    4. Probleme mit multihost slave nach node.js update
    • Mr. Qi
      Mr. Qi last edited by Mr. Qi
      @wendy2702
      Hier das log aus dem Slave
      2021-04-11 18:06:10.308  - info: host.IobrokerSlave Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-04-11 18:06:10.310  - info: host.IobrokerSlave hostname: IobrokerSlave, node: v12.22.1
      2021-04-11 18:06:10.311  - info: host.IobrokerSlave ip addresses: 192.168.178.29 2001:4dd3:bc98:0:ec94:df0d:3a4e:c3fa fe80::ebd8:7d12:20c5:ad6e 192.168.178.36 2001:4dd3:bc98:0:7f3b:ec48:5067:f0a0 fe80::3249:f072:1cc:e47
      2021-04-11 18:06:10.497  - info: host.IobrokerSlave connected to Objects and States
      2021-04-11 18:06:10.537  - info: host.IobrokerSlave added notifications configuration of host
      2021-04-11 18:06:11.146  - error: host.IobrokerSlave uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
      2021-04-11 18:06:11.148  - error: host.IobrokerSlave Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
          at Decipheriv.final (internal/crypto/cipher.js:172:29)
          at Object.decrypt (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1867:79)
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/main.js:202:46)
          at processImmediate (internal/timers.js:463:21)
      2021-04-11 18:06:11.160  - info: host.IobrokerSlave iobroker _restart
      2021-04-11 18:06:11.204  - warn: host.IobrokerSlave Cannot get view: Connection is closed.2021-04-11 18:06:11.205  - warn: host.IobrokerSlave Cannot get view: Connection is closed.2021-04-11 18:06:11.216  - info: host.IobrokerSlave no instances found
      2021-04-11 18:06:11.220  - error: host.IobrokerSlave Cannot write host object:Error: DB closed
      2021-04-11 18:06:11.222  - info: host.IobrokerSlave terminated
      2021-04-11 18:06:13.048  - info: host.IobrokerSlave iobroker.js-controller version 3.2.16 js-controller starting
      2021-04-11 18:06:13.056  - info: host.IobrokerSlave Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-04-11 18:06:13.058  - info: host.IobrokerSlave hostname: IobrokerSlave, node: v12.22.1
      2021-04-11 18:06:13.059  - info: host.IobrokerSlave ip addresses: 192.168.178.29 2001:4dd3:bc98:0:ec94:df0d:3a4e:c3fa fe80::ebd8:7d12:20c5:ad6e 192.168.178.36 2001:4dd3:bc98:0:7f3b:ec48:5067:f0a0 fe80::3249:f072:1cc:e47
      ^C
      master.admin@IobrokerSlave:~ $
      • Mr. Qi
        @wendy2702
        @Thomas-Braun
        @Latzi
        Ich bin noch mal in mich gegangen und kann nicht 100% sicher sage. Das ich an meinem multihost alles richtig gemacht habe.
        Aber so langsam wird mir klar das es so sein muss.
        Entschuldigt meine patzigen antworten. Deshalb hier die richtig Stellung.
        Ihr habt recht mir muss in irgend einer routine ein Fehler unterlaufen sein. Da es nur das multihost betrifft jeder Broker für sich tut was es soll. Ich werde denn Ratschlag mit dem Punkt im User beherzigen. Stammte mal aus einer Safty Anleitung für RPI und Smarthome.
        Ich spiele jetzt die backups in ein frisches system und korrigier ein paar config Fehler danach update ich Noch einmal. Ich melde mich mit dem Ergebnisse dann zurück.
        • Mr. Qi
          So jetzt hab ich es irgend wie geschafft ich kann mir nur nicht erklären was der Fehler war. Aus den vorhergegangenen log vom Slave haben wir ja bereit erfahren das er Objekte nicht finden kann oder keinen zugriff drauf hat.
          Ich habe jetzt kein neues System + Backup aufgespielt Sondern den Master RPI4 System mäßig auf Vordermann gebracht ganz nach den Anleitung und Tipps von @Thomas-Braun.
          1. Da ich dummerweise auf NPM7 gegangen bin war das die erste Baustelle
            Dokumentation Iobroker manuell Installation Schritt2-4
            hat ohne den ganze Broker neu aufzusetzen geklappt.
            Ich weis nicht ob das richtig war an dieser stelle ! ich habe in einer Forum gelesen das man im Anschluss ein:
          npm rebuild
          durchgeführt!
          F: wegen dem Versions Wechsel von NPM war das korrekt?
          1. Im zweiten schritt habe ich meine Datenbank mit den vorhandenen Redist Backups überholt. anschließend habe ich den Host gestoppt und den Slave gelöscht. 17054 multihost-slave-löschen
          2. Im dritten schritt habe ich mich nur damit befasst den Broker als Single lauffähig zu machen um ihn anschließend wieder mit einem Frischen Slave zu verbinden.
          3. Einrichten Multihost mit Redist
          Zum Schluss einmal die Fix durchlaufen lassen auf beiden Systemen.
          Iobroker Fix
          F:Wer kann mir dazu was sagen ich habe Objekte in file und Stats in redist wie euch sicher aufgefallen ist. der Grund dafür ist das ich vor geraume zeit Probleme mit den Dateien Manager von VIS hatte (Mann konnte keine einzige Datei sehen)
          Fazit bis auf die zwei fragen, so wie hier und da ein ein kleiner Schluckauf im System funktioniert alles einwandfrei auf.
          node und nodejs 12.22.1
          Npm 6.14.12
          Js Cont. 3.2.16
          • wendy2702
            wendy2702 @Mr. Qi last edited by
            @mr-qi sagte in Probleme mit multihost slave nach node.js update:
            Was sollen wir dir dazu denn sagen?
            Ist halt eine Möglichkeit iobroker zu betreiben.
            Mr. Qi 1 Reply Last reply Reply Quote 0
            • Mr. Qi
              Mr. Qi @wendy2702 last edited by
              @wendy2702
              Sorry wenn ich die Frage falsch formuliert habe!
              Meine frage richtet sich dahin das ich gern beides in redist betreiben möchte. Stats und Objekte.
              Ich stoße aber auf das Problem das dann im VIS der Dateienmanager unbrauchbar wird.
              Ist das normal?
              Ich hab es bislang nicht noch mal versucht. Aber vor geraume zeit ist bei mir das Problem aufgetreten und deshalb habe ich Objekte in File zurück konvertiert. ob mir dazu einer was sagen kann.
              wendy2702 apollon77 2 Replies Last reply Reply Quote 0
              • wendy2702
                @mr-qi Pauschal würde ich behaupten das ist nicht normal.
                Da ich aber Redis nicht benutze kann ich es leider auch nicht verifizieren.
                @apollon77 : hast du davon schon mal etwas gehört?
                  apollon77 @Mr. Qi last edited by apollon77
                  Was genau meinst Du? Auch mit Objects im Redis geht da alles.
                  Nur so der Vollständigkeit halber: Was Du mit Objects im Redis NICHT tun darfst ist zu erwarten das irgendwelche manuell in iobroker-data/files abgelegte Dateien beachtet werden ... kann es sein das du annimmst das das tut?
                  • Mr. Qi
                    Mr. Qi @apollon77 last edited by
                    @apollon77
                    Es ist schon eine Weile her aber dass kann es gewehsen sein.
                    Wie geheich den da vor wenn ich bei redis manuel daten abblege, dann probiere ich das mal aus.
                      @mr-qi Bei Nutzung von Redis kannst Du nur den vis File Editor (oder Admin 5.0.5 im latest der hat nen offiziellen File editor) nutzen. Manuell Files irgendwo hin kopieren ist auch für "Nicht redis DB" an sich nicht supportet und führt zu allerlei spass
                      • Mr. Qi
                        @apollon77
                        Ich meine ich hab es auch so gemacht ich muss mich damit befassen aber derzeit komme ich nicht dazu. Danke erst mal für die Hilfe.
                        Der Fehler mit dem Multi war ein updatefehler meinerseits und ist behoben.
                        Mit dem redis muss ich mich noch mal befassen.
                        Danke für die tip
                        crypto-js multihost verbindung multihostbetrieb node.js node node.js update
                        3093
