    4. [neuer Adapter] smartgarden adapter for Gardena smart system
    • JohGre
      JohGre last edited by JohGre
      Das Problem hat sich gelöst.
      Wahrscheinlich durch Admin 5.x mussten die Usercredential inkl. API-Key neu eingegeben und gespeichert werden, dann funktionierts wieder.
      @jpgorganizer Guten Morgen, habe seit heute 4:00 Uhr folgende Fehlermeldung im Log. Ist das ein Fehler auf Gardena Seite?
      SmartGarden 2.5.2
      Admin 5.0.18
      js-Controler: 3.3
      node: 12.22.1
      npm: 6.14.12
      smartgarden.0	2021-05-09 06:38:37.774	info	(4028) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
      smartgarden.0	2021-05-09 06:38:37.770	info	(4028) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
      smartgarden.0	2021-05-09 06:38:37.760	info	(4028) 3/ getConnection: trying to connect again in 300 seconds
      smartgarden.0	2021-05-09 06:38:37.759	info	(4028) 3/ getConnection: returned connection error: request returned 400 Bad Request
      smartgarden.0	2021-05-09 06:38:37.759	info	(4028) 3/ sgSetState: info.connection value=false ack=true
      smartgarden.0	2021-05-09 06:38:37.759	error	(4028) Error: request returned 400 Bad Request
      smartgarden.0	2021-05-09 06:38:37.758	info	(4028) 3/ Connection failure:..return with error
      smartgarden.0	2021-05-09 06:38:37.758	info	(4028) 3/ Connection failure.response.statusCode/Message=400/Bad Request
      smartgarden.0	2021-05-09 06:38:37.758	info	(4028) 3/ sgSetState: info.connection value=false ack=true
      smartgarden.0	2021-05-09 06:38:37.528	info	(4028) 3/ ---> State change by device: state smartgarden.0.info.revision changed: Main: 2466 / API: 2466 (ack = true)
      smartgarden.0	2021-05-09 06:38:37.525	info	(4028) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
      smartgarden.0	2021-05-09 06:38:37.523	info	(4028) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
      smartgarden.0	2021-05-09 06:38:37.517	info	(4028) 3/ sgSetState: info.revision value=Main: 2466 / API: 2466 ack=true
      smartgarden.0	2021-05-09 06:38:37.457	info	(4028) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
      smartgarden.0	2021-05-09 06:38:37.457	info	(4028) 3/ connecting to Gardena Smart System Service ...
      smartgarden.0	2021-05-09 06:38:37.456	info	(4028) 3/ sgSetState: info.connection value=false ack=true
      smartgarden.0	2021-05-09 06:38:37.453	info	(4028) 3/ connectToGardena...
      smartgarden.0	2021-05-09 06:38:37.452	info	(4028) 3/ getConnection...
      smartgarden.0	2021-05-09 06:38:37.319	info	(4028) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.22.1, js-controller: 3.3.8
      host.vm-iobroker	2021-05-09 06:38:36.242	info	instance system.adapter.smartgarden.0 started with pid 4028
      jpgorganizer 1 Reply Last reply Reply Quote 0
        Cosmicbase last edited by Cosmicbase
        @jpgorganizer
        Hast du die genauen Werte in Wort für die Bodenfeuchte zB. 55% = Feucht weiß ich.
        Die anderen Werte weiß ich nicht. 30,35,40, etc.
        Im Adapter stehen nur % Werte.
        Würde die gerne aber auch mit einer ChangeNode in Wort umändern.
        Danke für deine Hilfe.
        • jpgorganizer
          jpgorganizer @Cosmicbase last edited by
          @cosmicbase sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
          @jpgorganizer
          nein, gibt es nicht in der API - musst du dir selbst ausdenken.
          • jpgorganizer
            jpgorganizer @JohGre last edited by
            @johgre sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
            Ja, der Admin5 .... konnte ich bisher mir noch gar nicht ansehen, denn ich habe da noch ein ganz anderes Problem damit. Aber keine Sorge, das hat nichts mit diesem Adapter zu tun 🙂 Nur testen kann ich den Adapter nicht damit.
            Aber wenn du es einsetzt, die Config bearbeiten konntest, dann hört sich das ja gut an. Würde ich auch so erwarten.
            js-controller, nodejs 12/14/16 funktionieren auch. 🙂
            • jpgorganizer
              jpgorganizer @jpgorganizer last edited by
              Hallo allerseits,
              aufgrund der Weiterentwicklung von ioBroker waren mehr oder weniger kleine Änderungen am smartgarden Adapter erforderlich. Funktional ändert sich nichts.
              Bitte beachtet die Änderung der Datentypen der States (s. Release-Notes). Das kann je nachdem, wie ihr das weiterverarbeitet, für euch wichtig sein.
              Und eine Bitte: Wer schon auf js-controller 3.3.x umgestellt hat und noch Meldung ähnlich zur folgenden findet, der soll mir das bitte mit einem Log schreiben.
              State value to set for "smartgarden.0.LOCATION_....." has to be type "string" but received type "number" .
              Hier die Release-Notes:
              1.0.5
              • (jpgorganizer) 2021-May-13
                • necessary adjustments due to js-controller v3.3; e.g. Issue 29
                  • nearly all data points get deleted and created again with intended role/unit
                  • data types for following data points changed from string to number:
                    • for all devices: rfLinkLevel_value
                    • for mower: batteryLevel_value, operatingHours_value
                    • for sensor: batteryLevel_value, soilHumidity_value, soilTemperature_value, lightIntensity_value, ambientTemperature_value
                • compatibility test with node.js v14 and node.js v16 and added to Travis CI test;
                  compatibility test with the upcoming Admin 5 React UI;
                  e.g. Issue 30
                • new parameter beautify log in instance configuration; makes state ids a little bit shorter in log if switched on
              Bei Fragen fragen.
              Viel Spass weiterhin,
              jpgorganizer
                stevie77 @jpgorganizer last edited by
                @jpgorganizer Moin, bei mir ist 1.0.5 noch gar nicht verfügbar. Dauert das ne Weile, bis es dann irgendwann von alleine kommt? Bist du also nur früh dran mit deiner Veröffentlichung, oder mein System aus irgendeinem Grund spät? 😉
                Die Bitte mit der Meldung wegen falschem Datentyp im Log bezog sich auf nach dem Update auf 1.0.5, ne?
                • jpgorganizer
                  jpgorganizer @stevie77 last edited by jpgorganizer
                  @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                  im latest solltest du es finden, im stable werde ich es erst in ein paar Tagen aufnehmen lassen
                  ja natürlich, wenn es in der 1.0.5. auftritt. mit <=1.0.4 ist ja klar, sonst bräuchte ich kein Update dafür 🙂
                    Die Ventile haben den State state_value OK.
                    Was wäre das Gegenteil? state_value NOT_OK ?
                    Ich will den State in die VIS einbauen.
                    • jpgorganizer
                      https://github.com/jpgorganizer/ioBroker.smartgarden#data-points-of-the-adapter
                      "If you need more information about the data points please have a look at https://developer.husqvarnagroup.cloud/apis/GARDENA+smart+system+API#/swagger. There you'll find a description for every data point; except for those which are marked as data points of the adapter and not of the GARDENA smart system API."
                      Für dein state_value für ein valve findet man dort
                        Cosmicbase @jpgorganizer last edited by
                        @jpgorganizer
                        Vielen Dank
                          An alle die Bodenfeuchte in die VIS einbauen.
                          Hier die Tabelle von Gardena für den Smart Sensor 1/2.
                          Die Bodenfeuchte einach über eine Range und Change Node umändern.
                            lolax last edited by
                            in der Gardena App kann bei den Ventilen ja nicht einstellen, dass sie aus sein sollen wenn gemäht wird.
                            jetzt habe ich folgenden Objekt gefunden
                            irrigationWhileMowing_allowed_I
                            irrigationWhileMowing_mowerDefinition_i
                            irrigationWhileMowing_warningCode_i
                            Was hat es damit auf sich?
                            Mit freundlichen Grüßen
                            • jpgorganizer
                              jpgorganizer @lolax last edited by
                              @lolax
                              da sollte alles stehen was du wissen willst
                              https://github.com/jpgorganizer/ioBroker.smartgarden#irrigation-not-allowed-while-mowing
                                exmerci last edited by
                                Nehmt es mir nicht übel, bevor ich über 600 Beiträge durchlese, bei denen es dann fast ausschließlich um den Rasenmäher geht, nur eine kurze Frage. Kann ich mit einem der Adapter (Gardena oder Smartgarden) die Bewässerung auch steuern, oder nur die Zustände abfragen?
                                dslraser jpgorganizer 2 Replies Last reply Reply Quote 0
                                • dslraser
                                  dslraser Forum Testing Most Active @exmerci last edited by
                                  @exmerci sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                  Ja.
                                  Ich hatte beide Adapter, steuern geht mit beiden Adaptern. Ich nutze nur noch den Smartgarden Adapter.
                                  • jpgorganizer
                                    jpgorganizer @exmerci last edited by
                                    im README wirst du fündig: https://github.com/jpgorganizer/ioBroker.smartgarden
                                    Mit dem smartgarden Adapter kann man alle smart Geräte von Gardena steuern. Und zwar über die offiziell von Gardena supportete Schnittstelle.
                                      Also ich lasse den automatischen Part über die App machen und Zustände sowie manuelle Dinge mach ich über Adapter.
                                      Die Tiefbrunnenpumpe habe ich an einer Tasmota Steckdose dran. Somit wird die Pumpe nur dann eingeschaltet wenn das Ventil den Befehl gibt.
                                        deifel @Cosmicbase last edited by
                                        ich habe den Adapter erfolgreich mit einigen der Smart Sensoren und einer Water Control Pumpe am laufen - vielen Dank an dieser Stelle dafür.
                                        Kann es sein, dass ich für die Pumpe den Wasserzähler nicht über die Schnittstelle abrufen kann?
                                        In der Gardena App zeigt es mir den bisherigen Wasserverbrauch super an. Aber in den Objekten im Iobroker fehlt das leider bei der Pumpe.
                                        Danke für Eure Antwort und Grüße
                                        Frank
                                        • jpgorganizer
                                          jpgorganizer @deifel last edited by
                                          @deifel sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                          Pumpe oder Water Control ---- das sind doch zwei verschiedene Geräte, oder verwechsle ich da was?
                                          Es werden alle Daten im Adapter ausgegeben, die Gardena zur Verfügung stellt.
                                          ansonsten, siehe https://github.com/jpgorganizer/ioBroker.smartgarden#wishes-for-data-points
                                            deifel @jpgorganizer last edited by deifel
                                            @jpgorganizer
                                            Danke für Deine Antwort. Habe das Gardena smart Pressure Pump Set 5000 mit Gateway und das scheint schon mit Water-Control zu sein wie es dort heißt. Edit: Habe es jetzt verstanden... Water Control ist dort nicht die Ventilsteuerung gemeint... Also geht es mir rein um die Pumpe...
                                            So wie es aussieht werden aber wohl nicht alle Daten zur Verfügung gestellt - unter anderem der aktuelle Durchfluss, der Einschaltdruck und auch der Wasserzähler 😕 Wären für mich sehr interessante Parameter für Iobroker gewesen.
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            283302
