    4. Zwei Bugs mit backitup 2.1.0 und 2.0.5
      michael_4358 @metaxa last edited by
      @metaxa ioBroker;zigbee;jarvis
      und wenn ich die history mit einbinde stürtzt das adapter ab
      • simatec
        simatec Developer Most Active @michael_4358 last edited by
        @michael_4358
        Ohne Debug Log wird es schwierig dir zu helfen
          michael_4358 @simatec last edited by
          @simatec
          wendy2702 simatec 2 Replies Last reply Reply Quote 0
          • wendy2702
            wendy2702 @michael_4358 last edited by
            @michael_4358 kannst du das logfile bitte als Text in Code Tags </> posten!
            • simatec
              @michael_4358
              Bitte die Instanz auf debug stellen, damit man hier einfach mehr sieht
                michael_4358 @wendy2702 last edited by
                @wendy2702 wo kann ich den adapter umschalten?
                metaxa 1 Reply Last reply Reply Quote 0
                • metaxa
                  metaxa @michael_4358 last edited by
                    michael_4358 @metaxa last edited by michael_4358
                    @metaxa ```
                    2021-04-19 11:34:32.024 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2021-04-19 11:34:34.446 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 4271
                    2021-04-19 11:34:37.605 - debug: backitup.0 (4271) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2021-04-19 11:34:37.668 - debug: backitup.0 (4271) Objects client ready ... initialize now
                    2021-04-19 11:34:37.670 - debug: backitup.0 (4271) Objects create System PubSub Client
                    2021-04-19 11:34:37.672 - debug: backitup.0 (4271) Objects create User PubSub Client
                    2021-04-19 11:34:37.673 - debug: backitup.0 (4271) Objects client initialize lua scripts
                    2021-04-19 11:34:37.688 - debug: backitup.0 (4271) Objects connected to redis: 127.0.0.1:9001
                    2021-04-19 11:34:37.698 - debug: backitup.0 (4271) objectDB connected
                    2021-04-19 11:34:37.700 - debug: backitup.0 (4271) Redis States: Use Redis connection: 127.0.0.1:9000
                    2021-04-19 11:34:37.724 - debug: backitup.0 (4271) States create System PubSub Client
                    2021-04-19 11:34:37.726 - debug: backitup.0 (4271) States create User PubSub Client
                    2021-04-19 11:34:37.736 - debug: backitup.0 (4271) States connected to redis: 127.0.0.1:9000
                    2021-04-19 11:34:37.737 - debug: backitup.0 (4271) statesDB connected
                    2021-04-19 11:34:38.148 - debug: backitup.0 (4271) Plugin sentry Initialize Plugin (enabled=true)
                    2021-04-19 11:34:38.378 - info: backitup.0 (4271) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
                    2021-04-19 11:34:38.468 - info: backitup.0 (4271) [iobroker] backup was activated at 12:00 every 5 day(s)
                    2021-04-19 11:34:38.504 - debug: backitup.0 (4271) [iobroker] 10 00 12 */5 * *
                    2021-04-19 11:34:38.653 - debug: backitup.0 (4271) first mount attempt with smb option failed. try next mount attempt without smb option ...
                    2021-04-19 11:34:38.803 - debug: backitup.0 (4271) mount successfully completed
                    2021-04-19 11:34:40.869 - debug: backitup.0 (4271) detect backup file 1 from cifs: iobroker_2021_04_14-21_47_13_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:34:40.869 - debug: backitup.0 (4271) detect backup file 2 from cifs: iobroker_2021_04_14-21_48_53_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:34:40.870 - debug: backitup.0 (4271) detect backup file 3 from cifs: iobroker_2021_04_16-12_00_36_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:34:40.870 - debug: backitup.0 (4271) detect backup file 4 from cifs: iobroker_2021_04_17-14_10_04_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:34:40.871 - debug: backitup.0 (4271) detect backup file 5 from cifs: iobroker_2021_04_17-14_12_03_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:34:40.872 - debug: backitup.0 (4271) detect last backup file: iobroker_2021_04_17-14_12_03_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:34:48.477 - debug: backitup.0 (4271) mount activ... umount in 2 Seconds!!
                    2021-04-19 11:34:50.549 - debug: backitup.0 (4271) umount successfully completed
                    2021-04-19 11:34:51.476 - debug: backitup.0 (4271) telegram-instance: telegram.0
                    2021-04-19 11:34:51.479 - debug: backitup.0 (4271) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"1440354501":{"firstName":"Anja"},"1455495559":{"firstName":"Michael","userName":"michael4358"}}
                    2021-04-19 11:34:54.699 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                    2021-04-19 11:34:54.716 - info: backitup.0 (4271) Got terminate signal TERMINATE_YOURSELF
                    2021-04-19 11:34:54.717 - info: backitup.0 (4271) cleaned everything up...
                    2021-04-19 11:34:54.718 - info: backitup.0 (4271) terminating
                    2021-04-19 11:34:54.720 - debug: backitup.0 (4271) Plugin sentry destroyed
                    2021-04-19 11:34:54.721 - info: backitup.0 (4271) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2021-04-19 11:34:54.717 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                    2021-04-19 11:34:55.382 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2021-04-19 11:34:57.759 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 4543
                    2021-04-19 11:35:00.906 - debug: backitup.0 (4543) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2021-04-19 11:35:00.944 - debug: backitup.0 (4543) Objects client ready ... initialize now
                    2021-04-19 11:35:00.967 - debug: backitup.0 (4543) Objects create System PubSub Client
                    2021-04-19 11:35:00.968 - debug: backitup.0 (4543) Objects create User PubSub Client
                    2021-04-19 11:35:00.969 - debug: backitup.0 (4543) Objects client initialize lua scripts
                    2021-04-19 11:35:00.984 - debug: backitup.0 (4543) Objects connected to redis: 127.0.0.1:9001
                    2021-04-19 11:35:00.994 - debug: backitup.0 (4543) objectDB connected
                    2021-04-19 11:35:00.996 - debug: backitup.0 (4543) Redis States: Use Redis connection: 127.0.0.1:9000
                    2021-04-19 11:35:01.005 - debug: backitup.0 (4543) States create System PubSub Client
                    2021-04-19 11:35:01.006 - debug: backitup.0 (4543) States create User PubSub Client
                    2021-04-19 11:35:01.015 - debug: backitup.0 (4543) States connected to redis: 127.0.0.1:9000
                    2021-04-19 11:35:01.016 - debug: backitup.0 (4543) statesDB connected
                    2021-04-19 11:35:01.412 - debug: backitup.0 (4543) Plugin sentry Initialize Plugin (enabled=true)
                    2021-04-19 11:35:01.645 - info: backitup.0 (4543) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
                    2021-04-19 11:35:01.738 - info: backitup.0 (4543) [iobroker] backup was activated at 12:00 every 5 day(s)
                    2021-04-19 11:35:01.768 - debug: backitup.0 (4543) [iobroker] 10 00 12 */5 * *
                    2021-04-19 11:35:01.891 - debug: backitup.0 (4543) first mount attempt with smb option failed. try next mount attempt without smb option ...
                    2021-04-19 11:35:02.043 - debug: backitup.0 (4543) mount successfully completed
                    2021-04-19 11:35:02.619 - error: backitup.0 (4543) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                    2021-04-19 11:35:02.640 - debug: backitup.0 (4543) Backup has started ...
                    2021-04-19 11:35:02.655 - debug: backitup.0 (4543) [iobroker/mount] mount activ... umount is started before mount!!
                    2021-04-19 11:35:02.716 - debug: backitup.0 (4543) [iobroker/mount] umount successfully completed
                    2021-04-19 11:35:04.110 - debug: backitup.0 (4543) detect backup file 1 from cifs: iobroker_2021_04_14-21_47_13_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:35:04.110 - debug: backitup.0 (4543) detect backup file 2 from cifs: iobroker_2021_04_14-21_48_53_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:35:04.111 - debug: backitup.0 (4543) detect backup file 3 from cifs: iobroker_2021_04_16-12_00_36_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:35:04.111 - debug: backitup.0 (4543) detect backup file 4 from cifs: iobroker_2021_04_17-14_10_04_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:35:04.112 - debug: backitup.0 (4543) detect backup file 5 from cifs: iobroker_2021_04_17-14_12_03_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:35:04.113 - debug: backitup.0 (4543) detect last backup file: iobroker_2021_04_17-14_12_03_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:35:12.710 - debug: backitup.0 (4543) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                    2021-04-19 11:35:12.873 - debug: backitup.0 (4543) [iobroker/mount] mount successfully completed
                    2021-04-19 11:35:12.874 - debug: backitup.0 (4543) [iobroker/mount] done
                    2021-04-19 11:35:16.110 - debug: backitup.0 (4543) [iobroker/iobroker] host.raspberrypi 3777 states saved
                    2021-04-19 11:35:16.202 - debug: backitup.0 (4543) [iobroker/iobroker] host.raspberrypi 6872 objects saved
                    2021-04-19 11:35:19.933 - debug: backitup.0 (4543) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_04_19-11_35_13_Pi4-1_backupiobroker.tar.gz
                    2021-04-19 11:35:20.984 - debug: backitup.0 (4543) [iobroker/iobroker] done
                    2021-04-19 11:35:21.739 - debug: backitup.0 (4543) [iobroker/historyDB] compress from historyDB started ...
                    2021-04-19 11:35:21.740 - debug: backitup.0 (4543) [iobroker/historyDB] [IGNORED] Backitup cannot found source "undefined" for compress!
                    2021-04-19 11:35:21.892 - debug: backitup.0 (4543) [iobroker/zigbee] found zigbee database: zigbee.0,zigbee.1
                    2021-04-19 11:35:21.893 - debug: backitup.0 (4543) [iobroker/zigbee] done
                    2021-04-19 11:35:22.197 - debug: backitup.0 (4543) [iobroker/jarvis] Jarvis Backup cannot created. Please install a Jarvis version >= 2.2.0
                    2021-04-19 11:35:22.200 - debug: backitup.0 (4543) [iobroker/jarvis] done
                    2021-04-19 11:35:22.802 - debug: backitup.0 (4543) [iobroker/cifs] done
                    2021-04-19 11:35:23.405 - debug: backitup.0 (4543) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                    2021-04-19 11:35:23.406 - debug: backitup.0 (4543) [iobroker/clean] done
                    2021-04-19 11:35:23.864 - debug: backitup.0 (4543) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                    2021-04-19 11:35:23.872 - debug: backitup.0 (4543) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                    2021-04-19 11:35:23.873 - debug: backitup.0 (4543) [iobroker/telegram] done
                    2021-04-19 11:35:24.178 - debug: backitup.0 (4543) [iobroker/historyHTML] new history html values created
                    2021-04-19 11:35:24.179 - debug: backitup.0 (4543) [iobroker/historyHTML] done
                    2021-04-19 11:35:24.369 - debug: backitup.0 (4543) [iobroker/historyJSON] new history json values created
                    2021-04-19 11:35:24.371 - debug: backitup.0 (4543) [iobroker/historyJSON] done
                    2021-04-19 11:35:24.581 - debug: backitup.0 (4543) [iobroker/umount] mount activ, umount is started ...
                    2021-04-19 11:35:29.652 - debug: backitup.0 (4543) [iobroker/umount] umount successfully completed
                    2021-04-19 11:35:29.654 - debug: backitup.0 (4543) [iobroker/umount] done
                    2021-04-19 11:35:29.805 - debug: backitup.0 (4543) [iobroker] exec: done
                    • simatec
                      @michael_4358 Dein History Pfad ist nicht eingetragen. Nutzt du den history-Adapter?
                        Ja nutze ich...
                        • simatec
                          @michael_4358
                          Zeige mal bitte, was du dort konfiguriert hast
                            @simatec
                            ob was drin steht oder nicht es kommt immer der gleiche fehler...
                            • simatec
                              @michael_4358 Trage mal bitte in dem History Adapter und in Backitup folgenden Pfad ein
                              /opt/iobroker/iobroker-data/history
                                Scheint zu funktionieren!
                                Danke dir
                                3474
