    4. [Vorstellung] Meine dritte VIS
      Kuddel @Jens Meyer last edited by
      @jens-meyer hier der javascript export
      // import
      const moment = require("moment");
      const momentDurationFormatSetup = require("moment-duration-format");
      moment.locale("de");
      let enigma2AdapterRecordListId = 'enigma2.0.enigma2.MOVIE_LIST';
      on({ id: enigma2AdapterRecordListId }, formatList);
      function formatList() {
         try {
             let list = JSON.parse(getState(enigma2AdapterRecordListId).val);
             let myList = [];
             if (list && list !== null && list !== undefined && list !== '') {
                 for (var i = 0; i <= list.length - 1; i++) {
                     let listItem = list[i]
                     let recordTime = moment(listItem.recordingtime * 1000);
                     let recordDateFormatted = `${recordTime.format('ddd')} ${recordTime.format('DD.MM.')}`;
                     let recordTimeFormatted = `${recordTime.format('LT')}`
                     if (moment().isSame(recordTime, 'day')) {
                         recordDateFormatted = `Heute ${recordTime.format('DD.MM.')}`;
                     } else if (moment().add(-1, 'day').isSame(recordTime, 'day')) {
                         recordDateFormatted = `Gestern ${recordTime.format('DD.MM.')}`;
                     let rawtitle = listItem.eventname;
                     let title = rawtitle;
                     let subtitle = listItem.subtitle;
                     if (title.includes(' - ')) {
                         title = rawtitle.substring(0, rawtitle.indexOf(' - ')).trim();
                         subtitle = rawtitle.substring(rawtitle.indexOf(' - ') + 2, rawtitle.length).trim();
                         if (subtitle === undefined) {
                             subtitle = '';
                     myList.push(
                             channelImage: `http://192.168.4.24:8080/picon/${listItem.serviceRefName}.png`,
                             channel: listItem.servicename,
                             title: title,
                             recordDateFormatted: recordDateFormatted,
                             recordTimeFormatted: recordTimeFormatted,
                             dauer: listItem.length,
                             groesse: listItem.filesize_readable,
                             recordTime: listItem.recordingtime //In der VIS ausgeblendet
                             //lenght: listItem.length + ' min, ' + listItem.filesize_readable,
                             //subtitle: subtitle,
                             //size: listItem.filesize_readable,
                 setState('javascript.0.sonstige.vu_aufnahmen_liste', JSON.stringify(myList), true);
         } catch (err) {
             console.error(`[formatList] error: ${err.message}`);
             console.error(`[formatList] stack: ${err.stack}`);
      formatList();
      Die IP vom Receiver und die DPs müssen noch angepasst werden
      Jens Meyer 1 Reply Last reply Reply Quote 0
      • Jens Meyer
        Jens Meyer @Kuddel last edited by
        @kuddel
        vielen dank...top!
          samot13 last edited by
          @Kuddel
          Hallo Kuddel,
          ich habe versucht deine visu zu importieren aber ich habe Probleme mit dem Submenues.
          Hast du, bzw. einer eine Idee was da schief läuft?
          Ich habe den iobroker neu aufgesetzt.
          Gibt es bekannte Probleme mit Nodes12 ?
          Danke und Gruß
          samot13
          K Glasfaser 2 Replies Last reply Reply Quote 0
            Kuddel @samot13 last edited by
            @samot13 welche Version vom Adapter "Material Design Widgets" verwendest du ?
            Meine VIS läuft mit Version 0.2.54.
            Ich weiß, dass es bei neueren Version zu Probleme mit dem Menü kommt.
            Hatte leider noch keine Zeit, das Ganze zu aktualisieren
            • Glasfaser
              Glasfaser @samot13 last edited by
              @samot13 sagte in [Vorstellung] Meine dritte VIS:
              hier ist es erklärt was man ändern muß :
              https://forum.iobroker.net/topic/29660/material-design-widgets-top-app-bar-widget/207?_=1617005272342
                @ Kuddel: Ich verwende 0.4.42
                Ich werde es mal mit der älteren Versuchen oder ich schaue mir die Änderungen vom Link mal an.
                Danke für die Info
                @ Glasfaser: Danke für den Link
                • maximal1981
                  maximal1981 last edited by
                  erstmal echt super Arbeit.
                  Gefällt mir echt gut, und versuche die Datenpunkte an meine anzupassen.
                  Bin erst auf der Startseite über das Wetter-Widget hinaus gekommen, und stehe schon an.
                  Ich suche wie ein Irrer die Befüllung der javascript.0.zeiten.*. bin entweder blind oder hab diese irgendwie nicht im Projekt, oder gelöscht. Bitte um Unterstützung.
                  mfg maximal1981
                    Kuddel @maximal1981 last edited by
                    @maximal1981 hast du denn bzgl. der Datenobjekte ein Skript von mir importiert ?
                    blockly_export_zeiten.txt
                    maximal1981 1 Reply Last reply Reply Quote 0
                    • maximal1981
                      maximal1981 @Kuddel last edited by
                      @kuddel doch, hab nur mal alle deaktiviert, da ich sonst natürlich lauter Fehler wegen falschen Datenpunkten habe, und dann die "zeiten_v01" übersehen/-lesen.
                      Danke für die Antwort.
                      Mein Problem ist, dass ich keine Ahnung habe welche Scripts mit welchen Widgets zusammenspielen.
                      eine Vermutung ist z.B. für die Rollo-Steuerung auf der Main benötigt man folgendes:
                      • zeiten_v01 (muss mal eine Nacht an sein, damit alle nötigen Werte vorhanden sind = Vermutung)
                      • rolladen_tag_nacht
                      gibt es irgendwie im ioBroker die Möglichkeit Abhängigkeit aufzulösen, bzw. welche Varaiblen wo vorhanden sind um die übergeordneten Scripts zu finden?
                      C K 2 Replies Last reply Reply Quote 0
                        ChrisXY @maximal1981 last edited by ChrisXY
                        Habe auch das Menü kaputt. Leider verstehe ich nicht genau was ich da ändern/anpassen muss. Jemand eine Anleitung oder ein ausgebessertes menü??
                        • Glasfaser
                          Glasfaser @ChrisXY last edited by
                          @chrisxy sagte in [Vorstellung] Meine dritte VIS:
                          da ist nicht´s kaputt.
                          Ein paar Beiträge über deinem ist ein Link zum passenden Thread !
                            @maximal1981 die zeiten an sich können ohne Abhängigkeiten erstellt werden, wie z.B. Tageslänge.
                            Auf der Main kann man einstellen, wann die Rollos hoch- / herunterfahren sollen.
                            Dafür ist dann das Skript rolladen_tag_nacht, welches die DPs aus dem Zeiten Skirpt verwendet
                            • maximal1981
                              maximal1981 @Kuddel last edited by maximal1981
                              @kuddel du hast meine Frage falsch interpretiert, aber habe die Lösungen teilweise schon selbst gefunden.
                              Aber ein paar Fragen hab ich (gibt sicher mehr, aber die fallen mir gerade ein 🤠) :
                              • ich bekomme die Akkustand_History nicht hin. ist ein extrem langer flot-Link. Muss man dafür vermutlich auch Datenpunkte in einer History speichern, wenn ja mit welchen settings, und wie baut man dann den Chart-Link auf?
                              • bei der Darstellung vom Vis egal am Laptop oder Tablet habe ich nach rechts noch ca. einen halben Screen zum Scrollen. Kann man das kürzen bzw. nach dem Ende abschneiden?
                              • bei der Darstellung am Tablet mit Fully-Browser (am Laptop auch aber da ist es mir egal) hab ich das Problem, dass das Vis größer ist als der Screen. Man kann es zwar zoomen, aber nach einem reload bzw. Seitenwechsel ist der manuelle Zoom von gefüllt 90 % natürlich wieder auf 100 %. Vermutlich kann man das wo einstellen, finde es aber nicht.
                              • kann es sein, dass du für den Fully-Browser um ca. 7 € eine Lifetime Lizenz gekauft hast, und diese eigentlich auch mehr oder weniger für die 100 %ige Kompatibilität benötigt wird?
                              • wenn ich auf den Saugroboter-View wechsle, geht er nach 1 sec wieder auf die Startseite zurück. Des Weiteren hab ich den View Jump üer die Zahlen auch noch nicht verstanden, wie/wo wird das über die Zahl umgesetzt?
                              Für alle anderen:
                              • um Variablen in den Scripts zu finden, gibt es im ioBroker unter Scripts - wo man dann common, java, smarthome, sowie seine eigenen Scripts sieht - oben rechts eine Lupe. Dort dann den Varaiblennamen oder Teile davon eingeben, und es werden alles Scripts aufgelistet, welche diesen enthalten, egal ob zum Setzen, Trigger oder Bedingung
                              • in den einzelnen Views gibt es unzählige Widgets die übereinander liegen. z.B. bei Müllabfuhr in ... sind es 3 Widgets, bei Akkuanzeige sogar 5. Ich habe bis dato immer alle weggeschoben, jedoch kann man das viel leichter wenn man die aktiven Widgets durcharbeitet^^
                              • zur allgemeinen Erleichterung habe ich noch die Scripts und das Vis in einem Ordner abgelegt, und suche mir dort mittels SearchMyFiles Abhängigkeiten heraus, wenn ich mich gar nicht durchblicke wie was zusammenspielt
                              hoffe den einem oder anderen Vis/Script-Neuling hilft die Ausführung um auch hier mal Fuß zu fassen und nicht gleich verzweifelt. Hätte auch schon fast aufgegeben, wenn mir nicht Kuddels Vis so gefallen würde 😍 🤛
                                WeiserWolf @Kuddel last edited by
                                @kuddel
                                Die VIS ist einfach genial. Da ich grade erst mit iobroker anfange, habe ich gedacht ich nehme mir eine fertiges VIS und alles wird gut, naja purer Anfängerwahnsinn 🙂
                                Naja ich bin jetzt dazu übergegangen mir erst einmal einzelne Teile kopieren zu wollen in mein Projekt.
                                In erster Linie geht es um Anwesenheit und die IP-Kamera.
                                würde das gehen, wenn ich mir einzelne views in mein Projekt hole (die nötigen Adapter habe ich installiert)? Mir ist nur nicht wirklich klar, wie und wo was zu machen ist, um die
                                abzufragenden Geräte zu definieren. Kommt das alles aus dem UniFi-Controller?
                                Ich hatte mir den Master-Kurs von haus-automatisierung gegönnt, aber es hat mich irgendwie nicht weitergebracht, weil das Themas VIS überhaupt nicht behandelt wurde.
                                Aber das kommt davon, wenn man als Kreisligist meint, man könnte in der Champions-League mitspielen und auch noch gewinnen 😄
                                Wäre schön, wenn ich nicht gleich gesteinigt werde und jemand bereit ist mir da ein bisschen zu helfen. Danke schonmal 🙂
                                Wolf
                                  @maximal1981 sagte in [Vorstellung] Meine dritte VIS:
                                    -> Ja der DP muss vom History Adapter geloggt werden, sonst kann Flot nichts anzeigen
                                    -> Du musst einfach nur die Breite vom Widget "!View_Anzeige" auf Seite 0000_Startseite ändern
                                    -> Den Zoom kann man im FullyBrowser einstellenm, damit die VIS korrekt angezeigt wird. Musst du mal suchen. Wei so auch nicht genau, wo man das machen kann.
                                    -> Ja ich habe mal eine Liznez für 5€ gekauft, ob das aber eine Lifetime ist, weiß ich nicht. Auf jeden Fall gingen bei mir ein paar Feature nicht ohne Lizenz
                                    Im DP "javascript.0.VIS-Steuerung.Aktuelle_VIS_Seite" steht die aktuelle VIS Seite als Zahl. Dieser DP wird auch im Widget "!View_Anzeigen" auf Seite 0000_Startseite verwendet. Dort muss man alle Views eintragen. Zb 0 = Starseite. Ändern man also die Zahl im DP, weiß das Widget, welcher View angezeigt werden soll.
                                  Für alle anderen:
                                  Ich habe deine Fragen mal direkt im zitierten Block beantwortet
                                    Kuddel @WeiserWolf last edited by
                                    @weiserwolf die Anwesenheit regele ich primär über den Radar2 Adapter. Dort wird nach den Handys gesucht.
                                    Das funktioniert auch komplett ohne Unifi Adapter.
                                    Du kannst dir natürlich einzelne WIdgets oder Seiten exportieren und bei dir einfügen. So habe ich es bei meiner zweiten VIS auch gemacht.
                                    Importiere dir einfach meine komplette VIS und öffne sie im Editor.
                                    Dann machst du einen neuen Tab mit dem Editor und deiner VIS auf und kannst dann kopieren wie du lustig bist
                                      @kuddel Das Prinzip habe ich angewendet. Ich habe deien VIS 1:1 importiert und alle Adapter installiert die du verwendest (also bevor ich das Projekt importiere). Manche Icons fehlen (z.B. beim Wetter, weil deine IP nicht zu meiner passt, logisch) das kriege ich auch geregelt. Beim Wetter der Mond beispielsweise: Wie kann ich hier die Icons anpassen? Kann ich die originalen einfach überschreiben?
                                      Diesen Code hier habe ich als Script angelegt und einmalig ausführen lassen. War das so richtig?
                                      Ich habe versucht die Anwesenheitserkennung nachzuvollziehen und auf meine Bedürfnisse anzupassen, aber ich steige überhaupt nicht durch irgendwie. Das Widget Daniel verweist auf: javascript.0.VIS-Steuerung.Aktuelle_VIS_Seite mit Wert 4. Was sagt die "4" in dem Fall eigentlich aus? Die Zeit der letzten Statusänderung verweist auf "javascript.0.Anwesenheit.Daniel" wo finde ich das wieder?
                                      Entweder ich habe hier irgendwas grundsätzlich nicht verstanden und bin einfach zu blöd, oder hier ist beim Import etwas schief gelaufen. 😵
                                        @weiserwolf dein Codeschnipsel ist nur ein DP und kein Script.
                                        Mit dem DP wird gesteuert, welche Seite im VIS angezeigt wird.
                                        Die Mond Icons muss du importieren und dann enstprechend dem Pfad im Widget anpassen.
                                        "javascript.0.Anwesenheit.Daniel" ist der DP, der sagt, ob ich anwesend bin oder nicht.
                                        Auf der Startseite ist das Widget aber auch ein Navigations-Widget. Deswegen die 4 für den DP "javascript.0.VIS-Steuerung.Aktuelle_VIS_Seite ".
                                        D.h. wenn du auf das Icon klickst, landest auf Seite 4 (Geräte)
                                        Die Farbe (anwesend = gründ / abwesend = rot) wird über ein Binding bei der Rahemfarbe des Widget gesteuert.
                                        Da findes du auch "javascript.0.Anwesenheit.Daniel" wieder.
                                        Ich schlage vor, dass wir ein Thema nach dem anderen bearbeiten.
                                        1. Mond / Wetter etc.
                                        2. Anwesenheit
                                          WeiserWolf last edited by WeiserWolf
                                          @kuddel Also ich glaube ich habe meine Fehler grade gefunden was die Wetter-Geschichte angeht. Ich werde diesbezüglich noch etwas probieren. Deine lokale IP wird nicht zu meiner passen 🙂
                                          Zum Thema Anwesenheit hattest du gesagt UniFi brauche ich nicht unbedingt, das wird über Rader 2.0 gemacht.
                                          Ich habe alles was bei dir mit javascript.0 etc gefüllt war, durch "radar2.0.iPhone12Pro._here" ersetzt um überhaupt mal eine Anzeige zu bekommen. funktioniert auch in gewissem Rahmen, aber nach 3 Minuten sind die Geräte grundsätzlich abwesend.
                                          Also werde ich alles wieder rückgängig machen und versuchen den UniFi Adapter ans laufen zu bekommen, damit ich überhaupt die Objekte aus dem Anwesenheitsskript in Blocky zu erhalten um diese dann auf meine Geräte umzuschreiben.
                                          Ich glaube es hapert einfach am Verständnis...
                                          In Abhängigkeit der Anwesenheit kann ich doch bestimmt (wenn es dann mal funktioniert) auch einen API Befehl im Netzwerk absetzen oder? Ich möchte damit gerne den Home-Mode der Surveillance-Station auf meiner Synology steuern. Aber okay soweit bin ich noch lange nicht.
                                          Der Codeschnipsel ist nur ein DP, hast du gesagt, aber mal so für ganz doofe: Was mache ich damit? 🤷‍♂️
                                          edit:
                                          Ich habe das mit den Icons tatsächlich hinbekommen, aber dafür habe ich keine Ahnung wie du die Nachtlänge ermittelst. Seit ich alle Skripte importiert habe schmiert mir der Adapter dauern ab. Ich finde auch die -ich nenne es mal - variable nicht. 😞
                                          • maximal1981
                                            maximal1981 last edited by maximal1981
                                            @Kuddel vielen Dank für die Unterstützung und deine Geduld, je nach zeitlicher Möglichkeit migriere ich dein VIS weiter.
                                            @WeiserWolf es gibt auch einen "neuen" DP im unifi, nämlich isOnline die Zeit kann im Adapter eingestellt werden, welche vermutlich nach ersten Tests in Sekunden sein müssten.
                                            vis vis projekte
                                            83
                                            640
                                            172257
