    4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
      PhoenixCR @UncleSam last edited by
      @unclesam anbei
        "platform": "Govee",
        "name": "Govee",
        "apiKey": "Api",
        "model": "H6104",
        "controllable": true,
        "retrievable": true,
        "supportCmds": [
          "turn",
          "brightness",
          "color",
          "colorTem"
      beim API steht natürlich mein API
      UncleSam ? 2 Replies Last reply Reply Quote 0
      • UncleSam
        UncleSam Developer @PhoenixCR last edited by
        @phoenixcr Das ist der komplette Inhalt im Tab "Konfigurationsdatei"?
        Das wäre nämlich falsch: du musst jedes Gerät einzeln in Unterobjekte eintagen.
         "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
         "accessories": [
             "name": "MacBook",
             "services": [
               "increase-button",
               "decrease-button",
               "speaker",
               "lightbulb"
             "switchVolumeDelta": 5,
             "switchDelay": 10,
             "accessory": "ComputerSpeakers"
             "accessory": "SunPosition",
             "name": "Sun",
             "location": {
               "lat": 49,
               "long": 8
         "platforms": [
             "platform": "TadoAC",
             "username": "user@name.com",
             "password": "*************"
             "platform": "Ring",
             "refreshToken": "my-secret-token1"
             "platform": "WeatherPlus",
             "service": "openweathermap",
             "key": "YOUR_API_KEY",
             "locationId": 2950159,
             "locationCity": "Berlin, DE",
             "locationGeo": [
               52.5200066,
               13.404954
             "platform": "TuyaWebPlatform",
             "name": "TuyaWebPlatform",
             "options": {
               "platform": "form"
             "scenes": false
        Aber sonst leer doch einfach das Feld (also einfach {} rein schreiben) und verwende für alles den Tab. Das sollte auch gehen. Dort kannst du Module hinzufügen und entfernen und konfigurieren.
          A Former User @PhoenixCR last edited by
          @phoenixcr
          bei mir funktioniert das alle so in der Configdatei:
            "accessories": [],
            "platforms": [
                "name": "Govee",
                "lightDevices": [
                "apiKey": "blablablaapikey",
                "refreshTime": 30,
                "controlInterval": 500,
                "forceUpdates": true,
                "debug": true
                "name": "eWeLink",
                "mode": "auto",
                "platform": "eWeLink",
                "countryCode": "49",
                "username": "email",
                "password": "password"
                "platform": "yeelight",
                "name": "Yeelight"
          Wichtig war, sonst funktioniert Govee nicht, anschliessend in der HAM Config-Seite den Schraubenschlüssel aufzurufen und dort folgendes eintragen:
          so funktionierts hier auf jeden Fall.. 🙂
          P gelberlemmy 2 Replies Last reply Reply Quote 0
            @unclesam leider kriege ich nur ein gerät in Konfig rein
            bin ein Anfänger aber offen zum Lernen.
            Habe es nach deine Anleitung versucht allerdings der installiert kein Modul.
            Bleibt so hängen
            und im LOG keine neue Eintrag
              PhoenixCR @Guest last edited by
              @ilovegym genau das ist mein Problem, wenn ich der Schraubenschlüssel aufrufe, bleibt der Homebridge Tab hängen ...
                @phoenixcr dann stimmt ja irgendwas in der Konfig nicht. Logfile?
                  @ilovegym habe es nochmal versucht mit deine einstellungen ...
                  anbei der Log ...
                  ham.0	2021-05-12 09:45:19.362	info	(83738) All NPM Modules got reinstalled/updated ... restarting ...
                  ham.0	2021-05-12 09:45:19.343	info	Run `npm audit` for details.
                  ham.0	2021-05-12 09:45:19.343	info	a different dependency.
                  ham.0	2021-05-12 09:45:19.343	info	Some issues need review, and may require choosing
                  ham.0	2021-05-12 09:45:19.343	info	npm audit fix
                  ham.0	2021-05-12 09:45:19.343	info	To address issues that do not require attention, run:
                  ham.0	2021-05-12 09:45:19.343	info	5 high severity vulnerabilities
                  ham.0	2021-05-12 09:45:19.343	info	(83738)
                  ham.0	2021-05-12 09:45:19.301	info	run `npm fund` for details
                  ham.0	2021-05-12 09:45:19.301	info	(83738) 1 package is looking for funding
                  ham.0	2021-05-12 09:45:19.299	info	(83738)
                  ham.0	2021-05-12 09:45:19.297	info	up to date, audited 208 packages in 8s
                  ham.0	2021-05-12 09:45:19.297	info	(83738)
                  javascript.0	2021-05-12 09:45:19.082	info	(23009) script.js.Schrank.Server_Kühlung_PWM: PWM AUS
                  ham.0	2021-05-12 09:45:10.942	info	(83738) npm install homebridge-govee --production --loglevel error (System call)
                  ham.0	2021-05-12 09:45:10.940	info	(83738) Install/Update homebridge-govee
                  ham.0	2021-05-12 09:45:10.939	info	(83738) Install/Update the following Libraries: homebridge-govee
                  ham.0	2021-05-12 09:45:10.904	info	(83738) starting. Version 4.0.1 in /opt/iobroker/node_modules/iobroker.ham, node: v14.16.1, js-controller: 3.2.16
                  host.HomeAutomation	2021-05-12 09:45:09.695	info	instance system.adapter.ham.0 started with pid 83738
                  • UncleSam
                    UncleSam Developer last edited by
                    @PhoenixCR Jetzt gibt es glaube ich ein Durcheinander:
                    • zuerst muss die Konfiguration des Adapters stimmen oder leer sein (in den Instanz-Einstellungen, nicht im Tab)
                    • wenn die Konfiguration dort stimmt, sollte der Tab funktionieren
                    Welche Module willst du nun installieren (unten hattest du Govee und Homesung, nun hast du homesung-tv)?
                    Kannst du nochmals die gesamte Konfigurationsdatei aus der Instanz-Konfiguration zeigen (siehe unten)?
                      @unclesam
                      der ist leer,
                      aber über den Tab kann ich nicht der Homesung Modul installieren.
                        @phoenixcr sehe gerade, du verwendest V4.01, zieh dir mal die aktuelle 4.0.2 aus dem latest.. vielleicht hilft das.
                        Und mach anschliessend n upload, sicher ist sicher...
                          @ilovegym es gibt aber keine neuere Version ...
                          wie soll ich es updaten?
                            Ich habe es über terminal gemacht steht aber trotzdem 4.01 ...
                            ham.0	2021-05-13 05:02:46.349	info	(164338) No additional Libraries to install ...
                            ham.0	2021-05-13 05:02:46.314	info	(164338) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.16.1, js-controller: 3.2.16
                              @phoenixcr Moin, hast du danach n Upload gemacht?
                                @ilovegym Moin. Nein und leider weis ich auch nicht wie ...
                                Kannst du bitte es mir erklären?
                                Danke!
                                • BBTown
                                  BBTown @PhoenixCR last edited by
                                    PhoenixCR @BBTown last edited by
                                    @bbtown Super. Danke. Hat geklappt 😉
                                    • BBTown
                                      BBTown @PhoenixCR last edited by BBTown
                                      @phoenixcr also hast Du nun die 4.0.2.?
                                        PhoenixCR @BBTown last edited by PhoenixCR
                                        @bbtown ja hab ich ...
                                        Allerdings funzt jetzt die Samsung (homesung) Modul nicht mehr ...
                                        wenn ich es hier fragen darf, ist der Konfig richtig oder sieht ihr etwas das nicht stimmt?
                                        Bin kein pro ... aber lerne gern ...
                                          "accessories": [],
                                          "platforms": [
                                              "platform": "SamsungTV",
                                              "devices": [
                                                  "name": "[TV] Living room",
                                                  "ip": "192.168.1.110",
                                                  "identity": {
                                                    "sessionId": "1",
                                                    "aesKey": "0964262928ba5aecbadd51ec8e296088"
                                                  "power": {
                                                    "name": "Power TV",
                                                    "key": "KEY_POWEROFF",
                                                    "enableCEC": "false",
                                                    "switches": [
                                                        "name": "Vol Down 5",
                                                        "delay": 1000,
                                                        "command": "5*KEY_VOLDOWN"
                                                        "name": "Channel 12",
                                                        "command": [
                                                          "KEY_1",
                                                          "KEY_2"
                                                        "name": "Play with sound",
                                                        "command": [
                                                          "5*KEY_VOLDOWN",
                                                          "5*KEY_VOLUP"
                                                        "name": "Do something",
                                                        "command": {
                                                          "keys": "5*KEY_VOLDOWN",
                                                          "delay": 2000
                                                        "name": "Do more of something",
                                                        "command": {
                                                          "keys": [
                                                            "KEY_1",
                                                            "KEY_2"
                                                          "delay": 1000
                                                        "name": "Launch Netflix",
                                                        "command": [
                                                            "keys": "KEY_CONTENTS",
                                                            "delay": 2000
                                                            "keys": [
                                                              "3*KEY_LEFT",
                                                              "KEY_ENTER"
                                                            "delay": 1000
                                              "name": "Govee",
                                              "apiKey": "apikey",
                                              "refreshTime": 30,
                                              "debug": true,
                                              "platform": "Govee"
                                        • BBTown
                                          @phoenixcr
                                          Wenn sich das Gerät nicht geändert (neues Samsung Modell) und die Konfiguration zuvor funktioniert hat, dann würde ich als erstes prüfen ob denn der Fernseher auch tatsächlich immer unter der angegebenen IP erreichbar ist, oder ob der ggf. per DHCP immer wieder eine andere IP bekommt.
                                            @bbtown der IP ist fix, eigentlich hat sich nichts geändert und es hat funktioniert ...
                                            ich werde es noch probieren.
                                            Auf jeden Fall danke für eure Hilfe!
                                            238
                                            55928
