    4. Zeigt her eure Views zum Thema Mähroboter
      Hausbaer @falke69 last edited by
      @falke69 Jetzt bin ich komplett verwirrt 😕
      Bei mir schaut das so aus:
      Fehlt da nicht was???
      falke69 1 Reply Last reply Reply Quote 0
      • falke69
        falke69 @Hausbaer last edited by
        @hausbaer
        Jep, da fehlt was😯
        <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defnoreturn" id=")n+90MIa%*IHTOS*H1l$" x="388" y="88">
         <mutation>
           <arg name="Wochentag" varid="-GZ`VPVXSd7mOwiMwbq~"></arg>
           <arg name="Rand_schneiden" varid="WfdS57MV4CPYTS?q1Y)p"></arg>
           <arg name="Startzeit" varid="v)?%%:Z.]}MSj9:/$:_0"></arg>
           <arg name="Arbeitsdauer" varid="iE}N;B.En^;I2K+gcO;K"></arg>
         </mutation>
         <field name="NAME">Zeiten_setzen</field>
         <statement name="STACK">
           <block type="comment" id="-qWDb~O#u;*8x;5}Of63">
             <field name="COMMENT">* Datenpunkte im Adapter</field>
               <block type="controls_if" id="z~!`S]fcgs`3Aj`{j[Yf">
                 <mutation elseif="6"></mutation>
                   <block type="logic_compare" id="d!1R:#2O37cNvXZcC%]Z">
                     <field name="OP">EQ</field>
                       <block type="variables_get" id="opBrCmY/#6Isb$;%*]$d">
                         <field name="VAR" id="-GZ`VPVXSd7mOwiMwbq~">Wochentag</field>
                       <block type="math_number" id="G.M]q,Gb-tTa-Adq#C/w">
                         <field name="NUM">1</field>
                   <block type="comment" id="^4D/h3OZFFO7iEJ]Gzla">
                     <field name="COMMENT">Montag / Monday</field>
                       <block type="comment" id="FBW@~Hj;+XK!:i/DnCjd">
                         <field name="COMMENT">Border cut</field>
                           <block type="control_ex" id="@{aT9Nbig`1-k@3mK8E3" inline="true">
                             <value name="OID">
                               <shadow xmlns="http://www.w3.org/1999/xhtml" type="field_oid" id="9l-z{fxzcc+na3T}L/,X">
                                 <field name="oid">Object ID</field>
                               <block type="text_join" id="DXz)q4#P:c,#qtq~4R4/">
                                 <value name="ADD0">
                                   <block type="text" id="^c7r;$TQW@SkOp*iY7A4">
                                     <field name="TEXT">worx.0.</field>
                                 <value name="ADD1">
                                   <block type="variables_get" id="4X`J82ar-+X@A0W_{2T*">
                                     <field name="VAR" id="[j%$BG?g#3[u9mJ~-tJL">Seriennummer_Worx</field>
                                 <value name="ADD2">
                                   <block type="text" id="AmtexuWxRg8Z]HBD=Mlt">
                                     <field name="TEXT">.calendar.monday.borderCut</field>
                               <shadow xmlns="http://www.w3.org/1999/xhtml" type="logic_boolean" id="8j7/%J(TBNpLlo~SC~Vj">
                               <block type="variables_get" id="+C9Exb/Vz*G*y8p*KdPm">
                                 <field name="VAR" id="WfdS57MV4CPYTS?q1Y)p">Rand_schneiden</field>
                             <value name="DELAY_MS">
                               <shadow type="math_number" id="{f[Z*u/iAlLKf(Eu`JOw">
                                 <field name="NUM">0</field>
                               <block type="timeouts_settimeout" id="m-#XKe;s2|C_W-nKIY(q">
                                 <field name="NAME">timeout_Montag</field>
                                 <field name="DELAY">3</field>
                                   <block type="comment" id="|qLFXgp!C7H|9Z`U:%VU">
                                     <field name="COMMENT">Start time</field>
                                       <block type="control_ex" id="?krlbBB?TI9L61FU5N8B" inline="true">
                                         <value name="OID">
                                           <block type="text_join" id="a5rq~B!b!wGf9$%fwc52">
                                             <value name="ADD0">
                                               <block type="text" id="A:1pJ:(CVB:Q5C-Y={[)">
                                             <value name="ADD1">
                                               <block type="variables_get" id="$*}d(p6sv}3oQamiXLzQ">
                                             <value name="ADD2">
                                               <block type="text" id="CSP(clrCE90O;%Wam7LC">
                                                 <field name="TEXT">.calendar.monday.startTime</field>
                                           <shadow xmlns="http://www.w3.org/1999/xhtml" type="logic_boolean" id="!BS0`PW(Ptj|?S|nMqPT">
                                           <block type="variables_get" id="-LzN;|a:}[e!5fO+i.eT">
                                             <field name="VAR" id="v)?%%:Z.]}MSj9:/$:_0">Startzeit</field>
                                           <shadow type="math_number" id="#-HS(Cld.FU3FOPVok3K">
                                           <block type="timeouts_settimeout" id="mduBfdwY?wfVROLkd7xu">
                                             <field name="NAME">timeout_Montag2</field>
                                               <block type="comment" id="/;Y}c:SHSO3o-r_3fM#`">
                                                 <field name="COMMENT">Work time</field>
                                                   <block type="control_ex" id="gu_2n}{mx;=M/R^MS5`U" inline="true">
                                                     <value name="OID">
                                                       <block type="text_join" id="Pt|v3,~HdEYs,q7?JpwU">
                                                         <value name="ADD0">
                                                           <block type="text" id=".3[hy{*]W#:Jpqk,4_b}">
                                                         <value name="ADD1">
                                                           <block type="variables_get" id="h~JTHFT`_RqWIGG9@NAn">
                                                         <value name="ADD2">
                                                           <block type="text" id="UP4DM+[2^Z_#)AvTl}*z">
                                                             <field name="TEXT">.calendar.monday.workTime</field>
                                                       <shadow xmlns="http://www.w3.org/1999/xhtml" type="logic_boolean" id="UH(l;OHq;durRkP)p!UZ">
                                                       <block type="variables_get" id=")cpF:+_o~}O^KcayUp%W">
                                                         <field name="VAR" id="iE}N;B.En^;I2K+gcO;K">Arbeitsdauer</field>
                                                       <shadow type="math_number" id="1!s#C[[f;k%Zvsi%k.G3">
                 <value name="IF1">
                   <block type="logic_compare" id="8R]33BXj*`v2O`ML|n1C">
                       <block type="variables_get" id="g#c-8qAvwZeX{btgu?as">
                       <block type="math_number" id=":Kff/@pD{~_0YZ?]C@W^">
                         <field name="NUM">2</field>
                 <statement name="DO1">
                   <block type="comment" id="e!vt_XiEU!hYzYUE2]M|">
                     <field name="COMMENT">Dienstag / Tuesday</field>
                       <block type="control_ex" id="%e@2G[w+zGhKKSwiH}G*" inline="true">
                         <value name="OID">
                           <block type="text_join" id="E0*PQoi(CwVkGf{/wV59">
                             <value name="ADD0">
                               <block type="text" id="M$F]9(X!DZxZwA*yrGsC">
                             <value name="ADD1">
                               <block type="variables_get" id="s3YUU3Q8R^;/=B5;S?OG">
                             <value name="ADD2">
                               <block type="text" id="{{nItBN~G|4@}7nXABnh">
                                 <field name="TEXT">.calendar.tuesday.borderCut</field>
                           <block type="variables_get" id="CKe#_[i1Ki@pg7HjvpKX">
                           <shadow type="math_number" id="VIt7J|UNJ*RL,MvSj{Am">
                           <block type="timeouts_settimeout" id="8x0b8r{L4sB.k~vJ65W[">
                             <field name="NAME">timeout_Dienstag</field>
                               <block type="control_ex" id="@)./Ma#c,o#dcaD!6!7{" inline="true">
                                 <value name="OID">
                                   <block type="text_join" id=")EY`AL[nZ:$S#Zkg6E6#">
                                     <value name="ADD0">
                                       <block type="text" id="Vn{ZT}vFi#)w9q_OrMjP">
                                     <value name="ADD1">
                                       <block type="variables_get" id="v-vP!$UC8H8hL*;LHF}(">
                                     <value name="ADD2">
                                       <block type="text" id="ux74m!GAK7YcnOV$:!Wp">
                                         <field name="TEXT">.calendar.tuesday.startTime</field>
                                   <block type="variables_get" id="Eq*!#%HdQluw87k!#|w!">
                                   <shadow type="math_number" id="Zu4I2,IFWkiQG5!%}X%m">
                                   <block type="timeouts_settimeout" id="v)/uQOfir](I-nM-W%sv">
                                     <field name="NAME">timeout_Dienstag2</field>
                                       <block type="control_ex" id="S=25p!pB,HV)U3HO-7:l" inline="true">
                                         <value name="OID">
                                           <block type="text_join" id="`_#2e{NkLq$NylN@PDwI">
                                             <value name="ADD0">
                                               <block type="text" id="5t:sJb*DkAB5ggZV66/X">
                                             <value name="ADD1">
                                               <block type="variables_get" id="9MX+n5^*|P%~=MwUTouA">
                                             <value name="ADD2">
                                               <block type="text" id="i${qSm@laNi(iU[kaUTZ">
                                                 <field name="TEXT">.calendar.tuesday.workTime</field>
                                           <block type="variables_get" id=")9Up)cH88eR4h2Ang#rM">
                                           <shadow type="math_number" id="sMbi`w0FI[X-?sG[Z]H2">
                 <value name="IF2">
                   <block type="logic_compare" id="Mr/9h2K*XT.e]NKJv(pm">
                       <block type="variables_get" id="gLw%+P1!p2N@4f/Gp5EN">
                       <block type="math_number" id="#9iPFaP}Ku?9^%D#?RCx">
                         <field name="NUM">3</field>
                 <statement name="DO2">
                   <block type="comment" id="JdA`OxOF,@D7-GV(1x(!">
                     <field name="COMMENT">Mittwoch / Wednesday</field>
                       <block type="control_ex" id="+JW=f,-M+vVq@(PpfURr" inline="true">
                         <value name="OID">
                           <block type="text_join" id="A}j5b{q:(K0!hta@o~2%">
                             <value name="ADD0">
                               <block type="text" id="1WJ1=S?Y_K7g#04;@B4K">
                             <value name="ADD1">
                               <block type="variables_get" id="d-;O/xL|cMHJZb=QNMW}">
                             <value name="ADD2">
                               <block type="text" id="yXHtPQ-5=6AmR:l9O;w@">
                                 <field name="TEXT">.calendar.wednesday.borderCut</field>
                           <block type="variables_get" id="O]Ior}G3s!vtfGTz/,53">
                           <shadow type="math_number" id="1nMbN/SJgTR_vAF/;s7;">
                           <block type="timeouts_settimeout" id="5QRwrP:]6nU?VXyS%lvr">
                             <field name="NAME">timeout_Mittwoch</field>
                               <block type="control_ex" id="*YB,Xo+SA9!1jIBXM)%x" inline="true">
                                 <value name="OID">
                                   <block type="text_join" id="9lO`fd-IKz:JE3k-fIX!">
                                     <value name="ADD0">
                                       <block type="text" id="mEl4E63I,Nq$OP[15MwS">
                                     <value name="ADD1">
                                       <block type="variables_get" id="EOFoRU%*=)7C-H*T9R1s">
                                     <value name="ADD2">
                                       <block type="text" id="EB?~QZ~/3f`unF*bA[,L">
                                         <field name="TEXT">.calendar.wednesday.startTime</field>
                                   <block type="variables_get" id=",}iHLDA(RYNNpD#DqcpK">
                                   <shadow type="math_number" id="9RGb`]xb`h~wGPR;6=]X">
                                   <block type="timeouts_settimeout" id="~^hY=!xG#4yv-3si^][_">
                                     <field name="NAME">timeout_Mittwoch2</field>
                                       <block type="control_ex" id="Ng2v5i_]sNAKee(OBzm:" inline="true">
                                         <value name="OID">
                                           <block type="text_join" id="Py]/QXW?D`LUS;D[,g1f">
                                             <value name="ADD0">
                                               <block type="text" id="GC0IZU%J|D#?j=|Gi(T_">
                                             <value name="ADD1">
                                               <block type="variables_get" id="M_tn2VkSTjFl:=rd48{w">
                                             <value name="ADD2">
                                               <block type="text" id="Sme8u)LVE{Y1k^QgrV26">
                                                 <field name="TEXT">.calendar.wednesday.workTime</field>
                                           <block type="variables_get" id="NX-sjxqjRb=(GuQgcS*#">
                                           <shadow type="math_number" id="^BvTr!!eNgbW].E.[,],">
                 <value name="IF3">
                   <block type="logic_compare" id="rW#:A@a3^GB*r7tKs@!s">
                       <block type="variables_get" id="fjF(j_~`8T?|bH)mB{]n">
                       <block type="math_number" id="X[9QE6p;4$T#`e6`%VMT">
                         <field name="NUM">4</field>
                 <statement name="DO3">
                   <block type="comment" id="t;u1P#./kW*#J96@JAJY">
                     <field name="COMMENT">Donnerstag / Thursday</field>
                       <block type="control_ex" id="7Omw}WJ6j?S_XCcaBYgR" inline="true">
                         <value name="OID">
                           <block type="text_join" id="y8e8}%SZaqr@i@-Voe,T">
                             <value name="ADD0">
                               <block type="text" id="m.H+Q-o@#CDmn93cWnk7">
                             <value name="ADD1">
                               <block type="variables_get" id="7m1q:xCHrWX;b)jq%UWV">
                             <value name="ADD2">
                               <block type="text" id="EL`)45d}[fT!%w-^c{G9">
                                 <field name="TEXT">.calendar.thursday.borderCut</field>
                           <block type="variables_get" id="7!HJj,QJbDuPV_j,jii~">
                           <shadow type="math_number" id="bF~+#5xqhd/^2K=em2b]">
                           <block type="timeouts_settimeout" id="NjvrIrYUMvG2):aT,`jR">
                             <field name="NAME">timeout_Donnerstag</field>
                               <block type="control_ex" id="5s;n:XDf3#,KJN7~tZEc" inline="true">
                                 <value name="OID">
                                   <block type="text_join" id="mMjmbEGO9q8*yVyGTE1^">
                                     <value name="ADD0">
                                       <block type="text" id="O5_NXWgZTy,~ZH{}S-o#">
                                     <value name="ADD1">
                                       <block type="variables_get" id="==T(c%N`h`_1#$0gq98)">
                                     <value name="ADD2">
                                       <block type="text" id=",M-G.m.vY|9m7b$#m9{Q">
                                         <field name="TEXT">.calendar.thursday.startTime</field>
                                   <block type="variables_get" id="k)i7`2y8tLn=QGFJ9hYH">
                                   <shadow type="math_number" id="*4%t%xD%o%i.3Ke~Hy%l">
                                   <block type="timeouts_settimeout" id="LS.#A/-.xJvQ5c)d){Xp">
                                     <field name="NAME">timeout_Donnerstag2</field>
                                       <block type="control_ex" id="Z:c):CHjUR/sC4);6SHO" inline="true">
                                         <value name="OID">
                                           <block type="text_join" id="/|OSn$rkCr@D{gRM_5a/">
                                             <value name="ADD0">
                                               <block type="text" id="j0!`I.{b+@ZPqusS$BKu">
                                             <value name="ADD1">
                                               <block type="variables_get" id=";H0f.aC~AGR@|I+dRqrt">
                                             <value name="ADD2">
                                               <block type="text" id="=^eWxVIw*kp0R1b_lyGU">
                                                 <field name="TEXT">.calendar.thursday.workTime</field>
                                           <block type="variables_get" id="B0|YFm}7w*JdCE2%Q)s:">
                                           <shadow type="math_number" id="c-DX1tyx%ZMZBZ8yC5)K">
                 <value name="IF4">
                   <block type="logic_compare" id="fw.|^(:1eQBrw@k9hxhF">
                       <block type="variables_get" id="3p,}=8Tiyf!|p*.H}.Ol">
                       <block type="math_number" id="E6[=/rt!w~{do9*v!Eo1">
                         <field name="NUM">5</field>
                 <statement name="DO4">
                   <block type="comment" id="yLm?)qI=0ZSc+d:1z~IX">
                     <field name="COMMENT">Freitag / Friday</field>
                       <block type="control_ex" id="ZOYA7y)E~:(2hRn~DYgV" inline="true">
                         <value name="OID">
                           <block type="text_join" id="`zN=K;dDS2EK[IR8i:7.">
                             <value name="ADD0">
                               <block type="text" id="3EJu:4[8!8k7uP!QX8?i">
                             <value name="ADD1">
                               <block type="variables_get" id="nR8SMqcqw~B?a-#GqFVm">
                             <value name="ADD2">
                               <block type="text" id="%50Z_Jd3z[3.?s/_-JW{">
                                 <field name="TEXT">.calendar.friday.borderCut</field>
                           <block type="variables_get" id="Y);c#!vg]h^:x_h[Bcbz">
                           <shadow type="math_number" id="?nV*Zx_8z;FwvPCm{[/O">
                           <block type="timeouts_settimeout" id="n@gIRxNI]lf$mf:$:+~H">
                             <field name="NAME">timeout_Freitag</field>
                               <block type="control_ex" id="`F`Q{|dq_m9fh0;~$^V_" inline="true">
                                 <value name="OID">
                                   <block type="text_join" id="$O5Lni$lO-$`fpfpha-2">
                                     <value name="ADD0">
                                       <block type="text" id="}5;ETd^8p*_dWq^26Eck">
                                     <value name="ADD1">
                                       <block type="variables_get" id="j6K{)=iUkWZHtzgeK7_|">
                                     <value name="ADD2">
                                       <block type="text" id="ezcBR3UK9mOajcIXvhvc">
                                         <field name="TEXT">.calendar.friday.startTime</field>
                                   <block type="variables_get" id="`.kZ63%O|HW*Blk.XNQ6">
                                   <shadow type="math_number" id="%d;lE4,jgqv7Cj8BKW:{">
                                   <block type="timeouts_settimeout" id="G#C-TICjbP2G#d,VX9E#">
                                     <field name="NAME">timeout_Freitag2</field>
                                       <block type="control_ex" id="B}Q^R7}wG2,J:W(?{sAe" inline="true">
                                         <value name="OID">
                                           <block type="text_join" id="a4t#4pQIGf?SUGT.2dJ~">
                                             <value name="ADD0">
                                               <block type="text" id="^C~7NHZ_+;9*3aZl]Jo0">
                                             <value name="ADD1">
                                               <block type="variables_get" id="~hn]yIP3O_mW@cj@C5~I">
                                             <value name="ADD2">
                                               <block type="text" id="oF6*9@aEn^+L*0_D:,2j">
                                                 <field name="TEXT">.calendar.friday.workTime</field>
                                           <block type="variables_get" id="+RaVRCb5n#K/D|#J$//J">
                                           <shadow type="math_number" id="ok3wT~D*gPt1C^:2t!`Z">
                 <value name="IF5">
                   <block type="logic_compare" id="{e~X=CAxxEsk;A#1Vh%J">
                       <block type="variables_get" id="(@)xX)e*F+cD;Zekds7U">
                       <block type="math_number" id="/V@r3_~!VhojP~|jZO1@">
                         <field name="NUM">6</field>
                 <statement name="DO5">
                   <block type="comment" id="Rw?CLZzvU6BEb4dGh%0Z">
                     <field name="COMMENT">Samstag / Saturday</field>
                       <block type="control_ex" id="$ZxMfMveIL9q}?_Oy^7B" inline="true">
                         <value name="OID">
                           <block type="text_join" id="Lb/CT!zETaR5gLKqS/Jz">
                             <value name="ADD0">
                               <block type="text" id="G./}Azp^6B1Kd!#80s)M">
                             <value name="ADD1">
                               <block type="variables_get" id="^{13F;7fkA6Mu-.i18O~">
                             <value name="ADD2">
                               <block type="text" id="hz7+c}.;7Z@m.h#qD*E!">
                                 <field name="TEXT">.calendar.saturday.borderCut</field>
                           <block type="variables_get" id="4=-/`WMyen$`AJ0)9YdB">
                           <shadow type="math_number" id="p24)W{!~?IP0ydF{|n+R">
                           <block type="timeouts_settimeout" id="aI%L__wEDxKx[Gs(I.|m">
                             <field name="NAME">timeout_Samstag</field>
                               <block type="control_ex" id="V`vL;-!#wc[SyugACUO[" inline="true">
                                 <value name="OID">
                                   <block type="text_join" id="t+(*]]v9B/XG/#_~u(K5">
                                     <value name="ADD0">
                                       <block type="text" id="=ok%F4sSs}wXSf[7HR2a">
                                     <value name="ADD1">
                                       <block type="variables_get" id="?}tbblxL*Eb.d3ns?khQ">
                                     <value name="ADD2">
                                       <block type="text" id="oBf2RM;$_d(6OJ@4o_{!">
                                         <field name="TEXT">.calendar.saturday.startTime</field>
                                   <block type="variables_get" id="JH[xWn_g:qR-U[wtzGoM">
                                   <shadow type="math_number" id="Sf`(c}_+|%.,r-U|@Hf.">
                                   <block type="timeouts_settimeout" id="@9WHu!q$V]^H9`QT@;Y!">
                                     <field name="NAME">timeout_Samstag2</field>
                                       <block type="control_ex" id="{]X3o:pK8q*N/z8P-s%8" inline="true">
                                         <value name="OID">
                                           <block type="text_join" id="Oy{a5$jv2NN!ccUg@D+7">
                                             <value name="ADD0">
                                               <block type="text" id="{WOuw?/3m8o^$%|~~Wl~">
                                             <value name="ADD1">
                                               <block type="variables_get" id="(Il)u;i2Y=Ge?1ifOpon">
                                             <value name="ADD2">
                                               <block type="text" id="aAU1yhN?c%APjOsNhwQ%">
                                                 <field name="TEXT">.calendar.saturday.workTime</field>
                                           <block type="variables_get" id="p!G3;d%ZyJ/VPh}jmab8">
                                           <shadow type="math_number" id="pUWi@vLQ690[s6ugmoss">
                 <value name="IF6">
                   <block type="logic_compare" id="dM4M7vjBluVvy{VBc1_c">
                       <block type="variables_get" id="x])!=}P|M.o5,J)AiQIa">
                       <block type="math_number" id="{9LzlmAN7r.sixxJBT3o">
                         <field name="NUM">7</field>
                 <statement name="DO6">
                   <block type="comment" id="fdjY8Gr!bnzdtf5SLx~q">
                     <field name="COMMENT">Sonntag / Sunday</field>
                       <block type="control_ex" id="f?3XeT;*qZCs;csI*Ai+" inline="true">
                         <value name="OID">
                           <block type="text_join" id="GSO#H#@~[nA$Ay0jF~#5">
                             <value name="ADD0">
                               <block type="text" id="lu;qoH#:I:v2xRoket9w">
                             <value name="ADD1">
                               <block type="variables_get" id="5|F;D31PGo../HkPQbbO">
                             <value name="ADD2">
                               <block type="text" id="M~9A^I`,u?DS3]Ws.sV,">
                                 <field name="TEXT">.calendar.sunday.borderCut</field>
                           <block type="variables_get" id="c.DF0hE=W.i?;[{1Yq+`">
                           <shadow type="math_number" id="_VjA+z4@leT32G%2-yr(">
                           <block type="timeouts_settimeout" id=".OxwR!@bX3t%=t([(,K=">
                             <field name="NAME">timeout_Sonntag</field>
                               <block type="control_ex" id="1/Ma~+4MAmXu}cWUcssw" inline="true">
                                 <value name="OID">
                                   <block type="text_join" id="eB/w]nhzagt0u7X2QVk(">
                                     <value name="ADD0">
                                       <block type="text" id="lEMGPvZ{v.6~T`*EXI6W">
                                     <value name="ADD1">
                                       <block type="variables_get" id="Bl?6ydn})7Uw1{u,P+%a">
                                     <value name="ADD2">
                                       <block type="text" id="l+.L*?RP7T$d!CdkC^AV">
                                         <field name="TEXT">.calendar.sunday.startTime</field>
                                   <block type="variables_get" id="!epf7iN6D@ELa:#8^tPE">
                                   <shadow type="math_number" id="6QHRv9MAYZp`3enZ=ORZ">
                                   <block type="timeouts_settimeout" id="sf=YWH8{lr=MgAJ+Cg5B">
                                     <field name="NAME">timeout_Sonntag2</field>
                                       <block type="control_ex" id=";*RMnOk~.kkI?TKk:MJ^" inline="true">
                                         <value name="OID">
                                           <block type="text_join" id="hWRBo,1R;5*VwvJsK}4o">
                                             <value name="ADD0">
                                               <block type="text" id="}C}PN;zgp!{D:7Bpp2^k">
                                             <value name="ADD1">
                                               <block type="variables_get" id="W+?Uj#;y*zGJoSga-JFE">
                                             <value name="ADD2">
                                               <block type="text" id="2|uOg-)2lz$wzi$|;BdU">
                                                 <field name="TEXT">.calendar.sunday.workTime</field>
                                           <block type="variables_get" id="wk$cGNV32skEvN3e@28j">
                                           <shadow type="math_number" id="St@iKPWlHt?[m:[qZ7,o">
          @falke69
          Ahh, jetzt wird das auch klarer, da fehlt, warum auch immer, noch mehr.
          • falke69
            falke69 @Hausbaer last edited by falke69
            @hausbaer
            wo ist denn das alles hin?😰
            hier findest Du den Rest
              Ich hab mal in ein separates Script das original reingeladen - gleicher Fehler.
              Ich bin grad auf meiner Arbeitsumgebund. ich probiers mal in der Produktivumgebung auf meinem Raspi.
              • falke69
                @hausbaer
                hast Du dort Telegram installiert?
                  Ach du Sch....
                  Das ist mir gar nicht aufgefallen. Der Fehler hat den Rest auch gestoppt. Mit Telegram siehts da schon besser aus.
                  Ich zieh meine Sachen nach, probier nochmal und meld mich wieder.
                    Semmy @Hausbaer last edited by
                    Hallo
                    Ich bin auch gerade dabei, die zweite Startzeit zu integrieren. Sie wird auch gesetzt, wird dann aber direkt wieder auf 00:00 gesetzt. In Telegram bekomme ich die Meldung: Startzeit wurde nicht gesetzt.
                    Irgendwo steckt noch ein Fehler, weiß nur nicht, wo?
                    Viele Grüße
                    Semmy
                    • falke69
                      falke69 @Semmy last edited by
                      @semmy
                      ich sitze aktuell vor dem Problem, dass die Zeiten im Worx-Adapter in der zweiten Zeit kurz erscheinen und danach wieder gelöscht werden.
                      Ich habe alles Blockly Bausteine durchforstet, aber aktuell keine Idee, woran es liegen könnte.
                      Horst-29.04.zip
                      hsteinme H 2 Replies Last reply Reply Quote 0
                      • hsteinme
                        hsteinme @falke69 last edited by
                        @falke69 sagte in Zeigt her eure Views zum Thema Mähroboter:
                        Welche Adapter-Version setzt Du ein?
                          @semmy
                          Horst-29.04.zip
                          Guten Morgen,
                          dann bist du ja schon weiter wie ich.
                          Die Javascript-DP werden richtig befüllt. Ich hab nur noch nicht so ganz gecheckt, wie "Zeiten setzen" (also eigentlich die Übertragung an den worx-Adapter) angesprochen wird. Bei mir werden die Zeiten noch gar nicht übertragen. Leider 😖
                          • falke69
                            falke69 @hsteinme last edited by
                            @hsteinme
                            die 1.3.0
                            hsteinme 1 Reply Last reply Reply Quote 0
                            • falke69
                              @hausbaer
                              wenn ich den Datenpunkt (bei mir) 0_userdata.0.Rasenmaeher.01_Montag_Kantenschnitt
                              steuere, wird über den Block "Datensetzung 3min vor Startzeit" die jeweilige Variable in den Block "Zeiten_setzen" gesteuert und in den Worx Adapter übertragen.
                              Ich musste an verschiedenen Stellen in den gesamten Blockly für die zweite vorgesehene Zeit noch etwas ändern. Leider bin ich nicht so bewandert in diesen Dingen und versuche mehr oder weniger ans Ziel zu kommen.
                                @falke69 Ahh, wieder was gelernt.
                                Das heißt: Die über die VIS eingestellten Zeiten / Rasenkantenschnitte etc. werden erst drei Minuten vor Beginn übertragen.
                                Dann kanns quasi noch nicht funktioniert haben bei mir. Mal schaun, was er heute um neun macht.
                                • falke69
                                  @hausbaer
                                  so sieht es aus. Die Einträge für die zweite Zeit, werden bei mir auch in den Worx Adapter im Kalender in die zweite Zeit eingetragen. Die Einträge verschwinden aber nach ca. 3 Sekunden.
                                  Den Fehler habe ich aber noch nicht gefunden.
                                  Jetzt habe ich das ganze mal 1 zu 1 auf ein anderes System kopiert und siehe da es geht.
                                  Zumindest dachte ich das. Auf dem System hatte ich den Worx Adapter noch nicht gestartet.
                                  Sobald ich den Adapter starte, funktioniert es nicht mehr. 😞
                                  Somit würde ich fast behaupten wollen, dass das Script in seinen Grundzügen funktioniert.
                                  • falke69
                                    falke69 @falke69 last edited by
                                    @hausbaer
                                    Ich habe jetzt für die zweite Zeit mal den Kalendereintrag für den ersten Termin im Worx Adapter genommen. Jetzt bleibt auch die Zeit erhalten.
                                    Warum der Eintrag für die zweite Zeit im Adapter jedes mal gelöscht wird, ist mir schleierhaft.
                                      Der Adapter wurde um kurz vor neun nicht befüllt.
                                      Hier mal mein Script.
                                      Helmut_Script.zip
                                      Vielleicht kann sich das ja mal jemand anschauen
                                      falke69 S 2 Replies Last reply Reply Quote 0
                                      • falke69
                                        @hausbaer
                                        wie gesagt, ich bin auch nicht der Experte und versuche mich irgendwie zu behelfen und logische Zusammenhänge zu erkennen.
                                        Ich konnte aber bei Dir nicht die "Variable" Rand_schneiden nicht finden.
                                        diese sollten ja hier:
                                        wieder bei Dir auftauchen.
                                          @hausbaer sagte in Zeigt her eure Views zum Thema Mähroboter:
                                          Helmut_Script.zip
                                          Hallo
                                          Ich habe das Script mal übernommen, es werden keine Daten in die zweite Zeit geschrieben, in die erste schon. Bin am Verzweifeln.
                                          Viele Grüße
                                          Semmy
                                          • falke69
                                            falke69 @Semmy last edited by falke69
                                            @semmy
                                            hier werden jetzt die Daten für die zweite Zeit in den Adapter geschrieben und bleiben ca. 7 Minutenbis kurz nach dem Start auch drin. Werden jedoch kurz nach der Starzeit wieder gelöscht. Aber er fährt er nicht los.
                                            Keine Ahnung warum. 😞
                                            Horst_30.05.2021.zip
                                            M S 2 Replies Last reply Reply Quote -1
                                            vis
                                            70
                                            780
                                            190024
