    4. [gelöst]Oilfox gestört?
      Thomas Braun Most Active @RolfM last edited by
      @rolfm Ja und nun?
      RolfM 1 Reply Last reply Reply Quote 0
      • RolfM
        RolfM @Thomas Braun last edited by
        @thomas-braun werde es noch posten, bin grade nicht vor Ort.
          Thomas Braun Most Active @RolfM last edited by Thomas Braun
          @rolfm
          Vielleicht das Ding:
          https://github.com/iobroker-community-adapters/ioBroker.oilfox/issues/54
          Da würde ich wohl ausnahmsweise mal mit der git-Version probieren.
          kj187 created this issue in iobroker-community-adapters/ioBroker.oilfox
          closed Obsolete version in NPM repository #54
          • RolfM
            @thomas-braun so bin wieder da und Sorry aber meine Kranke Mutter geht natürlich vor.
            Vielen Dank für den Hinweis mit der Git-Version, werde ich testen. Ansonsten hier noch die geforderte Textdatei.
            code_text
            host.raspberrypi 2021-04-24 00:01:38.395 info stopInstance canceled schedule system.adapter.oilfox.0
            host.raspberrypi 2021-04-24 00:01:38.393 info stopInstance system.adapter.oilfox.0 (force=false, process=false)
            host.raspberrypi 2021-04-24 00:01:38.389 info "system.adapter.oilfox.0" disabled
            host.raspberrypi 2021-04-24 00:00:02.571 error instance system.adapter.oilfox.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            oilfox.0 2021-04-24 00:00:02.020 warn (14672) Terminated (UNCAUGHT_EXCEPTION): Without reason
            oilfox.0 2021-04-24 00:00:02.018 info (14672) terminating
            oilfox.0 2021-04-24 00:00:01.500 error (14672) Unexpected token < in JSON at position 0
            oilfox.0 2021-04-24 00:00:01.500 error at processTicksAndRejections (internal/process/task_queues.js:84:21)
            oilfox.0 2021-04-24 00:00:01.500 error at endReadableNT (_stream_readable.js:1241:12)
            oilfox.0 2021-04-24 00:00:01.500 error at IncomingMessage.emit (events.js:326:22)
            oilfox.0 2021-04-24 00:00:01.500 error at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.oilfox/main.js:64:27)
            oilfox.0 2021-04-24 00:00:01.500 error at JSON.parse (<anonymous>)
            oilfox.0 2021-04-24 00:00:01.500 error (14672) SyntaxError: Unexpected token < in JSON at position 0
            oilfox.0 2021-04-24 00:00:01.498 error (14672) uncaught exception: Unexpected token < in JSON at position 0
            oilfox.0 2021-04-24 00:00:01.497 debug (14672) recieved data: <!doctype html><html lang="en"><head><title>HTTP Status 404 – Not Found</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;bac
            oilfox.0 2021-04-24 00:00:01.496 debug (14672) recieved chunk: <!doctype html><html lang="en"><head><title>HTTP Status 404 – Not Found</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;ba
            oilfox.0 2021-04-24 00:00:01.310 debug (14672) send data: {"email":"my-email","password":"myPaswd"}
            oilfox.0 2021-04-24 00:00:01.274 debug (14672) adapter.main: << MAIN >>
            oilfox.0 2021-04-24 00:00:01.273 debug (14672) adapter.on-ready: << READY >>
            oilfox.0 2021-04-24 00:00:01.231 info (14672) starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.oilfox, node: v12.22.1, js-controller: 3.2.16
            oilfox.0 2021-04-24 00:00:01.105 debug (14672) statesDB connected
            oilfox.0 2021-04-24 00:00:01.104 debug (14672) States connected to redis: 127.0.0.1:9000
            oilfox.0 2021-04-24 00:00:01.097 debug (14672) States create User PubSub Client
            oilfox.0 2021-04-24 00:00:01.095 debug (14672) States create System PubSub Client
            oilfox.0 2021-04-24 00:00:01.088 debug (14672) Redis States: Use Redis connection: 127.0.0.1:9000
            oilfox.0 2021-04-24 00:00:01.085 debug (14672) objectDB connected
            oilfox.0 2021-04-24 00:00:01.076 debug (14672) Objects connected to redis: 127.0.0.1:9001
            oilfox.0 2021-04-24 00:00:01.063 debug (14672) Objects client initialize lua scripts
            oilfox.0 2021-04-24 00:00:01.062 debug (14672) Objects create User PubSub Client
            oilfox.0 2021-04-24 00:00:01.061 debug (14672) Objects create System PubSub Client
            oilfox.0 2021-04-24 00:00:01.058 debug (14672) Objects client ready ... initialize now
            oilfox.0 2021-04-24 00:00:01.025 debug (14672) Redis Objects: Use Redis connection: 127.0.0.1:9001
              @rolfm
              Bitte den Text zwischen die CodeTags setzen.
              Mit Version 0.0.5 wirst du aber nicht weit kommen.
              • RolfM
                @thomas-braun ist das so jetzt richtig?```
                  @rolfm
                  Nö. Siehste vermutlich selber.
                  Und da läuft immer noch Version 0.0.5
                  • RolfM
                    @thomas-braun so nun möchte ich dir erst einmal herzlich danken für deine Geduld die du mir gegenüber aufgebracht hast. Mit deinem Vorschlag die Git-Version zu nehmen läuft nun alles wunderbar. Das mit den CodeTags musst du mir noch mal erklären oder sagen wo ich das nachschlagen kann, da ich mit der suche keine richtigen Treffer landen konnte. Noch mal vielen Dank.
                      @rolfm
                      CodeTags:
                      </> Icon anklicken
                      Text aus der Zwischenablage reinkopiern, Posting abspeichern.
                      • RolfM
                        @thomas-braun komisch, so hab ich das doch gemacht, trotzdem Danke noch mal.
                          @rolfm
                          Dann setze Absätze. Die Steuerzeichen stehen am besten alleine in einer Zeile.
                          • RolfM
                            @thomas-braun alles klar, werd ich mir merken.
                            537
