    4. Test Adapter fb-checkpresence v1.1.x
    • afuerhoff
      afuerhoff Developer @sigi234 last edited by
      @sigi234 sagte in Test Adapter fb-checkpresence v1.1.x:
      Nein:
      Scheinen noch neue States dabei zu sein. Ich schaue noch mal.
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @afuerhoff last edited by
        @sigi234
        Neues Update. Bitte nochmal prüfen.
        • Wal
          Wal Developer @afuerhoff last edited by Wal
          @afuerhoff ,
          bei mir sieht es gut aus.
          edit: Ebend kam eine Warnung rein
          State value to set for "fb-checkpresence.0.familyMembers.Handy-Nathalie.comming" has wrong type "object" but has to be "string"
          edit:
          State value to set for "fb-checkpresence.0.familyMembers.Handy-Nathalie.going" has wrong type "object" but has to be "string"
          • afuerhoff
            afuerhoff Developer @Wal last edited by
            @wal sagte in Test Adapter fb-checkpresence v1.1.x:
            Hallo, ich habe ein Update eingespielt. Bitte testen.
            MichMein 1 Reply Last reply Reply Quote 1
            • MichMein
              MichMein @afuerhoff last edited by
              @afuerhoff
              Hi, ich bekomme bei Installation über die Katze folgende Fehlermeldungen.
              $ iobroker url fb-checkpresence --host ioBroker
              install fb-checkpresence
              NPM version: 6.14.12
              npm install fb-checkpresence --loglevel error --prefix "/opt/iobroker" (System call)
              npm ERR! code E404
              npm ERR! 404 Not Found - GET https://registry.npmjs.org/fb-checkpresence - Not foundnpm ERR! 404 npm ERR! 404 'fb-checkpresence@latest' is not in the npm registry.npm ERR! 404 You should bug the author to publish it (or use the name yourself!)npm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
              npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-05-01T12_57_11_533Z-debug.log
              upload [7] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
              upload [6] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/style.css style.css text/css
              upload [5] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
              upload [4] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
              upload [3] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/fb-checkpresence.png fb-checkpresence.png image/png
              upload [2] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/dateformat.png dateformat.png image/png
              upload [1] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/admin.d.ts admin.d.ts video/mp2t
              upload [0] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/access_settings_network.png access_settings_network.png image/png
              Process exited with code 0
              • afuerhoff
                afuerhoff Developer @MichMein last edited by
                @michmein
                Bitte über Beliebig mit dieser Url https://github.com/afuerhoff/ioBroker.fb-checkpresence installieren? Der andere Weg scheint buggy zu sein.
                  sigi234 Forum Testing Most Active @afuerhoff last edited by
                  @afuerhoff
                  Bekomme diesen Fehler:
                  $ ./iobroker url "https://github.com/afuerhoff/ioBroker.fb-checkpresence"
                  install afuerhoff/ioBroker.fb-checkpresence#0f8fe35b35c05f8bcaa94a300f4ab546c8febcfb
                  npm install afuerhoff/ioBroker.fb-checkpresence#0f8fe35b35c05f8bcaa94a300f4ab546c8febcfb --loglevel error (System call)
                  npm ERR! code EBUSY
                  npm ERR! syscall rmdir
                  npm ERR! path C:\Program Files\iobroker\Home\node_modules\iobroker.fb-checkpresence
                  npm ERR! errno -4082
                  npm ERR! EBUSY: resource busy or locked, rmdir 'C:\Program Files\iobroker\Home\node_modules\iobroker.fb-checkpresence'
                  npm ERR!     C:\Program Files\iobroker\Home\env\npm-cache\_logs\2021-05-01T14_56_40_726Z-debug.log
                  ERROR: host.Medion(Home) Cannot install afuerhoff/ioBroker.fb-checkpresence#0f8fe35b35c05f8bcaa94a300f4ab546c8febcfb: 4294963214
                  ERROR: process exited with code 25
                  • afuerhoff
                    afuerhoff Developer @sigi234 last edited by afuerhoff
                    @afuerhoff
                    npm ERR! code EBUSY
                    Hast du über GITHUB installiert oder Beliebig?
                    Ich hab schon einen Issue unter Admin 5 gemacht.
                      sigi234 Forum Testing Most Active @afuerhoff last edited by sigi234
                      @afuerhoff
                      Beliebig
                      Unter Admin 4.2.1 funktionierte es einwandfrei via eigene Url !
                      • afuerhoff
                        @sigi234
                        Also ein Admin 5 Fehler. Issue hatte ich schon erstellt
                          @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                          @sigi234
                          Jupp, meiner Meinung nach schon. Ist nicht nur bei deinem Adapter so. (Code 25) Einige gehen andere wieder nicht.
                          • afuerhoff
                            afuerhoff Developer last edited by
                            Ich hab gerade noch ein Update eingespielt. Beim ersten Adapterstart gab es noch Probleme beim Anlegen der Objekte. Fällt aber nur auf, wenn sie noch nicht existieren.
                              fritz0815 last edited by
                              ich benutze die Myfritz!App und habe damit VPN aktiviert. Das hat zur Auswirkung, dass auf der Fritzbox neue VPN Verbindungen und auch dedizierte Hosts erstellt werden. Dummerweise werden dafür Namen mit Sonderzeichen verwendet und leider kann man diese Hosts und auch nicht verändern. Nun gibt der Adapter periodisch die Meldung
                              2021-05-04 15:39:53.015 - debug: fb-checkpresence.0 (30680) loop family ends after 2,503761741 s
                              2021-05-04 15:39:55.494 - debug: fb-checkpresence.0 (30680) loop main ends after 0,476834836 s
                              2021-05-04 15:39:57.734 - info: fb-checkpresence.0 (30680) hostname: MyFRITZ!App-(Samsung-SM-G973F) false
                              2021-05-04 15:39:57.736 - info: fb-checkpresence.0 (30680) hostname: MyFRITZ!App-(Samsung-SM-T530) false
                              2021-05-04 15:39:57.763 - info: fb-checkpresence.0 (30680) hostname: MyFRITZ!App-2-(Samsung-SM-T530) false
                              2021-05-04 15:39:57.765 - debug: fb-checkpresence.0 (30680) getDeviceInfo activeCnt: 35
                              aus. Diese Hosts tauchen auch unter Family auf, jedoch bringt selektieren/deselektiere/löschen keine Änderung. Kann man an der Log Ausgabe etwas ändern, außer die Log-Stufe auf WARN stellen?
                              Viele Grüße
                              Markus
                              afuerhoff 2 Replies Last reply Reply Quote 0
                              • afuerhoff
                                afuerhoff Developer @fritz0815 last edited by afuerhoff
                                @fritz0815
                                Die Logstufe steht ja auf debug. Bitte auf Info stellen. Oder auch warn oder error.
                                Die Info Ausgabe kommt noch raus.
                                Die Sonderzeichen werden alle ersetzt.
                                • afuerhoff
                                  @fritz0815
                                  Hattest Du das neueste Update von Github geladen? Ich hatte gerade nachgesehen und die Info Meldung sollte eigentlich schon deaktiviert sein. Bitte einmal von Github aktualisieren.
                                    fritz0815 @afuerhoff last edited by
                                    @afuerhoff Danke - mit "test version: 1.1.3_g" ist die Meldung weg.
                                    • afuerhoff
                                      ich habe seit gestern die Version 1.1.4 ins latest hochgeladen. Es gab aber keine Änderungen mehr zur 1.1.3.
                                      ? 1 Reply Last reply Reply Quote 1
                                        A Former User @afuerhoff last edited by
                                        @afuerhoff Hi, ich habe sie seit gestern Abend laufen, keine Probleme.
                                        Leider wurde sie mir nicht als Update angezeigt, vielleicht war ich zu schnell..
                                        • afuerhoff
                                          afuerhoff Developer @Guest last edited by
                                          @ilovegym
                                          Hattest du vorher schon aus Github geladen?
                                            @afuerhoff Nur, wenn du schreibst, dass du n Update hochgeladen hast...
                                            Stephan Schleich 1 Reply Last reply Reply Quote 0
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            257942
