    4. Test Adapter fb-checkpresence v1.1.x
    • afuerhoff
      afuerhoff Developer @Wild Kaban last edited by
      @wild-kaban
      Kannst Du mal das Log im Loglevel debug posten. Vom Start des Adapters bis zum Fehler.
      • afuerhoff
        afuerhoff Developer last edited by
        @wild-kaban
        Hallo, ich habe noch ein Update auf Github hochgeladen. Bitte testen.
        Negalein W 2 Replies Last reply Reply Quote 1
        • Negalein
          Negalein Global Moderator @afuerhoff last edited by
          @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
          Adapter geht mit der neuen Version gleich auf Pause
          fb-checkpresence.0	2021-04-18 02:57:00.978	info	(6038) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          fb-checkpresence.0	2021-04-18 02:57:00.976	info	(6038) terminating
          fb-checkpresence.0	2021-04-18 02:57:00.474	info	(6038) cleaned everything up ...
          fb-checkpresence.0	2021-04-18 02:57:00.471	info	(6038) Got terminate signal TERMINATE_YOURSELF
          fb-checkpresence.0	2021-04-18 02:57:00.383	warn	(6038) onReady: Fb init: getSSLPort: DeviceInfo:1 GetSecurityPort timeout of 6000ms exceeded
          fb-checkpresence.0	2021-04-18 02:56:54.318	info	(6038) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.18.3, js-controller: 3.1.6
          fb-checkpresence.0	2021-04-18 02:56:52.336	debug	(6038) statesDB connected
          fb-checkpresence.0	2021-04-18 02:56:52.330	debug	(6038) States connected to redis: 0.0.0.0:9000
          fb-checkpresence.0	2021-04-18 02:56:52.231	debug	(6038) States create System PubSub Client
          fb-checkpresence.0	2021-04-18 02:56:52.228	debug	(6038) States create User PubSub Client
          fb-checkpresence.0	2021-04-18 02:56:52.183	debug	(6038) Redis States: Use Redis connection: 0.0.0.0:9000
          fb-checkpresence.0	2021-04-18 02:56:52.177	debug	(6038) objectDB connected
          fb-checkpresence.0	2021-04-18 02:56:52.164	debug	(6038) Objects connected to redis: 0.0.0.0:9001
          fb-checkpresence.0	2021-04-18 02:56:52.076	debug	(6038) Objects client initialize lua scripts
          fb-checkpresence.0	2021-04-18 02:56:52.075	debug	(6038) Objects create User PubSub Client
          fb-checkpresence.0	2021-04-18 02:56:52.074	debug	(6038) Objects create System PubSub Client
          fb-checkpresence.0	2021-04-18 02:56:52.043	debug	(6038) Objects client ready ... initialize now
          fb-checkpresence.0	2021-04-18 02:56:51.979	debug	(6038) Redis Objects: Use Redis connection: 0.0.0.0:9001
          afuerhoff 1 Reply Last reply Reply Quote 0
          • afuerhoff
            afuerhoff Developer @Negalein last edited by
            @negalein
            In der Initialisierung hat er keine Verbindung zur Fritzbox aufbauen können. Daher der Adapter-Stop. Hat aber nichts mit der Änderung zu tun. Da scheint ein Zugriffsproblem zur Fritzbox zu bestehen.
            • Negalein
              an der FB wurde nichts verändert.
              • afuerhoff
                @negalein
                Versuch mal einen Reboot der Fritzbox.
                Die sperrt schon mal den Zugriff über das tr-064 Protokoll.
                • Negalein
                  Merci
                  Das wars! 🙂
                  Btw., muss ich da was machen?
                  fb-checkpresence.0	2021-04-18 14:43:23.390	warn	(11400) The state "fb-checkpresence.0.Handy-Nega" will not longer exist in a future version. Please use "fb-checkpresence.0.Handy-Nega.presence" instead!
                  • afuerhoff
                    @negalein
                    Den Datenpunkt fb-checkpresence.0.Handy-Nega wird es in einer zukünftigen Version nicht mehr geben.
                    Wenn du auf Kompatibilität = false stellst, werden die Datenpunkte so wie in einer zukünftigen Version angelegt. Die alten Datenpunkte musst du dann allerdings manuell noch löschen.
                    Du solltest dann bei Gelegenheit auf diesen Datenpunkt umstellen -> Kompatibiltität = true: fb-checkpresence.0.Handy-Nega.presence oder Kompatibiltität = false: fb-checkpresence.0.familyMembers.Handy-Nega.presence.
                    Ich hoffe, ich hab mich einigermaßen verständlich ausgedrückt.
                    • Negalein
                      Ja 🙂
                      Hab aber das nächste Problem.
                      Ich hab die Ordnerstruktur gelöscht, damit sie vom Adapter neu erstellt wird.
                      Neu einlesen hab ich aktiviert.
                      Mir wird aber jetzt kein Device, Blacklist und Whitelist angelegt, bzw ist ziemlich leer.
                      Das kommt im Log beim Start.
                      fb-checkpresence.0	2021-04-18 15:24:39.517	warn	(4781) getExtIp:
                      fb-checkpresence.0	2021-04-18 15:24:25.499	warn	(4781) getActive Handy-Nega: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                      fb-checkpresence.0	2021-04-18 15:24:19.494	warn	(4781) getActive Handy-Lisi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                      fb-checkpresence.0	2021-04-18 15:24:13.489	warn	(4781) getActive Handy-Mausi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                      fb-checkpresence.0	2021-04-18 15:23:56.977	warn	(4781) Layer3Forwarding1-GetDefaultConnectionService is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.976	warn	(4781) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.975	warn	(4781) WANPPPConnection1-ForceTermination is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.975	warn	(4781) DeviceConfig1-Reboot is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.974	warn	(4781) X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.973	warn	(4781) X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.973	warn	(4781) DeviceInfo1-GetInfo is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.972	warn	(4781) WLANConfiguration3-GetSecurityKeys is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.972	warn	(4781) WLANConfiguration3-GetInfo is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.971	warn	(4781) WLANConfiguration3-SetEnable is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.970	warn	(4781) WANIPConnection1-GetInfo is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.970	warn	(4781) WANPPPConnection1-GetInfo is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.969	warn	(4781) WANCommonInterfaceConfig1-GetCommonLinkProperties is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.968	warn	(4781) Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.967	warn	(4781) Hosts1-X_AVM-DE_GetMeshListPath is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:56.966	warn	(4781) Hosts1-X_AVM-DE_GetHostListPath is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:28.356	warn	(3425) getActive Handy-Nega: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                      fb-checkpresence.0	2021-04-18 15:23:22.349	warn	(3425) getActive Handy-Lisi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                      fb-checkpresence.0	2021-04-18 15:23:16.344	warn	(3425) getActive Handy-Mausi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                      fb-checkpresence.0	2021-04-18 15:23:01.587	warn	(3425) Layer3Forwarding1-GetDefaultConnectionService is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:01.587	warn	(3425) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:01.586	warn	(3425) WANPPPConnection1-ForceTermination is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:01.586	warn	(3425) DeviceConfig1-Reboot is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:01.585	warn	(3425) X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:01.585	warn	(3425) X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:01.584	warn	(3425) DeviceInfo1-GetInfo is not supported! Feature is deactivated!
                      fb-checkpresence.0	2021-04-18 15:23:01.584	warn	(3425) WLANConfiguration3-GetSecurityKeys is not supported! Feature is deactivated!
                      • afuerhoff
                        @Negalein
                        Scheint schon wieder keine Verbindung zur Fritzbox zu bestehen.
                        • Negalein
                          jetzt läufts.
                          Warum auch immer, hat er immer nach dem speichern als Benutzername admin stehen gehabt.
                          Ich hab definitiv den richtigen reingeschrieben.
                          Jetzt nach 3maliger Prozedur läufts! 🙂
                          • afuerhoff
                            @Negalein
                            Das Problem gab es schon mal. Liegt am Browser und der Autofill Funktion. Problem
                            ist bloß, dass die Fritzbox ziemlich schnell den Zugang dicht macht, wenn die Login Daten nicht stimmen. Dann hilft immer nur ein Reboot.
                            sigi234 Negalein 2 Replies Last reply Reply Quote 0
                              sigi234 Forum Testing Most Active @afuerhoff last edited by
                              Jupp, Autofill habe ich deaktiviert.
                              • Negalein
                                die ist schon ewig deaktiviert.
                                  Wild Kaban @afuerhoff last edited by
                                  @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                                  @wild-kaban
                                  Danke ...sieht gut aus.
                                  Hab viele Meldungen "The state "fb-checkpresence.0.XXXX" will not longer exist in a future version. "
                                  Kann ich einfach den gesamten Datenbaum löschen um das weg zu bekommen ?
                                  • afuerhoff
                                    @wild-kaban
                                    Hallo, bitte hier nachlesen:
                                    https://forum.iobroker.net/topic/37959/test-adapter-fb-checkpresence-v1-1-x/509?_=1618851749435
                                    • afuerhoff
                                      ich habe noch ein Update hochgeladen. Die Filterung habe ich noch optimiert.
                                      • SBorg
                                        SBorg Forum Testing Most Active @afuerhoff last edited by
                                        @afuerhoff Ich habe gesehen, dass du auch den Admin 5.x testest. Wahrscheinlich weißt du es bereits, aber Ergebnis bei "react UI" und dunklem Thema (weißer Adler auf weißem Grund...) :
                                        TG70 afuerhoff 2 Replies Last reply Reply Quote 0
                                        • TG70
                                          TG70 Forum Testing @SBorg last edited by
                                          Hallo hat jemand einen Tipp für mich was das im Log bedeutet?
                                          fb-checkpresence.0	2021-04-21 13:11:02.377	error   (7269) getAllFbObjectsNew {}
                                          fb-checkpresence.0	2021-04-21 13:11:02.341	error	(7269) getDeviceList: "Can not read hostlist path"
                                          fb-checkpresence.0	2021-04-21 13:11:02.341	error	(7269) soapAction X_AVM-DE_GetHostListPath status=null errNo=0
                                          • afuerhoff
                                            afuerhoff Developer @SBorg last edited by
                                            @sborg sagte in Test Adapter fb-checkpresence v1.1.x:
                                            Ist bekannt und ein Issue habe ich im Admin erstellt.
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            257936
