    4. [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe
      Pittini Developer @Sneaker75 last edited by
      @sneaker75 sagte in [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe:
      @pittini Es geht um ca. 50 Sensoren, da ist vielleicht allgemein gesprochen das Implementieren einfacher, als mit alias-Datenpunkten zu arbeiten. Nur wenn Du mal Zeit finden solltest... 👼
      50....na das is ja mal ne Ansage. Ich werd sehen was ich tun kann, gib mir mal nen Screenshot vom Raw eines dieser Datenpunkte.
      S 2 Replies Last reply Reply Quote 1
        Sneaker75 @Pittini last edited by
        @pittini
          "type": "state",
          "common": {
            "type": "number",
            "role": "value",
            "read": true,
            "write": false,
            "min": 0,
            "max": 1,
            "name": "KG Straße (Batterie)",
            "states": "0:Leer;1:Okay",
            "icon": "/icons/4.png",
            "custom": {
              "linkeddevices.0": {
                "enabled": true,
                "number_unit": "",
                "linkedId": "Batterie.ÖM Keller Straße",
                "name": "ÖM Keller Straße",
                "role": "",
                "mergeSettingsOnRestart": false,
                "expertSettings": false,
                "number_convertTo": "",
                "number_maxDecimal": "",
                "number_min": "",
                "number_max": "",
                "number_calculation": "",
                "number_calculation_readOnly": "",
                "number_to_boolean_condition": "",
                "number_to_boolean_value_true": "",
                "number_to_boolean_value_false": "",
                "number_to_string_condition": "",
                "number_to_duration_convert_seconds": "",
                "number_to_duration_format": "",
                "number_to_datetime_convert_seconds": "",
                "number_to_datetime_format": "",
                "number_to_multi_condition": "",
                "boolean_convertTo": "",
                "boolean_to_string_value_true": "",
                "boolean_to_string_value_false": "",
                "string_convertTo": "",
                "string_prefix": "",
                "string_suffix": "",
                "string_to_boolean_value_true": "",
                "string_to_boolean_value_false": "",
                "string_to_number_unit": "",
                "string_to_number_maxDecimal": "",
                "string_to_number_calculation": "",
                "string_to_number_calculation_readOnly": "",
                "string_to_duration_format": "",
                "string_to_datetime_parser": "",
                "string_to_datetime_format": ""
          "native": {},
          "from": "system.adapter.lupusec.0",
          "user": "system.user.admin",
          "ts": 1583968824300,
          "_id": "lupusec.0.devices.RF:04a40010.battery_ok",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
        • N
          Nas007 last edited by Nas007
          @Pittini erst mal vielen Dank für die tolle Arbeit.
          ich habe es soweit zum laufen bekommen, nur habe ich zwei Fragen:
          1. Wofür sind die Funktion DeadCheck?
          2. Ich Versuche die bsp. Visu einzufügen und bekomme immer folgende Meldung
          Mein Vorgehen:
          • Inhalt von hier kopiert: https://github.com/Pittini/iobroker-Batterienauswertung/blob/master/viswidgets.txt
          • in den Viseditor --> View importieren
          • obigen Part eingefügt
          • und dann kommt die Fehlermeldung
          Mit der Vis an sich kenne ich mich leider noch nicht gut aus. Wahrscheinlich ist das ein dummer Fehler.
          Achja ich nutze
          • Rasp 4
          • alle Adapter aktuell
          • Zigbee: Deconz
          • Node.js v12.21.0
          • NPM 6.14.11
          Vielen Dank schon mal und Gruß!
            Sneaker75 @Nas007 last edited by Sneaker75
            @Nas007
            1. Damit kannst Du prüfen, ob ein Sensor tot ist. Wenn er ausfällt, kann er seinen Status nicht mehr senden, also nicht rufen „Hey, ich bin gerade ausgefallen“. Darum prüft der Datenpunkt, der für die Dead-Funktion gewählt wurde, wann er zuletzt aktualisiert wurde. Ist die definierte Zeitspanne überschritten, wird der Sensor als tot markiert.
            2. Nicht als Vis importieren, sondern als Widget.
              @pittini said in [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe:
              Hey Pittini. Konntest Du Dir das schon ansehen?
              • Dominik F.
                Dominik F. @Pittini last edited by
                @pittini
                Ich bekomme momentan eine Pushnachricht, dass bei dem im Bild unter Info gekennzeichneten Sensor die Batteriespannung unter Limit sei. Im Bild ist jedoch zu erkennen, dass der nicht unter Limit ist. Das was das Script anzeigt ist alles richtig, hab ich soweit überprüft, die Frage ist nun warum bekomm ich die Meldung das die Batteriespannung unter Limit ist?
                  canim @Dominik F. last edited by
                  @dominik-f der Entwickler wollte sein Script noch Anpassen, das unterm Limit < erst die Meldung kommt. <=
                  Dominik F. 1 Reply Last reply Reply Quote 0
                  • Dominik F.
                    Dominik F. @canim last edited by
                    @canim
                    Okay super. Ich hatte in Erinnerung das es ein Problem gab wenn U ist = U Limit ist und dann die Meldung fälschlicherweise kommt.
                      ChrisXY last edited by
                      Hm hab paar Homematic Geräte hinzugefügt ( Zigbee keine Probleme ) Die HM Geräte tauchen ALLE nicht auf nirgendwo. Im Script hab ich folgende Fehler:
                      20:04:08.621	info	javascript.0 (12421) script.js.common.batteriecheck: Reaching MakeTable
                      20:04:08.623	error	javascript.0 (12421) at MakeTable (script.js.common.batteriecheck:557:81)
                      20:04:08.623	error	javascript.0 (12421) at CheckDeadBatt (script.js.common.batteriecheck:351:13)
                      20:04:08.623	error	javascript.0 (12421) at main (script.js.common.batteriecheck:235:5)
                      20:04:08.623	error	javascript.0 (12421) at Object.<anonymous> (script.js.common.batteriecheck:106:13)
                      Im Log:
                      javascript.0
                      2021-05-06 20:06:45.712	error	at processImmediate (internal/timers.js:463:21)
                      javascript.0
                      2021-05-06 20:06:45.712	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1976:38)
                      javascript.0
                      2021-05-06 20:06:45.712	error	at Object.<anonymous> (script.js.common.batteriecheck:106:13)
                      javascript.0
                      2021-05-06 20:06:45.712	error	at main (script.js.common.batteriecheck:235:5)
                      javascript.0
                      2021-05-06 20:06:45.712	error	at CheckDeadBatt (script.js.common.batteriecheck:351:13)
                      javascript.0
                      2021-05-06 20:06:45.712	error	at MakeTable (script.js.common.batteriecheck:557:81)
                      javascript.0
                      2021-05-06 20:06:45.711	error	Error in callback: TypeError: Cannot read property 'toFixed' of undefined
                        Pittini Developer @ChrisXY last edited by
                        @chrisxy Zeig mal nen Screenshot der Objektliste wo ich die Zuweisug zu den HM Geräten seh. Und nen Log bei im Skript aktiviertem logging.
                          @pittini hi das Log war aktiv sind die ersten meldungen.
                          • Dominik F.
                            Dominik F. @ChrisXY last edited by
                            @chrisxy
                            Du hast keine Räume definiert
                            C 1 Reply Last reply Reply Quote 1
                              ChrisXY @Dominik F. last edited by
                              @dominik-f ja nutze ich nie auch bei Zigbee nicht da gehts aber hm
                                @chrisxy sagte in [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe:
                                1. Halt Dich an die Anweisung bzgl. der Räume oder lass es, gibt jedenfalls keinen Support wenn nicht.
                                2. Battery State hat nen null Wert, was soll das Skript damit anfangen? Gibts nicht wenigstens, wie bei den meisten HM Geräten nen lowbat Datenpunkt? Dann nimm den.
                                  ChrisXY @Pittini last edited by
                                  @pittini sorry hab nicht lang genug gewartet für den Screen da steht 3,2
                                  Hab mir noch kein Plan mit den Räumen gemacht. Zigbee hat auch ohne Raum geklappt deswegen für mich unnötig. Das würde die Anzeige im bis auch zu lang machen. Hab das rooms schon raus gemacht für Telegramm und vis. Aber hab zum Test das Original 1:1 am laufen. Versteh das nicht wieso es da zu Fehlern kommt. Aber Werd ich die Räume wohl Mal zuweisen müssen.
                                  • Dominik F.
                                    @chrisxy
                                    Das Skript braucht einfach die Zuweisung der Räume weil es dementsprechend programmiert ist, daher kommt es dann zu Fehlern.
                                    Es ist schon wichtig, dass du dich an die Anweisungen von Pittini hälst. Falls es durch Zufall vorher funktioniert hat, dann war das wirklich nur Zufall. 99% der Fehler oder Probleme die hier auftauchen haben meistens damit zu tun, dass die Anleitung nicht befolgt wird.
                                      Torsten_MG last edited by
                                      Irgendwie bin ich zu blöd den Adapter zu installieren.
                                      ich benutze folgende Url
                                      https://github.com/Pittini/iobroker-Batterienauswertung.git
                                      mit der Katze.
                                      Während der Installation bekomme ich immer folgende log
                                      $ ./iobroker url "https://github.com/Pittini/iobroker-Batterienauswertung.git" --debug
                                      install Pittini/iobroker-Batterienauswertung#f8762c8c34b9ec20e5e283c910fabcf32fbbb786
                                      NPM version: 6.14.12
                                      npm install Pittini/iobroker-Batterienauswertung#f8762c8c34b9ec20e5e283c910fabcf32fbbb786 --loglevel error --prefix "/opt/iobroker" (System call)
                                      npm ERR! premature close
                                      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-05-14T16_49_52_483Z-debug.log
                                      ERROR: host.raspberrypi Cannot install Pittini/iobroker-Batterienauswertung#f8762c8c34b9ec20e5e283c910fabcf32fbbb786: 1
                                      ERROR: process exited with code 25
                                        sigi234 Forum Testing Most Active @Torsten_MG last edited by
                                        @torsten_mg sagte in [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe:
                                        Das ist ein Skript und kein Adapter!
                                          Torsten_MG @sigi234 last edited by Torsten_MG
                                          @sigi234
                                          ok, das habe ich auch probiert und kriege das auch irgendwie nicht hin.
                                          Ich habe die zip runtergeladen, dann bei Scripte => oben bei den 3 Punkten auf scripts importieren geklickt.
                                          Anschließend hatte ich folgendes Script:
                                              "compileOnSave": true,
                                              "compilerOptions": {
                                                  // do not compile anything, this file is just to configure type checking
                                                  "noEmit": true,
                                                  // check JS files
                                                  "allowJs": true,
                                                  "checkJs": true,
                                                  "module": "commonjs",
                                                  "moduleResolution": "node",
                                                  // this is necessary for the automatic typing of the adapter config
                                                  "resolveJsonModule": true,
                                                  // Set this to false if you want to disable the very strict rules (not recommended)
                                                  "strict": true,
                                                  // Or enable some of those features for more fine-grained control
                                                  // "strictNullChecks": true,
                                                  // "strictPropertyInitialization": true,
                                                  // "strictBindCallApply": true,
                                                  "noImplicitAny": false,
                                                  "noUnusedLocals": true,
                                                  "noUnusedParameters": true,
                                                  // Consider targetting es2017 or higher if you require the new NodeJS 8+ features
                                                  "target": "es2017",
                                              "include": [
                                                  "**/*.js",
                                                  "**/*.d.ts"
                                              "exclude": [
                                                  "node_modules/**",
                                                  "admin/**"
                                          und da komme ich dann nicht weiter 😕
                                          ich bekomme folgende Fehlermeldung
                                          14.5.2021, 19:23:15.964	[info ]: javascript.0 (3186) Stop script script.js.iobroker-Batterienauswertung-master.tsconfig
                                          14.5.2021, 19:23:15.984	[info ]: javascript.0 (3186) Start javascript script.js.iobroker-Batterienauswertung-master.tsconfig
                                          14.5.2021, 19:23:15.991	[error]: javascript.0 (3186) script.js.iobroker-Batterienauswertung-master.tsconfig compile failed:
                                          at script.js.iobroker-Batterienauswertung-master.tsconfig:2
                                          • Negalein
                                            Negalein Global Moderator @Torsten_MG last edited by Negalein
                                            Nein, nicht eine Zip runterladen.
                                            Die .js anklicken und dann den Inhalt kopieren und im Script-Adapter als neues JS anlegen, Text einfügen und an dich anpassen.
                                            Pittini iobroker-Batterienauswertung  Überprüft Batteriespannungen beliebig vieler Geräte anhand vorgegebenem LowLimit.png iobroker-Batterienauswertung batterienauswertung-V1.7.3.js at master · Pittini iobroker-Batterienauswertung.png
                                            javascript monitoring template
                                            81
                                            581
                                            116597
