    3. Cloud Dienste
    4. Allgemein Google Home mit Iobroker (gelöst)
    • Marco Willi
      Marco Willi @Thomas Braun last edited by
      2020-11-11 20:45:43.328 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
      2020-11-11 20:45:44.851 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
      2020-11-11 20:45:46.220 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
      2020-11-11 20:45:51.888 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
      2020-11-11 20:45:52.490 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
      2020-11-11 20:45:58.741 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
      2020-11-11 20:46:38.826 - info: host.raspberrypi "system.adapter.iot.0" enabled
      2020-11-11 20:46:38.864 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 25632
      2020-11-11 20:46:40.925 - info: iot.0 (25632) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.iot, node: v12.19.0, js-controller: 3.1.6
      2020-11-11 20:46:40.965 - info: iot.0 (25632) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2020-11-11 20:46:41.560 - info: iot.0 (25632) Connection changed: connect
      2020-11-11 20:46:41.629 - error: iot.0 (25632) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: {"error":"Email not found or URL key not found"}
      2020-11-11 20:46:41.630 - warn: iot.0 (25632) [GHOME] Invalid URL Pro key. Status auto-update is disabled you can set states but receive states only manually: {"error":"Email not found or URL key not found"}
      2020-11-11 20:46:47.353 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-11-11 20:46:47.354 - error: iot.0 (25632) unhandled promise rejection: Test is not defined
      2020-11-11 20:46:47.359 - error: iot.0 (25632) ReferenceError: Test is not defined
      at eval (eval at (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2920:62), :1:1)
      at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2921:63
      at Array.forEach ()
      at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2917:43
      at Array.forEach ()
      at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2825:61
      at Array.forEach ()
      at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2802:37
      at Array.forEach ()
      at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2799:35
      2020-11-11 20:46:47.375 - info: iot.0 (25632) terminating
      2020-11-11 20:46:47.377 - info: iot.0 (25632) Terminated (NO_ERROR): Without reason
      2020-11-11 20:46:47.407 - info: iot.0 (25632) Connection changed: disconnect
      2020-11-11 20:46:47.408 - info: iot.0 (25632) Connection lost
      2020-11-11 20:46:47.927 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2020-11-11 20:46:47.928 - error: host.raspberrypi Caught by controller[1]: ReferenceError: Test is not defined
      2020-11-11 20:46:47.929 - error: host.raspberrypi Caught by controller[1]: at eval (eval at (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2920:62), :1:1)
      2020-11-11 20:46:47.929 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2921:63
      2020-11-11 20:46:47.930 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
      2020-11-11 20:46:47.930 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2917:43
      2020-11-11 20:46:47.931 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
      2020-11-11 20:46:47.931 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2825:61
      2020-11-11 20:46:47.932 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2802:37
      2020-11-11 20:46:47.932 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
      2020-11-11 20:46:47.933 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2799:35
      2020-11-11 20:46:47.933 - info: host.raspberrypi instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
        Thomas Braun Most Active @Marco Willi last edited by
        @Marco-Willi
        Marco Willi 1 Reply Last reply Reply Quote 0
        • Marco Willi
          @Thomas-Braun jap, das habe ich schon ein paar mal gelesen und an den Kopf bekommen. Trotz Mailadressenwechsel und Neuregistrierung immer die gleiche Meldung. Was muss ich tun?
          Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
            @Marco-Willi
            Hab kein iot pro, daher musste ich da auch noch nie was machen.
            • Marco Willi
              @Thomas-Braun soll ich es mal mit free versuchen? Meinste das könnte klappen? Ich will auch keine Lizenz für meine 2 Anfragen am Tag kaufen.
              • Marco Willi
                Marco Willi @Marco Willi last edited by
                also mit free account bleibt der adapter auf gelb
                • Meister Mopper
                  Meister Mopper @Marco Willi last edited by
                  @Marco-Willi sagte in Allgemein Google Home mit Iobroker:
                  Da steht ja, dass Du die certs löschen sollst. Hast Du das getan, mal auf den Mülleimer (s. Bild) geklickt?
                  Marco Willi 1 Reply Last reply Reply Quote 1
                  • Marco Willi
                    Marco Willi @Meister Mopper last edited by
                    @Meister-Mopper neiiin hab ich noch nicht. Fürs erste setzt ich das Projekt mal einer Pause aus. Nächste Woche nochmal.
                    Müsste ich dann was neues anfordern?
                    • Meister Mopper
                      @Marco-Willi Kostet ja nichts!
                      • Marco Willi
                        @meister-mopper
                        Hi Leute. Habe es jetzt in der zwischenzeit hinbekommen. Lag eher bei einem Verständnisproblem denke ich.
                        Alles nochmals auf. Sämtliche Verknüpfungen aufgehoben.
                        Alles neu registiert und wieder verknüpft. Ging nachher relativ flott.
                        Dann beim Broker die Sensoren die ich abfragen wollte reingeknallt und als Thermostat gekennzeichnet.
                        „Hey Google aktualisiere Geräte“ dann war iobroker auch mit von der Party und ich konnte die Geräte einem Raum zuordnen. Jetzt klappt es auch mit abfragen der Temps.
                        google home iot
                        2130
