    4. Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol
      Rookie50 @liv-in-sky last edited by
      @liv-in-sky hier das Blockly:
        <variables>
          <variable id="V!?b;m:_l0eU[qp:2SFO">result</variable>
        </variables>
        <block type="text_join" id="4(WJ8JQ5i=h371i{O,Gx" disabled="true" x="1263" y="-3137">
          <mutation items="5"></mutation>
          <value name="ADD0">
            <block type="text" id="8%K;p%N|6+p7q3AUWIx}">
              <field name="TEXT">http://</field>
          <value name="ADD1">
            <block type="get_value" id="NQJLL*}lv=eg,Y|jp6It">
              <field name="OID">0_userdata.0.Rookie.dieIP</field>
          <value name="ADD2">
            <block type="text" id="*K6dCQuo,^7.bb#wcY/V">
              <field name="TEXT">:11000/Folders?&amp;service=LocalMusic</field>
          <value name="ADD3">
            <block type="text" id="Ws(9{4OpO]NL2S0lx[Ja">
              <field name="TEXT">&amp;path=</field>
          <value name="ADD4">
            <block type="get_value" id="}3$_/Oiqr~$+E?UcbD!G">
              <field name="OID">0_userdata.0.Rookie.braucheNeueDatenNeu</field>
        <block type="comment" id="v0M32(PRj34s1Di,:=gY" x="-63" y="-3063">
          <field name="COMMENT">holt start daten - root ordner</field>
            <block type="schedule" id="t:}s~p^B_9Who+:7wtq~">
              <field name="SCHEDULE">*/30 * * * *</field>
                <block type="request" id="I6rYHt4A!iG?_jn{8XgO">
                  <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                  <field name="WITH_STATEMENT">TRUE</field>
                  <field name="LOG">debug</field>
                  <value name="URL">
                    <shadow type="text" id="{j7;c#y:g^xO}}Aj~/c]">
                      <field name="TEXT">http://192.168.101.107:11000/Folders?&amp;service=LocalMusic&amp;path=%2F%2F192.168.101.20%2Fmusic%2FBest%20of</field>
                    <block type="text_join" id="ZF$TN+yFuwmjO3G2]C3S">
                      <value name="ADD0">
                        <block type="text" id="Q4sSPYrC|(Iq}Od,2+sy">
                      <value name="ADD1">
                        <block type="get_value" id="}=@5A?KbJp+oeczBbn8j">
                      <value name="ADD2">
                        <block type="text" id="JMY{LdKQw,LYR!G`{8)O">
                    <block type="debug" id="WV$pQ0~9+,%o*^4x-FZs">
                      <value name="TEXT">
                        <shadow type="text">
                        <block type="variables_get" id="2x%*T/Rg?1#Pg,~3zNFn">
                          <field name="VAR" id="V!?b;m:_l0eU[qp:2SFO">result</field>
                        <block type="update" id="Mk1.W[|]*#%L^q-E=~y*">
                          <field name="OID">0_userdata.0.Rookie.startXML</field>
                            <block type="variables_get" id="ax.+|:3mB$=C,$r-smVb">
                <block type="request" id=")FaT:*h|xNP=q3@TmeAW">
                  <value name="URL">
                    <block type="text_join" id="`$qKv{o!)^nZ}Op+E;pd">
                      <value name="ADD0">
                        <block type="text" id="5,xtrHj#,dU=06WjB1-I">
                      <value name="ADD1">
                        <block type="get_value" id="t,WdT/?XM=MbUh@8B|`X">
                      <value name="ADD2">
                        <block type="text" id="y:[S^_f1ust[{?]M{2)m">
                    <block type="debug" id="y^k~DIV`iU`.#+QDRble">
                      <value name="TEXT">
                        <block type="variables_get" id="J$aetB4Wy1dZi$7=(m,j">
                        <block type="update" id="M}ufB2T]3GhRm.0n.wCK">
                            <block type="variables_get" id="^Rh#h4z|_xaS%:jjW7;{">
        <block type="comment" id="uwKrN/G!j[ud[u@1QR()" x="637" y="-3013">
          <field name="COMMENT">holt Daten</field>
            <block type="on_ext" id="N0#32_-c70.%tK[:LtJ%">
              <value name="OID0">
                <shadow type="field_oid" id="G#-!zS8!EsQlucJw^9md">
                  <field name="oid">0_userdata.0.Rookie.braucheNeueDatenNeu</field>
                <block type="debug" id="MgSAh8UGx{N=1mV[57:Z">
                  <value name="TEXT">
                    <shadow type="text" id="N@^8_se}L8h$pPuiF%ec">
                    <block type="text_join" id="bvItJ0`oBtd$WYv1POUJ">
                      <value name="ADD0">
                        <block type="text" id="0J-9IJ^j@qC2Faj`~k+R">
                      <value name="ADD1">
                        <block type="get_value" id="4@TIc0,d3M-oOY3B-33)">
                      <value name="ADD2">
                        <block type="text" id="kP?r1Z%PqX11,1ykbm7M">
                      <value name="ADD3">
                        <block type="text" id="Zb2HLfnz;QZ/+l2K,6=c">
                      <value name="ADD4">
                        <block type="get_value" id="aLdz2c4i#X`TFqLwymF4">
                    <block type="control" id="*Gf3Lq,S4]YjTU:PxU/9">
                      <field name="OID">0_userdata.0.Rookie.LOG.URL</field>
                        <block type="text_join" id="94xkBN)Mj32X;Rk.T5no">
                          <value name="ADD0">
                            <block type="text" id="xV[LVgV)_pvjD3@#8ltj">
                          <value name="ADD1">
                            <block type="get_value" id="R5qUlXB5Nt6Z+EN)Z6,m">
                          <value name="ADD2">
                            <block type="text" id="c1Oy`ur2xW{C]RgQ|JRm">
                          <value name="ADD3">
                            <block type="text" id="fk5{t|T|F..)]DH+DgGU">
                          <value name="ADD4">
                            <block type="get_value" id=".^}eU!l?yKkJmiKCF@RU">
                        <block type="request" id="8xkanaj=7q/R@]pZxS;3">
                          <field name="LOG">log</field>
                          <value name="URL">
                            <shadow type="text" id="vhX,`pssA5?!=7xz517O">
                            <block type="text_join" id="};@G%YX9~`ODL8{JUo:e">
                              <value name="ADD0">
                                <block type="text" id="i.8r7X@t8=@AwI*J||s6">
                              <value name="ADD1">
                                <block type="get_value" id="T)N-4aiOkb-S7LxDP(2=">
                              <value name="ADD2">
                                <block type="text" id="b|8{4d9.,`XLJ)XF;vKr">
                              <value name="ADD3">
                                <block type="text" id="vN=,qONjV]{?N:b2btaY">
                              <value name="ADD4">
                                <block type="get_value" id="[5c*W8en`EAjgmf]_J{O">
                            <block type="debug" id="88@B_=#eYb^`|[0q`J@6" disabled="true">
                              <value name="TEXT">
                                <shadow type="text" id="itD-2J12O=Mu1Z@WmnF?">
                                <block type="variables_get" id="tbs,D1!8.05BBk=G-!Z6">
                                <block type="control" id="1%u4czlp)1vbbyd%za(z">
                                  <field name="OID">0_userdata.0.Rookie.bekommeXML</field>
                                    <block type="variables_get" id="IVHki$jCs)Yqb:]Fd|]H">
        <block type="comment" id="zH38gdL8~[siVvu8CO[n" x="88" y="-1438">
          <field name="COMMENT">sendet mp3 play</field>
            <block type="on_ext" id="ThVmDpi$2B{5u:B(:Q(T">
              <value name="OID0">
                <shadow type="field_oid" id="Wyp5f+DI{wEAGEIM}B$Y">
                  <field name="oid">0_userdata.0.Rookie.STEUERUNG.PLAYmp3</field>
                <block type="debug" id="%!0^GACFy!r{ilCK4Y6;">
                  <value name="TEXT">
                    <block type="text_join" id="V2$00f#[L]Brjv0o2+lw">
                      <mutation items="6"></mutation>
                      <value name="ADD0">
                        <block type="text" id="T_r5cwr!P[e#HL5P[4t}">
                      <value name="ADD1">
                        <block type="get_value" id="Z/+5Inhc]oPYh40]5UpG">
                      <value name="ADD2">
                        <block type="text" id="vaCac{Fs90Y$_:GN@1YN">
                          <field name="TEXT">:11000/Add?service=LocalMusic</field>
                      <value name="ADD3">
                        <block type="text" id="[}Q++:vHUVV{9;n^jQyL">
                          <field name="TEXT">&amp;playnow=1&amp;where=next</field>
                      <value name="ADD4">
                        <block type="text" id="6)_SN(z~:`f5kV2MTu*_">
                          <field name="TEXT">&amp;file=</field>
                      <value name="ADD5">
                        <block type="get_value" id="!tNn7~e}_d;=N7{Kljjb">
                          <field name="OID">0_userdata.0.Rookie.STEUERUNG.PLAYmp3</field>
                    <block type="control" id="g89wiwrIwl]{*VOE2~yf">
                        <block type="text_join" id=":Gn0ItSvwo2eV]j!O(b7">
                          <value name="ADD0">
                            <block type="text" id="[ad)NVw[SYCsPBmAlq#c">
                          <value name="ADD1">
                            <block type="get_value" id="x8lLQ1q997Yk/wWj{BJK">
                          <value name="ADD2">
                            <block type="text" id=")@he!vfKv%ACb;s5E/lZ">
                              <field name="TEXT">:11000/Add?&amp;service=LocalMusic</field>
                          <value name="ADD3">
                            <block type="text" id="tw~ilay$Ux{_@c^_fjly">
                              <field name="TEXT">&amp;playnow=-1</field>
                          <value name="ADD4">
                            <block type="text" id="h02Vn$[i%U$9~dt+NSL;">
                          <value name="ADD5">
                            <block type="get_value" id="^s$T5CBxuqnT8]3h:}6x">
                        <block type="request" id="HmA5|uKGJbOnCp/w7p%5" disabled="true">
                          <value name="URL">
                            <block type="text_join" id="P4]g7Ii9jy)E-HOIPUp{">
                              <value name="ADD0">
                                <block type="text" id="R{3Df_5n53l[.B#ThOBh">
                              <value name="ADD1">
                                <block type="get_value" id="v7Se%3Hk7.A|MO,0GX47">
                              <value name="ADD2">
                                <block type="text" id="?-4{g!+U9h|Tn$VYENz8">
                              <value name="ADD3">
                                <block type="text" id="fve1Y,Ezl.|F]$#J:M!d">
                              <value name="ADD4">
                                <block type="get_value" id="A7+Y;K`0HU4Y2lz#Fos|">
                            <block type="debug" id="S9LK@;M(^q2io/#j=Xmf" disabled="true">
                              <value name="TEXT">
                                <block type="variables_get" id="|D-qgb:I.vH-baOSaBa:">
                                <block type="update" id="XZaO@~:FJM-=*VgQCuBu">
                                    <block type="variables_get" id="nJI4),xDQUS6sjs(Q[RJ">
                <block type="comment" id="Zy-`i2yz8~@YSm5aTbyp">
                  <field name="COMMENT">sendet add mp3 next</field>
                    <block type="on_ext" id="^uM%Q]roe/evLR%_@}IW">
                      <value name="OID0">
                        <shadow type="field_oid" id="B.WB{+_a{DM+Y]wMR4x.">
                          <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADDmp3</field>
                        <block type="debug" id=":(#d^8)4;P6@uH[ho42s">
                          <value name="TEXT">
                            <block type="text_join" id="yQ8hW9A4ShV:[0f+C/hc">
                              <value name="ADD0">
                                <block type="text" id="?|=0r)+JMy2T_TVbRa#o">
                              <value name="ADD1">
                                <block type="get_value" id="C1*ytTz??Yh75At#{Y~(">
                              <value name="ADD2">
                                <block type="text" id="HuI*YO-[U2KS@/ISsqz-">
                              <value name="ADD3">
                                <block type="text" id="*SzX1j0}q54ra7KiyfW=">
                                  <field name="TEXT">&amp;playnow=-1&amp;where=next</field>
                              <value name="ADD4">
                                <block type="text" id="H;*jiC);QY)VHkt8EWT2">
                              <value name="ADD5">
                                <block type="get_value" id="E#a3xI|w=]a=5m-i*;;t">
                                  <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADDmp3</field>
                            <block type="control" id="zsM,|)u^+#i!+1BXgE-h">
                                <block type="text_join" id="i5Nir(SHEU[=HIP;71*/">
                                  <value name="ADD0">
                                    <block type="text" id="X|uM$HkBMPLS~GD+U,gq">
                                  <value name="ADD1">
                                    <block type="get_value" id="9s{En1KN~$k|ui$2+Gln">
                                  <value name="ADD2">
                                    <block type="text" id="NWN0F:b{SQ~?(C^}fc|U">
                                  <value name="ADD3">
                                    <block type="text" id="h]oaTV(1Z50mMvGgh^j4">
                                  <value name="ADD4">
                                    <block type="text" id="-1.jsx-TOT-(`%(hVwc3">
                                  <value name="ADD5">
                                    <block type="get_value" id="kjUDvhbTu8$%E^$7H{2*">
                                <block type="request" id="%Bj*Pe[}(?w_sMK7|$GX" disabled="true">
                                  <value name="URL">
                                    <block type="text_join" id="$X5|m1-qt8.3!,fDAe_1">
                                      <value name="ADD0">
                                        <block type="text" id="ntH8HxOiItc334h*7QQu">
                                      <value name="ADD1">
                                        <block type="get_value" id="#?qL/NUaO!#a?p-.p:d!">
                                      <value name="ADD2">
                                        <block type="text" id="AEQL(.}@n51PPBd2dIMw">
                                      <value name="ADD3">
                                        <block type="text" id="f?XgQWNe2^Rb,80Dzq2g">
                                      <value name="ADD4">
                                        <block type="get_value" id="ErFZl+zwV$,qdS%KmyT.">
                                    <block type="debug" id="9H%}qkAm)kq0DL.0ih=-" disabled="true">
                                      <value name="TEXT">
                                        <block type="variables_get" id="tRJ+ge29B-t[W`:x^GS0">
                                        <block type="update" id="W@6Q98*{)G]CtMONHOqX">
                                            <block type="variables_get" id="JM4Zn?(!+VGN*ZQz$M],">
                        <block type="comment" id="A;]3}_esIT9Y6?Z_t4x4">
                          <field name="COMMENT">sendet add mp3 last</field>
                            <block type="on_ext" id="AA+8d]nGD3}L^!{GgObw">
                              <value name="OID0">
                                <shadow type="field_oid" id="hDwMq_$@HnS,w?MNNpu8">
                                  <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADDmp3Last</field>
                                <block type="debug" id="Bk)wW1*!?O|]l6O)J96Y">
                                  <value name="TEXT">
                                    <block type="text_join" id="[upb72zmekWTmi8TTO%.">
                                      <value name="ADD0">
                                        <block type="text" id=")8c^`7V_.ML=!+O-dYGh">
                                      <value name="ADD1">
                                        <block type="get_value" id="8#w^xzjCT$IF(ud$sC.%">
                                      <value name="ADD2">
                                        <block type="text" id="/)/{1DVoZ(M4vE#{MF^H">
                                      <value name="ADD3">
                                        <block type="text" id="H[h^}wK1_y;=.%UY;?h-">
                                          <field name="TEXT">&amp;playnow=-1&amp;where=last</field>
                                      <value name="ADD4">
                                        <block type="text" id="Uj^W_FNVv`^F#dH+p{;S">
                                      <value name="ADD5">
                                        <block type="get_value" id="nhsyR*:{sXw~R-J-A(Kg">
                                          <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADDmp3Last</field>
                                    <block type="control" id="k_g3+gG/!Ldc+-S;r{I]">
                                        <block type="text_join" id="|3zy0PvG!x1,|ab1fk6j">
                                          <value name="ADD0">
                                            <block type="text" id="C+:lvVog;L/vVZl*):BK">
                                          <value name="ADD1">
                                            <block type="get_value" id="h*|VGKmzknAELZK(hpPs">
                                          <value name="ADD2">
                                            <block type="text" id="K2?2~wN/Xh[VUpJa!kFs">
                                          <value name="ADD3">
                                            <block type="text" id="RXskyzdJ,+jF.gUiAb0W">
                                          <value name="ADD4">
                                            <block type="text" id="LOBG:)vl!V!6AgwN5zet">
                                          <value name="ADD5">
                                            <block type="get_value" id="pEWia6%vvTTOf6hdyy|S">
                                        <block type="request" id="oy;?aC0UQ9KtWk}fH|lZ" disabled="true">
                                          <value name="URL">
                                            <block type="text_join" id="^UuA.^LZLn)pq9QTAE+l">
                                              <value name="ADD0">
                                                <block type="text" id="QfG==+Q56rN`=D%nQ$Pi">
                                              <value name="ADD1">
                                                <block type="get_value" id="ic3M?^!6M;_4ppvrAz0O">
                                              <value name="ADD2">
                                                <block type="text" id="AtkrQ:Ak{*v7PV1+xk?8">
                                              <value name="ADD3">
                                                <block type="text" id="gUGnUc}{bb7kEQ4UX3))">
                                              <value name="ADD4">
                                                <block type="get_value" id="O#@UNPH2h:9i+3n^+ip@">
                                            <block type="debug" id="=Sl1]201(S{=2TlF5,Sx" disabled="true">
                                              <value name="TEXT">
                                                <block type="variables_get" id="uS/j8T]J_n~A!fx{6)Hi">
                                                <block type="update" id="4_6h?ol6xZNbmz-;?3Cv">
                                                    <block type="variables_get" id="+KR,f$?82=5taLI92{pV">
        <block type="comment" id="31:D[.TFR$!uczm2Ru_A" x="1188" y="-1412">
          <field name="COMMENT">sendet ordner play</field>
            <block type="on_ext" id="W~RG;O:8Z][fdTA@MXOK">
              <value name="OID0">
                <shadow type="field_oid" id="RBe2vre|%7I^g6`EU1:/">
                  <field name="oid">0_userdata.0.Rookie.STEUERUNG.PLAY</field>
                <block type="debug" id="0(2/PqFA%TNWf6)slm;4">
                  <value name="TEXT">
                    <block type="text_join" id="_[Ki9GFVdb(M(RPeX,AL">
                      <value name="ADD0">
                        <block type="text" id="3zST{G{u1|M-0[sl?09s">
                      <value name="ADD1">
                        <block type="get_value" id="Yq6VQySbRpybk+1pp-(y">
                      <value name="ADD2">
                        <block type="text" id="=KU3.xuWu[7N~cSf,4tz">
                      <value name="ADD3">
                        <block type="text" id="P[Vdowa/Hch$`,lV:)4T">
                      <value name="ADD4">
                        <block type="text" id="XPh]1k}_RUIxcdv4feoK">
                      <value name="ADD5">
                        <block type="get_value" id="OP,8m)8V02LCv9h{G%|D">
                          <field name="OID">0_userdata.0.Rookie.STEUERUNG.PLAY</field>
                    <block type="control" id="=2.{F8hxzHyJx|bu7hpc">
                        <block type="text_join" id="YW/6H|z#}4ALjw(C(0Y~">
                          <value name="ADD0">
                            <block type="text" id="iMYI;kibl}*)FuJB~G@t">
                          <value name="ADD1">
                            <block type="get_value" id="0AoQm[Ut#8F+9egAwpZ+">
                          <value name="ADD2">
                            <block type="text" id=";Rob|cMTNS4+uQ,B,{xn">
                          <value name="ADD3">
                            <block type="text" id="DOav*.JJH_TVJ+#!8!M=">
                          <value name="ADD4">
                            <block type="text" id="G3veM_kktZ{2x1WtK5Hc">
                          <value name="ADD5">
                            <block type="get_value" id="hg[mzaP1UvvqHI;=v^DC">
                        <block type="request" id="lv,9mzT}OdK;3/[3*YCA" disabled="true">
                          <value name="URL">
                            <block type="text_join" id="5Lp[2~k!ZQgZf([_[%pW">
                              <value name="ADD0">
                                <block type="text" id="-C:d]eW//,yT?Al`oxr5">
                              <value name="ADD1">
                                <block type="get_value" id="x)f}hor{bL,|aKwpH6__">
                              <value name="ADD2">
                                <block type="text" id="mpy*oDj=}|#2n1lk,D2t">
                              <value name="ADD3">
                                <block type="text" id="YLpY7I,vJXO~]w7tm9c+">
                              <value name="ADD4">
                                <block type="get_value" id="W0VHGV~@BGp+wSl9a!+`">
                            <block type="debug" id="{V4E9%O;6.Qsj_Tpf5xV" disabled="true">
                              <value name="TEXT">
                                <block type="variables_get" id="hP)64*3:X6%PQkpbpUH4">
                                <block type="update" id="P{~59nDP}[l(yMV~Cl^T">
                                    <block type="variables_get" id="QoH4|C(HW7wu0+Nq!$Uo">
                <block type="comment" id="{Q4khG|~QFFFL7!t/cE~">
                  <field name="COMMENT">sendet add ordner next</field>
                    <block type="on_ext" id="h4B,*3sx[0:R33g.gII{">
                      <value name="OID0">
                        <shadow type="field_oid" id="ayp^uC4o6CQwQkGT=+hV">
                          <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADD</field>
                        <block type="debug" id="L`UcgHbW/[{7[*=*2HN}">
                          <value name="TEXT">
                            <block type="text_join" id="E+27V2wEZ:TJRE/cE%t-">
                              <value name="ADD0">
                                <block type="text" id="nQSoKnI{GDmFSPFz0J[f">
                              <value name="ADD1">
                                <block type="get_value" id="SZ46d$R!#4(mIp!|^}R0">
                              <value name="ADD2">
                                <block type="text" id="yY]a`MR4bj6L@/[QdT3T">
                              <value name="ADD3">
                                <block type="text" id="!xhW,$bO0n.4B30Mi~s@">
                              <value name="ADD4">
                                <block type="text" id="PLa._{4|p6022mpCAv*i">
                              <value name="ADD5">
                                <block type="get_value" id="U$m(kZL$J2l_Hc[5UNsU">
                                  <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADD</field>
                            <block type="control" id="`MJI0e42z5YT+`[nv${3">
                                <block type="text_join" id="=C=YG$d;:x2njQjwR{0{">
                                  <value name="ADD0">
                                    <block type="text" id="*1sf)bQY*KTa2=!z;p*,">
                                  <value name="ADD1">
                                    <block type="get_value" id="s)`vT19lJTc.IWtj})Dl">
                                  <value name="ADD2">
                                    <block type="text" id="*f$z10Mb:UGCTA^]2A+|">
                                  <value name="ADD3">
                                    <block type="text" id="}|wjxmT)@-A%TK525q):">
                                  <value name="ADD4">
                                    <block type="text" id="6F6:_u#^~U6}yVmnTO2P">
                                  <value name="ADD5">
                                    <block type="get_value" id=":^!;v@it;1U|^{^.IE)m">
                                <block type="request" id="6BiCh=6#]ddTd%G^q=RR" disabled="true">
                                  <value name="URL">
                                    <block type="text_join" id="z$7*K8Cv]zK%XAToPCke">
                                      <value name="ADD0">
                                        <block type="text" id="H.,0GA?[@At-M4Rz}uZ|">
                                      <value name="ADD1">
                                        <block type="get_value" id="CqCmqe.`WRFrxCo28kG^">
                                      <value name="ADD2">
                                        <block type="text" id="~aicH`I`-k_m!%eY4(7v">
                                      <value name="ADD3">
                                        <block type="text" id="0xFDbu9r{OCKngn7WIO{">
                                      <value name="ADD4">
                                        <block type="get_value" id="@IKg#B|B[/TM.Ak|V{`q">
                                    <block type="debug" id="FKV$INmgRf0V6]a8cg,|" disabled="true">
                                      <value name="TEXT">
                                        <block type="variables_get" id="6h%Hv8Jh[2/YVuvHtei0">
                                        <block type="update" id="6JN{C550~j[]O]wb|teq">
                                            <block type="variables_get" id="]o3Bf*.+{M#*ugTiQ4mh">
                        <block type="comment" id="e5|h@r{pn6D1#Zw]OnN{">
                          <field name="COMMENT">sendet add ordner last</field>
                            <block type="on_ext" id="51U4{l7Kg7u4ttnU(vlv">
                              <value name="OID0">
                                <shadow type="field_oid" id="p{B7-G[!B=KV=ns6H!Ey">
                                  <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADDLast</field>
                                <block type="debug" id="lelwcg81pt],cL~E#2CC">
                                  <value name="TEXT">
                                    <block type="text_join" id="v}ouCP~FGCj5fT57Ip5p">
                                      <value name="ADD0">
                                        <block type="text" id="*Ia_@%o]sJM[j3s~HXfQ">
                                      <value name="ADD1">
                                        <block type="get_value" id="F@M}+Fnkyl4/:c1GY|Xd">
                                      <value name="ADD2">
                                        <block type="text" id=".(J0$^^{,Xl3`L{EosA5">
                                      <value name="ADD3">
                                        <block type="text" id="51W-[lp~=z.ZS.d#evM~">
                                          <field name="TEXT">&amp;playnow=1&amp;where=last</field>
                                      <value name="ADD4">
                                        <block type="text" id="=,w1VR4$$U^XF~mCQ:tK">
                                      <value name="ADD5">
                                        <block type="get_value" id="LKJi{SYL|js[w6K|fQn(">
                                          <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADDLast</field>
                                    <block type="control" id="tRqLL:X=_EQzl;%.vOb#">
                                        <block type="text_join" id="SeUJUC4KxF$YIT+7}KLK">
                                          <value name="ADD0">
                                            <block type="text" id="#kXFho0qaRQW{@OwD)m2">
                                          <value name="ADD1">
                                            <block type="get_value" id="wO{d!F9/@6B+u)670]iI">
                                          <value name="ADD2">
                                            <block type="text" id="u4Q)OLDG@uPcTUk9|H:U">
                                          <value name="ADD3">
                                            <block type="text" id="%jz[ZS!N[0sKUxmGHej1">
                                          <value name="ADD4">
                                            <block type="text" id="OjpjT(r*d7{eao:$SXnQ">
                                          <value name="ADD5">
                                            <block type="get_value" id="nbmV+[fKh:!X`TP$:1PH">
                                        <block type="request" id="p]TD.RpVp[:!~{i*jZ-b" disabled="true">
                                          <value name="URL">
                                            <block type="text_join" id="RST0|=/S2MNRGZl-J~!7">
                                              <value name="ADD0">
                                                <block type="text" id="V~dU.pr$8~z]Krd838k,">
                                              <value name="ADD1">
                                                <block type="get_value" id="DOVbO*9S|~R#6XCNeY(n">
                                              <value name="ADD2">
                                                <block type="text" id="a+k9YmmA5U`apkj?XBbe">
                                              <value name="ADD3">
                                                <block type="text" id="EONW,X{a)$tfR`P7d=UY">
                                              <value name="ADD4">
                                                <block type="get_value" id="(IrpNczt0rZJG;JlkF_v">
                                            <block type="debug" id="#Atf8cpT)*Vs;/zy5*,4" disabled="true">
                                              <value name="TEXT">
                                                <block type="variables_get" id="etIj=}dUqBH+K9+#wi`g">
                                                <block type="update" id="/#RLDq[bl*#C!LUhdbI`">
                                                    <block type="variables_get" id="DF_b6=Uftwc?QFk5;oz]">
        liv-in-sky @Rookie50 last edited by
        @rookie50 wann hast du mal zeit für eine session ? zum ersen testen
          Rookie50 @da_Woody last edited by
          @da_woody ja, dass ist unglaublich, was liv-in-sky da schon übers Wochenende hinbekommen hat.
          Ich denke Du hast das Grafana Dashboard über Background_HTML oder URL eingefügt, richtig?
          LG
          Rookie
          liv-in-sky da_Woody 2 Replies Last reply Reply Quote 0
            @rookie50
            view.txt table.txt objecte.txt main-js.txt blockly.txt
              @rookie50
              main script ohne shortcut
              main-ohne-js.txt
              • da_Woody
                da_Woody @Rookie50 last edited by
                @rookie50 jup, war irgendwie zufall. wollte eigentlich nur das komplette wetter dash rein haben. dann hab ich gesehn, daß da alles mit dabei ist. einloggen, editieren... natürlich kommste da auch auf alle anderen dann.
                eingebunden über URL
                temp und luftfeuchte hab ich ja schon vorher über einzelne eingebunden. z.b. bad/wc
                müsste man mal testen ob das mit vis... yes, funzt genauso!
                bedeutet, ich kann die listen in vis machen und sollten dann auch in iQontrol voll funktionsfähig sein... licht schalten funktioniert mal...
                  @rookie50
                  wenn du die shortcats aus der liste weghaben willst - ändere einfach diese zeile - dann sind die emojis in der letzten spalte weg
                  ist das table-script
                    @liv-in-sky
                    Guten Morgen, ich muss noch schauen, ob ich den shortcut benötige.
                    Leider hattest du recht, bis dato kann ich mir die Tabelle nur anzeigen lassen und nicht bedienen.
                    Allerdings würde mir diese Anzeige schon fast reichen.
                    LG
                    liv-in-sky 4 Replies Last reply Reply Quote 0
                      @rookie50
                      dann müßten wir evtl eine 2te tabelle schreiben, die du nur für iqontrol hast - wäre auch nicht wild .
                      in iqontrol reicht dann eigentlich nur eine spalte und die suche kann auch weg
                      ich schau mal ob ich die ein solches script vorbereiten kann - dann einfach dazufügen und in iqontrol einbinden
                      bleibt nur noch die steuerung in iqontrol
                        liv-in-sky @Rookie50 last edited by liv-in-sky
                        @rookie50
                        bitte 2- spaltig für iqontrol
                        einfach neues script anlegen undes gibt einen neuen dp untr javascript.0..... für die tabelle
                         //@liv-in-sky 2021  23.3.-15:40
                        // DAS WIDGET IN DER VIS
                        // das Standard html-Widget wird genutzt in der VIS - dazu den DP javascript.x.Tabellen@Liv.TestTabelleVIS.HTMLTableVis als binding angeben d.h.
                        // im html-teil des widgets wird dier daten punkt in geschweiften klammern angegeben z.B. {javascript.0.Tabellen@Liv.TestTabelleVIS.HTMLTableVis}
                        // @ts-ignore
                        let braucheEinVISWidget=true;                          // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                        let  dpVIS="SongsTabelleIQontrol"                            // WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  Ist der Name zum datenpunkt anlegen
                        let braucheEinJSON=false;                               // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                        let  dpJSON="SongsTabelleJSONIControl"                          // WICHTIG wenn braucheEinJSON auf true gesetzt !!   Ist der Name zum datenpunkt anlegen
                        let mySchedule="  */15 * * * * ";                         // jede minute
                        //ZUSÄTZLICH VARIABLEN
                        let sortierenEIN=false;
                        let farbeInaktiverShelly="#5590CA"
                        let welcheSortierung=1;          // je nach spalte von 0 bis 6
                        let geteiteVersionsAnzeige=true; // version in spalte 7 wird 2-zeilig
                        const schalterUmrahmung="0"                              //wenn überschriften buttons sind , den rahmen mit 0 wegmachen
                        let mitSearch=true;
                        let ipButtonColorONBkground="#CBCBCA";
                        let powerButtonColorONSchrift="black";
                         let ipButtonColorONBkground2="#5590CA";
                        let powerButtonColorONSchrift2="white";
                        let flexboxView=false;   // startet im flexbox modus - keine tabelle
                        //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3 - es MÜSSEN in allen Arrays die GLEICHE Anzahl für die Werte sein
                        let htmlFeld=        ["","NAME","PLAY","ADD",""];              // GLEICHE ANZAHL !! NAME/ÜBERSCHRIFT DER SPALTE
                        let val=             ["true","true","false","false","false"];                 // GLEICHE ANZAHL !! SPALTE ANZEIGEN/AUSBLENDEN UND HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WERDEN -  jeder val[x] muss unten in der schleife gesetzt werden !!
                        let Feld1lAlign=     ["center","left","center","center","center"];         // GLEICHE ANZAHL !! AUSRICHTUNG IN DER SPALTE
                        let htmlSpalte1Weite=["25px","200px","25px","95px","0px"];                        // GLEICHE ANZAHL !! BREITE DER SPALTE, wenn "0px" auto
                        let schalterInSpaltenUeberschrift=[true,true,true,true,true,true,true,true];                  // WENN BUTTONS INSTALLIERT WERDEN - sonst false
                        let symbolSchalter=              ["na","&check;","&cross;"];        //ONLINE SYMBOLE         // SYMBOLE DER BUTTONS - standardmäßig sind die spaltennamen (htmlFeld) genutzt - werden im standard nicht genutzt
                        //Symbole für Tabelle z.b.: ⚪  ⚫ ⭕  ➕ ➖ 🎵 🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀 🔹 ✅ ❌ ⚠️ mehr: https://emojiterra.com/de/ oder https://unicode-table.com/de/html-entities/
                        //hier werden die styles für die tabelle definiert
                        //ÜBERSCHRIFT ÜBER TABELLE
                        const htmlUberschrift=false;                             // mit Überschrift über der tabelle
                        const htmlSignature=true;                               // anstatt der Überscghrift eine signature: - kleiner - anliegend
                        const htmlFeldUeber='BlueSound Library';                // für Überschrift und Signature falls htmlUberschrift und htmlSignature ist true
                        const htmlFarbUber="white";                              // Farbe der Überschrift
                        const htmlSchriftWeite="normal";                         // bold, normal - Fettschrift für Überschrift
                        const htmlUEberFontGroesse="18px";                       // schriftgröße überschrift
                        //SEITENLEISTE
                        const ichWillSeitenLeiste=true;                          // links einblenden einer Seitenleiste
                        const nameSeitenLeiste="BLUESOUND"
                        const breiteSeitenleiste=35;
                        const schriftGroesseSeitenleiste=14;
                        const abstandSeitentextVonOben=4;
                        const htmlFarbSeiteSchrift="white";
                        const htmlBackgroundFarbeSeitenliste="blue";
                        //BUTTON ÜBERSCHRIFT
                        const htmlBackgroundButtonUeberschrift="transparent";
                        //SUCHE
                        let bkgroundSearch=1;                                    //   hintergrund für suche-ergebnis und flexboxen    // 1: carbon; 2: iobroker; 3: colored bubbles;  4: gradient farben von htmlFarbTableColorGradient1; 5: gradient farben wie farbeUngeradeZeilen; 6: heller hintergrund
                        const sucheEin=false;
                        const sucheHoehe=25;
                        //MEHRERE TABELLEN NEBENEINANDER
                        let mehrfachTabelle=1;                                   // bis zu 3 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3 !!!
                        const trennungsLinie=1;                                // extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                        const farbetrennungsLinie="#5590CA";                     // bei mehreren Tabellen nebeneinander wird ein Strich zw. den Tabellen gezogen
                        const htmlFarbTableColorUber="white"                     // Spalten-Überschrift in der tabelle - für die einzelnen Spalten //"#BDBDBD";
                        const htmlFarbZweiteTabelle="white";                     // Farbe der Spalten-Überschrift bei jeder 2.ten Tabelle
                        //ÜBERSCHRIFT SPALTEN - OBERSTE ZEILE IN TAB
                        const UeberSchriftHoehe=30;                            // Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                        const LinieUnterUeberschrift="1";                        // Liniehoehe nur unter Spaltenüberschrift
                        const farbeLinieUnterUeberschrift="#233E58";               // LinienFarbe unter Spaltenüberschrift
                        const groesseUeberschrift=12;
                        const UeberschriftStyle="normal"                         // möglich "bold"
                        const UeberschriftSpalten=true;                          // ein- oder ausblenden der spatlen-überschriften
                        //GANZE TABELLE
                        const abstandZelle="7";                                  // legt den abstand in den zellen zum rahmen fest
                        const zeilenAbstand=20;                                   // legt den abstand zwischen den zeilen fest
                        const farbeUngeradeZeilen="#2F2F2F";                     // Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2 - bei "transparent" gewinnt htmlFarbTableColorGradient1
                        const farbeGeradeZeilen="#3c3c3c"//"#151515";            // Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2   - bei "transparent" gewinnt htmlFarbTableColorGradient2
                        let weite="300";                                        // Weite der Tabelle - verhindert das dynamische breiter werden, wenn werte unterschiedliche werte haben
                        let hoeheTabelle=387;
                        const zentriert=true;                                    // ganze tabelle zentriert im html Widget - muss in pixel angegeben werden oder "auto"
                        const backgroundAll="#000000";                           // Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                        const htmlSchriftart="Helvetica"//"Ubuntu-Regular"                    // "Jura-DemiBold"   //"RobotoCondensed-Bold"   //"Helvetica"; .....
                        const htmlSchriftgroesse="12px";                         // schriftgröße in den zellen
                        const rahmenBreite="1px";                                //mit 0 ist äußerer rahmen weg
                        //FELDER UND RAHMEN
                        const htmlFarbFelderschrift="#CBCBCA";                   // SchriftFarbe der Felder
                        const htmlFarbFelderschrift2="#CBCBCA";                  // SchriftFarbe der Felder für jede 2te Tabelle
                        const htmlGragient=[150,30,70];                          // einstellung des gradienten
                        const htmlFarbTableColorGradient1="#0F263D";             // Gradient - Hintergrund der Tabelle - Verlauffarbe
                        const htmlFarbTableColorGradient2= "#233E58"//"#5590CA";              // Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                        const htmlFarbTableBorderColor="grey";                   // Farbe des Rahmen - ist dieser gleich den gradienten, sind die rahmen unsichtbar
                        let htmlRahmenLinien="none";                             // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                        // AB HIER NICHTS  ÄNDERN -------------------------------------------------------------------------------------------------
                        // AB HIER NICHTS  ÄNDERN ---------------------------------erst wieder ab Zeile 134----------------------------------------
                        let borderHelpBottum;
                        let borderHelpRight;
                        let htmlcenterHelp;
                        let htmlcenterHelp2;
                        let trHelperClass=" ";
                        let htmlTabUeber4;
                        let htmlTabUeber2;
                        let htmlTabUeber2_1;
                        let searchMe;
                        let htmlSeitenleiste;
                        let htmlTabStyle;
                        let htmlTabUeber3="";       //wird in function writeHTML gesetzt - wegen umschalten views
                        let buttonScript; //scripte am ende einfügen
                        let bkgDiv;   //background scroll-div
                        let scrollBar; //dünne scrollbar
                        let aktiv=-1; let inaktiv=0;
                        let myButtonUeberschrift; //not in use
                        let htmlZentriert;   //css
                        let einmalAbstand; //seitenleiste
                        if(String(htmlRahmenLinien)=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                        if(String(htmlRahmenLinien)=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                        if(String(htmlRahmenLinien)=="none") {borderHelpBottum=0;borderHelpRight=0;}
                        if(String(htmlRahmenLinien)=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                        zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                        zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                        if(weite=="auto") {weite="100%"} else {weite=String(Number(weite)*mehrfachTabelle)}
                         makeMyCSS();
                         makeMySearch_Seitenleiste();
                         makeMyVisScripte();
                        if ( !(val.length == Feld1lAlign.length && htmlSpalte1Weite.length == htmlFeld.length && val.length == htmlFeld.length) || (mehrfachTabelle<1 || mehrfachTabelle>3) )
                             { log("Anzahle der Definitions Arrays sind ungleich ODER mehrfachTabelle ist falsch - Script wurde gestoppt !!!","error");
                                 // @ts-ignore
                                 stopScript();}
                        let langeGesamt=0;
                        let htmlTabUeber="";
                        let htmlOut="";
                        let mix;
                        let counter;
                        let makeJsonWidget;
                        let myObject=[];
                        let mitAlphabet=false;
                        needDP();
                        function writeHTML(){
                            // rückkopplung zu vis -werteliste
                        setTimeout(function () {  setState("0_userdata.0.Rookie.VIEW.SEUERUNG.toPlay",false);
                                                     setState("0_userdata.0.Rookie.VIEW.SEUERUNG.addNext",false);
                                                     setState("0_userdata.0.Rookie.VIEW.SEUERUNG.addLast",false);
                                                 }, 500);
                            aktiv=-1;  inaktiv=0;
                        let seitenLeistenTest="";
                        //log(flexboxView.toString())
                        flexboxView ? htmlTabUeber3=`</tr></thead><tbody></tbody></table><div class="divFlexBoxen${dpVIS}">` :
                                     htmlTabUeber3=`</tr></thead><tbody class="scrollContent${dpVIS}" > `;
                        let htmlTabUeber1=htmlTabUeber4
                        myObject=[]
                        let helperLeerzeile=""
                        let makeJsonWidget=[];
                        htmlOut="";
                        counter=-1;
                        //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                        //---------alle val[x] werte müssen von euch bestimmt werden - val[0],val[1],val[2] !!!-------------------------------------------------------------
                        let valueuptime
                        let myReturnJson=[]
                        let myDataJson=JSON.parse(getState("0_userdata.0.Rookie.VIEW.JSON").val)
                        myReturnJson.push({
                              "nummer": "0",
                              "anzeige":"return",
                              "value" : "Return",
                              "file" : "⏱"
                        let myJSONDATA =myReturnJson.concat(myDataJson)
                        //log(JSON.stringify(myJSONDATA))
                        for (let i=0; i<myJSONDATA.length;i++) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                               val[0]=val[1]=val[1]=val[2]=val[3]= "missingState";
                                   // log( myJSONDATA.anzeige)
                                myObject.push({                "value0" : myJSONDATA[i].anzeige,            //  "INSTANCE"
                                                               "value1" : myJSONDATA[i].nummer,            //  "SINCE"
                                                               "value2" : myJSONDATA[i].file,            //  "STATUS"
                                                               "value3" : myJSONDATA[i].value
        //   ID
                                  makeJsonWidget.push({        [htmlFeld[0]] : val[0],  //  "INSTANCE"
                                                               [htmlFeld[1]] : val[1],  //  "SINCE"
                                                               [htmlFeld[2]] : val[2]
        // diese function muss als letztes in der eigenen schleife aufgerufen werden
                           };                                            // Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                          // Sortierungen---------------------------------------------------------
                          //welcheSortierung=3
                          if( sortierenEIN && (welcheSortierung==3 || welcheSortierung==4 || welcheSortierung==1)    ) {
                                     if(welcheSortierung==3) myObject.sort(function (alpha, beta) { return  Number(beta["value4"]) -Number(alpha["value4"]);   });
                                     if(welcheSortierung==4) myObject.sort(function (alpha, beta) { /*log(beta.valueuptime+" --" +alpha.valueuptime);*/ return  beta.valueuptime -alpha.valueuptime;   });
                                     if(welcheSortierung==1)   myObject.sort( function( a, b )   {
        a = a["value1"].split( '.' );
        b = b["value1"].split( '.' );
        for( var i = 0; i < a.length; i++ )	{
                           	                                 	if( ( a[i] = parseInt( a[i] ) ) < ( b[i] = parseInt( b[i] ) ) )
                           	                         		return -1;	else if( a[i] > b[i] )
                           	                            	return 1;}  	return 0;} );
                                     } else {
                            switch (welcheSortierung) {
                               case 0: sortMe("alpha","value0");break;
                               case 1: break;
                               case 2: sortMe("bool","value2");break;
                               case 3: break;
                               case 4: break;
                               case 5: sortMe("alpha","value5");break;
                               case 6: sortMe("alpha","value6");break;
                           for(let zz=0;zz<myObject.length;zz++){
                         // Unterüberschften ------------------------------------------------------
                                if (mitAlphabet){
                                  if( myObject[zz].value0[0]!=helperLeerzeile){ tabelleAusbessern();
        counter=-1;  for(let ic=0;ic<mehrfachTabelle;ic++ ) { for (let tt=0 ;tt<val.length;tt++)
        { tt==0 && ic==0 ? val[tt]=(myObject[zz].value0[0]).toUpperCase() : val[tt]="&ensp;"
        counter++;tabelleBind();langeGesamt++; }
                                  helperLeerzeile=myObject[zz].value0[0] } ; sortierenEIN=false;}
                         // Zuteilung der Tabellenspalten-------------------------------------------
                           aktiv++
                            val[0]=""
                            val[1]=myObject[zz].value0;
                            log(myObject[zz].value3)
                            val[2]=myObject[zz].value1; // log(typeof val[2])
                           // val[2]=myObject[zz].value2;
                         //  let valButton2=""
                           // val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton2+"\')\">"+"➡️" + "</button>"
                            val[4]= ""// "<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnShortcut\(\'"+"valButton"+"\')\">"+"🤍" + "</button>" //myObject[zz].value3;
                        //log(myObject[zz].value3)
                          let valButton=myObject[zz].value1;
                          if (myObject[zz].value2.includes("📁"))   { let valButton=myObject[zz].value1;
        val[0]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnNewFolder\(\'"+valButton+"\')\">"+myObject[zz].value2 + "</button>"
        valButton=encodeURI(getState("0_userdata.0.Rookie.braucheNeueDatenNeu").val+"/"+myObject[zz].value3)
        val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderPlay\(\'"+valButton+"\')\">"+"▶️" + "</button>"
        val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAdd\(\'"+valButton+"\')\">"+"⏩" + "</button>"
        val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
                          if (myObject[zz].value2.includes("⏱"))   {val[0]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnNewFolder\(\'"+valButton+"\')\">"+myObject[zz].value2 + "</button>"
        val[2]=""; val[2]="";val[4]=decodeURI(getState("0_userdata.0.Rookie.braucheNeueDatenNeu").val.replace(/^.+\/(.+)$/,"$1"))
        val[3]=""}
                          if (myObject[zz].value2.includes("🎵"))   {val[0]= "<font color=\"#A4ACF0\">"+" &#9834;"+" </font> " //+ myObject[zz].value2+" "+val[0]
        let valButton=encodeURI(myObject[zz].value3)
        val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Play\(\'"+valButton+"\')\">"+"▶️" + "</button>"
        val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Add\(\'"+valButton+"\')\">"+"⏩" + "</button>"
        //   val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Play\(\'"+valButton+"\')\">"+"⏩" + "</button>"
        val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3AddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
                        /* &#127926;
                           if (!myObject[zz].value2) {val[2]=symbolSchalter[2];inaktiv++}
                            if (myObject[zz].value2)  {val[2]=symbolSchalter[1];aktiv++}
                            if (!myObject[zz].value2) {     val[0]="<font color=\""+farbeInaktiverShelly +"\">"+val[0]+"</font>";
                                                           val[1]="<font color=\""+farbeInaktiverShelly +"\">"+val[1]+"</font>";
                                                           val[2]="<font color=\""+farbeInaktiverShelly +"\">"+val[2]+"</font>";
                                                           val[3]="<font color=\""+farbeInaktiverShelly +"\">"+val[3]+"</font>";
                                                           val[4]="<font color=\""+farbeInaktiverShelly +"\">"+val[4]+"</font>";
                                                           val[5]="<font color=\""+farbeInaktiverShelly +"\">"+val[5]+"</font>";
                                                           val[6]="<font color=\""+farbeInaktiverShelly +"\">"+val[6]+"</font>";
                             counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                            flexboxView ? flexboxBind() : tabelleBind();                                   // HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT
                             langeGesamt++;                                   // WICHTIG Seitenleiste
                        //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                           htmlTabUeber2=""
                        //SpaltenÜberschrift
                        for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { if (!schalterInSpaltenUeberschrift[ue] ) {
                                           htmlTabUeber2=htmlTabUeber2.concat("<td  style=\"color:"+htmlFarbTableColorUber+"\">"+htmlFeld[ue]+"</td>")}
                                           else {let valButton="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+ue;
                                            if(ue==htmlSpalte1Weite.length-1) {htmlTabUeber2=htmlTabUeber2.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\" >"+
        "<button class=\"myButt"+dpVIS+"\" style=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundButtonUeberschrift+"\; color: "
        +htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text\-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton+"\')\">"
        +htmlFeld[ue]+"</button>"+" <font style=\"; font-weight: normal; font-size :"+groesseUeberschrift+"; color: "+htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+";\" >"+aktiv+"</th>")} else{
                                                               htmlTabUeber2=htmlTabUeber2.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\">"+""
        +"<button class=\"myButt"+dpVIS+"\" style\=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundButtonUeberschrift+"\; color: "
        +htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton+"\')\">"
        +htmlFeld[ue]+"</button></th>")} } //symbolSchalter[ue]
                        //SpaltenÜberschrift bei mehrfachtabelle
                        if (!flexboxView){ htmlTabUeber2_1=""
                        for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { let valButton="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+ue;
                           if(ue==htmlSpalte1Weite.length) {htmlTabUeber2_1=htmlTabUeber2_1.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\" >"+""
        +"<button class=\"myButt"+dpVIS+"\" style\=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundButtonUeberschrift+"; color: "
                           else{ if(ue==0){htmlTabUeber2_1=htmlTabUeber2_1.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\" >"+""
                           } else{
        +htmlFeld[ue]+"</button></th>")}}  }
                        }else { htmlTabUeber2_1="";for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { htmlTabUeber2_1=htmlTabUeber2_1.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+" emptyFlex2_1"+dpVIS+"\">"+htmlFeld[ue]+"</th>")}
                        /*    for (let ue=0;ue<htmlSpalte1Weite.length;ue++) {
        +htmlFeld[ue]+"</button></th>")}*/
                         htmlTabUeber="";
                         switch (mehrfachTabelle) {
                           case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                           case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                           case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2_1+htmlTabUeber3; break;
                           case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                          if (!UeberschriftSpalten) {htmlTabUeber=""}
                           flexboxView ? flexboxFinish() :  tabelleFinish();
                              if (braucheEinJSON ) {setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".JSONVis",JSON.stringify(makeJsonWidget),1000 )}
                        } // function ende
                        //MAIN:
                        schedule(mySchedule,  function () {
                         writeHTML();
                        // if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                        on({id: "0_userdata.0.Rookie.VIEW.JSON", change: "any"}, function (obj) {
                         // var value = obj.state.val;
                         // log("bekommeXML: "+value)
                              writeHTML();
                        setTimeout(function () {writeHTML();  }, 2050);
                         function tabelleBind(){
                           case 1: if(counter%2==0)   {htmlOut=htmlOut+"<tr class=\"myclasstr_gerade"+dpVIS+" \">";
                                                       for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>"); // style=\"width:"+htmlSpalte1Weite[u]+"\"
        }  htmlOut=htmlOut.concat("</tr>");   break;
                                                       } else   {htmlOut=htmlOut+"<tr class=\"myclasstr_ungerade"+dpVIS+" \">";
        for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>"); //style=\"width:"+htmlSpalte1Weite[u]+"\"
                           case 2: if(counter%4==0){  if(counter%2==0)  {htmlOut = htmlOut+"<tr class=\"myclasstr_gerade"+dpVIS+" \">";
        for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+"\" style=\" border-right:"+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\">"+val[u]+"</td>")}
                                                        } else { for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  } break;
                                                   } else {
                                                     if(counter%2==0)  {htmlOut=htmlOut+"<tr class=\"myclasstr_ungerade"+dpVIS+" \">";
        {htmlOut=htmlOut.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+" toDel"+dpVIS+"\" style=\" border-right:"+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\">"+val[u]+"</td>")}
                                                        } else {        for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  }  break;}
                           case 3: if(counter%2==0)  {  if(counter%3==0 ) {htmlOut = htmlOut+"<tr class=\"myclasstr_gerade"+dpVIS+" \">";
        for(let u=0;u<val.length;u++){if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");} else
                                                       } else { if(counter%3==1)  {for(let u=0;u<val.length;u++){  if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+ "; color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>")}
        } else  { for(let u=0;u<val.length;u++){  htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  } }  break;
                                                     else {
                                                        if(counter%3==0 )  {htmlOut = htmlOut+"<tr class=\"myclasstr_ungerade"+dpVIS+" \">";
        for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+" toDel"+dpVIS+" toDel"+dpVIS+"\" style=\" border-right:"+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\">"+val[u]+"</td>")}
                                                     } else{ if(counter%3==1 )  { for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");} else
                                } //switch ende
                         function tabelleAusbessern() {         // bessert mei mehrfachtabellen die nicht vollen zeilenn aus - bevor die unterüberschriften kommen
                               case 1:    break;
                               case 2:    let helpMehrfach="</td>";
                                          for(let w=0;w<val.length;w++){helpMehrfach=helpMehrfach.concat("<td>&ensp;</td>")};helpMehrfach=helpMehrfach.concat("</tr>")
                                          if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach);
                                          break;
                               case 3:   let helpMehrfach2="</td>";
                                         for(let w=0;w<val.length;w++){helpMehrfach2=helpMehrfach2.concat("<td>&ensp;</td>")};helpMehrfach2=helpMehrfach2.concat("</tr>")
                                         if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                         if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach2);
                                         let helpMehrfach3="</td>";
                                         let helpMehrfach31="";for(let w=0;w<val.length;w++){helpMehrfach31=helpMehrfach31.concat("<td>&ensp;</td>")}
                                         for(let w=0;w<val.length;w++){if(w<val.length-1) {helpMehrfach3=helpMehrfach3.concat("<td>&ensp;</td>")} else
        {helpMehrfach3=helpMehrfach3.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+"\" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td>"+helpMehrfach31)}
        };helpMehrfach3=helpMehrfach3.concat("</tr>")
                                         if(counter%3==0)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach3);  break; }}
                         function tabelleFinish() {
                               case 1:    break;
                                          break;
                                var htmlUeber=    "<p  class=\"divWeiten"+dpVIS+"\" style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlUEberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), 'SS:mm:ss')+"</p>";
                                if(mitSearch) htmlUeber=htmlUeber+searchMe
                                var htmlUnter= "<div class=\"divWeiten"+dpVIS+"\" style=\"margin-top: 10px; color:"+htmlFarbUber+"; height: 30px; font-family:"+htmlSchriftart+"; font-size: 85%; text-align: center;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), "SS:mm:ss");"</div>";
                                if (!htmlSignature) htmlUnter="";
                                     var htmlOutVIS="";
                                     if (htmlUberschrift)
                                        { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript ;
                                    } else {
                                       zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript;
                          // log("bin raus aus tabelleBind");
                                   if (braucheEinVISWidget)  setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis", htmlOutVIS ,1000);
                         var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; height: 30px; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), "SS:mm:ss");+"</div>"
                          var htmlEnd="</table>"+htmlUnter+"</div></body>";
                         //mit oder ohne überschrift - zentriert oder links
                        //htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                         //log(htmlOut);
                        function flexboxBind(){
                          htmlOut=htmlOut+"<div class=\"divFlexBoxenEinzeln"+dpVIS+" divInFlex"+dpVIS+"\"> <div  style=\"font-size: 125%; font-weight: bold\">"+val[0]+"</style></div><br>IP: "+val[1]+"<br>RSSI: "+val[4]
        +" </div>"
                         //setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis", myFlexer ,1000);  "<br> "+val[3]+   "<br> "+val[5]+
                         //log(htmlOut)
                        function flexboxFinish(){
                        // htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript ;
                           var htmlOutVIS="";
                                        { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript ;
                                    } else {
                                       zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript;
                         // htmlOut=htmlOut+"<div> val[0] <br> val[2] </div>"
                        async function needDP(){
                           for(let s=0;s<schalterInSpaltenUeberschrift.length;s++){ if(schalterInSpaltenUeberschrift[s]){
                           if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+s))) {
                               await createStateAsync("Tabellen@Liv."+dpVIS+".Spalte"+s, false,{type: "boolean", name: "Schalter_Spalte"+s, role: "value", read: true, write: true, } ); }
                           if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis"))) {
                               await createStateAsync("Tabellen@Liv."+dpVIS+".HTMLTableVis", "empty",{type: "string", name: "HTML_Standard_Widget_mit_Binding", role: "value", read: true, write: true, } ); }
                            if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".JSONVis"))) {
                               await createStateAsync("Tabellen@Liv."+dpVIS+".JSONVis", "",{type: "string", name: "JSON Format", role: "value", read: true, write: true, } ); }
                           let arrTriggerSchalter=[]
                           $("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte*").each(function(id, i) {
                                  arrTriggerSchalter.push(id)
                         //  log(arrTriggerSchalter.toString())
                           on({id: arrTriggerSchalter, ack: false, change: "any"}, function (obj) {
                             //  log(obj.id)
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte0") welcheSortierung=1;
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte1" )  welcheSortierung=1 ;
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte2" )  welcheSortierung=1;
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte4")  welcheSortierung=3;
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte3" )  welcheSortierung=1;
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte5") welcheSortierung=5;
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte6" )  welcheSortierung=6;
                             if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte7" )  flexboxView=!flexboxView;
                           //  log(String(mehrfachTabelle))
                               writeHTML();
                        }, 900);
                           });}, 5050);
                        //SORTIEREN
                        function sortMe(myType,value){
                        if(myType=="alpha" ){ myObject.sort(function (alpha, beta) {
                                    if ((alpha[value].toString().toUpperCase()).trim() > (beta[value].toString().toUpperCase()).trim())
                                       return 1;
                                    if ((beta[value].toString().toUpperCase()).trim()> (alpha[value].toUpperCase().toString()).trim())
                                       return -1;
                                    return 0;
                        if(myType=="bool" ) {
                          myObject .sort(function(x, y) { return x[value] - y[value] }); }
                          if(myType=="num" )   { myObject.sort(function (alpha, beta) {
                                             return  beta[value] -alpha[value];   });}
                        function makeMyCSS() {
                           trHelperClass=" ";
                        for (let jj=0;jj<(Feld1lAlign.length)*mehrfachTabelle;jj++) {  //"td:nth-child(1) {width: "+htmlSpalte1Weite[0]+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite[1]+"}"+
                               trHelperClass= trHelperClass+ " .scrollContent"+dpVIS+" td"+":nth-of-type("+(jj+1)+") {width: "+htmlSpalte1Weite[jj]+"; text-align: "+Feld1lAlign[jj]+" }"
                         //log(trHelperClass)
                        switch (bkgroundSearch){
                           case 1 :   bkgDiv=`background:
                                              radial-gradient(black 15%, transparent 16%) 0 0,
                                              radial-gradient(black 15%, transparent 16%) 8px 8px,
                                              radial-gradient(rgba(255,255,255,.1) 15%, transparent 20%) 0 1px,
                                              radial-gradient(rgba(255,255,255,.1) 15%, transparent 20%) 8px 9px;
                                              background-color:#282828;
                                              background-size:16px 16px;`; break;
                          case 2 : bkgDiv=`background:
                                           url(data:image/gif;base64,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)`
                                          ; break
                          case 3 : bkgDiv=`background:
                                           radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.15) 30%, rgba(255,255,255,.3) 32%, rgba(255,255,255,0) 33%) 0 0,
                                           radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.1) 11%, rgba(255,255,255,.3) 13%, rgba(255,255,255,0) 14%) 0 0,
                                           radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.2) 17%, rgba(255,255,255,.43) 19%, rgba(255,255,255,0) 20%) 0 110px,
                                           radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.2) 11%, rgba(255,255,255,.4) 13%, rgba(255,255,255,0) 14%) -130px -170px,
                                           radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.2) 11%, rgba(255,255,255,.4) 13%, rgba(255,255,255,0) 14%) 130px 370px,
                                           radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.1) 11%, rgba(255,255,255,.2) 13%, rgba(255,255,255,0) 14%) 0 0,
                                           linear-gradient(45deg, #343702 0%, #184500 20%, #187546 30%, #006782 40%, #0b1284 50%, #760ea1 60%, #83096e 70%, #840b2a 80%, #b13e12 90%, #e27412 100%);
                                           background-size: 470px 470px, 970px 970px, 410px 410px, 610px 610px, 530px 530px, 730px 730px, 100% 100%;
                                           background-color: #840b2a;`; break;
                          case 4 : bkgDiv=`background: radial-gradient(${htmlFarbTableColorGradient1}, ${htmlFarbTableColorGradient2});`; break;   //265686 5590CA 2F2F2F 3c3c3c
                          case 5 : bkgDiv=`background: radial-gradient(${farbeUngeradeZeilen}, ${farbeGeradeZeilen});`; break;   //265686 5590CA 2F2F2F 3c3c3c
                          case 6 : bkgDiv=`background: radial-gradient(#bfbcbc, #ffffff);`; break;   //265686 5590CA 2F2F2F 3c3c3c
                        scrollBar=` .thescroller${dpVIS}::-webkit-scrollbar { width: 5px;}
                        .thescroller${dpVIS}::-webkit-scrollbar-track {background: transparent; width: 5px;}
                        .thescroller${dpVIS}::-webkit-scrollbar-thumb {border-radius: 40px; border: transparent ; background: ${htmlFarbTableColorGradient1}; }
                        .thescroller${dpVIS} {scrollbar-width: thin; scrollbar-color: ${htmlFarbTableColorGradient1} transparent;}}`
                        myButtonUeberschrift=" .myButt"+dpVIS+" {border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color: "+htmlBackgroundButtonUeberschrift+"\; color: "+htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text-align:left;}"
                                  htmlZentriert=   "<style>"+                       // <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no\" />
                                   /*weite*/          " .divWeiten"+dpVIS+" {  width: "+weite+"px }"+
                                   /*thead*/          " .fixedHeader"+dpVIS+" { position: sticky; top: 0px ; overflow-y:auto; overflow-x: hidden; width: 100%;  height: "+UeberSchriftHoehe+"px; border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+";"+
        " font-family:"+htmlSchriftart+"\;  color:"+htmlFarbTableColorUber+"; "+  //  border-spacing:"+abstandZelle+"px;
        " font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+";  background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); }"+ //
                                   /*tbody */         " .scrollContent"+dpVIS+" { width: 100%;  overflow-y: scroll;   }"+ // height: "+hoeheTabelle2+"px;
                                                      " .scrollContent"+dpVIS+" td {padding: "+abstandZelle+"px;}"+
                                   /*div*/            " .tableContainer"+dpVIS+" {  display: flex; flex-direction: column;  height: "+hoeheTabelle+"px; width: "+weite+"px; overflow-y:auto; overflow-x: hidden ; "
        +bkgDiv+" }"+  // position: sticky; top: 0; background-color: black;
                                   /*seitenl*/        " .seitenleiste"+dpVIS+" { background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); color: " //background-color: "+htmlBackgroundFarbeSeitenliste+";
        +htmlFarbSeiteSchrift+ ";font-size:"+schriftGroesseSeitenleiste+"px; vertical-align:top; text-align:center; width: "+breiteSeitenleiste+"px}"+  //margin-top: 30px;
                                                      " .flexContainer"+dpJSON+" {display: flex; width: "+weite+"px}"+
                                   /*table*/          " .tablezusatz"+dpVIS+" {  border:"+rahmenBreite+";  "+  //table-layout: fixed;
        "width:100%; color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+";"+
        "font-family:"+htmlSchriftart+"; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); }"+
                                                      " .mythclass0"+dpVIS+" {    }"+  //text-align:"+Feld1lAlign[0]+"
                                                      " .mythclass1"+dpVIS+" {   }"+
                                                      " .mythclass2"+dpVIS+" {   }"+
                                                      " .mythclass3"+dpVIS+" {  }"+
                                                      " .mythclass4"+dpVIS+" {  }"+
                                                      " .mythclass5"+dpVIS+" {  }"+
                                                      " .mythclass6"+dpVIS+" {   }"+
                                                      " .divFlexBoxen"+dpVIS+" {overflow-y: scroll; display: flex; flex-direction: row; flex-wrap: wrap; width: 100%; height: "+(hoeheTabelle-(Number(UeberSchriftHoehe)))+"px;  align-items: center; justify-content: center; }"+
                                                      " .divFlexBoxenEinzeln"+dpVIS+" { padding: 20px; color: "+htmlFarbFelderschrift+"; border: 2px solid; border-radius: 25px; width: auto; height: auto; border-color: "+htmlFarbTableColorGradient2+"; margin: 10px;}"+
                                                      " .divInFlex"+dpVIS+" {  background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" 10%,"+htmlFarbTableColorGradient1+" 20%); }"+ //  "+htmlGragient[1]+"   "+htmlGragient[2]+"
                                                      " .emptyFlex2_1"+dpVIS+" { color: transparent; background-image: none !important; background-color: "+htmlFarbTableColorGradient1+" !important;}"+
                                                    //  " th {position: sticky; top: 0px ; height: "+UeberSchriftHoehe+"px; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); }"+  //position: sticky; top: 0px ;
                                                      " .myclassueber_spalte_button     {color:"+htmlFarbTableColorUber+"}"+
                                                      " .myclassueber_spalte_ohne_button{color:"+htmlFarbTableColorUber+"}"+
                                                      " .myTHclass"+dpVIS+" {position: sticky; top: 0px ; height: "+UeberSchriftHoehe+"px; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%);}"+
                                                      " .myTRclass"+dpVIS+" {}"+
                                                      " .myclasstr_gerade"+dpVIS+" { height:"+zeilenAbstand+"px; background-color:"+farbeGeradeZeilen+"}"+  //border-spacing:"+abstandZelle+"px;
                                                      " .myclasstr_ungerade"+dpVIS+" {  height:"+zeilenAbstand+"px;  background-color:"+farbeUngeradeZeilen+"}"+ //border-spacing:"+abstandZelle+"px;
                                                      " .myclasstd_normal"+dpVIS+" {}"+
                                                      " .myclasstd_trennungslinie"+dpVIS+" {}"+
                                                      " .myinputclass"+dpVIS+" {width: "+weite+"px; border: 1px solid; border-color: "+htmlFarbTableColorGradient2+"; margin-bottom: 15px;  color: "+htmlFarbTableColorUber+
        "; height: "+sucheHoehe+"px; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+
        htmlGragient[2]+"%); font-family:"+htmlSchriftart+"\; font-size: 110%; color: "+htmlFarbTableColorUber+"}"+
                                                   trHelperClass+scrollBar+ //myButtonUeberschrift+
                                                 //     " .thescroller"+dpVIS+"::-webkit-scrollbar {width: 0px; }"+
                                                      "</style>"+'<center>'
                        //not in use
                        //alt -  falls eine extra html datei gebraucht wird
                        /*let htmlStart; //file
                        const path = "/htmlexample.html";                        //FIlenamen definieren
                        const home ='vis.0'                                      //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                        let   braucheEinFile=false;                              // bei true wird ein file geschrieben
                        htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html;  http-equiv=\"refresh\" content=\"30\"; charset=utf-8\">"+
                                           "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                           " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                          // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                           " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                           " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                           " </style></head><body> <div>";  */
                        }// endCSS
                        function makeMySearch_Seitenleiste() {
                        //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                          einmalAbstand=`<br>
                         let seitenLeistenTest="&#128472;";
                        seitenLeistenTest= "<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnRefresh\(\'"+"valButton"+"\')\">"+seitenLeistenTest + "</button>"
                         for (let f=0;f<abstandSeitentextVonOben;f++){
                             seitenLeistenTest=seitenLeistenTest+`<br>
                         for (let i=0;i<nameSeitenLeiste.length;i++){
                             seitenLeistenTest=seitenLeistenTest+nameSeitenLeiste[i]+`<br>
                         htmlSeitenleiste="";
                         if (ichWillSeitenLeiste) htmlSeitenleiste= "<div class=\"flexContainer"+dpJSON+"\"> <div class=\"seitenleiste"+dpVIS+"\">"+seitenLeistenTest+"</div>" ;// htmlTabUeber1=htmlTabUeber1+
                        searchMe="";
                        sucheEin ? searchMe="<div class=\"divWeiten"+dpVIS+"\"><input class=\"myinputclass"+dpVIS+"\" type=\"search\" id=\"search"+dpVIS+"\" placeholder=\"Filter by Item\""+">"+"</div>" :
                                   searchMe=""
                        searchMe=searchMe+htmlSeitenleiste
                        htmlTabStyle= "<div class=\"tableContainer"+dpVIS+" thescroller"+dpVIS+"\" >"+
                                           "<table class=\"tablezusatz"+dpVIS+"\" rules=\""+htmlRahmenLinien+"\">"+
                                           "<thead class=\"fixedHeader"+dpVIS+"\">"
                        htmlTabUeber4="<tr class=\"myTRclass"+dpVIS+"\">";
                        function makeMyVisScripte() {
                            let valSpalte=[] ;
                           for(let kk=0;kk<val.length;kk++){
                             valSpalte.push(val[kk])
                           let spaltenAnzeigeScript=`$(document).ready(function() { `
                           let spaltenAnzeigeScriptEnd=` });` ;
                        for (let ff=0;ff<(valSpalte.length);ff++){
                                                               // log(valSpalte[ff]);
        if (valSpalte[ff]=="false") { spaltenAnzeigeScript=spaltenAnzeigeScript.concat(`$('td:nth-child(${(ff+1)}).toDel${dpVIS},th:nth-child(${(ff+1)}).toDel${dpVIS}').hide();`)
        if (mehrfachTabelle==2) {spaltenAnzeigeScript=spaltenAnzeigeScript.concat(`$('td:nth-child(${(ff+1+valSpalte.length)}).toDel${dpVIS},th:nth-child(${(ff+1+valSpalte.length)}).toDel${dpVIS}').hide();`) }
        if (mehrfachTabelle==3) {spaltenAnzeigeScript=spaltenAnzeigeScript.concat(`$('td:nth-child(${(ff+1+(2*valSpalte.length))}).toDel${dpVIS},th:nth-child(${(ff+1+(2*valSpalte.length))}).toDel${dpVIS}').hide();`) }
                        buttonScript =   '<script> function setOnOtherValue(myval) {	var Self = this;	Self.servConn.getStates(myval, (error, states) => {  console.log(states); self.servConn.setState(myval, !states[myval].val);}  )}; '
                                             + 'function setOnNewFolder(myval) {	var Self = this;	vis.setValue("0_userdata.0.Rookie.holdData",myval)}; '
                                             + 'function setOnMp3Play(myval)    {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.PLAYmp3",myval)}; '
                                             + 'function setOnMp3Add(myval)     {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADDmp3",myval)}; '
                                             + 'function setOnFolderPlay(myval) {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.PLAY",myval)}; '
                                             + 'function setOnFolderAdd(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADD",myval)}; '
                                             + 'function setOnFolderAddLast(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADDLast",myval)}; '
                                             + 'function setOnMp3AddLast(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADDmp3Last",myval)}; '
                                             + 'function setOnRefresh(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.refreshAnzeige",true)}; '
                                             + 'function setOnShortcut(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.SHORTCUT.now",true)}; '
                                             + 'function setOnShortcutUsage(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.SHORTCUT.useShortcut",myval)}; '
                                             + 'function setOnShortcutDelete(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.SHORTCUT.deleteShortcut",myval)}; '
                                             + '$( "button.myButt'+dpVIS+'" ).click(function() {  $( this ).slideUp() });' //'[class*="test"]' [class~="value"]   "[class~='gerade']"
                            /*search*/       + `var allRows = $("[class*='gerade${dpVIS}']");  $("input.myinputclass${dpVIS}").on("keydown keyup", function() {  allRows.hide();  $("tr:contains('" + $(this).val() + "')").show();});`
                            /*search*/       + `var allRows2 = $("div.divFlexBoxenEinzeln${dpVIS}"); console.log(allRows2);  $("input.myinputclass${dpVIS}").on("keydown keyup", function() {  allRows2.hide();  $("div.divFlexBoxenEinzeln${dpVIS}:contains('" + $(this).val() + "')").show();});`
                                             + `$( ".seitenleiste${dpVIS}" ).click(function() {var Self = this; var myvali='javascript.0.Tabellen@Liv.ShellyTabelleVIS.Spalte7'; vis.setValue(myvali,true)    });`
                            /*dbclick*/      + `$( "[class*='gerade${dpVIS}']" ).dblclick(function() {var Self = this; var myvali='javascript.${instance}.Tabellen@Liv.${dpVIS}.Spalte7'; vis.setValue(myvali,true)    });`
                            /*dbclick*/      + `$( "[class*='divFlexBoxen${dpVIS}']" ).dblclick(function() {var Self = this; var myvali='javascript.${instance}.Tabellen@Liv.${dpVIS}.Spalte7'; vis.setValue(myvali,true)    });`
                                             +   spaltenAnzeigeScript  +  spaltenAnzeigeScriptEnd
                                             +'</script>'
                          @rookie50
                          soweit ich @da_Woody verstanden habe, kannst du einen teil der vis in iqontrol einbinden
                          d.h.
                          kannst du eine neue view machen, in der nur die valuelist widgets links oben zu sehen sind und die refresh und buttons
                          diesen kleine view dann in iqontrol einbinden - dann solltest du doch direkt bedienen können
                          du kannst nur nicht in der tabelle arbeiten, da dies direkt ein html ist - die neie kleine view wenn eingebunden ist, ist die grundlage vis - drüber ist iqontrol - dann sollte das funktionieren
                            @rookie50
                            habe gerade gemerkt, dass ich die anderen spalten nur ausblende mit jquery, was in iqontrol nicht funktioniert - daher sieht man in iqontrol alle spalten
                            das muss ichj anders lösen
                            du bekommst ein neues/anderes table script für iqontrol
                              Rookie50 @liv-in-sky last edited by
                              @liv-in-sky 💋
                                @rookie50 wie bindet man die vis seite in iqontrol ein - habe schon länger nicht damit gearbeitet
                                oder willst du kurz bei mir auf den pc drauf gehen
                                  @rookie50
                                  für iqontrol - kann man sicher noch schöner einstellen - aber es funzt 🙂
                                  SCRIPT FÜR IQONTROL - 2 spaltig
                                  // @ts-ignore
                                  let mitSearch=true;
                                  let htmlFeld=        ["","NAME"];              // GLEICHE ANZAHL !! NAME/ÜBERSCHRIFT DER SPALTE
                                  let val=             ["true","true"];                 // GLEICHE ANZAHL !! SPALTE ANZEIGEN/AUSBLENDEN UND HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WERDEN -  jeder val[x] muss unten in der schleife gesetzt werden !!
                                  let Feld1lAlign=     ["center","left"];         // GLEICHE ANZAHL !! AUSRICHTUNG IN DER SPALTE
                                  let htmlSpalte1Weite=["25px","200px"];                        // GLEICHE ANZAHL !! BREITE DER SPALTE, wenn "0px" auto
                                  //SEITENLEISTE
                                  //SUCHE
                                  //GANZE TABELLE
                                  //FELDER UND RAHMEN
                                  let htmlcenterHelp;
                                  let htmlTabUeber4;
                                  let htmlTabUeber2;
                                  let searchMe;
                                  let htmlTabStyle;
                                   makeMyCSS();
                                   makeMyVisScripte();
                                           // @ts-ignore
                                           stopScript();}
                                  let langeGesamt=0;
                                  let htmlOut="";
                                  let mix;
                                  let counter;
                                  let makeJsonWidget;
                                  let myObject=[];
                                  needDP();
                                                           }, 500);
                                  myObject=[]
                                  htmlOut="";
                                  counter=-1;
                                  let valueuptime
                                  let myReturnJson=[]
                                  myReturnJson.push({
                                        "nummer": "0",
                                        "anzeige":"return",
                                        "value" : "Return",
                                        "file" : "⏱"
                                         val[0]=val[1]= "missingState";
        //   ID
                                               } else {
                                         case 1: break;
                                         case 3: break;
                                         case 4: break;
                                          if (mitAlphabet){
                                     aktiv++
                                      val[0]=""
                                  //    val[2]=myObject[zz].value1; // log(typeof val[2])
                                   //   val[4]= ""// "<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnShortcut\(\'"+"valButton"+"\')\">"+"🤍" + "</button>" //myObject[zz].value3;
        //  val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderPlay\(\'"+valButton+"\')\">"+"▶️" + "</button>"
        //  val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAdd\(\'"+valButton+"\')\">"+"⏩" + "</button>"
        //  val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
        // val[2]=""; val[2]="";val[4]=decodeURI(getState("0_userdata.0.Rookie.braucheNeueDatenNeu").val.replace(/^.+\/(.+)$/,"$1"))
        // val[3]=""
        // val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Play\(\'"+valButton+"\')\">"+"▶️" + "</button>"
        // val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Add\(\'"+valButton+"\')\">"+"⏩" + "</button>"
        //   val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3AddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
                                  /* &#127926;
                                     htmlTabUeber2=""
                                     } else{
                                   htmlTabUeber="";
                                  } // function ende
                                  //MAIN:
                                   writeHTML();
                                        writeHTML();
                                                             } else {
                                                               else {
                                          } //switch ende
                                         case 1:    break;
                                                    break;
                                         case 1:    break;
                                                    break;
                                               var htmlOutVIS="";
                                              } else {
                                   //log(htmlOut);
        +" </div>"
                                   //log(htmlOut)
                                     var htmlOutVIS="";
                                              } else {
                                       //  log(obj.id)
                                         writeHTML();
                                  }, 900);
                                     });}, 5050);
                                  //SORTIEREN
                                                 return 1;
                                                 return -1;
                                              return 0;
                                     trHelperClass=" ";
                                                    ; break
                                  //not in use
                                  }// endCSS
                                    einmalAbstand=`<br>
                                  searchMe="";
                                             searchMe=""
                                      let valSpalte=[] ;
                                                       +'</script>'
                                    @rookie50
                                    so würde es mit shortcuts aussehen - nur in table view anwendbar
                                      @liv-in-sky
                                      hi, seit wir xml2json benutzen, funktioniert die Status Anzeige nicht mehr 😞
                                      Ich denke, dass hängt zusammen und ich muss das nun mit JS zerlegen und in Objekte schreiben.
                                      LG
                                        @rookie50
                                        glaub ich nicht - das blockly ruft das module nicht auf
                                        ist den der dp noch aktuell - ich nutze den nicht
                                          @liv-in-sky said in Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol:
                                          In meiner "ursprünglichen Steuerung" habe in den DP für die Anzeige von Album, Titel und Artist genutzt. Den Status habe ich alle 5 Sekunden abfragt, für fortschrittsbalken usw.
                                            @rookie50 @rookie50 verstehe - aber ich kann mir nicht vorstellen, dass dieses installierte modul auswirkungen auf das javascript hat, wenn es nicht expleziet aufgerufen wird
                                            ich war ja eh verwundert, das du ein xml format so lesen kannst
                                            habe gerade keine idee
                                            exportier' mal diesen block, dann schau ich mal bei mir
                                            6954
