    4. Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren
    • I
      Ibot @Thomas Braun last edited by
      @thomas-braun sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v12.22.1
      /usr/bin/node
      v12.22.1
      /usr/bin/npm
      6.14.12
      nodejs:
        Installiert:           12.22.1-1nodesource1
        Installationskandidat: 12.22.1-1nodesource1
        Versionstabelle:
       *** 12.22.1-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
        Thomas Braun Most Active @Ibot last edited by
        @ibot
        iobroker update
        iobroker upgrade
        Wenn das nicht funktioniert:
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        I 2 Replies Last reply Reply Quote 0
        • I
          Ibot @Thomas Braun last edited by wendy2702
          na dem Upgrade Befehl kommt:
          Error: Cannot find module 'mime'
          Require stack:
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
              at Function.Module._load (internal/modules/cjs/loader.js:667:27)
              at Module.require (internal/modules/cjs/loader.js:887:19)
              at require (internal/modules/cjs/helpers.js:74:18)
              at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/l        ib/setup/setupUpload.js:525:24)
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:211:28
              at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.j        s:2557:9)
              at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setu        p/setupUpgrade.js:205:13)
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:419:21
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.        js:223:55 {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js'        ,
              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js        ',
              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          MOD EDIT: CODE TAGS KORRIGIERT
          • I
            nach:cd /opt/iobroker
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.12
            > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
              CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
            In file included from ../../nan/nan.h:56,
                             from ../src/unix_dgram.cc:5:
            /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                   (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
               NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
             NODE_MODULE(unix_dgram, Initialize)
              SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
              COPY Release/unix_dgram.node
            make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
            > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
            > node rebuild.js
            ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
            > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
              CXX(target) Release/obj.target/diskusage/src/main.o
                             from ../src/main.cpp:3:
            ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
             NODE_MODULE(diskusage, Init)
              CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
              SOLINK_MODULE(target) Release/obj.target/diskusage.node
              COPY Release/diskusage.node
            make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
            > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            object _design/system updated
            > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
            > node scripts/postinstall
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            + iobroker.js-controller@3.2.16
            added 254 packages from 265 contributors, removed 6 packages, updated 1 package and moved 16 packages in 96.989s
            13 packages are looking for funding
              run `npm fund` for details
               │      New major version of npm available! 6.14.12 → 7.10.0      │
               │   Changelog: https://github.com/npm/cli/releases/tag/v7.10.0   │
               │               Run npm install -g npm to update!                │
            mikeal created this issue in request/request
            open Request’s Past, Present and Future #3142
              @ibot
              Und?
              • I
                iobroker ist über die webobefläche nicht mehr ereichbar soll ich das npm Update durchführen?
                  Thomas Braun Most Active @Ibot last edited by Thomas Braun
                  @ibot
                  Auf gar keinen Fall!
                  Das macht es nur schlimmer.
                  npm wird nur über den Paketmanager aktualisiert, im Zuge eine Updates von nodejs.
                  iobroker status
                  iobroker list adapters
                  iobroker list instances
                  • I
                    iobroker status
                    pi@raspberrypi:/opt/iobroker $ iobroker status
                    Objects type: file
                    States  type: file
                    pi@raspberrypi:/opt/iobroker $ iobroker list adapters
                    system.adapter.admin                   : admin          - v4.2.1
                    system.adapter.discovery               : discovery      - v2.6.1
                    system.adapter.flot                    : flot           - v1.10.6
                    system.adapter.history                 : history        - v1.9.12
                    system.adapter.info                    : info           - v1.7.14
                    system.adapter.javascript              : javascript     - v5.0.14
                    system.adapter.mqtt                    : mqtt           - v2.3.5
                    system.adapter.mqtt-client             : mqtt-client    - v1.3.1
                    system.adapter.node-red                : node-red       - v2.2.0
                    system.adapter.rpi2                    : rpi2           - v1.2.0
                    system.adapter.sonoff                  : sonoff         - v2.4.0
                    system.adapter.vis                     : vis            - v1.3.4
                    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
                    system.adapter.web                     : web            - v3.3.0
                    system.adapter.yahka                   : yahka          - v0.12.0
                    pi@raspberrypi:/opt/iobroker $ iobroker list instances
                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                    + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                    + instance is alive
                      @ibot
                      Sollte eigentlich laufen. Welche Meldungen bekommst du?
                      Homoran I 2 Replies Last reply Reply Quote 0
                        sehe ich auch so!
                        @Ibot
                        hast du mal den Browsercache gelöscht?
                        • I
                          Ibot @Thomas Braun last edited by Homoran
                          Im Browser steht
                          Cannot GET /
                            @ibot sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
                            Starte den Pi mal sauber durch:
                            iobroker stop
                            sudo reboot
                            Und BrowserCache löschen, wie @Homoran schon sagte.
                            • I
                              Ibot @Homoran last edited by
                              Hallo, ja habe ich sobald ich das Backup zurückspiele ist über den Browser auch alles wieder ereichbar
                                @ibot
                                Was für ein Backup?
                                Lösch mal den npm cache
                                cd /opt/iobroker
                                npm cache clean --force
                                  Homoran Global Moderator Administrators @Ibot last edited by
                                  von Backup hat niemand was gesagt!
                                  • I
                                    ich habe mit dem Iobroker Tool vorab ein Backup erstellt. Nach dem Neustart ist Iobroker wieder ereichbar und Vis ist auch aktuell Top Npm Cache trotzdem noch löschen?
                                      @ibot
                                      Nö, wenn alles läuft lass die Finger davon.
                                      Was liefert denn jetzt ein
                                      iobroker update
                                      iobroker upgrade
                                      • I
                                        iobroker update iobroker upgrade
                                        alles schick
                                        pi@raspberrypi:~ $ iobroker update
                                        Used repository: Stable (default)
                                        hash unchanged, use cached sources
                                        update done
                                        Adapter    "admin"         : 4.2.1    , installed 4.2.1
                                        Adapter    "alarm"         : 2.0.0
                                        Adapter    "alexa2"        : 3.8.1
                                        Adapter    "alias-manager" : 1.0.0
                                        Adapter    "alpha2"        : 1.0.0
                                        Adapter    "amazon-dash"   : 1.1.0
                                        Adapter    "artnet"        : 1.2.2
                                        Adapter    "asterisk"      : 1.0.6
                                        Adapter    "asuswrt"       : 1.0.1
                                        Adapter    "b-control-em"  : 0.2.1
                                        Adapter    "backitup"      : 2.1.0
                                        Adapter    "beckhoff"      : 1.4.0
                                        Adapter    "benq"          : 0.2.4
                                        Adapter    "binance"       : 1.1.3
                                        Adapter    "ble"           : 0.12.0
                                        Adapter    "bmw"           : 1.3.3
                                        Adapter    "bosesoundtouch": 0.9.3
                                        Adapter    "botvac"        : 1.0.0
                                        Adapter    "bring"         : 1.7.7
                                        Adapter    "broadlink2"    : 2.0.3
                                        Adapter    "bsblan"        : 0.2.2
                                        Adapter    "bshb"          : 0.1.13
                                        Adapter    "bydbatt"       : 1.0.3
                                        Adapter    "chromecast"    : 2.3.1
                                        Adapter    "cloud"         : 4.0.10
                                        Adapter    "comfoair"      : 1.1.3
                                        Adapter    "contactid"     : 1.0.2
                                        Adapter    "coronavirus-statistics": 0.6.3
                                        Adapter    "countdown"     : 1.1.0
                                        Adapter    "cul"           : 1.3.4
                                        Adapter    "daikin"        : 1.3.0
                                        Adapter    "daswetter"     : 3.0.4
                                        Adapter    "deconz"        : 1.3.11
                                        Adapter    "denon"         : 1.10.4
                                        Adapter    "device-reminder": 1.0.6
                                        Adapter    "devices"       : 0.3.16
                                        Adapter    "digitalstrom"  : 2.0.5
                                        Adapter    "discovergy"    : 0.5.4
                                        Adapter    "discovery"     : 2.6.1    , installed 2.6.1
                                        Adapter    "divera247"     : 0.0.10
                                        Adapter    "doorio"        : 1.1.4
                                        Adapter    "ds18b20"       : 1.4.0
                                        Adapter    "dwd"           : 2.7.5
                                        Adapter    "easee"         : 0.1.2
                                        Adapter    "ebus"          : 2.2.4
                                        Adapter    "echarts"       : 0.4.11
                                        Adapter    "ecovacs-deebot": 1.1.1
                                        Adapter    "egigeozone"    : 0.1.2
                                        Adapter    "ekey"          : 1.1.0
                                        Adapter    "email"         : 1.0.9
                                        Adapter    "emby"          : 1.0.2
                                        Adapter    "energymanager" : 1.2.3
                                        Adapter    "enet"          : 1.0.1
                                        Adapter    "epson_ecotank_et_2750": 0.0.4
                                        Adapter    "epson_stylus_px830": 0.2.1
                                        Adapter    "exchangerates" : 0.0.14
                                        Adapter    "fahrplan"      : 1.0.5
                                        Adapter    "fakeroku"      : 0.2.1
                                        Adapter    "fb-checkpresence": 1.1.0
                                        Adapter    "feiertage"     : 1.0.17
                                        Adapter    "fhem"          : 1.5.3
                                        Adapter    "find-my-iphone": 0.2.15
                                        Adapter    "firetv"        : 1.0.0
                                        Adapter    "flot"          : 1.10.6   , installed 1.10.6
                                        Adapter    "followthesun"  : 0.3.3
                                        Adapter    "foobar2000"    : 2.0.4
                                        Adapter    "fritzbox"      : 0.2.1
                                        Adapter    "fritzdect"     : 2.1.11
                                        Adapter    "fronius"       : 1.0.5
                                        Adapter    "frontier_silicon": 0.0.10
                                        Adapter    "fuelpricemonitor": 0.2.2
                                        Adapter    "fullcalendar"  : 1.1.0
                                        Adapter    "fullybrowser"  : 2.0.8
                                        Adapter    "g-homa"        : 0.5.3
                                        Adapter    "geofency"      : 1.0.3
                                        Adapter    "go-e"          : 1.0.0
                                        Adapter    "growatt"       : 1.0.1
                                        Adapter    "gruenbeck"     : 0.0.29
                                        Adapter    "haassohn"      : 1.0.3
                                        Adapter    "habpanel"      : 0.4.3
                                        Adapter    "haier"         : 1.0.4
                                        Adapter    "ham"           : 4.0.1
                                        Adapter    "ham-wemo"      : 1.1.1
                                        Adapter    "harmony"       : 1.2.2
                                        Adapter    "heatingcontrol": 2.2.0
                                        Adapter    "heos"          : 1.7.7
                                        Adapter    "heytech"       : 1.0.0
                                        Adapter    "hid"           : 0.1.17
                                        Adapter    "history"       : 1.9.12   , installed 1.9.12
                                        Adapter    "hm-rega"       : 3.0.16
                                        Adapter    "hm-rpc"        : 1.14.35
                                        Adapter    "hmip"          : 1.9.0
                                        Adapter    "homeconnect"   : 0.0.32
                                        Adapter    "homee"         : 1.1.0
                                        Adapter    "homepilot"     : 1.0.3
                                        Adapter    "hp-ilo"        : 1.0.6
                                        Adapter    "hs100"         : 2.0.3
                                        Adapter    "hue"           : 3.5.2
                                        Adapter    "hue-extended"  : 2.0.0
                                        Adapter    "i2c"           : 1.2.0
                                        Adapter    "ical"          : 1.7.4
                                        Adapter    "icons-addictive-flavour-png": 0.1.0
                                        Adapter    "icons-fatcow-hosting": 0.1.0
                                        Adapter    "icons-icons8"  : 0.0.1
                                        Adapter    "icons-material-png": 0.1.0
                                        Adapter    "icons-material-svg": 0.1.0
                                        Adapter    "icons-mfd-png" : 1.0.2
                                        Adapter    "icons-mfd-svg" : 1.0.2
                                        Adapter    "icons-open-icon-library-png": 0.1.2
                                        Adapter    "icons-ultimate-png": 1.0.1
                                        Adapter    "influxdb"      : 1.9.4
                                        Adapter    "info"          : 1.7.14   , installed 1.7.14
                                        Adapter    "innogy-smarthome": 0.3.6
                                        Adapter    "iogo"          : 0.6.5
                                        Adapter    "iot"           : 1.8.16
                                        Adapter    "iqontrol"      : 1.6.4
                                        Adapter    "jarvis"        : 2.1.0
                                        Adapter    "javascript"    : 5.0.14   , installed 5.0.14
                                        Adapter    "jeelink"       : 0.1.0
                                        Controller "js-controller" : 3.2.16   , installed 3.2.16
                                        Adapter    "kecontact"     : 1.1.1
                                        Adapter    "klf200"        : 1.0.1
                                        Adapter    "km200"         : 1.1.6
                                        Adapter    "knmi-weather"  : 1.0.0
                                        Adapter    "knx"           : 1.0.39
                                        Adapter    "kodi"          : 2.0.5
                                        Adapter    "kostal-piko-ba": 1.1.5
                                        Adapter    "kress"         : 2.5.5
                                        Adapter    "lametric"      : 1.2.0
                                        Adapter    "landroid"      : 1.0.3
                                        Adapter    "lcn"           : 1.0.2
                                        Adapter    "legrand-ecocompteur": 1.0.0
                                        Adapter    "letrika_comgw" : 0.0.5
                                        Adapter    "lgtv"          : 1.1.10
                                        Adapter    "lgtv-rs"       : 0.1.1
                                        Adapter    "lgtv11"        : 1.0.5
                                        Adapter    "lifx"          : 0.1.0
                                        Adapter    "lightify"      : 0.2.16
                                        Adapter    "link"          : 0.5.10
                                        Adapter    "linkeddevices" : 1.4.2
                                        Adapter    "linktap"       : 0.1.8
                                        Adapter    "linux-control" : 1.1.2
                                        Adapter    "logparser"     : 1.1.0
                                        Adapter    "lovelace"      : 1.0.16
                                        Adapter    "loxone"        : 2.1.0
                                        Adapter    "luftdaten"     : 1.0.2
                                        Adapter    "lupusec"       : 1.3.4
                                        Adapter    "luxtronik1"    : 0.3.0
                                        Adapter    "material"      : 0.13.9
                                        Adapter    "maxcube"       : 1.0.2
                                        Adapter    "maxcul"        : 1.3.1
                                        Adapter    "mbus"          : 2.3.4
                                        Adapter    "mclighting"    : 0.1.2
                                        Adapter    "megad"         : 1.2.1
                                        Adapter    "megadd"        : 0.2.0
                                        Adapter    "megaesp"       : 0.1.0
                                        Adapter    "melcloud"      : 1.0.6
                                        Adapter    "mercedesme"    : 0.0.50
                                        Adapter    "mercury"       : 0.1.4
                                        Adapter    "meross"        : 1.5.1
                                        Adapter    "meteoalarm"    : 1.1.3
                                        Adapter    "midea"         : 0.0.6
                                        Adapter    "miele"         : 0.1.5
                                        Adapter    "mielecloudservice": 2.0.3
                                        Adapter    "mihome"        : 1.3.7
                                        Adapter    "mihome-lamp"   : 1.1.0
                                        Adapter    "mihome-plug"   : 0.2.1
                                        Adapter    "mihome-vacuum" : 2.1.1
                                        Adapter    "mikrotik"      : 1.0.16
                                        Adapter    "milight"       : 0.3.6
                                        Adapter    "milight-smart-light": 1.2.0
                                        Adapter    "minuvis"       : 1.4.0
                                        Adapter    "mobile"        : 1.0.1
                                        Adapter    "modbus"        : 3.2.6
                                        Adapter    "moma"          : 1.2.8
                                        Adapter    "mpd"           : 1.0.6
                                        Adapter    "mqtt"          : 2.3.5    , installed 2.3.5
                                        Adapter    "mqtt-client"   : 1.3.1
                                        Adapter    "musiccast"     : 0.1.5
                                        Adapter    "mydlink"       : 1.1.7
                                        Adapter    "mysensors"     : 2.0.1
                                        Adapter    "nanoleaf-lightpanels": 1.2.0
                                        Adapter    "net-tools"     : 0.1.2
                                        Adapter    "netatmo"       : 1.3.3
                                        Adapter    "netatmo-crawler": 0.3.9
                                        Adapter    "nibeuplink"    : 0.4.0
                                        Adapter    "nina"          : 0.0.24
                                        Adapter    "node-red"      : 2.2.0
                                        Adapter    "nuki"          : 1.4.3
                                        Adapter    "nuki-extended" : 2.3.0
                                        Adapter    "nut"           : 1.4.3
                                        Adapter    "octoprint"     : 1.0.8
                                        Adapter    "odl"           : 1.1.4
                                        Adapter    "oilfox"        : 0.0.5
                                        Adapter    "omnicomm-lls"  : 0.0.7
                                        Adapter    "onkyo"         : 2.0.3
                                        Adapter    "onvif"         : 0.4.4
                                        Adapter    "openhab"       : 1.1.0
                                        Adapter    "openligadb"    : 1.1.0
                                        Adapter    "openweathermap": 0.1.0
                                        Adapter    "opi"           : 0.1.1
                                        Adapter    "oppoplayer"    : 0.2.4
                                        Adapter    "owfs"          : 0.6.4
                                        Adapter    "owntracks"     : 1.0.0
                                        Adapter    "panasonic-viera": 1.0.2
                                        Adapter    "parser"        : 1.0.7
                                        Adapter    "paw"           : 0.0.7
                                        Adapter    "phantomjs"     : 1.1.2
                                        Adapter    "pi-hole"       : 1.3.1
                                        Adapter    "piface"        : 1.0.0
                                        Adapter    "pimatic"       : 0.3.0
                                        Adapter    "ping"          : 1.4.12
                                        Adapter    "places"        : 1.0.0
                                        Adapter    "plenticore"    : 2.1.6
                                        Adapter    "plex"          : 0.8.11
                                        Adapter    "plexconnect"   : 0.0.7
                                        Adapter    "pollenflug"    : 1.0.6
                                        Adapter    "proxmox"       : 1.2.0
                                        Adapter    "proxy"         : 1.2.2
                                        Adapter    "pushbullet"    : 0.0.11
                                        Adapter    "pushover"      : 2.0.3
                                        Adapter    "pushsafer"     : 1.0.3
                                        Adapter    "radar2"        : 1.0.9
                                        Adapter    "radiohead"     : 1.1.1
                                        Adapter    "rflink"        : 2.1.6
                                        Adapter    "rickshaw"      : 1.0.0
                                        Adapter    "ring"          : 1.1.3
                                        Adapter    "robonect"      : 0.1.3
                                        Adapter    "roomba"        : 1.1.1
                                        Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
                                        Adapter    "s7"            : 1.2.4
                                        Adapter    "sainlogic"     : 0.6.6
                                        Adapter    "samsung"       : 0.2.9
                                        Adapter    "sanext"        : 0.0.5
                                        Adapter    "sayit"         : 1.12.2
                                        Adapter    "sbfspot"       : 4.0.4
                                        Adapter    "scenes"        : 2.3.6
                                        Adapter    "schoolfree"    : 0.7.0
                                        Adapter    "schwoerer-ventcube": 1.3.0
                                        Adapter    "seq"           : 0.2.10
                                        Adapter    "shelly"        : 4.0.7
                                        Adapter    "shuttercontrol": 1.1.5
                                        Adapter    "sia"           : 1.0.4
                                        Adapter    "siegenia"      : 1.1.0
                                        Adapter    "simple-api"    : 2.5.3    , installed 2.5.3
                                        Adapter    "smappee"       : 0.2.4
                                        Adapter    "smartcontrol"  : 1.2.1
                                        Adapter    "smartgarden"   : 1.0.4
                                        Adapter    "smartmeter"    : 3.2.0
                                        Adapter    "snips"         : 1.5.1
                                        Adapter    "snmp"          : 0.5.0
                                        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                                        Adapter    "solarlog"      : 2.0.2
                                        Adapter    "solarviewdatareader": 0.2.1
                                        Adapter    "solarwetter"   : 1.0.0
                                        Adapter    "sonnen"        : 1.7.1
                                        Adapter    "sonoff"        : 2.4.0    , installed 2.4.0
                                        Adapter    "sonos"         : 2.1.1
                                        Adapter    "sony-bravia"   : 1.0.1
                                        Adapter    "spotify-premium": 1.0.0
                                        Adapter    "sql"           : 1.15.5
                                        Adapter    "squeezebox"    : 1.0.0
                                        Adapter    "squeezeboxrpc" : 1.3.4
                                        Adapter    "starline"      : 1.1.3
                                        Adapter    "statistics"    : 1.0.2
                                        Adapter    "stiebel-isg"   : 1.6.0
                                        Adapter    "sunnyportal"   : 0.1.5
                                        Adapter    "swiss-weather-api": 0.3.2
                                        Adapter    "synology"      : 0.1.20
                                        Adapter    "systeminfo"    : 0.3.1
                                        Adapter    "tahoma"        : 0.3.2
                                        Adapter    "tankerkoenig"  : 2.0.5
                                        Adapter    "telegram"      : 1.8.0
                                        Adapter    "terminal"      : 0.1.2
                                        Adapter    "tesla-motors"  : 0.4.2
                                        Adapter    "text2command"  : 2.0.7
                                        Adapter    "tinker"        : 1.1.0
                                        Adapter    "tr-064"        : 4.2.11
                                        Adapter    "traccar"       : 0.0.7
                                        Adapter    "tradfri"       : 2.7.1
                                        Adapter    "trashschedule" : 1.1.1
                                        Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                        Adapter    "tuya"          : 3.5.9
                                        Adapter    "tvprogram"     : 1.0.0
                                        Adapter    "tvspielfilm"   : 1.0.4
                                        Adapter    "unifi"         : 0.5.8
                                        Adapter    "upnp"          : 1.0.17
                                        Adapter    "vaillant"      : 0.0.11
                                        Adapter    "valloxmv"      : 1.1.2
                                        Adapter    "vcard"         : 0.0.9
                                        Adapter    "velux"         : 0.0.7
                                        Adapter    "viessmann"     : 1.3.3
                                        Adapter    "virtualpowermeter": 1.4.2
                                        Adapter    "vis"           : 1.3.8    , installed 1.3.8
                                        Adapter    "vis-bars"      : 0.1.4
                                        Adapter    "vis-canvas-gauges": 0.1.5
                                        Adapter    "vis-colorpicker": 1.2.0
                                        Adapter    "vis-fancyswitch": 1.1.0
                                        Adapter    "vis-google-fonts": 0.1.0
                                        Adapter    "vis-history"   : 1.0.0
                                        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                                        Adapter    "vis-icontwo"   : 0.60.0
                                        Adapter    "vis-inventwo"  : 2.8.3
                                        Adapter    "vis-jqui-mfd"  : 1.0.12
                                        Adapter    "vis-justgage"  : 1.0.2
                                        Adapter    "vis-keyboard"  : 0.0.2
                                        Adapter    "vis-lcars"     : 1.0.4
                                        Adapter    "vis-map"       : 1.0.4
                                        Adapter    "vis-material-advanced": 1.6.0
                                        Adapter    "vis-metro"     : 1.1.2
                                        Adapter    "vis-players"   : 0.1.6
                                        Adapter    "vis-plumb"     : 1.0.2
                                        Adapter    "vis-rgraph"    : 0.0.2
                                        Adapter    "vis-timeandweather": 1.1.7
                                        Adapter    "vis-weather"   : 2.5.2
                                        Adapter    "volumio"       : 0.1.2
                                        Adapter    "volvo"         : 0.0.3
                                        Adapter    "vr200"         : 1.0.0
                                        Adapter    "vw-connect"    : 0.0.30
                                        Adapter    "weatherunderground": 3.3.0
                                        Adapter    "web"           : 3.3.0    , installed 3.3.0
                                        Adapter    "weishaupt-wem" : 0.0.9
                                        Adapter    "whatsapp-cmb"  : 0.1.6
                                        Adapter    "wiffi-wz"      : 2.2.0
                                        Adapter    "wifilight"     : 1.1.0
                                        Adapter    "windows-control": 0.1.5
                                        Adapter    "wled"          : 0.5.6
                                        Adapter    "wm-bus"        : 0.1.12
                                        Adapter    "wolf"          : 1.2.1
                                        Adapter    "worx"          : 1.3.0
                                        Adapter    "xbox"          : 0.7.7
                                        Adapter    "xs1"           : 1.0.2
                                        Adapter    "yahka"         : 0.12.0   , installed 0.12.0
                                        Adapter    "yamaha"        : 0.4.0
                                        Adapter    "yeelight-2"    : 1.0.3
                                        Adapter    "youtube"       : 1.0.3
                                        Adapter    "yr"            : 2.0.3
                                        Adapter    "zigbee"        : 1.4.4
                                        Adapter    "zont"          : 0.5.3
                                        Adapter    "zwave2"        : 1.8.11
                                        pi@raspberrypi:~ $ iobroker upgrade
                                        Adapter "admin"          is up to date.
                                        Adapter "alarm"          is not installed.
                                        Adapter "alexa2"         is not installed.
                                        Adapter "alias-manager"  is not installed.
                                        Adapter "alpha2"         is not installed.
                                        Adapter "amazon-dash"    is not installed.
                                        Adapter "artnet"         is not installed.
                                        Adapter "asterisk"       is not installed.
                                        Adapter "asuswrt"        is not installed.
                                        Adapter "b-control-em"   is not installed.
                                        Adapter "backitup"       is not installed.
                                        Adapter "beckhoff"       is not installed.
                                        Adapter "benq"           is not installed.
                                        Adapter "binance"        is not installed.
                                        Adapter "ble"            is not installed.
                                        Adapter "bmw"            is not installed.
                                        Adapter "bosesoundtouch" is not installed.
                                        Adapter "botvac"         is not installed.
                                        Adapter "bring"          is not installed.
                                        Adapter "broadlink2"     is not installed.
                                        Adapter "bsblan"         is not installed.
                                        Adapter "bshb"           is not installed.
                                        Adapter "bydbatt"        is not installed.
                                        Adapter "chromecast"     is not installed.
                                        Adapter "cloud"          is not installed.
                                        Adapter "comfoair"       is not installed.
                                        Adapter "contactid"      is not installed.
                                        Adapter "coronavirus-statistics" is not installed.
                                        Adapter "countdown"      is not installed.
                                        Adapter "cul"            is not installed.
                                        Adapter "daikin"         is not installed.
                                        Adapter "daswetter"      is not installed.
                                        Adapter "deconz"         is not installed.
                                        Adapter "denon"          is not installed.
                                        Adapter "device-reminder" is not installed.
                                        Adapter "devices"        is not installed.
                                        Adapter "digitalstrom"   is not installed.
                                        Adapter "discovergy"     is not installed.
                                        Adapter "discovery"      is up to date.
                                        Adapter "divera247"      is not installed.
                                        Adapter "doorio"         is not installed.
                                        Adapter "ds18b20"        is not installed.
                                        Adapter "dwd"            is not installed.
                                        Adapter "easee"          is not installed.
                                        Adapter "ebus"           is not installed.
                                        Adapter "echarts"        is not installed.
                                        Adapter "ecovacs-deebot" is not installed.
                                        Adapter "egigeozone"     is not installed.
                                        Adapter "ekey"           is not installed.
                                        Adapter "email"          is not installed.
                                        Adapter "emby"           is not installed.
                                        Adapter "energymanager"  is not installed.
                                        Adapter "enet"           is not installed.
                                        Adapter "epson_ecotank_et_2750" is not installed.
                                        Adapter "epson_stylus_px830" is not installed.
                                        Adapter "exchangerates"  is not installed.
                                        Adapter "fahrplan"       is not installed.
                                        Adapter "fakeroku"       is not installed.
                                        Adapter "fb-checkpresence" is not installed.
                                        Adapter "feiertage"      is not installed.
                                        Adapter "fhem"           is not installed.
                                        Adapter "find-my-iphone" is not installed.
                                        Adapter "firetv"         is not installed.
                                        Adapter "flot"           is up to date.
                                        Adapter "followthesun"   is not installed.
                                        Adapter "foobar2000"     is not installed.
                                        Adapter "fritzbox"       is not installed.
                                        Adapter "fritzdect"      is not installed.
                                        Adapter "fronius"        is not installed.
                                        Adapter "frontier_silicon" is not installed.
                                        Adapter "fuelpricemonitor" is not installed.
                                        Adapter "fullcalendar"   is not installed.
                                        Adapter "fullybrowser"   is not installed.
                                        Adapter "g-homa"         is not installed.
                                        Adapter "geofency"       is not installed.
                                        Adapter "go-e"           is not installed.
                                        Adapter "growatt"        is not installed.
                                        Adapter "gruenbeck"      is not installed.
                                        Adapter "haassohn"       is not installed.
                                        Adapter "habpanel"       is not installed.
                                        Adapter "haier"          is not installed.
                                        Adapter "ham"            is not installed.
                                        Adapter "ham-wemo"       is not installed.
                                        Adapter "harmony"        is not installed.
                                        Adapter "heatingcontrol" is not installed.
                                        Adapter "heos"           is not installed.
                                        Adapter "heytech"        is not installed.
                                        Adapter "hid"            is not installed.
                                        Adapter "history"        is up to date.
                                        Adapter "hm-rega"        is not installed.
                                        Adapter "hm-rpc"         is not installed.
                                        Adapter "hmip"           is not installed.
                                        Adapter "homeconnect"    is not installed.
                                        Adapter "homee"          is not installed.
                                        Adapter "homepilot"      is not installed.
                                        Adapter "hp-ilo"         is not installed.
                                        Adapter "hs100"          is not installed.
                                        Adapter "hue"            is not installed.
                                        Adapter "hue-extended"   is not installed.
                                        Adapter "i2c"            is not installed.
                                        Adapter "ical"           is not installed.
                                        Adapter "icons-addictive-flavour-png" is not installed.
                                        Adapter "icons-fatcow-hosting" is not installed.
                                        Adapter "icons-icons8"   is not installed.
                                        Adapter "icons-material-png" is not installed.
                                        Adapter "icons-material-svg" is not installed.
                                        Adapter "icons-mfd-png"  is not installed.
                                        Adapter "icons-mfd-svg"  is not installed.
                                        Adapter "icons-open-icon-library-png" is not installed.
                                        Adapter "icons-ultimate-png" is not installed.
                                        Adapter "influxdb"       is not installed.
                                        Adapter "info"           is up to date.
                                        Adapter "innogy-smarthome" is not installed.
                                        Adapter "iogo"           is not installed.
                                        Adapter "iot"            is not installed.
                                        Adapter "iqontrol"       is not installed.
                                        Adapter "jarvis"         is not installed.
                                        Adapter "javascript"     is up to date.
                                        Adapter "jeelink"        is not installed.
                                        Adapter "kecontact"      is not installed.
                                        Adapter "klf200"         is not installed.
                                        Adapter "km200"          is not installed.
                                        Adapter "knmi-weather"   is not installed.
                                        Adapter "knx"            is not installed.
                                        Adapter "kodi"           is not installed.
                                        Adapter "kostal-piko-ba" is not installed.
                                        Adapter "kress"          is not installed.
                                        Adapter "lametric"       is not installed.
                                        Adapter "landroid"       is not installed.
                                        Adapter "lcn"            is not installed.
                                        Adapter "legrand-ecocompteur" is not installed.
                                        Adapter "letrika_comgw"  is not installed.
                                        Adapter "lgtv"           is not installed.
                                        Adapter "lgtv-rs"        is not installed.
                                        Adapter "lgtv11"         is not installed.
                                        Adapter "lifx"           is not installed.
                                        Adapter "lightify"       is not installed.
                                        Adapter "link"           is not installed.
                                        Adapter "linkeddevices"  is not installed.
                                        Adapter "linktap"        is not installed.
                                        Adapter "linux-control"  is not installed.
                                        Adapter "logparser"      is not installed.
                                        Adapter "lovelace"       is not installed.
                                        Adapter "loxone"         is not installed.
                                        Adapter "luftdaten"      is not installed.
                                        Adapter "lupusec"        is not installed.
                                        Adapter "luxtronik1"     is not installed.
                                        Adapter "material"       is not installed.
                                        Adapter "maxcube"        is not installed.
                                        Adapter "maxcul"         is not installed.
                                        Adapter "mbus"           is not installed.
                                        Adapter "mclighting"     is not installed.
                                        Adapter "megad"          is not installed.
                                        Adapter "megadd"         is not installed.
                                        Adapter "megaesp"        is not installed.
                                        Adapter "melcloud"       is not installed.
                                        Adapter "mercedesme"     is not installed.
                                        Adapter "mercury"        is not installed.
                                        Adapter "meross"         is not installed.
                                        Adapter "meteoalarm"     is not installed.
                                        Adapter "midea"          is not installed.
                                        Adapter "miele"          is not installed.
                                        Adapter "mielecloudservice" is not installed.
                                        Adapter "mihome"         is not installed.
                                        Adapter "mihome-lamp"    is not installed.
                                        Adapter "mihome-plug"    is not installed.
                                        Adapter "mihome-vacuum"  is not installed.
                                        Adapter "mikrotik"       is not installed.
                                        Adapter "milight"        is not installed.
                                        Adapter "milight-smart-light" is not installed.
                                        Adapter "minuvis"        is not installed.
                                        Adapter "mobile"         is not installed.
                                        Adapter "modbus"         is not installed.
                                        Adapter "moma"           is not installed.
                                        Adapter "mpd"            is not installed.
                                        Adapter "mqtt"           is up to date.
                                        Adapter "mqtt-client"    is not installed.
                                        Adapter "musiccast"      is not installed.
                                        Adapter "mydlink"        is not installed.
                                        Adapter "mysensors"      is not installed.
                                        Adapter "nanoleaf-lightpanels" is not installed.
                                        Adapter "net-tools"      is not installed.
                                        Adapter "netatmo"        is not installed.
                                        Adapter "netatmo-crawler" is not installed.
                                        Adapter "nibeuplink"     is not installed.
                                        Adapter "nina"           is not installed.
                                        Adapter "node-red"       is not installed.
                                        Adapter "nuki"           is not installed.
                                        Adapter "nuki-extended"  is not installed.
                                        Adapter "nut"            is not installed.
                                        Adapter "octoprint"      is not installed.
                                        Adapter "odl"            is not installed.
                                        Adapter "oilfox"         is not installed.
                                        Adapter "omnicomm-lls"   is not installed.
                                        Adapter "onkyo"          is not installed.
                                        Adapter "onvif"          is not installed.
                                        Adapter "openhab"        is not installed.
                                        Adapter "openligadb"     is not installed.
                                        Adapter "openweathermap" is not installed.
                                        Adapter "opi"            is not installed.
                                        Adapter "oppoplayer"     is not installed.
                                        Adapter "owfs"           is not installed.
                                        Adapter "owntracks"      is not installed.
                                        Adapter "panasonic-viera" is not installed.
                                        Adapter "parser"         is not installed.
                                        Adapter "paw"            is not installed.
                                        Adapter "phantomjs"      is not installed.
                                        Adapter "pi-hole"        is not installed.
                                        Adapter "piface"         is not installed.
                                        Adapter "pimatic"        is not installed.
                                        Adapter "ping"           is not installed.
                                        Adapter "places"         is not installed.
                                        Adapter "plenticore"     is not installed.
                                        Adapter "plex"           is not installed.
                                        Adapter "plexconnect"    is not installed.
                                        Adapter "pollenflug"     is not installed.
                                        Adapter "proxmox"        is not installed.
                                        Adapter "proxy"          is not installed.
                                        Adapter "pushbullet"     is not installed.
                                        Adapter "pushover"       is not installed.
                                        Adapter "pushsafer"      is not installed.
                                        Adapter "radar2"         is not installed.
                                        Adapter "radiohead"      is not installed.
                                        Adapter "rflink"         is not installed.
                                        Adapter "rickshaw"       is not installed.
                                        Adapter "ring"           is not installed.
                                        Adapter "robonect"       is not installed.
                                        Adapter "roomba"         is not installed.
                                        Adapter "rpi2"           is up to date.
                                        Adapter "s7"             is not installed.
                                        Adapter "sainlogic"      is not installed.
                                        Adapter "samsung"        is not installed.
                                        Adapter "sanext"         is not installed.
                                        Adapter "sayit"          is not installed.
                                        Adapter "sbfspot"        is not installed.
                                        Adapter "scenes"         is not installed.
                                        Adapter "schoolfree"     is not installed.
                                        Adapter "schwoerer-ventcube" is not installed.
                                        Adapter "seq"            is not installed.
                                        Adapter "shelly"         is not installed.
                                        Adapter "shuttercontrol" is not installed.
                                        Adapter "sia"            is not installed.
                                        Adapter "siegenia"       is not installed.
                                        Adapter "simple-api"     is up to date.
                                        Adapter "smappee"        is not installed.
                                        Adapter "smartcontrol"   is not installed.
                                        Adapter "smartgarden"    is not installed.
                                        Adapter "smartmeter"     is not installed.
                                        Adapter "snips"          is not installed.
                                        Adapter "snmp"           is not installed.
                                        Adapter "socketio"       is up to date.
                                        Adapter "solarlog"       is not installed.
                                        Adapter "solarviewdatareader" is not installed.
                                        Adapter "solarwetter"    is not installed.
                                        Adapter "sonnen"         is not installed.
                                        Adapter "sonoff"         is up to date.
                                        Adapter "sonos"          is not installed.
                                        Adapter "sony-bravia"    is not installed.
                                        Adapter "spotify-premium" is not installed.
                                        Adapter "sql"            is not installed.
                                        Adapter "squeezebox"     is not installed.
                                        Adapter "squeezeboxrpc"  is not installed.
                                        Adapter "starline"       is not installed.
                                        Adapter "statistics"     is not installed.
                                        Adapter "stiebel-isg"    is not installed.
                                        Adapter "sunnyportal"    is not installed.
                                        Adapter "swiss-weather-api" is not installed.
                                        Adapter "synology"       is not installed.
                                        Adapter "systeminfo"     is not installed.
                                        Adapter "tahoma"         is not installed.
                                        Adapter "tankerkoenig"   is not installed.
                                        Adapter "telegram"       is not installed.
                                        Adapter "terminal"       is not installed.
                                        Adapter "tesla-motors"   is not installed.
                                        Adapter "text2command"   is not installed.
                                        Adapter "tinker"         is not installed.
                                        Adapter "tr-064"         is not installed.
                                        Adapter "traccar"        is not installed.
                                        Adapter "tradfri"        is not installed.
                                        Adapter "trashschedule"  is not installed.
                                        Adapter "tunnelbroker-endpoint-updater" is not installed.
                                        Adapter "tuya"           is not installed.
                                        Adapter "tvprogram"      is not installed.
                                        Adapter "tvspielfilm"    is not installed.
                                        Adapter "unifi"          is not installed.
                                        Adapter "upnp"           is not installed.
                                        Adapter "vaillant"       is not installed.
                                        Adapter "valloxmv"       is not installed.
                                        Adapter "vcard"          is not installed.
                                        Adapter "velux"          is not installed.
                                        Adapter "viessmann"      is not installed.
                                        Adapter "virtualpowermeter" is not installed.
                                        Adapter "vis"            is up to date.
                                        Adapter "vis-bars"       is not installed.
                                        Adapter "vis-canvas-gauges" is not installed.
                                        Adapter "vis-colorpicker" is not installed.
                                        Adapter "vis-fancyswitch" is not installed.
                                        Adapter "vis-google-fonts" is not installed.
                                        Adapter "vis-history"    is not installed.
                                        Adapter "vis-hqwidgets"  is up to date.
                                        Adapter "vis-icontwo"    is not installed.
                                        Adapter "vis-inventwo"   is not installed.
                                        Adapter "vis-jqui-mfd"   is not installed.
                                        Adapter "vis-justgage"   is not installed.
                                        Adapter "vis-keyboard"   is not installed.
                                        Adapter "vis-lcars"      is not installed.
                                        Adapter "vis-map"        is not installed.
                                        Adapter "vis-material-advanced" is not installed.
                                        Adapter "vis-metro"      is not installed.
                                        Adapter "vis-players"    is not installed.
                                        Adapter "vis-plumb"      is not installed.
                                        Adapter "vis-rgraph"     is not installed.
                                        Adapter "vis-timeandweather" is not installed.
                                        Adapter "vis-weather"    is not installed.
                                        Adapter "volumio"        is not installed.
                                        Adapter "volvo"          is not installed.
                                        Adapter "vr200"          is not installed.
                                        Adapter "vw-connect"     is not installed.
                                        Adapter "weatherunderground" is not installed.
                                        Adapter "web"            is up to date.
                                        Adapter "weishaupt-wem"  is not installed.
                                        Adapter "whatsapp-cmb"   is not installed.
                                        Adapter "wiffi-wz"       is not installed.
                                        Adapter "wifilight"      is not installed.
                                        Adapter "windows-control" is not installed.
                                        Adapter "wled"           is not installed.
                                        Adapter "wm-bus"         is not installed.
                                        Adapter "wolf"           is not installed.
                                        Adapter "worx"           is not installed.
                                        Adapter "xbox"           is not installed.
                                        Adapter "xs1"            is not installed.
                                        Adapter "yahka"          is up to date.
                                        Adapter "yamaha"         is not installed.
                                        Adapter "yeelight-2"     is not installed.
                                        Adapter "youtube"        is not installed.
                                        Adapter "yr"             is not installed.
                                        Adapter "zigbee"         is not installed.
                                        Adapter "zont"           is not installed.
                                        Adapter "zwave2"         is not installed.
                                          @ibot
                                          Gut.
                                          • I
                                            Besten Dank!
                                            vis update
                                            734
