    5. [gelöst]Trockenlaufschutz, Problem mit Blockly
      Jan1 @nole last edited by
      @nole
      Das sieht ja schon ganz gut aus hier 😉
      N 2 Replies Last reply Reply Quote 0
      • N
        nole @Jan1 last edited by
        @jan1 was sieht gut aus?
        • N
          @jan1 Das skript sieht bei mir jetzt so aus:
            <variables>
              <variable type="timeout" id="timeout3">timeout3</variable>
              <variable type="timeout" id="timeout4">timeout4</variable>
            </variables>
            <block type="on_ext" id="FB^,o-|.DkV*l1Zpw1ev" x="-487" y="88">
              <value name="OID0">
                <shadow type="field_oid" id="w]B4izL8Xi6Xis[a47]}">
                  <field name="oid">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field>
                <block type="controls_if" id="o9}:IIEo};jIF72b9AA.">
                    <block type="logic_operation" id="k/5vYdt)FO5#4fIMa~m;" inline="false">
                      <field name="OP">AND</field>
                        <block type="logic_compare" id="ViV`%UQ}k~UPs7,j-ryV">
                          <field name="OP">GTE</field>
                            <block type="on_source" id="u:72U[-3Dnb8^3xE,|!!">
                            <block type="math_number" id="!{rp568)Xa_3X^/P-X67">
                              <field name="NUM">100</field>
                        <block type="logic_compare" id="{T1t5z14z,+4|DC]gOXz">
                          <field name="OP">LT</field>
                            <block type="on_source" id="=QYK}e_eO)R!UP9V$lM^">
                              <field name="ATTR">oldState.val</field>
                            <block type="math_number" id="hLUSUOYJL$qWXsN7kTk8">
                    <block type="timeouts_cleartimeout" id="U_%ugF^L^YUcG@wP=]~Z">
                      <field name="NAME">timeout4</field>
                        <block type="control" id="hZTA=BSjCVV{]?(0pVgY">
                          <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.POWER</field>
                            <block type="logic_boolean" id="R||h%3X{{l}e4p`%Yawz">
                            <block type="timeouts_settimeout" id=".o~uvJbWt^KQ`oiI!e$!">
                              <field name="DELAY">30</field>
                                <block type="control" id="4S}(|m-Kt)y5P9txPZ+I">
                                    <block type="logic_boolean" id="}wd]{cXQ@x{`KvgI26LW">
                  <value name="IF1">
                    <block type="logic_operation" id="!/F3qNm$R2Q]m/jo|f#T" inline="false">
                        <block type="logic_compare" id="iHA4@^BN{s/[}$=sq31n">
                          <field name="OP">LTE</field>
                            <block type="on_source" id="gQBF^?(7;hKwq*ro`;LK">
                            <block type="math_number" id="E1Co9VoP0Z]U].V}:dk6">
                              <field name="NUM">50</field>
                        <block type="logic_compare" id="2[[fJeqHxkcfP[F^]I-Q">
                          <field name="OP">GT</field>
                            <block type="on_source" id="f5IDFVCeLD}U6K[_XEG@">
                            <block type="math_number" id="2k,M4Zr}0C_#uR%MuF|Q">
                  <statement name="DO1">
                    <block type="timeouts_cleartimeout" id="cL@Uuw#K=7Oj=lJL/W:h">
                        <block type="control" id="dYN%$E|/?la90IKRz{*w">
                            <block type="logic_boolean" id="lU?:V,sk#5e#Zs@){!|m">
                    <block type="debug" id=",qorWlCkGFLb!+WM7/rO">
                      <value name="TEXT">
                        <shadow type="text">
                        <block type="text_join" id="8h9QE+{dve}o}{xFz4^/">
                          <value name="ADD0">
                            <block type="text" id="^^vC/IAZ$YnpMiFFn.nC">
                              <field name="TEXT">Watt:</field>
                          <value name="ADD1">
                            <block type="on_source" id="-bW!=3`GYzyDgu_1}k0G">
            <block type="on_ext" id=")3Y6O)OSZ6,a.eId9_([" disabled="true" x="-487" y="688">
              <value name="OID0">
                <shadow type="field_oid" id="FB}qA2j)SArn`ar=BQ8z">
                <block type="controls_if" id="nT8{B{T^As}6|P1eFdAp">
                    <block type="logic_compare" id="h=ll3)j0~lH*]vID@v{h">
                        <block type="get_value" id="prv]M@]WP)O8k`WxQv,M">
                          <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field>
                        <block type="math_number" id="QWMd~%R.#BvSN.-Jr7|S">
                    <block type="controls_if" id=";N~?jZO,:^+(B6c4+e.p">
                        <block type="logic_compare" id="nLGp=iM$L~IydiZi8!Z?">
                            <block type="get_value" id="#X;Nd8faxS1r?ibN,9Ur">
                            <block type="math_number" id="3L+Hx`ZZZ[6;bcStTgXv">
                        <block type="timeouts_cleartimeout" id="s_tu+G)JzfXKRo!,-i?j">
                          <field name="NAME">timeout3</field>
                        <block type="timeouts_settimeout" id="|y|12`S1gi{?f|+:!d87">
                            <block type="control" id="]:Q/hgD*3Ye$XrhiCKVK">
                                <block type="logic_boolean" id="]qeVb0?p3y!^dSP8T!{!">
                    <block type="debug" id="jv2kcn+O#/wer{(+o+DW">
                      <value name="TEXT">
                        <block type="text_join" id="FXin0|uc^i=Wm;0R-Jtj">
                          <value name="ADD0">
                            <block type="text" id="Z##h?{^2;N/L6AAv4~..">
                          <value name="ADD1">
                            <block type="on_source" id="t@LBx#Y!8Fv5({,pHM[,">
            @nole
            Das Blockly.
            Wurde auch etwas optimierte und wie man timeouts verwendet siehst ja. Es sollte immer ein stopp des timeouts davor erfolgen um sicher zu stellen, dass nicht genau dieser schon läuft, sonst passt die ein gestellte Zeit nie und man wundert sich, was exakt bei Dir zu Beginn der Grund Deiner Verwirrung war 😉
            • N
              @jan1 ich arbeite mich gerade gedanklich durch das Blockly, ich habe dank euch allen heute einiges wichtige dazu gelernt. Vielen Dank an euch alle. Wenn alles läuft erfahrt ihr das natürlich. Ich gehe dann jetzt in die Testphase über.
              • N
                @jan1 irgendwas stimmt noch nicht, ich weiß nur noch nicht was. Schaltet immer noch ohne erkennbaren Grund aus. Ich probiere den Fehler zu finden.
                  Homoran Global Moderator Administrators @nole last edited by
                  @nole sagte in Trockenlaufschutz, Problem mit Blockly:
                  warum nie als screenshot??
                  Am Handy nutzt der xml-Export rein gar nix
                  • N
                    nole @Homoran last edited by
                      Homoran Global Moderator Administrators @nole last edited by Homoran
                      und was steht dann im debug?
                      Hast du mal auf "geändert" getriggert und das Problem bleibt?
                      ich weiß nicht, ob der Sensor ggf. 2x hintereinander den selben Wert liefert
                      lass dir vielleicht zusätzlich noch den vorherigen Wert ausgeben
                      • N
                        @homoran Die Pumpe hat wenn sie kein Wasser hat, also im Trockenlauf vor der ich die Pumpe schützen will, zwischen 150 und 200 Watt Verbrauch. Im Pumpen mit Wasser über 300 Watt und natürlich wenn der Wasserdruck im Haus ok ist 0 Watt.
                        Wenn der Druck erreicht ist und die Pumpe abschaltet zeigt die Wattanzeige vom Sonoff PowR2 kurze Zeit noch ein paar Watt an ( Zwischen 4 und 50 Watt).
                        Homoran 3 Replies Last reply Reply Quote 0
                          @nole ich hatte noch was editiert:
                          @homoran sagte in Trockenlaufschutz, Problem mit Blockly:
                          • N
                            @homoran ich werde es nochmal mit "geändert" probieren.
                              und warum prüfst du nicht auf diesen Bereich, sondern auf >100 um die Pumpe anzuschalten?
                              • N
                                @homoran das ist das was ich bei dem Skript auch noch nicht verstehe
                                  Aber das ist doch dein Ansatz gewesen.
                                  Was genau hast du dir denn dabei gedacht?
                                  • N
                                    @homoran eigentlich müsste es doch gehen wenn ich oben Wert größer als 100 und kleiner als 200 prüfe und danach den timeout starten lasse und nach 30 Minuten ausschalten lasse. Den Rest müsste ich doch weglassen können, oder habe ich mich da jetzt total verannt?
                                      Was hast du denn genau vor?
                                      Welche Zustände mit welche Werten gibt es in welchen Situationen?
                                      Was willst du erreichen?
                                      Ich denke, du willst verhindern, dass die Pumpe trocken läuft.
                                      kann das auch passieren, dass die Pumpe anspringt ohne dass Wasser da ist?
                                      Oder nur, dass die Pumpe nicht ausgeht, nachdem sie gepumpt hat?
                                        also hast du im Prinzip nur drei Zustände:
                                        • aus = 0W (ok)
                                        • Trockenlauf = 150-200 (nicht ok)
                                        • aktiv pumpend > 300 W (ok)
                                        Habe ich das richtig verstanden?
                                        Gibt es für das Hauswasserwerk(???) noch eine weitere Steuerung (Wasserdruck???) oder ziehst du mit dem SonoffPOW der Pumpe den ganzen Strom einfach weg?
                                        Wenn letzteres, wie osll die dann jemals wieder anspringen?
                                        • BBTown
                                          BBTown @nole last edited by
                                          Ich kann nicht nachvollziehen weshalb Vorschläge nicht so übernommen werden wie sie zur Verfügung gestellt werden. Zudem schon früher hier im Thread von @Jan1 darauf hingewiesen wurde, dass anstelle von "aktualisieren" "geändert" gesetzt werden soll.
                                          N 1 Reply Last reply Reply Quote 1
                                          • N
                                            @homoran Die Pumpe startet sobald der Wasserdruck im Haus abfällt, also wenn Wasser entnommen wird. Wenn die Pumpe kein Wasser hat ist also zwangsläufig der Wasserdruck im Haus auch nicht da und die Pumpe läuft und läuft. Den Hitzetod der Pumpe möchte ich verhindern. Der Strom soll nur weggenommen werden wenn die Pumpe trocken läuft.
                                            6711
