addr 30996): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.1	2021-04-20 10:54:17.270	info	(26906) Configuring 0x00158d00058a1b52 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.267	info	(26906) DeviceConfigure successful 0x00158d00019cf991 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.267	info	(26906) 0x00158d0003cd8453 (addr 26173): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.1	2021-04-20 10:54:17.247	info	(26906) Configuring 0x00158d00019cf991 lumi.weather
                                          zigbee.1	2021-04-20 10:54:17.245	info	(26906) Currently 46 devices are joined:
                                          zigbee.1	2021-04-20 10:54:17.243	info	(26906) Unable to set transmit power, unsupported function.
                                          zigbee.1	2021-04-20 10:54:17.242	info	(26906) --> transmitPower : normal
                                          zigbee.1	2021-04-20 10:54:17.242	info	(26906) Unable to disable LED, unsupported function.
                                          zigbee.1	2021-04-20 10:54:17.220	info	(26906) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                                          zigbee.1	2021-04-20 10:54:17.130	info	(26906) Installed Version: ioBroker/ioBroker.zigbee#fceb2d1e2b856bc6104f78dfbdfacf88345216cf
                                          zigbee.1	2021-04-20 10:54:17.060	info	(26906) Starting Zigbee npm ...
                                          zigbee.1	2021-04-20 10:54:17.026	info	(26906) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.0, js-controller: 3.2.16
                                          Ich hoffe, ich habe an alles gedacht. Gibt es hier vielleicht eine Lösung? Schlechte Verbindung kann es nicht sein, ich habe den Stripe direkt neben dem NUC angelernt.
                                          IdleBit 1 Reply Last reply Reply Quote 0
                                          • IdleBit
                                            IdleBit @PatrickFro last edited by
                                            @patrickfro Hast du die Innr FL 130 C der "Ausschliessen" Liste hinzugefügt und getestet?
                                            31.7k
                                            79.9k
                                            579
                                            111098
