    4. Backit-Up Error beim erstellen Grafana, Influx und JS
    • U
      Urs last edited by
      @thomas-braun sagte in Backit-Up Error beim erstellen Grafana, Influx und JS:
      Influx läuft lokal auf dem Rechner auf dem auch der ioBroker läuft?
      Auf dem gleichen NUC, ja, aber in unterschiedliche Proxmox Container (sorry das ich das nicht vorher erwähnt habe). Iobroker lebt an der Adresse192.168.1.10, Influx und Grafana an 192.168.1.16.
      Hab jetzt den influx-client nachinstalliert.
      Komme offenbar einen Schritt weiter, bin aber noch nicht am Ziel:
      [DEBUG] [influxDB] - Start InfluxDB Backup ...
      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.1.16:8088 "/opt/iobroker/backups/influxDB_2021_04_19-19_23_41_backupiobroker"
      2021/04/19 19:23:41 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 2s and retrying (0)...
      2021/04/19 19:23:43 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 2s and retrying (1)...
      2021/04/19 19:23:45 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 2s and retrying (2)...
      2021/04/19 19:23:47 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 2s and retrying (3)...
      2021/04/19 19:23:49 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 2s and retrying (4)...
      2021/04/19 19:23:51 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 2s and retrying (5)...
      2021/04/19 19:23:53 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
      2021/04/19 19:23:56 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
      2021/04/19 19:24:07 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
      2021/04/19 19:24:51 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
      backup: dial tcp 192.168.1.16:8088: connect: connection refused
      Ein Portscanner sieht nur die Ports 22, 3000(Grafana) und 8086, nicht aber den 8088.
      in /etc/influxdb/influxdb.conf hab ich testweise bind-adress = "0.0.0.0:8088" eingegeben. Hat aber irgendwie nichts gebracht.
      Irgendwelche weitere Ideen?
      Bei JS liegt der Spiegel außerhalb von /opt/iobroker ?
      Keine Ahnung . Wie checke ich das?
      wendy2702 simatec 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @Urs last edited by
        @urs Ich weiss garnicht ob der Adapter das kann wenn Influx auf einer anderen Maschine läuft.
        Aber warum richtest du nicht für den Ibflux/Grafana Container ein automatisches Backup unter Proxmox ein wenn es eh ein eigener Container ist. Der Adapter würde ja eh nur die DB sichern und du müsstest Influx eh neu installieren wenn der Container abschmiert.
        simatec U 2 Replies Last reply Reply Quote 0
        • simatec
          simatec Developer Most Active @wendy2702 last edited by
          @Urs Für Influx Backups auf einem anderen System musst du in Backitup auf Remote stellen und die IP des Influx Servers eintragen
          • simatec
            simatec Developer Most Active @Urs last edited by
            @urs sagte in Backit-Up Error beim erstellen Grafana, Influx und JS:
            Zeige mal die Einstellungen vom Spiegelpfad im JavaScript Adapter und die von Backitup
            • wendy2702
              wendy2702 @simatec last edited by
              @simatec sagte in Backit-Up Error beim erstellen Grafana, Influx und JS:
              Auch wieder was gelernt.
              • U
                Urs @wendy2702 last edited by
                @wendy2702 sagte in Backit-Up Error beim erstellen Grafana, Influx und JS:
                Das ist schon so eingerichtet, aber da ist der Platz begrenzt. Daher kann ich da auch nur maximal 10 Backups vorhalten und wenn der Proxmox verreckt ist alles weg. Wollte ja mal die Backups auf eine externe Platte welche an der Fritzbox hängt auslagern, aber nachdem ich auch nach tagelangem herumgebastel an der Linuxkonsole nicht hinbekommen habe diese unter Proxmox einzubinden hab ich das aufgegeben. Das nächste Problem ist die Dateigrösse. Den ganzen Container zu speichern benötigt 1.7Gb, das geht sicher auch schlanker indem man nur die unersetzlichen Daten speichert.
                Das hatte ich gemacht und ich denke das sollte so passen:
                Meinst Du das?
                • wendy2702
                  Ja, geht bestimmt schlanker.
                  Wobei mir sich bis heute die Frage nach unersetzlichen Daten in einer Smarthome Datenbank stellt. Aber das ist immer eine persönliche Sache und hat nichts mit deinem Problem zu tun.
                  • simatec
                    @urs
                    Hast du influx auch auf deinem System, auf dem iobroker läuft installiert?
                    Des Weiteren muss influx nach Änderungen in der conf neugestartet werden. Also wenn du bind geändert hast, bitte im Anschluss neustarten.
                    Der Pfad /opt/iobroker ist zum spiegeln sehr schlecht. Nimm einen eigenen Ordner dafür.
                    Bei mir ist das z.B /opt/iobroker /scripts
                    • U
                      Urs @simatec last edited by
                      Eigentlich nicht. Müsste ich das?
                      Ich meine da hab ich das genommen was der JS-Adapter vorgeschlagen hat. Und der Backitup-Adapter hat sich dann das von dort gekrallt.
                      Also mal auf /opt/iobroker/scripts umgestellt und siehe da, es werden 18MB Skripte gepackt und auch auf dem Netzlaufwerk gespeichert. Super Danke schonmal dafür.
                      Allerdings ist immer noch das Problem dass InfluxDB keinen Zugriff gewährt. Ich denke da ist der Port schlicht und einfach noch zu...muss ich nochmal anschauen. Und ja, ich hab da jedes mal als ich was geändert habe die Maschine mit dem Influx/Grafana drauf neu gestartet, leider ohne erfolg.
                      Was mir aber im Moment mehr sorgen macht ist dass der Iobroker selber keine Backups schreibt. Hier das aktuelle Log
                      backitup.0	2021-04-19 22:11:57.106	debug	(381) system.adapter.admin.0: logging true
                      backitup.0	2021-04-19 22:11:34.788	debug	(381) [iobroker] exec: done
                      backitup.0	2021-04-19 22:11:34.637	debug	(381) [iobroker/umount] done
                      backitup.0	2021-04-19 22:11:34.636	debug	(381) [iobroker/umount] umount successfully completed
                      backitup.0	2021-04-19 22:11:29.599	debug	(381) [iobroker/umount] mount activ, umount is started ...
                      backitup.0	2021-04-19 22:11:29.440	debug	(381) [iobroker/historyJSON] done
                      backitup.0	2021-04-19 22:11:29.440	debug	(381) [iobroker/historyJSON] new history json values created
                      backitup.0	2021-04-19 22:11:29.027	debug	(381) [iobroker/historyHTML] done
                      backitup.0	2021-04-19 22:11:29.027	debug	(381) [iobroker/historyHTML] new history html values created
                      backitup.0	2021-04-19 22:11:28.423	debug	(381) [iobroker/email] done
                      backitup.0	2021-04-19 22:11:28.423	debug	(381) sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                      backitup.0	2021-04-19 22:11:28.269	debug	(381) [iobroker/clean] done
                      backitup.0	2021-04-19 22:11:28.269	debug	(381) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                      backitup.0	2021-04-19 22:11:27.667	debug	(381) [iobroker/cifs] done
                      backitup.0	2021-04-19 22:11:27.365	debug	(381) [iobroker/javascripts] done
                      backitup.0	2021-04-19 22:11:27.362	debug	(381) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2021_04_19-22_11_19_backupiobroker.tar.gz
                      backitup.0	2021-04-19 22:11:24.764	debug	(381) [iobroker/javascripts] Packed 18MB so far...
                      backitup.0	2021-04-19 22:11:19.290	debug	(381) [iobroker/grafana] done
                      backitup.0	2021-04-19 22:11:19.290	debug	(381) [iobroker/grafana] cannot found Grafana Backup files
                      backitup.0	2021-04-19 22:11:19.290	debug	(381) [iobroker/grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                      backitup.0	2021-04-19 22:11:16.706	debug	(381) [iobroker/grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                      backitup.0	2021-04-19 22:11:14.363	debug	(381) [iobroker/grafana] start Grafana backup compress ...
                      backitup.0	2021-04-19 22:11:14.362	debug	(381) [iobroker/grafana] found Dashboard: proxmox-ve-home
                      backitup.0	2021-04-19 22:11:14.358	debug	(381) [iobroker/grafana] found Dashboard: proxmox-ve-node
                      backitup.0	2021-04-19 22:11:14.357	debug	(381) [iobroker/grafana] found Dashboard: proxmox-vm-overview
                      backitup.0	2021-04-19 22:11:14.353	debug	(381) [iobroker/grafana] found Dashboard: proxmox
                      backitup.0	2021-04-19 22:11:14.337	debug	(381) [iobroker/grafana] found Dashboard: proxmox-ve-alert
                      backitup.0	2021-04-19 22:11:14.309	debug	(381) [iobroker/grafana] found Dashboard: proxmox-ve-kvm
                      backitup.0	2021-04-19 22:11:14.295	debug	(381) [iobroker/grafana] found Dashboard: proxmox-ve-network
                      backitup.0	2021-04-19 22:11:14.268	debug	(381) [iobroker/grafana] found Dashboard: proxmox-ve-storages
                      backitup.0	2021-04-19 22:11:14.240	debug	(381) [iobroker/grafana] found Dashboard: new-dashboard-copy
                      backitup.0	2021-04-19 22:11:14.197	debug	(381) [iobroker/grafana] Error on Grafana Datasource Request
                      backitup.0	2021-04-19 22:11:14.179	debug	(381) [iobroker/grafana] Grafana is available ... Status: 200
                      backitup.0	2021-04-19 22:11:14.158	debug	(381) [iobroker/grafana] start Grafana request ...
                      backitup.0	2021-04-19 22:11:14.139	debug	(381) [iobroker/grafana] Created datasource directory
                      backitup.0	2021-04-19 22:11:13.605	debug	(381) [iobroker/grafana] Created dashboards_manually_restore directory
                      backitup.0	2021-04-19 22:11:13.511	debug	(381) [iobroker/grafana] Created dashboard directory
                      backitup.0	2021-04-19 22:11:13.425	debug	(381) [iobroker/grafana] Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                      backitup.0	2021-04-19 22:11:13.335	debug	(381) [iobroker/grafana] Start Grafana Backup ...
                      backitup.0	2021-04-19 22:11:12.431	debug	(381) [iobroker/influxDB] backup: dial tcp 192.168.1.16:8088: connect: connection refused
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:08:27 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 2m45.216s and retrying (9)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:43 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 43.477s and retrying (8)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:32 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 11.441s and retrying (7)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:29 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 3.01s and retrying (6)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:27 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 2s and retrying (5)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:25 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 2s and retrying (4)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:23 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 2s and retrying (3)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:21 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 2s and retrying (2)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:19 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 2s and retrying (1)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] 2021/04/19 22:07:17 Download shard 0 failed dial tcp 192.168.1.16:8088: connect: connection refused. Waiting 2s and retrying (0)...
                      backitup.0	2021-04-19 22:11:12.430	debug	(381) [iobroker/influxDB] [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.1.16:8088 "/opt/iobroker/backups/influxDB_2021_04_19-22_07_16_backupiobroker"
                      backitup.0	2021-04-19 22:11:12.429	debug	(381) [iobroker/influxDB] InfluxDB tmp directory was successfully deleted
                      backitup.0	2021-04-19 22:11:12.251	debug	(381) [iobroker/influxDB] Try deleting the InfluxDB tmp directory
                      backitup.0	2021-04-19 22:07:16.983	debug	(381) [iobroker/influxDB] InfluxDB Backup tmp directory created
                      backitup.0	2021-04-19 22:07:16.863	debug	(381) [iobroker/influxDB] Start InfluxDB Backup ...
                      backitup.0	2021-04-19 22:07:16.712	debug	(381) [iobroker/iobroker] done
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at processTicksAndRejections (internal/process/task_queues.js:93:5)
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at /opt/iobroker/node_modules/standard-as-callback/built/index.js:30:51
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] Emitted 'error' event on ScanStream instance at:
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at TCP.<anonymous> (net.js:673:12)
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at Socket.emit (events.js:315:20)
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at Object.onceWrapper (events.js:422:26)
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20)
                      backitup.0	2021-04-19 22:07:16.642	debug	(381) [iobroker/iobroker] at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25)
                      backitup.0	2021-04-19 22:07:16.641	debug	(381) [iobroker/iobroker] Error: Connection is closed.
                      backitup.0	2021-04-19 22:07:16.641	debug	(381) [iobroker/iobroker] ^
                      backitup.0	2021-04-19 22:07:16.641	debug	(381) [iobroker/iobroker] throw e;
                      backitup.0	2021-04-19 22:07:16.641	debug	(381) [iobroker/iobroker] /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                      backitup.0	2021-04-19 22:07:16.628	debug	(381) [iobroker/iobroker] at processTicksAndRejections (internal/process/task_queues.js:93:5)
                      backitup.0	2021-04-19 22:07:16.628	debug	(381) [iobroker/iobroker] at runMicrotasks (<anonymous>)
                      backitup.0	2021-04-19 22:07:16.628	debug	(381) [iobroker/iobroker] at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:384:79
                      backitup.0	2021-04-19 22:07:16.628	debug	(381) [iobroker/iobroker] at JSON.stringify (<anonymous>)
                      backitup.0	2021-04-19 22:07:16.627	debug	(381) [iobroker/iobroker] Uncaught Rejection: RangeError: Invalid string length
                      backitup.0	2021-04-19 22:07:12.717	debug	(381) [iobroker/iobroker] host.Iobroker-Live 51012 objects saved
                      backitup.0	2021-04-19 22:07:12.647	debug	(381) [iobroker/iobroker] host.Iobroker-Live 33345 states saved
                      backitup.0	2021-04-19 22:07:05.043	debug	(381) [iobroker/mount] done
                      backitup.0	2021-04-19 22:07:05.042	debug	(381) [iobroker/mount] mount successfully completed
                      backitup.0	2021-04-19 22:06:54.814	debug	(381) Backup has started ...
                      backitup.0	2021-04-19 22:06:52.747	debug	(381) system.adapter.admin.0: logging false
                      Das was da um Zeile 75 rum läuft macht mir sorgen.
                      • simatec
                        @urs
                        Schaue mal in die Readme.
                        https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#InfluxDB-Backup
                        • U
                          @simatec Ja, sorry, wer lesen kann ist klar im Vorteil...vielen Dank.
                          Werde ich mich dann morgen dran machen.
                          Da gibt es inzwischen eine v2.x der InfluxDB. Auf der bereits laufenden Maschine habe ich v1.8.x. Läuft Backitup auch mit v2.x und sollte ich dann auch die bereits laufende auf v2.x hoch ziehen oder doch besser erstmal auch auf dem Iobroker-System v1.8.x installieren?
                            Thomas Braun Most Active @Urs last edited by Thomas Braun
                            @urs Ich würde da nur die Version aus dem Paketmanager nehmen. Soweit ich weiß ist das die 1.8
                            Mit V2 gibt es wohl noch ein wenig Kopfweh.
                            • U
                              Urs @Thomas Braun last edited by
                              Vielen Dank
                                @urs
                                pi@raspberrypi:~ $ apt policy influxdb                         influxdb:
                                  Installiert:           (keine)
                                  Installationskandidat: 1.8.4-1
                                  Versionstabelle:
                                     1.8.4-1 500
                                        500 https://repos.influxdata.com/debian buster/stable armhf Packages
                                     1.6.4-1+deb10u1 500
                                pi@raspberrypi:~ $
                                • U
                                  Die Error so von wegen invalid string length usw von Iobroker aus dem obigen Log hab ich nun auch gelöst. Was die Ursache war weiss ich nicht wirklich. Hab mal eben ein Backup von vor 5 Tagen oder so zurückgespielt und gut ist. Kann nur vermuten dass auch das irgendwie mit Node Red und dem Javascript-Adapter zusammen hängt, denn in den letzten Tagen hab ich mal ein wenig mit node red herumgespielt. Dabei wurde das System extremst träge (trotz NUC mit entsprechend CPU-Leistung und 8GB Ram). Hab dann Node Red wieder runter geschmissen, aber da ist wohl noch sehr viel Datenmüll übrig geblieben, denn das waren noch 51000 Objekte vorhanden, die meisten davon unter Javascript.0 und script.js. Nun nach dem Backup einspielen sind nur noch knapp 20000 Objekte da und das Backup der Javascripts beträgt auch nur noch 17Mb anstatt 64Mb. Also irgendwas ist da massiv schief gelaufen... Aber das nur der Vollständigkeit halber.
                                  Influx und Grafana sichern bin ich noch nicht dazu gekommen, aber wie muss ich das Influx auf dem Iobroker-System aufsetzen? Nur so dass es läuft oder muss es 1:1 dem der die Daten speichert entsprechen? Also wenn ich auf dem Produktiv-Influx z.B 3 Datenbanken drauf hab (iobroker, NUC, NAS), muss ich dann genau die Datenbanken auch im Iobroker-System erstellen? Und die gleichen Login-Daten benutzen?
                                  984
