    4. ZigBee neue Version 1.5.x
      A Former User @BigMike71 last edited by
      @bigmike71
      Hier auch...
        disaster123 last edited by
        @Asgothian seit 1.5.X bekomme ich sehr oft folgenden Fehler:
        zigbee.0	2021-05-06 16:20:06.076	error	(448) Error: Error while opening serialport 'Error: Error: Input/output error setting custom baud rate of 38400' at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deco
        zigbee.0	2021-05-06 16:20:06.076	error	(448) Failed to start Zigbee
        dann folgt:
        zigbee.0	2021-05-06 16:20:30.683	error	(448) Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
        zigbee.0	2021-05-06 16:20:30.683	error	(448) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/d
        zigbee.0	2021-05-06 16:20:30.683	error	(448) unhandled promise rejection: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
        zigbee.0	2021-05-06 16:20:30.682	error	(448) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        und danach startet er in der Regel mit 1.4.4 habe ich das nie gesehen.
        • Asgothian
          Asgothian Developer @disaster123 last edited by
          @disaster123
          Was für Hardware hast du ?
            disaster123 @Asgothian last edited by
            @asgothian conbee 2 usb Stick via qemu / kvm in eine vm und von da in einen docker container mit iobroker
              @asgothian seit heute morgen sieht es alle 2 Stunden so aus:
              zigbee.0	2021-05-07 09:13:07.484	error	(6485) Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
              zigbee.0	2021-05-07 09:13:07.484	error	at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
              zigbee.0	2021-05-07 09:13:07.484	error	at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
              zigbee.0	2021-05-07 09:13:07.484	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:158:45)
              zigbee.0	2021-05-07 09:13:07.484	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
              zigbee.0	2021-05-07 09:13:07.484	error	at new Promise (<anonymous>)
              zigbee.0	2021-05-07 09:13:07.484	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
              zigbee.0	2021-05-07 09:13:07.484	error	at Generator.next (<anonymous>)
              zigbee.0	2021-05-07 09:13:07.484	error	at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:160:28)
              zigbee.0	2021-05-07 09:13:07.484	error	(6485) Error: Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
              zigbee.0	2021-05-07 09:13:07.484	error	(6485) unhandled promise rejection: Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
              zigbee.0	2021-05-07 09:13:07.482	error	(6485) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              Asgothian arteck 2 Replies Last reply Reply Quote -1
              • Tom Son
                Tom Son last edited by
                Langsam frustiert mich das ganze, jetzt mache ich das doofe js update schon zum dritten mal und immer sind alle Geräte in der Zigbee Instanz weg 😞 Muss dann alle wieder koppeln.... Gibt es da keine bessere Lösung?
                Ich glaube ich gehe zurück auf stable 😞 😞
                crunchip amg_666 L 3 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @Tom Son last edited by crunchip
                  @tom-son sagte in ZigBee neue Version 1.5.x:
                  js update
                  welches?
                  nach dem Fehler suchen (log) , oder die shepherd.dp aus dem backup einspielen, dann müssten die Sensoren wieder da sein, ohne neu anzulernen
                  Tom Son 1 Reply Last reply Reply Quote 0
                  • amg_666
                    amg_666 @Tom Son last edited by
                    @tom-son Hm, also bei mir läuft das alles stabil,
                    Node.js: v14.16.1, NPM: 6.14.12 und iobroker 3.3.8
                    admin 5.0.15 und zigbee 1.5.5
                    Das ganze läuft als VM unter Debian auf einem intel nuc mit proxmox
                    Einzig nerviger Punkt ist, dass der zigbee unter "Netzwerkkarte" alle Geräte als nicht verbunden und rot darstellt, das dauert dann zwischen 5 und vielleicht 20 Sekunden und dann stimmt die Karte auch.
                    KEINE "Verluste" von Geräten, KEINE Funktionseinschränkungen
                    Horst Böttcher 1 Reply Last reply Reply Quote 0
                    • Horst Böttcher
                      Horst Böttcher @amg_666 last edited by
                      Hallo der Adapter bleibt bei mir gelb
                      und nix geht mehr
                      Aus den log
                      zigbee.0	2021-05-07 21:55:23.893	error	(6335) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                        luie @Tom Son last edited by luie
                        js update
                        Wie gehst du vor?
                        Bei mir lief das update auf js-controller 3.3.8 ohne Probleme. Ich musste nur nach dem reboot des raspi den zigbee-Adapter 1x stoppen und dann wieder starten.
                        Horst Böttcher Tom Son 2 Replies Last reply Reply Quote 0
                        • Horst Böttcher
                          Horst Böttcher @luie last edited by Horst Böttcher
                          für leicht ist was falsch gelaufen
                          JS update nach anleitung
                          • Asgothian
                            @disaster123 da passt etwas mit der Weiterleitung der seriellen Schnittstelle nicht. Die Meldung
                            No such device or address...
                            Ist da recht eindeutig.
                            A.
                            • Asgothian
                              Asgothian Developer @Horst Böttcher last edited by
                              @horst-böttcher
                              Bitte das komplette log des Start Vorgangs des zigbee Adapters posten, nicht nur eine Zeile.
                              A.
                              • Horst Böttcher
                                Horst Böttcher @Asgothian last edited by
                                @asgothian
                                habe den USB Port gewechselt jetzt sind die Geräte da lassen sich aber nicht schalten
                                Über all steht Disconectet
                                • Tom Son
                                  Tom Son @crunchip last edited by
                                  @crunchip JS 3.3.8
                                  Das mit dem shepherd klingt gut, aber wie geht das? Hasz du bitte eine Anleitung?
                                  • Tom Son
                                    Tom Son @luie last edited by
                                    @luie mache das update über die Konsole wie inder Beschreibung und anschließend mach ich immer einen Reboot, aber nach einem restart des Adapter blieb immer noch alles leer...
                                      arteck Developer Most Active @disaster123 last edited by
                                      @disaster123 multihost ?
                                      • I
                                        io_laurent last edited by
                                        ich habe seit einiger Zeit eine Fehlermeldung im Log, mit welcher ich nichts anfangen kann:
                                        2021-05-08 11:04:04.567 - error: zigbee.0 (5950) Failed to DeviceConfigure.onZigbeeEvent (Error: '404001' has no configure
                                        at Object.getConfigureKey (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/configureKey.js:20:15)
                                        at DeviceConfigure.shouldConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:33:38)
                                        at DeviceConfigure.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:76:22)
                                        at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
                                        at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:14))
                                        Diese Meldung kommt ca. alle 20-60 Sekunden.
                                        Das System läuft ohne irgendwelche Probleme, raspi4, admin 5.0.18, Zigbee 1.5.5, js-controller 3.3.8 (den Fehler gab es aber auch schon vorher, ab 3.3.4 wenn ich richtig erinnere).
                                        Kann da jemand helfen?
                                        Vielen Dank!
                                          Hat irgendjemand eine Idee wie ich die sensivity beim Aqara Neigungssensor ändern kann? Es gibt zwar mit 1.5 ein drop down aber immer wenn ich Versuche dort etwas einzustellen kommt nach einiger Zeit:
                                          (449) Send command to 0x00158d0006896b8d failed with no error code (no response received)
                                          Habe schon versucht Knopf kurz drücken am Sensor oder lang drücken nach dem Absetzen - aber hilft alles nichts.
                                            crunchip Forum Testing Most Active @disaster123 last edited by
                                            @disaster123 hat bei mir bisher auch nicht funktioniert, habe mich damit allerdings nicht weiter beschäftigt
                                            579
                                            113104
