    4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
      stefande @Dutchman last edited by
      @Dutchman sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
      @stefande
      https://github.com/iobroker-community-adapters/ioBroker.wled/issues/110
      • Dutchman
        Dutchman Developer Most Active Administrators @stefande last edited by
        S 1 Reply Last reply Reply Quote 2
          Danke für die neue Version.
          Beim Start des Adapters bekomme ich bei jedem Controler folgende Meldungen:
          2021-01-03 14:43:07.752 - info: wled.0 (633) Try to contact : "Wohnzimmer Schrank" on IP : 192.168.0.193
          2021-01-03 14:43:08.984 - warn: wled.0 (633) Object 84f3ebe33356._info.fs.pmt is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file, json
          2021-01-03 14:43:08.985 - warn: wled.0 (633) This object will not be created in future versions. Please report this to the developer.
          2021-01-03 14:43:09.721 - warn: wled.0 (633) Object 84f3ebe33356.ccnf.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file, json
          2021-01-03 14:43:09.722 - warn: wled.0 (633) This object will not be created in future versions. Please report this to the developer.
          2021-01-03 14:43:11.313 - warn: wled.0 (633) Object 84f3ebe33356.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file, json
          2021-01-03 14:43:11.313 - warn: wled.0 (633) This object will not be created in future versions. Please report this to the developer.
          2021-01-03 14:43:11.365 - info: wled.0 (633) Device : "Wohnzimmer Schrank" Successfully connected on IP : 192.168.0.193
          Mit dem Type "number" kamen die Meldungen nicht.
          • Dutchman
            @stefande sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
            https://github.com/iobroker-community-adapters/ioBroker.wled/commit/43e69f55f5dab08a06d583b94ec33e67424795e1#diff-828e47c76a488b9e5fea71cb46b50205279fa84aa5bc7a6c844d7b9330736fbb
            0 committed to iobroker-community-adapters/ioBroker.wled
            chore: release v0.5.6
            Bugfix : State type definition for time and pmt
              Geht doch! 😊
                crunchip Forum Testing Most Active last edited by crunchip
                @Dutchman
                ich hab seit paar Tagen das Problem mit Wled, lässt sich nichts mehr steuern.
                hatte v.0.5.6 und bin grad mal testweise zurück auf v0.5.5, jedoch mit dem selben Ergebnis
                2021-04-12 21:42:40.631 - info: host.IoBroker iobroker upgrade wled@0.5.5
                2021-04-12 21:42:43.083 - info: host.IoBroker iobroker Update wled from @0.5.6 to @0.5.5
                2021-04-12 21:42:43.860 - info: host.IoBroker iobroker NPM version: 6.14.11npm install iobroker.wled@0.5.5 --loglevel error --prefix "/opt/iobroker" (System call)
                2021-04-12 21:43:54.347 - info: host.IoBroker iobroker upload [6] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/words.js words.js application/javascript
                2021-04-12 21:43:54.608 - info: host.IoBroker iobroker Update "system.adapter.wled.0"
                2021-04-12 21:43:54.642 - info: host.IoBroker stopInstance system.adapter.wled.0 (force=false, process=true)
                2021-04-12 21:43:54.691 - info: host.IoBroker stopInstance system.adapter.wled.0 send kill signal
                2021-04-12 21:43:54.773 - info: host.IoBroker iobroker upload [5] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/wled_large.png wled_large.png image/png
                2021-04-12 21:43:54.891 - info: host.IoBroker iobroker upload [4] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/wled.png wled.png image/png
                2021-04-12 21:43:54.992 - info: host.IoBroker iobroker upload [3] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/style.css style.css text/css
                2021-04-12 21:43:55.276 - info: host.IoBroker iobroker upload [2] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/index_m.html index_m.html text/html
                2021-04-12 21:43:55.390 - info: host.IoBroker iobroker upload [1] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/button.png button.png image/png
                2021-04-12 21:43:55.455 - info: host.IoBroker iobroker upload [0] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/admin.d.ts admin.d.ts video/mp2t
                2021-04-12 21:43:55.519 - info: host.IoBroker iobroker Adapter "wled" updated
                2021-04-12 21:43:55.694 - info: host.IoBroker stopInstance system.adapter.wled.0 killing pid 20698
                2021-04-12 21:43:56.539 - info: host.IoBroker iobroker exit 0
                2021-04-12 21:43:58.792 - info: host.IoBroker instance system.adapter.wled.0 started with pid 21975
                2021-04-12 21:43:59.524 - debug: wled.0 (21975) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2021-04-12 21:43:59.613 - debug: wled.0 (21975) Objects client ready ... initialize now
                2021-04-12 21:43:59.614 - debug: wled.0 (21975) Objects create System PubSub Client
                2021-04-12 21:43:59.615 - debug: wled.0 (21975) Objects create User PubSub Client
                2021-04-12 21:43:59.616 - debug: wled.0 (21975) Objects client initialize lua scripts
                2021-04-12 21:43:59.736 - debug: wled.0 (21975) Objects connected to redis: 127.0.0.1:9001
                2021-04-12 21:43:59.742 - debug: wled.0 (21975) objectDB connected
                2021-04-12 21:43:59.744 - debug: wled.0 (21975) Redis States: Use Redis connection: 127.0.0.1:9000
                2021-04-12 21:44:00.030 - debug: wled.0 (21975) States create System PubSub Client
                2021-04-12 21:44:00.031 - debug: wled.0 (21975) States create User PubSub Client
                2021-04-12 21:44:00.623 - debug: wled.0 (21975) States connected to redis: 127.0.0.1:9000
                2021-04-12 21:44:00.624 - debug: wled.0 (21975) statesDB connected
                2021-04-12 21:44:00.694 - error: wled.0 (21975) wled.0 already running
                2021-04-12 21:44:00.700 - debug: wled.0 (21975) Plugin sentry destroyed
                2021-04-12 21:44:00.702 - warn: wled.0 (21975) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-12 21:44:01.225 - error: wled.0 (21975) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-04-12 21:44:01.226 - error: wled.0 (21975) unhandled promise rejection: Cannot read property 'error' of undefined
                2021-04-12 21:44:01.229 - error: wled.0 (21975) TypeError: Cannot read property 'error' of undefined
                at Wled.onUnload (/opt/iobroker/node_modules/iobroker.wled/main.js:97:13)
                at Wled.emit (events.js:314:20)
                at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                at Object.onceWrapper (events.js:421:26)
                at process.emit (events.js:314:20)
                at process.exit (internal/process/per_thread.js:168:15)
                at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                at processTicksAndRejections (internal/process/task_queues.js:97:5)
                2021-04-12 21:44:01.230 - error: wled.0 (21975) Cannot read property 'error' of undefined
                der (positive) Nebeneffekt, seit wled nicht mehr läuft, die CPU ist seit dem gesunken, (da wolltest doch noch bisserl optimieren)
                  jkalver last edited by
                  @Dutchman sau cooler Adapter.
                  Leider habe ich plötzlich das Problem, dass sich meine WLEDs plötzlich nicht mehr steuern lassen. Sie werden als aktiv angezeigt aber Veränderungen werden weder an den WLED weitergegeben noch empfangen.
                  Steuerung über das Web Interface des WLEDs funktioniert problemlos.
                  Reboot des Adapters bzw auch des PI mit iobroker hat leider keine Änderung gebracht.
                  Was läuft falsch?
                  Gruss
                  Jens
                  • Dutchman
                    Dutchman Developer Most Active Administrators @jkalver last edited by
                    @jkalver sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                    Was läuft falsch
                    Ohne log muss ich meine Glaskugel fragen 🤷‍♂️
                    Mist kan die nicht finden 😳
                      jkalver @Dutchman last edited by jkalver
                      @dutchman
                      Guter Punkt.
                      Habe den Log Level geändert.
                      2021-04-18 20:02:51.452 - debug: wled.0 (31963) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2021-04-18 20:02:51.589 - debug: wled.0 (31963) Objects client ready ... initialize now
                      2021-04-18 20:02:51.640 - debug: wled.0 (31963) Objects create System PubSub Client
                      2021-04-18 20:02:51.642 - debug: wled.0 (31963) Objects create User PubSub Client
                      2021-04-18 20:02:51.644 - debug: wled.0 (31963) Objects client initialize lua scripts
                      2021-04-18 20:02:51.667 - debug: wled.0 (31963) Objects connected to redis: 127.0.0.1:9001
                      2021-04-18 20:02:51.687 - debug: wled.0 (31963) objectDB connected
                      2021-04-18 20:02:51.692 - debug: wled.0 (31963) Redis States: Use Redis connection: 127.0.0.1:9000
                      2021-04-18 20:02:51.705 - debug: wled.0 (31963) States create System PubSub Client
                      2021-04-18 20:02:51.707 - debug: wled.0 (31963) States create User PubSub Client
                      2021-04-18 20:02:51.720 - debug: wled.0 (31963) States connected to redis: 127.0.0.1:9000
                      2021-04-18 20:02:51.721 - debug: wled.0 (31963) statesDB connected
                      2021-04-18 20:02:51.732 - error: wled.0 (31963) wled.0 already running
                      2021-04-18 20:02:51.734 - debug: wled.0 (31963) Plugin sentry destroyed
                      2021-04-18 20:02:51.735 - warn: wled.0 (31963) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-04-18 20:02:52.264 - error: wled.0 (31963) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2021-04-18 20:02:52.265 - error: wled.0 (31963) unhandled promise rejection: Cannot read property 'error' of undefined
                      2021-04-18 20:02:52.270 - error: wled.0 (31963) TypeError: Cannot read property 'error' of undefined
                      at Wled.emit (events.js:198:13)
                      at Object.onceWrapper (events.js:286:20)
                      at process.emit (events.js:198:13)
                      at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                      at process._tickCallback (internal/process/next_tick.js:68:7)
                      2021-04-18 20:02:52.271 - error: wled.0 (31963) Ca
                      Gruss
                      Jens
                        crunchip Forum Testing Most Active @jkalver last edited by
                        @jkalver dein log in </> packen
                        du hast das selbe Problem wie ich auch, siehe 3 Post's weiter oben
                          jkalver @crunchip last edited by
                          @crunchip
                          Hast du eine Zwischenlösung?
                            @jkalver jep, nicht per iobroker steuern😁
                            Spaß beiseite, nein, benutze es seitdem nicht
                            • Dutchman
                              Dutchman Developer Most Active Administrators @crunchip last edited by
                              @crunchip sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                              Sobald mein Arm aus dem Gips ist löse ich es Fehler und Problem gefunden programmieren geht aber scheisse mit einer hand
                              Neuschwansteini J 2 Replies Last reply Reply Quote 2
                              • Neuschwansteini
                                Neuschwansteini @Dutchman last edited by
                                @dutchman Gute Besserung, ruh dich aus, und lass die Finger von der Tastatur..
                                Dutchman 1 Reply Last reply Reply Quote 1
                                  @dutchman
                                  Alles gut und dir gute Besserung. Erst gesund werden dann lösen 😀
                                  • Dutchman
                                    Dutchman Developer Most Active Administrators @Neuschwansteini last edited by
                                    @ilovegym sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                    Danke! Und no worries, mein rechter Daumen wird gut trainiert gerade 😂
                                    da_Woody J 2 Replies Last reply Reply Quote 0
                                    • da_Woody
                                      da_Woody @Dutchman last edited by
                                      @dutchman auch von mir ein: besser dich! 😉
                                        DocGame last edited by
                                        Im Moment habe ich 3 ESP's mit WLED im Echteinsatz. Alles funktioniert super.
                                        Ich habe aber ein Problem, Geräte die ich mal im Adapter hatte und mittlerweile mit anderer Firmware geflasht habe (Tasmota, ESPeasy usw,) nicht mehr aus dem Adapter rausbekomme. Das löschen des jeweiligen Channels bringt nichts. In der Instanzenübersicht sind diese auch weiter zu sehen (natürlich Rot).
                                        Wie kann ich den Adapter von diesen "Leichen" befreien? Wäre ein Delete-Button auf der Konfigseite denkbar?
                                        Wünsche dir auch ein gutes "Knochen-Zusammenwachsen"
                                          Muchul @DocGame last edited by Muchul
                                          @docgame
                                          Lösch die Datenpunkte in den Objekten.
                                          Dann sind sie weg.
                                            Labersack last edited by Labersack
                                            Kurze Zwischenfrage:
                                            Für eine VIS würde ich gerne den aktuellen Effekt anzeigen lassen.
                                            Die Nummer des Effekts finde ich unter wled.0.240ac4xyz.seg.0.fx, in den Details unter RAW finde ich auch zu jeder Nummer die zugehörige Bezeichnung. Aber wie komme ich per JS an diesen Text ran?
                                            31.7k
                                            79.9k
                                            adapater adapter neu hier test testen tester wled
                                            73
                                            655
                                            141422
