    4. zigbee shepherd.db Zugriffsproblem unter Windows
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Win 10, i5
      Arbeitsspeicher: 8GB
      Festplattenart: SSD 166GB, davon 108GB frei
      Betriebssystem: Windows 10
      Node-Version: 10.17.0
      Nodejs-Version: 10.17.0
      NPM-Version: 6.11.3
      Installationsart: Win Installer von @Stabilostick und manuell auf is-controller 3.2.16
      Image genutzt: Installer + manuelles update, workaround @AlCalzone
      Win Installer 2 Link
      |Zigbee-Adapter-Version:| 1.4.4 |
      Habe heute morgen bemerkt, daß ein Sensor, der alle 10 min updatet, eine AussetzerPeriode hatte. Andere Sensiren in diesem Zeitraum auch.
      Das log berichtet von einen Zugriffsproblem auf die shepherd.db
      Im Wesentlichen
      error: zigbee.1 (4920) uncaught exception: EPERM: operation not permitted, rename 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db.tmp' -> 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db'
      kopmlettes Log
      2021-05-14 06:09:11.047 - error: zigbee.1 (4920) uncaught exception: EPERM: operation not permitted, rename 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db.tmp' -> 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db'
      2021-05-14 06:09:11.052 - error: zigbee.1 (4920) Error: EPERM: operation not permitted, rename 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db.tmp' -> 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db'
      at Object.renameSync (fs.js:598:3)
      at Database.write (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\controller\database.js:67:22)
      at Database.update (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\controller\database.js:40:14)
      at Device.save (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\controller\model\device.js:216:35)
      at Controller.databaseSave (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\controller\controller.js:250:20)
      at Timeout.databaseSaveTimer.setInterval [as _onTimeout] (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\controller\controller.js:152:61)
      at ontimeout (timers.js:436:11)
      at tryOnTimeout (timers.js:300:5)
      at listOnTimeout (timers.js:263:5)
      at Timer.processTimers (timers.js:223:10)
      2021-05-14 06:09:11.052 - error: zigbee.1 (4920) Exception-Code: EPERM: EPERM: operation not permitted, rename 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db.tmp' -> 'C:\Program Files\iobroker\ioBrMain026\iobroker-data\zigbee_1\shepherd.db'
      2021-05-14 06:09:11.062 - info: zigbee.1 (4920) cleaned everything up...
      2021-05-14 06:09:11.063 - info: zigbee.1 (4920) Zigbee: disabling joining new devices.
      2021-05-14 06:09:11.578 - info: zigbee.1 (4920) terminating
      2021-05-14 06:09:11.585 - warn: zigbee.1 (4920) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-05-14 06:09:12.257 - error: host.DESKTOP-0UPK22M(ioBrMain2) instance system.adapter.zigbee.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-05-14 06:09:12.258 - info: host.DESKTOP-0UPK22M(ioBrMain2) Restart adapter system.adapter.zigbee.1 because enabled
      2021-05-14 06:09:42.291 - info: host.DESKTOP-0UPK22M(ioBrMain2) instance system.adapter.zigbee.1 started with pid 1020
      2021-05-14 06:09:54.727 - info: zigbee.1 (1020) starting. Version 1.4.4 in C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.zigbee, node: v10.17.0, js-controller: 3.2.16
      2021-05-14 06:09:55.439 - info: zigbee.1 (1020) Starting Zigbee npm ...
      2021-05-14 06:09:56.651 - info: zigbee.1 (1020) Installed Version: iobroker.zigbee@1.4.4
      2021-05-14 06:09:58.095 - info: zigbee.1 (1020) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210218}}
      2021-05-14 06:09:58.108 - info: zigbee.1 (1020) Unable to disable LED, unsupported function.
      2021-05-14 06:09:58.108 - info: zigbee.1 (1020) --> transmitPower : normal
      2021-05-14 06:09:58.120 - info: zigbee.1 (1020) Currently 47 devices are joined:
      Ich vermute mal ein Problem mit Zugriffsrechten.
      Ich habe solche Zugriffsmeldungen schon bei älteren Logfiles gesehen.
      Hat jemand einen Hinweis für eine Lösung oder wenigstens einen workaround wie z.B. Detektion des Fehlerzustandes und Neustarten des Adapters.
      Beim Log bleiben diese Zugriffsfehler folgenlos, beim Zigbee offensichtlich nicht. Und daran häng meine Lichtsteuerung...
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Installationsart: Skript/Manuell
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link Systemdata Bitte Ausfüllen
      NPM-Version: 6.11.3
      Im Wesentlichen
      kopmlettes Log
