    4. backitup redis ENOENT
      Thomas Braun Most Active @Xyolyp last edited by
      @xyolyp
      smb ist allerdings das bessere Protokoll im Vergleich zu ftp.
      Das würde ich versuchen ans fliegen zu bringen.
      Hier mal meine funktionierenden Einstellungen.
      Backitup:
      In der FritzBox User:
      Freigabe:
      • X
        Xyolyp @Thomas Braun last edited by
        @thomas-braun mit identischen Einstellungen scheitert bei mir wieder das redis backup. Inzwischen nachhaltig auch wenn ich nicht per SMB sichere.
          @xyolyp
          Mit welchen Meldungen im log file?
          • X
            Started iobroker ...
            [DEBUG] [iobroker] - host.iobroker 4162 states saved
            [DEBUG] [iobroker] - host.iobroker 5969 objects saved
            [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2021_04_25-15_23_36_backupiobroker.tar.gz'
            [DEBUG] [iobroker] - done
            [DEBUG] [redis] - Start Redis Backup ...
            [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" cannot created
            [ERROR] [redis] - Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/redistmp/dump.rdb'
            [ERROR] [redis] - [IGNORED] Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/redistmp/dump.rdb'
            [DEBUG] [javascripts] - javascript directory "/opt/iobroker/backups/javascript" not found
            [DEBUG] [javascripts] - done
            [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
            [DEBUG] [clean] - done
            [DEBUG] [telegram] - done
            [DEBUG] [historyHTML] - new history html values created
            [DEBUG] [historyHTML] - done
            [DEBUG] [historyJSON] - new history json values created
            [DEBUG] [historyJSON] - done
            [EXIT] 9
              Thomas Braun Most Active @Xyolyp last edited by Thomas Braun
              @xyolyp
              Da muss eigentlich mehr vorab kommen.
              Wird da eine Freigabe in /opt/iobroker/backups gemounted?
              Denn eigentlich sieht das so aus, wenn ein smb-Share eingehängt wird:
              [DEBUG] [mount] - mount successfully completed
              [DEBUG] [mount] - done
              [DEBUG] [iobroker] - host.raspberrypi 3911 states saved
              [DEBUG] [iobroker] - host.raspberrypi 4751 objects saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_04_25-15_28_21_backupiobroker.tar.gz
              [DEBUG] [redis] - Created redistmp directory
              [DEBUG] [redis] - redis-cli save started, please wait ...
              [DEBUG] [redis] - redis-cli save finish
              [DEBUG] [redis] - detected redis file: dump.rdb | file type: rdb
              [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_04_25-15_28_34_backupiobroker.tar.gz
              [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
              [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
              [DEBUG] [redis] - done
              [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_04_25-15_28_35_backupiobroker.tar.gz
              [DEBUG] [cifs] - done
              [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_04_25-15_28_21_backupiobroker.tar.gz...
              [DEBUG] [googledrive] - Google Drive: Copy redis_2021_04_25-15_28_34_backupiobroker.tar.gz...
              [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_04_25-15_28_35_backupiobroker.tar.gz...
              [DEBUG] [googledrive] - done
              [DEBUG] [whatsapp] - done
              [DEBUG] [umount] - mount activ, umount is started ...
              [DEBUG] [umount] - umount successfully completed
              [DEBUG] [umount] - done
              [EXIT] 0
              • X
                @thomas-braun SMB und FTP sind deaktiviert bei dem Backup Vorgang, um zu demonstrieren, dass es leider ohne entfernte Sicherung auch schon nicht mehr funktioniert
                  @xyolyp
                  Kann es sein, dass die Rechte verfummelt sind?
                  Mit mit
                  iobroker stop
                  iobroker fix
                  versucht?
                  Denn bei mir wird in
                  während des Backups natürlich ein Ordner backup für kurze Zeit angelegt. tmp halt. Offenbar funktioniert das ja schon nicht.
                  • X
                    @thomas-braun auch nach dem Fixer besteht der Fehler unverändert
                      @xyolyp
                      Wie sehen die Rechte dort aus:
                      getfacl /opt/iobroker/node_modules/iobroker.js-controller/tmp/
                      • X
                        @thomas-braun der Output von getfacl ist
                        getfacl: Removing leading '/' from absolute path names
                        # file: opt/iobroker/node_modules/iobroker.js-controller/tmp/
                        # owner: iobroker
                        # group: iobroker
                        user::rwx
                        group::r-x
                        group:iobroker:rwx
                        mask::rwx
                        other::r-x
                        default:user::rwx
                        default:group::r-x
                        default:group:iobroker:rwx
                        default:mask::rwx
                        default:other::r-x
                          @xyolyp Passt.
                          1097
