    5. [gelöst]Trockenlaufschutz, Problem mit Blockly
    • BBTown
      BBTown @nole last edited by
      @nole
      dein innerer "falls" Block wird nie erreicht, da Du fragst ob der Wert >= 100 ist, kann er innerhalb dieser Frage ja niemals <=50 sein
      • BBTown
        BBTown @nole last edited by BBTown
        @nole
        das könnte passen
         <variables>
           <variable type="timeout" id="timeout3">timeout3</variable>
         </variables>
         <block type="on_ext" id=")3Y6O)OSZ6,a.eId9_([" x="-488" y="138">
           <value name="OID0">
             <shadow type="field_oid" id="FB}qA2j)SArn`ar=BQ8z">
               <field name="oid">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field>
             <block type="controls_if" id="nT8{B{T^As}6|P1eFdAp">
                 <block type="logic_operation" id="k/5vYdt)FO5#4fIMa~m;" inline="false">
                   <field name="OP">AND</field>
                     <block type="logic_compare" id="h=ll3)j0~lH*]vID@v{h">
                       <field name="OP">GTE</field>
                         <block type="on_source" id="u:72U[-3Dnb8^3xE,|!!">
                         <block type="math_number" id="QWMd~%R.#BvSN.-Jr7|S">
                           <field name="NUM">100</field>
                     <block type="logic_compare" id="{T1t5z14z,+4|DC]gOXz">
                       <field name="OP">LT</field>
                         <block type="on_source" id="=QYK}e_eO)R!UP9V$lM^">
                           <field name="ATTR">oldState.val</field>
                         <block type="math_number" id="hLUSUOYJL$qWXsN7kTk8">
                 <block type="timeouts_cleartimeout" id="U_%ugF^L^YUcG@wP=]~Z">
                   <field name="NAME">timeout3</field>
                     <block type="control" id="hZTA=BSjCVV{]?(0pVgY">
                       <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.POWER</field>
                         <block type="logic_boolean" id="R||h%3X{{l}e4p`%Yawz">
                         <block type="timeouts_settimeout" id="|y|12`S1gi{?f|+:!d87">
                           <field name="DELAY">30</field>
                             <block type="control" id="]:Q/hgD*3Ye$XrhiCKVK">
                                 <block type="logic_boolean" id="]qeVb0?p3y!^dSP8T!{!">
               <value name="IF1">
                 <block type="logic_operation" id="!/F3qNm$R2Q]m/jo|f#T" inline="false">
                     <block type="logic_compare" id="iHA4@^BN{s/[}$=sq31n">
                       <field name="OP">LTE</field>
                         <block type="on_source" id="gQBF^?(7;hKwq*ro`;LK">
                         <block type="math_number" id="E1Co9VoP0Z]U].V}:dk6">
                           <field name="NUM">50</field>
                     <block type="logic_compare" id="2[[fJeqHxkcfP[F^]I-Q">
                       <field name="OP">GT</field>
                         <block type="on_source" id="f5IDFVCeLD}U6K[_XEG@">
                         <block type="math_number" id="2k,M4Zr}0C_#uR%MuF|Q">
               <statement name="DO1">
                 <block type="timeouts_cleartimeout" id="s_tu+G)JzfXKRo!,-i?j">
                     <block type="control" id="dYN%$E|/?la90IKRz{*w">
                         <block type="logic_boolean" id="lU?:V,sk#5e#Zs@){!|m">
                 <block type="debug" id="jv2kcn+O#/wer{(+o+DW">
                   <value name="TEXT">
                     <shadow type="text">
                     <block type="text_join" id="FXin0|uc^i=Wm;0R-Jtj">
                       <value name="ADD0">
                         <block type="text" id="Z##h?{^2;N/L6AAv4~..">
                           <field name="TEXT">Watt:</field>
                       <value name="ADD1">
                         <block type="on_source" id="t@LBx#Y!8Fv5({,pHM[,">
        [Edit]
        Nun bekommst Du allerdings bei jeder Temperatur-Änderung eine Meldung.
        Womöglich ist es sinnvoller die Meldungen auch innerhalb der falls Blöcke zu platzieren, je nachdem wann Du welche Meldung haben möchtest
        • BBTown
          @nole
          Mit Beispielmeldungen
          • N
            nole @BBTown last edited by
            @bbtown Wenn ich dein Skript importiere habe ich da "Ausführen timeout4" drin, die anderen beiden sind timeout3.
            • BBTown
              @nole ich habe den Timeout gar nicht angefasst, sondern von deinem Import übernommen und nur den Baustein einmal dupliziert. Umbenennen kannst Du ihn wie Du willst. Der Timeout muss nur zum Timer passen
              [EDIT] benutze doch mal die Auswahlliste des Timeout-Bausteins (DropDown) und wähle die korrekte Bezeichnung aus
              N 2 Replies Last reply Reply Quote 0
              • N
                @bbtown Umbenennen geht nicht, ändert sich immer wieder auf 4
                • N
                  @bbtown kommt das durch das kopieren des Bausteins?
                  BBTown N 2 Replies Last reply Reply Quote 0
                  • BBTown
                    @nole benutze doch mal die Auswahlliste des Timeout-Bausteins (DropDown) und wähle die korrekte Bezeichnung aus
                    • N
                      nole @nole last edited by
                      @nole Der timeout 4 hat komischerweise keine Auswahlliste, kann ich die anderen beiden einfach auf 4 ändern?
                      BBTown 2 Replies Last reply Reply Quote 0
                      • BBTown
                        @nole dann lösche den Baustein und füge ihn neu hinzu
                        • N
                          @bbtown dann ändert sich dieser timeout automatisch von der eingegebenen 3 auf 5
                          BBTown J 2 Replies Last reply Reply Quote 0
                          • BBTown
                            @nole Du kannst die Bezeichnung des Timers ändern und die neue Bezeichnung steht danach in den Auswahllisten der Timeout Bausteine zur Verfügung
                            • N
                              @bbtown ich habe jetzt die beiden anderen auf 4 geändert, das hat geklappt.
                              • BBTown
                                @nole dann kann ich dir nicht helfen.
                                Du hast jetzt eine Vorlage an der Du dich orientieren kannst
                                Entweder Du fängst ein neues Script an und versucht erneut den Import, oder aber Du legst ein neues Script manuell mit den Bausteinen gemäß Vorlage an.
                                  Jan1 @nole last edited by
                                  @nole
                                  Das sieht ja schon ganz gut aus hier 😉
                                  • N
                                    nole @Jan1 last edited by
                                    @jan1 was sieht gut aus?
                                    • N
                                      @jan1 Das skript sieht bei mir jetzt so aus:
                                        <variables>
                                          <variable type="timeout" id="timeout4">timeout4</variable>
                                        </variables>
                                        <block type="on_ext" id="FB^,o-|.DkV*l1Zpw1ev" x="-487" y="88">
                                          <value name="OID0">
                                            <shadow type="field_oid" id="w]B4izL8Xi6Xis[a47]}">
                                            <block type="controls_if" id="o9}:IIEo};jIF72b9AA.">
                                                    <block type="logic_compare" id="ViV`%UQ}k~UPs7,j-ryV">
                                                        <block type="math_number" id="!{rp568)Xa_3X^/P-X67">
                                                  <field name="NAME">timeout4</field>
                                                        <block type="timeouts_settimeout" id=".o~uvJbWt^KQ`oiI!e$!">
                                                            <block type="control" id="4S}(|m-Kt)y5P9txPZ+I">
        <block type="logic_boolean" id="}wd]{cXQ@x{`KvgI26LW">
                                              <value name="IF1">
                                                <block type="timeouts_cleartimeout" id="cL@Uuw#K=7Oj=lJL/W:h">
                                                <block type="debug" id=",qorWlCkGFLb!+WM7/rO">
                                                  <value name="TEXT">
                                                    <block type="text_join" id="8h9QE+{dve}o}{xFz4^/">
                                                      <value name="ADD0">
                                                        <block type="text" id="^^vC/IAZ$YnpMiFFn.nC">
                                                      <value name="ADD1">
                                                        <block type="on_source" id="-bW!=3`GYzyDgu_1}k0G">
                                        <block type="on_ext" id=")3Y6O)OSZ6,a.eId9_([" disabled="true" x="-487" y="688">
                                          <value name="OID0">
                                                    <block type="get_value" id="prv]M@]WP)O8k`WxQv,M">
                                                      <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field>
                                                <block type="controls_if" id=";N~?jZO,:^+(B6c4+e.p">
                                                    <block type="logic_compare" id="nLGp=iM$L~IydiZi8!Z?">
                                                        <block type="get_value" id="#X;Nd8faxS1r?ibN,9Ur">
                                                        <block type="math_number" id="3L+Hx`ZZZ[6;bcStTgXv">
                                                  <value name="TEXT">
                                                      <value name="ADD0">
                                                      <value name="ADD1">
                                        @nole
                                        Das Blockly.
                                        Wurde auch etwas optimierte und wie man timeouts verwendet siehst ja. Es sollte immer ein stopp des timeouts davor erfolgen um sicher zu stellen, dass nicht genau dieser schon läuft, sonst passt die ein gestellte Zeit nie und man wundert sich, was exakt bei Dir zu Beginn der Grund Deiner Verwirrung war 😉
                                        • N
                                          @jan1 ich arbeite mich gerade gedanklich durch das Blockly, ich habe dank euch allen heute einiges wichtige dazu gelernt. Vielen Dank an euch alle. Wenn alles läuft erfahrt ihr das natürlich. Ich gehe dann jetzt in die Testphase über.
                                          • N
                                            @jan1 irgendwas stimmt noch nicht, ich weiß nur noch nicht was. Schaltet immer noch ohne erkennbaren Grund aus. Ich probiere den Fehler zu finden.
                                            6711
