    4. [gelöst] Backitup kann influxdb Datenbank nicht sichern.
    • Christian Kohlöffel
      Christian Kohlöffel @Thomas Braun last edited by Christian Kohlöffel
      Scheint nicht so, könnte aber durch das viele ausprobieren passiert sein, oder?:
      pi@raspberrypi:/opt/iobroker/backups $ ls
      2020_10_16-11_01_16_backupiobroker.tar.gz            iobroker_2021_04_11-11_01_47_backupiobroker.tar.gz
      2020_11_14-12_17_24_backupiobroker-migration.tar.gz  iobroker_2021_04_12-11_29_39_backupiobroker.tar.gz
      influxDB_2021_04_06-13_08_09_backupiobroker          iobroker_2021_04_12-11_31_07_backupiobroker.tar.gz
      influxDB_2021_04_06-20_42_54_backupiobroker          minimal_2019_07_05-16_31_00_backupiobroker.tar.gz
      influxDB_2021_04_10-11_16_08_backupiobroker          minimal_2019_07_05-16_34_26_backupiobroker.tar.gz
      influxDB_2021_04_10-11_19_37_backupiobroker          minimal_2019_07_05-16_38_03_backupiobroker.tar.gz
      influxDB_2021_04_10-11_19_37_backupiobroker.tar.gz   minimal_2019_07_05-16_39_57_backupiobroker.tar.gz
      influxDB_2021_04_10-11_26_55_backupiobroker.tar.gz   minimal_2019_07_05-16_44_06_backupiobroker.tar.gz
      influxDB_2021_04_10-14_09_39_backupiobroker          minimal_2019_07_05-16_44_52_backupiobroker.tar.gz
      influxDB_2021_04_10-14_16_00_backupiobroker.tar.gz   minimal_2019_07_05-16_45_40_backupiobroker.tar.gz
      influxDB_2021_04_10-14_25_24_backupiobroker.tar.gz   minimal_2019_07_05-16_49_17_backupiobroker.tar.gz
      influxDB_2021_04_11-10_42_17_backupiobroker.tar.gz   minimal_2019_07_05-16_51_12_backupiobroker.tar.gz
      influxDB_2021_04_11-11_01_55_backupiobroker.tar.gz   redis_2021_04_12-11_29_53_backupiobroker.tar.gz
      iobroker_2021_04_06-13_08_01_backupiobroker.tar.gz   redis_2021_04_12-11_31_16_backupiobroker.tar.gz
      iobroker_2021_04_10-11_15_57_backupiobroker.tar.gz   total_2019_07_22-03_00_21_backupiobroker.tar.gz
      iobroker_2021_04_10-11_19_29_backupiobroker.tar.gz   total_2019_07_23-03_00_20_backupiobroker.tar.gz
      iobroker_2021_04_10-11_26_47_backupiobroker.tar.gz   total_2019_07_30-03_00_21_backupiobroker.tar.gz
      iobroker_2021_04_10-14_09_31_backupiobroker.tar.gz   total_2019_08_11-03_00_21_backupiobroker.tar.gz
      iobroker_2021_04_10-14_15_51_backupiobroker.tar.gz   total_2019_08_25-03_00_21_backupiobroker.tar.gz
      iobroker_2021_04_10-14_25_16_backupiobroker.tar.gz   total_2019_08_26-17_26_29_backupiobroker.tar.gz
      iobroker_2021_04_11-10_42_09_backupiobroker.tar.gz   total_2019_08_26-19_22_49_backupiobroker.tar.gz
      Thomas Braun simatec 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Christian Kohlöffel last edited by
        @christian-kohlöffel
        Mountpunkte müssen/sollten leer sein. Sonst hast du da ggf Doubletten bei den inodes.
        Da deuten ja auch die Meldungen drauf hin. Mach das Verzeichnis mal leer. Entweder löschen oder da wegschieben.
        • simatec
          simatec Developer Most Active @Christian Kohlöffel last edited by simatec
          Mache mal ein
          sudo umount /opt/iobroker/backups
          Schaue dann nochmal ... Bei meinen Systemen liegen aber auch lokal Backups und das tut dem mount nix. Also bei mir zumindest noch nie Probleme gehabt. Nutze allerdings hauptsächlich NFS
          Thomas Braun Christian Kohlöffel 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @simatec last edited by
            @simatec sagte in Backitup kann influxdb Datenbank nicht sichern.:
            Bei meinen Systemen liegen aber such lokal Backups und das tut dem mount nix
            Solange die inodes unterschiedliche Nummerierung haben ist das auch kein großes Problem. Wenn die allerdings auf den beiden Dateisystemen gleich lautend sich überlagern hast du ein Problem.
              Christian Kohlöffel @simatec last edited by
              @simatec
              pi@raspberrypi:/opt/iobroker/backups $ sudo umount /opt/iobroker/backups
              umount: /opt/iobroker/backups: not mounted.
              Soll ich das alles löschen? Wenn ja passt der Befehl?
              sudo rm -r /opt/iobroker/backups/
                Thomas Braun Most Active @Christian Kohlöffel last edited by Thomas Braun
                sudo -u iobroker rm /opt/iobroker/backups/*
                • simatec
                  sudo rm -rf /opt/iobroker/backups/*
                  Christian Kohlöffel 1 Reply Last reply Reply Quote 0
                    @simatec
                    Super, danke euch beiden ✌
                    • simatec
                      Kein Problem ... kannst du das Thema bitte noch auf [gelöst] setzen?
                        Thomas Braun Most Active @simatec last edited by Thomas Braun
                        @simatec sagte in [gelöst] Backitup kann influxdb Datenbank nicht sichern.:
                        „noserverino“ wird in Backitup nicht als Option verwendet.
                        Ich könnte das aber testhalber mal einbauen
                        Hi @simatec ,
                        ich habe jetzt auch mal mit der Option 'noserverino' herumgespielt.
                        Also bei mir muss die bei Backups von redis auf ein FritzNAS (SMB 3.1.1) auch gesetzt sein, sonst wird das Backup nicht geschrieben.
                        Vermutlich als Nebeneffekt: Jetzt funktioniert auch das gemeinsame Backup auf GoogleDrive und das FritzNAS in einer Instanz. Bislang hatte ich das in jeweils eigene Instanzen aufteilen müssen.
                        • simatec
                          simatec Developer Most Active @Thomas Braun last edited by
                          @thomas-braun Super ... dann hat die Funktion zu integrieren etwas positives gebracht
                            @simatec
                            Ich würde das aber vielleicht noch in die ReadMe aufnehmen.
                            Vielleicht unter dem Punkt 'redis-Backup'.
                            Bei anderen Typen weiß ich nicht ob die Option gesetzt werden muss.
                            Wobei es hier ja auch um influx-Backup ging.
                            • simatec
                              Ja nehme ich mit auf. War die Tage nur mit der 2.1.3 beschäftigt
                              • V
                                virFortis last edited by
                                Ich wollte mich mal einfach nur bedanken. Habe heute ioBroker, Grafana und InfluxDB für die Rücksicherung eingestellt. Der ioBroker und Grafana liefen ohne Probleme aber die InfluxDb wollte und wollte einfach nicht. Problem war auch bei mir die SMB Version von 1.0. Nach euren Beiträgen und der Umstellung auf 3.1.1 werden jetzt alle in einem rutsch erfolgreich gesichert.
                                • simatec
                                  simatec Developer Most Active @virFortis last edited by
                                  @virfortis Das hört man gerne 👍
                                  8354
