    4. Test Adapter fb-checkpresence v1.1.x
    • MichMein
      MichMein @afuerhoff last edited by
      @afuerhoff
      Hi, ich bekomme bei Installation über die Katze folgende Fehlermeldungen.
      $ iobroker url fb-checkpresence --host ioBroker
      install fb-checkpresence
      NPM version: 6.14.12
      npm install fb-checkpresence --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code E404
      npm ERR! 404 Not Found - GET https://registry.npmjs.org/fb-checkpresence - Not foundnpm ERR! 404 npm ERR! 404 'fb-checkpresence@latest' is not in the npm registry.npm ERR! 404 You should bug the author to publish it (or use the name yourself!)npm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-05-01T12_57_11_533Z-debug.log
      upload [7] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
      upload [6] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/style.css style.css text/css
      upload [5] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
      upload [4] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
      upload [3] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/fb-checkpresence.png fb-checkpresence.png image/png
      upload [2] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/dateformat.png dateformat.png image/png
      upload [1] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/admin.d.ts admin.d.ts video/mp2t
      upload [0] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/access_settings_network.png access_settings_network.png image/png
      Process exited with code 0
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @MichMein last edited by
        @michmein
        Bitte über Beliebig mit dieser Url https://github.com/afuerhoff/ioBroker.fb-checkpresence installieren? Der andere Weg scheint buggy zu sein.
          sigi234 Forum Testing Most Active @afuerhoff last edited by
          @afuerhoff
          Bekomme diesen Fehler:
          $ ./iobroker url "https://github.com/afuerhoff/ioBroker.fb-checkpresence"
          install afuerhoff/ioBroker.fb-checkpresence#0f8fe35b35c05f8bcaa94a300f4ab546c8febcfb
          npm install afuerhoff/ioBroker.fb-checkpresence#0f8fe35b35c05f8bcaa94a300f4ab546c8febcfb --loglevel error (System call)
          npm ERR! code EBUSY
          npm ERR! syscall rmdir
          npm ERR! path C:\Program Files\iobroker\Home\node_modules\iobroker.fb-checkpresence
          npm ERR! errno -4082
          npm ERR! EBUSY: resource busy or locked, rmdir 'C:\Program Files\iobroker\Home\node_modules\iobroker.fb-checkpresence'
          npm ERR!     C:\Program Files\iobroker\Home\env\npm-cache\_logs\2021-05-01T14_56_40_726Z-debug.log
          ERROR: host.Medion(Home) Cannot install afuerhoff/ioBroker.fb-checkpresence#0f8fe35b35c05f8bcaa94a300f4ab546c8febcfb: 4294963214
          ERROR: process exited with code 25
          • afuerhoff
            afuerhoff Developer @sigi234 last edited by afuerhoff
            @sigi234 sagte in Test Adapter fb-checkpresence v1.1.x:
            @afuerhoff
            npm ERR! code EBUSY
            Hast du über GITHUB installiert oder Beliebig?
            Ich hab schon einen Issue unter Admin 5 gemacht.
              sigi234 Forum Testing Most Active @afuerhoff last edited by sigi234
              @afuerhoff
              Beliebig
              Unter Admin 4.2.1 funktionierte es einwandfrei via eigene Url !
              • afuerhoff
                @sigi234
                Also ein Admin 5 Fehler. Issue hatte ich schon erstellt
                  @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                  @sigi234
                  Jupp, meiner Meinung nach schon. Ist nicht nur bei deinem Adapter so. (Code 25) Einige gehen andere wieder nicht.
                  • afuerhoff
                    afuerhoff Developer last edited by
                    Ich hab gerade noch ein Update eingespielt. Beim ersten Adapterstart gab es noch Probleme beim Anlegen der Objekte. Fällt aber nur auf, wenn sie noch nicht existieren.
                      fritz0815 last edited by
                      ich benutze die Myfritz!App und habe damit VPN aktiviert. Das hat zur Auswirkung, dass auf der Fritzbox neue VPN Verbindungen und auch dedizierte Hosts erstellt werden. Dummerweise werden dafür Namen mit Sonderzeichen verwendet und leider kann man diese Hosts und auch nicht verändern. Nun gibt der Adapter periodisch die Meldung
                      2021-05-04 15:39:53.015 - debug: fb-checkpresence.0 (30680) loop family ends after 2,503761741 s
                      2021-05-04 15:39:55.494 - debug: fb-checkpresence.0 (30680) loop main ends after 0,476834836 s
                      2021-05-04 15:39:57.734 - info: fb-checkpresence.0 (30680) hostname: MyFRITZ!App-(Samsung-SM-G973F) false
                      2021-05-04 15:39:57.736 - info: fb-checkpresence.0 (30680) hostname: MyFRITZ!App-(Samsung-SM-T530) false
                      2021-05-04 15:39:57.763 - info: fb-checkpresence.0 (30680) hostname: MyFRITZ!App-2-(Samsung-SM-T530) false
                      2021-05-04 15:39:57.765 - debug: fb-checkpresence.0 (30680) getDeviceInfo activeCnt: 35
                      aus. Diese Hosts tauchen auch unter Family auf, jedoch bringt selektieren/deselektiere/löschen keine Änderung. Kann man an der Log Ausgabe etwas ändern, außer die Log-Stufe auf WARN stellen?
                      Viele Grüße
                      Markus
                      afuerhoff 2 Replies Last reply Reply Quote 0
                      • afuerhoff
                        afuerhoff Developer @fritz0815 last edited by afuerhoff
                        @fritz0815
                        Die Logstufe steht ja auf debug. Bitte auf Info stellen. Oder auch warn oder error.
                        Die Info Ausgabe kommt noch raus.
                        Die Sonderzeichen werden alle ersetzt.
                        • afuerhoff
                          @fritz0815
                          Hattest Du das neueste Update von Github geladen? Ich hatte gerade nachgesehen und die Info Meldung sollte eigentlich schon deaktiviert sein. Bitte einmal von Github aktualisieren.
                            fritz0815 @afuerhoff last edited by
                            @afuerhoff Danke - mit "test version: 1.1.3_g" ist die Meldung weg.
                            • afuerhoff
                              ich habe seit gestern die Version 1.1.4 ins latest hochgeladen. Es gab aber keine Änderungen mehr zur 1.1.3.
                              ? 1 Reply Last reply Reply Quote 1
                                A Former User @afuerhoff last edited by
                                @afuerhoff Hi, ich habe sie seit gestern Abend laufen, keine Probleme.
                                Leider wurde sie mir nicht als Update angezeigt, vielleicht war ich zu schnell..
                                • afuerhoff
                                  afuerhoff Developer @Guest last edited by
                                  @ilovegym
                                  Hattest du vorher schon aus Github geladen?
                                    @afuerhoff Nur, wenn du schreibst, dass du n Update hochgeladen hast...
                                    Stephan Schleich 1 Reply Last reply Reply Quote 0
                                    • Stephan Schleich
                                      Stephan Schleich @Guest last edited by
                                      bei mir ist es auch noch nicht im latest
                                        ak1 last edited by
                                        Ich habe gestern auf Version 1.1.4 aktualisiert. Gleichzeitig habe ich der Familiengruppe noch einen Namen gegeben.
                                        Heute Vormittag fällt mir dann auf, dass
                                        fb-checkpresence.0.xyz.presence
                                        nicht aktualisiert wird. Meine Frau ist nicht zu Hause. Ihr iPhone ist in der Fritz!Box derzeit als nicht aktives Gerät verzeichnet. Dennoch steht der Datenpunkt auf true. Mehrfacher Neustart des Adapters hat nichts verändert.
                                        Hat jemand einen Troubleshooting-Tipp für mich?
                                        • afuerhoff
                                          afuerhoff Developer @ak1 last edited by afuerhoff
                                          @ak1 sagte in Test Adapter fb-checkpresence v1.1.x:
                                          Ist das ggfs. der alte Datenpunkt? Wenn du eine Gruppe vergeben hast, befindet sich der Datenpunkt an anderer Stelle.
                                          Die alten Datenpunkte können manuell gelöscht werden.
                                          -> fb-checkpresence.0.familymembers.gruppex.xyz.presence
                                          • afuerhoff
                                            afuerhoff Developer @Stephan Schleich last edited by
                                            @stephan-schleich sagte in Test Adapter fb-checkpresence v1.1.x:
                                            React UI Problem? Am besten mal den Info Adapter aufrufen.
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            257944
