    2. English
    3. ioBroker general
    4. How to replace null with 0 using alias-manager
    • Tomasz Nowak
      Tomasz Nowak @apollon77 last edited by
      @apollon77
      This is JSON for an alias object:
        "user": "system.user.admin",
        "ts": 1619609676629,
        "common": {
          "name": "Scene ID",
          "role": "level",
          "type": "number",
          "read": true,
          "write": true,
          "alias": {
            "id": "zwave2.0.Node_014.Scene_Activation.sceneId",
            "read": "val == null?0:val"
        "native": {},
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
        "_id": "alias.0.Fibaro_Dimmer_1_SceneID.sceneId",
        "type": "state"
      and this is for the source object:
        "type": "state",
        "common": {
          "role": "level",
          "read": true,
          "write": true,
          "name": "Scene ID",
          "type": "number",
          "min": 1,
          "max": 255
        "native": {
          "nodeId": 14,
          "valueId": {
            "commandClass": 43,
            "endpoint": 0,
            "property": "sceneId"
        "from": "system.adapter.zwave2.0",
        "ts": 1619558168447,
        "_id": "zwave2.0.Node_014.Scene_Activation.sceneId",
        "acl": {
          "object": 1636,
          "state": 1636,
      Thanks
      Tomasz Nowak 1 Reply Last reply Reply Quote 0
      • Tomasz Nowak
        Tomasz Nowak @Tomasz Nowak last edited by
        Mqtt-client crash log is here (I've created an issue out of this):
        https://github.com/Pmant/ioBroker.mqtt-client/issues/45
        tnowak created this issue in Pmant/ioBroker.mqtt-client
        closed Uncaught exception: Cannot read property 'from' of null #45
          apollon77 @Tomasz Nowak last edited by
          @tomasz-nowak js-controller Version??
          • Tomasz Nowak
            @apollon77
            • JS-Controller version: 3.2.16
            • Node version: v12.22.1
            • Operating system: docker image @ Raspberry OS
            • all adapters in current released versions
              Ok, jetuzt mal ganz genau: was ist der exakte wert?
              • In allen screenshots ist gar kein Wert zu sehen - auch nicht "null"
              • Der mqtt-client Adapter crasht weil der state an sich "null" ist - also NICHT "state wert ist null" sondern es gibt gar keinen state!! Nix
              • Aliasse greifen dann nicht weil Sie nur Werte mappen - bedeutet also das der resulting Alias auch "keinen Wert hat"
              Am besten dazu jetzt mal
              iobroker state get zwave2.0.Node_014.Scene_Activation.sceneId
              machen und Ausgabe posten.
              • Tomasz Nowak
                @apollon77 said in How to replace null with 0 using alias-manager:
                Yes, no value is seen on the screenshots because there no value at all for most of the time. It gets "26" or "24" depending on number of clicks, but only for a second. Then it returns to empty / null.
                Now, because mqtt-client can't handle this correctly, I've been trying to alias this object somehow to push it to MQTT anyway. So, I can not rewrite empty object with any custom value (such as "0" for instance)?
                • Tomasz Nowak
                  Tomasz Nowak @Tomasz Nowak last edited by Tomasz Nowak
                  Thats strange:
                  And I still see this object in ioBroker admin panel
                    apollon77 last edited by apollon77
                    Ok nicht englishc.
                    Nicht Dinge vermischen!!
                    Es gibt Objekte - das siehst Du im Admin. Und Objekte haben (vielleicht) einen Wert. Ein Wert kann da sein und einen value haben und der Wert kann auch NICHT da sein (weil nie gesetzt wurde, weil expired oder weil gelöscht.
                    Also: Jetzt wieder zwave2 Frage ... warum existiert der state nicht?
                    • Tomasz Nowak
                      @apollon77
                      That issue I've also reported here 🙂
                      https://github.com/AlCalzone/ioBroker.zwave2/issues/597
                      tnowak created this issue in AlCalzone/ioBroker.zwave2
                      closed Scene_Activation.sceneId null value seems to be crashing mqtt-client #597
                        @tomasz-nowak ;üsste man umformulieren!
                        Wie gesagt der crash ist ein Fehler in mqtt-client! Die Frage an zwave2 ist warum der state gelöscht wird
                          paul53 @Tomasz Nowak last edited by
                          @tomasz-nowak
                          If the state expires after a second, use a script:
                          on({id: 'zwave2.0.Node_014.Scene_Activation.sceneId'}, function(dp) {
                              setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', dp.state.val, true);
                              setTimeout(function() {
                                  setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', 0, true);
                              }, 1000);
                          Tomasz Nowak 1 Reply Last reply Reply Quote 1
                          • Tomasz Nowak
                            Tomasz Nowak @paul53 last edited by Tomasz Nowak
                            I've never used Javascript in ioBroker, but I have installed Javascript adapter now, created that channel and object under 0_userdata.0 and......
                            WOW, it works as it should !!!!!!!!!!!!
                            I get 26 and 24 values on 1- and 2-click and then the objects turns to 0. And it works with mqtt-client putting it to the broker just fine:
                            Thank you @paul53 for this quick solution! 🙌
                            I hope mqtt-client (and probably zwave2) adapters will be address with this issue in the future, but for now I may switch my lights again!
                            • AlCalzone
                              AlCalzone Developer @Tomasz Nowak last edited by
                              @tomasz-nowak sagte in How to replace null with 0 using alias-manager:
                              and probably zwave2
                              I can only repeat myself: This is not a problem in zwave2. It just uses the expire feature for states which mqtt-client doesn't handle correctly.
                              Tomasz Nowak paul53 2 Replies Last reply Reply Quote 1
                              • Tomasz Nowak
                                Tomasz Nowak @AlCalzone last edited by Tomasz Nowak
                                Yes, that's true.
                                And for the record, this issue (with Fibaro sceneId) is totally solved with two PR's to mqtt-client adapter proposed by @AlCalzone (#46 & #47) and merged by @apollon77
                                You guys are amazing!
                                  paul53 @AlCalzone last edited by
                                  @alcalzone sagte: It just uses the expire feature for states
                                  Wozu ist ein Datenpunkt ohne Zustand gut? Bringt es irgend einen Vorteil, state.expire zu nutzen?
                                  AlCalzone apollon77 2 Replies Last reply Reply Quote 0
                                  • AlCalzone
                                    AlCalzone Developer @paul53 last edited by
                                    @paul53 Im vorliegenden Fall handelt es sich um Events, die eigentlich nur exakt in dem Moment, in dem sie empfangen werden, eine Bedeutung haben (z.B. kurzer Knopfdruck). Damit man trotzdem sowohl darauf reagieren kann, als auch im Admin etwas sieht, habe ich mich entschieden, diese für jeweils 1 Sekunde im State zu speichern.
                                    Expire macht diese Funktion recht praktisch, weil sich ioBroker bzw. die Datenbank dann ums Timeout kümmert und man nicht selbst jeden State tracken muss.
                                    Das Zurücksetzen funktioniert so auch dann noch, wenn innerhalb der Sekunde der Adapter beendet wird.
                                      apollon77 @paul53 last edited by
                                      @paul53 Naja Formal ist es ein Unterschied (auf einer reinen Datenebene) ob ein State einen Wert hat - und ja formal ist auch "null" ein Wert der eine spezifische Bedeutung haben kann. Damit braucht es eine Abgrenzung zu "es ist kein Wert da" und das ist genau der Fall hier.
                                      Auch das zurücksetzen von Werten (einige Adapter machen bei "Button" States die an sich immer nur auf true getriggert werden extra timeouts damit der Button wieder auf false zurückgesetzt wird (weil User das gern in Visus so haben wollen ... no offense 😉 ) Wenn aber jetzt der Adapter beendet wird oder das Skript nicht mehr läuft bleibt das halt auf true stehen.
                                      Mit expires kann du den Wert automatisiert "clearen" weil das in der Verantwortung der Datenbank liegt (File-DB bzw Redis sorgt dafür)
                                      Mit expires kann man auch durchaus Überwachungen bauen. Zum Beispiel funktionieren die wie system.adapter.alive so, dass diese alle 15s neu gesetzt werden mit einem expire von 30s oder so. So lange also der prozess läuft expired das nie weil es immer neu gesetzt wird.
                                      Wenn jetzt der Adater komisch hängenbleibt, sodass er nicht crasht aber auch nicht regelmässig alive setzen kann wird der state expiren ... das registriert der Controller und reragiert durch kill des prozesses und neustart ...
                                      Also es gibt durchaus sinnvolle Anwendungsformen.
                                      Die die @AlCalzone beschrieben hat könnte man für alle buttons nutzen (wenn es mit alles visus und der User erwartung kompatibel wäre 😉 )
                                      2397
