    4. [gelöst] Web Socket Error
      derrapf last edited by
      Hallo
      Ich habe inzischen einen neuen Bananapi mit Jessie und den aktuellen Adaptern aufgesetzt.
      Bei mir komt der Fehler ziemlich gleich nachdem Ich in VIS in den Editmodus gehe und an irgendeinem Widget rumschraube.
      Im Log hab ich dann
      ioBroker-BPi	2017-01-09 18:20:39.694	info	host.ioBroker-BPi Restart adapter system.adapter.javascript.0 because enabled
      ioBroker-BPi	2017-01-09 18:20:39.693	error	host.ioBroker-BPi instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 18:20:39.369	info	javascript.0 received all objects
      javascript.0	2017-01-09 18:20:37.801	info	javascript.0 received all states
      javascript.0	2017-01-09 18:20:34.318	info	javascript.0 requesting all objects
      javascript.0	2017-01-09 18:20:34.317	info	javascript.0 requesting all states
      javascript.0	2017-01-09 18:20:34.315	info	javascript.0 starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
      host.ioBroker-BPi	2017-01-09 18:20:28.457	info	instance system.adapter.javascript.0 started with pid 14937
      host.ioBroker-BPi	2017-01-09 18:19:58.367	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-BPi	2017-01-09 18:19:58.365	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-01-09 18:19:58.321	info	terminating
      javascript.0	2017-01-09 18:19:58.293	error	at Zlib.callback (zlib.js:625:5)
      javascript.0	2017-01-09 18:19:58.293	error	at TransformState.afterTransform (_stream_transform.js:54:12)
      javascript.0	2017-01-09 18:19:58.293	error	at afterTransform (_stream_transform.js:79:3)
      javascript.0	2017-01-09 18:19:58.293	error	at WritableState.onwrite (_stream_writable.js:89:5)
      javascript.0	2017-01-09 18:19:58.293	error	at onwrite (_stream_writable.js:345:7)
      javascript.0	2017-01-09 18:19:58.293	error	at afterWrite (_stream_writable.js:354:3)
      javascript.0	2017-01-09 18:19:58.293	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
      javascript.0	2017-01-09 18:19:58.293	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
      javascript.0	2017-01-09 18:19:58.293	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      javascript.0	2017-01-09 18:19:58.293	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      javascript.0	2017-01-09 18:19:58.293	error	at WebSocket.emit (events.js:172:7)
      javascript.0	2017-01-09 18:19:58.293	error	at emitTwo (events.js:87:13)
      javascript.0	2017-01-09 18:19:58.293	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      javascript.0	2017-01-09 18:19:58.293	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      javascript.0	2017-01-09 18:19:58.293	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2017-01-09 18:19:58.293	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2017-01-09 18:19:58.293	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 18:19:58.293	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
      javascript.0	2017-01-09 18:19:58.293	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
      javascript.0	2017-01-09 18:19:58.293	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 18:19:58.293	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 18:19:58.293	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      javascript.0	2017-01-09 18:19:58.293	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      javascript.0	2017-01-09 18:19:58.293	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      javascript.0	2017-01-09 18:19:58.293	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 18:19:58.293	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      javascript.0	2017-01-09 18:19:58.293	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2017-01-09 18:19:58.293	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2017-01-09 18:19:58.293	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2017-01-09 18:19:58.293	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      javascript.0	2017-01-09 18:19:58.293	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
      javascript.0	2017-01-09 18:19:58.293	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
      javascript.0	2017-01-09 18:19:58.293	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
      javascript.0	2017-01-09 18:19:58.293	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
      javascript.0	2017-01-09 18:19:58.293	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
      javascript.0	2017-01-09 18:19:58.267	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
      Wobei ich nicht weiss ob das direkt was damit zu tun hat.
      Gruss Ralf
      • Bluefox
        Bluefox last edited by
        Hast du ein Coffescript?
        ICh vermute - nein. Schalte mal JS adapter aus und probiere noch mal.
          Hallo Bluefox
          Nochmal für die Blöden: Was ist ein Coffe-Script?
          Ja, Ich habe Java-Scripts am Laufen.
          Ich nehme an mit JS ausschaten meinst Du Java-Script ausschalten und nicht den JS-Controller
          Das kann ich zwar machen, aber dann laufen ja meine Scripte nicht mehr. Was hab ich dann davon?
          Ich verstehe nicht ganz auf was Du raus willst..!?
          Gruss Ralf
            Mit dem javascript Adapter kannst du drei arten von Skripts erstellen und ausführen
            • javascript
            • coffeescript
            • blockly
            Die Fehlermeldung sagt etwas von einem coffeescript!
            Entweder hast du eins, was Bluefox und ich nicht glauben, oder du hast bei der Erstellung eines javascript die Einstellung coffeescript gewählt.
            Rainer
            • Jeeper.at
              Jeeper.at last edited by
              Wollte mal anfragen ob es eine Lösung zu dem Web Socket Problem vom Thread Anfang gibt.
              Es ist nach wie vor vorhanden und tritt bei fast jedem einschalten des Tablets auf.
              Lg
              Günther
              • Bluefox
                @Jeeper.at:
                Lg
                Günther `
                hast du 0.12.4 ? Wenn nicht, dann verstehe ich nicht was du erwartest.
                • Jeeper.at
                  Von was?
                  VIS?
                  Nein habe ich nicht, weil im ganzen Thread nix davon steht, das diese Version das beheben soll.
                  Na dann werde ich mal einen Test starten.
                  Lg
                  Günther
                  • Jeeper.at
                    So, kann bestätigen, das mit der git Version der Web Socket Error weg ist. Dafür habe ich ne Menge andere Probleme. Die werde ich aber noch genauer anschauen und in anderen Threads posten.
                    LG
                    Günther
                    • rantanplan
                      rantanplan last edited by
                      Hallo Jeeper.at
                      Ich bin wieder auf die VIS 0.10.15 zurück.
                      Die neue Version machte bei mir nur Chaos.
                      Da lebe ich lieber mit einem kleinen Socket Error.
                      • htrecksler
                        htrecksler Forum Testing last edited by
                        @rantanplan:
                        Hallo Jeeper.at
                        Die neue Version machte bei mir nur Chaos. `
                        Kann ich nicht bestätigen. Die Version läuft bei mir fast ohne Probleme. Einzig die Probleme mit der Sichtbarkeit sind immer noch da. (aber die hatte ich auch in den vorherigen Versionen. Wenn sich die Bedingung zur Sichtbarkeit ändert (Status Regensensor) während das Tablet ausgeschaltet ist (z. B. Nachts) kriegt die Visualisierung das nicht mit. Erst nach einem Neuladen der Seite ist die Sichtbarkeit dann korrekt.
                        Aber ansonsten…sehr sehr stabile Version.
                          Hallo Rainer
                          @Homoran:
                          • javascript
                          • coffeescript
                          • blockly
                          r `
                          Ahhhh!!!! Jetzt hab ich es geschnallt.
                          Ich dachte Coffeecript ist einfach der Name des Java-Script Adapters (in Anlehnung an Java. Was ja auch ein Kaffee ist) . Deine erste Vermutung war richtig. Jetzt sind die Fehler weg.
                          Danke.
                          Gruss Ralf
                            Ritschi last edited by
                            Hallo
                            Leider ist bei mir der Web socket error immer noch vorhanden.
                            Den java skript Adapter habe ich nicht installiert, von da her kann es also nicht kommen.
                            Ich habe vis 0.10.15 am laufen.
                            Es soll da anscheinend schon einen neuere Version geben, allerdings wird diese bei mir nicht angezeigt.
                            Nun habe ich auf github die Version 0.12.11 gesehen.
                            Die Frage ist nur, wie insalliere ich denn diese Version?
                            Danke schon mal für die Hilfestellung.
                            Gruss
                            Ritschi
                            • eric2905
                              eric2905 last edited by
                              Ohne mir den ganzen Thread (im Urlaub) durchzulesen, ein kleiner Hinweis:
                              Ich bekomme den Websocket-Fehler auf meinem iPad, wenn dort Vis geladen ist (sei es im Safari oder in Kiosk) und ich dann die ioBroker-Maschine durchstarte - das iPad also den Connect verliert.
                              Habt ihr ggf. ähnliche Konstellationen, wo der Connect wackelt?
                              Nur als Hinweis. Wenn's schon gesagt wurde, dann einfach ignorieren.
                              Gruß,
                              Eric
                              • Jeeper.at
                                Mit den aktuellen 0.12.x Versionen die man von GIT installieren kann ist der Fehler weg.
                                Lg
                                Günther
                                  Ich habe 0.12.17
                                  Trotzdem kommt immer wieder der Websocket Error.
                                  In VIS, speziell wenn ich am editieren von Views bin. Inzwischen läuft alles auf Raspi, weil ich Fehler am Bananapi ausschliessen wollte; und der PI hängt auch am Kabel um Fehler über WLAN auszuschliessen. Wie befürchtet war es das alles nicht. De Verbindungsabbrueche bestehen weiterhin. Sowohl beim Editieren von Views als auch beim normalen Betrieb von Vis. Aus dem gleichen Grund wird bei mir wohl auch die VIS-App nicht funktionieren.
                                  Gruss Ralf
                                  • Bluefox
                                    @derrapf:
                                    Ich habe 0.12.17
                                    Gruss Ralf `
                                    Screenshot?
                                      Hi Bluefox
                                      Hab eben festgestellt: Wenn VIS spinnt, komme ich auch nicht mehr auf die IOBroker Seite und auch per Telnet geht nichts mehr. Wenn dann die Verbindung wieder steht, sehe ich im Log folgendes
                                      web.0	2017-03-21 23:10:50.883	info	web.0 2017-03-21T22:10:50.866Z Connected system.user.admin
                                      web.0	2017-03-21 23:10:48.899	info	web.0 http server listening on port 8082
                                      web.0	2017-03-21 23:10:48.898	info	web.0 socket.io server listening on port 8082
                                      web.0	2017-03-21 23:10:47.292	info	web.0 starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.web, node: v4.7.2
                                      ioBroker-Pi2	2017-03-21 23:10:43.516	info	host.ioBroker-Pi2 instance system.adapter.web.0 started with pid 22730
                                      ioBroker-Pi2	2017-03-21 23:10:25.863	info	host.ioBroker-Pi2 instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
                                      tvspielfilm.0	2017-03-21 23:10:24.854	info	tvspielfilm.0 objects written
                                      tvspielfilm.0	2017-03-21 23:10:24.732	info	tvspielfilm.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v4.7.2
                                      hm-rpc.1	2017-03-21 23:10:18.283	warn	hm-rpc.1 Reconnection to DB.
                                      hm-rpc.1	2017-03-21 23:10:18.221	warn	hm-rpc.1 Reconnection to DB.
                                      rpi2.0	2017-03-21 23:10:17.177	warn	Reconnection to DB.
                                      rpi2.0	2017-03-21 23:10:16.753	warn	Reconnection to DB.
                                      hm-rpc.0	2017-03-21 23:10:16.422	warn	Reconnection to DB.
                                      hm-rpc.0	2017-03-21 23:10:15.989	warn	Reconnection to DB.
                                      javascript.0	2017-03-21 23:10:15.407	warn	Reconnection to DB.
                                      javascript.0	2017-03-21 23:10:15.388	warn	Reconnection to DB.
                                      telegram.0	2017-03-21 23:10:14.679	warn	Reconnection to DB.
                                      simple-api.0	2017-03-21 23:10:14.590	warn	Reconnection to DB.
                                      text2command.0	2017-03-21 23:10:14.563	warn	Reconnection to DB.
                                      history.0	2017-03-21 23:10:14.492	warn	Reconnection to DB.
                                      text2command.0	2017-03-21 23:10:14.448	warn	Reconnection to DB.
                                      admin.0	2017-03-21 23:10:14.215	warn	Reconnection to DB.
                                      hm-rega.0	2017-03-21 23:10:14.205	warn	Reconnection to DB.
                                      fritzbox.0	2017-03-21 23:10:14.175	warn	Reconnection to DB.
                                      amazon-dash.0	2017-03-21 23:10:14.139	warn	Reconnection to DB.
                                      socketio.0	2017-03-21 23:10:14.129	warn	Reconnection to DB.
                                      admin.0	2017-03-21 23:10:14.095	warn	Reconnection to DB.
                                      sayit.0	2017-03-21 23:10:14.069	warn	Reconnection to DB.
                                      hm-rega.0	2017-03-21 23:10:14.058	warn	Reconnection to DB.
                                      telegram.0	2017-03-21 23:10:13.962	warn	Reconnection to DB.
                                      history.0	2017-03-21 23:10:13.951	warn	Reconnection to DB.
                                      simple-api.0	2017-03-21 23:10:13.946	warn	Reconnection to DB.
                                      fritzbox.0	2017-03-21 23:10:13.943	warn	Reconnection to DB.
                                      amazon-dash.0	2017-03-21 23:10:13.895	warn	Reconnection to DB.
                                      socketio.0	2017-03-21 23:10:13.872	warn	Reconnection to DB.
                                      sayit.0	2017-03-21 23:10:13.763	warn	Reconnection to DB.
                                      host.ioBroker-Pi2	2017-03-21 23:10:13.415	warn	instance system.adapter.tvspielfilm.0 does not started, because just executed
                                      host.ioBroker-Pi2	2017-03-21 23:10:13.397	info	Restart adapter system.adapter.web.0 because enabled
                                      host.ioBroker-Pi2	2017-03-21 23:10:13.396	error	instance system.adapter.web.0 terminated with code null ()
                                      host.ioBroker-Pi2	2017-03-21 23:10:13.385	warn	instance system.adapter.web.0 terminated due to SIGKILL
                                      host.ioBroker-Pi2	2017-03-21 23:10:12.830	info	instance system.adapter.tvspielfilm.0 started with pid 22588
                                      Wenn es nochmal passiert mache ich Dir einen Screenshot
                                      Gruss Ralf
                                        Und schon wieder:
                                        web.0	2017-03-21 23:16:21.056	info	2017-03-21T22:16:21.055Z Connected system.user.admin
                                        web.0	2017-03-21 23:16:19.280	info	http server listening on port 8082
                                        web.0	2017-03-21 23:16:19.272	info	socket.io server listening on port 8082
                                        web.0	2017-03-21 23:16:17.188	info	starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.web, node: v4.7.2
                                        host.	2017-03-21 23:16:17.058	info	States connected to redis 127.0.0.1:6379
                                        host.ioBroker-Pi2	2017-03-21 23:16:11.984	info	instance system.adapter.web.0 started with pid 22874
                                        host.ioBroker-Pi2	2017-03-21 23:15:39.397	info	Restart adapter system.adapter.web.0 because enabled
                                        host.ioBroker-Pi2	2017-03-21 23:15:39.396	error	instance system.adapter.web.0 terminated with code null ()
                                        host.ioBroker-Pi2	2017-03-21 23:15:39.394	warn	instance system.adapter.web.0 terminated due to SIGKILL
                                        host.ioBroker-Pi2	2017-03-21 23:15:06.099	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
                                        tvspielfilm.0	2017-03-21 23:15:04.664	info	objects written
                                        Und nochmal:
                                          Hallo Bluefox
                                          Du wolltes vor knapp 2 Monaten einen Screenshot von mir. Den hatte ich eingestellt.
                                          Hat das was geholfen? Du hast nie wieder geantwortet….
                                          Gruss Ralf
                                          • Bluefox
                                            Ich vermute, dass dein Problem dann passiert, wenn WEB adapter sich verabschiedet.
                                            Jetzt muss man rausfinden warum web neu gestartet wird.
                                            Kannst du Auf DEBUG level umschalten und web beobachten?
                                            46
                                            8336
