    4. eqiva Türschloßantrieb
    • U
      UwesSmartHome last edited by UwesSmartHome
      code_text
      ```pi@RaspiMaster:~ $ keyble-registeruser -n 7 -q M001A22098C33K7E57A65F118662D9E3B425DA66D6ED2FNEQ1058982
      internal/modules/cjs/loader.js:1057
        return process.dlopen(module, path.toNamespacedPath(filename));
      Error: The module '/usr/lib/node_modules/keyble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
          at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
          at Module.load (internal/modules/cjs/loader.js:863:32)
          at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          at Module.require (internal/modules/cjs/loader.js:887:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at Object.<anonymous> (/usr/lib/node_modules/keyble/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)
          at Module._compile (internal/modules/cjs/loader.js:999:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          at Function.Module._load (internal/modules/cjs/loader.js:708:14)```
      code_text
        Thomas Braun Most Active @UwesSmartHome last edited by Thomas Braun
        @uwessmarthome
        Node sauber?
        Konsolenmeldungen bitte nicht als Screenshot sondern als Text in CodeTags ins Forum.
        • U
          UwesSmartHome @Thomas Braun last edited by UwesSmartHome
          codpi@RaspiMaster:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/nodejs
          v12.21.0
          /usr/bin/node
          v12.21.0
          /usr/bin/npm
          6.14.12
          nodejs:
            Installiert:           12.21.0-1nodesource1
            Installationskandidat: 12.21.0-1nodesource1
            Versionstabelle:
           *** 12.21.0-1nodesource1 100
                  100 /var/lib/dpkg/status
               10.24.0-1nodesource1 500
                  500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u1 500
          e_text
          Thomas Braun U 2 Replies Last reply Reply Quote 0
            @uwessmarthome
            Bitte CodeTags verwenden.
            Und das System auf Stand halten.
            sudo apt update
            sudo apt dist-upgrade
            sudo reboot
            Für node12 ist keine Paketquelle / kein Repository angelegt. Lies den Kram zu node aus meiner Signatur.
            • U
              UwesSmartHome @UwesSmartHome last edited by UwesSmartHome
              @uwessmarthome
              Hab es heute nochmal versucht, leider erfolglos. Diese Fehlermeldung bleibt. Node Modul Version falsch?
              • U
                 keyble-registeruser -n 7 -q M001A22098C33K7E57A65F11xxxxxxx        425DA66D6ED2FNEQ1058982
                Error: The module '/usr/lib/node_modules/keyble/node_modules/@abandonware/blueto        oth-hci-socket/lib/binding/bluetooth_hci_socket.node'
                    at Object.<anonymous> (/usr/lib/node_modules/keyble/node_modules/@abandonwar        e/bluetooth-hci-socket/lib/native.js:6:15)
                • U
                  /usr/lib/node_modules/keyble/node_modules $ sudo npm rebuild
                  > @abandonware/noble@1.9.2-11 install /usr/lib/node_modules/keyble/node_modules/@abandonware/noble
                  > node-gyp rebuild
                  gyp ERR! clean error
                  gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                  gyp ERR! System Linux 5.10.17-v7+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /usr/lib/node_modules/keyble/node_modules/@abandonware/noble
                  gyp ERR! node -v v12.22.1
                  gyp ERR! node-gyp -v v5.1.0
                  gyp ERR! not ok
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! @abandonware/noble@1.9.2-11 install: `node-gyp rebuild`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the @abandonware/noble@1.9.2-11 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /root/.npm/_logs/2021-04-11T10_57_26_697Z-debug.log
                    @uwessmarthome Nicht als root rumhampeln, npm nicht in Verbindung mit sudo einsetzen.
                    U B 2 Replies Last reply Reply Quote 0
                    • U
                      @thomas-braun ```
                      pi@Master:~ $ keyble-registeruser -n Use -q M001A22098DF0K676641D845A53AB9481166DDAF024C9ANEQ1058450
                      Press and hold "Unlock" button until the yellow light flashes in order to enter pairing mode
                      Registering user on Smart Lock with address "00:xx:22:09:8d:xx", card key "676641d845a53aXXXXXXddaf024c9a" and serial "NEQ1058450"...
                      Habe es auf dem einem System geschafft die Fehlermeldungen kommen nicht mehr. Leider ist eine Anmeldung nicht möglich, es bleibt immer stehen nachdem der Button am Türschloss gedrückt wurde. Die QR Daten habe ich schon x-mal geprüft. Die Bluetooth Adresse ebenso, auch das Schloss ganz nahe am Raspberry bringt keine Anmeldung zustande. Noch eine Idee?
                        bambo587 @Thomas Braun last edited by
                        habe das gleich problem wie @UwesSmartHome.
                        Da fehlt die halbe Ausgabe.
                        System neu geupdatet, sogar mit Node 14 ausprobiert, wg. Fehler wieder bei node 12.
                        Was fehlt da??
                          Thomas Braun Most Active @bambo587 last edited by
                          @bambo587 sagte in eqiva Türschloßantrieb:
                          Was fehlt da??
                          Meldungen aus deinem System fehlen da...
                          • V
                            Vocaris last edited by
                            ich überlege gerade, ob ich das Türschloss von Homematic kaufen soll oder das günstigere von eqiva.
                            Der eqiva hat ja nur BT. Scheint also mit einem ioB zu gehen, wenn dieser BT hat. Zumindest verstehe ich das hier so.
                            Kann man es auch direkt mit Alexa verbinden?
                            Was meint Ihr so? Besser HM oder Eqiva.
                            PS: Wenn der ioB aus wäre (z.B. abgestürzt) könnte ich das Schloss von HM ja nicht öffnen. Bei Eqiva könnte ich immer noch per BT öffnen. Aber ist BT ggf. einfacher zu "knacken"?
                              JayP79 @Elzershark last edited by
                              @elzershark bei mir kommt nach "Registering user on Smart Lock wird address... " keine Rückmeldung mit username_1 etc.
                              Hat jemand einen Tipp für mich?
                              Viele Grüße
                              JP
                                JayP79 @JayP79 last edited by
                                Jetzt bekomme ich immer die Meldung: TypeError: Cannot read properties of undefined (reading 'get_discovered_characteristic')
                                at /usr/lib/node_modules/keyble/keyble.js:878:56
                                • Schaxxe
                                  Schaxxe last edited by
                                  Das Ding wird scheinbar nicht wirklich weiterentwickelt und gefixt oder?
                                  Ich dachte, ich nutze einen BT Dongel in einer VM unter Proxmox, bekomme aber die Selbe Meldung wie JayP79 und kann keinen Benutzer anlernen.
                                  Wenn ich einen alten Pi neben dran halte, bekomme ich User Key und einen Benutzer angelegt, dann kann ich in der eigens dafür angelegten VM genau EINMAL erfolgreich den Status des Schlosses abfragen, dann geht nie wieder irgendein Befehl (VM neu aufsetzen, dann gehts wieder, genau einmal)...Das ist dann die Antwort:
                                  Error: TypeError: Cannot read properties of undefined (reading 'get_discovered_characteristic')
                                  Ist die "Lösung" wirklich einen Pi mit Bluetooth neben das Schloss zu nageln, obwohl mein Proxmox mit BT nur ca 2m weiter hinten steht? Wenn ja, nicht sehr sexy
                                    Homoran Global Moderator Administrators @Schaxxe last edited by
                                    @schaxxe sagte in eqiva Türschloßantrieb:
                                    Dieses bitte auf Github beim Entwickler nachfragen.
                                    Das ist kein ioBroker-Projekt
                                    Sieht aber so aus, als ob die letzte Aktivität 3 Jahre her ist
                                    • Marc_el_K
                                      Marc_el_K last edited by
                                      Falls auch noch jemand Interessa dem Github Projekt mittels ESP32 hat, würde ich mich freuen, wenn ihr den Beitrag mit +1 pusht 🙂
                                      https://forum.iobroker.net/topic/68563/anfrage-für-programmier-code-anpassung-gesucht
                                      • DJMarc75
                                        DJMarc75 @Marc_el_K last edited by
                                        @marc_el_k sagte in eqiva Türschloßantrieb:
                                        den Beitrag hier im Forum oder Dein Issue auf Github ?
                                        Marc_el_K 1 Reply Last reply Reply Quote 0
                                        • Marc_el_K
                                          Marc_el_K @DJMarc75 last edited by
                                          @djmarc75 diesen hier: https://forum.iobroker.net/topic/68563/anfrage-für-programmier-code-anpassung-gesucht
                                            rza @Elzershark last edited by
                                            @elzershark said in eqiva Türschloßantrieb:
                                            Eintragen in den Adapter. Fertig
                                            Hallo @Elzershark, vielen lieben Dank schon mal für deine Erläuterungen.
                                            Magst du einmal sagen in welchen Adapter die Daten eingetragen werden müssen.
                                            Der Adapter in IOB hat ja "noch" keine klassischen Textboxen.
                                            26
                                            4237
