    4. Admin Problem
    Admin Problem
      Homoran Global Moderator Administrators @Jautze last edited by Homoran
      @jautze sagte in Admin Problem:
      Seit Samstag nach dem Update auf Admin 5.0.3 bzw. jetzt auf 5.0.4 lädt die Admin Oberfläche unendlich.
      Du weisst aber das admin 5.x noch sehr alpha ist?
      passt das hier?
      https://forum.iobroker.net/topic/44282/test-adapter-admin-5-0-x-alpha-der-neuen-ui/57?_=1618818514226
      J cash 2 Replies Last reply Reply Quote 0
        Jautze @Homoran last edited by
        nein nicht wirklich.
        Ich habe keine Errors im Log.
        marcel@IOBroker:/opt/iobroker$ less log/iobroker.current.log | grep admin.0
        2021-04-19 08:18:13.138  - info: host.IOBroker instance system.adapter.admin.0 started with pid 991
        2021-04-19 08:18:13.947  - info: admin.0 (991) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
        2021-04-19 08:18:13.967  - info: admin.0 (991) requesting all states
        2021-04-19 08:18:13.968  - info: admin.0 (991) requesting all objects
        2021-04-19 08:18:15.011  - info: admin.0 (991) received all objects
        2021-04-19 08:18:15.114  - info: admin.0 (991) http server listening on port 8081
        2021-04-19 08:18:15.114  - info: admin.0 (991) Use link "http://localhost:8081" to configure.
        2021-04-19 08:33:39.282  - info: host.IOBroker object deleted system.adapter.admin.0
        2021-04-19 08:33:39.282  - info: host.IOBroker stopInstance system.adapter.admin.0 (force=false, process=true)
        2021-04-19 08:33:39.287  - info: admin.0 (991) Got terminate signal TERMINATE_YOURSELF
        2021-04-19 08:33:39.293  - info: admin.0 (991) terminating http server on port 8081
        2021-04-19 08:33:39.294  - info: admin.0 (991) terminating
        2021-04-19 08:33:39.295  - info: admin.0 (991) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-04-19 08:33:39.328  - info: host.IOBroker stopInstance system.adapter.admin.0 send kill signal
        2021-04-19 08:33:39.912  - error: host.IOBroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2021-04-19 08:33:39.913  - info: host.IOBroker Do not restart adapter system.adapter.admin.0 because desired by instance
        2021-04-19 08:34:25.286  - info: host.IOBroker instance system.adapter.admin.0 started with pid 25302
        2021-04-19 08:34:26.595  - info: admin.0 (25302) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
        2021-04-19 08:34:26.617  - info: admin.0 (25302) requesting all states
        2021-04-19 08:34:26.618  - info: admin.0 (25302) requesting all objects
        2021-04-19 08:34:27.663  - info: admin.0 (25302) received all objects
        2021-04-19 08:34:27.756  - info: admin.0 (25302) http server listening on port 8081
        2021-04-19 08:34:27.756  - info: admin.0 (25302) Use link "http://localhost:8081" to configure.
        2021-04-19 08:34:27.819  - warn: admin.0 (25302) State "admin.0.info.newUpdates" has no existing object, this might lead to an error in future versions
        2021-04-19 08:34:27.820  - warn: admin.0 (25302) State "admin.0.info.updatesJson" has no existing object, this might lead to an error in future versions
        2021-04-19 08:34:27.820  - warn: admin.0 (25302) State "admin.0.info.lastUpdateCheck" has no existing object, this might lead to an error in future versions
        2021-04-19 08:42:59.988  - info: host.IOBroker stopInstance system.adapter.admin.0 (force=false, process=true)
        2021-04-19 08:43:00.098  - info: admin.0 (25302) Got terminate signal TERMINATE_YOURSELF
        2021-04-19 08:43:00.101  - info: admin.0 (25302) terminating http server on port 8081
        2021-04-19 08:43:00.102  - info: admin.0 (25302) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-04-19 08:43:00.192  - info: host.IOBroker stopInstance system.adapter.admin.0 send kill signal
        2021-04-19 08:43:02.704  - info: host.IOBroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-04-19 08:46:41.057  - info: host.IOBroker instance system.adapter.admin.0 started with pid 1475
        2021-04-19 08:47:02.215  - info: admin.0 (1475) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
        2021-04-19 08:47:02.241  - info: admin.0 (1475) requesting all states
        2021-04-19 08:47:02.241  - info: admin.0 (1475) requesting all objects
        2021-04-19 08:47:03.783  - info: admin.0 (1475) received all objects
        2021-04-19 08:47:22.890  - info: admin.0 (1475) http server listening on port 8081
        2021-04-19 08:47:22.890  - info: admin.0 (1475) Use link "http://localhost:8081" to configure.
        Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Jautze last edited by
          @jautze
          Mal neugestartet?
          Browser Cache gelöscht?
            es wäre trotzdem sinnvoll den Alpha-Test eines Adapters auch in dem zugehörigen Thread zu behandeln
              was hast du denn alles inzwischen gemacht
                Jautze @Homoran last edited by Jautze
                Cache, Cookies usw. gelöscht,
                anderer Browser
                IOBroker neustart
                VM neustart
                Logs durchgesehen.
                Admin von 5.0.3 auf 5.0.4 geupdated.
                Neuer Admin auf anderem Port installiert.
                Beide Admins gelöscht
                Neuen installiert
                und festgestellt das die Easy Admin Seite funktioniert.
                Ja ich glaube das war es. Mehr fällt mir nicht ein.
                Den Thread mit Admin 5 habe ich nicht gefunden nur diesen geöffneten.
                Danke und viele Grüße
                Marcel
                  hab ich dir verlinkt
                    Ja klar aber bevor ich da rein geschrieben habe habe ich es nicht gefunden.
                    Soll ich dort jetzt auch noch kommentieren.
                    Fällt dir noch irgendwas ein was ich noch probieren kann.
                    Marcel
                      Jautze @Jautze last edited by
                      Ich habe jetzt mal über Easy Admin React aktiviert und damit funktioniert die Admin Seite.
                        A Former User @Jautze last edited by
                        @jautze Kannst du mal genau beschreiben wie du das gemacht hast. Ich habe das gleiche Problem.
                          legro @Guest last edited by legro
                          Bei meinen allwöchentlichen Updates habe aus Versehen auf Admin 5.0.5 aktualisiert. Jetzt geht die Anmeldung nicht mehr; ich komme nicht mehr ins System.
                          Die Fehlermeldung lautet: .. Server hat die Verbindung unterbrochen ..
                          Gibt es eine Möglichkeit zurück auf 4.2.1 ohne die Admin-Oberfläche verwenden zu müssen? Gibt es also eine Möglichkeit über die Konsole den Adapter auszutauschen?
                            crunchip Forum Testing Most Active @legro last edited by
                            @legro siehe oben https://forum.iobroker.net/post/617299
                            • cash
                              cash Most Active @Homoran last edited by
                              @homoran Dies ist ein gutes Beispiel warum ein Alpha-Test nicht in den Beta-Channel (latest) gehört.
                                Homoran Global Moderator Administrators @cash last edited by
                                @cash sagte in Admin Problem:
                                das stimmt nur teilweise.
                                Der Alpha-Status bezieht sich auf die neue react Oberfläche.
                                und diese muss bewusst aktiviert werden
                                  legro @crunchip last edited by
                                  @crunchip
                                  Mir ist schon klar, dass die neue Version noch nicht als stabil gilt. Es war ja auch ein Versehen meinerseits, dass ich auf den Aktualisierungsknopf gedrückt habe. Das war nicht beabsichtigt.
                                  Sei's d'rum. Da spiele ich das letzte mit ApplePiBaker erstellte Abbild der SD-Karte wieder ein. Damit geht mir jedoch die Arbeit von zwei Tagen verloren.
                                    Thomas Braun Most Active @legro last edited by
                                    @legro
                                    Warum haust du den Admin nicht über Kommandozeile rein?
                                    iobroker set admin.0 --react false
                                    Falls gar nichts mehr mit Admin geht kann mittels
                                    iobroker install admin@4.2.1
                                    ein Downgrade gemacht werden
                                      legro @Thomas Braun last edited by legro
                                      @thomas-braun said in Admin Problem:
                                      Vielen Dank. Genau danach hatte ich gefragt und hilft das mir sehr.
                                      Bei mir zeigt sich der Fehler darin, dass die Anmeldung nicht mehr geht. Ich komme also gar nicht mehr ins System.
                                      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                        @legro
                                        Auch mit dem admin 4.2.1?
                                          @legro sagte in Admin Problem:
                                          So ausführlich wie @Thomas-Braun hab ich es zwar nicht gemacht, aber den Link für dein Problem gezeigt, in dem hättest du die Lösung gefunden.
                                            @legro
                                            Mit dieser alten Version hatte ich nie Probleme.
                                            Nun werkelt wieder die 4.2.1 bei mir und alles ist gut.🙂
                                            adapter iobroker
                                            11
                                            74
                                            5465
