    4. [gelöst] Common Error Skript Fehler?
    • padrino
      padrino Most Active last edited by padrino
      Musste, weil ein Skript amok lief 😌 die JS Instanz neu starten...
      Nun wirft sie immer den Fehler aus?
      Kann mir jemand helfen, worum es gehen könnte?
      2021-05-04 23:27:12.204 - info: javascript.0 (26331) Start javascript script.js.common.error-skript
      2021-05-04 23:27:12.225 - error: javascript.0 (26331) script.js.common.error-skript compile failed:
      at script.js.common.error-skript:1
      2021-05-04 23:27:12.226 - error: javascript.0 (26331) function (err) {
      2021-05-04 23:27:12.227 - error: javascript.0 (26331) ^
      2021-05-04 23:27:12.228 - error: javascript.0 (26331) SyntaxError: Unexpected token (
      2021-05-04 23:27:12.229 - error: javascript.0 (26331) at new Script (vm.js:83:7)
      2021-05-04 23:27:12.230 - error: javascript.0 (26331) at Object.createScript (vm.js:277:10)
      2021-05-04 23:27:12.231 - error: javascript.0 (26331) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
      2021-05-04 23:27:12.231 - error: javascript.0 (26331) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
      2021-05-04 23:27:12.232 - error: javascript.0 (26331) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17)
      2021-05-04 23:27:12.233 - error: javascript.0 (26331) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
      2021-05-04 23:27:12.233 - error: javascript.0 (26331) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
      2021-05-04 23:27:12.234 - error: javascript.0 (26331) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2021-05-04 23:27:12.235 - error: javascript.0 (26331) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      2021-05-04 23:27:12.236 - error: javascript.0 (26331) at process._tickCallback (internal/process/next_tick.js:68:7)
      F paul53 2 Replies Last reply Reply Quote 0
        fastfoot @padrino last edited by
        @padrino die Funktion hat keinen Namen
        padrino 1 Reply Last reply Reply Quote 0
        • padrino
          padrino Most Active @fastfoot last edited by padrino
          @fastfoot
          Welche meinst Du?
          Also,
          a) nutze ich nur "funktionslose" Blockly Skripte
          und
          b) ist "error-skript" nicht von mir, müsste also etwas vom System sein.
            paul53 @padrino last edited by
            @padrino
            Error in Zeile 1 lässt vermuten, dass ein Skript unter der Gruppe "global" aktiv ist, was es nicht sollte (im Expertenmodus deaktivieren).
            • padrino
              padrino Most Active @paul53 last edited by padrino
              Nö, "Global" ist (wie's sich gehört ;)) leer.
                @padrino
                Dann poste mal den Javascript-Code von "common.error-skript" in Code tags.
                  @padrino sagte in Common Error Skript Fehler?:
                  liegt lt LOG in common, vlt kannst du es ja dort finden. Sonst wüsste ich nicht was zu tun ist
                  padrino 1 Reply Last reply Reply Quote 1
                  • padrino
                    Danke Euch 2, da lag wirklich was in common. 🤦‍♂️
                    Keine Ahnung, wo das her ist.
                    Mein Hirn wird immer mehr ein Sieb. 😞
