    4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
      crunchip Forum Testing Most Active last edited by crunchip
      @Dutchman
      ich hab seit paar Tagen das Problem mit Wled, lässt sich nichts mehr steuern.
      hatte v.0.5.6 und bin grad mal testweise zurück auf v0.5.5, jedoch mit dem selben Ergebnis
      2021-04-12 21:42:40.631 - info: host.IoBroker iobroker upgrade wled@0.5.5
      2021-04-12 21:42:43.083 - info: host.IoBroker iobroker Update wled from @0.5.6 to @0.5.5
      2021-04-12 21:42:43.860 - info: host.IoBroker iobroker NPM version: 6.14.11npm install iobroker.wled@0.5.5 --loglevel error --prefix "/opt/iobroker" (System call)
      2021-04-12 21:43:54.347 - info: host.IoBroker iobroker upload [6] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/words.js words.js application/javascript
      2021-04-12 21:43:54.608 - info: host.IoBroker iobroker Update "system.adapter.wled.0"
      2021-04-12 21:43:54.642 - info: host.IoBroker stopInstance system.adapter.wled.0 (force=false, process=true)
      2021-04-12 21:43:54.691 - info: host.IoBroker stopInstance system.adapter.wled.0 send kill signal
      2021-04-12 21:43:54.773 - info: host.IoBroker iobroker upload [5] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/wled_large.png wled_large.png image/png
      2021-04-12 21:43:54.891 - info: host.IoBroker iobroker upload [4] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/wled.png wled.png image/png
      2021-04-12 21:43:54.992 - info: host.IoBroker iobroker upload [3] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/style.css style.css text/css
      2021-04-12 21:43:55.276 - info: host.IoBroker iobroker upload [2] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/index_m.html index_m.html text/html
      2021-04-12 21:43:55.390 - info: host.IoBroker iobroker upload [1] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/button.png button.png image/png
      2021-04-12 21:43:55.455 - info: host.IoBroker iobroker upload [0] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/admin.d.ts admin.d.ts video/mp2t
      2021-04-12 21:43:55.519 - info: host.IoBroker iobroker Adapter "wled" updated
      2021-04-12 21:43:55.694 - info: host.IoBroker stopInstance system.adapter.wled.0 killing pid 20698
      2021-04-12 21:43:56.539 - info: host.IoBroker iobroker exit 0
      2021-04-12 21:43:58.792 - info: host.IoBroker instance system.adapter.wled.0 started with pid 21975
      2021-04-12 21:43:59.524 - debug: wled.0 (21975) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-04-12 21:43:59.613 - debug: wled.0 (21975) Objects client ready ... initialize now
      2021-04-12 21:43:59.614 - debug: wled.0 (21975) Objects create System PubSub Client
      2021-04-12 21:43:59.615 - debug: wled.0 (21975) Objects create User PubSub Client
      2021-04-12 21:43:59.616 - debug: wled.0 (21975) Objects client initialize lua scripts
      2021-04-12 21:43:59.736 - debug: wled.0 (21975) Objects connected to redis: 127.0.0.1:9001
      2021-04-12 21:43:59.742 - debug: wled.0 (21975) objectDB connected
      2021-04-12 21:43:59.744 - debug: wled.0 (21975) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-04-12 21:44:00.030 - debug: wled.0 (21975) States create System PubSub Client
      2021-04-12 21:44:00.031 - debug: wled.0 (21975) States create User PubSub Client
      2021-04-12 21:44:00.623 - debug: wled.0 (21975) States connected to redis: 127.0.0.1:9000
      2021-04-12 21:44:00.624 - debug: wled.0 (21975) statesDB connected
      2021-04-12 21:44:00.694 - error: wled.0 (21975) wled.0 already running
      2021-04-12 21:44:00.700 - debug: wled.0 (21975) Plugin sentry destroyed
      2021-04-12 21:44:00.702 - warn: wled.0 (21975) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-12 21:44:01.225 - error: wled.0 (21975) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-12 21:44:01.226 - error: wled.0 (21975) unhandled promise rejection: Cannot read property 'error' of undefined
      2021-04-12 21:44:01.229 - error: wled.0 (21975) TypeError: Cannot read property 'error' of undefined
      at Wled.onUnload (/opt/iobroker/node_modules/iobroker.wled/main.js:97:13)
      at Wled.emit (events.js:314:20)
      at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
      at Object.onceWrapper (events.js:421:26)
      at process.emit (events.js:314:20)
      at process.exit (internal/process/per_thread.js:168:15)
      at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-04-12 21:44:01.230 - error: wled.0 (21975) Cannot read property 'error' of undefined
      der (positive) Nebeneffekt, seit wled nicht mehr läuft, die CPU ist seit dem gesunken, (da wolltest doch noch bisserl optimieren)
        jkalver last edited by
        @Dutchman sau cooler Adapter.
        Leider habe ich plötzlich das Problem, dass sich meine WLEDs plötzlich nicht mehr steuern lassen. Sie werden als aktiv angezeigt aber Veränderungen werden weder an den WLED weitergegeben noch empfangen.
        Steuerung über das Web Interface des WLEDs funktioniert problemlos.
        Reboot des Adapters bzw auch des PI mit iobroker hat leider keine Änderung gebracht.
        Was läuft falsch?
        Gruss
        Jens
        • Dutchman
          Dutchman Developer Most Active Administrators @jkalver last edited by
          @jkalver sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
          Was läuft falsch
          Ohne log muss ich meine Glaskugel fragen 🤷‍♂️
          Mist kan die nicht finden 😳
            jkalver @Dutchman last edited by jkalver
            @dutchman
            Guter Punkt.
            Habe den Log Level geändert.
            2021-04-18 20:02:51.452 - debug: wled.0 (31963) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2021-04-18 20:02:51.589 - debug: wled.0 (31963) Objects client ready ... initialize now
            2021-04-18 20:02:51.640 - debug: wled.0 (31963) Objects create System PubSub Client
            2021-04-18 20:02:51.642 - debug: wled.0 (31963) Objects create User PubSub Client
            2021-04-18 20:02:51.644 - debug: wled.0 (31963) Objects client initialize lua scripts
            2021-04-18 20:02:51.667 - debug: wled.0 (31963) Objects connected to redis: 127.0.0.1:9001
            2021-04-18 20:02:51.687 - debug: wled.0 (31963) objectDB connected
            2021-04-18 20:02:51.692 - debug: wled.0 (31963) Redis States: Use Redis connection: 127.0.0.1:9000
            2021-04-18 20:02:51.705 - debug: wled.0 (31963) States create System PubSub Client
            2021-04-18 20:02:51.707 - debug: wled.0 (31963) States create User PubSub Client
            2021-04-18 20:02:51.720 - debug: wled.0 (31963) States connected to redis: 127.0.0.1:9000
            2021-04-18 20:02:51.721 - debug: wled.0 (31963) statesDB connected
            2021-04-18 20:02:51.732 - error: wled.0 (31963) wled.0 already running
            2021-04-18 20:02:51.734 - debug: wled.0 (31963) Plugin sentry destroyed
            2021-04-18 20:02:51.735 - warn: wled.0 (31963) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2021-04-18 20:02:52.264 - error: wled.0 (31963) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2021-04-18 20:02:52.265 - error: wled.0 (31963) unhandled promise rejection: Cannot read property 'error' of undefined
            2021-04-18 20:02:52.270 - error: wled.0 (31963) TypeError: Cannot read property 'error' of undefined
            at Wled.emit (events.js:198:13)
            at Object.onceWrapper (events.js:286:20)
            at process.emit (events.js:198:13)
            at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
            at process._tickCallback (internal/process/next_tick.js:68:7)
            2021-04-18 20:02:52.271 - error: wled.0 (31963) Ca
            Gruss
            Jens
              crunchip Forum Testing Most Active @jkalver last edited by
              @jkalver dein log in </> packen
              du hast das selbe Problem wie ich auch, siehe 3 Post's weiter oben
                jkalver @crunchip last edited by
                @crunchip
                Hast du eine Zwischenlösung?
                  @jkalver jep, nicht per iobroker steuern😁
                  Spaß beiseite, nein, benutze es seitdem nicht
                  • Dutchman
                    Dutchman Developer Most Active Administrators @crunchip last edited by
                    @crunchip sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                    Sobald mein Arm aus dem Gips ist löse ich es Fehler und Problem gefunden programmieren geht aber scheisse mit einer hand
                    Neuschwansteini J 2 Replies Last reply Reply Quote 2
                    • Neuschwansteini
                      Neuschwansteini @Dutchman last edited by
                      @dutchman Gute Besserung, ruh dich aus, und lass die Finger von der Tastatur..
                      Dutchman 1 Reply Last reply Reply Quote 1
                        @dutchman
                        Alles gut und dir gute Besserung. Erst gesund werden dann lösen 😀
                        • Dutchman
                          Dutchman Developer Most Active Administrators @Neuschwansteini last edited by
                          @ilovegym sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                          Danke! Und no worries, mein rechter Daumen wird gut trainiert gerade 😂
                          da_Woody J 2 Replies Last reply Reply Quote 0
                          • da_Woody
                            da_Woody @Dutchman last edited by
                            @dutchman auch von mir ein: besser dich! 😉
                              DocGame last edited by
                              Im Moment habe ich 3 ESP's mit WLED im Echteinsatz. Alles funktioniert super.
                              Ich habe aber ein Problem, Geräte die ich mal im Adapter hatte und mittlerweile mit anderer Firmware geflasht habe (Tasmota, ESPeasy usw,) nicht mehr aus dem Adapter rausbekomme. Das löschen des jeweiligen Channels bringt nichts. In der Instanzenübersicht sind diese auch weiter zu sehen (natürlich Rot).
                              Wie kann ich den Adapter von diesen "Leichen" befreien? Wäre ein Delete-Button auf der Konfigseite denkbar?
                              Wünsche dir auch ein gutes "Knochen-Zusammenwachsen"
                                Muchul @DocGame last edited by Muchul
                                @docgame
                                Lösch die Datenpunkte in den Objekten.
                                Dann sind sie weg.
                                  Labersack last edited by Labersack
                                  Kurze Zwischenfrage:
                                  Für eine VIS würde ich gerne den aktuellen Effekt anzeigen lassen.
                                  Die Nummer des Effekts finde ich unter wled.0.240ac4xyz.seg.0.fx, in den Details unter RAW finde ich auch zu jeder Nummer die zugehörige Bezeichnung. Aber wie komme ich per JS an diesen Text ran?
                                  • Dutchman
                                    Dutchman Developer Most Active Administrators @Labersack last edited by
                                    @labersack sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                    Wieso per js?
                                    Kannst doch die Sachen vom raw als json Dropdown kopieren ?
                                      Labersack @Dutchman last edited by Labersack
                                      @dutchman Rauskopieren ist nicht das Problem, aber ich würde einfach zum jeweiligen Programm auch immer den aktuell zughörigen Namen anzeigen lassen. Wenn ich die Liste einmalig rauskopiere, stimmt sie ja nach dem nächsten Update nicht mehr unbedingt oder ist bei neuen Effekten jedenfalls nicht mehr vollständig.
                                      ..oder habe ich deinen Vorschlag falsch verstanden?
                                        Noch ne kleine Erklärung zu meinem Vorhaben:
                                        Ich habe aktuell ein Script laufen, das zufällig anhand per VIS auswählbaren Parametern (Zeit, "Effekt-Gruppe", usw) einen Effekt wählt. Die Nummer des ausgewählten Effekts schreibt das Script in einen Objekt unter 0_userdata, diese Nummer wird dann wieder am Wand-Tablet angezeigt. Und bei dieser Anzeige hätte ich gerne den Namen des Effekts mit angezeigt, den ich dazu in ein weiteres Objekt unter 0_userdata schreiben würde.
                                          @dutchman
                                          ich habe meine Logs die Tage mal näher beobachtet, um die Fehlerursache weiter einzuschränken.
                                          Dabei bin ich auf folgendes gestossen. Irgendwann am Nachmittag erzeugt mein iobroker einen Fehler : read ECONNRESET
                                          Während die anderen Adapter damit umgehen können (siehe beiliegendes log) hat der WLED Adapter ein Problem, sich davon zu erholen.
                                          Vielleicht hilft das ja bei der Fehlersuche.
                                          2021-04-21 20:04:16.595  - error: fronius.0 (775) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.677  - error: email.0 (1960) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.573  - error: wled.0 (2140) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.746  - error: tr-064.0 (1599) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.784  - error: javascript.0 (1801) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.845  - error: backitup.0 (844) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.906  - error: discovery.0 (756) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.913  - error: robonect.0 (1562) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.875  - info: wled.0 (2140) cleaned everything up...
                                          2021-04-21 20:04:16.918  - error: sql.0 (1327) States database error: write ECONNRESET
                                          2021-04-21 20:04:16.876  - info: javascript.0 (1801) Stop script script.js.PV_Leistung_nach_KNX
                                          2021-04-21 20:04:16.878  - info: javascript.0 (1801) Stop script script.js.Batterie_Ladezustand_nach_KNX
                                          2021-04-21 20:04:16.880  - info: javascript.0 (1801) Stop script script.js.Batterie_Leistung
                                          2021-04-21 20:04:16.880  - info: javascript.0 (1801) Stop script script.js.Netz_Leistung
                                          2021-04-21 20:04:16.881  - info: javascript.0 (1801) Stop script script.js.FehlerEmail
                                          2021-04-21 20:04:16.882  - info: javascript.0 (1801) Stop script script.js.Hausverbrauch_Wh
                                          2021-04-21 20:04:16.883  - info: javascript.0 (1801) Stop script script.js.Garagentor_Licht_Steuerung.PRESET_von_KNX_nach_WLED
                                          2021-04-21 20:04:16.883  - info: javascript.0 (1801) Stop script script.js.Wled_Terasse.Preset_vonKNX_nach_WLED
                                          2021-04-21 20:04:16.884  - info: javascript.0 (1801) Stop script script.js.Wled_Terasse.Ein_Aus_Schalten
                                          2021-04-21 20:04:16.884  - info: javascript.0 (1801) Stop script script.js.Wled_Terasse.Dimmer
                                          2021-04-21 20:04:16.885  - info: javascript.0 (1801) Stop script script.js.Wled_Terasse.Ausschalten_wenn_Steckdose_ausschaltet
                                          2021-04-21 20:04:16.959  - error: ping.0 (1341) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.963  - error: admin.0 (745) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.963  - error: modbus.0 (1762) States database error: write ECONNRESET
                                          2021-04-21 20:04:17.052  - error: web.0 (791) States database error: read ECONNRESET
                                          2021-04-21 20:04:16.998  - error: modbus.0 (1762) Objects database error: read ECONNRESET
                                          2021-04-21 20:04:17.115  - info: backitup.0 (844) cleaned everything up...
                                          2021-04-21 20:04:17.113  - error: info.0 (810) States database error: write ECONNRESET
                                          2021-04-21 20:04:17.002  - error: admin.0 (745) Objects database error: read ECONNRESET
                                          2021-04-21 20:04:17.159  - info: robonect.0 (1562) cleaned everything up...
                                          2021-04-21 20:04:17.197  - info: admin.0 (745) terminating http server on port 8081
                                          2021-04-21 20:04:17.257  - info: info.0 (810) cleaned everything up...
                                          2021-04-21 20:04:17.176  - error: knx.0 (1376) States database error: write EPIPE
                                          2021-04-21 20:04:17.334  - info: web.0 (791) terminated http server on port 8082
                                          2021-04-21 20:04:17.296  - error: info.0 (810) Objects database error: write EPIPE
                                          2021-04-21 20:04:17.453  - error: knx.0 (1376) Objects database error: read ECONNRESET
                                          2021-04-21 20:04:18.379  - debug: wled.0 (2140) Plugin sentry destroyed
                                          2021-04-21 20:04:18.380  - info: wled.0 (2140) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.389  - info: javascript.0 (1801) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.416  - info: fronius.0 (775) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.592  - info: email.0 (1960) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.625  - info: backitup.0 (844) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.671  - info: robonect.0 (1562) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.672  - info: discovery.0 (756) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.685  - info: sql.0 (1327) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.730  - info: admin.0 (745) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.732  - info: ping.0 (1341) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.767  - info: info.0 (810) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:18.846  - info: web.0 (791) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-04-21 20:04:20.085  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:21.754  - error: wled.0 (2140) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:21.783  - error: fronius.0 (775) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:21.821  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.835  - error: email.0 (1960) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:21.838  - error: javascript.0 (1801) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:21.846  - error: tr-064.0 (1599) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:21.842  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.843  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.844  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.845  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.846  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.847  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.848  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.849  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.850  - warn: fronius.0 (775) get state error: DB closed
                                          2021-04-21 20:04:21.920  - error: backitup.0 (844) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:21.982  - warn: backitup.0 (844) get state error: DB closed
                                          2021-04-21 20:04:22.003  - error: robonect.0 (1562) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.087  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.097  - warn: robonect.0 (1562) get state error: DB closed
                                          2021-04-21 20:04:22.099  - error: discovery.0 (756) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.098  - error: ping.0 (1341) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.096  - error: admin.0 (745) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.105  - warn: email.0 (1960) get state error: DB closed
                                          2021-04-21 20:04:22.104  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.105  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.106  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.108  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.109  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.111  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.112  - warn: sql.0 (1327) No Connection to database
                                          2021-04-21 20:04:22.129  - error: web.0 (791) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.143  - warn: discovery.0 (756) get state error: DB closed
                                          2021-04-21 20:04:22.147  - warn: admin.0 (745) get state error: Connection is closed.
                                          2021-04-21 20:04:22.149  - warn: web.0 (791) get state error: DB closed
                                          2021-04-21 20:04:22.189  - error: modbus.0 (1762) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.194  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.213  - error: sql.0 (1327) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.196  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.198  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.201  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.203  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.209  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.210  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.213  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.215  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.216  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.218  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.219  - warn: ping.0 (1341) get state error: DB closed
                                          2021-04-21 20:04:22.305  - error: info.0 (810) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:22.434  - warn: info.0 (810) get state error: Connection is closed.
                                          2021-04-21 20:04:22.436  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.437  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.438  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.439  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.440  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.441  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.442  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.449  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.450  - warn: info.0 (810) get state error: DB closed
                                          2021-04-21 20:04:22.576  - error: knx.0 (1376) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-04-21 20:04:26.789  - error: fronius.0 (775) Cannot check object existence of "fronius.0.info.lastsync": Connection is closed.
                                          2021-04-21 20:04:27.106  - error: ping.0 (1341) Cannot check object existence of "ping.0.192_168_1_1.alive": Connection is closed.
                                          2021-04-21 20:04:27.312  - error: info.0 (810) Cannot check object existence of "info.0.sysinfo.cpu.currentspeed.maxSpeed": Connection is closed.
                                          2021-04-21 20:04:31.183  - info: host.ioBroker-RasPi4 iobroker.js-controller version 3.2.16 js-controller starting
                                          2021-04-21 20:04:31.193  - info: host.ioBroker-RasPi4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                          2021-04-21 20:04:31.194  - info: host.ioBroker-RasPi4 hostname: ioBroker-RasPi4, node: v10.23.0
                                          2021-04-21 20:04:31.195  - info: host.ioBroker-RasPi4 ip addresses: 192.168.1.8 2003:cd:5735:8200:3252:103f:8920:f841 fe80::d70c:377c:4d1e:edc2
                                          2021-04-21 20:04:32.951  - info: host.ioBroker-RasPi4 connected to Objects and States
                                          2021-04-21 20:04:33.054  - info: host.ioBroker-RasPi4 added notifications configuration of host
                                          2021-04-21 20:04:33.999  - info: host.ioBroker-RasPi4 17 instances found
                                          2021-04-21 20:04:34.061  - info: host.ioBroker-RasPi4 starting 15 instances
                                          2021-04-21 20:04:34.244  - info: host.ioBroker-RasPi4 instance system.adapter.admin.0 started with pid 7446
                                          2021-04-21 20:04:37.540  - error: admin.0 (7446) admin.0 already running
                                          2021-04-21 20:04:37.545  - warn: admin.0 (7446) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:04:38.196  - info: host.ioBroker-RasPi4 instance system.adapter.discovery.0 started with pid 7459
                                          2021-04-21 20:04:38.321  - error: host.ioBroker-RasPi4 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:04:38.323  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.admin.0 because enabled
                                          2021-04-21 20:04:40.370  - error: discovery.0 (7459) discovery.0 already running
                                          2021-04-21 20:04:40.374  - warn: discovery.0 (7459) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:04:41.070  - error: host.ioBroker-RasPi4 instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:04:41.072  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.discovery.0 because enabled
                                          2021-04-21 20:04:42.141  - info: host.ioBroker-RasPi4 instance system.adapter.fronius.0 started with pid 7472
                                          2021-04-21 20:04:44.870  - error: fronius.0 (7472) fronius.0 already running
                                          2021-04-21 20:04:44.874  - warn: fronius.0 (7472) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:04:45.515  - error: host.ioBroker-RasPi4 instance system.adapter.fronius.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:04:45.516  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.fronius.0 because enabled
                                          2021-04-21 20:04:46.250  - info: host.ioBroker-RasPi4 instance system.adapter.web.0 started with pid 7485
                                          2021-04-21 20:04:48.480  - error: web.0 (7485) web.0 already running
                                          2021-04-21 20:04:48.484  - warn: web.0 (7485) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:04:49.163  - error: host.ioBroker-RasPi4 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:04:49.164  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.web.0 because enabled
                                          2021-04-21 20:04:50.232  - info: host.ioBroker-RasPi4 instance system.adapter.info.0 started with pid 7498
                                          2021-04-21 20:04:53.806  - error: info.0 (7498) info.0 already running
                                          2021-04-21 20:04:53.811  - warn: info.0 (7498) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:04:54.115  - info: host.ioBroker-RasPi4 instance system.adapter.backitup.0 started with pid 7519
                                          2021-04-21 20:04:54.488  - error: host.ioBroker-RasPi4 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:04:54.489  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.info.0 because enabled
                                          2021-04-21 20:04:58.201  - info: host.ioBroker-RasPi4 instance system.adapter.sql.0 started with pid 7528
                                          2021-04-21 20:05:01.151  - error: sql.0 (7528) sql.0 already running
                                          2021-04-21 20:05:01.157  - warn: sql.0 (7528) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:05:01.811  - error: host.ioBroker-RasPi4 instance system.adapter.sql.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:01.813  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.sql.0 because enabled
                                          2021-04-21 20:05:01.930  - error: backitup.0 (7519) backitup.0 already running
                                          2021-04-21 20:05:01.934  - warn: backitup.0 (7519) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:05:02.201  - info: host.ioBroker-RasPi4 instance system.adapter.ping.0 started with pid 7551
                                          2021-04-21 20:05:02.592  - error: host.ioBroker-RasPi4 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:02.594  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.backitup.0 because enabled
                                          2021-04-21 20:05:04.276  - error: ping.0 (7551) ping.0 already running
                                          2021-04-21 20:05:04.281  - warn: ping.0 (7551) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:05:04.962  - error: host.ioBroker-RasPi4 instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:04.963  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.ping.0 because enabled
                                          2021-04-21 20:05:06.124  - info: host.ioBroker-RasPi4 instance system.adapter.knx.0 started with pid 7564
                                          2021-04-21 20:05:08.354  - info: host.ioBroker-RasPi4 instance system.adapter.admin.0 started with pid 7576
                                          2021-04-21 20:05:08.482  - error: knx.0 (7564) knx.0 already running
                                          2021-04-21 20:05:09.149  - error: host.ioBroker-RasPi4 instance system.adapter.knx.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:09.151  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.knx.0 because enabled
                                          2021-04-21 20:05:10.106  - info: host.ioBroker-RasPi4 instance system.adapter.robonect.0 started with pid 7584
                                          2021-04-21 20:05:11.114  - info: host.ioBroker-RasPi4 instance system.adapter.discovery.0 started with pid 7595
                                          2021-04-21 20:05:12.098  - info: admin.0 (7576) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v10.23.0, js-controller: 3.2.16
                                          2021-04-21 20:05:12.209  - info: admin.0 (7576) requesting all states
                                          2021-04-21 20:05:12.211  - info: admin.0 (7576) requesting all objects
                                          2021-04-21 20:05:13.736  - info: admin.0 (7576) Request actual repository...
                                          2021-04-21 20:05:14.802  - info: admin.0 (7576) received all objects
                                          2021-04-21 20:05:15.131  - info: admin.0 (7576) http server listening on port 8081
                                          2021-04-21 20:05:15.132  - info: admin.0 (7576) Use link "http://localhost:8081" to configure.
                                          2021-04-21 20:05:15.739  - info: host.ioBroker-RasPi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                          2021-04-21 20:05:15.917  - info: host.ioBroker-RasPi4 instance system.adapter.fronius.0 started with pid 7616
                                          2021-04-21 20:05:15.981  - info: host.ioBroker-RasPi4 instance system.adapter.tr-064.0 started with pid 7623
                                          2021-04-21 20:05:16.054  - error: robonect.0 (7584) robonect.0 already running
                                          2021-04-21 20:05:16.060  - warn: robonect.0 (7584) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:05:17.164  - error: host.ioBroker-RasPi4 instance system.adapter.robonect.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:17.167  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.robonect.0 because enabled
                                          2021-04-21 20:05:17.657  - info: discovery.0 (7595) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v10.23.0, js-controller: 3.2.16
                                          2021-04-21 20:05:18.223  - info: host.ioBroker-RasPi4 instance system.adapter.modbus.0 started with pid 7636
                                          2021-04-21 20:05:19.220  - info: host.ioBroker-RasPi4 instance system.adapter.web.0 started with pid 7651
                                          2021-04-21 20:05:19.759  - error: tr-064.0 (7623) tr-064.0 already running
                                          2021-04-21 20:05:19.873  - info: fronius.0 (7616) starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.fronius, node: v10.23.0, js-controller: 3.2.16
                                          2021-04-21 20:05:20.461  - error: host.ioBroker-RasPi4 instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:20.463  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.tr-064.0 because enabled
                                          2021-04-21 20:05:21.253  - error: modbus.0 (7636) modbus.0 already running
                                          2021-04-21 20:05:22.131  - error: host.ioBroker-RasPi4 instance system.adapter.modbus.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:22.133  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.modbus.0 because enabled
                                          2021-04-21 20:05:23.400  - info: admin.0 (7576) Repository received successfully.
                                          2021-04-21 20:05:24.757  - warn: web.0 (7651) slow connection to states DB. Still waiting ...
                                          2021-04-21 20:05:25.028  - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 started with pid 7675
                                          2021-04-21 20:05:26.255  - info: host.ioBroker-RasPi4 instance system.adapter.info.0 started with pid 7683
                                          2021-04-21 20:05:26.305  - info: host.ioBroker-RasPi4 instance system.adapter.email.0 started with pid 7684
                                          2021-04-21 20:05:27.532  - info: web.0 (7651) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v10.23.0, js-controller: 3.2.16
                                          2021-04-21 20:05:28.350  - info: web.0 (7651) socket.io server listening on port 8082
                                          2021-04-21 20:05:28.384  - info: web.0 (7651) simpleAPI server listening on port 8082
                                          2021-04-21 20:05:28.386  - info: web.0 (7651) Allow states only when user is owner: false
                                          2021-04-21 20:05:28.407  - info: web.0 (7651) http server listening on port 8082
                                          2021-04-21 20:05:29.598  - error: email.0 (7684) email.0 already running
                                          2021-04-21 20:05:29.606  - warn: email.0 (7684) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:05:32.147  - info: host.ioBroker-RasPi4 instance system.adapter.wled.0 started with pid 7724
                                          2021-04-21 20:05:32.196  - info: host.ioBroker-RasPi4 instance system.adapter.sql.0 started with pid 7730
                                          2021-04-21 20:05:32.474  - error: host.ioBroker-RasPi4 instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:32.475  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.email.0 because enabled
                                          2021-04-21 20:05:32.668  - info: host.ioBroker-RasPi4 instance system.adapter.backitup.0 started with pid 7738
                                          2021-04-21 20:05:33.155  - error: javascript.0 (7675) javascript.0 already running
                                          2021-04-21 20:05:33.166  - warn: javascript.0 (7675) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:05:33.966  - error: host.ioBroker-RasPi4 instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-04-21 20:05:33.968  - info: host.ioBroker-RasPi4 Restart adapter system.adapter.javascript.0 because enabled
                                          2021-04-21 20:05:35.056  - info: host.ioBroker-RasPi4 instance system.adapter.ping.0 started with pid 7747
                                          2021-04-21 20:05:35.576  - info: info.0 (7683) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v10.23.0, js-controller: 3.2.16
                                          2021-04-21 20:05:36.488  - debug: wled.0 (7724) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2021-04-21 20:05:36.786  - debug: wled.0 (7724) Objects client ready ... initialize now
                                          2021-04-21 20:05:36.812  - debug: wled.0 (7724) Objects create System PubSub Client
                                          2021-04-21 20:05:36.816  - debug: wled.0 (7724) Objects create User PubSub Client
                                          2021-04-21 20:05:36.819  - debug: wled.0 (7724) Objects client initialize lua scripts
                                          2021-04-21 20:05:36.939  - debug: wled.0 (7724) Objects connected to redis: 127.0.0.1:9001
                                          2021-04-21 20:05:37.019  - debug: wled.0 (7724) objectDB connected
                                          2021-04-21 20:05:37.037  - debug: wled.0 (7724) Redis States: Use Redis connection: 127.0.0.1:9000
                                          2021-04-21 20:05:37.085  - debug: wled.0 (7724) States create System PubSub Client
                                          2021-04-21 20:05:37.093  - debug: wled.0 (7724) States create User PubSub Client
                                          2021-04-21 20:05:37.150  - debug: wled.0 (7724) States connected to redis: 127.0.0.1:9000
                                          2021-04-21 20:05:37.153  - debug: wled.0 (7724) statesDB connected
                                          2021-04-21 20:05:37.194  - error: wled.0 (7724) wled.0 already running
                                          2021-04-21 20:05:37.213  - debug: wled.0 (7724) Plugin sentry destroyed
                                          2021-04-21 20:05:37.214  - warn: wled.0 (7724) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-04-21 20:05:37.618  - info: sql.0 (7730) starting. Version 1.15.5 in /opt/iobroker/node_modules/iobroker.sql, node: v10.23.0, js-controller: 3.2.16
                                          2021-04-21 20:05:38.410  - error: wled.0 (7724) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2021-04-21 20:05:38.415  - error: wled.0 (7724) unhandled promise rejection: Cannot read property 'error' of undefined
                                          2021-04-21 20:05:38.429  - error: wled.0 (7724) TypeError: Cannot read property 'error' of undefined
                                          2021-04-21 20:05:38.430  - error: wled.0 (7724) Cannot read property 'error' of undefined
                                          • Dutchman
                                            danke, ja das hilft zur estaetigung das diese Innovation das problem loesen wird :
                                            https://github.com/DrozmotiX/ioBroker.wled/issues/145
                                            DutchmanNL created this issue in DrozmotiX/ioBroker.wled
                                            closed Change complete communication logic to WebSocket #145
                                            31.7k
                                            79.9k
                                            adapater adapter neu hier test testen tester wled
                                            73
                                            655
                                            141425
