    4. Mini-HowTo: Cannot find view "system" for search "host"
      apollon77 @WolfgangFB last edited by
      @wolfgangfb sagte in Mini-HowTo: Cannot find view "system" for search "host":
      Also generell sieht man hier schön das es ein Harter "power off style" reboot gewesen ist. Wie aich immer das normale json UND das bak kaputt sein können und das von states UND objects verstehe ich zwar nur bedingt aber naja. Ich würde hier ggf sogar auf Filesystem Schaden tippen
        @apollon77 So, gerade wieder, diesmal nichts neu gestartet sondern gleich die Logs gesichert.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:BA:3C:74 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d7e1e8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set the console keyboard layout.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Coldplug all Devices.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Memory: 3654936K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K cma-reserved, 3264512K highmem)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Helper to synchronize boot up for ifupdown...
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
        Apr 20 14:24:11 raspberrypi4 systemd-fsck[134]: rootfs: clean, 198103/1859088 files, 1454653/7566848 blocks
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: Hierarchical RCU implementation.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on Root Device.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000026] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Remount Root and Kernel File Systems...
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000088] bcm2835: system timer (irq = 25)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000761] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000780] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.000795] Switching to timer-based delay loop, resolution 18ns
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Helper to synchronize boot up for ifupdown.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.001050] Console: colour dummy device 80x30
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.001117] printk: console [tty1] enabled
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.001171] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.001204] pid_max: default: 32768 minimum: 301
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.001375] LSM: Security Framework initializing
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.001565] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.001591] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.003164] Disabling memory control group subsystem
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Remount Root and Kernel File Systems.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.003285] CPU: Testing write buffer coherency: ok
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.003755] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create System Users...
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.004973] Setting up static identity map for 0x200000 - 0x20003c
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.005172] rcu: Hierarchical SRCU implementation.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.006106] smp: Bringing up secondary CPUs ...
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.007344] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.008746] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.010062] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save Random Seed...
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.010240] smp: Brought up 1 node, 4 CPUs
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.010261] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.010276] CPU: All CPU(s) started in HYP mode.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Flush Journal to Persistent Storage...
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.010290] CPU: Virtualization extensions available.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.011228] devtmpfs: initialized
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.025476] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.025712] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.025744] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.032843] pinctrl core: initialized pinctrl subsystem
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.033944] NET: Registered protocol family 16
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.038118] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save Random Seed.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.038898] audit: initializing netlink subsys (disabled)
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.039160] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.039747] thermal_sys: Registered thermal governor 'step_wise'
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.040550] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.040568] hw-breakpoint: maximum watchpoint size is 8 bytes.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.041004] Serial: AMBA PL011 UART driver
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Flush Journal to Persistent Storage.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.073158] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create System Users.
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.090895] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.100907] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.145645] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.149841] vgaarb: loaded
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.150279] SCSI subsystem initialized
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.150509] usbcore: registered new interface driver usbfs
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.150570] usbcore: registered new interface driver hub
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Static Device Nodes in /dev...
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.150646] usbcore: registered new device driver usb
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.151344] usb_phy_generic phy: supply vcc not found, using dummy regulator
        Apr 20 14:24:11 raspberrypi4 kernel: [    0.153338] clocksource: Switched to clocksource arch_sys_counter
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.152426] VFS: Disk quotas dquot_6.6.0
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.152528] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.152706] FS-Cache: Loaded
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Static Device Nodes in /dev.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.152906] CacheFiles: Loaded
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.153980] simple-framebuffer 3e6c7000.framebuffer: framebuffer at 0x3e6c7000, 0x500000 bytes, mapped to 0x(ptrval)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting udev Kernel Device Manager...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.154001] simple-framebuffer 3e6c7000.framebuffer: format=a8r8g8b8, mode=1280x1024x32, linelength=5120
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.154476] Console: switching to colour frame buffer device 160x64
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems (Pre).
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Kernel Device Manager.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Show Plymouth Boot Screen...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Received SIGRTMIN+20 from PID 172 (plymouthd).
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Show Plymouth Boot Screen.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local Encrypted Volumes.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
        Apr 20 14:24:11 raspberrypi4 systemd-udevd[168]: Using default interface naming scheme 'v240'.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/serial1.
        Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 5: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
        Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 4: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
        Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 4 was not an MTP device
        Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
        Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 3 was not an MTP device
        Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 5 was not an MTP device
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/disk/by-partuuid/19d7e1e8-01.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Huge Pages File System being skipped.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting File System Check on /dev/disk/by-partuuid/19d7e1e8-01...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.171948] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.171993] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.172148] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.172220] TCP: Hash tables configured (established 8192 bind 8192)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in FUSE Control File System being skipped.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.172386] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.172423] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.172688] NET: Registered protocol family 1
        Apr 20 14:24:11 raspberrypi4 systemd-udevd[163]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.173461] RPC: Registered named UNIX socket transport module.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.173477] RPC: Registered udp transport module.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.173492] RPC: Registered tcp transport module.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.173507] RPC: Registered tcp NFSv4.1 backchannel transport module.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.173531] PCI: CLS 0 bytes, default 64
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.176598] Initialise system trusted keyrings
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.176847] workingset: timestamp_bits=14 max_order=20 bucket_order=6
        Apr 20 14:24:11 raspberrypi4 systemd-udevd[189]: Using default interface naming scheme 'v240'.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.185544] zbud: loaded
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.187463] FS-Cache: Netfs 'nfs' registered for caching
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.188227] NFS: Registering the id_resolver key type
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.188260] Key type id_resolver registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.188275] Key type id_legacy registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.188414] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.189464] Key type asymmetric registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.189481] Asymmetric key parser 'x509' registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.189673] bounce: pool size: 64 pages
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.189720] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.189946] io scheduler mq-deadline registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.189963] io scheduler kyber registered
        Apr 20 14:24:11 raspberrypi4 systemd-udevd[160]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.194565] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.194596] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.194676] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.194764] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.255446] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.255832] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.255852] pci_bus 0000:00: root bus resource [bus 00-ff]
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.255873] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.255962] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        Apr 20 14:24:11 raspberrypi4 systemd-udevd[152]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.256206] pci 0000:00:00.0: PME# supported from D0 D3hot
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.259734] PCI: bus0: Fast back to back transfers disabled
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.260075] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: fsck.fat 4.1 (2017-01-24)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.260204] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.260638] pci 0000:01:00.0: PME# supported from D0 D3cold
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.264174] PCI: bus1: Fast back to back transfers disabled
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.264238] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.264262] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.264344] pci 0000:00:00.0: PCI bridge to [bus 01]
        Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.264370] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.264800] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.265035] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
        Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]:  Automatically removing dirty bit.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.273628] iproc-rng200 fe104000.rng: hwrng registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.273943] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.274817] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.287194] brd: module loaded
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.299668] loop: module loaded
        Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: Performing changes.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.301375] Loading iSCSI transport class v2.0-870.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.303870] libphy: Fixed MDIO Bus: probed
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.305567] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.323383] libphy: bcmgenet MII bus: probed
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.403508] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.404703] usbcore: registered new interface driver r8152
        Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: /dev/mmcblk0p1: 264 files, 97566/516190 clusters
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.404771] usbcore: registered new interface driver lan78xx
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.404832] usbcore: registered new interface driver smsc95xx
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.406470] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on /dev/disk/by-partuuid/19d7e1e8-01.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.406637] xhci_hcd 0000:01:00.0: xHCI Host Controller
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.406673] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.410047] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.411381] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.411401] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounting /boot...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.411418] usb usb1: Product: xHCI Host Controller
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.411435] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.411451] usb usb1: SerialNumber: 0000:01:00.0
        Apr 20 14:24:11 raspberrypi4 systemd-udevd[196]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.412211] hub 1-0:1.0: USB hub found
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.412328] hub 1-0:1.0: 1 port detected
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.412999] xhci_hcd 0000:01:00.0: xHCI Host Controller
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.413038] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.413064] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounted /boot.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.413633] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.413652] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.413669] usb usb2: Product: xHCI Host Controller
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.413685] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.413701] usb usb2: SerialNumber: 0000:01:00.0
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.414412] hub 2-0:1.0: USB hub found
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.414496] hub 2-0:1.0: 4 ports detected
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.416217] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.416531] dwc_otg: FIQ enabled
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.416546] dwc_otg: NAK holdoff enabled
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.416560] dwc_otg: FIQ split-transaction FSM enabled
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Preprocess NFS configuration...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.416578] Module dwc_common_port init
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.417030] usbcore: registered new interface driver uas
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.417136] usbcore: registered new interface driver usb-storage
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.417332] mousedev: PS/2 mouse device common for all mice
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.419051] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.422586] sdhci: Secure Digital Host Controller Interface driver
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.422602] sdhci: Copyright(c) Pierre Ossman
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.423310] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.424006] sdhci-pltfm: SDHCI platform and OF driver helper
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Set console font and keymap...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.428187] ledtrig-cpu: registered to indicate activity on CPUs
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.428545] hid: raw HID events driver (C) Jiri Kosina
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.428739] usbcore: registered new interface driver usbhid
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.428755] usbhid: USB HID core driver
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.434717] Initializing XFRM netlink socket
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.434760] NET: Registered protocol family 17
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.434888] Key type dns_resolver registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.435341] Registering SWP/SWPB emulation handler
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Raise network interfaces...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.435522] registered taskstats version 1
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.435550] Loading compiled-in X.509 certificates
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.436381] Key type ._fscrypt registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.436398] Key type .fscrypt registered
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Volatile Files and Directories...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.436413] Key type fscrypt-provisioning registered
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.448070] uart-pl011 fe201000.serial: there is not valid maps for state default
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.448377] uart-pl011 fe201000.serial: cts_event_workaround enabled
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.448469] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        Apr 20 14:24:11 raspberrypi4 systemd[1]: nfs-config.service: Succeeded.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.455276] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.456349] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.456366] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.486695] of_cfs_init
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Preprocess NFS configuration.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.486967] of_cfs_init: OK
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.507463] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.509156] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.510840] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.513978] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.515664] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target NFS client services.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems (Pre).
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set console font and keymap.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Volatile Files and Directories.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Network Time Synchronization...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Update UTMP about System Boot/Shutdown.
        Apr 20 14:24:11 raspberrypi4 systemd-timesyncd[338]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2021-04-20 14:24:08 CEST
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Network Time Synchronization.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Time Synchronized.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: plymouth-read-write.service: Succeeded.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Initialization.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started CUPS Scheduler.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Paths.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.524316] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.525279] Waiting for root device PARTUUID=19d7e1e8-02...
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.556591] random: fast init done
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.560965] mmc0: new high speed SDHC card at address b368
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily rotation of log files.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.561943] mmcblk0: mmc0:b368 NCard 29.1 GiB
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.564164]  mmcblk0: p1 p2
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.586167] mmc1: new high speed SDIO card at address 0001
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily Cleanup of Temporary Directories.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.595504] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.595521] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.773383] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.955972] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.955994] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt download activities.
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.956011] usb 1-1: Product: USB2.0 Hub
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.958069] hub 1-1:1.0: USB hub found
        Apr 20 14:24:11 raspberrypi4 kernel: [    1.958360] hub 1-1:1.0: 4 ports detected
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on D-Bus System Message Bus Socket.
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.283380] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.423754] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.00
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.423773] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.423792] usb 1-1.1: Product: USB Receiver
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt upgrade and clean activities.
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.423809] usb 1-1.1: Manufacturer: Logitech
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.436786] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C534.0001/input/input0
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.504263] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily man-db regeneration.
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.516405] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input1
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.516951] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input2
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.583693] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input3
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.584302] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.683377] usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.821311] usb 1-1.2: New USB device found, idVendor=0458, idProduct=0007, bcdDevice= 0.00
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.821332] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Timers.
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.821349] usb 1-1.2: Product: Optical Mouse
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.821366] usb 1-1.2: Manufacturer:  KYE
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on CUPS Scheduler.
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.830698] input:  KYE   Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0458:0007.0003/input/input6
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.831210] hid-generic 0003:0458:0007.0003: input,hidraw2: USB HID v1.10 Mouse [ KYE   Optical Mouse] on usb-0000:01:00.0-1.2/input0
        Apr 20 14:24:11 raspberrypi4 kernel: [    2.923377] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.062846] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.062866] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on triggerhappy.socket.
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.062883] usb 1-1.3: Product: TI CC2531 USB CDC
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.062899] usb 1-1.3: Manufacturer: Texas Instruments
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.062916] usb 1-1.3: SerialNumber: __0X00124B001CD40626
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.531627] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.590223] EXT4-fs (mmcblk0p2): 9 orphan inodes deleted
        Apr 20 14:24:11 raspberrypi4 kernel: [    3.590242] EXT4-fs (mmcblk0p2): recovery complete
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sockets.
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.879135] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.879224] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.894488] devtmpfs: mounted
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Basic System.
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903459] Freeing unused kernel memory: 2048K
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903785] Run /sbin/init as init process
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903799]   with arguments:
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903814]     /sbin/init
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Regular background program processing daemon.
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903828]     splash
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903842]   with environment:
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903857]     HOME=/
        Apr 20 14:24:11 raspberrypi4 kernel: [    4.903871]     TERM=linux
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
        Apr 20 14:24:11 raspberrypi4 kernel: [    7.032863] NET: Registered protocol family 10
        Apr 20 14:24:11 raspberrypi4 kernel: [    7.034356] Segment Routing with IPv6
        Apr 20 14:24:11 raspberrypi4 kernel: [    8.463450] random: systemd: uninitialized urandom read (16 bytes read)
        Apr 20 14:24:11 raspberrypi4 kernel: [    8.481708] random: systemd: uninitialized urandom read (16 bytes read)
        Apr 20 14:24:11 raspberrypi4 kernel: [    8.482962] random: systemd: uninitialized urandom read (16 bytes read)
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting rng-tools.service...
        Apr 20 14:24:11 raspberrypi4 kernel: [    8.721652] i2c /dev entries driver
        Apr 20 14:24:11 raspberrypi4 kernel: [    9.554904] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.641713] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.642290] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.642885] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.643750] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.822744] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Configure Bluetooth Modems connected by UART...
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.824501] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.826737] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.826771] [vc_sm_connected_init]: start
        Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (pidfile fd = 3)
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.848273] [vc_sm_connected_init]: installed successfully
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.849805] bcm2835_audio bcm2835_audio: card created with 4 channels
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.853096] bcm2835_audio bcm2835_audio: card created with 4 channels
        Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (Running @reboot jobs)
        Apr 20 14:24:11 raspberrypi4 kernel: [   10.982850] mc: Linux media interface: v0.10
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.105427] videodev: Linux video capture interface: v2.00
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.427266] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.427273] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.462722] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Manage Sound Card State (restore and store).
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.550425] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.557730] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.584209] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.584751] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.585224] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        Apr 20 14:24:11 raspberrypi4 alsactl[383]: alsactl 1.1.8 daemon started
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dhcpcd on all interfaces...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for v3d driver...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started D-Bus System Message Bus.
        Apr 20 14:24:11 raspberrypi4 rng-tools[378]: Starting Hardware RNG entropy gatherer daemon: rngd.
        Apr 20 14:24:11 raspberrypi4 rngd[398]: rngd 2-unofficial-mt.14 starting up...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting WPA supplicant...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Save/Restore Sound Card State...
        Apr 20 14:24:11 raspberrypi4 rngd[398]: entropy feed to the kernel ready
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Login Service...
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.585569] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.585601] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.585627] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Disk Manager...
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.585650] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.585672] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting triggerhappy global hotkey daemon...
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.585873] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.632460] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.632488] checking generic (3e6c7000 500000) vs hw (0 ffffffffffffffff)
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.632506] fb0: switching to vc4drmfb from simple
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.633128] Console: switching to colour dummy device 80x30
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting System Logging Service...
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.634949] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.636914] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.636972] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.637019] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.637061] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.637112] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.637157] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.637199] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.637239] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Raise network interfaces.
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started rng-tools.service.
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.637280] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Save/Restore Sound Card State.
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.665628] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.721157] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.721203] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.734419] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sound Card.
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.734457] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.741420] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.741459] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.745750] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.856935] Console: switching to colour frame buffer device 160x64
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.880028] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.940829] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.946802] usbcore: registered new interface driver cdc_acm
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.946823] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        Apr 20 14:24:11 raspberrypi4 kernel: [   11.960247] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: dev: loaded udev
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.076017] brcmfmac: F1 signature read @0x18000000=0x15264345
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.086842] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.087515] usbcore: registered new interface driver brcmfmac
        Apr 20 14:24:11 raspberrypi4 thd[412]: Found socket passed from systemd
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.231259] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.286383] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.477063] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.529613] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.716938] logitech-djreceiver 0003:046D:C534.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
        Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.800235] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
        Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Successfully dropped root privileges.
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.803626] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input7
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.807717] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input8
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.814168] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input9
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.814657] hid-generic 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
        Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: avahi-daemon 0.7 starting up.
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.816229] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
        Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: forked to background, child pid 440
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.818419] input: Logitech Wireless Mouse PID:4038 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input14
        Apr 20 14:24:11 raspberrypi4 kernel: [   12.819041] hid-generic 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
        Apr 20 14:24:11 raspberrypi4 kernel: [   13.713076] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input18
        Apr 20 14:24:11 raspberrypi4 rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
        Apr 20 14:24:11 raspberrypi4 kernel: [   13.714890] logitech-hidpp-device 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
        Apr 20 14:24:11 raspberrypi4 kernel: [   13.856632] input: Logitech Wireless Mouse PID:4038 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input19
        Apr 20 14:24:11 raspberrypi4 kernel: [   13.857187] logitech-hidpp-device 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
        Apr 20 14:24:11 raspberrypi4 kernel: [   16.716140] random: crng init done
        Apr 20 14:24:11 raspberrypi4 rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="413" x-info="https://www.rsyslog.com"] start
        Apr 20 14:24:11 raspberrypi4 kernel: [   16.716164] random: 7 urandom warning(s) missed due to ratelimiting
        Apr 20 14:24:11 raspberrypi4 kernel: [   16.737069] uart-pl011 fe201000.serial: no DMA platform data
        Apr 20 14:24:11 raspberrypi4 kernel: [   18.518351] 8021q: 802.1Q VLAN Support v1.8
        Apr 20 14:24:11 raspberrypi4 udisksd[411]: udisks daemon version 2.8.1 starting
        Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 8.2.0 CTV); collect: 128K
        Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 14768/63488
        Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 7.99864
        Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: fills: 0, generated: 0
        Apr 20 14:24:11 raspberrypi4 dphys-swapfile[410]: want /var/swap=100MByte, checking existing: keeping it
        Apr 20 14:24:11 raspberrypi4 dhcpcd-run-hooks[488]: wlan0: starting wpa_supplicant
        Apr 20 14:24:12 raspberrypi4 kernel: [   19.850495] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started triggerhappy global hotkey daemon.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started System Logging Service.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
        Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully called chroot().
        Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully dropped remaining capabilities.
        Apr 20 14:24:12 raspberrypi4 wpa_supplicant[403]: Successfully initialized wpa_supplicant
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started dhcpcd on all interfaces.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Check for v3d driver.
        Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: No service file found in /etc/avahi/services.
        Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Network interface enumeration completed.
        Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Server startup complete. Host name is raspberrypi4.local. Local service cookie is 2766927354.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Login Service.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started WPA supplicant.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Make remote CUPS printers available locally.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Permit User Sessions...
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started ioBroker Server.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network is Online.
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Samba NMB Daemon...
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Daily apt download activities...
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting /etc/rc.local Compatibility...
        Apr 20 14:24:12 raspberrypi4 systemd[1]: Started VNC Server in Service Mode daemon.
        Apr 20 14:24:12 raspberrypi4 kernel: [   20.513499] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting OpenBSD Secure Shell server...
        Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting MariaDB 10.3.27 database server...
        Apr 20 14:24:13 raspberrypi4 systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
        Apr 20 14:24:13 raspberrypi4 systemd[1]: Started Permit User Sessions.
        Apr 20 14:24:13 raspberrypi4 systemd[1]: Started /etc/rc.local Compatibility.
        Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
        Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
        Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Light Display Manager...
        Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Hold until boot process finishes up...
        Apr 20 14:24:13 raspberrypi4 dnsmasq[502]: dnsmasq: Syntaxprüfung OK.
        Apr 20 14:24:14 raspberrypi4 raspi-config[414]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
        Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: connected to Access Point `'
        Apr 20 14:24:14 raspberrypi4 systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
        Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: eth0: waiting for carrier
        Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: waiting for carrier
        Apr 20 14:24:14 raspberrypi4 kernel: [   21.989989] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        Apr 20 14:24:14 raspberrypi4 kernel: [   21.990254] bcmgenet fd580000.ethernet eth0: Link is Down
        Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'mdraid' libblockdev plugin
        Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'crypto' libblockdev plugin
        Apr 20 14:24:14 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.5' (uid=0 pid=411 comm="/usr/lib/udisks2/udisksd ")
        Apr 20 14:24:14 raspberrypi4 systemd[1]: Starting Authorization Manager...
        Apr 20 14:24:14 raspberrypi4 systemd[1]: Started Mosquitto MQTT v3.1/v3.1.1 Broker.
        Apr 20 14:24:14 raspberrypi4 systemd[1]: Started OpenBSD Secure Shell server.
        Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: gestartet, Version 2.80, Cachegröße 150
        Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: DNS-Dienst auf lokale Subnetze eingeschränkt
        Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: Übersetzungsoptionen: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
        Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: /etc/hosts gelesen - 5 Adressen
        Apr 20 14:24:15 raspberrypi4 dnsmasq[556]: keine Server in /run/dnsmasq/resolv.conf gefunden, werde es später neu versuchen
        Apr 20 14:24:15 raspberrypi4 dnsmasq[557]: Too few arguments.
        Apr 20 14:24:15 raspberrypi4 systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
        Apr 20 14:24:15 raspberrypi4 systemd[1]: Reached target Host and Network Name Lookups.
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]: BOOTLOADER: up-to-date
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:     LATEST: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:             Use raspi-config to change the release.
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:   VL805_FW: Dedicated VL805 EEPROM
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:      VL805: up-to-date
        Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: 000138a1
        Apr 20 14:24:16 raspberrypi4 rpi-eeprom-update[385]:     LATEST: 000138a1
        Apr 20 14:24:16 raspberrypi4 systemd[1]: Started Check for Raspberry Pi EEPROM updates.
        Apr 20 14:24:18 raspberrypi4 dhcpcd[440]: eth0: carrier acquired
        Apr 20 14:24:18 raspberrypi4 kernel: [   26.153638] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
        Apr 20 14:24:18 raspberrypi4 kernel: [   26.153698] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: DUID 00:01:00:01:27:8f:0c:24:dc:a6:32:ba:3c:74
        Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: IAID 32:ba:3c:74
        Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: adding address fe80::da0:a631:6da1:f23c
        Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
        Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv6 for mDNS.
        Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: probing address 192.168.1.203/24
        Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Registering new address record for fe80::da0:a631:6da1:f23c on eth0.*.
        Apr 20 14:24:19 raspberrypi4 lightdm[524]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.629392] Bluetooth: Core ver 2.22
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.629502] NET: Registered protocol family 31
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.629516] Bluetooth: HCI device and connection manager initialized
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.630104] Bluetooth: HCI socket layer initialized
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.630124] Bluetooth: L2CAP socket layer initialized
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.630171] Bluetooth: SCO socket layer initialized
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.869925] Bluetooth: HCI UART driver ver 2.3
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.869946] Bluetooth: HCI UART protocol H4 registered
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.870061] Bluetooth: HCI UART protocol Three-wire (H5) registered
        Apr 20 14:24:20 raspberrypi4 kernel: [   27.870348] Bluetooth: HCI UART protocol Broadcom registered
        Apr 20 14:24:20 raspberrypi4 btuart[380]: bcm43xx_init
        Apr 20 14:24:20 raspberrypi4 btuart[380]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
        Apr 20 14:24:20 raspberrypi4 btuart[380]: Set Controller UART speed to 3000000 bit/s
        Apr 20 14:24:20 raspberrypi4 btuart[380]: Device setup complete
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Configure Bluetooth Modems connected by UART.
        Apr 20 14:24:20 raspberrypi4 polkitd[552]: started daemon version 0.105 using authority implementation `local' version `0.105'
        Apr 20 14:24:20 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-start.service: Succeeded.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-quit-wait.service: Succeeded.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Hold until boot process finishes up.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Received SIGRTMIN+21 from PID 172 (n/a).
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Authorization Manager.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Light Display Manager.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Getty on tty1.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Reached target Login Prompts.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Created slice system-bthelper.slice.
        Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Bluetooth service...
        Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: soliciting an IPv6 router
        Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: Router Advertisement from fe80::f2af:85ff:fe8c:99dc
        Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca/64
        Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
        Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca.
        Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca on eth0.*.
        Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding route to 2a02:810b:c63f:d98c::/64
        Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Withdrawing address record for fe80::da0:a631:6da1:f23c on eth0.
        Apr 20 14:24:20 raspberrypi4 kernel: [   28.477216] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: confirming prior DHCPv6 lease
        Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
        Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding default route via fe80::f2af:85ff:fe8c:99dc
        Apr 20 14:24:21 raspberrypi4 systemd[1]: Started Disk Manager.
        Apr 20 14:24:21 raspberrypi4 udisksd[411]: Acquired the name org.freedesktop.UDisks2 on the system message bus
        Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: REPLY6 received from fe80::f2af:85ff:fe8c:99dc
        Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c::d7c2/128
        Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: renew in 21600, rebind in 34560, expire in 43200 seconds
        Apr 20 14:24:21 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c::d7c2 on eth0.*.
        Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Bluetooth daemon 5.50
        Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Bluetooth service.
        Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Raspberry Pi bluetooth helper.
        Apr 20 14:24:22 raspberrypi4 systemd[1]: Reached target Bluetooth.
        Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Starting SDP server
        Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Note] /usr/sbin/mysqld (mysqld 10.3.27-MariaDB-0+deb10u1) starting as process 642 ...
        Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Warning] Could not increase number of max_open_files to more than 16384 (request: 32186)
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: Raspberry Pi BDADDR already set
        Apr 20 14:24:23 raspberrypi4 kernel: [   30.787342] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        Apr 20 14:24:23 raspberrypi4 kernel: [   30.787364] Bluetooth: BNEP filters: protocol multicast
        Apr 20 14:24:23 raspberrypi4 kernel: [   30.787394] Bluetooth: BNEP socket layer initialized
        Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Bluetooth management interface 1.18 initialized
        Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.13' (uid=0 pid=691 comm="/usr/lib/bluetooth/bluetoothd ")
        Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ServerManager: Server started
        Apr 20 14:24:23 raspberrypi4 systemd[1]: Starting Hostname Service...
        Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Sap driver initialization failed.
        Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: sap-server: Operation not permitted (1)
        Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Failed to set privacy: Rejected (0x0b)
        Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.hostname1'
        Apr 20 14:24:23 raspberrypi4 systemd[1]: Started Hostname Service.
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001801-0000-1000-8000-00805f9b34fb
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001800-0000-1000-8000-00805f9b34fb
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Alias: BlueZ 5.50
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Pairable: yes
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power off succeeded
        Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power on succeeded
        Apr 20 14:24:23 raspberrypi4 systemd[1]: bthelper@hci0.service: Succeeded.
        Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Cannot find a running X server on vt1
        Apr 20 14:24:24 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Found running X server (pid=681, binary=/usr/lib/xorg/Xorg)
        Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: using static address 192.168.1.203/24
        Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding route to 192.168.1.0/24
        Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.203.
        Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv4 for mDNS.
        Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding default route via 192.168.1.200
        Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Registering new address record for 192.168.1.203 on eth0.IPv4.
        Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
        Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
        Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
        Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
        Apr 20 14:24:25 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
        Apr 20 14:24:27 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
        Apr 20 14:24:29 raspberrypi4 systemd[1]: Started Samba NMB Daemon.
        Apr 20 14:24:29 raspberrypi4 systemd[1]: Starting Samba SMB Daemon...
        Apr 20 14:24:29 raspberrypi4 vncserver-x11[536,root]: AgentInitCheck: no response from agent
        Apr 20 14:24:30 raspberrypi4 systemd[1]: Created slice User Slice of UID 1000.
        Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Runtime Directory /run/user/1000...
        Apr 20 14:24:30 raspberrypi4 systemd[1]: Started User Runtime Directory /run/user/1000.
        Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Manager for UID 1000...
        Apr 20 14:24:30 raspberrypi4 systemd[1]: apt-daily.service: Succeeded.
        Apr 20 14:24:30 raspberrypi4 systemd[1]: Started Daily apt download activities.
        Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
        Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
        Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
        Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
        Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 2a02:810b:c63f:d98c:f2af:85ff:fe8c:99dc#53
        Apr 20 14:24:32 raspberrypi4 systemd[1]: Started MariaDB 10.3.27 database server.
        Apr 20 14:24:32 raspberrypi4 /etc/mysql/debian-start[901]: Upgrading MySQL tables if necessary.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on Sound System.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Paths.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Timers.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG network certificate management daemon.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Starting D-Bus User Message Bus Socket.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on D-Bus User Message Bus Socket.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Sockets.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Basic System.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Default.
        Apr 20 14:24:32 raspberrypi4 systemd[811]: Startup finished in 2.212s.
        Apr 20 14:24:32 raspberrypi4 systemd[1]: Started User Manager for UID 1000.
        Apr 20 14:24:32 raspberrypi4 systemd[1]: Started Session 1 of user pi.
        Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: /usr/bin/mysql_upgrade: the '--basedir' option is always ignored
        Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysql' as: /usr/bin/mysql
        Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysqlcheck' as: /usr/bin/mysqlcheck
        Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: This installation of MySQL is already upgraded to 10.3.27-MariaDB, use --force if you still need to run mysql_upgrade
        Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[984]: Checking for insecure root accounts.
        Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[990]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
        Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Samba SMB Daemon.
        Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Multi-User System.
        Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Graphical Interface.
        Apr 20 14:24:35 raspberrypi4 systemd[1]: Starting Update UTMP about System Runlevel Changes...
        Apr 20 14:24:35 raspberrypi4 systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
        Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Update UTMP about System Runlevel Changes.
        Apr 20 14:24:35 raspberrypi4 systemd[1]: Startup finished in 6.594s (kernel) + 36.438s (userspace) = 43.033s.
        Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: connected: 192.168.1.24::54365 (TCP)
        Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: authenticated: 192.168.1.24::54365 (TCP), as (anonymous) (d permissions)
        Apr 20 14:24:37 raspberrypi4 kernel: [   44.583156] broken atomic modeset userspace detected, disabling atomic
        Apr 20 14:24:37 raspberrypi4 systemd[1]: systemd-fsckd.service: Succeeded.
        Apr 20 14:34:15 raspberrypi4 systemd-timesyncd[338]: Synchronized to time server for the first time [2a02:a00:1009:6202::123]:123 (2.debian.pool.ntp.org).
        Apr 20 14:34:15 raspberrypi4 lightdm[1064]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
        Apr 20 14:34:15 raspberrypi4 systemd[1]: Started Session 3 of user pi.
        Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
        Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
        Apr 20 14:34:16 raspberrypi4 bash[504]: object system.meta.uuid created: f2bf0859-fa5f-19ae-5629-68c17843bcf5
        Apr 20 14:34:16 raspberrypi4 bash[504]: object system.user.admin created
        Apr 20 14:34:16 raspberrypi4 systemd[811]: Started D-Bus User Message Bus.
        Apr 20 14:34:29 raspberrypi4 systemd[1]: systemd-hostnamed.service: Succeeded.
        Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=1000 pid=1083 comm="/usr/bin/lxsession -s LXDE-pi -e LXDE ")
        Apr 20 14:34:30 raspberrypi4 systemd[811]: Starting Virtual filesystem service...
        Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.Daemon'
        Apr 20 14:34:30 raspberrypi4 systemd[811]: Started Virtual filesystem service.
        Apr 20 14:34:30 raspberrypi4 kernel: [   62.126481] fuse: init (API version 7.32)
        Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounting FUSE Control File System...
        Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounted FUSE Control File System.
        Apr 20 14:34:31 raspberrypi4 systemd[811]: Starting Sound Service...
        Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.29' (uid=1000 pid=1238 comm="/usr/bin/pulseaudio --daemonize=no ")
        Apr 20 14:34:32 raspberrypi4 systemd[1]: Starting RealtimeKit Scheduling Policy Service...
        Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
        Apr 20 14:34:32 raspberrypi4 systemd[1]: Started RealtimeKit Scheduling Policy Service.
        Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully called chroot.
        Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully dropped privileges.
        Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully limited resources.
        Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Running.
        Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Canary thread running.
        Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Watchdog thread running.
        Apr 20 14:34:33 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
        Apr 20 14:34:33 raspberrypi4 systemd[811]: Starting Virtual filesystem service - disk device monitor...
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - disk device monitor.
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Media Transfer Protocol monitor.
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
        Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1238 of process 1238 (n/a) owned by '1000' high priority at nice level -11.
        Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - digital camera monitor...
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - digital camera monitor.
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - GNOME Online Accounts monitor.
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Apple File Conduit monitor...
        Apr 20 14:34:34 raspberrypi4 gvfs-afc-volume-monitor[1295]: Volume monitor alive
        Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
        Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Apple File Conduit monitor.
        Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
        Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1302 of process 1238 (n/a) owned by '1000' RT at priority 5.
        Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 2 threads of 1 processes of 1 users.
        Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1303 of process 1238 (n/a) owned by '1000' RT at priority 5.
        Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 3 threads of 1 processes of 1 users.
        Apr 20 14:34:35 raspberrypi4 systemd[811]: Started Sound Service.
        Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSource
        Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSink
        Apr 20 14:34:35 raspberrypi4 pulseaudio[1238]: E: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
        Apr 20 14:34:35 raspberrypi4 kernel: [   66.990077] Bluetooth: RFCOMM TTY layer initialized
        Apr 20 14:34:35 raspberrypi4 kernel: [   66.990099] Bluetooth: RFCOMM socket layer initialized
        Apr 20 14:34:35 raspberrypi4 kernel: [   66.990120] Bluetooth: RFCOMM ver 1.11
        und hier das Ende vom IOBroker log:
        2021-04-20 14:28:55.984  - error: javascript.0 (14256) function(DeviceName(s, x)){ // mit Punkt am Ende
        2021-04-20 14:28:55.985  - error: javascript.0 (14256) ^^^^^^^^
        2021-04-20 14:28:55.985  - error: javascript.0 (14256) SyntaxError: Function statements require a function name
        2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at new Script (vm.js:88:7)
        2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at Object.createScript (vm.js:261:10)
        2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17)
        2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at processImmediate (internal/timers.js:463:21)
        2021-04-20 14:29:01.400  - error: javascript.0 (14256) script.js.Test: test
        2021-04-20 14:29:29.817  - info: javascript.0 (14256) Stop script script.js.Sensoren.ShellyErfassen
        2021-04-20 14:29:29.839  - info: javascript.0 (14256) Start javascript script.js.Sensoren.ShellyErfassen
        2021-04-20 14:30:00.052  - info: host.raspberrypi4 instance system.adapter.daswetter.0 started with pid 4110
        2021-04-20 14:30:01.917  - info: daswetter.0 (4110) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.21.0, js-controller: 3.2.16
        2021-04-20 14:30:14.329  - info: daswetter.0 (4110) Terminated (NO_ERROR): Without reason
        2021-04-20 14:30:14.854  - info: daswetter.0 (4110) cleaned everything up...
        2021-04-20 14:30:14.869  - info: host.raspberrypi4 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-04-20 14:24:38.869  - info: host.raspberrypi4 iobroker.js-controller version 3.2.16 js-controller starting
        2021-04-20 14:24:38.874  - info: host.raspberrypi4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-04-20 14:24:38.875  - info: host.raspberrypi4 hostname: raspberrypi4, node: v12.21.0
        2021-04-20 14:24:38.876  - info: host.raspberrypi4 ip addresses: 192.168.1.203 2a02:810b:c63f:d98c::d7c2 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca fe80::da0:a631:6da1:f23c
        2021-04-20 14:24:38.941  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
        2021-04-20 14:24:38.943  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
        2021-04-20 14:24:39.020  - error: host.raspberrypi4 Cannot read system.config: null (OK when migrating or restoring)
        2021-04-20 14:24:39.029  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
        2021-04-20 14:34:15.578  - info: host.raspberrypi4 connected to Objects and States
        2021-04-20 14:34:15.727  - warn: host.raspberrypi4 logger system.adapter.admin.0.logging was deleted
        2021-04-20 14:34:15.728  - warn: host.raspberrypi4 logger system.adapter.javascript.0.logging was deleted
        2021-04-20 14:34:15.773  - info: host.raspberrypi4 added notifications configuration of host
        2021-04-20 14:34:15.780  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
        2021-04-20 14:34:15.781  - error: host.raspberrypi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
        2021-04-20 14:34:15.796  - info: host.raspberrypi4 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2021-04-20 14:34:15.803  - error: host.raspberrypi4 Cannot find view "system" for search "host"
        2021-04-20 14:34:15.812  - error: host.raspberrypi4 Cannot find view "system" for search "state"
        2021-04-20 14:34:15.813  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
        2021-04-20 14:34:15.815  - error: host.raspberrypi4 Could not collect system.host.raspberrypi4 states to check for obsolete states: Error: Cannot find view "system"
        2021-04-20 14:34:15.816  - error: host.raspberrypi4 _design/system missing - call node iobroker.js setup
        2021-04-20 14:34:16.643  - info: host.raspberrypi4 Created UUID: f2bf0859-fa5f-19ae-5629-68c17843bcf5
        und
        pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ free -h
        Mem:          3,7Gi       244Mi       3,1Gi        48Mi       404Mi       3,3Gi
        Swap:          99Mi          0B        99Mi
        pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ who -r
                 Runlevel 5   2021-04-20 14:24
        Gruß Wolfgang
        apollon77 Thomas Braun 2 Replies Last reply Reply Quote 0
          apollon77 @WolfgangFB last edited by
          @wolfgangfb sagte in Mini-HowTo: Cannot find view "system" for search "host":
          Was kommt denn im Syslog DAVOR? Du hst mit dem Syslog genau mit dem Reboot gestartet ... Alao ja...das dicng hat rebootet "aus dem Nichts". Warum könnte man höchstens im sysLog vorher sehen
            Thomas Braun Most Active @WolfgangFB last edited by
            Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
            Kein "Stromausfall" oder sonstiges rüdes Umgehen mit dem System? Da scheint mir auf dem Datenträger was krumm zu sein dann.
            Und den mitlaufenden Desktop würde ich auch ausschalten. Im Serverbetrieb ist Kommandozeile angesagt.
              WolfgangFB @Thomas Braun last edited by
              Hier der Teil des Syslog davor:
              Apr 20 12:43:51 raspberrypi4 rngd[404]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 12:44:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:45:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:46:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:47:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:48:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:49:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:50:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:51:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:52:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:53:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:54:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:54:54 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
              Apr 20 12:54:54 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
              Apr 20 12:55:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:56:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:57:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:58:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 12:59:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:00:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:01:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:02:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:03:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:04:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:05:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:06:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:07:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:08:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:09:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:10:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:11:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:12:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:13:06 raspberrypi4 vncserver-x11[544,root]: Connections: disconnected: 192.168.1.24::64761 (TCP) ([IdleTimeout] Das Zeitlimit dieser Verbindung wurde durch Inaktivität überschritten.)
              Apr 20 13:13:10 raspberrypi4 vncserver-x11[544,root]: Connections: connected: 192.168.1.24::51718 (TCP)
              Apr 20 13:13:10 raspberrypi4 vncserver-x11[544,root]: Connections: authenticated: 192.168.1.24::51718 (TCP), as (anonymous) (d permissions)
              Apr 20 13:13:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:14:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:15:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:16:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:17:01 raspberrypi4 CRON[8441]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 13:17:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:18:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:19:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:20:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:21:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:22:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:23:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:24:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:25:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:26:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:27:14 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
              Apr 20 13:27:14 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
              Apr 20 13:27:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:28:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
              Apr 20 13:28:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
              Apr 20 13:28:15 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
              Apr 20 13:28:16 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
              Apr 20 13:28:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:29:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:29:36 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
              Apr 20 13:29:37 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
              Apr 20 13:29:58 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
              Apr 20 13:29:58 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
              Apr 20 13:30:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:31:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
              Apr 20 13:31:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
              Apr 20 13:31:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:32:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:33:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:34:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:35:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:36:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:37:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:38:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:39:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:40:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:41:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:42:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:43:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: bits received from HRNG source: 1320064
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: bits sent to kernel pool: 1262560
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: entropy added to kernel pool: 1262560
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2 successes: 66
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2 failures: 0
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: HRNG source speed: (min=285.570; avg=490.356; max=513.940)Kibits/s
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS tests speed: (min=4.830; avg=16.596; max=31.474)Mibits/s
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: Lowest ready-buffers level: 2
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: Entropy starvations: 0
              Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 13:44:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:45:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:46:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:47:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:48:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:49:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:50:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:51:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:52:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:53:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:54:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:55:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:56:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:57:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:58:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 13:58:43 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
              Apr 20 13:58:44 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
              Apr 20 13:59:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:00:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:01:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:02:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:03:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:04:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:05:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:06:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:07:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:08:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:09:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:10:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:11:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:12:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:13:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:14:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:15:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:16:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:17:01 raspberrypi4 CRON[31531]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 14:17:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:18:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:19:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:20:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:21:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:22:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:23:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:24:19 raspberrypi4 vncserver-x11[544,root]: Connections: disconnected: 192.168.1.24::51718 (TCP) ([IdleTimeout] Das Zeitlimit dieser Verbindung wurde durch Inaktivität überschritten.)
              Apr 20 14:24:23 raspberrypi4 vncserver-x11[544,root]: Connections: connected: 192.168.1.24::53991 (TCP)
              Apr 20 14:24:23 raspberrypi4 vncserver-x11[544,root]: Connections: authenticated: 192.168.1.24::53991 (TCP), as (anonymous) (d permissions)
              Apr 20 14:24:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:25:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:26:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:27:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:28:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:29:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:30:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:31:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:32:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
              Apr 20 14:24:11 raspberrypi4 systemd-modules-load[106]: Inserted module 'i2c_dev'
              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Booting Linux on physical CPU 0x0
              apollon77 Thomas Braun wendy2702 3 Replies Last reply Reply Quote 0
                Ok, faktisch nicht s zu sehen was den Reboot verursacht hat ... Dann tippe ich ggf auf Spannungsversorgung? bzw die üblichen verdächtigen 🙂
                  @wolfgangfb
                  vncserver-x11
                  ist ein Prozess der da nicht laufen sollte. Schalte den verdammten Desktop-Quatsch aus!
                  dmesg -T
                  bringt?
                  • wendy2702
                    wendy2702 @WolfgangFB last edited by
                    @wolfgangfb Was ist überhaupt alles auf dem Pi installiert ?
                      Mit dmesg -T kommt eine ewig lange Liste, die aber nicht den Reboot Zeitpunkt beinhalten.
                      Was aber ein paarmal auftritt ist folgender Part:
                      Di Apr 20 17:19:50 2021] [  12060]  1001 12060     1177      156    24576        0             0 ping
                      [Di Apr 20 17:19:50 2021] [  12062]     0 12062       98        1    24576        0             0 resolvconf
                      [Di Apr 20 17:19:50 2021] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=9736,uid=1001
                      [Di Apr 20 17:19:50 2021] Out of memory: Killed process 9736 (node) total-vm:1223992kB, anon-rss:1090996kB, file-rss:7692kB, shmem-rss:0kB, UID:1001 pgtables:3496kB oom_score_adj:0
                      [Di Apr 20 17:19:50 2021] oom_reaper: reaped process 9736 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                      Das habe ich durch ein fehlerhaftes Javaskript verursacht bei dem ich nicht beachtet habe, dass Variablen in Funktionen nicht lokal sind und damit jedes mal die Javaskript Instanz gekillt habe. Ob das zum Reboot Zeitpunkt auch der Fall war weiß ich nicht.
                      Der Raspi ist mein Bastelrechner, deshalb auch der vnc-Server mit dem ich einfach alles mögliche ausprobiere.
                        Thomas Braun Most Active @WolfgangFB last edited by Thomas Braun
                        @wolfgangfb
                        Dir geht halt der Speicher aus.
                        Bedingt durch die Kombination unsaubere skripte und laufender X-Server.
                        Da kann man dir nicht weiterhelfen, wenn du die Dinge nicht anpasst.
                        Warum auf einem Bastelrechner ein Desktop per VNC laufen muss erschließt sich mir auch nicht. Basteln kann man auch ohne Desktop und VNC.
                          Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                          @apollon77
                          Mir ist eben etwas in meinem eigenen Log aufgefallen, das ich mir nicht erklären kann, aber hiermit etwas zu tun haben könnte.
                          Log sagt:
                          2021-05-03 18:47:12.973  - error: host.chet-Server Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker/iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json.new'. Try direct write as fallback
                          Das ist aber nicht richtig, denke ich. Die Ziel-Datei gibt es nämlich:
                          pi@chet:~ $ ls -la /opt/iobroker/iobroker-data/objects.json
                          objects.json      objects.json.bak
                          -rw-rw-r--+ 1 iobroker iobroker 10767373 Mai  3 18:53 /opt/iobroker/iobroker-data/objects.json
                          (Gut, die objects.json.new gibt es nicht (mehr?).
                          apollon77 2 Replies Last reply Reply Quote 0
                            apollon77 @Thomas Braun last edited by
                            @thomas-braun Sehr komisch. SOlche Fälle hab ich in Logs mal gesehen ... aber der Grund ist unklar. so wie der code abläuftkann das an sich nur passieren wenn dinge parallel laufen ... ich schaue nochmal code an
                              Thomas Braun Most Active @apollon77 last edited by
                              @apollon77
                              Ich hab jetzt mal im syslog geschaut. Da ist eigentlich nix wildes drin. Der Zufallszahlengenerator hat ungefähr zu der Zeit gepokert:
                              May  3 18:47:10 chet rngd[385]: stats: bits received from HRNG source: 80064
                              May  3 18:47:10 chet rngd[385]: stats: bits sent to kernel pool: 33824
                              May  3 18:47:10 chet rngd[385]: stats: entropy added to kernel pool: 33824
                              May  3 18:47:10 chet rngd[385]: stats: FIPS 140-2 successes: 4
                              May  3 18:47:10 chet rngd[385]: stats: FIPS 140-2 failures: 0
                              May  3 18:47:10 chet rngd[385]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                              May  3 18:47:10 chet rngd[385]: stats: FIPS 140-2(2001-10-10) Poker: 0
                              May  3 18:47:10 chet rngd[385]: stats: FIPS 140-2(2001-10-10) Runs: 0
                              May  3 18:47:10 chet rngd[385]: stats: FIPS 140-2(2001-10-10) Long run: 0
                              May  3 18:47:10 chet rngd[385]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                              May  3 18:47:10 chet rngd[385]: stats: HRNG source speed: (min=348.393; avg=433.922; max=572.361)Kibits/s
                              May  3 18:47:10 chet rngd[385]: stats: FIPS tests speed: (min=8.859; avg=11.454; max=14.593)Mibits/s
                              May  3 18:47:10 chet rngd[385]: stats: Lowest ready-buffers level: 2
                              May  3 18:47:10 chet rngd[385]: stats: Entropy starvations: 0
                              May  3 18:47:10 chet rngd[385]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                                @thomas-braun ALso diese .new ist der "neue" Weg seit Controller 3.3 um zu verhindern das ein Crash während dem Schreiben der Datei zu kaputten JSONs führt. Wir schreiben in .new und dann benennen wir die nur um und löschen die alte.
                                Dieser Fehler - unter der premisse das vorher kein Fehler vom schreiben kam - kann an sich nur bedeuten das eine Schreibaktion der 10MB so lange gedauert hat das parallel ne zweite kam und es so zur konstellation kam das ein rename ausgeführt wurde und daher das zwite warten musste.
                                Was ist es denn für ein System? SD Karte? Du noch ne IDee?
                                Das einzige was mir einfällt das ich explizit das schreiben blocke wenn noch eine Schreibaktion läuft. Das sollte solche Parallelitäten ausschliessen
                                Das würde dann heissen das es viele Objektänderungen gab und die Karte >5s gebraucht hat um das new zu schreiben, sodass in der zwischenzeit ein zweiter Prozess gestartet hat zu schreiben und die sich dann komisch überlappt haben (aber geht das zwei mal gleiches File zum schreiben öffnen ... dachte wird eher gelockt ... hm ....)
                                  Thomas Braun Most Active @apollon77 last edited by Thomas Braun
                                  @apollon77
                                  Ist ein Raspi 4 mit 8 GB auf einer 32GB-SD-Karte, die auch keine Ausfallerscheinungen zeigt, soweit ich sehe.
                                  [Mo Mai  3 17:47:03 2021] mmc1: new high speed SDIO card at address 0001
                                  [Mo Mai  3 17:47:03 2021] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                                  (Zufällig(?) genau eine Stunde zuvor ein Reboot gemacht.)
                                  Und eigentlich meine ich das System recht schlank zu haben, das sollte sich mehr oder weniger langweilen.
                                  Objekte: 4668, Zustände: 3998
                                  sagt mir der Objekte-Reiter. Das sollte ja eigentlich noch nicht kritsch sein.
                                  pi@chet:~ $ iobroker status
                                  Objects type: file
                                  States  type: redis
                                    @thomas-braun Danke, wir haben geschaut und eine Stelle optimiert die potentiell parallele DB Speichern-Fälle erzeugen konnte. Kommt in 3.3.8 später
                                      @apollon77
                                      Aber nich wieder meine Beleuchtung ausknipsen, wie mit dem 3.3.6, okay? 😄
                                        @thomas-braun Ach menno ... gönnst mir aber auch gar keinen Spass 😉
                                        Eine Bitte mit der 3.3.8 - da wir dort was am Speicherverhalten ändern (an sich unkritisch aber sicher ist sicher) bitte verifizieren nach dem Update das die beiden jsons danach regelmäßig geschrieben werden. Erste Tests bei mir waren ok.
                                          3.3.8 (2021-05-03)
                                          • (Apollon77/foxriver76) Optimize Database storage behaviour for file database
                                          • (foxriver76) change default behaviour of cli update command -> only list installed, allow --all as parameter to see all again
                                            @apollon77
                                            Kurztest: Beide Dateien werden regelmäßig (Timestamp etwa minütlich) geschrieben. Ist das normal oder richtig in der Häufigkeit? Hab das nicht im Blick wie es sein soll.
                                            302
                                            69469
