    4. Test Adapter Material Design Widgets v0.5.x
      Marcel85 last edited by Marcel85
      ich habe ein "kleines" Problem beim erstellen von Widgets mit HTML.
      Es werden dann zum Teil Werte überschrieben wenn man ein zweites Widget einfügt.
      Ich hänge mal ein Widget an.
      [{"tpl":"tplVis-materialdesign-Button-State-vertical","data":{"oid":"nothing_selected","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"raised","vibrateOnMobilDevices":"50","iconPosition":"top","autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockFilterGrayscale":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"buttontext":"<div>\n<div class='vis-widget materialdesign-widget materialdesign-button materialdesign-button-html-element'\n\tstyle='width: 100px; height: 100px; position: absolute; top: 15px; left: 10px; padding: 0px;'\n\tmdw-type='state_vertical'\n\tmdw-buttonStyle='text'\n\tmdw-value='true'\n\tmdw-vibrateOnMobilDevices='50'\n\tmdw-buttontext='Rolladen'\n\tmdw-textFontFamily='RobotoCondensed-Bold'\n\tmdw-textFontSize='18'\n\tmdw-alignment='center'\n\tmdw-mdwButtonPrimaryColor='{0_userdata.0.VIS.07.Farbe.Akzentfarbe.Akzentfarbcode}'\n\tmdw-mdwButtonSecondaryColor='{0_userdata.0.VIS.07.Farbe.Akzentfarbe.Akzentfarbcode}'\n\tmdw-image='alpha-r-box'\n\tmdw-imageColor='{0_userdata.0.VIS.07.Farbe.Akzentfarbe.Akzentfarbcode}'\n\tmdw-iconPosition='top'\n\tmdw-iconHeight='40'\n\tmdw-autoLockAfter='10'\n\tmdw-lockIconTop='5'\n\tmdw-lockIconLeft='5'\n\tmdw-lockIconColor='#mdwTheme:vis-materialdesign.0.colors.button.lock_icon'\n\tmdw-lockFilterGrayscale='30'\n></div>\n<div class='vis-widget materialdesign-widget materialdesign-button2 materialdesign-button-html-element'\n\tstyle='width: 150px; height: 80px; position: absolute; top: 25px; left: 120px; padding: 0px;'\n\tmdw-type='toggle_vertical'\n\tmdw-oid='nothing_selected'\n\tmdw-buttonStyle='text'\n\tmdw-toggleType='boolean'\n\tmdw-stateIfNotTrueValue='on'\n\tmdw-vibrateOnMobilDevices='50'\n\tmdw-buttontext='Rolladen fahren um {shuttercontrol.0.info.upTimeLiving} Uhr hoch'\n\tmdw-labelTrue='Rolladen fahren um {shuttercontrol.0.info.downTimeLiving} Uhr herunter'\n\tmdw-labelColorFalse='#ffffff'\n\tmdw-labelColorTrue='#ffffff'\n\tmdw-textFontFamily='RobotoCondensed-Bold'\n\tmdw-textFontSize='18'\n\tmdw-alignment='center'\n\tmdw-distanceBetweenTextAndImage='10'\n\tmdw-mdwButtonPrimaryColor='#212121'\n\tmdw-mdwButtonSecondaryColor='#ffffff'\n\tmdw-colorBgFalse='#212121'\n\tmdw-colorBgTrue='#212121'\n\tmdw-image='archive-arrow-up'\n\tmdw-imageColor='#ffffff'\n\tmdw-imageTrue='archive-arrow-down'\n\tmdw-imageTrueColor='#ffffff'\n\tmdw-iconPosition='top'\n\tmdw-iconHeight='26'\n\tmdw-autoLockAfter='10'\n\tmdw-lockIconTop='5'\n\tmdw-lockIconLeft='5'\n\tmdw-lockIconColor='#mdwTheme:vis-materialdesign.0.colors.button.lock_icon'\n\tmdw-lockFilterGrayscale='30'\n></div>\n</div>","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.vertical.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.vertical.text","alignment":"center","mdwButtonPrimaryColor":"{0_userdata.0.VIS.07.Farbe.Hell_Dunkel.Widgets}","mdwButtonSecondaryColor":"{0_userdata.0.VIS.07.Farbe.Hell_Dunkel.Widgets}","image":"pencil","iconHeight":"26","lockIconColor":"#mdwTheme:vis-materialdesign.0.colors.button.lock_icon","generateHtmlControl":"true","value":"8"},"style":{"left":"880px","top":"500px","background":"{0_userdata.0.VIS.07.Farbe.Hell_Dunkel.Widgets}","width":"280px","height":"120px","z-index":"2"},"widgetSet":"materialdesign"}]
      Dort sollte eigentlich die Textfarbe bei "Rolladen" in einer anderen Farbe sein als weiß.
      Schon mal vielen Dank.
      Es liegt wahrscheinlich nur an meiner Unwissenheit beim Programmieren.
      Gruß Marcel
      • O
        Oli @Scrounger last edited by
        @scrounger
        ich habe mir soeben mal wieder eine neue Version gegönnt. Leider werden damit keine Farbeinstellungen mehr übernommen.
        Wenn ich die Farben manuell im Widget ändere funktioniert es.
        Ist das ein Fehler, oder sitzt das Problem wieder mal vor der Tastatur?
        • Scrounger
          Scrounger Developer @Oli last edited by
          @oli
          Generell oder nur beim Tablet Widget?
          Was steht in der console, debug Modus davor aktivieren?
          • O
            @scrounger
            betrifft leider alle Widgets von dir.
            adapter/rssfeed/words.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
            dimmer.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
            DevTools failed to load SourceMap: Could not load content for http://192.168.2.120:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
            instrument.ts:129 [Button w00348] stop waiting after 100 retries
            (anonymous) @ instrument.ts:129
            waitForElement @ widgets.min.js:1
            (anonymous) @ widgets.min.js:1
            sentryWrapped @ helpers.ts:87
            setTimeout (async)
            (anonymous) @ trycatch.ts:119
            setTimeout (async)
            setTimeout (async)
            • Scrounger
              @oli
              Hast du VIS Adapter 1.3.8 installiert?
              Ich brauch das vollständige log ab laden der runtime.
              • O
                @scrounger
                ja, ich habe die Version 1.3.8 installiert
                Ich hoffe ich hab jetzt das Richtige
                log Console
                • Scrounger
                  @oli
                  Teste bitte die aktuelle Version von github.
                  In den Adapter Themen settings alle zurücksetzen, also hell, dunkel, Schriftart und Schriftgröße - Button oben rechts.
                  Und wichtig vis Upload machen!
                  O 2 Replies Last reply Reply Quote 0
                  • O
                    @scrounger
                    nach ersten Tests, sollte wieder alles funktionieren, Danke
                    • O
                      @scrounger
                      Sorry, aber ein Problem ab ich beim Dialog Widget och festgestellt
                      • Scrounger
                        Scrounger Developer @Oli last edited by Scrounger
                        @Oli
                        wie immer console log?
                        Debug Modus beim Widget davor aktivieren
                        • O
                          @scrounger
                          sorry für die doofe Frage, aber wo aktiviere ich den Debug Modus bei einem Widget?
                          • Glasfaser
                            Glasfaser last edited by
                            @oli
                            Unter Editor Settings :
                            https://github.com/Scrounger/ioBroker.vis-materialdesign
                            • O
                              Oli @Glasfaser last edited by
                              @glasfaser
                              danke für den Hinweis, wieder was gelernt
                              • O
                                @scrounger
                                hier das gewünschte log
                                log neu
                                • Scrounger
                                  @oli
                                  Hast du das Dialog Widget angewählt bevor du das console log gezogen hast?
                                  Erstell Mal das Dialog Widget komplett neu.
                                  • O
                                    Oli @Scrounger last edited by Oli
                                    @scrounger
                                    Ja habe ich, heute schaffe ich es nicht mehr, liefer es morgen nach
                                    • Scrounger
                                      @oli
                                      OK da steht leider nix brauchbares drin. Dann bitte Dialog Widget komplett neu erstellen.
                                      • O
                                        @scrounger
                                        guten Morgen, habe den Fehler gefunden. Ich habe bei der Rahmenfarbe ein Binding hinterlegt, sobald ich das herausnehme funktioniert das Widget wieder
                                        Hier mal ein Export des Widgets.
                                        [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"360","vibrateOnMobilDevices":"50","buttonStyle":"raised","iconPosition":"left","closingClickOutside":"true","showTitle":"true","buttonPosition":"flex-end","buttonSize":"medium","signals-cond-0":">","signals-val-0":"0","signals-icon-0":"/icons-mfd-png/measure_battery_0.png","signals-icon-size-0":"40","signals-blink-0":false,"signals-horz-0":"7","signals-vert-0":"10","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"0","signals-icon-1":"/icons-mfd-png/measure_battery_100.png","signals-icon-size-1":"40","signals-blink-1":false,"signals-horz-1":"7","signals-vert-1":"10","signals-hide-edit-1":false,"signals-cond-2":">","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"Startseite_System_Batteriestatus_Dialog","dialogMaxWidth":"85%","viewHeight":"90%","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.background","showDivider":true,"dividerColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.divider","titleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.title","titleFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.title","title":"Batteriestatus","titleColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_text","buttonFullWidth":true,"buttonText":"Schließen","buttonFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.button","buttonFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.button","buttonFontColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_text","pressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_press","viewDistanceToBorder":"0","signals-oid-2":"","signals-oid-1":"0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm","signals-oid-0":"0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm","class":"","headerBackgroundColor":"linear-gradient(to bottom, #202020, grey, #202020)","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.default.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.secondary","fullscreenCloseIcon":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.dialog.close_button_icon;dark:vis-materialdesign.0.colors.dark.dialog.close_button_icon; mode === \"true\" ? dark : light}","imageColor":"#mdwTheme:vis-materialdesign.0.colors.button.icon.icon_off","footerBackgroundColor":"linear-gradient(to bottom, #202020, grey, #202020)","overlayColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.overlay","fullscreenCloseIconColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_icon","fullscreenCloseIconPressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_fullscreen_press","debug":true},"style":{"left":"calc(66% - 35px)","top":"45px","height":"50px","width":"50px","z-index":"1","background":"#2e2e2e","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","border-radius":"5px","border-color":"{wert:0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm; wert==0 ? \"green\" :: \"red\"}","border-style":"solid","border-width":"2px"},"widgetSet":"materialdesign"}]
                                        Stephan Schleich 1 Reply Last reply Reply Quote 0
                                        • Stephan Schleich
                                          Stephan Schleich @Oli last edited by
                                          @Scrounger Welcher Punkte wäre das in deinem Adapter wenn ich die Beschreibung in weiß ändern möchte? Ist nun ja direkt in deinem Adapter zu setzten wenn ich mich nicht irre
                                          • Scrounger
                                            Scrounger Developer @Stephan Schleich last edited by
                                            @stephan-schleich
                                            Du kannst es nach wie vor per vis Editor konfigurieren.
                                            Oder über die Adapter Einstellungen. Hier gibt's ein Filter Feld, dort den Namen des Widget eingeben oder auswählen und dann werden dir alle Einstellung für dieses Widget angezeigt. Die Beschreibung ist gleich wie im vis Editor.
                                            1.0k
                                            adapter material material design widgets vis visualisation widget
                                            22
                                            110
                                            17748
