    4. Test Adapter wolf-smartset 1.0.x
      KeTuLE @Meistertr last edited by
      @meistertr Ich kann jetzt keine Device-List mehr abrufen. Bei Abrufen kommt nach kurzem der Error{}. Die Credentials haben sich nicht geändert und werden per Copy&Past vom Password-Manager übertragen.
      node main.js --debug
      2021-03-27 19:07:10.336  - debug: wolf-smartset.0 (4437) Redis Objects: Use Redis connection: 127.0.0.1:6379
      2021-03-27 19:07:10.369  - debug: wolf-smartset.0 (4437) Objects client ready ... initialize now
      2021-03-27 19:07:10.376  - debug: wolf-smartset.0 (4437) Objects create System PubSub Client
      2021-03-27 19:07:10.377  - debug: wolf-smartset.0 (4437) Objects create User PubSub Client
      2021-03-27 19:07:10.378  - debug: wolf-smartset.0 (4437) Objects client initialize lua scripts
      2021-03-27 19:07:10.390  - debug: wolf-smartset.0 (4437) Objects connected to redis: 127.0.0.1:6379
      2021-03-27 19:07:10.398  - debug: wolf-smartset.0 (4437) objectDB connected
      2021-03-27 19:07:10.400  - debug: wolf-smartset.0 (4437) Redis States: Use Redis connection: 127.0.0.1:6379
      2021-03-27 19:07:10.407  - debug: wolf-smartset.0 (4437) States create System PubSub Client
      2021-03-27 19:07:10.409  - debug: wolf-smartset.0 (4437) States create User PubSub Client
      2021-03-27 19:07:10.416  - debug: wolf-smartset.0 (4437) States connected to redis: 127.0.0.1:6379
      2021-03-27 19:07:10.417  - debug: wolf-smartset.0 (4437) statesDB connected
      2021-03-27 19:07:10.551  - info: wolf-smartset.0 (4437) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.wolf-smartset, node: v12.21.0, js-controller: 3.2.16
      2021-03-27 19:07:10.578  - error: wolf-smartset.0 (4437) Please configure user, password and device in config
      2021-03-27 19:07:17.742  - info: wolf-smartset.0 (4437) getDeviceList
      2021-03-27 19:07:17.975  - error: wolf-smartset.0 (4437) API GET AUTH TOKEN ERROR: Error: Request failed with status code 400
      2021-03-27 19:07:17.977  - debug: wolf-smartset.0 (4437) sendTo "getDeviceList" to system.adapter.admin.0 from system.adapter.wolf-smartset.0
      2021-03-27 19:07:33.120  - info: wolf-smartset.0 (4437) getDeviceList
      2021-03-27 19:07:33.227  - error: wolf-smartset.0 (4437) API GET AUTH TOKEN ERROR: Error: Request failed with status code 400
      2021-03-27 19:07:33.228  - debug: wolf-smartset.0 (4437) sendTo "getDeviceList" to system.adapter.admin.0 from system.adapter.wolf-smartset.0
      2021-03-27 19:07:34.691  - info: wolf-smartset.0 (4437) Got terminate signal TERMINATE_YOURSELF
      2021-03-27 19:07:36.389  - info: wolf-smartset.0 (4437) getDeviceList
      2021-03-27 19:07:36.491  - error: wolf-smartset.0 (4437) API GET AUTH TOKEN ERROR: Error: Request failed with status code 400
      2021-03-27 19:07:36.492  - debug: wolf-smartset.0 (4437) sendTo "getDeviceList" to system.adapter.admin.0 from system.adapter.wolf-smartset.0
      2021-03-27 19:07:38.113  - warn: wolf-smartset.0 (4437) Got terminate signal. Checking desired PID: 0 vs own PID 4437
      2021-03-27 19:07:38.138  - warn: wolf-smartset.0 (4437) Got terminate signal. Checking desired PID: 4460 vs own PID 4437
      2021-03-27 19:07:41.957  - info: wolf-smartset.0 (4437) getDeviceList
      2021-03-27 19:07:42.066  - error: wolf-smartset.0 (4437) API GET AUTH TOKEN ERROR: Error: Request failed with status code 400
      2021-03-27 19:07:42.067  - debug: wolf-smartset.0 (4437) sendTo "getDeviceList" to system.adapter.admin.0 from system.adapter.wolf-smartset.0
      2021-03-27 19:09:08.825  - info: wolf-smartset.0 (4437) getDeviceList
      2021-03-27 19:09:08.955  - error: wolf-smartset.0 (4437) API GET AUTH TOKEN ERROR: Error: Request failed with status code 400
      2021-03-27 19:09:08.956  - debug: wolf-smartset.0 (4437) sendTo "getDeviceList" to system.adapter.admin.0 from system.adapter.wolf-smartset.0
      2021-03-27 19:09:16.484  - info: wolf-smartset.0 (4437) Got terminate signal TERMINATE_YOURSELF
      2021-03-27 19:09:17.681  - info: wolf-smartset.0 (4437) getDeviceList
      2021-03-27 19:09:17.814  - error: wolf-smartset.0 (4437) API GET AUTH TOKEN ERROR: Error: Request failed with status code 400
      2021-03-27 19:09:17.815  - debug: wolf-smartset.0 (4437) sendTo "getDeviceList" to system.adapter.admin.0 from system.adapter.wolf-smartset.0
      2021-03-27 19:09:19.894  - warn: wolf-smartset.0 (4437) Got terminate signal. Checking desired PID: 0 vs own PID 4437
      2021-03-27 19:09:19.917  - warn: wolf-smartset.0 (4437) Got terminate signal. Checking desired PID: 4500 vs own PID 4437
      Meistertr 1 Reply Last reply Reply Quote 0
      • Meistertr
        Meistertr Developer @KeTuLE last edited by Meistertr
        @ketule ich kann den fehler nciht reproduzieren. 400 kommt bei mir, wenn ich falsche zugangsdaten nehme. habe die Version auf 4 Systemen ohne Fehler am laufen.. welche js-controller version nutzt du?
        K 2 Replies Last reply Reply Quote 0
          @meistertr Folgende Node.js Version und JS-Controller sind installiert und verwendet: node: v12.21.0, js-controller: 3.2.16
          Ich deinstalliert nochmal die Instanz und den Adapter. Mal sehen, ob noch es dann geht. Ich melde mich dann.
            @meistertr Jetzt geht es. Mein Fehler. Ich habe den Adapter nochmals gelöscht und wieder von Git installiert. Ich hatte noch eine Shell im Verzeichnis offen und, der Adapter konnte nicht richtig gelöscht werden. Danke Dir.
              Cepheus last edited by
              Hallo zusammen! Ich habe hier auch eine ISM7 und war schon am grübeln ob sich ein wechsel auf die ISM8 loht. Daher schon einmal danke für die Mühe das hier ans Laufen zu bekommen.
              Ich wollte jetzt auch mal schauen wie der Stand ist und den Adapter installieren.
              Daher wollte ich den Adapter installieren, was auch ohne Fehlermeldung funktioniert hat. Jedoch finde ich keine Einträge im ioBroker. Es wird keine Instanz und daher auch keine Objekte angezeigt.
              Hab dann noch einmal versucht die Installation im Debug-Modus zu wiederholen. Scheinbar auch wieder ohne Fehler mit dem selben Ergebnis.
              Die Meldung sieht wie folgt aus:
              $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.wolf-smartset" --debug
              install iobroker-community-adapters/ioBroker.wolf-smartset#beae0860d95912468408ca29c801a3d7e7d43bf4
              NPM version: 6.14.12
              npm install iobroker-community-adapters/ioBroker.wolf-smartset#beae0860d95912468408ca29c801a3d7e7d43bf4 --loglevel error --prefix "/opt/iobroker" (System call)
              + iobroker.wolf-smartset@0.2.2removed 2 packages and updated 1 package in 53.442s
              146 packages are looking for funding  run `npm fund` for details
              upload [4] wolf-smartset.admin /opt/iobroker/node_modules/iobroker.wolf-smartset/admin/words.js words.js application/javascript
              upload [3] wolf-smartset.admin /opt/iobroker/node_modules/iobroker.wolf-smartset/admin/wolf-smartset.png wolf-smartset.png image/png
              upload [2] wolf-smartset.admin /opt/iobroker/node_modules/iobroker.wolf-smartset/admin/style.css style.css text/css
              upload [1] wolf-smartset.admin /opt/iobroker/node_modules/iobroker.wolf-smartset/admin/index_m.html index_m.html text/html
              upload [0] wolf-smartset.admin /opt/iobroker/node_modules/iobroker.wolf-smartset/admin/admin.d.ts admin.d.ts video/mp2t
              process exited with code 0
              Irgendeine Idee warum das bei mir nicht läuft? System ist auf dem neusten Stand, alles aktuell.
                sigi234 Forum Testing Most Active @Cepheus last edited by
                @cepheus
                Instanz mit + Icon hinzugefügt?
                C 1 Reply Last reply Reply Quote 1
                  Cepheus @sigi234 last edited by
                  @sigi234
                  Oh man... Wie doof kann man eigentlich sein...
                  Danke, das war's!
                  • AFi
                    AFi @Meistertr last edited by
                    @meistertr Hi,
                    besitze eine Wolf Heizung ca. 2 Jahre alt mit Gastherme, Mischmodul, Bedienmodul und Solar. Habe derzeit alles in eine ISM8i gebündelt und über den Wolfadapter in iobroker integriert, leider wird der Adapter nicht mehr gepflegt und ist Fehlerbehaftet, s. https://forum.iobroker.net/topic/40621/wolf-ism8i-adapter-variablendefinition/59.
                    Nun bin ich auf diesen Beitrag gestoßen und habe folgende Fragen:
                    • Schnittstellenmodul ISM7e / Link home / Link pro
                      => funktioniert es mit allen dreien
                    • Kann ich den Sparfaktor und die Sollwertkorrektur verändern.
                    • Warum erscheint der Wolf-Smartset nicht bei den auswählbaren Adaptern unter ioBroker.
                    VG Axel
                    • Meistertr
                      Meistertr Developer @AFi last edited by
                      @afi Der Adapter nutzt die Wolf Cloud, also alle Module die mit der App kompatibel sind, sollten auch mit dem adapter gehen.
                      Es können alle Werte geschrieben und gelesen werden die von Wolf freigeben sind, incl. Sparfaktor und Sollwertkorrektur
                      Er ist noch nciht gelistet weil er noch in der Beta Phase ist und ich meine Prio zur Zeit auf einem anderen Apdater habe. kommt aber in den nächsten Wochen ins lastest
                      Z AFi 2 Replies Last reply Reply Quote 0
                      • Z
                        Zico @Meistertr last edited by
                        @meistertr
                        Als erstes ein unglaublich dickes Lob für diesen Adapter der für mich persönlich genau zur richtigen Zeit von Dir erstellt wurde und grandios funktioniert. Ich logge seit 23.3. Daten in eine Influx Datenbank und werte diese mit Grafana aus. Bisher hatte ich lediglich 2 oder 3 Aussetzer, der letzte ist aber auch schon ewig her. Ich schreibe seit Oktober beginnend und jetzt parallel dazu 2x am Tag mir wichtige Werte manuell in eine Tabelle, ua. auch Werte, an die ich nur über die Fachmannebene komme. Daher meine Frage: das Passwort zur Fachmannebene steht in jedem Manual und auch Youtube Video aus dem Hause Wolf, ist also nicht unbedingt als geheim einzustufen. Ist es evtl auch möglich über den Adapter an diese Werte, zb Verdichterstarts, Drehzahl Ventilator usw. zu kommen? Da ich über den Adapter auch gar keine Werte geändert habe bzw ändern möchte gilt die Frage auch nur dem Lesemodus der (versteckten?) Fachmann-Werte.
                        • AFi
                          @meistertr Hi,
                          ich klinke mich hier etwas aus Verzweiflung ein, es ist mir bewußt, das dieses Thema eigentlich nicht hierher gehört aber ich hoffe Du hilfst uns leidgeplagten Adapterverwender des Standardadapters von Wolf.
                          Du findest hier, den derzeitigen Stand der Dinge, im Prinzip geht es um den Sparfaktor bzw. Sollwertkorrektur, 0,5-Schritte
                          Beitrag unter ioBroker
                          Gehe ganz an den Schluß und Du findest in den letzten 4-5 Beiträgen alle Informationen.
                          Ich bitte Dich darum den Adapter zu korrigieren, diese Technik beherrsche ich leider nicht, mir fehlt das
                          Wissen mit GitHub umzugehen und vorallem das Wissen der Programmierung. In ioBroker mache ich alles mit Blockly.
                          Schon mal vielen Dank im voraus.
                          VG Axel
                          Meistertr 1 Reply Last reply Reply Quote 1
                          • Meistertr
                            so die 1.0.0 ist draußen, gerne testen bitte adapter vorher löschen, da ich alle objekte nochmal geändert habe und die Fachmann daten hinzugefügt habe
                            A Loemic 2 Replies Last reply Reply Quote 0
                              Adri525 @Meistertr last edited by
                              @meistertr
                              Vielen Dank!!!!
                              Jetzt kann ich auch endlich die Bypass Klappe steuern 🙂
                              • O
                                oxident last edited by
                                Geniale Arbeit! Läuft bei mir mit ISM7e, CGW20/120, Mischer und 2 BMs hervorragend (parallel zu einer MQTT/eBusd-Installation).
                                Danke 😉
                                • O
                                  Nur mal so rein interessehalber: Wäre es nicht auch möglich, dass der Adapter eine lokal laufende Instanz der Smartset-Software abfragt?
                                  Ich meine, die Webseite, die die Windows-Software bereitstellt ist doch eigentlich die gleiche, die auch in der Cloud vorhanden ist...
                                    finke3 last edited by finke3
                                    HI @Meistertr
                                    ich plane auch deinen finalen Adapter zu nutzen.
                                    Eine Frage bezüglich der Fachmann-Ebene: Sind die Daten nun nur in "read only" im default?
                                    Nicht, dass ich nach der Installation gleich einen Heizungsmonteur brauche 😄
                                    Update: Ich habe den Adapter nun erfolgreich in Verwendung. Allerdings hatte ich es in den letzten 24 Stunden schon 2 mal, dass für jeweils paar Minuten die Wolf-Cloud nicht erreichbar war (auch nicht über die App). In dieser Zeit hat der Adapter dann falsche Werte geliefert, was die Diagramme verfälscht.
                                    Kann man eventuell das Adapterverhalten ändern, falls die Wolf API nicht erreichbar bzw. einen HTTP 400 liefert?
                                    Lieben Gruß
                                    Finke
                                    • bullrandle
                                      bullrandle last edited by
                                      hatte bis jetzt ein ism8 mit dem Wolf Adapter in Betrieb, hat allerdings keine Werte mehr geliefert.
                                      Darum gestern auf ein ism7 gewechselt, soweit funktioniert auch alles.
                                      Allerdings gabs beim ism8 für die CWL ein Objekt für die Filterwarnung, wird das beim ism7 über die App gemeldet?
                                      LG
                                      Christian
                                        e-i-k-e last edited by
                                        Guten Abend,
                                        erstmal vielen Dank für diesen Adapter, ich habe mir genau so etwas gewünscht! 👍
                                        Bei mir wurden leider unter der Fachmannebene Parameter verstellt und ich hatte am nächsten Tag kein WW. Ob ich dies versehentlich selbst durch den Adapter gemacht habt, kann ich nicht sagen. Würde mir aber "einen Schutz" wünschen, dass so etwas nicht auf die schnelle passieren kann.
                                        • Loemic
                                          Loemic @Meistertr last edited by
                                          @meistertr du schreibst, dass die Datenpunkte in der Fachmannebene bearbeitbar sind. Beispielsweise die Datenpunkte für die Heizkurven sind bei mir auf read only.
                                          kann das in Zukunft geändert werden?
                                          • Meistertr
                                            Meistertr Developer @Loemic last edited by
                                            @loemic ob die datenpunkte beschreibbar sind wird von wolf vorgegeben
                                            31.7k
                                            79.8k
                                            ism7 wolf
                                            28
                                            118
                                            13566
